45469
45469
    GREENLEECOMMUNICATIONS(格林利)
    KITVOICE/CAT5TERM
45469 数据手册
TOM ST. VRAIN Electrician/Journeyman Wireman V O I C E • D ATA • V I D E O Premium brands known for time-tested reliability in the voice, data and video fields have come together as Tempo... ...bringing you a complete line of industry-leading tools, testers and network certification instruments for copper and fiber installation. Test equipment for the telecom industry Complete line of voice/data/video installation tools Leading provider of tone generators, probes and telephone test sets Network certification instruments for copper/fiber Fiber optic test equipment 192 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com D’VERSIBIT® System It bends to meet your needs! Fishing wire or cable through existing walls used to be frustrating and time-consuming, but the D’VersiBIT® has made it as simple as bowing the spring steel shaft in the direction you want to drill and turning on the power. Proven in the field to deliver accurate and professional results in many applications. Bits range from 3/16" to 1" (4.8 to 25.4 mm) in diameter and in shaft length from 12" to 72" (304.8 to 1828.8 mm). The D’VersiBIT® System makes it possible to easily accomplish even complex installations. This patented system attaches a quality drill bit to a long flexible spring steel shaft. When used with the Placement Tool, this flexibility makes it possible to easily manipulate the bit within walls. After drilling, attach a D’VersiGRIP to the hole in the drill and pull wire or cable back through the wall. Placement Tool Wire and Cable Pulling Grips • Allows placement of the drill bit at any point within the wall. • Helpful in judging where the bit will be during drilling to avoid accidentally drilling through the wall. • Useful for vertical and horizontal placements. Type M, Masonry CAT. NO. UPC NO. DESCRIPTION 712P 38350 D’VersiBIT® Placement Tool Type HS High Speed Steel • For drilling in • Designed for masonry walls and aggressive cutting through plaster. in all types of wood. • Recommended for • High speed bit head use with Abrasion ensures longer life. Shield to reduce • Replaces Bellhanger friction and abrasion drills on 12", 18" as the shaft turns and 24" lengths. against masonry. BIT DIA. INCH (mm) COLOR CODE SHAFT LENGTH INCH mm SHAFT DIA. INCH mm 3/8" (9.5 mm) Black 9/16" (14.3 mm) Orange 3/4" (19.1 mm) Red 36 54 72 36 54 72 36 54 72 3/16 3/16 3/16 3/16 3/16 3/16 1/4 1/4 1/4 914.4 1371.6 1828.8 914.4 1371.6 1828.8 914.4 1371.6 1828.8 4.8 4.8 4.8 4.8 4.8 4.8 6.4 6.4 6.4 • Clip attaches to hole in bit, mesh basket holds wire or cable during recovery, swivel reduces twisting. • For use with bit 3/8" (9.5 mm) diameter or larger. • A variety of sizes for pulling wire and cable. CAT. NO. UPC NO. DESCRIPTION 125 38691 150 38692 168 38693 D’VersiGRIP for pulling single wire with 3/8" to 1/2" (9.5 mm to 12.7 mm) bits. D’VersiGRIP for pulling 1/2" (12.7 mm) OD wire with 1/2" to 9/16" (12.7 to 14.3 mm) bits. D’VersiGRIP for pulling 3/4" (19.1 mm) OD wire with 3/4" to 1" (19.2 to 25.4 mm) bits. Type A, Auger Type B, Combination with Screw Point Type C, Combination • Wood-type auger bit with screw point. • Pulls itself through wood, avoids walking or skidding. • Excellent for drilling in soft woods or through thin sections. • Slow back-taper allows for easy retrieval. • For aggressive chip removal in many types of woods. • Screw point for easy starting and pulling through wood. • With screw point removed, this bit can be ground to function like a standard combination bit. • For drilling in tough woods and thick obstacles. • Drilling speed relative to pressure applied. • Chips can be brought easily out of the hole. TYPE B COMBINATION WITH SCREW POINT CAT. NO. UPC NO. TYPE C COMBINATION CAT. NO. UPC NO. TYPE A AUGER CAT. NO. UPC NO. 06-03-36A 06-03-54A 06-03-72A 09-03-36A 09-03-54A 09-03-72A 12-04-36A 12-04-54A 12-04-72A 38067 38068 38069 38077 38078 38079 38082 38083 38084 For a complete listing of D’VersiBIT® extensions and accessories, see page 55 to 57. 06-03-36B 06-03-54B 06-03-72B 09-03-36B 09-03-54B 09-03-72B — — — 38092 38093 38094 38102 38103 38104 — — — 06-03-36C 06-03-54C 06-03-72C — 09-03-54C 09-03-72C — 12-04-54C 12-04-72C V O I C E • D ATA • V I D E O A new twist to an old problem. These flexible steel drill bits are the right tools for installing wire or cable inside existing walls. 38117 38118 38119 — 38128 38129 — 38133 38134 193 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com CableCaster® V O I C E • D ATA • V I D E O Significantly speeds up the installation of lightweight communications cable through hard-to-reach spaces such as suspended ceilings, rafters and sub-floors. • 50' (15 m) range allows for faster installations with fewer pulls. • Bright yellow body reduces chances of leaving the CableCaster behind. • Glow-in-the-dark darts minimize replacement costs because they are easy to locate. • Aerodynamic darts provide high accuracy and fast installation. • Optional flashlight improves visibility. CAT. NO. UPC NO. DESCRIPTION 06186 06186 CableCaster Wire Pulling Tool with Three Darts 06259 06259 CableCaster Replacement Darts (Pack of Four) 46500 46500 Pocket-light Flashlight POCKET-LIGHT Flashlight • High intensity Xenon fired lamp. • Luminous tip so flashlight can be located in the dark. • Submersible to 500 feet. • Dust and rust proof. • Batteries included. • Lifetime limited warranty. CAT. NO. UPC NO. DESCRIPTION 46500 46500 Pocket-Light Flashlight 46533 46533 Lamp Module 46534 46534 O-Ring MINI POCKET LIGHT Flashlight • • • • 194 High intensity Xenon fired lamp. Submersible to 500 feet. Dust and rust proof. Compact pocket and key chain light. • Includes key ring and handy hat/clothing clip. • Batteries included. • Made in the USA. CAT. NO. UPC NO. DESCRIPTION 46503 46503 Mini Pocket Light Flashlight 46533 46533 Lamp Module 46534 46534 O-Ring USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com EZ Reach Fish Tape CAT. NO. UPC NO. DESCRIPTION 438-2X 01696 25' EZ Reach Tape SPECIFICATION Dimensions Steel tape 25' (7.6 m) long X 1/4" (6.4 mm) wide X .030 (.8 mm) thick. EZ Reach Fish Stix V O I C E • D ATA • V I D E O • Flat steel tape reaches easily above ceilings, under carpets, and through walls to install wire. • 25' (7.6 m) long, extending your reach where a traditional fish tape can’t. • Winder case with crank handle for easy compact storage. • High visible green color rods can be easily threaded together and seen when working above ceilings, down walls, or under raised floors. • 1/4" (6.4 mm) diameter fiberglass rods provide added rigidity when multiple sections are connected. • 200 lbs (0.9 kN) minimum pulling strength for long lasting durability and peace of mind. • Two different threaded tips available to accommodate various bundles of wire or cable. CAT. NO. UPC NO. DESCRIPTION 540-12 10504 EZ Reach™ Stix 12' (3.6 m) kit with bullet nose and “J” hook threaded tips, packaged in clear plastic tube. 540-24 10506 EZ Reach™ Stix 24' (7.3 m) kit with bullet nose and “J” hook threaded tips, packaged in clear plastic tube. SPECIFICATION 540-12 Total Length Weight Material 540-24 Total Length Weight Material 12' (3.6 m) – (3) 4' (1.2 mm) sections 1.04 lbs. (.5 kg) 1/4" (6.4 mm) dia. fiberglass rod 24' (7.3 m) (3) 6' (1.8 mm) and (2) 3' (.9 m) sections 1.94 lbs. (.9 kg) 1/4" (6.4 mm) dia. fiberglass rod 195 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O Clear Lube R R LISTED • • • • • Designed for use within electrical or datacom cable pulls. Clear and colorless for quick, easy clean-up. Excellent lubricity for fast pulls (.27-.29 COF). Environmentally safe, non-hazardous, non-toxic and non-corrosive. Easy to apply either by hand, brush or pump. CAT. NO. UPC NO. DESCRIPTION CLR-Q CLR-1 CLR-5 10437 10438 10439 Clear Lube pulling lubricant, 1 quart (.95 l) Clear Lube pulling lubricant, 1 gallon (3.79 l) Clear Lube pulling lubricant, 5 gallon (18.93 l) SPECIFICATIONS Temperature Range Remains stable over a wide range of temperatures, 20° F to 190° F (-6° C to 88° C) Polymer base with no silicon additives. Average coefficient of friction (IEEE, 375-2 test procedure), .27 in PVC and .29 in EMT. Three-year shelf life with no deterioration in lubricant. Fiber-Gel™ Cable Pulling Lubricant • Synthetic gel is specially designed for lightweight fast pulling of fiber optic cables. • Compatible with all cable jackets. • Cleans up easily. • Environmentally safe. • Operating range from 32° - 190° F (0°C - 88°C). • Compatible with pre-lubricated innerducts. • Dries slowly and leaves a long lasting lubricating film. CAT. NO. FIBR-Q FIBR-1 FIBR-5 UPC NO. 02040 02041 02045 DESCRIPTION Fiber-Gel™ One Quart Squeeze Bottle (.95 l) Fiber-Gel™ One Gallon (3.79 l) Fiber-Gel™ 5 Gallons (18.93 l) SPECIFICATIONS Weight FIBR-Q – 2.3 lbs. (1 kg) FIBR-1 – 8.5 lbs. (3.9 kg) FIBR-5 – 45 lbs. (20.4 kg) Viscosity 2,000 - 3,000 CPS PH Range 7.0 - 8.0 Poly Line • • • • • • Ready-to-use, pre-punched hole in lid with resealable cap. Use with power fishing systems directly from the container. Resists tangling when dispensing. Rot and mildew resistant. Handy reusable plastic dispenser pail with handle keeps the line dry. Use to pull rope through conduit. CAT. NO. UPC NO. DESCRIPTION 430 431 37959 430R 21481 21482 37959 37835 Poly Line 6500' (1981 m) Poly Line 5200' (1585 m) Poly Line 2200' (670 m) Poly Line Refill 6500' (1981 m) SPECIFICATIONS 196 Size 430 – 6500' (1981 m), 431 – 5200' (1585 m), 37959 – 2200' (670 m) Capacity 430 – 210 lbs. (934 N) average breaking strength 431 – 240 lbs. (1 kN) average breaking strength 37959 – 500 lbs. (2.2 kN) average breaking strength Weight 430 – 11 lbs. (5 kg), 431 – 12 lbs. (5.4 kg) USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Wire Cutter, 30-10 AWG CAT. NO. UPC NO. DESCRIPTION 1915 31892 Wire Cutter, 30-10 AWG Cable Cutter, 8 AWG Designed to cut solid, stranded wire up to 8 AWG (10 mm2) and multiconductor cable up to 1⁄2" (12.7 mm) in diameter. • Curved cutting blades ensure an easy cut. • Economically priced. • Cushioned-grip handle for comfortable use. • Heat-treated for long life. • Stamped and precision ground from high-carbon tool steel. • Return spring. • Locking latch. • Rust-resistant black oxide finish. CAT. NO. UPC NO. DESCRIPTION 45482 45482 Cable Cutter, 8 AWG V O I C E • D ATA • V I D E O Cuts 30-10 AWG (0.08-6 mm2) copper wire. • Small, economical wire cutter fits in any tool belt. • Cushioned-grip vinyl handle for comfortable use. • Heat-treated for long life. • Stamped and precision ground from high-carbon tool steel. • Return spring. • Pivot joints have hardened steel bushings. • Rust-resistant black oxide finish. Cable Cutter Easily cuts heavier copper and aluminum cables up to 2/0 (70 mm2). • Plastic-coated, high-leverage handles for easier cuts. • Heat-treated for long life. • Made of heavy-duty forged steel. • Precision ground, shear action, curved cutting blades. • Rust-resistant black oxide finish. • Made in the USA. CAT. NO. UPC NO. DESCRIPTION 727 31291 Cable Cutter 197 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O Cable Splicer’s Knife and Electrician’s Scissors Cuts cable, telephone wire and strips insulation. • Tough, tempered steel knife blade holds its edge longer. • Full-sized knife handle provides greater comfort. • Knife has a short, coping-type blade made of the finest cutlery steel. • Scissors have an upper blade with two stripping notches to strip most insulations from 19-24 AWG. PT-K01 PT-T01 CAT. NO. UPC NO. DESCRIPTION PT-K01 08704 Scissors and Knife Kit with Two-pocket Pouch PT-T01 08707 Cable Splicer’s Knife PT-T02 08708 Electrician’s Scissors PT-C01 08702 Two-Pocket Leather Pouch PT-T02 The TERMINATORS® Wire Strippers/Cutter • • • • • • • 1916 198 Precision ground blades ensure consistent stripping and cutting. Heat-treated for long life. Cushioned-grip vinyl handle for comfortable use. Serrated nose grip for wire pulling and straightening. Stamped from high-carbon tool steel. Pivot joints have hardened steel bushings. Rust-resistant black oxide finish. CAT. NO. UPC NO. DESCRIPTION 1916 31891 20-10 AWG (0.8 to 2.6 mm dia.) Solid Wire 1917 31890 26-16 AWG (0.4 to 1.3 mm dia.) Stranded Wire 1918 31889 30-22 AWG (0.25 to 0.64 mm dia.) Solid Wire USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Pro Wire Strippers CAT. NO. UPC NO. DESCRIPTION 1950 06852 Pro Wire Stripper 10-18 AWG 1951 06853 Pro Wire Stripper 22-32 AWG 1955 06857 Pro Plus Wire Stripper 10-18 AWG V O I C E • D ATA • V I D E O 1950 Strips the outer jacket off both solid and stranded wire. • Machined stripping stations with a positive stop provide precise stripping diameters. • Ergonomically designed, extra-long cushioned handles add superior comfort and reduce hand fatigue. • Long curved cutter blades reduce force required by 25% and can cut NM in a single cut. • Lock tab protects cutting edges during storage. • Pliers nose for working with small nuts and pulling wire. • Hole in jaws for looping wires. • Opening stop prevents spring from disengaging. • Easy-to-read graphics. • Cuts screws. 1955 Kwik Stripper™ Flat Telephone Cable Cutter/Stripper Designed to cut and strip flat modular telephone cables (Silver Satin). • Built-in cable stop/guide for consistent strip length. • Heat-treated for long life. • Cushioned-grip vinyl handle for comfortable use. • 2- to 10- conductor capacity. • Stamped from high-carbon tool steel. • Rust-resistant black oxide finish. CAT. NO. UPC NO. DESCRIPTION 45480 45480 KWIK STRIPPER Flat Telephone Cable Cutter/Stripper 45480 Typically used for Modular Plug Connectors (See page 208). 199 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O Kwik Stripper™ Coax Stripper – 2 Level and 3 Level • • • • • • Designed to provide precise, repeatable strips consistently. Prepares RG58, RG59, RG62, RG6 and many other types of coax cable. Strips braid and dielectric to 1⁄4" (6.4 mm). Blades are easily replaced in the field. Blade adjustment for cutting depth. Replaceable and interchangeable blade cassettes. CAT. NO. UPC NO. DESCRIPTION 45576 45576 KWIK STRIPPER Coax Stripper – 2 Level 45577 45577 KWIK STRIPPER Coax Stripper – 3 Level 45040 45040 Replacement Cartridge – 2 Level 45039 45039 Replacement Cartridge – 3 Level .23 (5.9) .23 (5.9) 45576 2 Level Typically used for F-type connectors (See page 210). Frame accepts only 2 level cartridges. 45577 3 Level Typically used for BNC-type connectors (See page 209). Frame accepts both 2 and 3 level cartridges. Kwik Stripper™ Twisted Pair Stripper No tool is better for trimming the jacket from twisted pair cable without damaging the individual conductors. • Blade depth adjustment ensures precise cutting depth. • Blade penetration controlled by tension loop. • Strip length gauge. • Made in the USA. CAT. NO. UPC NO. DESCRIPTION 45579 45579 KWIK STRIPPER Twisted Pair Stripper 45579 Typically used for Modular Plug Connectors (See page 208). 