MRF14-J/P-088/SO-MD
MRF14-J/P-088/SO-MD
    HRS(广濑)
    TOOLSOLDERJIGFORMRF14
MRF14-J/P-088/SO-MD 数据手册
MKT-E-11012F MRF14 Series Non-magnetic, High Durability Connector  Features 1.Non-magnetic characteristics 2.High durability, 60,000 times of mating/unmating 3.Low insertion/withdrawal force 4.Customizable housing design 5.RoHS compliant Coaxial Type Signal Type Plug Side Jack Side Coaxial Plug Plug Side Coaxial Jack 29.9 Jack Side Male Contact Female Contact 29.9 13 6 19 19 7 19 【Excellent High Frequency Characteristics】 DC to 0.5 GHz: V.S.W.R. 1.3 Max. 0.5 to 1 GHz: V.S.W.R. 1.5 Max. 【Small & Light Weight Contact】 Male contact: O.D.  2.09 mm, Weight 0.35 to 0.62 g Female contact: O.D.  2.04 mm, Weight 0.18 g 【Small Dia.】 O.D.  3.84 mm for both Plug & Jack 【Variations】 TH Soldering type, Cable type 【Low Insertion/Withdrawal Force】 【Low Insertion/Withdrawal Force】 Insertion Force: 1.5 N max./pin Withdrawal Force: 0.15 N min./pin Insertion Force: 0.3 N (Nominal)/pin Withdrawal Force: 0.02 N min./pin  Varieties Plug Side Jack Side Remarks  1.37 Flex coax. cable Coaxial MRF14-P-088NM-1 MRF14-J-088NM-1 Housing for coaxial MRF14-xxP-CH MRF14-xxJ-CH 4, 8 pos. Signal contact MRF14-CON(*) * MC: Cable assy M1, M2:TH soldering MRF14-CON(F) AWG#24 Housing for signal MRF14-CON(M)-14M 14 pos. Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings or availabilities. Issued: Nov. 18, 2013
MRF14-J/P-088/SO-MD 价格&库存
很抱歉,暂时无法提供与“MRF14-J/P-088/SO-MD”相匹配的价格&库存,您可以联系我们找货
