32973
    WIHA(威汉)
    INSULATEDPLIERS/CUTTERS&DRIVE
32973 数据手册
2013 Complete Insulated Program 10,000 Volt Tested 1000 Volt Rated #32800 Professional Insulated Tools Supporting Arc Flash Protection pg. 5 pg. 31 pg. 39 pg. 37 pg. 23 Toll Free: (800) 494-6104 2 Arc Flash Protection: Wiha Insulated tools can be a vital component in your Arc Flash protection strategy. What is Arc Flash? ARC FLASH An Arc Flash is an electrical explosion due to a fault condition or short circuit when either a phase to ground or phase to phase conductor is connected. Arc flashes cause electrical equipment to explode, resulting in an arc-plasma fireball. Temperatures may exceed 35,000° F (the surface of the sun is 9000° F). These high temperatures cause rapid heating of surrounding air and extreme pressures, resulting in an arc blast. The arc blast will likely vaporize all solid copper conductors which will expand up to 67,000 times its original volume when it is vaporized. The result of this violent event is usually destruction of the equipment involved, fire, and severe injury or death to any nearby people. WHY ARC FLASHES HAPPEN There are a variety of reasons why an Arc Flash can occur, but most of them are preventable. Most arc flashes occur when maintenance workers are manipulating live equipment for testing or repair and accidentally cause a fault. Improper tools, improper electrical equipment, corrosion of equipment, improper work techniques and lack of training are just some of the events that can lead to a devastating arc flash or arc blast. Wiha Insulated Wrenches Description Page Insulated Open End Spanners 4-5 Insulated Gear Wrenches 6 Ins. Offset Ring Wrenches 7 Wiha Insulated Adjustable Wrenches Description Page Insulated Adjustable Wrenches 8 8.0, 10.0, 12.0, 15.0” Wiha Insulated L-keys Description Page Insulated L-keys 9 ARC FLASH COMPLIANCE There are 4 main regulations that govern electrical safety & arc flash: 1. OSHA Standards 29CFR, Part 1910. Occupational Safety and Health Standards. 1910 sub part S (electrical) Standard number 1910.333 specifically addresses Standards for Work Practices and references NFPA 70E. OSHA 29CFR 1910.335 (a) (1)(i) requires the use of protective equipment when working where a potential electrical hazard exists and 29CFR 1910.132(d)(1) which requires the employer assess the workplace for hazards and the need for personal protective equipment. OSHA compliance is required by any plant building or facility. 2. The National Fire Protection Association (NFPA) Standard 70 2002 “The National Electrical Code” (NEC) contains requirements for warning labels. 3. NFPA 70E provides guidance on implementing appropriate work practices that are required to safeguard workers from injury while working on or near exposed electrical conductors or circuit parts that could become energized. Part II 2-1.3.3 regarding Arc Flash Analysis states that a “Flash Hazard Analysis shall be done before a person approaches any exposed electrical conductor or circuit part that has not been placed in an electrical safe work condition”. This Arc Flash Hazard Analysis must be done to determine the level of Personal Protection Equipment PPE that a worker must use, and the Arc Flash Boundary in inches along with the incident energy found at each location. Each panel must be marked with an ANSI z535 approved Arc Flash Warning Label. 