200 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Kwik Stripper™ CATV Cable Stripper CAT. NO. UPC NO. DESCRIPTION 45578 45578 KWIK STRIPPER CATV Cable Stripper 45580 45580 Replacement Cartridge RG6/RG59 45581 45581 Replacement Cartridge RG11/RG7 45578 Typically used for F-type connectors (See page 210). V O I C E • D ATA • V I D E O Designed for the professional CATV cable installer, this stripper is perfect for high volume and uses replaceable stripping cartridges for RG6, RG59, RG11 and RG7 CATV cables. • Pre-measured stops eliminate time-consuming measuring and trimming. • No adjustments needed. • Spare cartridge holder is conveniently built into the tool. • Included with the tool, the RG6/RG59 cartridge strips cable jacket and dielectric to 1⁄4" (6.4 mm). • Included with the tool, the RG11/RG7 cartridge strips cable jacket and dielectric to 1⁄4" (6.4 mm). • Extra-large finger hole. • Made in the USA. Kwik Stripper™ CATV/UTP Stripper Used for both unshielded twisted pair (UTP) and coaxial cabling, this tool reduces the number of tools needed without any adjustments. • Switching from four pair UTP to RG6 or RG59 is simple – just change cartridges. • Cartridges are color-coded for quick identification; yellow for UTP and black for coax. • Pre-measured stops eliminate time-consuming measuring and trimming. • UTP cartridge strips four-pair UTP without scoring the individual conductors. • Spare cartridge holder is conveniently built into the tool. • Included with the tool, the RG6/RG59 cartridge strips the cable jacket and dielectric to 1⁄4" (6.4 mm). • Extra-large finger hole. • Made in the USA. CAT. NO. UPC NO. DESCRIPTION 45677 45677 KWIK STRIPPER CATV/UTP Stripper with Both Cartridges 45667 45667 Replacement Cartridge UTP 45580 45580 Replacement Cartridge RG6/RG59 45581 45581 Replacement Cartridge RG11/RG7 45677 Typically used for F-type connectors (See page 210). The most versatile stripper in the industry. 45579 Typically used for Modular Plug Connectors (See page 208). 201 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O Pocket Cable Stripper Specifically designed for stripping power and telecommunications cables from 3/16" to 1-1/8" in diameter (4.5 mm to 29 mm). • Easy blade depth adjustment. • 90˚ blade rotation allows longitudinal, circular and spiral slitting of insulation. CAT. NO. UPC NO. DESCRIPTION 1900 45824 Pocket Cable Stripper 07915 07915 Replacement Cutting Blade Pocket Cable Stripper Specifically designed for stripping power and telecommunications cables from 3/4" to 1-1/2" in diameter (19 mm to 40 mm). • Strips solid conductor, stranded conductor and multiple conductor cables. • Easy blade depth adjustment. • Blade rotates for circular, longitudinal and spiral cuts. CAT. NO. UPC NO. DESCRIPTION 1901 45823 Pocket Cable Stripper 07915 07915 Replacement Cutting Blade Punchdown Tool • • • • • • • • • 46023 202 Inserts wire for a corrosion-resistant termination and trims off excess wire. Terminates 66, 110, BIX and Krone cross-connect and wall jacks. Spring loaded for fast, low-effort wire seating and termination. Internal impact mechanism eliminates jamming for longer, trouble-free service life. Adjustable low- and high-impact force settings. Bayonet-style blade locking mechanism. Neoprene pad for shock absorption. Spare blade storage in the handle. Color-coded yellow on the cut side of tool. CAT. NO. UPC NO. DESCRIPTION 46020 46020 Punchdown Tool Only 46021 46021 Punchdown Tool w/66 Blade 46023 46023 Punchdown Tool w/110 Blade USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Replacement Blades for the Punchdown Tool 46024 CAT. NO. UPC NO. DESCRIPTION 46022 46022 66 Style Blade 46024 46024 110 Style Blade 46025 46025 BIX Style Blade 46026 46026 Krone Style Blade 46025 46010 Clip-On Twisted Pair Kit Our Clip-On Twisted Pair Kit comes with all the tools necessary for terminating voice and data cable including a Punchdown Tool with 110 blade. See page 232 for details. V O I C E • D ATA • V I D E O 46022 • Cut side labeled to eliminate costly punching errors. • Made of high-carbon tool steel, heat-treated and precision ground for long life. • Reversible blades for seating/cut or seating only for jumper wires. • Rust-resistant finish. 46026 Coax Connector Insertion Tool Used in CATV applications, the Insertion Tool holds F- and BNC-style connectors securely in place allowing the installer to seat the connector properly on the cable. • Prevents injury on center conductor. • Screwdriver bit can be removed to allow the ratcheting screwdriver to be used with standard bits. • Screwdriver bit can be purchased separately for use in standard ratcheting screwdrivers. • BNC screwdriver bit sold separately for use with BNC connectors. CAT. NO. UPC NO. DESCRIPTION 45516 45516 Coax Connector Insertion Tool with F-style Connector Bit 45517 45517 Replacement Bit F-style Connector 45518 45518 Replacement Bit BNC-style Connector 45516 Use with F-style and BNC-style Connectors (See pages 208 to 210). 203 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Kwik Cycle™ Cable Tie Guns V O I C E • D ATA • V I D E O The Standard Cable Tie Gun is for use with 5⁄64" to 3⁄16" wide cable ties (2.2 mm to 4.8 mm), and the gun is made of molded nylon. The Heavy-duty Cable Tie Gun is for use with cable ties up to 1⁄4" wide (6.35 mm), and the gun is made of durable metal. • Tension adjustment allows the user to adapt the tool to the size of the tie. • Automatic cut-off eliminates sharp edges on ties. CAT. NO. UPC NO. DESCRIPTION 45306 45306 Standard Cable Tie Gun 45300 45300 Heavy-duty Cable Tie Gun 45300 Telephone Ratchet Crimper Combination tool terminates RJ11 6P4C, RJ12 6P6C and RJ45 8P8C modular style plugs. • No need to change crimping dies. • Full-cycle ratchet mechanism provides consistent, quality terminations every cycle. • Straight action ensures uniform crimp. • Small, compact design. • Built-in wire cutter and stripper. • All-steel frame has rust-resistant, black oxide finish. CAT. NO. UPC NO. DESCRIPTION 45553 45553 Telephone Ratchet Crimper 45575 45575 Telephone Ratchet Crimper 45553 Typically used for Modular Plug Connectors (See page 208). 45575 204 45469 Voice and Category 5 Data Termination Kit This kit includes our Telephone Ratchet Crimper plus other tools and connectors necessary for installing a voice and data network. Everything is conveniently organized in a durable zipper case. See page 231 for details on our Voice and Category 5 Data Termination Kit. Typically used for Modular Plug Connectors (See page 208). Our Telephone Ratchet Crimper was designed with a compact head to fit into tight spaces and ergonomic handles for operator comfort. USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Kwik Cycle™ 9 Crimp Frame CAT. NO. UPC NO. DESCRIPTION 45504 45504 KWIK CYCLE 9" Crimp Frame 45504 See our comprehensive line of connectors on pages 208 to 210. V O I C E • D ATA • V I D E O Used to manually crimp a wide variety of connectors and terminals to factory specifications. • Frame features a precision full-cycle ratchet for accurate, repeatable crimps every cycle. • Crimp release lever improves throughput by eliminating rejected terminations due to improper connector positioning. • Frame features a tension adjustment preset at the factory for optimum performance. • High-leverage force and ergonomically-designed handle provides comfortable use. • Frame and dies are manufactured from heat-treated, hardened tool steel for superior function and long life. • All die sets are easily interchangeable with a simple screwdriver. Kwik Cycle™ 9 Interchangeable Die Sets for Coaxial Connectors DESCRIPTION CABLE TYPE RG58, RG59 Plenum & Non-Plenum Thinwire CONNECTION CRIMP PROFILE & DIMENSIONS CAT. NO. BRAID CRIMP CENTER CONTACT 0.213 0.190 0.068 0.042 UPC NO. TOOL WITH DIE CAT. NO. UPC NO. DIE ONLY 45556 45556 BNC/TNC 50/75 OHM 45582 45582 45557 45557 RG6, RG174, 8281, AT&T 728 BNC/TNC/F 0.324 0.178 0.068 45558 45558 RG58/141/142/58 Teflon/ 58 Thinney/RG59 BNC/TNC/F 0.255 0.213 0.100 0.068 0.052 45559 45559 RG58/59/62 Teflon BNC/TNC from Cambridge/AIM 0.325 0.215 0.065 205 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O Kwik Cycle™ 9 Interchangeable Die Sets for Coaxial Connectors CRIMP PROFILE & DIMENSIONS DESCRIPTION CABLE TYPE RG58/RG59/ RG59TFE/RG6 CONNECTION BRAID CRIMP CAT. NO. CENTER CONTACT UPC NO. TOOL WITH DIE CAT. NO. UPC NO. DIE ONLY 45562 45562 BNC/TNC Cambridge/ AIM, 2-piece 0.320 0.210 0.185 45563 45563 Belden 1694A BNC/TNC 0.315 0.068 45574 45574 RG22B/U Twinax & others Twinax 0.429 0.075 0.075 45544 45544 46826 46826 RG58/RG174/8218 BNC/TNC 50 and 75 OHM 0.213 0.178 RG6/RG59 & 8281 0.068 0.042 BNC/TNC & F, 50 and 75 OHM. Also 1695, 1505, 9259 and 9231 45545 45545 46830 46830 0.324 0.255 0.068 0.042 46800 46800 46824 46824 RG58/RG59/62AU BNC/TNC 0.256 0.213 0.068 46801 46801 46808 46808 RG59, RG6 CATV F 0.354 0.324 0.255 Kwik Cycle™ 9 Interchangeable Die Sets for Modular Plugs DESCRIPTION CONNECTION UPC NO. TOOL WITH DIE CAT. NO. UPC NO. DIE ONLY RJ11 2-, 4- and 6-position Western Electric and Stewart style connectors 46120 46120 46116 46116 RJ45 8-position AMP modular plug connectors 45540 45540 46117 46117 RJ11 4- and 6-position AMP modular plug connectors 45541 45541 46118 46118 RJ45 10-position Modular plug connectors 45571 45571 45566 45566 Hand set plug 4-position 206 CAT. NO. FEATURES USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Kwik Cycle™ 9 Interchangeable Die Sets for Open Barrel Contacts CONNECTION 22-10 AWG (0.3 TO 6 MM2) CAT. NO. FEATURES UPC NO. TOOL WITH DIE Open barrel, non-insulated terminals, ring tongue, spade and slide-on style CAT. NO. UPC NO. DIE ONLY 45508 45508 Kwik Cycle™ 9 Interchangeable Die Sets for Insulated and Non-Insulated Terminals DESCRIPTION CONNECTION 22-10 AWG 22-10 AWG 26-16 AWG 22-8 AWG CAT. NO. FEATURES Color coded nests for easy identification Standard insulated terminals, ring tongue, spade lug, slide on and butt splices Color coded nests for easy identification For fully insulated slide-on syle connectors AMP Ultrafast™ style UPC NO. TOOL WITH DIE UPC NO. DIE ONLY 45500 45500 45509 45509 45501 45501 45570 45570 45565 45565 45507 45507 For mini insulated terminals with smaller wire barrels. Ring tongue, spade, slide on and butt splices For non-insulated terminals and splices CAT. NO. 45505 45505 V O I C E • D ATA • V I D E O DESCRIPTION 207 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O Modular Plugs We offer modular plugs for a wide variety of installations – from simple tasks like connecting a telephone handset cord to the most demanding requirements of Category 5 wiring. • Gold-plated contacts provide long life and reliable performance • Manufactured to comply with FCC 68 guidelines F-STYLE CONNECTORS RECOMMENDED TOOL DESCRIPTION CONNECTOR TYPE CABLE TYPE QUANTITY CAT. NO. UPC NO. STRIPPER CAT. NO. UPC NO. Handset 4 Contact Flat Cable Stranded Wire 25/Pack 50/Pack 100/Pack 45737 45750 45770 45737 45750 45770 45480 45480 RJ11 6 Contact Flat Cable Stranded Wire 25/Pack 50/Pack 100/Pack 45738 45751 45771 45738 45751 45771 45480 45480 DEC MMJ 6 Contact Flat Cable Stranded Wire 25/Pack 45739 45739 45480 45480 RJ45 8 Contact Flat Cable Stranded Wire 25/Pack 50/Pack 100/Pack 45740 45753 45773 45740 45753 45773 45480 Handset 4 Contact Round Cable Solid Wire 25/Pack 50/Pack 100/Pack 45742 45755 45775 45742 45755 45775 RJ11 6 Contact Round Cable Solid Wire 25/Pack 50/Pack 100/Pack 45743 45756 45776 DEC MMJ 6 Contact Round Cable Solid Wire 25/Pack RJ45 8 Contact Round Cable Solid Wire RJ45 Cat 5 8 Contact Round Cable Solid Wire 45504 w/die 45504 w/die 45566 45566 COMBO 45575 45575 45553 45575 45553 45575 45480 45553 45575 45553 45575 45579 45579 45504 w/die 45504 w/die 45575* 45566 45566 45575* 45743 45756 45776 45579 45579 45553* 45575* 45553* 45575* 45744 45744 45579 45579 45553* 45575* 45553* 45575* 25/Pack 50/Pack 100/Pack 45745 45758 45778 45745 45758 45778 45579 45579 45553* 45575* 45553* 45575* 25/Pack 50/Pack 100/Pack 45747 45760 45780 45747 45760 45780 45579 45579 45553* 45575* 45553* 45575* *Not for use on round cable 208 CRIMPER CAT. NO. UPC NO. For the best tools to use with our modular plugs, see page 199 to 201 for stripping, and pages 204 and 205 for crimping. 45541 45541 45504 w/die 45504 w/die 46119 46119 45541 45541 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com BNC Coaxial Connectors BNC CONNECTORS RECOMMENDED TOOL DESCRIPTION CONNECTOR TYPE CABLE TYPE QUANTITY CAT. NO. UPC NO. STRIPPER CAT. NO. UPC NO. CRIMPER CAT. NO. UPC NO. BNC Crimp Plug RG58 Thinnet PVC 5/Pack 45730 45730 45577 45577 46800 46800 BNC Crimp Plug RG58 Thinnet Plenum 5/Pack 45731 45731 45577 45577 46800 46800 BNC Crimp Plug RG59/62 PVC 5/Pack 45732 45732 45577 45577 46800 46800 BNC Crimp Plug RG59/62 Plenum 5/Pack 45733 45733 45577 45577 46800 46800 V O I C E • D ATA • V I D E O • Gold-plated, captive center contact provides long life and reliable performance • Precision manufactured from machined brass and nickel plated for corrosion resistance BNC ADAPTERS DESCRIPTION ADAPTER TYPE QUANTITY CAT. NO. UPC NO. BNC Tee-style Plug to Jack/Jack 1/Pack 45727 45727 BNC Straight Jack to Jack 1/Pack 45728 45728 For the best tools to use with our BNC connectors, see page 200 for stripping and pages 205 for crimping. BNC TERMINATORS DESCRIPTION ADAPTER TYPE QUANTITY CAT. NO. UPC NO. BNC Terminator 50 OHM 1/Pack 45725 45725 BNC Terminator 93 OHM 1/Pack 45726 45726 209 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O F-style Coaxial Connectors • Nickel plated for corrosion resistance F-STYLE CONNECTORS RECOMMENDED TOOL DESCRIPTION CONNECTOR TYPE CABLE TYPE QUANTITY CAT. NO. UPC NO. STRIPPER CAT. NO. UPC NO. ‘F’ Connector Twist-on RG59 10/Pack 50/Pack 45735 45749 45735 45749 45576 45578 45677 45576 45578 45677 ‘F’ Connector Crimp RG59 10/Pack 50/Pack 45734 45748 45734 45748 45576 45578 45677 45576 45578 45677 ‘F’ Connector Twist-on RG6 10/Pack 50/Pack 45327 45328 45327 45328 45576 45578 45677 45576 45578 45677 ‘F’ Connector Crimp RG6 10/Pack 50/Pack 45315 45316 45315 45316 45576 45578 45677 ‘F’ Connector Crimp RG59 Quad-shield 10/Pack 50/Pack 45321 45322 45321 45322 ‘F’ Connector Crimp RG6 Quad-shield 10/Pack 50/Pack 45323 45324 45323 45324 CRIMPER CAT. NO. UPC NO. 46801 46801 45576 45578 45677 46801 46801 45576 45578 45677 45576 45578 45677 46801 46801 45576 45578 45677 45576 45578 45677 46801 46801 F-STYLE ADAPTERS DESCRIPTION ADAPTER/TERMINATOR TYPE 210 QUANTITY CAT. NO. UPC NO. ‘F’ Female Adapter 5/Pack 45325 45325 ‘F’ Terminator 5/Pack 45326 45326 For the best tools to use with our F-style connectors, see page 200 to 201 for stripping and pages 205 for crimping. USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com PE 900 Series Telephone Test Sets PE961 FEATURE CAT. NO. UPC NO. DESCRIPTION PE930 PE945 PE961 PE901 PE902 60487 60489 60511 60492 60493 Test Set with Adjustable Ringer Test Set with Two-way Hands Free Test Set with Two-way Hands Free and DigAlert Ground Start Cordset Replacement Cordset PE930 PE945 PE961 Data Safe Monitor ✓ ✓ ✓ Adjustable Ringer ✓ ✓ ✓ Waterproof Design ✓ ✓ ✓ Loud Speaker Listening ✓ ✓ Two-way