The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information.
All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative.
2mm Pitch Connector for Discrete Wire Connection(Product approved by UL CSA Standard)
DF3 Series
■Features
Correspond to Board Design in Wide Variation
●ID Socket
(1) Low profile design with the mounting height of 6.8mm
(2) Achieves the multi-harness by the full automatic ID machine in combination with the DF11 series ID
type.
(DF11 series represents the 2mm pitch single-row product.Please refer to page B220 to B233.)
●Crimp Socket
(1) Low profile design with mounting height 7.5mm.
(2) Provide the contact crimping area with the sufficient space, and secures the stable crimping
operation.
●Receptacle
(1) The board can be connected horizontally or vertically in combination with the straight header with the
right angle header.
(2) For horizontal connection, the board to board size is the low profile of 6.6mm.
(3) Compatibility with the in-line plug allows the receptacle to set the board side to the receptacle and
the cable side to the plug in the board to cable connection.
●Pin Header
(1) The board pre-fixed kink is treated with the post pin.
(2) The style employs a scoop-proof and sturborn box type.
(3) The type corresponding to SMT is avilable, using the heat-proof resin.
This SMT header is equipped with the metal tab to prevent peeling in the solder joint area.
●In-line Plug
(1) The crimping in-line plug consits of two types, one type, which has pursued after space merits, and
the other employs the panel lock type, which can be fixed to the panel.
(2) The in-line adapter is available to insert and in-line the ID socket from both sides.
■Applications
Business equipment such as copy machine and printer
B207
All non-RoHS
products
soon. PleaseWire
checkConnection(Product
website RoHS
DF3
Series●2mm
Pitch Connector
for Discrete
approved
bysearch
UL CSA
Standard)
■Product Specifications
Crimping
Current rating
Rating
Wire size
Note 1
IDC
Voltage rating AC100V Crimping
AWG#22 to 24 :3A
Operating Temperature Range -30ç to +85ç Note 2.
AWG#26
:2A
Operating Humidity Range
AWG#28
:1A
Wire size
AWG 26, 28:1A
Press-fit: 250V AC
IDC
Storage Temperature Range -10ç to +60ç Note 3.
Press-connect: 100V AC
Storagg Humidity Range
UL-CSA Safety Standard and Approved specification
Rated Current
Wire size
Rating
Rated Voltage
AWG 24 to 28: 1A
30V AC
Item
40% to 70% Note 3.
■UL CSA Safety Standard File No.
UL
:E52653
CSA
:LR95109
■UL CSA Acquisition Objective Item
1DF3-*S-2C
2DF3/3A-*P-2DSA/DS
3DF3/DF3AA-*EP-2C
4DF3-*S-2R26/28
5DF3-*P-2H
Specification
Condition
1. Insulation Resistance
1000M ohms min.
500V DC
2. Withstanding voltage
No flashover or insulation breakdown.
650V AC/1 minute
3. Contact Resistance
30m ohms max
100mA
4. Single Insertor/Extraction Force MIN0.3N (30gf), MAX4.4N(450gf)
5. Vibration
40% to 80%
Measure by the square steel pin with 0.5±0.002mm
No electrical discontinuity of 1µs or more
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
6. Humidity (Steady state) Contact resistance: 30m ohms max.Insulation resistance: 500M ohms min.
96 hours at temperature of 40ç and humidity of 90% to 95%
7. Temperature Cycle
(-55ç: 30 minutes 5 to 35ç: 10 minutes 85ç: 30 minutes 5 to 35ç: 10minutes) 5 cycles
Contact resistance: 30m ohms max.:Insulation resistance: 1000M ohms min.
8. Durability (Mating/un-mating) Contact resistance: 30m ohms max.
Tin plating: 30 cycles Gold plating: 50 cycles
9. Resistance to Soldering Heat No deformation of components affecting performance.
Flow: 260ç for 10 seconds Manual soldering: 300ç for 2 seconds
Reflow: At the recommended temperature profile Manual soldering: 300ç for 3 seconds
Note 1: Current rating of header is 3A.
Note 2: Includes temperature rise caused by current flow.
Note 3: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 4: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for
a specific part number shown.