4. The Institute of Electronics and Electrical Engineers (IEEE) 1584 – 2002 Guide to Performing Arc-Flash Hazard Calculations copyright © information by: American Trainco, Inc. http://www.martinarcflash.com OSHA Wiha tools assists with compliance of OSHA 29CFR 1910 (Sub Parts electrical standard) Wiha Insulated 3/8” Hex Drive Bit Sockets Description Page Ins. 3/8” Hex Dr. Bit Sockets 10 Wiha Insulated Electrician’s Knives Description Page Insulated Knives 8 Wiha Insulated Socket Accessories Description Page Insulated Sockets 1/4, 3/8, 1/2” 10-14 Insulated Ratchets 10,13,15 Insulated T-handle 10,13,15 Insulated Extension Bars 11,13,15 Wiha Insulated Cable Cutters Description Page Insulated Cable Cutters 15 www.wihatools.com 3 Wiha Insulated Hacksaw Wiha Insulated Tools Description Page Description Page Insulated Hacksaw Xeno Terminal Block Combination Screwdrivers 26 Insulated TorqueControl Handle & Blade Holder 18 15 Wiha Insulated Multi-Bit Holders Description Page Insulated Multi-Bit Drivers 18 Insulated 26 Single-Pole Voltage Detector Insulated Hex 17 Inch/Metric T-handles Wiha Insulated SlimLine Tools Description Page Insulated Slotted Drivers 23-24 Insulated SlimLine Handle 19 Insulated Phillips Drivers 23-24 Insulated SlimLine Blades 19-20 Insulated SlimLine Blade Sets 20 Insulated SlimLine Drivers 21 Insulated SlimLine Driver Sets 22 Wiha Insulated BitFlip Sets Description Page Insulated BitFlip Sets 27 Insulated Torx Drivers 26 Insulated Nut Drivers 25-26 Insulated Square Tip Drivers 24 Retaining Ring Bit Holder 27 Insulated Tweezers 16 Wiha Insulated 1000Volt Pliers/Cutters Description Page Wiha Insulated Belt Pack Pouch Sets Description Page Insulated Belt Pack Pouches 28 Pliers & Cutters Pliers/Cutters & Screwdrivers Pliers/Cutters & Multi Bit Set Insulated Lineman’s Pliers 34 Insulated Combination Pliers 34 Insulated Heavy Duty Diagonal Cutters 35 Insulated Serrated Edge Cable Cutter 35 Description Page Insulated Bent Nose Pliers 36 Insulated Inomic Pliers Insulated Long Nose Pliers 36 Wiha Insulated Inomic Pliers 37 Inomic Combo Pliers Inomic Long Nose Pliers Inomic Diagonal Cutters Wiha Insulated Industrial Pliers/Cutters Description Page Insulated Industrial Pliers/Cutters 38-41 Insulated Round Nose Pliers 36 Insulated Stripping Pliers Insulated Pliers Sets 36 29-33 Toll Free: (800) 494-6104 4 Wiha Insulated Open-End Wrenches Insulation Test Standards: Insulation according to ASTM F-1505-01, EN/IEC 60900, VDE 0680, DIN 7446 and CSA Each tool individually tested to 10,000 volts and certified to 1000 Volt ac or 1500 Volt dc Insulation High visibility, grip is double coated Steel Forged from chrome vanadium, meets - DIN 3110 Angled 15 O 1000V 1000Volt 1000Volt 20190 14 Piece Insulated Inch Open End Wrench Set Item OAL OAL No. Inch Inch Inch Inch 20190 20133 5/16 3.9 20142 3/4 7.0 20135 3/8 4.1 20144 13/16 7.5 20136 7/16 4.6 20145 7/8 7.6 20137 1/2 5.5 20146 15/16 7.9 20138 9/16 5.7 20147 1 8.4 20140 5/8 6.2 20148 1-1/16 9.2 20141 11/16 6.5 20149 1-1/8 9.1 lbs. 5.70 1000Volt 20192 8 Piece Insulated Inch Open End Wrench Set Item OAL OAL No. Inch Inch Inch Inch 20192 20133 5/16 3.9 20138 9/16 5.7 20135 3/8 4.1 20140 5/8 6.2 20136 7/16 4.6 20141 11/16 6.5 20137 1/2 5.5 20142 3/4 7.0 lbs. 1.59 20091 15 Piece Insulated Metric Open End Wrench Set Item OAL OAL No. mm mm mm mm lbs. 20091 20006 6.0 97 20014 14 150 3.0 20007 7.0 98 