Hands Free ✓ ✓ DigAlert™ Data Lock-out ✓ ADSL Compatible ✓ PE930 PE945 V O I C E • D ATA • V I D E O • Waterproof tested to an IEC IP67 rating, these test sets are so impervious to water they can actually withstand submersion. • The PE950 and PE961 feature our DigAlert over-voltage alarm and lock-out function to eliminate the danger of damaging or knocking out digital service lines. • The new PE961 provides full ADSL compatibility. • Ten-number speed dial memory (32 digits each). • Last number redial. • Precise hook flash. • Microphone mute. • Audible and visual mode indicators. • Polarity test in any mode. • Unique quick-release belt clip. • Premium cordset with bed-of-nails and piercing pin clips. • Three year warranty. PE961 Tele-Mate Communication Test Set Designed for communications wiring installation and repair to quickly verify the quality of a new installation. • Affordable • Tone/Pulse dialing. • Headset for hands-free operation. • Last number redial. • Rugged design for demanding use. • Line polarity indication. • Compact design and durable belt clip • Microphone mute. make it easy to carry. • Data safe monitor mode. • Adjustable volume. • Replaceable premium cordset • Built-in ringer. with telco-style clips. CAT. NO. UPC NO. DESCRIPTION PE810 60298 Tele-Mate Communication Test Set 211 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O P-Phone Adapters Enables analog telephone test sets to be used on POTS or Meridian Digital Centrex lines with the use of a simple slide switch. • Connects directly to most analog test sets. • PE290-01, PE290-02 and PE290-04 feature angled bed-of-nails clips and piercing spike. PE290-01 PE290-00 CAT. NO. UPC NO. DESCRIPTION PE290-00 60494 Hard-wired P-Phone Adapter PE290-01 60495 Hard-wired P-Phone Adapter with 5' OSP Cordset PE290-02 60515 Hard-wired P-Phone Adapter with 5' Combi-cord PE290-04 60496 Clip-to P-Phone Adapter with 5' OSP Cordset PE290-04 PE290-02 TurTEL Modular Adapters/Polarity Tester Use with tone generators, test sets and other test devices to troubleshoot and isolate problems with telephone circuits. • Two jacks allow in-line testing without service interruption. • The TurTEL 6 has two six-position, six-wire jacks. • The TurTEL 8 has two eight-position, eight-wire jacks. • Simple, push button operation to check polarity and power. • Reduced chance of shorting adjacent alligator clips due to unique shape. • Test contacts are perforated to provide sure grip for alligator clips or use of probes. • The TurTEL 6 has an internal circuit to allow testing of polarity for either of two lines (pairs 4 to 5 or 3 to 6) – circuit allows verification of power and phone number assignments. • Patch cord included. • Heavy-duty stainless steel belt clip. • Lifetime limited warranty. 46040 46050 212 CAT. NO. UPC NO. DESCRIPTION 46040 46040 TurTEL 6 Modular Adapter/Polarity Tester 46050 46050 TurTEL 8 Modular Adapter USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Classic 77 Series Tone Generators 77HP CAT. NO. UPC NO. DESCRIPTION 77HP 08687 77HP Tone Generator 77HP/6A 08688 77HP/6A Tone Generator 77HP/6AC 60480 77HP/6AC Tone Generator 77HP CAT. NO. UPC NO. DESCRIPTION 77CS 08686 Leather Belt Holster for Classic 77 Series Tone Generators V O I C E • D ATA • V I D E O Permits technicians to identify the conductor within a bundle, at a crossconnect point or at the remote end. Can be used on twisted pair wiring (telecom, datacom, etc.), single conductors, coaxial cables, de-energized AC wiring and most other wiring. 77CS Classic 77 Series Tone Generators FEATURES / SPECIFICATIONS 77HP 77HP / 6A 77HP / 6AC Selectable Warble Tone ✓ ✓ ✓ Continuity Testing ✓ ✓ ✓ Polarity Testing ✓ ✓ ✓ Talk Battery Supply ✓ ✓ ✓ Two-line Modular Test Lead (RJ-11) ✓ ✓ ✓ Three-color LED (identifies AC ring voltage) ✓ ✓ ✓ Weather-resistant Design ✓ ✓ ✓ ✓ Bent Nose Clips with Bed-of-Nails Penetrator ✓ ✓ Cloth Test Leads Battery Operated (9V not included) ✓ ✓ 77HP ✓ 77HP/6A 77HP/6AC 213 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O Professional GX Series Tone Generators 77GX • • • • • • • • • • Microprocessor controlled circuitry for increased reliability. Two-line polarity indication for fast outlet identification. Automatic shutoff to prevent battery drain. Snag-proof boot prevents broken plug tabs. Convenient wrist/hanging lanyard. Three distinct, selectable tone signal outputs for multiple line identification. Two selectable tone power outputs for use on open and shorted pairs. Independent continuity test function. Independent talk battery supply with higher output voltage. Fixed alligator clips and removable modular plug for multiple connection options. • 77GX2 includes premium telco-style bent nose clips with piercing pin and bed-of-nails connectors. CAT. NO. UPC NO. DESCRIPTION 77GX 60556 77GX Tone Generator 77GX2 60560 77GX2 Tone Generator Replacement Piercing Clips These traditional telco-style clips can be used with almost any style cordsets. • Clips feature bent nose design for use on 66 style punchdown blocks and bed-of-nails penetrator for use on insulated wires. • Package of two clips with red and black boots. CAT. NO. UPC NO. DESCRIPTION RPC 08710 Replacement Piercing Clips AdapToner Modular Breakout Tone Generator The AT Tone Generator makes it simple to test continuity, polarity, send tone and even supply talk battery to any configuration of pairs in 8-position modular jacks and plugs. • Combines the features of our tone generators and a modular breakout adapter • In-line testing is made simple with both a modular plug and jack on each unit • 8-position “snag-proof” modular plug • 8-position jack with protective cover • Quick reference guide with common wiring configurations • Selectable solid/warble tone signal • Tone, continuity and talk battery supply using alligator clips • Weather-resistant design • Battery operated (9V not included) 214 CAT. NO. UPC NO. DESCRIPTION AT8 08693 AdapToner Modular Breakout Tone Generator USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com LAN Toner With HUB Blink CAT. NO. UPC NO. DESCRIPTION AT8L 60583 LAN Toner V O I C E • D ATA • V I D E O The LAN Toner is designed for the network installation and maintenance professional and can be used on any wiring system including datacom, telecom, security/alarm, audio and CATV. • Blinks HUB, Switch Port, and PC activity lights for fast identification. • Provides tone signaling, continuity testing and telephone line polarity indication combined with a modular breakout adapter. • Selectable tone outputs for identifying multiple cable runs. • Includes multiple connection options. Tone Test Set • Our most comprehensive tone test set. • Traditional alternating tone signal for wire identification. • Audible line condition testing (level) indicates dead, working and off-hook lines. • Line 1 and 2 polarity testing using 4-conductor modular plug. • Improved talk battery supply for communication over inactive pairs. • Tone and test functions using either modular plug or 24" alligator clip leads. • Audible resistance level measurement. • Audible capacitance level measurement. • Battery operated (9V not included). CAT. NO. UPC NO. DESCRIPTION 600LS 08680 Tone Test Set CAT. NO. UPC NO. DESCRIPTION 600CS 08679 Leather Belt Holster for 600LS Test Set 215 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O Alarm Loop Verifier/Tone Generator Designed specifically for the security and alarm industry, the PE620 can be connected to a Normally Open or Normally Closed loop pair and provides a distinct audible tone when the alarm condition occurs. • Latching feature provides a simple method for identifying intermittent failures (“swingers”) and confirming operation of switches at remote locations. • In the latching mode, the unit will catch the alarm condition and continue sounding until the tester is reset. • As a tone generator, the unit provides a traditional variable tone that can be applied using the 24" red and black test leads or a convenient 6-position modular plug. • Convenient magnetic back plate allows the PE620 to be mounted directly to the control panel cabinet or door. • Battery operated (9V not included). CAT. NO. UPC NO. DESCRIPTION PE620 08665 Alarm Loop Verifier/Tone Generator Data Mate® Precision Tracing Tone Generator Trace wire or cable without interfering with digital two-way cable or ADSL services. The model 7780 Data Mate® Precision Tone Generator is intended to provide tone for tracing and troubleshooting communication circuits without disrupting digital traffic on the line or adjacent lines. The high purity of the tracing tones combined with internal isolating filters allows safe tracing on circuits that carry digital services above the baseband (two-way cable and ADSL). The high-power differential output of the 7780 makes tones easy to find, even over long distances. Also useful for continuity testing and polarity testing, the 7780 provides the standard warble tone and talk battery supply. • • • • • High Power Tone Output. High Purity Tone Signal. Low Crosstalk. Filter-isolated Circuitry. Modular and Telco Pro Alligator Leads. • Popular, Standard Warble Tone Frequencies Continuity Testing • Line Voltage and Polarity Indication. • Low Battery Indicator. • Two-way Broadband Compatible • ADSL Service Compatible. • Long Range. • Compatible with existing tone probes. CAT. NO. UPC NO. DESCRIPTION PE7780 60777 Date Mate® Tone Generator SPECIFICATIONS 216 Electrical Output Power +9dBm Output Signal Frequency 877/982 Hz alternating Output Impedence 3,500 ohms minimum, 25kHz to 1.1 MHz Mechanical Length 140 mm (5.5 inches) Depth 25 mm (1.0 inches) Width 57 mm (2.25 inches) Weight 0.17 kg (0.38 pounds) USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com 200 Series Inductive Amplifiers 200EP 200GX ✓ ✓ One-button Operation ✓ ✓ ✓ Adjustable Volume Control ✓ ✓ ✓ LED for Visual Signal Strength Indication ✓ ✓ ✓ Recessed Tabs for Telephone Test or Headset Connection ✓ ✓ ✓ Powerful 2" Speaker V O I C E • D ATA • V I D E O MODEL NO. 200FP ✓ Powerful, Rear-fire Speaker ✓ Speaker Bypass When Using Telephone Test Sets ✓ Noise Filtration Improved Tip Design for Better Reception and Lower Risk of Shorting Terminals ✓ ✓ Continuous-on Feature ✓ Five-minute Auto Shutoff ✓ ✓ Low-battery Indicator Battery Operated (9V not included) ✓ ✓ ✓ 200EP 200GX 200FP Inductive Amplifiers Used in conjunction with any tone generator, Inductive Amplifiers permit wire and cable identification without having to make direct metallic contact with the conductor. • All models feature powerful speaker for noisy environments, recessed on/off button control and high gain for accurate wire identification in congested cable bundles and equipment rooms. • The 200EP also includes adjustable volume control for precise identification, an LED for visual signal strength indication and recessed telephone test set connectors. • The 200GX includes all the features of the 200EP in a new rugged, ergonomically-designed housing. CAT. NO. UPC NO. DESCRIPTION 200EP 08671 Inductive Amplifier 200GX 60557 Inductive Amplifier CAT. NO. UPC NO. DESCRIPTION 200C 08670 Leather Belt Holster for 200 Series Inductive Amplifiers 200GX 217 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Filter Probe V O I C E • D ATA • V I D E O By selectively filtering out all 60Hz and 60Hz harmonics, the 200FP can be used with any tone generator for faster, more accurate, cable and wire identification. • With three types of noise filtration, the Filter Probe virtually eliminates power-related noise from the tone-and-probe operation. • Slim, comfortable design for use in limited-space areas. • Recessed on/off push-button control to conserve battery life. • Adjustable sensitivity/volume control to increase accuracy. • Blended carbon/plastic tip to reduce the risk of shorting terminals. CAT. NO. UPC NO. DESCRIPTION 200FP 08672 Filter Probe Replacement Plastic Tips for 200 Series Probes Plastic tips perform much the same as traditional metal tips while reducing the risk of shorting terminals. • Specially formulated with a carbon powder and carbon fiber blended plastic. • Tips fit 200B, 200EP, 200GX and 200FP probes. • RPT-1 comes with two pencil-style tips and two spade-style tips. RPT-2 CAT. NO. UPC NO. DESCRIPTION RPT-1 08711 Replacement Plastic Tips for 200B, 200EP, 200FP RPT-2 60561 Replacement Plastic Tips for 200GX RPT-1 Replacement Metal Tips for 200B and 200EP Probes Metal tips provide maximum performance when probing insulated wires or making direct metallic contact. • Made of nickel-plated brass. • Tips fit 200B and 200EP probes. • Package contains two pencil-style tips. 218 CAT. NO. UPC NO. DESCRIPTION RMT-1 08709 Replacement Metal Tips for 200B and 200EP Probes USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Classic Tone and Probe Kit CAT. NO. UPC NO. DESCRIPTION 701K 08684 Classic Tone and Probe Kit Professional Tone and Probe Kit Designed for the telecom professional, this kit is for use on single conductors, twisted pairs, coax cables and de-energized electrical wiring. • Housings are drop-tested to ensure durability. • Kit includes the 77GX Tone Generator and 200GX Inductive Amplifier in a rugged carrying case. CAT. NO. UPC NO. DESCRIPTION 711K 60558 Professional Tone and Probe Kit V O I C E • D ATA • V I D E O Used to identify single conductors or cables within a bundle, at a crossconnect point or at remote ends. • Kit includes the 77HP High Power Tone Generator and the 200EP Inductive Amplifier in a rugged, woven polyester carrying case. Premium Tone and Probe Kit Designed for more accurate wire identification, the 801K virtually eliminates power-related noise from the tone and probe operation. • Kit includes the 77HP/6A High Power Tone Generator and 200 FP Filter Probe in a convenient Cordura® case. CAT. NO. UPC NO. DESCRIPTION 801K 08690 Premium Tone and Probe Kit AdapToner Kit Designed for fast, accurate wire identification by combining the features of our tone generators and modular breakout adapter. • Kit includes the AT8 Modular Breakout Tone Generator and 200EP Inductive Amplifier in a convenient carrying case. CAT. NO. UPC NO. DESCRIPTION AT8K 08694 AdapToner Kit 219 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O LAN Toner Kit Designed for the network installation and maintenance professional, the LAN Toner sends tone and blinks HUB, Switch Port, and PC activity lights for fast identification. This kit can be used on any wiring system including datacom, telecom, security/alarm, audio and CATV. • Kit includes the AT8L LAN Toner and the 200GX Inductive Amplifier in a rugged, woven polyester carrying case. CAT. NO. UPC NO. DESCRIPTION AT8LK 60584 LAN Toner Kit CATV Cable Tone Test Kit Designed specifically for the CATV industry, this kit allows you to tone through splitters, directional couplers and traps. • Simple to use, the 402K provides accurate results and will eliminate long delays trying to figure out non-tagged or mis-tagged cable drops. • Kit includes one transmitter, one receiver, one male F-to-F connector adapter cable, one male F-to-alligator clip adapter cable and a carrying case. • Transmitter and receiver are equipped with female F-connectors. • Three methods of signal reception: electrostatic pickup for non-terminated cables, electromagnetic pickup for terminated or shorted cables and direct connection when identifying in the presence of passive devices. • In continuity mode, provides both audible tone and LED display. • Identifies the presence of AC or DC voltage on the cable under test. • Four selectable tone outputs for multiple line identification. CAT. NO. UPC NO. DESCRIPTION 402K 08677 CATV Cable Tone Test Set Security and Alarm Kit Designed specifically for the security and alarm industry, the 620K provides a simple method for identifying intermittent failures (swingers) and confirming operation of switches at remote locations. • To better satisfy industry requirements, we’ve combined the Model PE620 Tone Generator with the popular Model 200EP Inductive Amplifier in a durable woven polyester pouch. 