■Material
Product
Part
Crimping Socket
Insulator
IDC Contact for Socket
Contact
ID Socket
Receptacle
Pin Header
SMT Pin Header
Finish
Remarks
Polyamide
Black
UL94V-0
Phosphor bronze
Tin plated or gold plated
Insulator
Polyamide
Black
UL94V-0
Contact
Phosphor bronze
Insulator
Polyamide
Black
UL94V-0
Contact
Phosphor bronze
Insulator
Polyamide
Black
UL94V-0
Contact
Brass
Insulator
Polyamide
Beige
UL94V-0
Contact
Brass
Metal tab
Brass
Tin plated
In-line Plug
Insulator
Polyamide
Black
UL94V-0
In-line IDC Contact
Contact
Phosphor bronze
Insulator
Polyamide
Black
UL94V-0
Contact
Brass
Tin plated
In-line Adapter
B208
Materia
soon. Please checkPitch
the products
status on for
the Hirose
websiteWire
RoHS search
or contact
representative.
DF3 Series●2mm
Connector
Discrete
Connection(Product
approved
by your
UL Hirose
CSA sales
Standard)
■Ordering Information
●Connector
DF3 - * S - 2C
q
w
e
rt
: DF3, 3A, 3AA t Connection Form/Contact Style
q Series Name
w Number of Contacts : 2~15
C
e Connector Type
R26 : ID socket for AWG26
: Crimp socket
S
: Socket
R28 : ID socket for AWG28
P
: Pin Header
DSA : Straight through hole
EP
: In-line Plug
DS : Right angle through hole
: 2mm
V
: Straight SMT
H
: Right angle SMT
A
: Adapter
r Contact Pitch
●Contact
DF3 - EP2428PCFA
q
q Contact Type
w
e
r
e Contact Type/Packaging Type
Blank : For socket
SCF
: Socket contact, Reel
EP
SC
: Socket contact, Bag
PCF
: Plug contact, Reel
PC
: Plug contact, Bag
: For in-line plug
w Applicable Wire Size
22
: AWG#22
2428 : AWG#24 to#28
r Plating Type
Blank
: Tin plated
A
: Gold plated (Plug contact)
C
: Gold plated (Socket contact)
■Application pattern
DF3-πS-2R**(05)
DF3Z-πP-2H
DF3-πS-2R**(05)
DF3Z-πP-2V
DF3Z-πP-2H
DF3Z-πP-2V
DF3-πS-2DSA(25)
DF3Z-πP-2H
DF3Z-πP-2V
B209
All non-RoHS
products
soon. PleaseWire
website RoHS
DF3
Series●2mm
Pitch Connector
for Discrete
approved
bysearch
UL CSA
Standard)
■ID Socket
[Specific No.]–* *, (* *)
(01)
: Gold plated, 100 pieces per bag
(05)
: Tin plated, 100 pieces per bag
(25)
: Tin plated, Tube packaging
This picture shows the cable
assembled status.
Note 1.
Mark to determine the socket name
Mark6: R26, Mark8: R28
●AWG#28
Unit: mm
Unit: mm
Number of
Tube packaging
Number of
Tube packaging
Part Number
CL No.
A B
RoHS
Part Number
CL No.