20015 15 151 20008 8.0 104 20016 16 164 20009 9.0 108 20017 17 162 20010 10.0 107 20019 19 178 20011 11.0 118 20022 22 196 20012 12.0 129 20024 24 211 20013 13.0 137 1000Volt 20093 8 Piece Insulated Metric Open End Wrench Set Item OAL OAL No. mm mm mm mm 20093 20006 6.0 97 20013 13.0 137 20007 7.0 98 20014 14.0 150 20008 8.0 104 20017 17.0 162 20010 10.0 107 20019 19.0 178 lbs. 1.4 www.wihatools.com 5 1000Volt 1000Volt 201 Inch Open-End Wrenches, With Insulated Handle Insulation According to VDE Specification 0680 and EN/IEC 60900, DIN 7446 and CSA, up to 1000 Volt. Individually Tested. Chrome-vanadium steel, hardened. Angled 15O. Item OAL OAL No. Inch mm Inch lbs. pkg. 20131 1/4 87.5 3.4 .04 1 20133 5/16 100 3.9 .05 1 20135 3/8 105 4.1 .09 1 20136 7/16 117 4.6 .09 1 20137 1/2 140 5.5 .15 1 20138 9/16 146 5.7 .15 1 20140 5/8 158 6.2 .20 1 20141 11/16 165 6.5 .23 1 20142 3/4 178 7.0 .33 1 20144 13/16 191 7.5 .42 1 20145 7/8 192 7.6 .44 1 20146 15/16 201 7.9 .51 1 20147 1 213 8.4 .61 1 20148 1-1/16 233 9.2 .79 1 20149 1-1/8 233 9.2 .77 1 * Lengths are +/- 5% due to coating process In Tool Box Tray 20194 13 Piece Insulated Inch Open End Wrench In Tool Box Tray Item OAL No. Inch Inch Inch 20194 20131 1/4 3.4 20141 11/16 20133 5/16 3.9 20142 3/4 20135 3/8 4.1 20144 13/16 20136 7/16 4.6 20145 7/8 20137 1/2 5.5 20146 15/16 20138 9/16 5.7 20147 1 20140 5/8 6.2 Set OAL Inch 6.5 7.0 7.5 7.6 7.9 8.4 lbs. 4.90 1000Volt 200 Metric Open-End Wrenches, With Insulated Handle Insulation According to VDE Specification 0680 and EN/IEC 60900, DIN 7446 and CSA, up to 1000 Volt. Individually Tested. Chrome-vanadium steel, hardened. Angled 15O. Item OAL OAL No. mm mm Inch lbs. pkg. 20006 6.0 97 3.8 .04 1 20007 7.0 98 3.9 .05 1 20008 8.0 104 4.1 .07 1 20009 9.0 108 4.3 .07 1 20010 10.0 107 4.2 .08 1 20011 11.0 118 4.6 .11 1 20012 12.0 129 5.1 .11 1 20013 13.0 137 5.4 .19 1 20014 14.0 150 5.9 .19 1 20015 15.0 151 5.9 .17 1 20016 16.0 164 6.5 .22 1 20017 17.0 168 6.4 .24 1 20018 18.0 173 6.8 .41 1 20019 19.0 178 7.0 .32 1 20020 20.0 190 6.9 .36 1 20022 22.0 196 7.7 .39 1 20024 24.0 211 8.3 .58 1 20027 27.0 218 8.6 .68 1 20030 30.0 235 9.3 .97 1 20032 32.0 237 9.3 1.01 1 In Tool Box Tray 1000Volt 20196 13 Pc. Insulated Metric Open End Wrench Set In Tool Box Tray Item OAL OAL No. mm mm mm mm 20196 20008 8.0 104 20016 16.0 164 20010 10.0 107 20017 17.0 168 20011 11.0 118 20018 18.0 173 20012 12.0 129 20019 19.0 178 20013 13.0 137 20022 22.0 196 20014 14.0 150 20024 24.0 211 20015 15.0 151 lbs. 4.90 Toll Free: (800) 494-6104 6 Wiha Insulated Ratchet Wrenches Insulation Test Standards: Insulation according to ASTM F-1505-01, EN/IEC 60900, ISO 3110 and CSA Specification Each tool individually tested to 10,000 volts and certified to 1000 Volt ac or 1500 Volt dc Steel Forged from chrome vanadium, meets - DIN 3110 1000V 1000Volt 1000Volt 213 Inch Insulated Ratchet Wrenches, With Insulated Handle Insulation According to EN/IEC 60900, ISO 3110 Specification, Up To 1000 Volt. Individually Tested. Blade chrome-vanadium steel, hardened. Item OAL OAL No. Inch mm Inch lbs. pkg. 3/8 140 5.5 .14 1 21325 7/16 143 5.6 .15 1 21327 1/2 154 6.1 .18 1 21329 9/16 162 6.4 .22 1 21331 5/8 177 7.0 .30 1 21333 3/4 209 8.2 .46 1 21335 1000Volt 1000Volt 21391 6 Piece Inch Insulated Ratchet Wrenches Set Item OAL OAL No. Inch Inch Inch Inch 21391 21325 3/8 5.5 21331 9/16 6.4 21327 