220 CAT. NO. UPC NO. DESCRIPTION 620K 08682 Security and Alarm Kit USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Cabling Pouch CAT. NO. UPC NO. DESCRIPTION 750C 08685 Cabling Pouch V O I C E • D ATA • V I D E O Designed to hold a complete set of wiring tools including: any (one) 77 Series Tone Generator, any (one) 200 Series Inductive Amplifier, a punchdown tool, a cabling knife and scissors. • Convenient loop to hold most telephone test sets. • Removable “parts pouch” allows you to keep small components in reach. • Made of a durable woven polyester. • Fits belts up to 5" wide. Tone and Probe Carrying Case Allows you to build your own kit using any tone generator and 200 Series probe. • Durable woven polyester case. • Fits belts up to 3" wide. CAT. NO. UPC NO. DESCRIPTION 700C 08683 Tone and Probe Carrying Case T-Bug® Digital Signal Identifier Used to detect digital signals on twisted pair cables, identify and isolate digital pairs for special handling and help technicians avoid accidentally putting pairs out of service. • Operation is non-invasive and does not involve metallic contact so there’s no risk of service interruption. • Simple to use – just place the probe between the pairs in question. • Differential amplifier saves time by allowing the technician to determine whether the signal is truly present or is an induced signal from adjacent pairs. • False readings due to noise are virtually eliminated. • Continuous self test ensures that the unit is functioning properly. • Emits both visible and audible indication when digital signals are present. CAT. NO. UPC NO. DESCRIPTION 0134-0500 60764 T-Bug Digital Signal Identifier 221 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Voice Tagger V O I C E • D ATA • V I D E O Multi-wire identifier The Voice Tagger allows for simultaneous tracing or identification of up to 9 wires. The Voice Tagger provides a numbered voice signal for eight lines, plus a standard warble tone trace signal on alligator clip leads. When connected to the Voice Tagger multiple wires can be identified or traced using any standard wire tracing tone probe. The signals are compatible with voice twisted pair, category 5 or 6 data cable, coaxial cable and non-energized electrical wiring. • Voice-identified wire tagging. • Simultaneous tracing of nine individual circuits. • Works with any standard tone probe. • Single 9 VDC battery operation. • Labor saving during cable installation and maintenance. • Compatible with a wide range of wiring and cable. • Rugged reliable construction. CAT. NO. UPC NO. DESCRIPTION 1185-5001 60518 Voice Tagger SPECIFICATIONS Electrical Range 9 cable miles Warble Tone Signal 460/920 Hz alternating Power Source One 9 VDC battery (NEDA1604 or 6LR61) Mechanical Length 140 mm (5.5 inches) Height 32 mm (1.25 inches) Width 70 mm (2.75 inches) Modular Cable Tester/Tone Generator Quickly identifies opens, shorts, reversals and transposed pairs. • Economical tester includes all the basic functions. • Connecting the receiver unit automatically activates the test process. • Sequencing red and green LEDs provide fast, accurate and simple-tounderstand results. • Alerts the technician if connected to an active circuit without harming the unit. • Connect any eight-position modular plug to the appropriate jack on the transmitter and a sweeping tone signal is applied to all pairs. • At the far end of the cable, use any Tempo inductive amplifier (probe) to locate the corresponding plug or jack. • Battery operated (9V not included). 468 222 CAT. NO. UPC NO. DESCRIPTION 468 08661 Modular Cable Tester/Tone Generator 468C 60382 Carrying Case for the Modular Cable Tester/Tone Generator USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Sure Signal™ CAT. NO. UPC NO. DESCRIPTION 46060 46060 Sure Signal Line Verifier and Patch Cord Tester 46070 46070 Sure Signal Remote 45276 45276 Carrying Case 46065 46065 Sure Signal Accessory Kit V O I C E • D ATA • V I D E O Designed for cable installers and communications technicians for testing four-pair data/voice cable links terminated with standard, modular eightposition RJ45-style jacks. • Simplest tester available for identifying common wiring faults such as shorts, opens and miswires. • Diagnosis can be completed at one end. • Sequentially-lighting LEDs correspond to each wire allowing easier diagnosis of miswires than testers that check pairs. • Can test more wiring configurations than other testers due to sequential wiremap testing. • Shielded test ports allow extra versatility to test shielded and screened twisted pair. • Optional patch cords allow the Sure Signal to be used as a coax tester, eliminating the need for a second tester. • Optional remote unit can be used to check patch cords for wiring errors. • Optional Accessory Kit includes two RJ45 patch cords, two RJ45 to BNC adapter cords, two RJ45 to RJ11 snap-in adapters and one BNC plug to BNC plug adapter. • Battery operated (9V not included). • Lifetime limited warranty. 46060 Pair Mapper Twisted Pair Fault Tester 45280 Use to identify various wiring faults found in 10BASE-T and other four-pair, unshielded twisted pair (UTP) cables per TIA/EIA 568A and 568B. • Tests and identifies up to four cables with unique Remote Terminators. • Easy-to-use, compact. • Tests four-pair UTP cables including 100 BASE T. • Checks UTP cable for shorts, opens, crossed pairs, reversed pairs and split pairs. • Battery operated (9V not included). • Lifetime limited warranty. CAT. NO. UPC NO. DESCRIPTION 45280 45280 PairMapper Twisted Pair Fault Tester with Remote 1 45275 45275 Remote Terminators 2, 3, 4 45276 45276 Carrying Case Identifiers 2, 3, 4 sold separately. 223 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O Coaxial Cable Tester Provides quick verification of opens or shorts in either the conductor or the shield of coax cable. • Simple one-button operation provides pass/fail indication. • Remote terminator allows testing of cables before or after installation. • Clear red/green LED indication of short or open conditions. • Standard BNC- and F-type female connectors. • Battery operated (9V included). • Lifetime limited warranty. CAT. NO. UPC NO. DESCRIPTION 45055 45055 Coaxial Cable Tester 45055 NETcat® LAN Trouble Shooter Tests and maintains 10BASE-T and coaxial Ethernet networks consisting of CAT 3, 4 and 5 cable. Tests include WireMap, TDR length, near-end crosstalk (NEXT) and attenuation to 16MHz, signal-to-noise ratio and noise. • Diagnoses many common network problems with its combination of cable testing and network monitoring. • Autotest function automatically performs critical cable tests and reports PASS or FAIL, along with cause for any failure. • Detects active Ethernet traffic. • Monitors Ethernet traffic for utilization, collisions, hub link pulse and jabber. • Battery operated (three 9V batteries included). • Two year warranty. 52397 CAT. NO. UPC NO. DESCRIPTION 52397 55412 52404 52397 55412 52404 NETcat LAN Trouble Shooter Vinyl Carrying Case Token Ring Adapter NETcat® Plus LAN Trouble Shooter 54801 224 Tests and maintains CAT 3, 4 and 5 Ethernet, 10BASE-T and Token Ring networks. Tests include WireMap, TDR length, near-end crosstalk (NEXT) and attenuation to 20MHz and noise. • Diagnoses many common network problems with its combination of cable testing and Ethernet network monitoring. • Autotest function automatically performs critical cable tests and reports PASS or FAIL, along with cause for any failure. • Stores and prints up to 500 autotest reports. • Verifies network moves, adds and changes. • Identifies distance to any cable damage. • Detects active Ethernet traffic. • Monitors Ethernet traffic for utilization, collisions, hub link pulse and jabber. • Datalogs Ethernet traffic up to 30 hours. • Includes batteries, AC/mains adapter, printer cable and system carrying case. • Operates from batteries or AC/mains adapter. • Two year warranty. CAT. NO. UPC NO. DESCRIPTION 54801 52404 54801 52404 NETcat Plus LAN Trouble Shooter Token Ring Adapter USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Omni Marker™ APPLICATION COLOR FREQUENCY CAT NO. UPC NO. Power Red 169.8kHz 160 60765 Water Blue 145.7kHz 161 60766 Sanitary Green 121.6kHz 162 60767 Telephone Orange 101.4kHz 163 60768 Gas Yellow 83.0kHz 164 60769 Cable TV Orange/Black 77.0kHz 165 60770 V O I C E • D ATA • V I D E O Electronically marks and relocates buried facilities. • Unique design produces a uniform, spherical RF field in every direction. • Easily located up to 5' away with any modern marker locator. • Wider field with a signal peak directly above the marker provides precise location. • Requires no particular orientation when buried. • Greater range than standard 4" ball markers. • High-reliability design lasts as long as your buried plant. • Color coded by utility application. • Lifetime limited warranty. Uni Marker™ Electronically marks buried facilities for later relocation. • Rugged polyethylene case ensures years of useful life. • Small size and flat design attach easily to non-metallic utility box lids, hand holes and other buried enclosures. • Location is simple with any modern marker locator. • Range is 25% more than other similar-style markers. • Signal peak ensures location within inches of the marker. • Color coded by utility application. • Lifetime limited warranty. APPLICATION COLOR FREQUENCY CAT NO. UPC NO. Power Red 169.8kHz 170 60771 Water Blue 145.7kHz 171 60772 Sanitary Green 121.6kHz 172 60773 Telephone Orange 101.4kHz 173 60774 Gas Yellow 83.0kHz 174 60775 Cable TV Orange/Black 77.0kHz 175 60776 225 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Buried Line Locator V O I C E • D ATA • V I D E O • LED and LCD signal strength indicators make it quick and easy to find exact line location. • Lightweight and ergonomically balanced. • Automatic signal boost makes it easy to trace lines, even those with very weak signals. • Receiver may be used in active or passive mode. • Receiver locates multiple passive frequencies with a single setting. • Receiver automatically locks out passive range when it detects a transmitter signal, reducing the chance of tracing other lines carrying weaker signals. • Microprocessor-based circuitry delivers increased accuracy and features auto-gain control in all environments. • Traces 20' (6 m) underground and provides depth readings up to 15'. • Transmitter can be connected to live lines up to 600V. • Molded carrying case included. CAT. NO. UPC NO. DESCRIPTION BLL-200 07796 Buried Line Locator Tracker II Traces the path and determines the depth of wires and metallic pipes on active or dead systems without having to deactivate the system. • Lightweight receiver provides audible and visual indications of signal strength. • Transmitter output and receiver sensitivity are fully adjustable for maximum accuracy. • Transmitter offers three methods of connection: direct, inductive coupler and inductive antenna. • Includes transmitter assembly, receiver assembly, inductive coupler (clamp), built-in inductive antenna, two 8' test leads (2.4 m) with heavy-duty alligator clips and a durable polyethylene case. • High frequency transmitter provides range up to 4,000' (1,219 m) and depths up to 7' (2 m). • Receiver is 32" long (813 mm). • Battery operated (eight AA and one 9V battery is included). • Molded carrying case included. CAT. NO. UPC NO. DESCRIPTION 501 08662 Tracker II HS-1 (08695) Optional headset is available for use in high-traffic areas or other noisy environments. 226 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Wire Finder/Mini Locator CAT. NO. UPC NO. DESCRIPTION 508S 08678 Wire Finder/Mini Locator V O I C E • D ATA • V I D E O Used to trace energized or degenerated wires in walls and drop ceilings. • Determines the approximate depth of a wire before digging begins. • Transmitter and receiver are fully-adjustable for accurate locating. • Reliable results on buried cables to depths of 3' and lengths up to 1000'. • Quick-change test leads for use in any industry, even international power outlets. • Voltage protection allows use on live AC circuits. • Automatic shutoff prevents accidental battery discharge. • Both the transmitter and receiver are housed in a durable, molded carrying case with a quick reference operation guide on the inside of the lid. • Compact design. • Easy-to-understand operations. • Battery operated (two 9V batteries included). • Molded carrying case included. Pulser Identifies the exact location of even the smallest breaks in insulation by “pulsing” a high-voltage signal that radiates into the earth at the location of the faults. With the A-frame mounted receiver, a visual analog meter points the way to the source of the voltage. • Multiple faults on a single wire can be identified indicating the need to replace instead of repair. • Extra-long test leads feature heavy-duty alligator clips for use on multiple cable types. • Includes a rechargeable transmitter, receiver, A-frame, ground stake, 120V charger and a 12V DC (cigarette lighter) adapter. • Battery operated (one 12V and one 9V battery is included). • Molded carrying case included. CAT. NO. UPC NO. DESCRIPTION PE2003 08666 Pulser PE2003 Great complement to any buried line cable locator. 