DH-17-CMB(5.6)UNIT
DH-17-CMB(5.6)UNIT
    HRS(广濑)
    ATTACHMENT FOR DH-17-CMB(5.6)
DH-17-CMB(5.6)UNIT 数据手册
NEW High speed transmission, 1mm pitch Small Interface Connector DH Series ■Overview DH Series is an impedance controlled interface connector for high speed transmission. 1mm contact mating pitch together with a 0.5mm mounting pitch yields a more compact, lower profile, higher density alternate to conventional half pich interface connectors. 4 different lock styles are available to meet various applications. Screw Lock Type (Locked with screwdriver) Screw Lock Type (Hand-screw) One Touch Lock Type (Metal Button) One Touch Lock Type (Plastic Button) ■Features Mating face area 1. Small Design Approx 50% reduced DXM Series DH Series (Conventional·general purpose half pitch type) pos.) 30(27 po s.) Mounting pitch: 0.5mm SMT 4.8 9.3 31 7.2 .16(26 8 Mating pitch:1.27mm Mating pitch:1.0mm 2. Robust design Receptacle Robust design resists wrenching D-shaped opening. Plug PCB Retention Force Through hole mounting for shell and metal fitting increases PCB retention force. M2 screw Secure Panel Attachment (optional) with easy to use hexagon sockets. Robust & Secure Screw Lock Tightening torque:0.06 to 0.07 N·m max 2010.9 1 DH Series●High speed transmission, 1mm pitch Small Interface Connector 3. Excellent Shielding for EMI Privention Grounding Structure Panel Metal Shielding Common component used for both top and bottom shielding /Easy assembly PCB 4. Wide variation There are various variations corresponding to the usage. ●Lock variation Lock type Cover case Item Specification /Part number Screw lock Screwdriver type DH-**-CV1B Hand-screw type DH-**-CV2B receptacle Item Connector Part number DH60-**P / DH80-**P Applicable panel thickness(mm) Number of washers 0 1.4 to 1.6 1(t=0.4) 0.9 to 1.2 1(t=0.6) 0.5 to 0.8mm 1(t=0.8) No panel Panel lock Metal button DH-**-CT1B Connector One touch lock Plastic button DH-**-CT2B *Screw lock type and One touch lock type does not mate together. Part No. DH-LNA DH-LNA-W4 DH-LNA-W8 DH-LNA-W16 DH60A-**P / DH80A-**P ●Common part Plug Lock type Connector Item Clamp metal Specification / Part number IDC type Screw lock One touch lock Cable spec. Outer dia. Construction Part No. Twinax cable 0.88 to 0.92 7/0.127 DH30B-**S Twisted pair cable 0.64 to 0.68 (AWG#28) DH32B-**S solder type DH40-**S (Developing Pin-variation of the above item is under planning. Please consult HRS sales.) *The figure in ( ) clamp part number is equal to the cable's outer diameter. 2 No. of pos. Part No. 17 DH-17-CMB(6.3) 27 DH-27-CMB(6.9) DH-27-CMB(7.3) 37 DH-37-CMB(8.8) 51 DH-51-CMB(9.6) DH Series●High speed transmission, 1mm pitch Small Interface Connector 5. High Speed Data Transmission This data is for reference only. The data can differ due to cable or PCB used in evaluation. Eye Diagram [ CH1-CH2 ] 500Mbps 1Gbps 2.5Gbps (Cable:10m) (Cable:5m) (Cable:2m) Measurement Condition Pin Assignment G:ground S:Signal Pair B G-S-S-G