127-0000-902
127-0000-902
    CINCH
    TOOL SMP CENTER CONTACT HOLDER
127-0000-902 数据手册
High Speed Miniature Product Catalog SMP3, SMPM and SMP belfuse.com/cinch About Bel Bel is a publicly traded company that has been operated by the same family for over 65 years. Our history of organic growth and acquisitions have broadened our product portfolio. This has established Bel as a world leader with a diverse offering of power, protection and interconnect products. We design and manufacture these products which are primarily used in the networking, telecommunications, computing, military, aerospace, transportation and broadcasting industries. Bel’s portfolio of products also finds application in the automotive, medical and consumer electronics markets. About JohnsonTM Johnson designs and manufactures an industry-leading line of RF coaxial connectors and adapters, available in both 50 and 75 Ohm versions, operating up to 67GHz. The range of products available within the product line includes board and cable mount connectors across subminiature, micro-miniature, ultra-miniature and millimeter wave classes as well as semi-rigid, conformable, and flexible RF coaxial cables. Johnson connectors are designed to provide the highest quality data transmission for data, audio, and video applications. Table of Contents SMP SMP3 Introduction 3 Introduction 19 Specifications 3 Specifications 20 Surface Mount Connectors 4 PCB Mount Connectors 24 Bullet Adapter 4 End Launch Connectors 25 SMP3 -1.85mm Between Series Adapters 5 Vertical Launch Connectors (Microstrip and Stripline) 25 SMP3 - 2.4mm Between Series Adapters 6 Flange Mount Connectors 26 SMP3 - 2.92mm Between Series Adapters 7 Hermetic Seal 27 0.047” Cable Connectors 27 0.086” Cable Connectors 27 Ganged Connectors 28 Ganged Edge Mount Connectors 30 Blind Mate Interconnect 33 Same Series Adapters 33 Between Series Adapters 34 Tools 34 Assembly Instructions 35 SMPM Introduction 8 Specifications 9 PCB Mount Connectors 11 End Launch Connectors 12 Vertical Launch Connectors (Microstrip and Stripline) 12 Flange Mount Connectors 13 0.047” Cable Connectors 13 0.086” Cable Connectors 14 Ganged Edge Mount Connectors 15 Blind Mate Interconnect 15 Between Series Adapters 17 Tools 18 2 SMP3 Introduction Cinch Connectivity Solutions introduces the new SMP3 family of connectors. SMP3 is the next generation of sub-miniature push-on style connectors. It follows the prior generation SMPM and SMP connectors. SMP3 is more miniaturized (approximately 30% smaller than SMPM) and operates to 67 GHz by design. It is ideal for applications where there is high shock and vibration. The design is similar to SMPM and SMP for its utilization of a floating bullet. This helps compensate for axial and radial misalignment when mating. This also helps maintain a high performance retention in rugged military applications. The sub-miniature, push-on connector interface is known for its blind mate capability. The smaller profile allows design engineers to fit the interconnects into dense packaging area. Specifications Environmental Specification Meets or exceeds the applicable paragraph of MIL-PRF-39012 Operating temperature -65°C to +165°C Thermal shock MIL-STD-202, Method 107, Condition B Corrosion/Salt Spray MIL-STD-202, Method 101, Condition B Vibration MIL-STD-202, Method 204, Condition D Mechanical Shock MIL-STD-202, Method 213, Condition I Moisture resistance MIL-STD-202, Method 106 (except step 7b omitted) Mechanical Specification Interface Design: MIL-STD-348A, Series SMP3 Full detent (FD) 2.5 Full detent (FD) 4.5 Mated Radial Misaligment Between centerlines of mating planes 0.010” Mated Axial Misalignment Between mating planes Durability Full detent (all connectors and adapters) Engagement Force (pounds maximum, mated pair) Disengagement Force (pounds minimum, mated pair) 100 (mating cycles minimum) Mounting Holes Figure 1 Figure 2 Figure 3 3 SMP3 Surface Mount Connectors Part Number Description Interface Interface VSWR Frequency Range 123-0701-801 End Launch Male Full Detent 50 Ohms 1.5 Max DC - 50 GHz 123-0701-811 End Launch Male 2 port Full Detent 50 Ohms 1.5 Max DC - 67 GHz 123-0701-201 Vertical Surface Mount Full Detent 50 Ohms 1.4 Max DC - 50 GHz Bullet Adapter Female to Female Bullet Adapter 4 Part Number Material Impedance VSWR Frequency Range 123-0901-801 Gold-Plated 50 Ohms 1.4 Max DC - 67 GHz SMP3 SMP3 -1.85mm Between Series Adapters 1.85mm Male to SMP3 Male Part Number Material Impedance VSWR Frequency Range 134-1000-032 Passivated 50 Ohms 1.30 Max DC - 67 GHz 1.85mm Male to SMP3 Female Part Number Material Impedance VSWR Frequency Range 134-1000-033 Gold-Plated 50 Ohms 1.30 Max DC - 67 GHz 1.85mm Female to SMP3 Male Part Number Material Impedance VSWR Frequency Range 134-1000-034 Passivated 50 Ohms 1.30 Max DC - 67 GHz 1.85mm Female to SMP3 Female Part Number Material Impedance VSWR Frequency Range 134-1000-035 Gold-Plated 50 Ohms 1.30 Max DC - 67 GHz 5 SMP3 SMP3 - 2.4mm Between Series Adapters 2.4mm Male to SMP3 Male Part Number Material Impedance VSWR Frequency Range 134-1000-036 Passivated 50 Ohms 1.25 Max DC - 50 GHz 2.4mm Male to SMP3 Female Part Number Material Impedance VSWR Frequency Range 134-1000-037 Gold-Plated 50 Ohms 1.25 Max DC - 50 GHz 2.4mm Female to SMP3 Male Part Number Material Impedance VSWR Frequency Range 134-1000-038 Passivated 50 Ohms 1.25 Max DC - 50 GHz 2.4mm Female to SMP3 Female Part Number Material Impedance VSWR Frequency Range 134-1000-039 Gold-Plated 50 Ohms 1.25 Max DC - 50 GHz 6 SMP3 SMP3 - 2.92mm Between Series Adapters 2.92mm Male to SMP3 Male Part Number Material Impedance VSWR Frequency Range 134-1000-040 Passivated 50 Ohms 1.25 Max DC - 40 GHz 2.92mm Male to SMP3 Female Part Number Material Impedance VSWR Frequency Range 134-1000-041 Gold-Plated 50 Ohms 1.25 Max DC - 40 GHz 2.92mm Female to SMP3 Male Part Number Material Impedance VSWR Frequency Range 134-1000-042 Passivated 50 Ohms 1.25 Max DC - 40 GHz 2.92mm Female to SMP3 Female Part Number Material Impedance VSWR Frequency Range 134-1000-043 Gold-Plated 50 Ohms 1.25 Max DC - 40 GHz 7 SMPM Introduction