7/16 5.6 21333 5/8 7.0 21329 1/2 6.1 21335 3/4 8.2 212 Metric Insulated Ratchet Wrenches, With Insulated Handle Insulation According to EN/IEC 60900, ISO 3110 Specification, Up To 1000 Volt. Individually Tested. Blade chrome-vanadium steel, hardened. Item OAL OAL No. mm mm Inch lbs. pkg. 21208 8.0 125 4.9 .08 1 21210 10.0 140 5.5 .12 1 21212 12.0 150 5.9 .18 1 21213 13.0 152 6.0 .18 1 21214 14.0 163 6.4 .22 1 21217 17.0 193 7.6 .38 1 21219 19.0 210 8.3 .45 1 lbs. 1.95 21290 7 Piece Metric Insulated Ratchet Wrenches Set Item OAL OAL No. mm mm mm mm 21290 21208 8.0 4.9 21214 14.0 6.4 21210 10.0 5.5 21217 17.0 7.6 21212 12.0 5.9 21219 19.0 8.3 21213 13.0 6.0 lbs. 2.10 www.wihatools.com 7 Wiha Insulated Deep Offset Ring Wrenches Insulation Test Standards: Insulation according to ASTM F-1505-01, EN/IEC 60900, ISO 3110 and CSA Specification Steel Forged from chrome vanadium, meets - DIN 3110 1000V Each tool individually tested to 10,000 volts & certified to 1000 Volt ac or 1500 Volt dc 1000Volt 210 Insulated Metric Offset Ring Wrenches, Insulation According to EN/IEC 60900, ISO 3110 Specification, Up To 1000 Volt. Individually Tested. Blade Chrome-Vanadium steel, hardened. Item OAL OAL No. mm mm Inch lbs. pkg. 21008 8.0 159 6.3 .16 1 21009 9.0 159 6.3 .18 1 21010 10.0 171 6.8 .20 1 21011 11.0 178 7.0 .22 1 21012 12.0 191 7.5 .30 1 21013 13.0 194 7.6 .30 1 21014 14.0 203 8.0 .34 1 21015 15.0 203 8.0 .34 1 21017 17.0 219 8.6 .44 1 21019 19.0 241 9.5 .52 1 21020 20.0 250 9.8 .58 1 21022 22.0 257 10.1 .64 1 21024 24.0 279 11.0 .90 1 21027 27.0 286 11.3 .96 1 21030 30.0 311 12.3 1.28 1 21032 32.0 318 12.5 1.38 1 21095 8 Item No. 21095 Piece Metric Insulated Offset Ring Wrenches Set Metric: 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, lbs. 17.0, 19.0mm 3.20 1000Volt 210 Insulated Inch Offset Ring Wrenches Item No. Inch lbs. pkg. 21040 1/4 .16 1 21042 5/16 .18 1 21044 3/8 .20 1 21046 7/16 .22 1 21048 1/2 .30 1 21050 9/16 .30 1 21052 5/8 .34 1 21054 11/16 .34 1 21056 3/4 .44 1 21057 25/32 .58 1 21058 13/16 .52 1 21060 7/8 .64 1 21062 15/16 .90 1 21064 1.0 .96 1 21066 1-1/16 1.28 1 21068 1-1/4 1.38 1 1000Volt 21094 15 Piece Inch Insulated Offset Ring Wrenches Set Item No. 21094 Inch: 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, lbs. 8.70 13/16, 7/8, 15/16, 1, 1-1/16, 1-1/4” 1000Volt 21093 15 Piece Metric Insulated Offset Ring Wrenches Set Item No. 21093 Metric: 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 17.0, lbs. 8.70 19.0, 22.0, 24.0, 27.0, 30.0, 32.0mm 21096 8 Item No. 21096 Piece Inch Insulated Offset Ring Wrenches Set Inch: 5/16, 3/8, 7/16, 1/2, 9/16, lbs. 5/8, 11/16, 3/4” 3.20 Toll Free: (800) 494-6104 8 Wiha Insulated Adjustable Wrenches 1000Volt 76208 Insulated 8” Adjustable Wrench Insulation According to ASTM, EN/IEC, NFPA, CSA and ISO Specification, up to 1000 Volt. Individually Tested. Etched on scale for pre-setting size. Slip guard handle for added protection. Item OAL OAL Capacity No. Inch mm Opening lbs. pkg. 76208 8.0 200 1” .7 1 1000Volt 76210 Insulated 10” Adjustable Wrench Insulation According to ASTM, EN/IEC, NFPA, CSA and ISO Specification, up to 1000 Volt. Individually Tested. Etched on scale for pre-setting size. Slip guard handle for added protection. Item OAL OAL Capacity No. Inch mm Opening lbs. pkg. 76210 10.0 250 1-1/4” 1.4 1 1000Volt 76212 Insulated 12” Adjustable Wrench Insulation