Pair A G-S-S-G Pair A Pulse Pattern Generator Pair B Oscilloscope Measurement Condition ·Measurement Pair:Deferential Pair A ·Cable:Twinax cable ·Input signal voltage:500mV Cable length 3 DH Series●High speed transmission, 1mm pitch Small Interface Connector ■Specifications Current rating Voltage rating Ratings 0.5A 125 V AC Operating temperature range Storage temperature range Item 1 1.Contact resistance 2.Insulation resistance 3.Withstanding voltage 4.Insertion and with drawal forces 5.Durability Specification 50mø max.(signal) 1000Mø min. No flashover or insulation breakdown 17pos. 27pos. 37pos. Insertion f. 25N max. 30N max. 36N max. 3N min. 3.3N min. with drawal f. 2.6N min. 1 ➀Contact resistance:70mø max. ➁No damage, cracks or parts dislocation. Conditions 100mA(DC or 1,000Hz) 100 V DC 250 V AC/1minute 51pos. 43N max. 3.8N min. Frequency:10 to 50Hz, single amplitude of 0.75mm, 5min/cycle, total 10 cycles. Acceleration of 490m/s2, 11ms duration, sine half-wave waveform, 3 cycles in each of the 3 axis. Temperature: -55ç/+5ç to +35ç/+85ç/5ç to+35ç Time:30/5/30/5(Minutes) 5cycles 7.Shock 8.Temperature cycle 1 9.Humidity (Steady state) 10.Salt spray test 1 2 Measured by applicable connector. 1000 cycles ➀No electrical discontinuity of 10µs or longer. ➁No damage, cracks or parts dislocation. 6.Vibration –25ç to +85ç –25ç to +60ç ➀Contact resistance:70mø max. ➁No damage, cracks or parts dislocation. ➀Insulation resistance:100Mømin. ➁No damage, cracks or parts dislocation. ➀Contact resistance:100mø max. 96 hours at 40ç And RH 90% to 95%. 5% salt water solution for 48 hours. Excludes wire conductor resistance. *Unless otherwise specified, refer to JIS C 5402 Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Materials Products Screw lock type receptacle connector (DH60-**P / DH80-**P) One Touch Lock Type Receptacl connector (DH60A-**P / DH80A-**P) Plug connector (DH3*B-**S) Screw lock type cover case (DH-**-CV1B) Lock type cover case (DH-**-CV2B) One Touch Lock Type metal button cover case (DH-**-CT1B) One Touch Lock Type plastic button cover case (DH-**-CT2B) Lock screw (DH-LNA***) Metal clamp(DH-CMB(**)) 4 Components Material Finish Remarks Insulator Contacts Shell Metal fitting Insulator Contacts Shell Metal fitting Metal grounding post Insulator Contacts Rear insert Shell Cover Shield Screw lock Tapping screw Cover Shield Screw lock Screw insulator Tapping screw Cover Shield Lock spring Tapping screw Cover Shield Lock spring Button Tapping screw Screw lock Waher Spring washer Metal clamp Polyamide resin Copper alloy Stainless steel Stainless steel Polyamide resin Copper alloy Stainless steel Brass Steel Polyamide resin Copper alloy PBT resin Stainless steel Polycarbonate resin Stainless steel Steel Steel Polycarbonate resin Stainless steel Steel Polyamide resin Steel Polycarbonate resin Stainless steel Stainless steel Steel Polycarbonate resin Stainless steel Stainless steel Polycarbonate resin Steel Steel Steel Steel Brass