A B
RoHS
Contacts
Quantity
Contacts
Quantity
DF3- 2S-2R26(**) 543-0078-7-**
2
6 2 190 pieces
DF3- 2S-2R28(**) 543-0092-8-**
2
6 2 190 pieces
DF3- 3S-2R26(**) 543-0079-0-**
3
8 4 142
DF3- 3S-2R28(**) 543-0093-0-**
3
8 4 142
DF3- 4S-2R26(**) 543-0080-9-**
4
10 6 114
DF3- 4S-2R28(**) 543-0094-3-**
4
10 6 114
DF3- 5S-2R26(**) 543-0081-1-**
5
12 8 94
DF3- 5S-2R28(**) 543-0095-6-**
5
12 8 94
DF3- 6S-2R26(**) 543-0082-4-**
6
14 10 80
DF3- 6S-2R28(**) 543-0096-9-**
6
14 10 80
DF3- 7S-2R26(**) 543-0083-7-**
7
16 12 70
DF3- 7S-2R28(**) 543-0097-1-**
7
16 12 70
DF3- 8S-2R26(**) 543-0084-0-**
8
18 14 62
DF3- 8S-2R28(**) 543-0098-4-**
8
18 14 62
YES
YES
DF3- 9S-2R26(**) 543-0085-2-**
9
20 16 56
DF3- 9S-2R28(**) 543-0099-7-**
9
20 16 56
DF3-10S-2R26(**) 543-0086-5-** 10
22 18 52
DF3-10S-2R28(**) 543-0100-4-** 10
22 18 52
DF3-11S-2R26(**) 543-0087-8-** 11
24 20 46
DF3-11S-2R28(**) 543-0101-7-** 11
24 20 46
DF3-12S-2R26(**) 543-0088-0-** 12
26 22 44
DF3-12S-2R28(**) 543-0102-0-** 12
26 22 44
DF3-13S-2R26(**) 543-0089-3-** 13
28 24 40
DF3-13S-2R28(**) 543-0103-2-** 13
28 24 40
DF3-14S-2R26(**) 543-0090-2-** 14
30 26 38
DF3-14S-2R28(**) 543-0104-5-** 14
30 26 38
DF3-15S-2R26(**) 543-0091-5-** 15
32 28 34
DF3-15S-2R28(**) 543-0105-8-** 15
32 28 34
Note 2.The quantity for delivery of the specific No. (01) and (05) is determined per bag (100pcs.). If needed, please order the
productsper bag.
Note 3.If the Full automatic IDC machine to hit the DF11 single core,the (25) tube packaging specification will be applied.
Note 4.Order the tube packaging product, multiplying the tube packaging quantity (pieces).
●AWG#26
■Applicable Cable
Part Number
Applicable Cable
Jacket Diameter
DF3-*S-2R26(**)
UL1061 AWG#26 (7/0.16)
Ø0.9 to 1mm
DF3-*S-2R28(**)
UL1061 AWG#28 (7/0.127)
Ø0.9 to 1mm
■Applicable ID Connection Tool
B210
Type
Part Number
DF11 Single Contact Punching
Full Automatic ID Machine
AM700/DF11
DF3 DF4 Desktop ID Machine
SA701/DF3
Connection Type
■ Effective Harness Form
1DF11-Both ended, single ended
2DF11-DF11, Separation
3DF11-DF3, Separation
■ Effective Harness Length
100 to 2,000mm
■ Conduction Inspection Mechanism Installed
DF3 No restriction
DF4 No restriction
Remarks
Connector is the
specification (25).
Tube packaging applied
Desktop machine for small lot
the products
status on for
the Hirose
websiteWire
RoHS search
or contact
representative.
DF3 Series●2mm
Connector
Discrete
Connection(Product
approved
by your
UL Hirose
CSA sales
Standard)
■Crimping Socket
[Specific No.] –* *, (* *)
Blank: 100 pieces per pack
This picture shows the Contact
crimped status.
Unit: mm
Number of Contacts
A
B
DF3-2S-2C(**) 543-0003-8-**
2
06
02
DF3-3S-2C(**) 543-0004-0-**
3
08
DF3-4S-2C(**) 543-0005-3-**
4
10
DF3-5S-2C(**) 543-0006-6-**
5
12
08
DF3-6S-2C(**) 543-0007-9-**
6
14
10
DF3-7S-2C(**) 543-0008-1-**
7
16
12
Part Number
CL No.
Number of Contacts
A
B
DF3-19S-2C(**) 543-0010-3-**
09
04
DF3-10S-2C(**) 543-0011-6-**
10
22
18
06
DF3-11S-2C(**) 543-0012-9-**
11
24
DF3-12S-2C(**) 543-0013-1-**
12
26
22
DF3-13S-2C(**) 543-0014-4-**
13
28
24
DF3-14S-2C(**) 543-0015-7-**
14
30
26
RoHS
YES
Part Number
CL No.
RoHS
YES
14
28
18
32
8
15
DF3-8S-2C(**) 543-0009-4-**
DF3-15S-2C(**) 543-0016-0-**
Note1: The product's contact number indicated.
Note2: The quantity for delivery of the specification No. "None" is determined per bag (100 pcs.).
If needed, please order the products per bag.
Note3: A quantity of "500 pieces package" and "1000 pieces package" for delivery is dealt with pieces. Order example: 500, 1000, and 1500 pieces...