According to ASTM, EN/IEC, NFPA, CSA and ISO Specification, up to 1000 Volt. Individually Tested. Etched on scale for pre-setting size. Slip guard handle for added protection. Item OAL OAL Capacity No. Inch mm Opening lbs. pkg. 76212 12.0 300 1-1/2” 1.9 1 Wiha Insulated Electrician’s Knives Insulation Test Standards: Insulation according to ASTM, EN/IEC, VDE & CSA Specification Individually tested Insulation molded on for permanent bonding 1000V Each tool individually tested to 10,000 volts & rated to 1000 Volt ac or 1500 Volt dc 1000Volt 15000 Insulated Electrician’s Cable Stripping Knife, With Insulated Handle, Insulation According To VDE Specification, Up To 1000 Volt. Individually Tested. Blade tool steel, hardened, molded directly on. Cover included. Item Blade OAL OAL No. mm mm Inch lbs. pkg. 50 216 8.5 .30 1 15000 1000Volt 76215 Insulated 15” Adjustable Wrench Insulation According to ASTM, EN/IEC, NFPA, CSA and ISO Specification, up to 1000 Volt. Individually Tested. Etched on scale for pre-setting size. Slip guard handle for added protection. Item OAL OAL Capacity No. Inch mm Opening lbs. pkg. 76215 15.0 380 1-11/16” 2.8 1 1000Volt 15003 Insulated Electrician’s Cable Stripping Knife, With Insulated Handle, Insulation According To VDE Specification, Up To 1000 Volt. Individually Tested. Straight, partly insulated, strong blade. Insulation molded directly on. Cover included. Item Blade OAL OAL No. mm mm Inch lbs. pkg. 15003 50 230 9.0 .23 1 1000Volt 1000Volt 76290 3 Pc. Insulated Adjustable Wrenches Etched on scale for pre-setting size. Slip guard handle for added protection. Item No. 76290 Set includes the following: lbs. 4.0 8.0”, 10.0”, 12.0” Adjustable Pliers 15050 Insulated Stripping Knife, With Insulated Handle Insulation According To VDE Specification, Up To 1000 Volt. Individually Tested. Blade tool steel, hardened. Insulation molded directly on. Hooked cutting edge, half-round ground. Cover included. Item Blade OAL OAL No. mm mm Inch lbs. pkg. 15050 35 222 8.75 .22 1 www.wihatools.com 9 Wiha Insulated Hex L-keys Insulation Test Standards: Insulation according to ASTM, F-1505-01, EN/IEC 60900 and CSA Insulation Applied directly onto blade for permanent bonding 1000V Each tool individually tested to 10,000 volts and certified to 1000 Volt ac or 1500 Volt dc 1000Volt 136 Inch Insulated Hex L-keys, With Insulated Handle Insulation According to IEC 60900 Specification, Up To 1000 Volt. Individually Tested. Blade chrome-vanadium steel, hardened. Item OAL OAL No. Inch mm Inch lbs. pkg. 13670 1/16 79 3.1 .05 1 13671 5/64 84 3.3 .05 1 13672 3/32 89 3.5 .05 1 13673 7/64 94 3.7 .06 1 13663 1/8 104 4.1 .06 1 13665 5/32 104 4.1 .06 1 13666 3/16 134 5.3 .10 1 13667 7/32 134 5.3 .12 1 13668 1/4 134 5.3 .16 1 13669 5/16 144 5.7 .24 1 13662 3/8 234 9.2 .51 1 13664 1/2 234 9.2 .77 1 1000Volt 136 Metric Insulated Hex L-keys, With Insulated Handle Insulation According to IEC 60900 Specification, Up To 1000 Volt. Individually Tested. Blade chrome-vanadium steel, hardened. Item OAL OAL No. mm mm Inch lbs. pkg. 13650 1.5 100 3.9 .09 1 13651 2.0 105 4.1 .09 1 13652 2.5 115 4.5 .09 1 3 130 5.1 .10 1 13653 4 120 4.7 .10 1 13654 5 140 5.5 .10 1 13655 6 140 5.5 .13 1 13656 8 150 5.9 .24 1 13658 10 220 8.7 .51 1 13659 13657 12 260 10.2 .77 1 # 13691 #13690 1000Volt 13690 8 Piece Insulated Inch Hex L-key Set Item OAL OAL No. Inch Inch Inch