Black Selective gold plated Tin plated Selective Tin plated Black selective gold plated Tin plated Tin plated Nickel plated Black Selective gold plated Black,Natural Nickel plated Black Nickel plated Nickel plated Black chromate(Cr+3) Black Nickel plated Nickel plated Black Black chromate(Cr+3) Black Nickel plated UL94V-0 --Black chromate(Cr+3) Black Nickel plated --Black Black chromate(Cr+3) Nickel plated Nickel plated Nickel plated --- ------UL94V-0 --------UL94V-0 --UL94V-0 --UL94V-0 ------UL94V-0 ----UL94V-0 --UL94V-0 ------UL94V-0 ----UL94V-0 ----------- DH Series●High speed transmission, 1mm pitch Small Interface Connector Screw lock type 25 8 0.5 0.18 ■Receptacle connector 4 [17pos. DH60-17P] 8 ●Right angle type 19.2 12.2 No.2 No.1 No.8 No.9 4.8 3.6 M2.3∞0.4 No.10 No.11 0.9 1.6 No.17 No.16 1.1 Ø1 19(BOSS PITCH) 19.2(CLAMP METAL PITCH) 24.8 0.2 1.56 0.5 30 13 0.5 0.18 4 8 [27pos. DH60-27P] 24.2 17.2 No.13 No.14 M2.3∞0.4 4.8 3.6 No.2 No.1 No.15 No.16 No.27 No.26 1.1 Ø1 24(BOSS PITCH) 24.2(CLAMP METAL PITCH) 29.8 0.9 1.6 0.2 1.56 0.5 35 18 0.5 0.18 4 8 [37pos. DH60-37P] 29.2 22.2 No.18 No.19 M2.3∞0.4 0.2 No.20 No.21 Ø1 No.37 No.36 1.1 0.9 1.6 4.8 3.6 No.2 No.1 1.56 0.5 29(BOSS PITCH) 29.2(CLAMP METAL PITCH) 34.8 5 DH Series●High speed transmission, 1mm pitch Small Interface Connector [51pos. DH60-51P] 42 25 0.18 4 8 0.5 36.2 29.2 No.25 No.26 M2.3∞0.4 3.6 4.8 No.2 No.1 0.2 No.27 No.28 Ø1 0.9 1.6 No.51 No.50 1.1 1.56 0.5 36(BOSS PITCH) 36.2(CLAMP METAL PITCH) 41.8 ●Straight type [27pos. DH80-27P] 27.8 16.5 1.5 4 4.9 1.5 Ø1 30.8 24.2 17.2 No.13 No.14 M2.3∞0.4 No.15 No.16 6 No.27 No.26 2.4 2.75 4.4 6.5 4.6 3.6 No.1 0.2 No.2 DH Series●High speed transmission, 1mm pitch Small Interface Connector ■Lock screw [Applicable panel thickness 1.4 to 1.6mm:DH-LNA] [Applicable panel thickness 0.9 to 1.2mm:DH-LNA-W4] 6 3. 6 2.5 2.5 3. M2∞0.4 14.4 14.4 0.4 4.4 4.4 M2∞0.4 M2.3∞0.4 M2.3∞0.4 [Applicable panel thickness 0.5 to 0.8mm:DH-LNA-W8] [No panel:DH-LNA-W16] 6 6 3. 2.5 2.5 3. M2∞0.4 14.4 1.6 14.4 0.8 4.4 4.4 M2∞0.4 M2.3∞0.4 M2.3∞0.4 7 DH Series●High speed transmission, 1mm pitch Small Interface Connector ■Cover case ●Screw lock [17pos. DH-17-CV1B] Note 1. This product is delivered separately. A recommended screw tightening torque to lock screw(DH-LNA***) should be from 2 0.06 to 0.07N•m. 3 A recommended screw tightening torque for covers to be from 0.1 to 0.15N•m. .8 Ø7 3 25.4 31.4 2 11.7 26 [27pos. DH-27-CV1B] .8 Ø8 3 25.4 31.4 2 11.7 31 8 DH Series●High speed transmission, 1mm pitch Small Interface Connector [37pos. DH-37-CV1B] 3 0. Ø1 3 25.4 39 2 11.7 13.6 36 [51pos. DH-51-CV2B] 1 1. Ø1 3 25.4 39 2 11.7 14.3 43 9 DH Series●High speed transmission, 1mm pitch Small Interface Connector ●Hand screw Ø7 .8 [17pos. DH-17-CV2B] Note 1. This product is delivered separately. 