Cinch Connectivity Solutions offers the Johnson line of SMPM connectors. The sub-miniature, push-on style micro interfaces are distinguished for blind mating and for their size (about 35% smaller than the SMP design) and becoming increasingly popular for the two-fold design benefit of allowing for a higher-density of connection points and maintaining solid Return Loss performance from DC-level frequencies up to 65 GHz. The Johnson SMPM family includes PC mount, End Launch and Vertical Launch styles, and straight and right-angled, 0.047” and 0.086” cabled connectors and sealable flange mounts. All male connectors are offered in both full detent or smooth bore designs to meet your preference of engagement / disengagement forces. Detent features are provided to retain the push-on connectors in mated condition. Different levels of engage and disengage forces are accomplished by various Detent offerings in the shroud housing. The SMPM bullet adapter provides the same coveted blind mate functionality as the larger SMP size connectors, mitigating axial and radial misalignment with negligible change to VSWR and other signal losses. The SMPM-series is perfect for use in test equipment, instrumentation, phased array radar and MIMO and active antenna applications. Key Features & Benefits • 35% smaller than SMP connectors • DC-65GHz • Bullet adapter provides blind mate capabilities • Excellent electrical performance with axial and radial misalignment • Available in PC mount, end launch and cabled styles Estimated spacing between two mated boards connected via PC mount and bullet adapters 8 SMPM Specifications The Johnson SMPM Connector Family provides an excellent solution for demanding applications requiring high frequency transmission. • • • • Precision manufacturing allows superior electrical performance of 1.15 to 18 GHz, 1.25 to 40 GHz and 1.45 to 65 GHz. Connector mating interface per MIL-STD-348A Mating interface control provides consistent electrical performance. Available in end launch, board mount, flange mount, vertical launch, cabled connector and bullet adapter/ between series adapter styles Electrical Specification Impedance 50 ohms Frequency Range: Bullet adapter, semi-rigid straight cabled connectors VSWR: (maximum) Bullet adapter: 0-18 GHz 1.15 18-40 GHz 1.25 40-65 GHz 1.45 Connectors: 0-20 GHz 1.20 20-26.5 GHz 1.25 26.5-40 GHz 1.30 0-40 GHz All other in-series adapters and connectors 0-18 GHz Note: See drawing for additional specifications Insertion Loss: (dB maximum, tested at 10GHz) Adapters and connectors Working Voltage: 335 Vrms maximum at sea level, 65 Vrms maximum at 70,000 feet Dielectric Withstanding Voltage: 500 Vrms minimum at sea level RF High Potential Withstanding Voltage: 325 Vrms minimum at sea level, tested at 4 and 7MHz Corona Level: 190 Vrms minimum at 70,000 feet Contact Resistance: (milliohms maximum initial, not applicable after environmental testing) Inner conductor 6.0 Outer conductor 2.0 Insulation Resistance: 5000 megohms minimum RF Leakage: Adapters and connectors 0.10 √ F (GHz) -80 9 SMPM Mechanical Specification Interface Design: MIL-STD-348A, Series SMPM Engagement Force (pounds maximum, mated pair) Disengagement Force (pounds minimum, mated pair) Mated Radial Misaligment (inches maximum allowed) Full detent (FD) 15.0 Limited detent (LD) 10.0 Smooth bore and catcher’s mitt (SB and CM) 2.0 Full detent (FD) 5.0 Limited detent (LD) 2.0 Smooth bore and catcher’s mitt (SB and CM) 0.5 Between centerlines of mating planes (FD,LD, SB) 0.010” Between centerlines of mating planes (CM only) 0.020” Mated Axial Misalignment 010 inches maximum allowed between mating planes (female adapters only) Durability Full detent (all connectors and adapters) 100 Limited detent 500 Smooth bore and catcher’s mitt 1000 (mating cycles minimum) Contact Retention 1.5 pounds minimum axial force (captivated contact) Axial Force* (lbs) Torque (in-oz) Cabled connectors for RG-405 (0.086 semi-rigid) 30 16.0 Cabled connectors for M17/151 (0.047 semi-rigid) 20 N/A Cable Retention: (minimum) *Or cable breaking strength, whichever is less Environmental Specification Meets or exceeds the applicable paragraph of MIL-PRF-39012 Operating temperature -65°C to +165°C Thermal shock MIL-STD-202, Method 107, Condition B (except high temp +165°C or max high temp of cable) Corrosion MIL-STD-202, Method 101, Condition B Vibration MIL-STD-202, Method 204, Condition D Shock (specified pulse) MIL-STD-202, Method 213, Condition I Moisture resistance MIL-STD-202, Method 106 (except step 7b) Mechanical Specification Bodies: 348A, Series SMP Beryllium copper per ASTM B196, gold* plated per MIL-DTL-45204 (0.00005” min) Hermetic seal bodies (male) Kovar alloy per ASTM F15, gold* plated per MIL-DTL-45204 (0.00005” min) All other shroud bodies (male) Stainless steel, type 303, per ASTM A582, passivated per MIL-DTL-14072 (EL 300) Connector and adapter contacts (male and female) Beryllium copper per ASTM B196, gold* plated per MIL-DTL-45204 (0.00005” min) Hermetic seal center pins Kovar alloy per ASTM F15, gold* plated per MIL-DTL-45204 (0.00005” min) EMI/anti-rock rings Beryllium copper per ASTM B196, gold* plated per MIL-DTL-45204 (0.00003” min) PC mount legs Brass per ASTM B16, gold* plated per MIL-DTL-45204 (0.00003” min) Connector and adapter insulators Brass per ASTM B16, gold* plated per MIL-DTL-45204 (0.00003” min) Hermetic seal glass Corning 7070 *All gold plated parts include a 0.00005” minimum nickel barrier layer 10 SMPM PCB Mount Connectors Straight PC mount, female Part Number Material VSWR Frequency Range 125-0801-201 Gold Plated Dependent on application 0 - 40 GHz Straight PC mount male Part Number Material Interface VSWR Frequency Range 125-0701-201 Gold Plated Full Detent Dependent on application 0 - 40 GHz 125-2701-201 Gold Plated Smooth Bore Dependent on application 0 - 40 GHz Straight PC Mount, male, 0.150” height (Low Profile) Part Number Material Interface VSWR Frequency Range 125-0701-211 Gold Plated Full Detent Dependent on application 0 - 20 GHz Straight PC Mount, male, 0.113” height (Super Low Profile) Part Number