Inch 13690 13663 1/8 4.1 13668 1/4 5.3 13665 5/32 4.1 13669 5/16 5.7 13666 3/16 5.3 13662 3/8 9.2 13667 7/32 5.3 13664 1/2 9.2 lbs. 2.17 13691 7 Piece Insulated Metric Hex L-key Set 1000Volt Item OAL OAL No. mm mm mm mm lbs. 13691 13653 3.0 130 13658 8.0 150 2.07 13654 4.0 120 13659 10.0 220 13655 5.0 140 13657 12.0 260 13656 6.0 140 1000Volt 13693 10 Piece Insulated Metric Hex L-key Set 1000Volt Item OAL OAL No. mm mm mm mm lbs. 13693 13650 1.5 100 13655 5.0 140 2.26 13651 2.0 105 13656 6.0 140 13652 2.5 115 13658 8.0 150 13653 3.0 130 13659 10.0 220 13654 4.0 120 13657 12.0 260 1000Volt 13694 12 Piece Insulated Inch Hex L-key Set 1000Volt Item OAL OAL No. Inch Inch Inch Inch lbs. 13694 13670 1/16 3.1 13666 3/16 5.3 2.40 13671 5/64 3.3 13667 7/32 5.3 13672 3/32 3.5 13668 1/4 5.3 13673 7/64 3.7 13669 5/16 5.7 13663 1/8 4.1 13662 3/8 9.2 13665 5/32 4.1 13664 1/2 9.2 Toll Free: (800) 494-6104 10 Wiha Insulated 1/4” Sockets & Sets Wiha Insulated Hex Bit Sockets Inch 6 Point 1000Volt 318 Insulated 3/8” Drive Sockets - Insulation according to EN/IEC 60900, DIN 7448 Specification, Up To 1000 Volt. Individually Tested. Chrome-vanadium steel, forged, oil-hardened. Item OAL No. Inch Inch lbs. pkg. 31805 3/16 3.1” .13 1 31807 7/32 3.1” .14 1 31809 1/4 3.1” .14 1 31811 5/16 3.1” .16 1 31813 3/8 3.1” .18 1 31815 7/16 3.1” .20 1 31817 1/2 3.1” .22 1 *Sockets must be used with insulated ratchets & extensions 1000Volt 1000Volt 313 Insulated 1/4” Drive Sockets - 6 Point, Insulation According To ASTM F-1505-01, DIN 7448 & CSA Specification, Up To 1000 Volt. Individually Tested. Chrome-vanadium steel, forged, oil-hardened. Item No. Inch lbs. pkg. 31336 3/16 .03 1 31337 7/32 .03 1 31338 1/4 .03 1 31339 9/32 .04 1 31340 5/16 .04 1 31341 11/32 .05 1 31342 3/8 .05 1 31343 7/16 .06 1 31344 1/2 .07 1 31345 9/16 .07 1 *Sockets must be used with insulated ratchets & extensions Metric 6 Point 31890 7 Pc. Insulated 3/8” Drive Socket Set - Inch CV steel, forged, oil-hardened sockets. Insulated to EN/IEC 60900. Item No. 31890 Set includes the following: lbs. 1.7 3/16, 7/32, 1/4, 5/16, 3/8, 7/16, 1/2” WARNING! Insulated Tools are intended to provide protection against accidental contact with charged energized circuits. For maximum safety we recommend de-energizing all circuits whenever possible before starting work on electrical apparatus or conductors. Always visually inspect insulation on tools before use, do not use tools if insulation shows signs of wear or damage to the insulated areas of the tool. Wear appropriate eye protection when using hand tools. Use NFPA70E certified insulated protective outer wear when appropriate. Use & Care Guide For Insulated Tools: Store tools to minimize risk of damage to insulation, always wear approved eye protection, Inspect insulation prior to each use of any insulated tool. Use insulated tools where the ambient temperature is between -20 to +70O C. Have a qualified safety technician visually inspect insulation on tools annually for safe use. 1000Volt 313 Insulated 1/4” Drive Sockets - 6 Point, Insulation According To ASTM F-1505-01, DIN 7448 & CSA Specification, Up To 1000 Volt. Individually Tested. Chrome-vanadium steel, forged, oil-hardened. Item No. mm lbs. pkg. 31326 5.0 .03 1 31327 6.0 .03 1 31328 7.0 .03 1 31329 8.0 .04 1 31330 9.0 .04 1 31331 10.0 .05 1 31332 11.0 .05 1 31333 12.0 .06 1 31334 13.0 .06 1 31335 