2 A recommended screw tightening torque to the lock screws to be from 0.06 to 0.07N•m. 3 A recommended screw tightening torque for covers to be from 0.1 to 0.15N•m. 3 25.4 31.4 2 11.7 26 *Available in the near future Ø8 .8 [27pos. DH-27-CV2B] 3 25.4 31.4 2 11.7 31 10 *Available in the near future DH Series●High speed transmission, 1mm pitch Small Interface Connector Ø1 0. 3 [37pos. DH-37-CV2B] 3 25.4 39 2 11.7 13.6 36 *Available in the near future Ø1 1. 1 [51pos. DH-51-CV2B] 3 25.4 39 2 11.7 14.3 43 *Available in the near future 11 DH Series●High speed transmission, 1mm pitch Small Interface Connector One Touch Lock Type ■Receptacle connector 25.8 8 0.5 0.18 ●Right angle type 5.2 4 8 [17pos. DH60A-17P] 17.2 No.8 No.9 21.2 12.2 M2∞0.4 3.6 4.8 No.2 No.1 No.10 No.11 0.2 0.9 1.6 No.17 No.16 0.95 Ø1 19(BOSS PITCH) 19.2(CLAMP METAL PITCH) 24.8 1.56 0.7 30.8 13 0.5 0.18 5.2 4 8 [27pos. DH60A-27P] 22.2 No.13 No.14 M2∞0.4 26.2 17.2 No.15 No.16 No.27 No.26 0.95 Ø1 24(BOSS PITCH) 24.2(CLAMP METAL PITCH) 29.8 0.2 [37pos. DH60A-37P] 0.9 1.6 4.8 3.6 No.2 No.1 1.56 0.7 35.8 18 0.5 5.2 4 8 0.18 27.2 No.18 No.19 31.2 22.2 No.2 No.1 0.2 No.20 No.21 Ø1 No.37 No.36 0.95 29(BOSS PITCH) 29.2(CLAMP METAL PITCH) 34.8 12 0.9 1.6 4.8 3.6 M2∞0.4 1.56 0.7 DH Series●High speed transmission, 1mm pitch Small Interface Connector [51pos. DH60A-51P] 42.8 25 0.5 5.2 4 8 0.18 34.2 No.25 No.26 38.2 29.2 No.2 No.1 4.8 3.6 M2∞0.4 No.27 No.28 Ø1 0.9 1.6 0.2 No.51 No.50 0.95 1.56 0.7 36(BOSS PITCH) 36.2(CLAMP METAL PITCH) 41.8 ●Straight type [27pos. DH80A-27P] 27.8 1.5 21.3 16.5 1 4 2.45 4.9 1.5 Ø1 30.8 26.2 17.2 0.2 No.13 No.14 No.15 No.16 No.27 No.26 M2∞0.4 2.4 2.75 4.4 6.5 4.6 3.6 No.2 No.1 13 DH Series●High speed transmission, 1mm pitch Small Interface Connector ■Cover case ●Metal button type [17pos. DH-17-CT1B] Note 1. This product is delivered separately. 2 A recommended screw tightening torque for covers to be from 0.1 to 0.15N•m. .8 Ø7 17 31.4 2 11.7 26 [27pos. DH-27-CT1B] .8 Ø8 17 31.4 2 11.7 31 14 DH Series●High speed transmission, 1mm pitch Small Interface Connector [37pos. DH-37-CT1B] Ø1 0.3 17 39 2 11.7 13.6 36 [51pos. DH-51-CT1B] 1.1 Ø1 17 39 2 11.7 14.3 43 15 DH Series●High speed transmission, 1mm pitch Small Interface Connector ●Plastic button type [17pos. DH-17-CT2B] Note 1. This product is delivered separately. 2 A recommended screw tightening torque for covers to be from 0.1 to 0.15N•m. .8 Ø7 17 31.4 2 11.7 26 [27pos. DH-27-CT2B] Ø8 .8 17 31.4 2 11.7 31 16 DH Series●High speed transmission, 1mm pitch Small Interface Connector [37pos. DH-37-CT2B] 0.3 Ø1 17 39 2 11.7 13.6 36 [51pos. DH-51-CT2B] 1.1 Ø1 17 39 2 11.7 14.3 43 17 DH Series●High speed transmission, 1mm pitch Small Interface Connector ■Plug unit ●IDC type [17pos. DH30B-17S] No.9 No.1 No.8 No.2 No.17 7 Bundled parts No.1 No.8 No.2 No.11 8.2 No.10 16.02 No.17 No.10 No.16 No.10 No.17 No.11 No.16 6.18 6.18 3.9 3.9 No.9 No.1 3.75 9.55 6.65 No.9 14.8 12.35 8 1 0.5 11 11 [27pos. DH30B-27S,DH30B-27S] No.13 No.1 No.14 No.2 19.8 17.35 13 No.14 1 0.5 No.1 3.75 9.55 6.65 Bundled parts No.27 No.13 3.9 3.9 No.15 No.27 No.1 No.15 No.16 No.26 No.26 No.16 No.27 No.15 6.18 No.2 6.18 No.14 16 16 *DH30B-27S and DH32B-27S are different holes in the attached parts. 