227 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O Precision Tone Generator Used in the telecommunications industry for pair identification and fault locating. • Supplies a precise 577.5Hz crystal controlled signal frequency. • Variable output allows technicians to adjust signal strength to suit field conditions and improve accuracy. • Designed to work with any common amplifier and exploring coil for aerial fault locating. • For communications over inactive pairs, the unit supplies talk battery to power two telephone test sets (buttsets). • Each of the three test leads is equipped with traditional bent nose piercing clips with “bed-of-nails” insulation piercing pins. • The tone generator and test leads fit neatly in a durable, protective woven polyester carrying case with shoulder strap. • 1-year warranty. • Battery-operated (1 – 6V lantern included). CAT. NO. UPC NO. DESCRIPTION 177 08657 Precision Tone Generator SPECIFICATIONS Power Requirements One 6V lantern battery Battery Life 40 hours nominal Transmitter Frequency 577.5Hz pulsed at 1Hz, crystal controlled Output Voltage 0.1 to 80Vp-p Output Signal Level 0 to +30dBm Construction High impact ABS plastic in woven polyester case Dimensions 7.25" x 5.5" x 4.5" in case Weight 3 lbs. with battery Load Coil Detector Designed for the telecommunications market, the 88 Load Coil Detector will identify the presence and count the number of load coils on an active or inactive circuit. • No complicated screens or test instructions to decipher. • Designed to withstand the rigors of daily use, the tester speeds troubleshooting dedicated data circuits. Simply connect the test leads and turn the switch. • While gradually turning the control, the display will “kick” to signify each coil detected on the pair. • Accurately identifies and counts up to four load coils on the circuit under test. • 1-year warranty. CAT. NO. UPC NO. DESCRIPTION 88 08656 Load Coil Detector SPECIFICATIONS Power Requirements One 9V battery 228 Battery Life 100 hours nominal Construction High impact ABS plastic Dimensions 4 x 2.25 x 1.5" Weight 5.8 oz. with battery USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Professional Installation Kit CAT. NO. UPC NO. DESCRIPTION 45471 45471 Professional Installation Kit Kit contents may be purchased separately: 45482 45482 Cable Cutter 45579 45579 KWIK STRIPPER Twisted Pair Stripper 46023 46023 Punchdown Tool with 110 Blade 46022 46022 66 Style Punchdown Blade 45575 45575 Telephone Ratchet Crimper for 4-, 6- and 8-position Modular Plugs AT8 08693 AdapToner Modular Breakout Tone Generator 200EP 08671 Inductive Amplifier Probe 45280 45280 PairMapper™ Twisted Pair Fault Tester 45275 45275 PairMapper Remote Terminators 2, 3, 4 45577 45577 KWIK STRIPPER Coax Stripper, 3 Level 45040 45040 KWIK STRIPPER 2-Level Coax Cartridge 46801 46801 KWIK CYCLE® 9" Crimp Frame with Die Set for F-style Connectors on RG6 and RG59 Cable 46824 46824 KWIK CYCLE Die Set for BNC-style Coax Connectors on Thinnet RG58 Cable 45481 45481 Center Conductor Cutter for Coax Cable 45516 45516 F Connector Insertion Tool 45324 45324 F-style Crimp-on Connectors for Quad-shield RG6 (Qty. 50) 45760 45760 Category 5 Connectors RJ45, 8 Position (Qty. 50) 45751 45751 Flat Cable Connectors RJ12, 6 Position, 6 Conductor (Qty. 50) 45486 45486 Carrying Case V O I C E • D ATA • V I D E O Includes all the tools, connectors and testers for installing and maintaining most types of communications cabling including voice, data and cable TV and coax Ethernet networks. • Durable Cordura Plus carrying case protects and organizes tools and includes see-through pouches for storing connectors. • Outside pockets provide convenient storage of instruction manuals or worksite documents. • Case has durable handles and eyelets for adding a shoulder strap. 229 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Coax/Twisted Pair LAN Termination and Test Kit V O I C E • D ATA • V I D E O Provides the essential tools, connectors and testers necessary for maintaining a Local Area Network, twisted pair cabling and coax Ethernet (Thinnet) cabling. • Durable Cordura Plus carrying case protects and organizes tools and includes a see-through pouch for storing connectors. • Outside pockets provide convenient storage of instruction manuals or worksite documents. • Case has durable handles and eyelets for adding a shoulder strap. CAT. NO. UPC NO. DESCRIPTION 45468 45468 Coax/Twisted Pair LAN Termination and Test Kit Kit contents may be purchased separately: 45482 45579 46023 46022 45575 45482 45579 46023 46022 45575 45577 46800 45577 46800 45481 AT8 200EP 45781 45481 08693 08671 45781 45760 45478 45760 45478 Cable Cutter KWIK STRIPPER Twisted Pair Stripper Punchdown Tool with 110 Blade 66 Style Punchdown Blade Telephone Ratchet Crimper for 4-, 6- and 8-position Modular Plugs KWIK STRIPPER Coax Stripper, 3 Level KWIK CYCLE 9" Crimp Frame with Die Set for BNC-style Connectors on Thinnet RG8 Cable Center Conductor Cutter for Coax Cable AdapToner Modular Breakout Tone Generator Inductive Amplifier Probe BNC-style Coax Connectors for RG58 Thinnet Plenum Cable (Qty. 20) Category 5 Connectors RJ45, 8 Position (Qty. 50) Carrying Case Cable TV Coax Termination and Test Kit Contains the tools, connectors and tester for installing and testing a Cable TV system. • Cable TV tone test set uses both electromagnetic and electrostatic pickup to tone through splitters, directional couplers and taps. • Durable Cordura Plus zipper case protects and organizes tools and includes a see-through pouch for storing connectors. • Outside pockets provide convenient storage of instruction manuals or worksite documents. CAT. NO. UPC NO. DESCRIPTION 45467 45467 Cable TV Coax Termination and Test Kit Kit contents may be purchased separately: 230 45482 45578 45482 45578 46801 46801 45516 45323 402T 402R 45477 45516 45323 60376 60377 45477 Cable Cutter KWIK STRIPPER CATV Stripper, 2 level stripper for RG6, RG59, RG7, RG11 KWIK CYCLE 9" Crimp Frame with Die Set for F-style Connectors on RG6 and RG59 Cable F Connector Insertion Tool F-style Crimp-on Connectors for Quad-shield RG6 (Qty. 25) Cable TV Tone Generator Cable TV Tone Receiver Zipper Case USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Category 5 Data Termination and Test Kit CAT. NO. UPC NO. DESCRIPTION 45470 45470 Category 5 Data Termination and Test Kit Kit contents may be purchased separately: 45482 45482 Cable Cutter 45579 45579 KWIK STRIPPER Twisted Pair Stripper 46023 46023 Punchdown Tool with 110 Blade 45575 45575 Telephone Ratchet Crimper for 4-, 6- and 8-position Modular Plugs 45760 45760 Category 5 Connectors RJ45, 8 Position (Qty. 50) 468T 60379 Modular Cable Tester Transmitter with Tone Generator 468R 60380 Modular Cable Tester Receiver 45485 45485 Zipper Case V O I C E • D ATA • V I D E O Includes the tools, connectors and testers necessary for installing a Cat 5 data network. • Durable Cordura Plus zipper case protects and organizes tools and includes a see-through pouch for storing connectors. • Outside pockets provide convenient storage of instruction manuals or worksite documents. Voice and Category 5 Data Termination Kit Includes the tools and connectors necessary for installing a voice and data network. • Durable Cordura® Plus zipper case protects and organizes tools and includes a see-through pouch for storing connectors. • Outside pockets provide convenient storage of instruction manuals or worksite documents. CAT. NO. UPC NO. DESCRIPTION 45469 45469 Voice and Category 5 Data Termination Kit Kit contents may be purchased separately: 45482 45482 Cable Cutter 45579 45579 KWIK STRIPPER™ Twisted Pair Stripper 46023 46023 Punchdown Tool with 110 Blade 46022 46022 66 Style Punchdown Blade 45575 45575 Telephone Ratchet Crimper for 4-, 6- and 8-Position Modular Plugs 45760 45760 Category 5 Connectors RJ45, 8 Position (Qty. 50) 45751 45751 Flat Cable Connectors RJ12, 6 Position, 6 Conductor (Qty. 50) 45479 45479 Zipper Case 231 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Cable TV Coax Termination Kit V O I C E • D ATA • V I D E O Contains the tools and connectors necessary for installing a Cable TV system. • Durable Cordura Plus zipper case protects and organizes tools and includes a see-through pouch for storing connectors. • Outside pockets provide convenient storage of instruction manuals or worksite documents. CAT. NO. UPC NO. DESCRIPTION 45466 45466 Cable TV Coax Termination Kit Kit contents may be purchased separately: 45482 45482 Cable Cutter 45578 45578 KWIK STRIPPER™ CATV Stripper, 2 Level Stripper for RG6, RG59, RG7, RG11 46801 46801 KWIK CYCLE® 9" Crimp Frame with Die Set for F-style Connectors on RG6 and RG59 Cable 45516 45516 F Connector Insertion Tool 45324 45324 F-style Crimp-on Connectors for Quad-shield RG6 (Qty. 50) 45476 45476 Zipper Case Clip-On Twisted Pair Kit Provides the most essential tools for terminating voice and data cabling right at the installer’s side. • Rugged Cordura® pouch is built to last, lowering replacement costs. • Heavy-duty metal clip snaps over the installer’s belt so that the kit can be removed without removing the belt. • Side holsters allow the installer to carry a flashlight and a favorite screwdriver. CAT. NO. UPC NO. DESCRIPTION 46010 46010 Clip-On Twisted Pair Kit Kit contents may be purchased separately: 46023 46023 Punchdown Tool with 110 Blade PT-T02 08708 Electrician’s Scissors 45579 45579 Twisted Pair Stripper 46500 46500 Pocket-light Flashlight 45272 45272 Pouch Replacement Tools and Blades are also available: 46020 46020 Punchdown Tool 232 46021 46021 Punchdown Tool with 66 Blade 46022 46022 66 Style Punchdown Blade 46024 46024 110 Style Punchdown Blade 46025 46025 BIX Style Punchdown Blade 46026 46026 Krone Style Punchdown Blade USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Telecom Field Technician Kit CAT. NO. UPC NO. DESCRIPTION 45473 45473 Telecom Field Technician Kit V O I C E • D ATA • V I D E O Contains all the essential tools and testers to maintain a telecommunications network. • Top quality digital multimeter and telephone test set make troubleshooting a voice network easy. • DMM features an industry-leading lifetime warranty. • Insulated screwdrivers protect the technician up to 10,000V. • Durable Cordura® Plus carrying case protects and organizes tools and includes see-through pouches for storing connectors. • Outside pockets provide convenient storage of instruction manuals or worksite documents. • Case has durable handles and eyelets for adding a shoulder strap. Kit contents may be purchased separately: 45482 45482 Cable Cutter 46023 46023 Punchdown Tool with 110 Blade 46022 46022 66 Style Punchdown Blade PT-T02 08708 Electrician’s Scissors PT-T01 08707 Cable Splicer’s Knife 77HP 08687 Tone Generator 200EP 08671 Inductive Amplifier Probe PE930 60487 Telephone Test Set 46040 46040 TurTEL6 Modular Adapter and Polarity Tester DM-800 07549 Digital Multimeter 46500 46500 Pocket-light Flashlight 1955 06857 Wire Strippers/Cutter, 10-18 AWG solid, 12-20 AWG stranded 45439 45439 Insulated Screwdrivers, 6-piece Set, 1000V Rating 45487 45487 Carrying Case Telecom Technician Pouch Contains all the essential tools and testers to install and maintain the voice network. • Durable woven polyester pouch fits any belt up to 5" wide and keeps all the tools conveniently accessible. CAT. NO. UPC NO. DESCRIPTION 45472 45472 Telecom Technician Pouch Kit contents may be purchased separately: 46023 46023 Punchdown Tool with 110 Blade 46022 46022 66 Style Punchdown Blade PT-T02 08708 Electrician’s Scissors PT-T01 08707 Cable Splicer’s Knife 77HP 08687 Tone Generator 200EP 08671 Inductive Amplifier Probe PE930 60487 Telephone Test Set 750C 08685 Cabling Pouch 233 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O Fiber Optic Kevlar® Shears Easily cuts through DuPont Kevlar or other aramid yarn. • Serrated blade prevents slipping. • High-leverage handles facilitate cutting. • Cushioned-grip handle for comfortable use. • Manufactured from hot-forged, high-carbon steel for long life. CAT. NO. UPC NO. DESCRIPTION 45586 45586 Fiber Optic Kevlar Shears Ceramic Kevlar Cutter Quickly and precisely trims the Kevlar strength member in fiber optic cable. • Ceramic blades never need sharpening and have a long life. • Handle is tough and durable. CAT. NO. UPC NO. DESCRIPTION 45483 45483 Ceramic Kevlar Cutter Kevlar is a registered trademark of E.I. Dupont, Inc. Fiber Optic Carbide-tipped Scribe Provides consistently good cleaves. • 30° wedge tip is made of carbide to ensure long life. • Made in the USA. 234 CAT. NO. UPC NO. DESCRIPTION 45593 45593 Fiber Optic Carbide-tipped Scribe USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Fiber Optic Buffer Stripper CAT. NO. UPC NO. DESCRIPTION 45589 45589 Fiber Optic Buffer Stripper Pro Plus Wire Stripper Strips the outer jacket off fiber optic cable. • Extra-long, curved and cushioned handles add comfort and reduce hand fatigue. • Lock tab protects cutting edges during storage. • Made in the USA. CAT. NO. UPC NO. DESCRIPTION 1955 06857 Pro-Plus Wire Stripper, 10-18 AWG V O I C E • D ATA • V I D E O Easily removes the buffer from both 250 and 900 micron cables. • Preset at the factory – no adjustments required. • Cushioned-grip ergonomic handles for comfortable use. • Will not scratch or nick glass or fiber. • 1.0 mm diameter stripping hole strips most fiber jackets. • Made in the USA. Kwik Cycle™ 9 Crimp Tool For Fiber Optic Connectors Used to manually crimp a wide variety of connectors and terminals to factory specifications. • Frame features a precision full-cycle ratchet for accurate, repeatable crimps every cycle. • Crimp release lever improves throughput by eliminating rejected terminations due to improper connector positioning. • Frame features a tension adjustment preset at the factory for optimum performance. • High-leverage force and ergonomically-designed handle provides comfortable use. • Frame and dies are manufactured from heat-treated, hardened tool steel for superior function and long life. • All die sets are easily interchangeable with a simple screwdriver. CAT. NO. UPC NO. DESCRIPTION 45504 45504 KWIK CYCLE 9" Crimp Frame 45572 45572 Fiber Optic Die Set DESCRIPTION CONNECTION CAT. NO. FEATURES O-style crimp cavities with dimensions of 0.131" x 0.162" x 0.196" (3.33 mm x 4.11 mm x 4.98 mm) For AMP Optimate SMA-style fiber optic connectors UPC NO. DIE ONLY 45572 45572 235 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O Kwik Cycle™ 8 Crimp Tool For Fiber Optic Connectors • Features a smaller handle spread with a comfortable, ergonomically designed handle. • Ideal for the hard to handle smaller connectors, such as fiber optic connectors and open barrel contacts. • Die sets are easily interchangeable with a screwdriver. • Includes die set. CAT. NO. UPC NO. DESCRIPTION 45637 45637 8" Crimper Frame with 45637 die set DESCRIPTION CAT. NO. CONNECTION FEATURES UPC NO. TOOL WITH DIE 0.151" (3.84 mm) hex cavity 0.178" (4.52 mm) hex cavity 0.213" (5.41 mm) hex cavity Universal fiber optic die 45637 45637 Fiber Optic Co-polymer Polishing Puck Used for standard ST, SC and FC connectors with 2.5 mm ferrules. CAT. NO. UPC NO. DESCRIPTION 45598 45598 Fiber Optic Co-polymer Polishing Puck Fiber Optic Stainless Steel Polishing Puck Used for standard ST, SC and FC connectors with 2.5 mm ferrules. • Made of stainless steel to last for years of termination. • Precision hole prevents even the slightest misalignment. • Grooves in the puck’s surface eliminate “sticking” during wet polishes. 