Material Interface VSWR Frequency Range 125-0701-221 Gold Plated Full Detent Dependent on application 0 - 20 GHz 11 SMPM End Launch Connectors End Launch Male Part Number Material Interface VSWR Frequency Range 125-0701-801 Gold Plated Full Detent Dependent on application 0 - 40 GHz 125-2701-801 Gold Plated Smooth Bore Dependent on application 0 - 40 GHz Vertical Launch Connectors SMPM Compression Connector, Microstrip Part Number Material Impedance VSWR Frequency Range 125-0701-241 Gold-Plated 50 Ohms 1.4 Typical from DC - 50 GHz DC - 65 GHz SMPM Compression Connector, Stripline Part Number Material Impedance Maximum Frequency VSWR 125-0701-251 Gold-Plated 50 Ohms DC - 65 GHz 1.4 Typical from DC - 50 GHz 12 SMPM Flange Mount Connectors 2-hole flange mount male shroud, full detent Part Number Material Interface Frequency Range 125-0701-602 Gold Plated Full Detent DC - 40 GHz 125-2701-602 Gold Plated Smooth Bore DC - 40 GHz 0.047” Cable Connectors Straight male for 0.047” semi-rigid cable Part Number Material Interface VSWR Frequency Range 125-0592-001 Gold Plated Full Detent 1.15 Max to 26.5 GHz 1.30 Max to 40 GHz DC - 40 GHz 125-2592-001 Gold Plated Smooth Bore 1.15 Max to 26.5 GHz 1.30 Max to 40 GHz DC - 40 GHz Straight female for 0.047” cable Part Number Material VSWR Frequency Range 125-0692-001 Gold Plated 1.15 to 26.5 GHz 1.30 to 40 GHz DC - 40 GHz 13 SMPM Low profile right-angled female for 0.047” cable, full detent Part Number Material VSWR 125-0692-111 Gold Plated ①          ② Frequency Range ③        ④       1.10 to 10 GHz   1.25 to 20 GHz  数字签名人 Lin Ma DN:cn=Lin Ma, c=CN,o=Cinch Connectivity Solutions (Shanghai) Co. Ltd, email=lin.ma@cn.cinch. com 日期:2016.06.28 12:52:31 +08'00'      DC - 20 GHz                              ~ ,                       0.086” Cable Connectors , , ℃ , ℃ , ,        , ,            ,                                Straight male for 0.086” semi-rigid cable, full detent Part Number 125-0593-001 Material PART NUMBER 125-0901-811 Gold Plated ITEM 1 BODY ITEM 2 CONTACT BERYLLIUM COPPER GOLD PL .00005 MIN OVER NICKEL PL.00005 MIN OVER COPPER PL.00005 MIN BERYLLIUM COPPER GOLD PL .00005 MIN OVER NICKEL PL.00005 MIN OVER COPPER PL.00005 MIN VSWR Frequency Range ITEM 3 INSULATOR TEFLON 1.15 Max 1.25 Max 1.45 Max REV 1 ECO ECO-16-0019 DATE 2/23/2016 18 GHz 40 GHz 65 GHz .210 REF 2X SMPM FEMALE INTERFACE PER MIL-STD-348B ACCEPTS .011~.013 PIN  .108 2 1 3 SPECIFICATION: IMPEDANCE: 50 OHMS FREQUENCY RANGE: 0-65 GHz VSWR: 1.15 MAX TO 18GHz, 1.25 MAX TO 40GHz and 1.45 MAX TO 65GHz INSERTION LOSS: 0.10 F dB MAX (F IN GHz) WORKING VOLTAGE: 325 VRMS MAX AT SEA LEVEL DIELECTRIC WITHSTANDING VOLTAGE: 325 VRMS MIN AT SEA LEVEL INSULATION RESISTANCE: 5000 MEGOHM MIN CONTACT RESISTANCE: CENTER CONTACT - INITIAL 6 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE OUTER CONDUCTOR - INITIAL 2 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE RF LEAKAGE: -65dB TYPICAL AT 3GHz Right angle male for 0.086” semi-rigid cable, full detent Part Number Material 125-0593-101 Gold Plated MECHANICAL: VSWR Frequency Range 1.10 to 10 GHz 1.25 to 20 GHz DC - 40 GHz ENGAGEMENT FORCE: FULL DETENT(FD) 4.5LBS TYPICAL; SMOOTH BORE(SB) 2.5LBS TYPICAL DISENGAGEMENT FORCE: FD 6.5LBS TYPICAL; SB 1.5LBS TYPICAL CONTACT RETENTION: 1.5 LBS MIN AXIAL FORCE MISALIGNMENT: RADIAL +/- .010 AXIAL .010 (FLUSH TO .010 FROM THE REFERENCE PLANE) DURABILITY: FD 100 CYCLES MIN; SB 500 CYCLES MIN ENVIRONMENTAL: OPERATING TEMPERATUR: -65 TO 165°C THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B MECHANICAL SHOCK: MIL-STD-202, METHOD 213, CONDITION I CORROSION: MIL-STD-202, METHOD 101 VIBRATION: MIL-STD-202, METHOD 204 MOISTURE RESISTANCE: MIL-STD-202, MEHTOD 106, EXCEPT STEP 7B  SEE NOTE This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. 14  SEE NOTE   RoHS2 2011/65/EU  UNLESS OTHERWISE SPECIFIED UNITS: INCH .XX .01 .XXX .003 .XXXX .0010 ANGLES 100'   SMPM BULLET ADAPTER .210 LENGTH    125-0901-811 R.SHEN  2/23/16  C DO NOT SCALE DRAWING 1 Sheet 1 of 1 SMPM Ganged Edge Mount Connectors Male, Full Detent, PCB Edge Mount Part Number No. of Ports Interface VSWR Frequency Range 125-0701-821 2 Full Detent 1.15 Max 0 - 65 GHz Male, Full Detent, PCB Edge Mount Part Number No. of Ports Interface VSWR Frequency Range 125-0701-831 4 Full Detent 1.15 Max 0 - 65 GHz 15 SMPM Male, Smooth Bore, PCB Edge Mount Part Number No. of Ports Interface VSWR Frequency Range 125-2701-811 2 Smooth Bore 1.15 Max 0 - 65 GHz Male, Smooth Bore, PCB Edge Mount Part Number No. of Ports Interface VSWR Frequency Range 125-2701-821 4 Smooth Bore 1.15 Max 0 - 65 GHz 16 SMPM Blind Mate Interconnect Bullet adapter, 0.210” Length Part Number 125-0901-811 Material Gold Plated PART NUMBER 125-0901-811 VSWR ITEM 1 BODY ITEM 2 CONTACT BERYLLIUM COPPER GOLD PL .00005 MIN OVER NICKEL PL.00005 MIN OVER COPPER PL.00005 MIN BERYLLIUM COPPER GOLD PL .00005 MIN OVER NICKEL PL.00005 MIN OVER COPPER PL.00005 MIN Frequency Range ITEM 3 INSULATOR REV 1 ECO ECO-16-0 TEFLON 1.15 Max 1.25 Max 1.45 Max DC – 18 GHz 18 – 40 GHz 40 – 65 GHz .210 REF 2X SMPM FEMALE INTERFACE PER MIL-STD-348B ACCEPTS .011~.013 PIN  .108 2 1 Bullet adapter, 0.265” Length 3 SPECIFICATION: Part Number Material 125-0901-801 Gold Plated VSWR Frequency Range 1.15 Max 1.25 Max 1.45 Max DC – 18 GHz 18 – 40 GHz 40 – 65 GHz IMPEDANCE: 50 OHMS FREQUENCY RANGE: 0-65 GHz VSWR: 1.15 MAX TO 18GHz, 1.25 MAX TO 40GHz and 1.45 MAX TO 65GHz INSERTION LOSS: 0.10 F dB MAX (F IN GHz) WORKING VOLTAGE: 325 VRMS MAX AT SEA LEVEL DIELECTRIC WITHSTANDING VOLTAGE: 325 VRMS MIN AT SEA LEVEL INSULATION RESISTANCE: 5000 MEGOHM MIN CONTACT RESISTANCE: CENTER CONTACT - INITIAL 6 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE OUTER CONDUCTOR - INITIAL 2 MILLIOHM MAX, AFTER ENVIRONMENTAL NOT APPLICABLE RF LEAKAGE: -65dB TYPICAL AT 3GHz MECHANICAL: ENGAGEMENT FORCE: FULL DETENT(FD) 4.5LBS TYPICAL; SMOOTH BORE(SB) 2.5LBS TYPICAL DISENGAGEMENT FORCE: FD 6.5LBS TYPICAL; SB 1.5LBS TYPICAL CONTACT RETENTION: 1.5 LBS MIN AXIAL FORCE MISALIGNMENT: RADIAL +/- .010 AXIAL .010 (FLUSH TO .010 FROM THE REFERENCE PLANE) DURABILITY: FD 100 CYCLES MIN; SB 500 CYCLES MIN ENVIRONMENTAL: OPERATING TEMPERATUR: -65 TO 165°C THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B MECHANICAL SHOCK: MIL-STD-202, METHOD 213, CONDITION I CORROSION: MIL-STD-202, METHOD 101 VIBRATION: MIL-STD-202, METHOD 204 MOISTURE RESISTANCE: MIL-STD-202, MEHTOD 106, EXCEPT STEP 7B  SEE NOTE This PROPRIETARY Document is property of Cinch Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. Between Series Adapters INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009.  