■Receptacle
(25) :Tin plated, Tube packaging
(55) :Gold plated, Tube packaging
●Board Through-hole Diameter: Ø0.8++0.1
Unit: mm
Part Number
CL No.
Number of Contacts A
B
Tube Package
RoHS
Quantity
Part Number
CL No.
B
Tube Package
RoHS
Quantity
DF3-2S-2DSA(**) 543-0048-6-**
2
06 02 80 pieces
DF3- 9S-2DSA(**) 543-0055-1-**
09
20 16 24 pieces
DF3-3S-2DSA(**) 543-0049-9-**
3
08 04 60
DF3-10S-2DSA(**) 543-0056-4-**
10
22 18 21
DF3-4S-2DSA(**) 543-0050-8-**
4
10 06 48
DF3-11S-2DSA(**) 543-0057-7-**
11
24 20 20
DF3-5S-2DSA(**) 543-0051-0-**
5
12 08 40
DF3-12S-2DSA(**) 543-0058-0-**
12
26 22 18
DF3-6S-2DSA(**) 543-0052-3-**
6
14 10 34
DF3-13S-2DSA(**) 543-0059-2-**
13
28 24 17
DF3-7S-2DSA(**) 543-0053-6-**
7
16 12 30
DF3-14S-2DSA(**) 543-0060-1-**
14
30 26 16
18 14 27
8
DF3-8S-2DSA(**) 543-0054-9-**
DF3-15S-2DSA(**) 543-0061-4-**
Note2: Please order the tube packaging at the multiplied tube packaging quantity (pieces).
15
32 28 15
YES
YES
B211
All non-RoHS
products
soon. PleaseWire
website RoHS
DF3
Series●2mm
Pitch Connector
for Discrete
approved
bysearch
UL CSA
Standard)
■Straight Pin Header
●Kink Pre-fixed Effective Diameter: Ø0.8++0.05
Unit: mm
Tin Plating
Gold Plating
Part Number
CL No.
Part Number
CL No.
543-0017-2-01
543-0165-0
DF3A- 2P-2DSA
DF3- 2P-2DSA(01)
543-0018-5-01
543-0166-2
DF3A- 3P-2DSA
DF3- 3P-2DSA(01)
543-0019-8-01
543-0167-5
DF3A- 4P-2DSA
DF3- 4P-2DSA(01)
543-0020-7-01
543-0168-8
DF3A- 5P-2DSA
DF3- 5P-2DSA(01)
543-0021-0-01
543-0169-0
DF3A- 6P-2DSA
DF3- 6P-2DSA(01)
543-0022-2-01
543-0170-0
DF3A- 7P-2DSA
DF3- 7P-2DSA(01)
543-0023-5-01
543-0171-2
DF3A- 8P-2DSA
DF3- 8P-2DSA(01)
543-0024-8-01
543-0172-5
DF3A- 9P-2DSA
DF3- 9P-2DSA(01)
543-0025-0-01
543-0173-8
DF3A-10P-2DSA
DF3-10P-2DSA(01)
543-0026-3-01
543-0174-0
DF3A-11P-2DSA
DF3-11P-2DSA(01)
543-0027-6-01
543-0175-3
DF3A-12P-2DSA
DF3-12P-2DSA(01)
543-0028-9-01
543-0176-6
DF3A-13P-2DSA
DF3-13P-2DSA(01)
543-0029-1-01
543-0177-9
DF3A-14P-2DSA
DF3-14P-2DSA(01)
543-0030-0-01
543-0178-1
DF3A-15P-2DSA
DF3-15P-2DSA(01)
Note : The quantity for delivery is determined per bag (100 pcs.). If needed, please order the products per bag.
2
3
4
5
6
7
8
9
10
11
12
13
14
15
06
08
10
12
14
16
18
24
26
28
30
32
B RoHS
02
04
06
08
10
12
14
YES
16
18
24
26
28
■Right Angle Pin Header
Unit: mm
Tin Plating
Gold Plating
Part Number
CL No.
Part Number
CL No.
