53073607
53073607
    ASTROTOOL
    EJECTOR MINI LOCATOR
53073607 数据手册
Extract from the online catalog     RW 8 Order No.: 3073607 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=3073607   Feed-through terminal block, Connection method: Bolt connection, Load current : 125 A, Cross-section: 2.5 mm² - 35 mm², AWG 14 - 2, Connection direction of the conductor to plug-in direction: 0 °, Width: 20.3 mm, Color: gray   Product notes WEEE/RoHS-compliant since: 02/07/2008 Commercial data GTIN (EAN) 4 046356 368414 sales group A420 Pack 10 pcs. Customs tariff 85369010 Catalog page information Page 56 (NTK-2010) http:// www.download.phoenixcontact.com Please note that the data given here has been taken from the online catalog. For comprehensive information and data, please refer to the user documentation. The General Terms and Conditions of Use apply to Internet downloads. Technical data General Number of levels 1 Number of connections 2 Color gray PHOENIX CONTACT Inc., USA http://www.phoenixcon.com Page 1 / 4 May 9, 2011 RW 8 Order No.: 3073607 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=3073607 Insulating material PA Inflammability class acc. to UL 94 V0 Dimensions Width 20.3 mm Technical data Maximum load current 125 A Rated surge voltage 6 kV Pollution degree 3 Surge voltage category III Insulating material group I Connection in acc. with standard IEC 60947-7-1 Nominal current IN 125 A Nominal voltage UN 1000 V Connection data Conductor cross section solid min. 2.5 mm² Conductor cross section solid max. 35 mm² Conductor cross section stranded min. 2.5 mm² Conductor cross section stranded max. 35 mm² Conductor cross section AWG/kcmil min. 14 Conductor cross section AWG/kcmil max 2 Connection method Bolt connection Screw thread M8 Tightening torque, min 4.5 Nm Tightening torque max 5 Nm Certificates / Approvals Certification PHOENIX CONTACT Inc., USA http://www.phoenixcon.com UL Page 2 / 4 May 9, 2011 RW 8 Order No.: 3073607 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=3073607 Accessories Item Designation Description 3075171 RW 8-F Flange cover, Color: gray 0820222 ZB 16,3:UNPRINTED Terminal marking 0820248 ZB 20,3:UNPRINTED Terminal marking TMT (EX9,5)R Terminal marking with 9.5 mm strip height, continuous, without color print, for all terminals with ZB or ZBF groove, can be labeled using a thermal transfer printer, 1 roll = 50 m SZS 1,0X6,5 VDE Screwdriver, bladed, VDE insulated, size: 1.0 x 6.5 x 150 mm, 2component grip, with non-slip grip General Marking 0828295 Tools 1205079 Diagrams/Drawings Dimensioned drawing PHOENIX CONTACT Inc., USA http://www.phoenixcon.com Page 3 / 4 May 9, 2011 RW 8 Order No.: 3073607 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=3073607 Address PHOENIX CONTACT Inc., USA 586 Fulling Mill Road Middletown, PA 17057,USA Phone (800) 888-7388 Fax (717) 944-1625 http://www.phoenixcon.com © 2011 Phoenix Contact Technical modifications reserved; PHOENIX CONTACT Inc., USA http://www.phoenixcon.com Page 4 / 4 May 9, 2011
53073607 价格&库存
很抱歉,暂时无法提供与“53073607”相匹配的价格&库存,您可以联系我们找货