SEE NOTE  UNLESS OTHERWISE SPECIFIED UNITS: INCH .XX .01 .XXX .003 .XXXX .0010 ANGLES 100' SMA-SMPM Adapters Part Number Interface VSWR Frequency 134-1001-001 SMA Plug to SMPM Plug 1.20 Max 1.25 Max DC - 20 GHz 20 - 26.5 GHz 134-1001-002 SMA Plug to SMPM Jack 1.20 Max 1.25 Max DC - 20 GHz 20 - 26.5 GHz Part Number Interface VSWR Frequency 134-1001-003 SMA Jack to SMPM Jack 1.20 Max 1.25 Max DC - 20 GHz 20 - 26.5 GHz 134-1001-004 SMA Jack to SMPM Plug 1.20 Max 1.25 Max DC - 20 GHz 20 - 26.5 GHz  RoHS2 2011/65/EU  17   SMPM BULLET AD .210 LENGTH   125-0901- R.SHEN  2/23/16  C DO NOT SCALE DRAWING SMPM Tools SMPM extraction tool for cabled connectors Part Number Material 125-0000-900 Gold Plated SMPM bullet adapter installation/extraction tool Part Number Material 125-0000-901 Gold Plated SMPM bullet extraction removal tool NOTES: Part Number 125-0000-906 1. MATERIAL: STAINLESS STEEL , TYPE 304, PER QQ-S-764. 2. FINISH: PASSIVATED. 3. SHARP EDGES: NO SHARP EDGES ALLOWED. 0.005 X 45 ° Max. NOTES: 4. PACKAGE: ONE PIECE PER BAG. 1. MATERIAL: STAINLESS STEEL , TYPE 304, PER QQ-S-764. 2. FINISH: PASSIVATED. 3. SHARP EDGES: NO SHARP EDGES ALLOWED. 0.005 X 45 ° Max. REV ECO 1 INITIAL RELEASE DATE REV ECO 1 INITIAL RELEASE 13AUG2020 DATE 13AUG2020 Material Gold Plated 0.43 4. PACKAGE: ONE PIECE PER BAG. 0.43 4.85 REF 0.05 0.05 4.85 REF JOHNSON Model No: Cage Code Title: SMPM REMOVAL TOOL T his PROP RI ET ARY Document is property of Cinch Connectivity S olutions .I t is confidential in nature, non- transferable, and is s ued with the clear understanding that it is not traced or copied without permis s ion and is returnable upon demand. INTERPRET DRAWING IN ACC ORDANC E WITH ASME Y14.5-2009. 3RD ANGLE PROJECTION U NLES S OT HERW IS E SPECIFIED U NIT S: INCH .X ±.1 .XX ±.01 ANGLES ±2° Drawing No. Drawn by: Bill Peng Model No: Date: 08/13/2020 Cage Code Size Title: B property of Cinch Connectivity S olutions .I t is confidential in nature, non- transferable, and is s ued with the clear traced or copied without permis s ion and is returnable upon demand. INTERPRET DRAWING IN ACC ORDANC E WITH ASME Y14.5-2009. 18 3RD ANGLE PROJECTION U NLES S OT HERW IS E SPECIFIED U NIT S: INCH .X ±.1 .XX ±.01 ANGLES ±2° Drawing No. Drawn by: Bill Peng Date: 08/13/2020 Size REV. JOHNSON 1 NONE W or kmanship Std: Sheet DRAWING 1 OF 1 SMPM REMOVAL TOOL T his PROP RI ET ARY Document is understanding that it is not 125-0000-906 DO NOT SCALE B REV. 125-0000-906 DO NOT SCALE DRAWING W or kmanship Std: NONE 1 Sheet 1 OF 1 SMP Introduction Cinch Connectivity Solutions offers the Johnson line of industry standard SMP connectors. The sub-miniature, push-on connector interface is known for its micro miniature size and its blind mate capability. The smaller profile allows design engineers to fit the interconnects into dense packaging area. Blind mate means to accommodate for an up to 9 degree axial and radial misalignment with minimal impact on VSWR performance. This makes it ideal for application with shock and vibration. SMP has intermate compatibility with the Corning Gilbert GPO and other industry SMP connectors. The SMP family offers connectors in various form factors including: End Launch, PC mount thru hole and surface mount, Vertical Launch (solderless compression mount), 2 hole flange, 4 hole flange, Ganged 2 port and 4 port in Vertical, Right Angle and Edge Launch, Straight and Right Angle cabled connectors for 0.086” and 0.047” cable types. The female-female bullet adapter is available in different lengths. Johnson offers shroud types: Full Detent, Limited Detent, Smooth Bore, and Catcher’s Mitt. The family additionally provides between series adapters SMA-SMP, SMP-SMPM, 2.92mm-SMP, 2.4mm-SMP. SMP connectors exhibit excellent return loss performance at frequencies from DC to 40 GHz. The design of the SMP bullet and shroud system allows for both axial and radial misalignment. The basic system is comprised of an inner “bullet” adapter, and two outer receptacles called “shrouds”. The bullet provides a flexible link between the shroud connections. In blind-mate applications, one shroud connector will be typically specified as a snap-on interface and the other as a slide-on. This ensures that the bullet adapter remains fixed in the same shroud connector when the connection is disengaged. The two snap-on interfaces Full Detent (FD) and Limited Detent (LD) each have different engage and disengage coupling forces. The LD is typically selected as the snap-on interface in PCB mount or blind-mate applications, while the FD is mainly used for cabled connections where higher retention forces are required. The two slide-on interfaces Smooth Bore (SB) and Catcher’s Mitt (CM) allow for reduced connection forces as compared to the snap-on versions. The push-on interface creates a sliding connection that does not physically locate the mating reference planes, allowing for axial and radial misalignment. Both the SB and CM have the same engage/disengage forces; however the CM is typically specified as the shroud configuration in blind-mate applications as its generous lead-in chamfer helps capture and guide the bullet into place. Radial Misalignment Axial Misalignment Bullet Length Shroud 19 SMP Specifications The Johnson SMP Connector Family provides an excellent solution for demanding applications requiring high frequency transmission. • • • • Precision manufacturing allows superior electrical performance > 40 GHz with VSWR performance to < 1.70 Max Connector mating interface per MIL-STD-348A Mating interface control provides consistent electrical