543-0179-4
543-0031-3-01
DF3A- 2P-2DS
DF3- 2P-2DS(01)
543-0180-3
543-0032-6-01
DF3A- 3P-2DS
DF3 -3P-2DS(01)
543-0181-6
543-0033-9-01
DF3A- 4P-2DS
DF3- 4P-2DS(01)
543-0182-9
543-0034-1-01
DF3A- 5P-2DS
DF3- 5P-2DS(01)
543-0183-1
543-0035-4-01
DF3A- 6P-2DS
DF3- 6P-2DS(01)
543-0184-4
543-0036-7-01
DF3A- 7P-2DS
DF3- 7P-2DS(01)
543-0185-7
543-0037-0-01
DF3A- 8P-2DS
DF3- 8P-2DS(01)
543-0186-0
543-0038-2-01
DF3A- 9P-2DS
DF3- 9P-2DS(01)
543-0187-2
543-0039-5-01
DF3A-10P-2DS
DF3-10P-2DS(01)
543-0188-5
543-0040-4-01
DF3A-11P-2DS
DF3-11P-2DS(01)
543-0189-8
543-0041-7-01
DF3A-12P-2DS
DF3-12P-2DS(01)
543-0190-7
543-0042-0-01
DF3A-13P-2DS
DF3-13P-2DS(01)
543-0191-0
543-0043-2-01
DF3A-14P-2DS
DF3-14P-2DS(01)
543-0192-2
543-0044-5-01
DF3A-15P-2DS
DF3-15P-2DS(01)
Note : The quantity for delivery is determined per bag(100 pcs.). If needed, please order the products per bag.
B212
2
3
4
5
6
7
8
9
10
11
12
13
14
15
06
08
10
12
14
16
18
24
26
28
30
32
B RoHS
02
04
06
08
10
12
14
YES
16
18
24
26
28
the products
status on for
the Hirose
websiteWire
RoHS search
or contact
representative.
DF3 Series●2mm
Connector
Discrete
Connection(Product
approved
by your
UL Hirose
CSA sales
Standard)
■Straight Pin Header (SMT)
BPCB mounting pattern
C
Note :
If a pattern is included in the shaded area and is not treated with resist,
it could touch the connector contact.
(21) :Tin plated packaging
(51) :Gold plated packaging
Unit: mm
Without Boss
Part Number
CL No.
Number of
Contacts
A
DF3DZ- 2P-2V(**)
0543-1056-0-**
2
02
08.5 08.74
DF3DZ- 3P-2V(**)
0543-1057-2-**
3
04
10.5 10.74
DF3DZ- 4P-2V(**)
0543-1058-5-**
4
06
12.5 12.74
DF3DZ- 5P-2V(**)
0543-1059-8-**
5
08
14.5 14.74
DF3DZ- 6P-2V(**)
0543-1060-7-**
6
10
16.5 16.74
DF3DZ- 7P-2V(**)
0543-1061-0-**
7
12
18.5 18.74
DF3DZ- 8P-2V(**)
0543-1062-2-**
8
14
20.5 20.74
DF3DZ- 9P-2V(**)
0543-1063-5-**
9
16
22.5 22.74
DF3DZ-10P-2V(**)
0543-1064-8-**
10
18
24.5 24.74
DF3DZ-11P-2V(**)
0543-1065-0-**
11
DF3DZ-12P-2V(**)
0543-1066-3-**
12
22
28.5 28.74
DF3DZ-13P-2V(**)
0543-1067-6-**
13
24
30.5 30.74
DF3DZ-14P-2V(**)
0543-1068-9-**
14
26
32.5 32.74
B
C
RoHS
YES
15
0543-1069-1-**
DF3DZ-15P-2V(**)
28 34.5 34.74
Note1: Please order the emboss packaging product by the reel number. (1 reel : 1000 pcs.)
Note2: Embossed packaging products have the reel wrapped in polyethylene and include a desiccant.
Note3: Small blisters of the molding compounds in small areas will not affect from,fit or function.
B213
All non-RoHS
products
soon. PleaseWire
website RoHS
DF3
Series●2mm
Pitch Connector
for Discrete
approved
bysearch
UL CSA
Standard)
■Right Angle Pin Header (SMT)
D
(21) :Tin plated embossed packaging
(Note the number of contacts
for marchandization.)
(51) :Gold plated embossded packaging
Unit: mm
Without Boss
Part Number
CL No.