18 12 8.2 16.02 DH Series●High speed transmission, 1mm pitch Small Interface Connector [37pos. DH30B-37S] No.19 No.1 No.18 No.2 No.19 1 0.5 24.8 22.35 18 No.1 No.1 No.21 No.37 No.20 No.36 No.20 No.37 No.21 8.2 16.02 No.37 3.9 3.9 No.19 3.75 9.55 6.65 Bundled parts No.2 No.20 No.36 6.18 6.18 No.18 21 21 [51pos. DH30B-51S] No.25 No.1 No.26 No.2 31.8 29.35 25 No.26 1 0.5 No.1 3.75 9.55 6.65 Bundled parts No.51 No.27 No.2 No.28 28 8.2 16.02 No.50 No.28 No.51 No.27 No.50 6.18 6.18 No.26 No.27 No.51 3.9 No.1 3.9 No.25 24 28 19 DH Series●High speed transmission, 1mm pitch Small Interface Connector ●Solder contact type [27pos. DH40-27S] 19.8 17.35 13 No.14 1 0.5 No.13 No.14 No.2 No.1 No.1 3.75 6.65 9.55 DH40 No.27 No.15 12 8.2 15.7 No.27 No.26 No.15 No.16 [37pos. DH40-37S] No.19 1 0.5 24.8 22.35 18 No.2 No.1 No.1 No.18 No.19 3.75 6.65 9.55 DH40 No.37 17 20 No.20 8.2 15.7 No.20 No.21 No.37 No.36 DH Series●High speed transmission, 1mm pitch Small Interface Connector ■Metal clamp [27pos. DH-27-CMB(6.9)] (Cable outer diameter 6.9mm) 4.7 5.5 4.7 5.5 [17pos. DH-17-CMB(6.3)] (Cable outer diameter 6.3mm) 13.5 10.1 11.3 9.3 0.5 9 10.6 0.5 5 4.7 6.1 [37pos. DH-37-CMB(8.8)] (Cable outer diameter 8.8mm) 4.7 5.5 [27pos. DH-27-CMB(7.3)] (Cable outer diameter 7.3mm) R4 R4 .2 .35 .5 R3 R3 17.6 12.1 14.4 10.2 0.8 R4 .8 .6 R4 R4 . R4 5 .3 9.5 12.4 0.5 21 DH Series●High speed transmission, 1mm pitch Small Interface Connector 4.7 6.1 [51pos. DH-51-CMB(9.6)] (Cable outer diameter 9.6mm) 18.4 13.1 R5 22 R5 .2 13 0.8 DH Series●High speed transmission, 1mm pitch Small Interface Connector ■Recommended PCB Mounting pattern ●DH60-**P, DH60A-**P A B C D R1 R1 2-1.5(Land) H) (T 4 1. Ø R0 .82 5 2- 25 .3 R0 3.1 2.2 1.2 PAD FOR TERMINAL PAD FOR SHELL 2-2.55(TH) 2-3.55(Land) 2.9 2-2(Land) P=0.5 0.3 2-0.65(TH) 2-1.65(Land) E F :PATTERN PROHIBITION AREA :REFERENCE PLANE POSITION (PATTERN PROHIBITION AREA) A 2.5 0.15 HO 1( Ø1 2- Ø1 . 2-1(Land) POSITIONING HOLE PCB END LE ) 1.3 Unit:mm 3- DH60-17P DH60A-17P DH60-27P DH60A-27P DH60-37P DH60A-37P DH60-51P DH60A-51P B C D E F 8 19 26 29.8 24.2 19.3 13 24 31 34.8 29.2 24.3 18 29 36 41.8 36.2 31.3 25 36 43 24.8 19.2 14.3 ●DH80-27P Ø2. nd La .2( Ø3 H) 6(T 27.8 24.2 13 ) No.2 No.1 0.43 PAD FOR TERMINAL No.13 No.14 2.6(Land) 2(TH) ) ole 1 Ø (H 1.1 12 16.5 No.15 No.16 POSITIONING HOLE No.27 No.26 0.65(TH) 1.25(Land) 2.75 4.4 7.4 3.6 PAD FOR SHELL 1 ●DH80A-27P 27.8 Ø1 .8 21.3 13 H) (T Ø2 .4 (L an d PAD FOR SHELL ) PAD FOR TERMINAL No.13 No.14 2.6(Land) 2(TH) No.15 No.16 1 12 16.5 No.27 No.26 0.65(TH) 1.25(Land) POSITIONING HOLE ) (H ole Ø1 .1 2.75 4.4 7.4 3.6 No.2 No.1 1 0.43 ■Terminal No.chart ●DH60-**P, DH60A-**P D No.1 No.(N+3)/2 No.2 No.(N+5)/2 No.(N+1)/2 No.N No.(N-1)/2 No.