PA4934
PA4934
    GREENLEECOMMUNICATIONS(格林利)
    PROTOOLKITULTIMATEDATAREADY
PA4934 数据手册
PRO TOOLKIT - ULTIMATE DATAREADY Ultimate DataReady® Pro Kit Cat No: PA4934 UPC No: 769328113174 Description If you're an installer or technician needing a data cable tool kit solution, this is it. It includes all the tools you need for Cat5, Cat5e and Cat6 installation or maintenance in our rugged Ultimate Tool Bag Specifications • • • • • • Includes : PA1116 Data SureStrip UTP/STPAnd Flat Satin Cutter/Stripper, PA1923 Untwist Tool, PA8000 CrimpALL Crimp Frame With EZI-CHANGE Thumb Screws, PA3589 SurePunch Pro Punchdown Tool, DetachableLED Light, PA4571 110/ 66 Blade, PA4591 Doubl Replacement Part : PA1116 Data SureStrip UTP/STPAnd Flat Satin Cutter/Stripper, PA1923 Untwist Tool, PA8000CrimpALL Crimp Frame With EZI-CHANGE Thumb Screws, PA3589 SurePunch Pro Punchdown Tool, PA4599 SurePunch Pro DetachableLED Light, PA4571 110/ 66 Blade, PA4591 Doubl Size : 11.000 IN (279.000 MM) Width X 8.500 IN (216.000 MM) LengthX 6.000 IN (152.000 MM) Depth Sub Brand : DataReady Type : Ultimate, Pro Weight : 5.150 LB (2.300 KG)
PA4934 价格&库存
很抱歉,暂时无法提供与“PA4934”相匹配的价格&库存,您可以联系我们找货