Number of
Contacts
A
DF3DZ- 2P-2H(**)
0543-1070-0-**
2
02
08.5 08.74
DF3DZ- 3P-2H(**)
0543-1071-3-**
3
04
10.5 10.74
DF3DZ- 4P-2H(**)
0543-1072-6-**
4
06
12.5 12.74
DF3DZ- 5P-2H(**)
0543-1073-9-**
5
08
14.5 14.74
DF3DZ- 6P-2H(**)
0543-1074-1-**
6
10
16.5 16.74
DF3DZ- 7P-2H(**)
0543-1075-4-**
7
12
18.5 18.74
DF3DZ- 8P-2H(**)
0543-1076-7-**
8
14
20.5 20.74
DF3DZ- 9P-2H(**)
0543-1077-0-**
9
16
22.5 22.74
DF3DZ-10P-2H(**)
0543-1078-2-**
10
18
24.5 24.74
DF3DZ-11P-2H(**)
0543-1079-5-**
11
DF3DZ-12P-2H(**)
0543-1080-4-**
12
22
28.5 28.74
DF3DZ-13P-2H(**)
0543-1081-7-**
13
24
30.5 30.74
DF3DZ-14P-2H(**)
0543-1082-0-**
14
26
32.5 32.74
B
C
RoHS
YES
15
28 34.5 34.74
0543-1083-2-**
DF3DZ-15P-2H(**)
B214
the products
status on for
the Hirose
websiteWire
RoHS search
or contact
representative.
DF3 Series●2mm
Connector
Discrete
Connection(Product
approved
by your
UL Hirose
CSA sales
Standard)
■In-line Plug
Photo: Contact inserted status
Number of Contacts
Part Number
CL No.
543-0064-2
2
DF3- 2EP-2C
3
543-0065-5
DF3- 3EP-2C
4
543-0066-8
DF3- 4EP-2C
5
543-0067-0
DF3- 5EP-2C
6
543-0068-3
DF3- 6EP-2C
7
543-0069-6
DF3- 7EP-2C
8
543-0070-5
DF3- 8EP-2C
Note : The specific No."None" item is delivered
Number of Contacts
A
B
RoHS
Part Number
CL No.
02
06
543-0071-8
09
DF3- 9EP-2C
04
08
10
543-0072-0
DF3-10EP-2C
06
10
11
543-0073-3
DF3-11EP-2C
08
YES
12
12
543-0074-6
DF3-12EP-2C
10
14
13
543-0075-9
DF3-13EP-2C
12
16
14
543-0076-1
DF3-14EP-2C
14
18
15
543-0077-4
DF3-15EP-2C
per bag (100 pcs.). Please order products per bag unit.
■In-line Plug with Panel Lock
A
24
26
28
30
32
B
16
18
24
26
28
Unit: mm
RoHS
YES
BPanel Cutouts
Photo: Contact insertion status
Part Number
CL No.
B
2
06
DF3AA- 2EP-2C 543-0151-5
11
3
08
DF3AA- 3EP-2C 543-0152-8
13
4
10
DF3AA- 4EP-2C 543-0153-0
15
5
12
DF3AA- 5EP-2C 543-0154-3
17
6
14
DF3AA- 6EP-2C 543-0155-6
19
7
16
DF3AA- 7EP-2C 543-0156-9
21
8
18
DF3AA- 8EP-2C 543-0157-1
23
9
DF3AA- 9EP-2C 543-0158-4
25
10
22
DF3AA-10EP-2C 543-0159-7
27
11
24
DF3AA-11EP-2C 543-0160-6
29
12
26
DF3AA-12EP-2C 543-0161-9
31
13
28
DF3AA-13EP-2C 543-0162-1
33
14
30
DF3AA-14EP-2C 543-0163-4
35
15
32
DF3AA-15EP-2C 543-0164-7
37
Note : Delivered per bag (100 pcs.). Please order products
C
02
04
06
08
10
12
14
16
18
24
26
28
per
Unit: mm
D
E RoHS
9.4 6.3
11.4 8.3
13.4 10.3
15.4 12.3
17.4 14.3
19.4 16.3
21.4 18.3
YES
23.4 20.3
25.4 22.3
27.4 24.3
29.4 26.3
31.4 28.3
33.4 30.3
35.4 32.3
bag unit.