performance. Available in end launch, board mount, flange mount, vertical launch, cabled connector and bullet adapter/ between series adapter styles Electrical Specification Impedance 50 ohms Frequency Range: Bullet adapter, semi-rigid straight cabled connectors VSWR: (maximum) Bullet adapter: 0-18 GHz 1.10 18-26.5 GHz 1.30 26.5-40 GHz 1.70 Connectors: 0-18 GHz 1.20 18-26.5 GHz 1.35 26.5-40 GHz 1.70 0-40 GHz All other in-series adapters and connectors 0-18 GHz Note: See drawing for additional specifications Insertion Loss: (dB maximum, tested at 10GHz) Adapters and connectors Working Voltage: 335 Vrms maximum at sea level, 65 Vrms maximum at 70,000 feet Dielectric Withstanding Voltage: 500 Vrms minimum at sea level RF High Potential Withstanding Voltage: 325 Vrms minimum at sea level, tested at 4 and 7MHz Corona Level: 190 Vrms minimum at 70,000 feet Contact Resistance: (milliohms maximum initial, not applicable after environmental testing) Inner conductor 6.0 Outer conductor 2.0 Insulation Resistance: 5000 megohms minimum RF Leakage: Adapters and connectors 20 0.10 √ F (GHz) -80 SMP Connectivity for SMP Connectors Mechanical Specification Business-Critical Continuity Specifications Interface Design: MIL-STD-348A, Series SMP Engagement Force (pounds maximum, mated pair) Disengagement Force Full detent (FD) 15.0 Limited detent (LD) 10.0 Smooth bore and catcher’s mitt (SB and CM) 2.0 Full detent (FD) 5.0 Limited detent (LD) 2.0 MECHANICAL SPECIFICATIONS (pounds minimum, mated pair) Interface Design: MIL-STD-348A, SmoothSeries boreSMP and catcher’s mitt (SB and CM) 0.5 Between centerlines of mating planes (FD,LD, SB) Mated Radial Misaligment Engagement Force: (pounds maximum, mated pair) (inches maximum allowed) 0.010” Full Detent (FD) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15.0 Limited Detent (LD) Between . . . . . . . . . . centerlines . . . . . . . . . . . . . of . . . mating . . . . . . . . .planes . . . . . . . .(CM . . . . .only) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.0 Smooth Bore and Catcher’s Mit (SM and CM) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.0 Mated Axial Misalignment 010 inches maximum allowed between mating planes (female adapters only) Disengagement Force: (pounds minimum, mated pair) Durability Full Detent (FD) . . . .Full . . . . detent . . . . . . . . (all . . . .connectors . . . . . . . . . . . . . and . . . . . adapters) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.0 (mating cycles minimum) Limited Detent (LD) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.0 Limited detent Smooth Bore and Catcher’s Mit (SM and CM) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.5 Smooth bore and catcher’s mitt Contact Retention Mated Radial Misalignment: (inches maximum allowed, female adapters only) Between Centerlines1.5 of Mating Planes (FD, LD, SM) . . . force . . . . . . .(captivated . . . . . . . . . . . . .contact) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .010 pounds minimum axial Between Centerlines of Mating Planes (CM only) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .020 Cable Retention: Mated Axial Misalignment: .010 inches maximum allowed between mating planes (female adapters only) Axial Force* (lbs) (minimum) 0.020” Cabled connectors for RG-405 (0.086 semi-rigid) 30 Durability: (mating cycles minimum) Full Detent (all femaleCabled connectors and adapters) . . . . . . . . . . .(0.047 . . . . . . . .semi-rigid) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .20 . . . 100 connectors for. M17/151 Limited Detent (female adapters only) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 500 *Or cable breaking strength, whichever is less Smooth Bore and Catcher’s Mit (female adapters only) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1000 100 500 1000 Torque (in-oz) 16.0 N/A Contact Retention: 1.5 pounds minimum axial force (captivated contacts only) Cable Retention: (minimum) Axial Force* (lbs) Cabled Connectors for RG-405 (.086 Semi-Rigid) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 Cabled Connectors for M17/151 (.047 Semi-Rigid) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Typical Measured Return Loss Bullet Adapter 127-0901-801 Torque (in-oz) 16.0 N/A *Or cable breaking strength, whichever is less Typical Measured Return Loss Bullet Adapter 127-0901-801 127-0901-801 VSWR = 1.10 (0-18GHz), 1.15 (18-23GHz), 1.30 (23-26.5GHz), 1.70 (26.5-40GHz) 127-0801-901 VSWR = 1.10 (0-18 GHz), 1.15 (18-23 GHz), 1.30 (23-26.5 GHz), 1.70 (26.5-40 GHz) 0 -10 S11 (dB) S11(dB) -20 -30 -40 -40 -50 -50 -60 -60 00 5 10 10 15 15 20 25 30 30 35 35 40 Frequency (GHz) Frequency (GHz) 6 21 SMP Environmental Specification Meets or exceeds the applicable paragraph of MIL-PRF-39012 Operating temperature -65°C to +165°C Thermal shock MIL-STD-202, Method 107, Condition B (except high temp +165°C or max high temp of cable) Corrosion MIL-STD-202, Method 101, Condition B Vibration MIL-STD-202, Method 204, Condition D Shock (specified pulse) MIL-STD-202, Method 213, Condition I Moisture resistance MIL-STD-202, Method 106 (except step 7b) Mechanical Specification Bodies: 348A, Series SMP Beryllium copper per ASTM B196, gold* plated per MIL-DTL-45204 (0.00005” min) Hermetic seal bodies (male) Kovar alloy per ASTM F15, gold* plated per MIL-DTL-45204 (0.00005” min) All other shroud bodies (male) Stainless steel, type 303, per ASTM A582, passivated per MIL-DTL-14072 (EL 300) Connector and adapter contacts (male and female) Beryllium copper per ASTM B196, gold* plated per MIL-DTL-45204 (0.00005” min) Hermetic seal center pins Kovar alloy per ASTM F15, gold* plated per MIL-DTL-45204 (0.00005” min) EMI/anti-rock rings Beryllium copper per ASTM B196, gold* plated per MIL-DTL-45204 (0.00003” min) PC mount legs Brass per ASTM B16, gold* plated per MIL-DTL-45204 (0.00003” min) Connector and adapter insulators Brass per ASTM B16, gold* plated per MIL-DTL-45204 (0.00003” min) Hermetic seal glass Corning 7070 *All gold plated parts include a 0.00005” minimum nickel barrier layer Mounting Holes Figure 1 Figure 2 *This pattern is for reference only. Pattern will vary depending on board type and specific electrical and mechanical requirements. 