(N-1) *N:Number of positions 23 DH Series●High speed transmission, 1mm pitch Small Interface Connector ■Panel cutout ●Screw lock type Panel cutout for reference (Right angle type, Straight type) (The dimension is specified based on the center of the connector interface) DH-LNA(CL244-0045-0-00) A 5 Ø2 .5 2.5 B PCB MOUNTING SURFACE POSITION *Please set piercing R as less than R1. DH-LNA-W4(CL244-0046-2-00) DH-LNA-W8(CL244-0004-2-00) DH-LNA-W16(CL244-0005-5-00) C 5 2.5 2.9 D 2-R A·B·C·D dimension table *Please set piercing R as less than R1. 1.1 PCB MOUNTING SURFACE POSITION Unit:mm Number of contacts A B C D 17 19.2 13.7 22 15 27 24.2 18.7 27 20 37 29.2 23.7 32 25 51 36.2 30.7 39 32 Connector mounted on PCB (For example, panel thickness is 1.6mm) *The drawing is shown sample of DH60-27P. PCB *LOCK SCREW (DH-LNA) 30 24.2 PANEL 2.5 30.8 24.2 PANEL 4.6 4.8 PCB t=1.6 PANEL BACKSIDE PCB MOUNTING SURFACE PCB MOUNTING SURFACE Panel cutout for reference *An attachment to the panel needs screws shown in the table below. Applicable panel thickness(mm) Part No. Code No. 1.4 to 1.6 DH-LNA 244-0045-0-00 0.9 to 1.2 DH-LNA-W4 244-0046-2-00 0.5 to 0.8 DH-LNA-W8 244-0004-2-00 No panel DH-LNA-W16 244-0005-5-00 *The recommended screw tightening torque to be from 0.12 to 0.3 N·m 24 PCB *PANEL t=1.6 *PANEL t=1.6 4.9 8 PANEL BACKSIDE PCB t=1.6 *DH80-27P DH Series●High speed transmission, 1mm pitch Small Interface Connector ●One Touch Lock Type Panel cutout for reference (Right angle type, Straight type) (The dimension is specified based on the center of the connector interface) A 2.5 5 2.4 B .1 R1 2- PCB MOUNTING SURFACE POSITION *Please set piercing R as less than R1. A·B dimension table Unit:mm Number of contacts A B 17 23.5 18 27 28.5 23 37 33.5 28 51 40.5 35 Connector mounted on PCB PCB t=1.6 MAX *SCREW FOR INSTALATION 30.8 26.2 PANEL PANEL BACKSIDE PCB MOUNTING SURFACE *SCREW FOR INSTALATION Ø3.5 30.8 26.2 PANEL *Installation with the panel must use a dedicated screw. Purchase:qHRS part No.[DH60A-SCREW] CL No.[CL244-0042-1] wNITTOSEIKO Co., Ltd. [FINE PAN HEAD MACHINE SCREW 2 TYPES] *SCREW FOR INSTALATION Ø3.5 *Installation with the panel must use a dedicated screw. Purchase:qHRS part No.[DH80A-SCREW] CL No.[CL244-0059-4] wNITTOSEIKO Co., Ltd. [FINE PAN HEAD MACHINE SCREW 2 TYPES] *SCREW FOR INSTALATION Ø3.5 M2∞0.4∞10 0.6 0.6 PCB t=1.6 4.6 4.8 2.5 PCB MOUNTING SURFACE PCB t=1.6MAX 0.6 5.1 4.9 8.4 8 PANEL BACKSIDE PCB t=1.6 *DH80A-27P *DH60A-27P is representative examples. M2∞0.4∞5 25 DH Series●High speed transmission, 1mm pitch Small Interface Connector ■Applicable tools Part No. Process 1 Cable end processing CL No. manual work 2 Upper level wire arranging 3 Upper level press fitting 4 Lower level wire arranging wire arranging tool : DH/CA-MO CL902-2183-0 5 Lower level press fitting 6 Cable cutting 7 IDC manual work(nipper etc.) ➀ IDC·clamping tool:DH/IDCK-MP CL902-2185-5 ➁ attachment for 17pos:DH-17UNIT CL902-2186-8 attachment for 27pos:DH-27UNIT CL902-2187-0 attachment for 37pos:DH-37UNIT CL902-2188-3 attachment for 51pos:DH-51UNIT CL902-2189-6 ➂ HI-FLEX termination press (Select appropriate attachment of each