Note1: Applicable panel thickness is
1.6 to 1.0mm. (However, a
slight backlash is considered for
the thickness other than 1.6
and 1.2mm.)
Note2: Use the non-radius surface at
the hooking panel edge.
Note3: Contact No. indicates 1, 4, 8,
12, and 15.
Blank : 100 pcs. per bag
B215
All non-RoHS
products
soon. PleaseWire
website RoHS
DF3
Series●2mm
Pitch Connector
for Discrete
approved
bysearch
UL CSA
Standard)
■In-line Adapter with Panel Lock
BPanel Cutouts
Adapter to in-line by pushing 2 pcs. of
No.1-No.1 connection circuit type
Unit: mm
Part Number
CL No.
Number of Contacts
A
B
C
D
E
DF3- 2EP-2A
543-0267-0
2
11
06
02
9.4
6.3
DF3- 3EP-2A
543-0268-2
3
13
08
04
11.4
8.3
DF3- 4EP-2A
543-0269-5
4
15
10
06
13.4 10.3
DF3- 5EP-2A
543-0270-4
5
17
12
08
15.4 12.3
DF3- 6EP-2A
543-0271-7
6
19
14
10
17.4 14.3
DF3- 7EP-2A
543-0272-0
7
21
16
12
19.4 16.3
DF3- 8EP-2A
543-0273-2
8
23
18
14
21.4 18.3
DF3- 9EP-2A
543-0274-5
9
25
23.4 20.3
DF3-10EP-2A
543-0275-8
10
27
22
18
25.4 22.3
DF3-11EP-2A
543-0276-0
11
29
24
DF3-12EP-2A
543-0277-3
12
31
26
22
29.4 26.3
DF3-13EP-2A
543-0278-6
13
33
28
24
31.4 28.3
DF3-14EP-2A
543-0279-9
14
35
30
26
33.4 30.3
DF3-15EP-2A
543-0280-8
15
37
32
28
35.4 32.3
Note : Delivered per bag (100 pcs.). Please order products per bag unit.
B216
RoHS
Note1: Applicable panel thickness is 1.6
to 1.0mm.(However,backlash
will occur except for 1.6, 1.2mm
thickness.)
Note2: Please use the non-radius surface
at the hooking panel edge.
YES
the products
status on for
the Hirose
websiteWire
RoHS search
or contact
representative.
DF3 Series●2mm
Connector
Discrete
Connection(Product
approved
by your
UL Hirose
CSA sales
Standard)
■Crimping Contact for Socket
Part Number
CL No.
Type
Quantity
Finish
DF3-22SCF
543-0235-3 Reel contact
10000 pcs. per reel
DF3-22SC
543-0236-6 Bulk contact
100 pcs.
DF3-22SCFC
543-0861-0 Reel contact
10000 pcs. per reel
DF3-22SCC
543-0862-3 Bulk contact
100 pcs.
DF3-2428SCF
543-0001-2 Reel contact
10000 pcs. per reel
DF3-2428SC
543-0002-5 Bulk contact
100 pcs.
DF3-2428SCFC
543-0046-0 Reel contact
10000 pcs. per reel
DF3-2428SCC
543-0047-3 Bulk contact
100 pcs.
per pack
per pack
per pack
per pack
●Applicable Wire (Tin Plating Annealed
Copper Wire)
Conductor Size (Wire Configuration)
Jacket Diameter
AWG#22 (17pcs./0.16mm)
Ø1.2 to Ø1.45mm
RoHS
Tin plated
Gold plated
YES
Tin plated
Gold plated
●Recommended Wire
UL1061, UL1007 (Note 2.)
●Strip Length
1.8 to 2.3mm
AWG#24 (11pcs./0.16mm)
AWG#26 (7pcs./0.16mm)
Ø0.75 to Ø1.45mm
AWG#28 (7pcs./0.127mm)
Note1: If other wires are used instead of the applicable cable, please contact HRS company.
Note2: DF3-22SCF is applicable to UL1061.
■Crimping Contact for In-line Plug
Part Number
CL No.
Type
Quantity
Finish
DF3-EP2428PCF
543-0062-7 Reel contact
10000 pcs. per reel
DF3-EP2428PC
543-0063-0 Bulk contact
100 pcs.
per pack
DF3-EP2428PCFA 543-0149-3 Reel contact
10000 pcs. per reel
DF3-EP2428PCA
100 pcs.