22 Figure 3 SMP Mating Engagement for SMP Series per MIL-STD-348A Notes: 1. Socket to accept mating pin Ø0.015±0.001 (0.38±0.03). 2. EMI/Anti-Rock Ring configuration optional, used on cabled connectors only. Shall not prevent proper mating engagement. 3. All dimensions shown in inches. Metric equivalents (rounded to nearest 0.01mm) are given for general information only. SMP Female Connector Interface Dimension Cabled A Uncabled Minimum Maximum Minimum Maximum 0.025 (0.64) 0.035 (0.89) 0.018 (0.46) 0.025 (0.64) SMP Male Connector Interface Dimension Full Detent Limited Detent Smooth Bore Catcher’s Mitt Minimum Maximum Minimum Maximum Minimum Maximum Minimum Maximum B 0.051 (1.30) 0.057 (1.45) 0.054 (1.37) 0.060 (1.52) 0.059 (1.50) 0.065 (1.65) N/A N/A C 0.0205 (0.52) 0.0235 (0.60) 0.0205 (0.52) 0.0235 (0.60) N/A N/A N/A N/A D 0.003 (0.08) 0.008 (0.20) 0.003 (0.08) 0.008 (0.20) 0.003 (0.08) 0.008 (0.20) 0.043 (1.09) 0.047 (1.19) E 0.033 (0.84) 0.037 (0.94) 0.033 (0.84) 0.037 (0.94) 0 .033 (0.84) 0.037 (0.94) N/A N/A F 0.139 (3.53) 0.145 (3.68) 0.139 (3.53) 0.145 (3.68) 0.139 (3.53) 0.145 (3.68) 0.123 (3.12) 0.127 (3.23) G 0.114 (2.90) 0.118 (3.00) 0.118 (3.00) 0.122 (3.10) 0.123 (3.12) 0.127 (3.23) N/A N/A H 0.124 (3.15) 0.126 (3.20) 0.124 (3.15) 0.126 (3.20) N/A N/A N/A N/A K 35° REF 35° REF 35° REF 35° REF 35° REF 35° REF N/A N/A M 30° REF 30° REF 30° REF 30° REF N/A N/A N/A N/A 23 SMP PCB Mount Connectors Straight PCMount Male Receptacle Part Number Material Interface Frequency Range “A” 127-0701-201 Passivated* Full Detent 0-12GHz 0.218 (5.54) 127-1701-201 Passivated* Limited Detent 0-12GHz 0.218 (5.54) 127-2701-201 Passivated* Smooth Bore 0-12GHz 0.218 (5.54) 127-3701-201 Passivated* Catcher’s Mitt 0-12GHz 0.234 (5.94) * Base and legs gold plated brass Mounting hole layout figure 3 on page 6 SMP Male, Straight Surface Mount Part Number Material Interface Impedance VSWR Maximum Frequency 127-0701-221 Gold-Plated Full Detent 50 Ohms 1.5 Max 18 GHz 127-1701-221 Gold-Plated Limited Detent 50 Ohms 1.5 Max 18 GHz 127-2701-221 Gold-Plated Smooth Bore 50 Ohms 1.5 Max 18 GHz 24 SMP End Launch Connectors End Launch Male Receptacle – Surface Mount Part Number Material Interface Frequency Range Packaging 127-0701-801 Gold Plated Full Detent 0-18GHz Bag 127-0701-802 Gold Plated Full Detent 0-18GHz Tape and reel -1000 pieces 127-1701-801 Gold Plated Limited Detent 0-18GHz Bag 127-1701-802 Gold Plated Limited Detent 0-18GHz Tape and reel -1000 pieces 127-2701-801 Gold Plated Smooth Bore 0-18GHz Bag 127-2701-802 Gold Plated Smooth Bore 0-18GHz Tape and reel -1000 pieces Vertical Launch Connectors SMP Compression Connector, Microstrip Part Number Material Impedance VSWR Maximum Frequency 127-0701-631 Gold-Plated 50 Ohms 1.5 Max DC - 40 GHz SMP Compression Connector, Stripline Part Number Material Impedance VSWR Maximum Frequency 127-0701-641 Gold-Plated 50 Ohms 1.3 Max DC - 40 GHz 25 SMP Flange Mount Connectors 2-Hole Flange Mount Male Shroud - Without Contact Part Number Material Interface 127-0701-602 Passivated Full Detent 127-1701-602 Passivated Limited Detent 127-2701-602 Passivated Smooth Bore 2-Hole Flange Mount Male Catcher’s Mitt Shroud - Without Contact Part Number Material Interface 127-3701-602 Passivated Catcher’s Mitt Mounting hole layout figure 1 on page 6 2-Hole Flange Mount Male Field Replaceable Part Number Material Interface VSWR Frequency Range* Accepts Pin Size 127-0701-612 Passivated Full Detent 1.15 typical 0-18 GHz 0.012 (0.030) 127-1701-612 Passivated Limited Detent 1.15 typical 0-18 GHz 0.012 (0.030) 127-2701-612 Passivated Smooth Bore 1.15 typical 0-18 GHz 0.012 (0.030) * Two connectors mated back to back with hermetic seal fixture 26 SMP Hermetic Seal Part Number Material Interface Frequency Range 127-0701-601 Gold Plated Full Detent 0-18 GHz 127-1701-601 Gold Plated Limited Detent 0-18 GHz 127-2701-601 Gold Plated Smooth Bore 0-18 GHz Mounting hole layout figure 2 on page 7 0.047” Cable Connectors Part Number Material Cable Type VSWR Frequency Range* 127-0692-001 Gold Plated M17/151, 0.047 Semi-Rigid Straight 1.20 max 1.35 max 1.70 max 0-18 GHz 18-26.5 GHz 26.5-40 GHz Figure 1 127-0692-101 Gold Plated M17/151, 0.047 Semi-Rigid Right Angle 1.20 max 0-18 GHz 127-0692-101 2 * Specifications dependent on cable ratings .248 (6.30) .197 (5.00) Figure 1 0.047” 0.086” Cable Connectors Figure 2 Right Angle Part Number Material Cable Type VSWR Frequency Range* 127-0693-001 Gold Plated RG-405, 0.086 Semi-Rigid Straight 1.20 max 1.35 max 1.70 max 0-18 GHz 18-26.5 GHz 26.5-40 GHz 3 RG-405, 0.086 Semi-Rigid Right Angle 1.20 max 0-18GHz 127-0693-101 4 127-0693-101 Figure * Specifications dependent on cable ratings .271 (6.88) .209 (5.31) Figure 3 0.086” Figure 4 Right Angle 27 SMP Ganged Connectors Male, Full Detent, Vertical PCB Surface Mount Part Number No. of Ports Interface VSWR Frequency Range 127-0711-221 4 Full Detent 1.25 Max 0 - 18 GHz 1.50 Max 18 - 26.5 GHz Male, Full Detent, Right Angle PCB Surface Mount Part Number No. of Ports Interface VSWR Frequency Range 127-0711-321 4 Full Detent 1.25 Max 0 - 18 GHz 1.50 Max 18 - 26.5 GHz Male, Smooth Bore/Limited Detent, Vertical PCB Surface Mount Part Number No. of Ports Interface VSWR Frequency Range 127-2711-221 4 Smooth Bore 1.25 Max 0 - 18 GHz 1.50 Max 18 - 26.5 GHz 127-1721-221 4 Limited Detent 1.25 Max 0 - 18 GHz 1.50 Max 18 - 26.5 GHz 28 SMP Male, Smooth Bore/Limited Detent Right Angle PCB Surface Mount Part Number No. of Ports Interface VSWR Frequency Range 127-2711-321 4 Smooth Bore 1.25 Max 0 - 18 GHz 1.50 Max 18 - 26.5 GHz 1.25 Max 0 - 18 GHz 1.50 Max 18 - 26.5 GHz 127-1721-321 4 Limited Detent Male, Full Detent, Cabled Part Number No. of Ports Interface VSWR Frequency Range 127-0593-011 4 Full Detent 1.25 Max 0 - 18 GHz 1.35 Max 18 - 26.5 GHz 1.50 Max 26.5 - 40 GHz 29 SMP Ganged Edge Mount Connectors Male, Full Detent, PCB Edge Mount Part Number No. of Ports Interface VSWR Frequency Range 127-0701-811 4 Full Detent 1.5 Max 0 - 40 GHz Male, Full Detent, PCB Edge