14.0 .07 1 *Sockets must be used with insulated ratchets & extensions 1000Volt 12851 Insulated 1/4” Drive Ratchet, EN/IEC 60900 & CSA Chrome-Vanadium steel. Reversible. Item OAL OAL No. Inch mm Inch lbs. pkg. 12851 1/4” 140 5.5 .28 1 www.wihatools.com 11 Wiha Insulated 1/4” Sockets & Sets 1000Volt 31390 13 Piece Insulated 1/4” Drive Socket Set - Inch CV steel, forged, oil-hardened sockets. Insulated after EN/IEC 60900. Item No. 31390 Set includes the following: 3/16, 7/32, 1/4, 9/32, 5/16, 11/32, lbs. 3/8, 7/16, 1/2, 9/16” 1.39 1/4” x 50mm Extension Bar 1/4” x 100mm Extension Bar 1/4” Ratchet - 140mm 1000Volt 31395 11 Piece Insulated 1/4” T-handle & Socket Set - Metric CV steel, forged, oil-hardened sockets. Insulated after EN/IEC 60900. Item No. 31395 Set includes the following: 5, 6, 7, 8, 9, 10, 11, 12, 13, 14mm lbs. 1.40 Insulated 1/4” T-handle Each tool individually tested to 10,000 volts & certified to 1000 Volt ac or 1500 Volt dc 1000Volt Wiha Insulated 1/4” Socket accessories 31391 13 Piece Insulated 1/4” Drive Socket Set - Metric CV steel, forged, oil-hardened sockets. Insulated after EN/IEC 60900. Item No. 31391 Set includes the following: 5, 6, 7, 8, 9, 10, 11, 12, 13, 14mm lbs. 1/4” x 50mm Extension Bar 1.41 1/4” x 100mm Extension Bar 1/4” Ratchet - 140mm 1000Volt 29006 Insulated 1/4” Drive T-handle, With Insulated Handle Insulation according to EN/IEC 60900 & CSA specification, up to 1000 Volt. Individually Tested. Blade CV steel, hardened. Item OAL OAL No. Inch mm Inch lbs. pkg. 29006 1/4 160 6.2” .57 1 1000Volt 11 Piece Insulated 1/4” T-handle & Socket Set - Inch 31394 CV steel, forged, oil-hardened sockets. Insulated after EN/IEC 60900. Item No. 31394 Set includes the following: 3/16, 7/32, 1/4, 9/32, 5/16, 11/32, lbs. 3/8, 7/16, 1/2, 9/16” 1.40 Insulated 1/4” T-handle 1000Volt 128 Insulated 1/4” Extension Bars, ASTM F-1505-01, EN/IEC 60900 & CSA Chrome-Vanadium steel. Item OAL OAL No. Inch mm Inch lbs. pkg. 12854 1/4” 50 2.0 .08 1 12855 1/4” 100 3.9 .12 1 Toll Free: (800) 494-6104 12 Wiha Insulated 3/8” Sockets & Sets Wiha Insulated 3/8” Sockets & Sets 1000Volt 314 Insulated 3/8” Drive Sockets - Insulation according to EN/IEC 60900, DIN 7448 & CSA specification, up to 1000 Volt. Individually Tested. CV steel, forged, oil-hardened. Item No. Inch lbs. pkg. 31425 1/4 .07 1 31428 9/32 .07 1 31429 5/16 .07 1 31430 11/32 .07 1 31431 3/8 .08 1 31432 7/16 .08 1 31433 1/2 .10 1 31434 9/16 .10 1 31435 5/8 .10 1 31436 11/16 .13 1 31437 3/4 .14 1 31438 13/16 .17 1 31439 7/8 .18 1 *Sockets must be used with insulated ratchets & extensions 1000Volt 31493 10 Piece Insulated 3/8” Drive Socket Set - Inch CV steel, forged, oil-hardened sockets. Insulated to EN/IEC 60900. Item No. 31493 Set includes the following: 5/16, 3/8, 7/16, 1/2, lbs. 9/16, 5/8, 11/16, 3/4” 2.50 3/8” x 125mm Extension Bar 3/8” Ratchet - 280mm 1000Volt 1000Volt Insulated 3/8” Drive Sockets - Metric Insulation according to 315 VDE, EN/IEC 60900, DIN 7448 & CSA specification, up to 1000 Volt. Individually Tested. Chrome-vanadium steel, forged, oil-hardened. Item No. mm lbs. pkg. 31506 6.0 .07 1 31507 7.0 .07 1 31508 8.0 .07 1 31509 9.0 .07 1 31510 10.0 .07 1 31511 11.0 .08 1 31512 12.0 .10 1 31513 13.0 .10 1 31514 14.0 .10 1 31515 15.0 .10 1 31516 16.0 .10 1 31517 17.0 .11 1 31518 18.0 .12 1 31519 19.0 .14 1 31520 20.0 .15 1 31521 21.0 .17 1 31522 22.0 .18 