543-0150-2 Bulk contact
per pack
Copper Wire)
Jacket Diameter
Tin plated
YES
Gold plated
●Recommended Wire
UL1061, UL1007
●Strip Length
1.9 to 2.5mm
RoHS
Ø0.75 to Ø1.45mm
BApplicable Crimping Tool
Type
Applicator
Press Unit
Hand Crimping Tool
Extraction Tool
Part Number
CL No.
Applicable Contact
AP105-DF3-2428S
901-4503-3
DF3-2428SCF/SCFC
AP105-DF3-22S
901-4549-4
DF3-22SCF
AP105-DF3-EP2428P
901-4508-7
DF3-EP2428PCF/PCFA
CM-105
901-0005-4
DF3-TA2428HC
550-0164-5
DF3-2428SC/SCC
DF3EP-TA2428HC
550-0184-2
DF3-EP2428PC/PCA
DF3-TA22HC
550-0257-4
DF3-22SC
DF-C-PO (A)
550-0170-8
DF3-****SCF
DF3-EP****PCF
Note : If any trouble has occurred due to tools other than designated tool, Hirose bears no respoisibility for any trouble.
B217
All non-RoHS
products
soon. PleaseWire
website RoHS
DF3
Series●2mm
Pitch Connector
for Discrete
approved
bysearch
UL CSA
Standard)
BEmbossed Carrier Tape Dimensions
●Straight Pin Header
1
0.
+ 0
5
0.1
12
0.1
E
6.4
0.3
1.5
0.3
0.4
0.1
0.5
0.1
13
2
0.2
1.
4
0.1
0.1
2
1.75
E-E
( 80 )
2
370
C 0.3
B
0.1
A
21 0.8
D +20
0.2
E
.75
R0
1.7 +0.05
(D+6) MAX
1.5 +0.1
Unit: mm
Product Type
Size
Number of Contacts
A
B
C
D
2 to 4
24.0
11.5
24.4
5 to 7
32.0
28.4
14.2
32.4
8 to 10
44.0
40.4
20.2
44.4
11 to 15
56.0
52.4
26.2
56.4
DF3DZ-*P-2V
●Right Angle Pin Header
12±0.1
4±0.1
1
0.
+ 0
E
5
1.
Ø
1.75±0.1
2±0.1
2±0.5
E–E
Ø80
B±0.1
A±0.3
Ø13±0.2
Ø370±2
C±0.1
Carrier hole length
E
Unreeling direction
0.2
.75
R0
D+0.2
0.4±0.1
(D+6)MAX
6.1±0.3 1.6±0.3
Unit: mm
Product Type
DF3DZ-*P-2H
B218
Size
Number of Contacts
A
B
C
D
2 to 4
24.0
11.5
24.4
5 to 7
32.0
28.4
14.2
32.4
8 to 10
44.0
40.4
20.2
44.4
11 to 15
56.0
52.4
26.2
56.4
the products
status on for
the Hirose
websiteWire
RoHS search
or contact
representative.
DF3 Series●2mm
Connector
Discrete
Connection(Product
approved
by your
UL Hirose
CSA sales
Standard)
BPrecautions
1. Recommended Temperature Profile (SMT)
temperature (ç)
10s max
250
230
200
180±10
60s max
Soldering
150
100 to 120s
Preheating
100
Time (S)
Note1: Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that
there is a return to normal temperature between the first and second cycle.
Note2: The temperature profile indicates the board surface temperature at the point of cintacts with
the connector terminals.
2. Recommended Manual Soldering Condition (SMT) Soldering iron temperature: 290±10ç, Soldering time: Within 3 seconds
3. Recommended Screen Thickness (SMT) 0.15 to 0.2mm
4. Board Warpage (SMT)
5. Recommended Soldering Condition (DIP)
Based on both connector edges, 0.03mm max. in the connector center portion
■Flow Condition with Automatic Soldering Tool. Soldering temperature: 250±5ç, Soldering time: Within 10 seconds
■Manual Soldering Condition. Soldering iron temperature: 290±10ç, Soldering time: Within 2 seconds
6. Cleaning Condition
Refer to the "Nylon Connector Use Hand book".
7. Connection Condition
8. Precations
B219