pin count from ➁.) 8 Cable clamping ➀ IDC·clamping tool:DH/IDCK-MP CL902-2185-5 ➁ attachment for DH-17-CMB(6.3):DH-17-CMB(6.3)UNIT CL902-2190-5 attachment for DH-27-CMB(6.9):DH-27-CMB(6.9)UNIT CL902-2194-6 attachment for DH-27-CMB(7.3):DH-27-CMB(7.3)UNIT CL902-2191-8 attachment for DH-37-CMB(8.8):DH-37-CMB(8.8)UNIT CL902-2192-0 attachment for DH-51-CMB(9.6):DH-51-CMB(9.6)UNIT CL902-2193-3 ➂ HI-FLEX termination press (Select appropriate attachment of each pin count from ➁.) 9 Cover attaching CL550-0082-2 CL550-0082-2 manual work(torque driver etc.) *Customers already having HI-FLEX termination press can apply it to this product assembly. *Each ➀ and ➂ of 7. IDC and 8. Clamping are the same tools. All the parts ➀, ➁ and ➂ are required for each 7. IDC and 8. Clamping processes for mass-production. 26 DH Series●High speed transmission, 1mm pitch Small Interface Connector NOTES : 27 DH Series●High speed transmission, 1mm pitch Small Interface Connector USA: HIROSE ELECTRIC (U.S.A.), INC. Headquarters 2688 Westhills Court, Simi Valley, CA 93065-6235 Phone : 1-805-522-7958 Fax : 1-805-522-3217 http://www.hiroseusa.com USA: HIROSE ELECTRIC (U.S.A.), INC. North California Office 20400 Stevens Creek Blvd., Ste 250, Cupertino, CA 95014 Phone : 1-408-253-9640 Fax : 1-408-253-9641 http://www.hiroseusa.com USA: HIROSE ELECTRIC (U.S.A.), INC. Detroit Office (Automotive) 37677 Professional Center Drive, Suite #100C Livonia, MI 48154 Phone : 1-734-542-9963 Fax : 1-734-542-9964 http://www.hiroseusa.com GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Herzog-Carl-Strasse 4 D-73760 Ostfildern (Scharnhauser Park) Phone : 49-711-4560-02-1 Fax : 49-711-4560-02-299 http://www.hirose.de THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : 31-20-6557460 Fax : 31-20-6557469 http://www.hiroseeurope.com UK: HIROSE ELECTRIC EUROPE B.V. UK BRANCH First Floor, St Andrews House, Caldecotte Lake Business Park, Milton Keynes MK7 8LE Phone : 44-1908-369060 Fax : 44-1908-369078 http://www.hirose.co.uk CHINA: HIROSE ELECTRIC CO., LTD. BEIJING REPRESENTATIVE OFFICE A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, Chao Yang District, Beijing, 100025 Phone : 86-10-5165-9332 Fax : 86-10-5908-1381 http://www.hirose-china.com.cn CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 1501-02, Cross Tower Building, 318 Fuzhou Road, Huang Pu District, Shanghai 200001 Phone : 86-21-6391-3355 Fax : 86-21-6335-0767 http://www.hirose-china.com.cn CHINA: HIROSE ELECTRIC CO., LTD. SHENZHEN OFFICE Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre 5002, ShenNanDong Road, ShenZhen City, Guangdong Province, 518008 Phone : 86-755-8207-0851 Fax : 86-755-8207-0873 http://www.hirose-china.com.cn HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Unit 1102 A&B, Energy Plaza, 92 Granville Road, Tsim Sha Tsui East, Kowloon Phone : 852-2803-5338 Fax : 852-2591-6560 http://www.hirose-hongkong.com.hk TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : 886-2-2555-7377 