Mount Part Number No. of Ports Interface VSWR Frequency Range 127-0701-821 2 Full Detent 1.5 Max 0 - 40 GHz 30 SMP Male, Limited Detent, PCB Edge Mount Part Number No. of Ports Interface VSWR Frequency Range 127-1701-821 2 Limited Detent 1.5 Max 0 - 40 GHz Male, Limited Detent, PCB Edge Mount Part Number No. of Ports Interface VSWR Frequency Range 127-1701-831 4 Limited Detent 1.5 Max 0 - 40 GHz 31 SMP Male, Smooth Bore, PCB Edge Mount Part Number No. of Ports Interface VSWR Frequency Range 127-2701-811 2 Smooth Bore 1.5 Max 0 - 40 GHz Male, Smooth Bore, PCB Edge Mount Part Number No. of Ports Interface VSWR Frequency Range 127-2701-821 4 Smooth Bore 1.5 Max 0 - 40 GHz 32 SMP Blind Mate Interconnects Female to Female Bullet Adapter Part Number Material VSWR Frequency Range 127-0901-801 Gold Plated 1.10 Max 1.15 Max 1.30 Max 1.70 Max 0-18 GHz 18-23 GHz 23-26.5 GHz 26.5-40 GHz Female to Female Long Bullet Adapter Part Number Material VSWR Frequency Range 127-0901-811 127-0901-811 1.10 Max 1.15 Max 1.20 Max 0-4 GHz 4-12 GHz 12-18 GHz Same Series Adapters Male to Male Catcher’s Mitt Adapters, Stainless Steel Part Number Material Interface VSWR Frequency Range 127-0901-822 Stainless Steel, Passivated Full Detent 1.10 max 1.15 max 1.20 max 0-4 GHz, 4-12 GHz, 12-18 GHz 127-1901-822 Stainless Steel, Passivated Limited Detent 1.10 max 1.15 max 1.20 max 0-4 GHz, 4-12 GHz, 12-18 GHz 127-2901-822 Stainless Steel, Passivated Smooth Bore 1.10 max 1.15 max 1.20 max 0-4 GHz, 4-12 GHz, 12-18 GHz 33 SMP Between Series Adapters SMA to SMP Adapters Part Number Material Interface VSWR Frequency Range Figure Dimension A 134-1019-441 Gold Plated SMA Plug to SMP Plug 1.20 max 1.25 max 0-20 GHz 20-26.5 GHz 1 .621 (15.77) 134-1019-451 Gold Plated SMA Plug to SMP Jack 1.20 max 1.25 max 0-20 GHz 20-26.5 GHz 1 .561 (14.25) 134-1019-461 Gold Plated SMA Jack to SMP Jack 1.20 max 1.25 max 0-20 GHz 20-26.5 GHz 2 .529 (13.44) 134-1019-471 Gold Plated SMA Jack to SMP Plug 1.20 max 1.25 max 0-20 GHz 20-26.5 GHz 2 .574 (14.58) Dim. A Dim. A Figure 1 Tools Figure 2 Accurate assembly of the semi-rigid cabled connectors is obtained with the tools listed below. Industry standard devices are used if possiblefor customer convenience and tool compatibility. G. A. J. F. H. B. C. E. K. I. D. Part Number Item Description 127-0000-900 A SMP bullet extraction tool 127-0000-901 B SMP cabled connector removal tool 140-0000-962 C Soldering vise (does not include clamp inserts or stop screw) 140-0000-981 D Stop screw for soldering vise 140-0000-964 140-0000-997 E Semi-rigid cable clamp inserts for 0.086” OD cable Semi-rigid cable clamp inserts for 0.047” OD cable 140-0000-984 F Solder shim for 0.086” OD cable 127-0000-902 G SMP center contact holder 127-0000-903 H SMP interface locator tool 127-0000-904 I SMP right angle body holder 127-0000-905 127-0000-906 127-0000-907 J SMP Full Detent shroud centering tool SMP Limited Detent shroud centering tool SMP Smooth Bore shroud centering tool 127-0000-910 K SMP bullet extraction removal tool 34 SMP Assembly Instructions SMP Straight Female Solder Style for 0.047 OD Semi-Rigid Cable 1. Identify tools (5 piece parts) and connector parts (3 piece parts). 2. Strip cable jacket and dielectric to dimension shown. Do not nick center conductor. Clean all debris from prepared cable. 3. Insert center conductor into cable stop as shown and place contact onto center conductor. 4. Insert contact into contact holder fixture and clamp cable in vise. Tighten stop screw until light pressure is applied between contact, cable stop and cable jacket. 5. Solder contact to center conductor through solder hole using 0.016 (0.41) diameter flux core solder wire or solder paste. Use a minimum amount of solder and heat for a good joint. Do not allow heat to build up for a long period of time as cable stop may melt. 6. After solder joint has cooled, remove cable from vise. Remove any excess solder from contact with a sharp blade and clean all debris from contact and cable. 7. Insert contact into connector assembly, making sure cable stop bottoms out against internal shoulder of connector body. Insert connector assembly into interface location fixture and clamp cable in vise. Make sure connector assembly isfully engaged within location fixture. Tighten stop screw until light pressure is applied between connector assembly and cable stop. 8. Solder end of connector body to cable jacket, using a minimum amount of solder and heat for a full fillet joint. Allow assembly to cool before removing connector from vise and location fixture. Best results are obtained when contact location is flush to 0.004 (0.10) recessed from reference plane. Interface location fixture is pre-set atfactory, but can be adjusted to control location. Part Number Cable Group 127-0692-101 MIL-C-17/151, 0.047 Semi-Rigid Part Number Tool 140-0000-962 Cable Vise 140-0000-981 Stop Screw 140-0000-997 Clamp Inserts 127-0000-902 Contact Holder 127-0000-903 Interface Location Fixture 35 SMP SMP Right Angle Female Solder Style for 0.047 OD Semi-Rigid Cable 1. Identify tools (5 piece parts) and connector parts (3 piece parts). 2. Strip cable jacket and dielectric to dimension shown. Do not nick center conductor. Clean all debrisfrom prepared cable. 3. Insert center conductor into cable stop as shown. Make sure slot in connector contact is aligned with cross hole in body as shown. Insert cable into cross hole in connector body, making sure cable stop bottoms out against internal shoulder of connector body. 4. Insert connector assembly into interface location fixture and clamp cable in vise using body holder fixture as shown. Tighten stop screw until light pressure is applied between connector body, cable stop and cable jacket. 5. Solder contact to center conductor through rear access port in connector body using a minimum amount of solder and heat for a good joint. 6. After center conductor solder joint has cooled, solder connector body to cable jacket, using a minimum amount of solder and heat for a full fillet joint. Take care so that solder does notflow onto anti-rock ring or into rear access port. Allow assembly to cool before removing connector from vise and location fixture. 