236 CAT. NO. UPC NO. DESCRIPTION 45599 45599 Fiber Optic Stainless Steel Polishing Puck USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Fiber Optic Polishing Pad CAT. NO. UPC NO. DESCRIPTION 45612 45612 Fiber Optic Polishing Pad Fiber Optic Inspection Microscope High-powered microscope is used to check a connector’s endface for excess epoxy, core or cladding chips or other irregularities that degrade optical performance of the connector. • Laser safety filter protects eyesight. • Rubber eyecup for comfortable use. • Rugged aluminum housing. • 200X magnification. • Universal adapter works with ST, SC or FC connectors. CAT. NO. UPC NO. DESCRIPTION 45651 45651 Fiber Optic Inspection Microscope V O I C E • D ATA • V I D E O Resilient pad is perfect for PC (physical contact) pre-radiused ferrules. • 3" x 8". • 70 durometer. Connector Cleaning Systems Special lint-free fabric-on-a-reel quickly cleans ferrule endfaces of dust, oil and other contaminants. • Cleaning system is completely self-contained • No need for alcohol • A single cleaning reel can be used for over 400 ferrule cleanings • ReelCleaner™ can be used on all connector types including MTP and MT-RJ CAT. NO. UPC NO. DESCRIPTION 948 60692 ReelCleaner Connector Cleaning System 948/6 60693 Replacement Reel Set, 6/Package Adapter Cleaning Wands Specially-created, lint-free materials clean hard-to-reach fiber optic interfaces, bulkhead adapters and ferrule alignment sleeves. CAT. NO. UPC NO. DESCRIPTION 946 60571 2.5 mm Cleaning Wands, 10/Package 946K 60689 2.5 mm Cleaning Wands, 200/Box 947 60690 1.25 mm Cleaning Wands, 10/Package 947K 60691 1.25 mm Cleaning Wands, 200/Box 237 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O Quick Reference Charts for Fiber Testing Applications FIBER OPTICS MEASUREMENTS MATRIX APPLICATION SINGLE-MODE PAGE NO. MULTIMODE (glass fiber) PAGE NO. Visual Fault Location T160L / T164L / T165L 263LX + FoPro® 246, 248 256 T160L / T164L / T165L 263LX + FoPro® 246, 248 256 Visual Continuity T160L / T164L / T165L 263LX 246, 248 T160L / T164L / T165L 263LX 246, 248 522B / 555B 522B-HP / 558B 243, 244 245 522B / 555B / 557B 243, 244 245 241, 242 244 249 Measure Optical Power (to +3dBm) (to +27dBm) Measure Insertion Loss / Attenuation (Dual Wavelength) 262A + 555B 10,000 Series / 11,000 Series 523B-13/15 239 240 244 252B + 555B 5,000 Series / 6,000 Series FiberMeter™ Data Storage Capability 522B / 522B-HP 523B-13/15 239 243 522B / 522B-HP 244 SPECIAL TEST EQUIPMENT FOR MT-RJ INTERCONNECTIONS APPLICATION SINGLE-MODE PAGE NO. MULTIMODE (glass fiber) PAGE NO. Visual Fault Location 263MT 246 263MT 246 Visual Continuity 263MT 246 263MT 246 Measure Optical Power 556MT 244 556MT 244 Measure Insertion Loss 262A + 556MT 244 255MT / 257MT + 556MT 5,000 Series / 6,000 Series 60576MT / 60556MT 241, 242 244 250 SPECIAL TEST EQUIPMENT FOR PLASTIC OPTICAL FIBER (POF) 238 APPLICATION MULTIMODE (1 mm POF) Visual Fault Location 253B 250 Visual Continuity 253B 250 Measure Optical Power 557B 245 Measure Insertion Loss 253B + 557B 245 250 NOTE: Typical POF Connectors include Versatile Link, J/V/Z Pins and TOSLINK. See SOC adapter selection guide on pages 253 and 254. PAGE NO. USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Optical Loss Test Sets PACKAGE SOURCE TYPE FIBERMETER™ 523B-13/15 10,000 & 11,000 SERIES 5,000 & 6,000 SERIES 60556MT 253B+557B Handheld Handheld Handheld Palm-sized Palm-sized Palm-sized LED LED Laser Laser LED LED 350/1300 1310/1550 1310/1550 850/1300 850/1300 650 MEASUREMENT RANGE +3 to -5dBm +3 to -75dBm +3 to -60dBm +3 to -60dBm +3 to -60dBm +3 to -60dBm MEASUREMENT UNITS dB, dBm dB, dBm, W dB, dBm dB, dBm dB, dBm dB, dBm ✓ ✓ ✓ ✓ CALIBRATION WAVELENGTHS (nm) Storage Capability ✓ Single-mode Multimode (glass) ✓ ✓ ✓ Multimode (POF) Talk Function ✓ 55430 253B + 557B 6052B2K 523B-13/15 V O I C E • D ATA • V I D E O MODEL NO. 105202K 60556MT Advanced Single-mode Optical Loss Test Set Incorporates a stable dual 1310nm/1550nm laser source and optical power meter in a convenient self-contained package to perform insertion loss and link loss testing. • Large, backlit LCD display makes it easy to view power levels and calibration wavelengths. • Operation is simple due to the user-friendly keypad and intuitive controls. • Remote operation permits the automation of tedious or repetitive measurements. • Rubber boot protects against dropping and crushing. • Rugged and splashproof. • Indium-gallium-arsenide (InGaAs) photodetector. • 1310/1550nm dual laser source. • +3dBm to -75dBm measurement range. • PASS/FAIL testing with audible signal. • Manual or timer-driven data logging for periods from one second to one hour. • Data storage for 1,000 measurements. • RS232 interface for instrument configuration and data transfer to a PC-compatible workstation or serial printer. • Powered by a rechargeable nickel-metal hydride (NiMH) battery pack, four alkaline batteries or AC adapter. • Built-in NiMH battery charger with external power supply. CAT. NO. UPC NO. DESCRIPTION 523B-13/15 60550 Advanced Single-mode Optical Loss Test Set Requires one SOC and one UCI connector adapter (See pages 253 and 254). Source output is directly compatible with PC connectors. For APC use hybrid cable approach (See page 257). 239 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com fiberTOOLS® Single-mode Optical Loss Test Sets V O I C E • D ATA • V I D E O These conveniently packaged test sets are used to test, troubleshoot and maintain telco, CATV, LAN and other single-mode network applications. The Basic Set can be used to measure output power and certify end-to-end attenuation on deployed fiber spans. • Easy-to-use, all-in-one prepackaged kit. • Dual wavelength 1310/1550nm source covers all requirements. • Source has stable, calibrated output. • Rugged, splashproof instruments. • Water- and air-tight hard carrying case. • Meets the link certification requirements of TIA-568B and ISO/IEC-11801. • 0.01dB measurement resolution. • Two AA batteries provide power for over 100 hours in the optical power meters, over 50 hours in the LED sources and over 48 hours in the visual fault finder. Basic Sets include: • 555B Optical Power Meter plus adapter. • 262A Dual Wavelength 1310/1550nm Laser Source plus adapters. • Hard carrying case (900B). Deluxe Sets include: • Basic Set contents. • Visual fault finder T160. • Connector Cleaner. • Cleaning Wands. CAT. NO. UPC NO. DESCRIPTION Basic Single-mode Test Sets 10520E2 60611 Basic SM Test Set, E2000-PC 105202K 60608 Basic SM Test Set, FC-PC 105203K 60609 Basic SM Test Set, ST-PC 105206K 60610 Basic SM Test Set, SC-PC 1052011 60607 Basic SM Test Set, DIN Deluxe Single-mode Test Sets To accommodate other connector types, see our SOC/UCI adapters on pages 253 and 254 and reference cables on page 257. 240 11520E2 60618 Deluxe SM Test Set, E2000-PC 115202K 60615 Deluxe SM Test Set, FC-PC 115203K 60616 Deluxe SM Test Set, ST-PC 115206K 60617 Deluxe SM Test Set, SC-PC 115201U 60614 Deluxe SM Test Set, DIN 90ACK 60686 AC/Main Power Converter 120V (one required per handheld unit) USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com fiberTOOLS® Multimode Optical Loss Test Sets Basic Sets include: • 555B Optical Power Meter plus adapter. • 252B Dual Wavelength 850/1300nm LED Source plus 2x adapters. • Hard carrying case (900B). Deluxe Sets include: • Basic Set contents. • Visual fault finder T160L. • Connector Cleaner. • Cleaning Wands. CAT. NO. UPC NO. 50/125 DESCRIPTION CAT. NO. Basic Multimode Test Sets UPC NO. 50/125 V O I C E • D ATA • V I D E O These conveniently packaged test sets are used to test, troubleshoot and maintain LAN and other network applications. • Easy-to-use, all-in-one prepackaged kit. • Dual wavelength 850/1300nm LED source(s) covers all requirements. • Rugged, splashproof instruments. • Water- and air-tight hard carrying case. • Meet the link certification requirements of TIA-568B and ISO/IEC-11801. • 0.01dB measurement resolution. • Two AA batteries provide power for over 100 hours in the optical power meters, over 24 hours in the LED sources and over 48 hours in the visual fault finder. DESCRIPTION Deluxe Multimode Test Sets 5052BE2 60627 Basic MM Test Set, E2000-PC 5152BE2 60635 5052B2K 60624 Basic MM Test Set, FC-PC 5152B2K 60632 Deluxe MM Test Set, E2000-PC Deluxe MM Test Set, FC-PC 5052B3K 60625 Basic MM Test Set, ST-PC 5152B3K 60633 Deluxe MM Test Set, ST-PC 5052B6K 60626 Basic MM Test Set, SC-PC 5152B6K 60634 Deluxe MM Test Set, SC-PC 5052BIU 60623 Basic MM Test Set, DIN 5152BIU 60631 Deluxe MM Test Set, DIN 90ACK 60686 AC/Main Power Converter 120V (one required per handheld unit) 90ACK 60686 AC/Main Power Converter 120V (one required per handheld unit) 241 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O fiberTOOLS® MT-RJ Optical Loss Test Sets Our MT-RJ Test Sets provide all the equipment required to test, troubleshoot and certify multimode optical links. • Easy-to-use, all-in-one prepackaged kit. • Both 850 and 1300nm LED sources available. • Rugged, splashproof instruments. • Conveniently packaged in a water- and air-tight hard case. • Meets the link certification requirements of TIA-568B and ISO/IEC-11801. • 0.01dB measurement resolution. • Two AA batteries provide power for over 100 hours in the optical power meters, over 24 hours in the LED sources and over 48 hours in the visual fault finder. Basic Single Wavelength Test Sets include: • 556MT Optical Power Meter plus MT-RJ adapter. • 255MT (1300nm) or 257MT (850nm) LED Source. • Hard carrying case (900B). Dual Wavelength Deluxe Test Sets include: • 556MT Optical Power Meter plus MT-RJ adapter. • 255MT 1300nm MT-RJ LED Source. • 257MT 850nm MT-RJ LED Source. • MTRJ connector cleaner. • Hard carrying case (901B). • 263MT MT-RJ Visual Fault Finder. • Cleaning Wands. CAT. NO. UPC NO. DESCRIPTION Single Wavelength MT-RJ Test Sets 60556MT 60555 Basic MM Test Set, 1300nm 60576MT 60727 Basic MM Test Set, 850nm Dual Wavelength 850/1300nm MT-RJ Test Sets 242 60552MT 60654 Deluxe MM Test Set, 850/1300nm 90ACK 60686 AC/Main Power Converter 120V (one required per handheld unit) USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Optical Power Meters 522B PACKAGE 522B-HP 555B 556MT 557B 558B Palm-sized Palm-sized Handheld Handheld Palm-sized Palm-sized 1 mm InGaAs Filtered 2 mm InGaAs 1 mm InGaAs 3 mm Ge 850/980/1310/ 1480/1550/1625 850/980/1310/ 1480/1550/1625 850/1300/1310/1550 850/1300/1550 635/780/850 980/1310/1550 MEASUREMENT RANGE +3 to -75dBm +27 to -53dBm +3 to -60dBm +3 to -40dBm +3 to -60dBm +27 to -30dBm MEASUREMENT UNITS dB, dBm, mW dB, dBm, mW dB, dBm dB, dBm dB, dBm dB, dBm OPTICAL POWER METER INTERFACE TYPE SOC Universal SOC Universal SOC Universal SOC Universal SOC Universal SOC Universal User-selectable Auto Shutoff ✓ ✓ ✓ ✓ ✓ ✓ Storage Capability ✓ ✓ DETECTOR TYPE CALIBRATION WAVELENGTHS (nm) 555B 522B 3 x 3.5 mm Silicon Filtered 2 mm InGaAs V O I C E • D ATA • V I D E O MODEL NO. 557B 556MT 522B-HP 558B Advanced Optical Power Meters 522B To accommodate other connector types, see our SOC/UCI adapters on pages 253 and 254 and reference cables on page 257. Designed for insertion loss and link loss measurements using an external light source. • Large, backlit LCD display makes it easy to view power levels and calibration wavelengths. • Operation is simple due to the user-friendly keypad and intuitive controls. • Remote operation permits the automation of tedious or repetitive measurements. • Rubber boot protects against dropping and crushing. • Rugged and splashproof. • 850nm, 980nm, 1310nm, 1480nm, 1550nm and 1625nm calibration wavelengths. • InGaAs photodetector. • +3dBm to -75dBm measurement range. • PASS/FAIL testing with audible signal. • Manual or timer-driven data logging for periods from one second to one hour. • Data storage for 1,000 measurements. • RS232 interface for instrument configuration and data transfer to a PC-compatible workstation or serial printer. • Powered by a rechargeable nickel-metal hydride (NiMH) battery pack, four alkaline batteries or AC adapter. • Built-in NiMH battery charger with external power supply. CAT. NO. UPC NO. DESCRIPTION 522B 60548 Advanced Optical Power Meter, Medium Power to +3dBm 522B-HP 60549 Advanced Optical Power Meter, High Power to +27dBm Requires one Snap-On Connector (SOC) interface (See pages 253 and 254). Compatible with both PC and APC connectors. 243 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com InGaAs Optical Power Meter V O I C E • D ATA • V I D E O Suitable for power measurements on both laser and LED based single-mode and multimode fiber optic systems. • Easy-to-use; three buttons control all essential functions. • Multi-wavelength reference stores and recalls reference power levels for faster, more efficient measurement. • Rubber boot protects against dropping and crushing. • Rugged and splashproof. • 850nm, 1300nm, 1310nm and 1550nm calibration wavelengths. • InGaAs detector. • +3 to -60dBm measurement range. • 0.01dB measurement resolution. • Relative logarithmic dB and absolute logarithmic dBm units. • User-selectable auto shutoff. • Two AA batteries provide power for over 100 hours. • Optional AC power converter/adapter is available for prolonged or benchtop use. CAT. NO. UPC NO. DESCRIPTION 555B 60567 InGaAs Optical Power Meter 90ACK 60686 AC/Main Power Converter 120V (one required per handheld unit) Requires one Snap-On Connector (SOC) adapter (See pages 253 and 254). Compatible with both PC and APC connectors. Ge MT-RJ Optical Power Meter Pair with an LED source to test insertion loss of multimode MT-RJ fiber optic cables and connectors or use independently to perform link loss testing of installed cable plants. • Easy-to-use; three buttons control all essential functions. • Multi-wavelength reference storage capability permits convenient insertion and link loss testing at different transmission windows. • Wide area detector allows for testing of each channel individually, simultaneously or alternating between the two channels. • Rubber boot protects against dropping and crushing. • Rugged and splashproof. • 850nm, 1300nm and 1550nm NIST traceable calibration wavelengths. • Special extra-large area germanium detector. • +3 to -40dBm measurement range. • -0.01dB measurement resolution. • Relative logarithmic dB and absolute logarithmic dBm units. • User-selectable auto shutoff. • Two AA batteries provide power for over 100 hours. • Optional AC power converter/adapter is available for prolonged or benchtop use. CAT. NO. UPC NO. DESCRIPTION 556MT 60552 Ge MT-RJ Optical Power Meter 90ACK 60686 AC/Main Power Converter 120V (one required per handheld unit) Requires one 13A2 for MT-RJ Snap-On Connector (SOC) adapter (See page 254). Compatible with both PC and APC connectors. 