Fax : 886-2-2555-7350 http://www.hirose-taiwan.com.tw SINGAPORE: HIROSE ELECTRIC CO., LTD. 10 Anson Road #26-16 International Plaza 079903 Phone : 65-6324-6113 Fax : 65-6324-6123 http://www.hirose-singapore.com.sg KOREA: HIROSE KOREA CO., LTD. 1261-10, Jeoungwhang-Dong, Shihung-City, Kyunggi-Do 429-450 Phone : 82-31-496-7000,7124 Fax : 82-31-496-7100 http://www.hirose.co.kr ® 28 5-23,OSAKI 5-CHOME,SHINAGAWA-KU,TOKYO 141-8587,JAPAN PHONE: 81-3-3491-5300, FAX: 81-3-3495-5230 http://www.hirose.com http://www.hirose-connectors.com The contents of this catalog are current as of date of 09/2010. Contents are subject to change without notice for the purpose of improvements. DH シリーズ ハーネス治具設置メーカー 一覧 2012/04/1 現在 as of Apr. 1, 2012 List of Cable Assembly House for DH Series 地域 対応メーカー / 代理店 住所 連絡先 ホームページアドレス Region Assy House/Distributer Address Contact HP 日立電線ファインテック株式会社 Hitachi Cable Fine-Tech,Ltd. 〒 319-1411 茨城県日立市川尻町4-10-1 4-10-1,Kawajiricho, TEL:0294-42-5480 FAX:0294-43-6169 http://www.fine.hitachi-cable.co.jp/ Hitachi-Shi, Ibaraki, 319-1411, Japan 株式会社 マルニックス Marunix Co. , Lt d. 〒343-0011 埼玉県越谷市増林6794-2 6794-2, Masubayashi, TEL:048-965-0200 FAX:048-965-2327 http://www.marunix.co.jp Koshigaya-Shi, Saitama, 343-0011, Japan 平河ヒューテック株式会社 HIRAKAWA-HEWTECH CORP. 〒140-8551 東京都品川区南大井3-28-10 JK大森ビル JK OomoriBldg, 3-28-10, TEL:03-5493-1721 http://www.hewtech.co.jp/ FAX:03-5493-1702 index.html Minami-oi, Shinagawa-Ku, Tokyo, 140-8511, Japan 日本 Japan インターワイヤード株式会社 INTERWAIRERD.CO.,LTD. 〒140-8547 東京都品川区南大井5-19-8 5-19-8,Minami-oi, TEL:03-3761-6787 (代) http://www.interwired.co.jp/ FAX:03-3765-7873 Shinagawa-Ku, Tokyo, electricwire/index.html 140-8547, Japan 日星電気株式会社 NISSEI ELECTRIC CO.,LTD. 〒432-8006 静岡県浜松市西区大久保町 1509番地 1509, Ookubo-Cho, TEL:053-485-4705 (代) FAX:053-485-5444 http://www.nissei-el.co.jp/ Nishi-Ku, Hamamatsu-Shi, Shizuoka, 432-8006, Japan ダイトデンソー株式会社 DAITO DENSO CO.,LTD. 〒520-3044 滋賀県栗東市伊勢落宇野神 689番地1 1-689, Azanogami, Iseochi, Ritto-Shi, Shiga, 520-3044, Japan TEL:077-553-7600(代) FAX:077-553-7877 http://www.daitodenso.co.jp/ Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Hirose Electric: DH-27-CMB(6.9)UNIT DH-27-CMB(7.3)UNIT DH-37-CMB(8.8)UNIT DH-IDCK/MP DH80A-SCREW DH-17CMB(6.3)UNIT DH-51-CMB(9.6)UNIT DH-27-CMB(6.9) DH-27-CMB(7.3) DH-27-CT1B DH-27-CT2B DH-27-CV1B DH-27-CV2B DH-37-CMB(8.8) DH-37-CT1B DH-37-CT2B DH-37-CV1B DH-37-CV2B DH40-27S DH40-37S DH60-27P DH60-37P DH60A-27P DH60A-37P DH60A-SCREW DH80-27P DH-LNA DH-LNA-W16 DH-LNA-W4 DH-LNA-W8 DH32B-27S DH80A-27P DH40-17S DH40-51S DH32B-17S DH32B-37S DH60A-37P-L DH60A-51PL DH32B-51S DH-51-CMB(9.0) DH-37-CMB(7.8) DH-17-CMB(5.6) DH-17-CV1B(13) DH-27-CV1B(13) DH-27UNIT DH-51UNIT DH32B-27S/CU-MP(62) DH32/CK-MP(71) DH-37-CV1B(13) DH-17UNIT DH/CA-MD DH-37CMB(7.8)UNIT DH-17-CMB(5.6)UNIT DH-37UNIT DH-17-CMB(6.6)UNIT DH-51-CMB(9.0)UNIT DH-51-CV1B(13) DH32B-27S/CU-MP(61) DH30B-51S DH30B-27S DH30B-17S DH30B-37S
DH-17-CMB(5.6)UNIT 价格&库存
很抱歉,暂时无法提供与“DH-17-CMB(5.6)UNIT”相匹配的价格&库存,您可以联系我们找货
