SMD050L
SMD050L
    SEA&LAND(台湾陆海)
    PTC自恢复保险丝 FUSE2920 Vmax=60V Ih=500mA
SMD050L 数据手册
SEA & LAND ELECTRONIC CORP. WWW.SEALAND-PPTC.COM ALPHA-TOP TECHNOLOGY CORP. WWW.ALPHA-TOP.CN APPROVAL SHEET MODEL NO.: SMD Series CUSTOMER: CUSTOMER'S APPROVAL: AUTHORIZED SIGNATURE/STAMP: DATE MANUFACTURER: HEAD OFFICE: China Branch: Submitted by: Approved by: DATE: 13F.,No.120-10,Sec.3,Zhongshan Rd.,Zhonghe Dist.,New Taipei City 23544,Taiwan Tel: 886-2-8221-2567 Fax:882-2-2225-7268 E-mail:service@chipfast.com.tw Factory Building B)Shuangpeng,Weibu Village, Qiuchang Town, Huiyang District, Huizhou City, Guangdong Province, P.R.C.) Tel: 86-752-3562001 Fax:86-752-3558696 E-mail:service@atpptc.com Chen YC Lin 24-Jun-22 SEA & LAND ELECTRONIC CORP. 第 1页 Features Applications ■ Surface Mount Devices Almost anywhere there is a low voltage ■ Lead free device power supply, up to 60V and a load to be ■ Size 7.5*5.5 mm 0.29*0.20 inch protected, including: ■ Surface Mount packaging ■ Computer mother board, Modem. for automated assembly ■ Telecommunication equipments. SMD Series Alpha-Top (Sea & Land Alliance) Performance Specification Maximum Time To Trip Ihold Itrip Pd @25°C @25°C Typ. Current Time (Vdc) (A) (A) (A) (W) (A) (Sec) SMD030L 60 100 0.30 0.60 1.5 1.5 3.0 SMD050L 60 100 0.50 1.00 1.5 2.5 4.0 SMD075L 33 100 0.75 1.50 1.5 8.0 0.3 SMD075L-60V 60 100 0.75 1.50 1.5 8.0 0.3 SMD100L 33 100 1.10 2.20 1.5 8.0 0.5 SMD125L 33 100 1.25 2.50 1.5 8.0 2.0 SMD150L 33 100 1.50 3.00 1.5 8.0 2.0 SMD185L 33 100 1.85 3.70 1.5 8.0 2.5 SMD200L 16 100 2.00 4.00 1.5 8.0 4.5 SMD200L-24V 24 100 2.00 4.00 1.5 8.0 4.5 SMD250L 16 100 2.50 5.00 1.5 8.0 16.0 SMD260L 6 100 2.60 5.20 1.5 8.0 10.0 SMD300L 6 100 3.00 6.00 1.5 8.0 20.0 SMD300L-13.2V 13.2 100 3.00 6.00 1.5 8.0 20.0 SMD300L-16V 16 100 3.00 6.00 1.5 8.0 20.0 SMD300L-24V 24 100 3.00 6.00 1.5 8.0 20.0 SMD400L 6 40 4.00 8.00 1.5 16.0 20.0 SMD400L-16V 16 40 4.00 8.00 1.8 16.0 20.0 SMD400L-24V 24 40 4.00 8.00 1.8 16.0 20.0 SMD500L 6 40 5.00 10.00 1.8 20.0 10.0 SMD500L-13.2V 13.2 40 5.00 10.00 1.8 20.0 10.0 SMD500L-24V 24 40 5.00 10.00 1.8 20.0 10.0 SMD600L 6 40 6.00 12.00 1.8 25.0 8.0 SMD600L-13.2V 13.2 40 6.00 12.00 1.8 25.0 8.0 SMD600L-16V 16 40 6.00 12.00 1.8 25.0 8.0 SMD600L-24V 24 40 6.00 12.00 1.8 25.0 8.0 SMD700L 6 40 7.00 14.00 1.8 35.0 2.0 SMD700L-13.2V 13.2 40 7.00 14.00 1.8 35.0 2.0 SMD800L 6 40 8.00 16.00 1.8 35.0 2.5 Ihold = Hold Current. Maximum current device will not trip in 25°C still air. Itrip = Trip Current. Minimum current at which the device will always trip in 25°C still air. Vmax = Maximum operating voltage device can withstand without damage at rated current (Imax). Imax = Maximum fault current device can withstand without damage at rated voltage (Vmax). Pd = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Rimin/max = Minimum/Maximum device resistance prior to tripping at 25°C. R1max = Maximum device resistance is measured one hour post reflow. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. Model Vmax Imax Environmental Specifications Test Conditions Passive aging +85°C, 1000 hrs. Humidity aging +85°C, 85% R.H. , 168 hours Thermal shock +85°C to -40°C, 20 times Resistance to solvent MIL-STD-202,Method 215 Vibration MIL-STD-202,Method 201 Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C In case of special use, please contact our engineer Agency Approvals : E201504(Alpha-Top)/E319079(Sea&Land) 2015/863/EU Regulation/Standard: EN14582 第 2页 Resistance Rimin (Ω) 0.600 0.180 0.100 0.100 0.065 0.050 0.035 0.030 0.020 0.020 0.020 0.014 0.012 0.012 0.012 0.012 0.012 0.012 0.012 0.005 0.005 0.005 0.004 0.004 0.004 0.004 0.002 0.002 0.001 R1max (Ω) 4.800 1.400 1.000 1.000 0.410 0.250 0.230 0.150 0.120 0.120 0.085 0.075 0.048 0.048 0.048 0.048 0.035 0.035 0.035 0.031 0.031 0.031 0.026 0.026 0.026 0.026 0.018 0.018 0.010 Agency Approval UL √ √ √ √ √ TUV 0 Ihold Versus Temperature Model -40°C 0.45 0.76 1.13 1.66 1.89 2.27 2.80 3.02 3.78 3.64 4.53 5.97 7.55 8.60 9.50 10.80 SMD030L SMD050L SMD075L SMD100L SMD125L SMD150L SMD185L SMD200L SMD250L SMD260L SMD300L SMD400L SMD500L SMD600L SMD700L SMD800L 3 -20°C 0.40 0.67 1.01 1.47 1.68 2.01 2.47 2.68 3.35 3.25 4.02 5.30 6.70 7.75 8.70 9.76 Maximum ambient operating temperature (Tmao) vs. hold current (Ihold) 0°C 25°C 40°C 50°C 60°C 0.35 0.30 0.25 0.23 0.20 0.59 0.50 0.42 0.38 0.33 0.88 0.75 0.62 0.56 0.50 1.29 1.10 0.91 0.83 0.73 1.46 1.25 1.04 0.94 0.83 1.76 1.50 1.25 1.13 1.00 2.17 1.85 1.54 1.39 1.22 2.34 2.00 1.66 1.50 1.32 2.93 2.50 2.08 1.88 1.65 2.91 2.60 2.26 2.08 1.95 3.51 3.00 2.52 2.26 1.99 4.66 4.00 3.36 3.04 2.71 5.85 5.00 4.15 3.75 3.30 6.89 6.00 5.04 4.56 3.96 7.90 7.00 6.40 5.85 5.40 8.80 8.00 6.56 6.08 5.44 Max. 7.98 7.98 7.98 7.98 7.98 7.98 7.98 7.98 7.98 7.98 7.98 7.98 7.98 7.98 7.98 7.98 Min. 4.80 4.80 4.80 4.80 4.80 4.80 4.80 4.80 4.80 4.80 4.80 4.80 4.80 4.80 4.80 4.80 Construction And Dimension (Unit:mm) Model Min. 6.73 6.73 6.73 6.73 6.73 6.73 6.73 6.73 6.73 6.73 6.73 6.73 6.73 6.73 6.73 6.73 SMD030L SMD050L SMD075L SMD075L-60V SMD100L SMD125L SMD150L SMD185L SMD200L SMD200L-24V SMD250L SMD260L SMD300L SMD300L-16V SMD500L SMD500L-13.2V A B Max. 5.44 5.44 5.44 5.44 5.44 5.44 5.44 5.44 5.44 5.44 5.44 5.44 5.44 5.44 5.44 5.44 Min. 0.60 0.60 0.60 0.60 0.40 0.40 0.40 0.60 0.30 0.60 0.30 0.30 0.30 0.60 0.40 0.60 C Recommended Pad Layout (mm) Dimensions & Marking A 2.3 士0.1 5.6士0.1 2.3士0.1 300L B D Min. 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 Max. 1.30 1.30 1.30 1.30 1.00 0.90 0.90 1.30 0.90 1.30 0.90 0.90 0.90 1.30 1.30 1.30 D 5.1士0.1 E C α = Trademark 300L = Hold current 第 3页 70°C 0.17 0.29 0.44 0.64 0.73 0.87 1.07 1.16 1.45 1.74 1.75 2.38 2.90 3.54 4.80 4.80 E Min. 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 85°C 0.14 0.23 0.34 0.50 0.56 0.74 0.85 0.90 1.13 1.13 1.34 1.83 2.25 2.76 3.95 3.68 SMD Series Alpha-Top (Sea & Land Alliance) Termination Pad Characteristics Terminal pad materials:Gold-Plated Nickel-Copper or Tin-plated Nickel-Copper Terminal pad solderability:Meets EIA specification RS186-9E and ANSI/J-STD-002 Category 3. Rework Use standard industry practices, the removal device must be replaced with a