244 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Silicon Optical Power Meter CAT. NO. UPC NO. DESCRIPTION 557B 60553 Silicon Optical Power Meter 90ACK 60686 AC/Main Power Converter 120V (one required per handheld unit) V O I C E • D ATA • V I D E O Optimized for power measurements on fiber optic systems based on single-mode, multimode, plastic or large core glass optical fibers and using near-infrared or visible light sources. • Easy-to-use; three buttons control all essential functions. • Multi-wavelength reference stores and recalls reference power levels for faster, more efficient measurement. • Rubber boot protects against dropping and crushing. • Rugged and splashproof. • 635nm, 780nm and 850nm calibration wavelengths. • 3 x 3.5 mm Silicon detector. • +3 to -60dBm measurement range. • 0.01dB measurement resolution. • Relative logarithmic dB and absolute logarithmic dBm units. • User-selectable auto shutoff. • Two AA batteries provide power for over 100 hours. • Optional AC power converter/adapter is available for prolonged or benchtop use. Requires one Snap-On Connector (SOC) adapter (See pages 253 and 254). Compatible with both PC and APC connectors. To accommodate other connector types, see our SOC/UCI adapters on pages 253 and 254 and reference cables on page 257. High Intensity InGaAs Optical Power Meter Suitable for power measurements on high power single-mode and DWDM fiber optic systems. • Easy-to-use; three buttons control all essential functions. • Multi-wavelength reference stores and recalls reference power levels for faster, more efficient measurement. • Rubber boot protects against dropping and crushing. • Rugged and splashproof. • 980nm, 1310nm and 1550nm calibration wavelengths. • +25 to -30dBm measurement range at 1310/1550nm. • 0.01dB measurement resolution. • Relative logarithmic dB and absolute logarithmic dBm units. • User-selectable auto shutoff. • Two AA batteries provide power for over 100 hours. • Optional AC power converter/adapter is available for prolonged or benchtop use. CAT. NO. UPC NO. DESCRIPTION 558B 60568 High Intensity InGaAs Optical Power Meter 90ACK 60686 AC/Main Power Converter 120V (one required per handheld unit) Requires one Snap-On Connector (SOC) interface (See pages 253 and 254). Compatible with both PC and APC connectors. 245 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O Fault Locators and Light Detectors MicroOTDR™ 510 LS SensoLITE® T160L Visible Laser OTDR Light Detector (Ge) Visible Laser 635nm (red) 1310nm 630 to 1600nm Up to 3 km (very bright) Up to 1 km (bright) up to 20 km LIFE / BATTERY TYPE 40 hours (2 AA) 24 hours (2 AA) 13,000 Tests (4 AA) 1 year (2 AA) 48 hours (2 AA) OPTICAL INTERFACE TYPE Fixed FC-PC Interface Fixed MT-RJ Interface Fixed ST-PC Interface Universal Interface 2.5 MM Universal Interface MODEL 263LX 263MT TYPE Visible Laser WAVELENGTH (NM) 635nm (red) DISTANCE Single-mode ✓ Multimode ✓ 635nm (red) Up to 3 km (very bright) ✓ ✓ ✓ 263LX ✓ ✓ 55446 263MT ✓ T160L 510LS FC-PC and MT-RJ Visual Fault Finders Used to quickly locate bending loss and breaks in optical fibers, and to identify bad connectors. • 635nm red laser makes fiber breaks and bending losses easily visible. • Stable, calibrated output. • Continuous wave output mode for steady fault illumination. • Blinking output mode increases viewing contrast. • Optional AC power converter/adapter is available for prolonged or benchtop use. • Proven, reliable and compact design. • Economically priced. • Rugged and splashproof. • 263LX model includes fixed FC-PC interface, for use with optional FoPro® Adapter Cable (See page 32) or user-supplied hybrid cable (See page 33). • 263MT model is designed for MT-RJ duplex connectors to test both fibers simultaneously. • LX model has a range up to 3 km. • MT model has a range up to 1 km. • More than 40 hours of continuous operation. 246 CAT. NO. UPC NO. DESCRIPTION 263LX 60538 Visual Fault Finder 263MT 60539 MT-RJ Visual Fault Finder 90ACK 60686 AC/Main Power Converter 120V (one required per handheld unit) USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com MicroOTDR™ Optical Fault Locator CAT. NO. UPC NO. DESCRIPTION 55446 55446 MicroOTDR Optical Fault Locator V O I C E • D ATA • V I D E O Provides fast, easy and accurate identification of loss points/faults and length for multimode and single-mode fiber optic cable. • Easy-to-use; one button controls all essential functions. • Fast; takes less than six seconds to identify the distance to six optical events plus the cable end. • Delivers over 13,000 tests from four AA batteries. • Fixed ST-PC interface, use hybrid cables for other connector types. • Uses 1310nm laser OTDR technology. • Measures cable length to 20 km. • Identifies distance to seven loss points/faults. • Distance accuracy of ±2 m. • ST-style output connection. • Two year warranty. SensoLITE® Light Detector Identifies live multimode and single-mode fibers. • Helps prevent accidental eye exposure to hazardous laser radiation. • Simple one-button test. • Patented light baffle accepts all standard fiber optic connector types, bare fiber and even fiber loop. • Includes both audible and visible indicators. • Unique design permits testing in bright light conditions. • Wide sensitivity from +25dBm to -55dBm. • Detects visible and invisible light wavelengths from 630nm to 1600nm. • Operates for approximately one year on two AA batteries. • Automatic battery check. CAT. NO. UPC NO. DESCRIPTION 510LS 60566 SensoLITE Light Detector 247 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Visual Fault Finder V O I C E • D ATA • V I D E O Pinpoints cable breaks and bad connections in both single-mode and multimode fiber. • Quick connect interface adapts to all standard PC and APC polished 2.5 mm ferruled connectors without adapters. • Both continuous and pulsed operation aid in fault detection even in high ambient lighted areas. • Pocket-sized. • Rugged, waterproof design. • Ultra-bright 635nm visible laser detects fiber breaks up to 3 km away. • Operates for over 48 hours on two AA batteries. • Includes integral dust cap and nylon, belt-mounted carrying pouch. • Optional snap-on adapters permit attachment to ST, SC and FC connectors. CAT. NO. UPC NO. DESCRIPTION T160L 60562 Visual Fault Finder 1630 60580 ST SOC Adapter 1662 60581 SC SOC Adapter 1620 60582 FC SOC Adapter Bare Fiber Adapter Allows temporary connection of 125 micron multimode or single-mode fiber to measuring equipment such as Sources, Optical Power Meters and Fault Locators with an FC-style connector. Connection to other common fiber optic connector styles can be accomplished with a hybrid test jumper. • Short 5 mm minimum strip length provides easy insertion into the capillary and avoids fiber breakage. • Reusable. • Includes a durable 2.5 mm tungsten carbide ferrule and a ferrule cleaning tool. 248 CAT. NO. UPC NO. DESCRIPTION 934-125 55456 Bare Fiber Adapter (125µm, FC-style connector) USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com LED Sources SOURCE TYPE 252B 253B 255MT 257MT LED LED LED LED 850/1300 650 1300 850 OPTICAL INTERFACE TYPE SOC Universal SOC Universal Fixed MT-RJ Fixed MT-RJ Continuous and Modulated Output Modes ✓ ✓ ✓ ✓ User-selectable Auto Shutoff ✓ ✓ ✓ ✓ Single-mode ✓ Multimode (glass) ✓ WAVELENGTHS (NM) ✓ ✓ ✓ ✓ Multimode (plastic) 252B V O I C E • D ATA • V I D E O MODEL 255MT 253B 257MT Dual Wavelength LED Source Perform multimode insertion loss and link loss measurements on local area networks, premises networks and Fiber Distributed Data Interface (FDDI) installations. • Stable, calibrated output. • Proven, reliable and compact design. • Easy-to-use; three buttons control all essential functions. • Rubber boot protects against dropping and crushing. • Rugged and splashproof. • Single unit combines 850nm and 1300nm calibrated wavelengths. • Nominal output for 62.5/125 is -13dBm for 850nm and -20dBm for 1300nm. • Continuous and modulated output modes. • User-selectable auto shutoff. • TIA-568B compliant. • Two AA batteries provide power for over 24 hours. • Optional AC power converter/adapter is available for prolonged or benchtop use. CAT. NO. UPC NO. DESCRIPTION 252B 60530 Dual 850/1300nm LED Source 90ACK 60686 AC/Main Power Converter 120V (one required per handheld unit) Requires two Snap-On Connector (SOC) adapters (See pages 253 and 254). 249 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Single Wavelength 650nm LED Source V O I C E • D ATA • V I D E O Performs multimode insertion loss and link loss measurements when paired with an optical power meter for POF testing. • Stable, calibrated output. • Proven, reliable and compact design. • Easy-to-use; two buttons control all essential functions. • Rubber boot protects against dropping and crushing. • Rugged and splashproof. • Nominal output into 200/230 is -15dBm. • Continuous and modulated output modes. • User-selectable auto shutoff. • Two AA batteries provide power for over 24 hours. • Optional AC power converter/adapter is available for prolonged or benchtop use. CAT. NO. UPC NO. DESCRIPTION 253B 60531 650nm LED Source 90ACK 60686 AC/Main Power Converter 120V (one required per handheld unit) Requires one Snap-On Connector (SOC) adapter (See pages 253 and 254). To accommodate other connector types, see our SOC/UCI adapters on pages 253 and 254 and reference cables on page 257. MT-RJ Dual Channel LED Sources Test insertion loss of multimode MT-RJ fiber optic cables and connectors, or pair with an optical power meter for link loss testing of installed cable plants. • Stable, calibrated output. • Proven, reliable and compact design. • Easy-to-use; two buttons control all essential functions. • Rubber boot protects against dropping and crushing. • Rugged and splashproof. • 255MT model has a 1300nm wavelength. • 257MT model has an 850nm wavelength. • Nominal output for 62.5/125 is -20dBm for both 850nm and 1300nm. • Continuous and alternating output modes. • Fixed MT-RJ interface. • User-selectable auto shutoff. • Two AA batteries provide power for over 24 hours. • Optional AC power converter/adapter is available for prolonged or benchtop use. 255MT 250 CAT. NO. UPC NO. DESCRIPTION 255MT 60533 MT-RJ Dual Channel LED Source 1300nm 257MT 60536 MT-RJ Dual Channel LED Source 850nm 90ACK 60686 AC/Main Power Converter 120V (one required per handheld unit) USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Laser Sources 262A 265A 266A Fabry-Perot Laser Fabry-Perot Laser Fabry-Perot Laser 1310/1550 1310 1550 OPTICAL INTERFACE TYPE UCI Universal UCI Universal UCI Universal Continuous and Modulated Output Modes ✓ ✓ ✓ User-selectable Auto Shutoff ✓ ✓ ✓ Single-mode ✓ ✓ ✓ SOURCE TYPE WAVELENGTHS (NM) 262A 266A V O I C E • D ATA • V I D E O MODEL 265A 1310/1550 Dual Wavelength Laser Source Performs single-mode insertion loss and link loss measurements when paired with an optical power meter. • Single output interface simplifies dual wavelength measurements. • Stable, calibrated output. • Proven, reliable and compact design. • Easy-to-use; three buttons control all essential functions. • Rubber boot protects against dropping and crushing. • Rugged and splashproof. • Single unit toggles between 1310nm and 1550nm wavelengths. • Fabry-Perot laser diodes. • Calibrated output power is nominal -7.0dBm. • Continuous and modulated output modes. • User-selectable auto shutoff. • Two AA batteries provide power for over 50 hours. • Optional AC power converter/adapter is available for prolonged or benchtop use. CAT. NO. UPC NO. DESCRIPTION 262A 60564 Dual Laser Source 90ACK 60686 AC/Main Power Converter 120V (one required per handheld unit) Requires one UCI adapter (See pages 253 and 254). For PC polished connectors only. For APC connectors, use hybrid reference cables (See page 257). To accommodate other connector types, see our SOC/UCI adapters on pages 253 and 254 and reference cables on page 257. 251 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Single Wavelength Laser Sources V O I C E • D ATA • V I D E O Performs single-mode insertion loss and link loss measurements when paired with an optical power meter. • Stable, calibrated output. • Proven, reliable and compact design. • Easy-to-use; two buttons control all essential functions. • Rubber boot protects against dropping and crushing. • Rugged and splashproof. • 265A has a 1310nm wavelength and -7dBm output for single-mode testing. • 266A has a 1550nm wavelength and -7dBm output for single-mode testing. • Continuous and modulated output modes. • User-selectable auto shutoff. • The 265A model operates for over 36 hours on two AA batteries. • The 266A model operates for over 80 hours on two AA batteries. • AC power converter/adapter is available for prolonged or benchtop use. CAT. NO. UPC NO. DESCRIPTION 265A 60565 1310nm Laser Source, SM 266A 60544 1550nm Laser Source, SM 90ACK 60686 AC/Main Power Converter 120V (one required per handheld unit) 265A Requires one UCI adapter (See pages 253 and 254) For PC polished connectors only. For APC connectors, use hybrid reference cables (See page 257). To accommodate other connector types, see our SOC/UCI adapters on pages 253 and 254 and reference cables on page 257. fiberTOOLS® Carrying Cases Designed to hold Tempo handheld instruments and a full range of test accessories. Carry Case only 900B and 901B Hard Carrying Cases • Top tray holds up to 3 (900B) or 4 (901B) handheld instruments and a T160L Visual Fault Finder. • Bottom compartment of both models stores additional instruments and test accessories. • Compact, waterproof and lockable. • Molded from black structural foam resin. 252 CAT. NO. UPC NO. DESCRIPTION 900B 60684 Hard Carrying Case, Holds 3x Handhelds 901B 60579 Hard Carrying Case, Holds 4x Handhelds 900B Instruments and accessories not included USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Fiber Optic Instrument Adapters – SOC and UCI • SOC adapters are compatible with both PC and Angled APC physical contact interfaces. • UCI adapters feature durable phosphor bronze alignment sleeve. • SOC (Snap-On Connector) adapter is used on all power meters and 250 “B” series LED Sources. • UCI (Universal Connector Interface) adapter is used on all 250/260 “A” Series Sources and 330 Series Variable Optical Attenuators. Fiber Optic Instrument Adapters — SOC and UCI CONNECTOR TYPE DESCRIPTION SOC ADAPTER UCI ADAPTER CAT. NO. UPC NO. CAT. NO. UPC NO. 1.25 mm Quick-Connect Universal Adapter (LC, MU, etc.) T1026 30588 2.5 mm SOC Quick-Connect Adapter (E2000, FC, SC, ST, etc.) T1025 60587 Blank Adapter (for custom applications) T1001 60585 D4 T1089 60597 DIN 47256 T1010 60586 AD-108 60697 E-2000 T10E2 60599 AE2-10 60698 EC-Radiall T10E0 60598 Use hybrid cable only * FC T1020 60576 APC-108 60572 HMS-0 1050 60592 AMS-00 60700 HMS-10/A (SMA-2.5 mm) 1086 60595 AMT-10 60701 HMS-10/HP 1040 60590 AHP-10 60699 LC 10LC 60600 Use hybrid cable only * AU-250 V O I C E • D ATA • V I D E O Our SOC and UCI adapters provide direct connectivity for Tempo fiberTOOLS® to a wide range of industry-standard fiber optic connectors. • Adapter design ensures maximum accuracy and repeatability when performing critical measurements on fiber optic systems. • Easy to clean and use. • Single-mode and multimode compatible. 