32390
32390
    WIHA(威汉)
    TOOLS PROTURN INSUL 11PC W/BAG
32390 数据手册
www.wihatools.com 41 Wiha Insulated Industrial Tool Sets In Roll Out Pouch 1000Volt 32986 11 Pc. Pliers & Screwdriver Set. Insulation According to VDE 0682/part 201, DIN EN 60900, EN/IEC 60900, ASTM F-1505, NFPA70E, up to 1000 volt. Individually Tested. In Roll Out Pouch Set Includes: lbs. 3.62 Item# 32986 6.3” Long Nose Pliers 6.3” Diagonal Cutters 8.0” Combination Pliers 6.3” Stripping Pliers Insulated Slotted: 3.0, 4.5, 5.5mm Insulated Phillips: #1, #2 Insulated Square: #1, #2 In Roll Out Pouch 1000Volt 32973 22 Pc. Pliers & Driver Set. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505, NFPA70E & CSA, up to 1000 volt. Individually Tested. In molded tool box Item# 32973 Set Includes: lbs. 8.70 9.0” Linemans Pliers W/Cutters 8.0” Long Nose Pliers W/Cutter 8.0” Diagonal Cutters 50mm Cable Stripping Knife Insulated Slim Phillips #1, 2 Insulated Slim Slotted 3.5, 4.5mm Insulated Slim Xeno #1, 2 Insulated Slim Square #1, 2 Insulated T-handle Hex Inch: 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Insulated Inch Nut Drivers: 3/8, 7/16, 1/4, 5/16” 1000Volt Now in canvas tool bag 1000Volt 32987 8 Pc. Pliers & Cutters Set. Insulation According to VDE 0682/part 201, DIN EN 60900, EN/IEC 60900, ASTM F-1505, NFPA70E, up to 1000 volt. Individually Tested. In Roll Out Pouch Item# 32987 Set Includes: lbs. 5.52 6.3” Long Nose Pliers 6.3” Diagonal Cutters 8.0” Long Nose Pliers 8.0” H.D. Diagonal Cutters 9.0” Lineman’s w/Cutters 6.3” Stripping Pliers 8.0” Cable Cutters 7.0” Crimpers 1000Volt In Roll Out Pouches 32988 22 Pc. Pliers & Cutters Set. Insulation According to VDE 0682/part 201, DIN EN 60900, EN/IEC 60900, ASTM F-1505, NFPA70E, up to 1000 volt. Individually Tested. In Roll Out Pouches Item# 32988 Set Includes: lbs. 5.74 8.0” Long Nose Pliers 6.3” Diagonal Cutters 9.0” Lineman’s w/Cutters 8.0” H.D. Diagonal Cutters 8.0” Cable Cutters 6.3” Stripping Pliers 7.0” Crimping Pliers 15 Pc. SlimLine Blade Set includes: Insulated SlimLine Blade Holder Slotted: 3.0, 4.0, 5.5, 6.5 Phillips: #1, #2 Xeno: #1, #2 : T8, T10, T15, T20 Square: #1, #2 32390 11 Pc. Pliers & Driver Set. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505, NFPA70E & CSA, up to 1000 volt. Individually Tested. In canvas tool bag Item# 32390 Set Includes: lbs. 6.30 8.0” Linemans Pliers 6.3” Long Nose Pliers W/Cutter 8.0” Long Nose Pliers W/Cutter 6.3” Diagonal Cutter 8.0” High Leverage Cutter Insulated Phillips #0, 1, 2 Insulated Slotted 3.0, 4.5, 6.5mm 1000Volt 32399 10 Pc. Pliers & Driver Set. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505, NFPA70E & CSA, up to 1000 volt. Individually Tested. In canvas zipper pouch Item# 32399 Set Includes: lbs. 5.74 8.0” Linemans Pliers 8.0” Long Nose Pliers W/Cutter 8.0” Diagonal Cutter 6.3” Wire Stripper 10.0” Adjustable Pliers Insulated Phillips #1, 2 Insulated Slotted 3.0, 4.5, 6.5mm
32390 价格&库存
很抱歉,暂时无法提供与“32390”相匹配的价格&库存,您可以联系我们找货
    • 1+46.007421+5.94380
    • 5+44.345565+5.72910
    • 10+42.7711610+5.52570
    • 1+46.31893
    • 5+44.66596
    • 10+43.01300
