14DC-05D09NP
14DC-05D09NP
    YDS(元册)
    插件,19.5x6mm
    DC-DC转换电源模块 输出5VDC±10% 输出±9VDC±5% ±56mA 83%
14DC-05D09NP 数据手册
14DC-05D09NP -Features 1WATT SIP PACKAGE EFFICIENCY TO 83% 100% BURNED IN No-load Input Current as Low as 5mA UL 94V-0 PACKAGE MATERIAL CUSTOM SOLUTIONS AVAILABLE UNREGULATED OUTPUT TYPES 1 Watt DC/DC Converter 1 Watt Dual O/P Isolated DC-DC Converter Input Specifications Input Voltage :5Vdc Input Voltage Range :±10% Output Specifications Output Voltage :±9Vdc Output Voltage Accuracy :±5% Output Current :±56mA Efficiency :83% TYP Ripple / Noise :30mVp-p TYP, 75mVp-p MAX Short Circuit Protection : Continuous Line Regulation :±1.2% TYP @For 1.0% OF Vin Load Regulation :±8% TYP,±10% MAX @10% to 100% full load Capacitive Load :±470uF MAX @Vout=±8.55~±9.45Vdc@Vin=5Vdc @20MHz Bandwidth General Specifications Operating Temperature Range :-40℃ ~ +105℃ Storage Temperature :-55℃ ~ +125℃ Switching Frequency :215 or 370KHz TYP Humidity :95% MAX Isolation Voltage :1500Vdc @Input to Output ( 60sec/0.5mA ) Isolation Resistance :1000MΩ MIN @ 500Vdc Cooling :Free air convection MTBF :>3500000 Hours Case Material :DAP Weight :2.1 g TYP EMI EMS MIL-HDBK-217F@25℃,Ground Benign. CE CISPR32/EN55032 CLASS B (see Fig. 1 for recommended circuit) RE CISPR32/EN55032 CLASS B (see Fig. 1 for recommended circuit) ESD IEC/EN61000-4-2 Air ±8kV , Contact ±4kV perf. Criteria B Page 1 of 3 Rev. 1.0 DWN: Wu YongSong 2022-9-29 14DC-05D09NP OutPut Power(%) Temperature Derating Graph 14DC – 05 D 09 N P A B C D E F A:Series B:Input Voltage C: Dual Output D: Output Voltage E:Unregulated(N) F:Protection 120 100 80 60 Nature Convection 40 20 0 -40 Vin Part Number -20 0 20 40 60 80 100105 +Vout Case Surface Temperature(℃) Cin Single Cout -Vout Recommended Test Circuit GND +Vout Vin Cin Cout Dual COM Cout GND -Vout Vin Cin Dual Vout Cout 5Vdc 4.7µF/25V ±9Vdc ±2.2µF/16V To make sure the product work at perfect operation status with full loading external capacitor is necessary and it is recommended to use high frequency low resistance electrolytic capacitor. EMC (CLASS B) compliance circuit EMC recommended circuit value table C1 4.7µF /50V C2 4.7µF /50V CY 1nF/4kV C3,C4 Recommended Test Circuit L 6.8µH EMI Flg.1 Outline Dimensions 19.50 6.00 printed face 1.25 TOP VIEW BOTTOM VIEW 12.70 2.00 0.25±0.05 10.00 4.0 1 4 5 2 6 0.50±0.05 2.54 UNIT:mm Unless otherwise specified,all tolerances are ±0.25 PIN 1 2 4 5 6 DUAL +Vin -Vin -Vout COM +Vout Page 2 of 3 Rev. 1.0 DWN: Wu YongSong 2022-9-29 14DC-05D09NP Packing Information: Weight-------------- 2.1grams/pcs TUBE-----------25pcs Weight: 73g per tube Size(mm) A 9.50 B 16.50 C 522 D 5.00 Outer carton unit: 2500pcs/100Tube/box Weight: 7.5kg per carton Page 3 of 3 Rev. 1.0 DWN: Wu YongSong 2022-9-29
14DC-05D09NP 价格&库存
很抱歉,暂时无法提供与“14DC-05D09NP”相匹配的价格&库存,您可以联系我们找货