60703 Use hybrid cable only * Use hybrid cable * or FoPro® ✖ 253 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O Fiber Optic Instrument Adapters – SOC and UCI CONNECTOR TYPE DESCRIPTION UPI-PC ADAPTER CAT. NO. UPC NO. MIL-T-29504/4 & /5 Termini T1038 60589 Use hybrid cable * or FoPro® ✖ Mini-BNC T1047 60591 Use hybrid cable only * MT-RJ ◆ T13A2 60605 ◆ Use hybrid cable only * MT-RJ Ferrule Only ◆ T13AF 60606 ◆ Use hybrid cable only * MU T10ML 60601 SC T1062 60575 ASC-108 60574 SMA 905/906 T1087 60596 ASM-90 60702 ST T1030 60577 ATS-108 60573 STRATOS 430/ HOLTEK 38000 T1057 60593 Use hybrid cable only * TOSLINK – Simplex T10TB 60602 Use hybrid cable only * TOSLINK – Duplex (Set of 2) T10TD 60603 Use hybrid cable only * Versatile Link – V/Z PIN T10ZP 60604 Use hybrid cable only * VFO – Radiall T1081 60594 Use hybrid cable only * ✖ CAT. NO. UPC NO. Use hybrid cable * or FoPro® ✖ FoPro ferrule options include 2.5 mm, 1.57 mm (MIL-style 16AWG optical contacts) and 1.25 mm. using a Hybrid Adapter Cable, the instrument * When UCI adapter and one end of the Hybrid Adapter Cable should be a commonly available connector type. (i.e. FC, SC or ST) ◆ SOC adapter for use only with the 556MT Optical Power Meter on page 244. 254 SOC ADAPTER 90SOC (60687) SOC adapter tool for easy installation and removal of SOC adapters from instrument interfaces. USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com fiberSAFE™ USA/Canada Telecom Adapter Kit – SOC and UCI USA/Canada Telecom Adapter Kit includes: • FC-PC/APC (wide key) bulkhead/mating adapter. • ST-PC/APC bulkhead/mating adapter. • SC-PC/APC bulkhead/mating adapter. • E2000-PC/APC bulkhead/mating adapter. • FC/SC hybrid bulkhead adapter. • FC/ST hybrid bulkhead adapter. • FC/E2000 hybrid bulkhead adapter. • Universal 2.5 mm Quick Connect SOC adapter. CAT. NO. UPC NO. DESCRIPTION 956US 60695 USA/Canada Adapter Kit V O I C E • D ATA • V I D E O Conveniently combines the most popular SOC, UCI and bulkhead mating adapters used in the North American telecommunications market. Enables direct connectivity for Tempo fiberTOOLS® to industry-standard fiber optic connectors. fiberSAFE™ Worldwide Telecom Adapter Kit – SOC and UCI Conveniently combines the most popular SOC, UCI and bulkhead mating adapters used outside the USA and Canada. Enables direct connectivity for Tempo fiberTOOLS to industry-standard fiber optic connectors. Worldwide Telecom Adapter Kit includes: • DIN 47256-PC/APC bulkhead/mating adapter. • FC-PC/APC (wide key) bulkhead/mating adapter. • SC-PC/APC bulkhead/mating adapter. • E2000-PC/APC bulkhead/mating adapter. • FC/DIN hybrid bulkhead adapter. • FC/SC hybrid bulkhead adapter. • FC/E2000 hybrid bulkhead adapter. • Universal 2.5 mm Quick Connect SOC adapter. CAT. NO. UPC NO. DESCRIPTION 956WW 60696 Worldwide Adapter Kit fiberSAFE™ LAN Adapter Kit – SOC and UCI Conveniently combines the most popular SOC, UCI and bulkhead mating adapters used for Local Area Networks. Enables direct connectivity for Tempo fiberTOOLS to industry-standard fiber optic connectors. LAN Adapter Kit includes: • FC-PC/APC (wide key) bulkhead/mating adapter. • ST-PC/APC bulkhead/mating adapter. • SC-PC/APC bulkhead/mating adapter. • SMA 905/906 bulkhead/mating adapter. • FC/ST hybrid bulkhead adapter. • ST/SC hybrid bulkhead adapter. • Universal 2.5 mm Quick Connect SOC Adapter. CAT. NO. UPC NO. DESCRIPTION 956LN 60694 LAN Adapter Kit 255 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com FoPro® Fiber Optic Test Probes V O I C E • D ATA • V I D E O By eliminating the need for specialized connectors, adapters and hybrid jumper cables, FoPro fiber optic probes simplify testing patch panels and the numerous termination types encountered in the field. • Small, light and cost effective. • Patented design protects delicate connector endfaces from scratching. • Anti-rotation grip prevents the probe endface from grinding against the connector endface during a test. • Eliminates the need to stock numerous hybrid test cable configurations. • All standard FoPro assemblies are 3 m (9.8') long and come in a protective carrying case. • A tethered adapter converts the FoPro from a male to female interface for testing to plug connectors as well as testing the “pin” interface of multichannel connectors. FP2K-101-03 DESCRIPTION 256 Available in three ferrule configurations: • FP series for connector applications with 2.5 mm OD ferrules (DIN, E2000, FC, SC, ST, etc.). • F1 series for connector applications with 1.25 mm OD ferrules (LC, MU, etc.). • F2 series for MIL-T-29504 /4 and /5 termini applications with 1.57 mm (0.62") OD ferrules. CAT. NO. UPC NO. CAT. NO. UPC NO. CAT. NO. UPC NO. FOPRO WITH 2.5 MM FERRULE FC-PC SM 9/125 FP2K-101-03 60704 MM 50/125 FP2K-105-03 60705 MM 62.5/125 FP2K-106-03 60706 ST-PC FP3K-101-03 60707 FP3K-105-03 60708 FP3K-106-03 60709 SC-PC FP6K-101-03 60710 FP6K-105-03 60711 FP6K-106-03 60712 FOPRO WITH 1.25 MM FERRULE FC-PC SM 9/125 F12K-101-03 60713 MM 50/125 F12K-105-03 60714 MM 62.5/125 F12K-106-03 60715 ST-PC F13K-101-03 60716 F13K-105-03 60717 F13K-106-03 60718 SC-PC F16K-101-03 60719 F16K-105-03 60720 F16K-106-03 60721 FOPRO WITH MIL-STYLE 1.57 MM FERRULE ST-PC SM 9/125 F23K-101-03 60722 MM 50/125 F23K-105-03 60723 MM 62.5/125 F23K-106-03 60724 CAT. NO. UPC NO. MM 100/140 FP36-110-03 60728 MM 100/140 F136-110-03 60729 MM 100/140 F236-110-03 60730 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com TIA-568B and FOTP-171A Certified Reference Cables Meets and/or exceeds the latest industry standards including: • TIA/EIA-455-171 (FOTP-171A), issued June, 2001. • TIA-568B, TIA-562-7 (OFSTP-7) and TIA-526-14 (OFSTP-14) for optical link testing. • TIA-455-171 (FOTP-171, Attenuation) and TIA-455-8 (FOTP-8, Return Loss) for cable assembly testing. • Corresponding IEC measurement standards. SPECIFICATIONS Ferrule OD 2.4990 ±0.0005 mm. Fiber to Ferrule Eccentricity ≤ 0.25µm (SM) and ≤ 3µm (MM). 572J Insertion Loss ≤ 0.15dB (SM, 1310/1550nm) and ≤ 0.25dB (MM, 850/1300nm). Return Loss ≥ 55dB (SM, 1310/1550nm) and ≥ 40dB (MM, 850/1300nm). Beam Exit Angle ≤ 0.25° (SM) and ≤ 0.5° (MM). Standard Length 3 m. V O I C E • D ATA • V I D E O Ensures accurate measurements for repeatable and reproducible testing to the latest industry standards. STANDARD REFERENCE CABLES (TYPE A TO TYPE B) DESCRIPTION Single-mode Reference Cables: FC-PC to FC-PC CAT NO. 562K-101 ST-PC to ST-PC 563K-101 SC-PC to SC-PC UPC NO. 60658 DESCRIPTION Multimode Reference Cables: FC-PC to FC-PC CAT NO. UPC NO. 50/125 562K-105 60659 CAT NO. UPC NO. 62.5/125 562K-106 60660 60661 ST-PC to ST-PC 563K-105 60662 563K-106 60663 566K-101 60664 SC-PC to SC-PC 566K-105 60665 566K-106 60666 E2000-PC to E2000-PC 56E2-101 60667 E2000-PC to E2000-PC 56E2-105 60668 56E2-106 60669 LC-PC to LC-PC 56LC-LFM 60670 LC-PC to LC-PC 56LC-LM5 60671 56LC-LM6 60672 MU-PC to MU-PC 56MU-LFM 60673 MU-PC to MU-PC 56MU-LM5 60674 56MU-LM6 60675 HYBRID REFERENCE CABLES (FC-PC TO TYPE A) DESCRIPTION Single-mode Reference Cables: FC-PC to FC-APC CAT NO. UPC NO. DESCRIPTION Multimode Reference Cables: CAT NO. UPC NO. 50/125 CAT NO. UPC NO. 62.5/125 572J-101 60680 FC-PC to SC-APC 576J-101 60681 FC-PC to E2000-APC 57E8-101 60682 FC-PC to LC-PC 57LC-LFM 60733 FC-PC to LC-PC 57LC-LM5 60734 57LC-LM6 60735 FC-PC to MU-PC 57MU-LFM 60736 FC-PC to MU-PC 57MU-LM5 60737 57MU-LM6 60738 262A To measure attenuation of SM links with APC polished connectors, use our 262A Dual Wavelength Laser Source (see page 251) with the APC108 FC UCI Adapter (see page 253) and a Hybrid Reference Cable. Use same hybrid reference cable approach for LC-PC and MO-PC connectors. 257 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Fiber Optic Hand Tools Kit V O I C E • D ATA • V I D E O Contains the most commonly used fiber optic termination tools in a durable Cordura Plus zipper case. CAT. NO. UPC NO. DESCRIPTION 45655 45655 Fiber Optic Hand Tools Kit Kit contents may be purchased separately: 45586 45586 Kevlar Shears 1955 06857 Stripper for Cable Jackets 45589 45589 Buffer Stripper 45593 45593 Carbide-tipped Scribe 45637 45637 KWIK CYCLE® 8" Crimp Frame with 0.151", 0.178", 0.213" Hex Cavities 45651 45651 Fiber Optic Inspection Microscope 45599 45599 Stainless Steel Polishing Puck 45612 45612 Resilient Polishing Pad, 3" x 8" 45644 45644 Zipper Case Fiber Optic Cut and Strip Kit Includes three basic tools for cutting and stripping optical fiber cables in a durable Cordura Plus zipper case. CAT. NO. UPC NO. DESCRIPTION 45657 45657 Fiber Optic Cut and Strip Kit Kit contents may be purchased separately: 45586 45586 Fiber Optic Kevlar® Shears 1955 06857 Stripper for Cable Jackets 45589 45589 Fiber Optic Buffer Stripper Fiber Optic Consumables Kit Contains the most commonly used consumables for epoxy and polish fiber optic terminations. CAT. NO. UPC NO. DESCRIPTION 45656 45656 Fiber Optic Consumables Kit Kit includes the following consumable items which are not sold separately: 50 Sheets Polishing Paper, 1 micron 10 Syringes 50 Sheets Polishing Paper, 5 micron 10 Needle Tips 10 ml (0.34 oz.) Opticure Adhesive 100 Lint-free Wipes 26 ml (0.9 oz.) Opticure Primer 10 Alcohol Wipes 258 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com Fiber Optic Termination Kit CAT. NO. UPC NO. DESCRIPTION 45658 45658 Fiber Optic Termination Kit Kit contents may be purchased separately: 45586 45586 Kevlar® Shears 1955 06857 Stripper for Cable Jackets 45589 45589 Buffer Stripper 45593 45593 Carbide-tipped Scribe 45637 45637 KWIK CYCLE® 8" Crimp Frame with 0.151", 0.178", 0.213" Hex Cavities 45651 45651 Fiber Optic Inspection Microscope 45599 45599 Stainless Steel Polishing Puck 45612 45612 Resilient Polishing Pad, 3" x 8" 45639 45639 Carrying Case V O I C E • D ATA • V I D E O Contains all of the tools and consumable materials necessary for epoxy and polish connector terminations.* • Durable Cordura® Plus carrying case protects and organizes tools and includes see-through pouches for storing connectors. • Outside pockets provide convenient storage of instruction manuals or worksite documents. • Case has durable handles and eyelets for adding a shoulder strap. Kit includes the following consumable items which are not sold separately: 50 Sheets Polishing Paper, 0.3 micron 100 Lint-free Wipes 50 Sheets Polishing Paper, 1 micron 10 Alcohol Wipes 50 Sheets Polishing Paper, 5 micron 1 Alcohol Bottle 10 ml (0.34 oz.) Opticure Adhesive 1 Water Bottle 26 ml (0.9 oz.) 1 Fiber Debris Disposal Container Opticure Primer 1 Pair Safety Glasses 10 Syringes 1 Plastic Utility Box 10 Needle Tips 1 Felt-tipped Marker * Some connector manufacturers may require alternative tools or materials. 259 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com V O I C E • D ATA • V I D E O LANcat® System 5 and System 6 Network Cable Tester & Talk Set • System 5 Autotest Suite includes Power Sum NEXT, Attenuation, Power Sum ACR, Length, WireMap, Propagation Delay, Delay Skew and headroom margin. • System 6 Autotest Suite includes Power Sum NEXT, Attenuation, EL-FEXT, Return Loss, Length, WireMap, Propagation Delay and Delay Skew. • Built-in two-way talk set. • Cable toner for locating cable ends. • Fiberoptic cable testing options. • Save up to 800 autotest reports for upload to a PC using provided Windows-based software. • Operates from AA cells, AC/mains adapter or optional NiMH battery pack. • Includes hard carrying case. • Two year warranty. 54713 System 5 System 5 • Certifies up to 100 MHz Category 5/Class D twisted pair cabling. System 6 • Certifies up to CAT5 and Enhanced CAT5 twisted pair cabling to the most demanding TIA Category 5e Level IIe requirements. CAT. NO. UPC NO. DESCRIPTION 54713 54713 LANcat System 5 (115V, 60Hz) 54784 54784 LANcat System 6 (115V, 60Hz) SYSTEM ACCESSORIES 54784 System 6 CAT. NO. 54459 UPC NO. 54459 DESCRIPTION NiMH Rechargeable Battery Pack 54458 54458 Coax Cable Testing Module Option 54655 54655 110 Block Connecting Module Option (T568A wired)* 54657 54657 110 Block Connecting Module Option (T568B wired)* 54741 54741 Handset Cover for LANcat System 5 Handsets 54742 54742 Installers Kit [NiMH battery packs (2), System 5 Handset covers (2)] *Category 5/Class D testing FIBERcat™ Optical Loss Test Kit Converts any LANcat System 5 or System 6 handset into a precision optical power meter for measuring fiberoptic power or cable loss. • Measures 850/1300nm optical loss on multimode fiber. • Measures 1310/1550nm optical loss on single-mode fiber. • Includes 850/1300nm LED light source. • Memory for multiple loss references. • Saves up to 400 autotest reports in LANcat handsets for upload to a PC using provided Windows-based software. • Optional ST Fiber Test Kit includes two ST simplex launch cables 62.5/125µ, two ST bulkhead adapters and alcohol pads. • Two year warranty. 54653 Handset not included. 260 CAT. NO. UPC NO. DESCRIPTION 54653 54653 FIBERcat Optical Loss Test Kit 54720 54720 ST Fiber Test Kit 54870 54870 ST to ST Simplex Patch Cable (62.5/125µ) 54871 54871 ST to SC Simplex Patch Cable (62.5/125µ) USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 greenlee.com FIBERcat™ Test & Talk Fiber Certification System 54869 CAT. NO. UPC NO. DESCRIPTION 54869 54872 54720 54870 54871 54869 54872 54720 54870 54871 FIBERcat Test & Talk LANcat System 6 w/ Test & Talk ST Fiber Test Kit ST to ST Simplex Patch Cable (62.5/125µ) ST to SC Simplex Patch Cable (62.5/125µ) V O I C E • D ATA • V I D E O Converts any LANcat® System 5 or System 6 into a precision multimode optical loss test set. • Measures dual wavelength, bi-directional multimode 850/1300nm optical loss and link length on two cables simultaneously. • Includes automated link loss budget calculation and automatic PASS/FAIL determination. • Tests two fibers with one autotest. • Measures link length and propagation delay. • Saves up to 800 autotest reports in LANcat handsets for upload to a PC using provided Windows-based software. • Talk over multimode fiber. • Optional ST Fiber Test Kit includes two ST simplex launch cables 62.5/125µ, two ST bulkhead adapters and alcohol pads. • Two year warranty. FiberMeter™ Fiber Certification System A complete system for field testing of premise wiring fiber links on multimode fiber per TIA-568B.3. Multimode fiber testing features: • Accommodates both 50/125 and 62.5/125 multimode fiber. • Test two multimode fibers with one setup. • Automated measurement of optical loss and cable length. • PASS/FAIL certification against industry standards. • Detailed certification reports. • Built-in talk set. • Fixed ST-PC interface (use hybrid reference cables for other connector types). • Measurement range +3 to -55dBm. • Measure bi-directional loss at 850/1300nm. • Measure link length to 2000 meters. • Saves up to 2000 link reports for upload to a PC using provided Windowsbased software. • Operates from AA cells, AC/mains or optional NiMH rechargeable battery packs. • System includes thermoform handset covers, four test jumpers, earphones, AA batteries, AC/mains adapters and a carrying case. • Two year warranty. CAT. NO. UPC NO. DESCRIPTION 55430 55430 FiberMeter Fiber Certification System 115V 261 USA Tel: 800-435-0786 Canada Tel: 800-435-0786 International Tel: +1-815-397-7070 Fax: 800-451-2632 Fax: 800-524-2853 Fax: +1-815-397-9247 V O I C E • D ATA • V I D E O Notes 262 greenlee.com
45469 价格&库存
很抱歉,暂时无法提供与“45469”相匹配的价格&库存,您可以联系我们找货