fresh one. Thermal Derating Curve Typical Time-To-Trip At 25°C · Use PPTC beyond the maximum ratings or improper use may result in device damage and possible electrical arcing and flame. · PPTC are intended for protection against occasional over current or over temperature fault conditions and should not be used when repeated fault conditions or prolonged trip events are anticipated. · Device performance can be impacted negatively if devices are handled in a manner inconsistent with recommended electronic, thermal, and mechanical procedures for electronic components. · Use PPTC with a large inductance in circuit will generate a circuit voltage (L di/dt) above the rated voltage of the PPTC. · Avoid impact PPTC device its thermal expansion like placed under pressure or installed in limited space. · Contamination of the PPTC material with certain silicon based oils or some aggressive solvents can adversely impact the performance of the devices. PPTC SMD can be cleaned by standard methods. · Requests that customers comply with our recommended solder pad layouts and recommended reflow profile. Improper board layouts or reflow profile could negatively impact solderability performance of our devices. 第 4页 SMD Series Alpha-Top (Sea & Land Alliance) Recommended Solder Reflow Conditions 300 Preheating Soldering ‧Recommended reflow methods:IR, vapor phase oven, hot air oven. Cooling ‧Devices are not designed to be wave soldered to the bottom side 250 of the board. 200 ‧Recommended maximum paste thickness is 0.25 mm (0.010 inch). 190 ‧Devices can be cleaned using standard method and solvents. 160 Note:If reflow temperatures exceed the recommended profile, 100 0 devices may not meet the performance requirements. 60-120 sec. 30~60sec. Tape And Reel Specifications (mm) Governing Specifications W P0 P1 P2 A0 B0 B1max. D0 F E1 E2min. Tmax. T 1max. K0 Leader min. Trailer min. Reel Dimensions A max. N min. W1 W 2max. 120 sec. EIA Tape Component Dimensions EIA 481-2 16.0 ± 0.3 4.0 ± 0.10 8.0 ± 0.10 2.0 ± 0.05 5.70 ± 0.10 8.00 ± 0.10 12.1 1.5 + 0.1, -0 7.5 ± 0.05 1.75 ± 0.10 14.25 0.6 0.1 0.80 ± 0.1 390 160 178 60 16.4 + 2.0, -0.0 22.4 P0 T P2 D0 Embossment E1 Cover tape A0 B1 K0 F T1 W E2 B0 P1 EIA Reel Dimensions W2(measured at hub) N(hub dia.) A 2 Cover tape 2 W1(measured at hub) Carrier tape Embossed cavity Storage And Handling ‧ Storage conditions:40°C max, 70% R.H. ‧ Devices may not meet specified performance if storage conditions are exceeded. Order Information SMD Product name Size 7555 mm /2920 inch SMD:surface mount device Tape & reel packaging per EIA481-1 050L Hold Current 0.50A Labeling Information Sea & Land Electronic Corp. Pb RoHS Model: Part no.: Spec.: Lot no.: Q'ty: 倉儲:密封!溫度:18~33℃/濕度:30~60% A 第 5页 Packaging Tape & Reel Quantity 075L-60V 200L-24V 500L-13.2V 1500PCS/reel 2,000 pcs/reel
SMD050L 价格&库存
很抱歉,暂时无法提供与“SMD050L”相匹配的价格&库存,您可以联系我们找货
SMD050L
    • 10+0.59113
    • 100+0.48658
    • 400+0.39511
    • 800+0.39116
    • 2000+0.38334
    库存:1613
    SMD050L
      • 5+0.64487
      • 50+0.53082
      • 150+0.47380
      库存:424