7. Using a fixture plate as shown, press end cap into rear access port using a 0.156 (3.96) diameter flat punch untilfully seated within body counter bore. 8. Best results are obtained when contact location is flush to 0.004 (0.10) recessed from reference plane. Interface location fixture is pre-set at factory, but can be adjusted to control location. Part Number Cable Group 127-0692-101 MIL-C-17/151, 0.047 Semi-Rigid Part Number Tool 140-0000-962 Cable Vise 140-0000-981 Stop Screw 140-0000-997 Clamp Inserts 127-0000-904 Body Holder 127-0000-903 Interface Location Fixture 36 SMP SMP Straight Female Solder Style for 0.086 OD Semi-Rigid Cable 1. Identify tools (6 piece parts) and connector parts (2 piece parts). 2. Strip cable jacket and dielectric to dimension shown. Do not nick center conductor. Clean all debris from prepared cable. 3. Place contact onto center conductor, insert solder shim between cable jacket and contact. 4. Insert contact into contact holder fixture and clamp cable in vise. Tighten stop screw until light pressure is applied between contact, solder shim and cable jacket. 5. Solder contact to center conductor through solder hole using 0.016 (0.41) diameter flux core solder wire or solder paste. Use a minimum amount of solder and heat for a good joint. Do not allow heat to build up for a long period of time as cable dielectric will expand. 6. After solder joint has cooled, remove solder shim and cable from vise. Remove any excess solder from contact with a sharp blade and clean all debris from contact and cable. 7. Insert contact into connector assembly, making sure cable jacket bottoms out against internal shoulder of connector body. Insert connector assembly into interface location fixture and clamp cable in vise. Make sure connector assembly is fully engaged within location fixture. Tighten stop screw until light pressure is applied between connector assembly and cable jacket. 8. Solder end of connector body to cable jacket, using a minimum amount of solder and heat for a full fillet joint. Allow assembly to cool before removing connector from vise and location fixture. Best results are obtained when contact location is flush to 0.004 (0.10) recessed from reference plane. Interface location fixture is preset at factory, but can be adjusted to control location. Part Number Cable Group 127-0693-001 RG-405, 0.086 Semi-Rigid Part Number Tool 140-0000-962 Cable Vise 140-0000-981 Stop Screw 140-0000-964 Clamp Inserts 140-0000-984 Solder Shim 127-0000-902 Contact Holder 127-0000-903 Interface Location Fixture 37 SMP SMP Right Angle Female Solder Style for 0.086 OD Semi-Rigid Cable 1. Identify tools (5 piece parts) and connector parts (2 piece parts). 2. Strip cable jacket and dielectric to dimension shown. Do not nick center conductor. Clean all debris from prepared cable. 3. Make sure slot in connector contact is aligned with cross hole in body as shown. Insert cable into cross hole in connector body, making sure cable jacket bottoms out against internal shoulder of connector body. 4. Insert connector assembly into interface location fixture and clamp cable in vise using body holder fixture as shown. Tighten stop screw until light pressure is applied between connector body and cable jacket. 5. Solder contact to center conductor through rear access port in connector body using a minimum amount of solder and heat for a good joint. Do not allow solder to build up along exposed center conductor. 6. After center conductor solder joint has cooled, solder connector body to cable jacket, using a minimum amount of solder and heat for a full fillet joint. Take care so that solder does not flow onto anti-rock ring or into rear access port. Allow assembly to cool before removing connector from vise and location fixture. 7. Using a fixture plate as shown, press end cap into rear access port using a 0.156 (3.96) diameter flat punch untilfully seated within body counter bore. 8. Best results are obtained when contact location is flush to 0.004 (0.10) recessed from reference plane. Interface location fixture is preset at factory, but can be adjusted to control location. Part Number Cable Group 127-0693-101 RG-405, 0.086 Semi-Rigid Part Number Tool 140-0000-962 Cable Vise 140-0000-981 Stop Screw 140-0000-964 Clamp Inserts 127-0000-904 Body Holder 127-0000-903 Interface Location Fixture 38 SMP SMP Hermetic Seal Installation 1. Prepare housing panel per figure 2 as shown on page 6 2. Install solder ring on hermetic seal as shown. Recommended ring size is 0.103 (2.62) ID x 0.128 (3.25) OD x 0.015 (0.38) thick. 3. Solder in place as shown Part Number Interface 127-0711-601 Full Detent 127-1711-601 Limited Detent 127-2711-601 Smooth Bore SMP Shroud Installation 1. Install appropriate assembly tool into shroud as shown. 2. While holding tool in place, align flange mount with mounting holes in panel. Install fasteners and torque to 6-8 in/lbs. Shroud Part Number Tool Part Number 127-0701-602 127-0000-905 127-1701-602 127-0000-906 127-2701-602 127-0000-905 127-3701-602 127-0000-905 39 About Cinch Connectivity Solutions For over 100 years, Cinch Connectivity Solutions has manufactured high-quality and reliable high-performance connectors and cable assemblies. Cinch is recognized as a world class connectivity supplier of RF, fiber optic, hybrid, microwave components, circular, d-subminiatures, modular rectangular, electronic enclosures and cable assemblies. Cinch provides innovative solutions to the military, commercial aerospace, networking, telecommunication, test and measurement, oil and gas and other harsh environment industries. For more information, please contact us: North America +1 507.833.8822 ccsorders@us.cinch.com Asia-Pacific +86 21 5442 7668 ccs.asia.sales@as.cinch.com Europe, Middle East +44 (0) 1245 342060 CinchConnectivity@eu.cinch.com belfuse.com/cinch.com ca-ccs-JOHN-high-speed-miniature-10182022 © 2022 Cinch Connectivity Solutions
127-0000-902 价格&库存
很抱歉,暂时无法提供与“127-0000-902”相匹配的价格&库存,您可以联系我们找货
  • 1+150.447011+19.48815