1 31524 24.0 .26 1 *Sockets must be used with insulated ratchets & extensions 31590 10 Piece Insulated 3/8” Drive Socket Set - Metric CV steel, forged, oil-hardened sockets. Insulated to EN/IEC 60900. Item No. Set includes the following: 31590 8, 10, 11, 12, 13, 14, 17, 19mm lbs. 3/8” x 125mm Extension Bar 2.50 3/8” Ratchet - 280mm 1000Volt 31491 16 Piece Insulated 3/8” Drive Socket Set - Inch/Metric CV steel, forged, oil-hardened sockets. Insulated to EN/IEC 60900. Item No. Set includes the following: 31491 5/16, 3/8, 7/16, 1/2, lbs. 9/16, 5/8, 11/16, 3/4” 2.01 8, 10, 11, 12, 13, 14, 17, 19mm www.wihatools.com 13 Wiha Insulated 3/8” Sockets & Sets 1000Volt 1000Volt 31495 24 Piece Insulated 3/8” Drive Socket Set - Inch CV steel, forged, oil-hardened sockets. Insulated to EN/IEC 60900. Item No. 31495 Set includes the following: 1/4, 9/32, 5/16, 11/32, 3/8, 7/16 1/2, 9/16, 5/8,11/16, 3/4” Sockets lbs. 3/8” x 125mm Extension Bar 9.07 3/8” x 250mm Extension Bar 3/8” Ratchet - 190mm Insulated Electrician’s Knife - 50mm Slotted: 3.5, 4.5, 6.5mm Phillips: 1, 2, 3 6.3” Long Nose Pliers 8.0” Combo Pliers 6.3” Diagonal Cutters *Sockets must be used with insulated ratchets & extensions 31496 10 Piece Insulated 3/8” T-handle & Socket Set - Inch CV steel, forged, oil-hardened sockets. Insulated after EN/IEC 60900. Item No. 31496 Set includes the following: 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4” lbs. 3/8” x 125mm Extension Bar 2.47 Insulated 3/8” T-handle 31595 10 Piece Insulated 3/8” T-handle & Socket Set - Metric CV steel, forged, oil-hardened sockets. Insulated after EN/IEC 60900. Item No. 31595 Set includes the following: 8, 10, 11, 12, 13, 14, 17, 19mm lbs. 3/8” x 125mm Extension Bar 2.47 Insulated 3/8” T-handle Wiha Insulated 3/8” Socket accessories 1000Volt 12852 Insulated 3/8” Drive Ratchet, EN/IEC 60900 Chrome-Vanadium steel. Reversible. Item OAL OAL No. Inch mm Inch lbs. pkg. 12852 3/8” 190 7.5 .93 1 1000Volt 1000Volt 31592 24 Piece Insulated 3/8” Drive Socket Set - Metric CV steel, forged, oil-hardened sockets. Insulated to EN/IEC 60900. Item No. 31592 Set includes the following: 6, 7, 8, 9, 10, 11, 12, 13, 14, 17, 19mm Sockets lbs. 3/8” x 125mm Extension Bar 9.08 3/8” x 250mm Extension Bar 3/8” Ratchet - 190mm Insulated Electrician’s Knife - 50mm Slotted: 3.5, 4.5, 6.5mm Phillips: 1, 2, 3 6.3” Long Nose Pliers 8.0” Combo Pliers 6.3” Diagonal Cutters *Sockets must be used with insulated ratchets & extensions 128 Insulated 3/8” Extension Bars, EN/IEC 60900 Chrome-Vanadium steel. Item OAL OAL No. Inch mm Inch lbs. pkg. 12856 3/8” 125 4.9 .41 1 12857 3/8” 250 9.8 .57 1 1000Volt #29009 #12327 1000Volt Insulated 3/8” Drive T-handle Or Breaker Bar Insulation according to EN/IEC 60900 specification, up to 1000 Volt Rated. Individually Tested. Blade chrome-vanadium steel, hardened. Item OAL OAL No. Inch mm Inch lbs. pkg. 3/8 200 7.9” .55 1 29009 12327 3/8 225 9.0” .68 1 Toll Free: (800) 494-6104 14 Wiha Insulated 1/2” Sockets & Sets Wiha Insulated 1/2” Sockets & Sets 1000Volt 317 Insulated 1/2” Drive Sockets - Insulation According to ASTM F-1505-01, DIN 7448 & CSA Specification, Up To 1000 Volt. Individually Tested. CV steel, forged, oil-hardened. Item No. Inch lbs. pkg. 31703 5/16 .16 1 31704 11/32 .16 1 31705 3/8 .16 1 31707 7/16 .16 1 31708 1/2 .16 1 31709 9/16 .17 1 31710 5/8 .19 1 31712 11/16 .19 1 31713 3/4 .21 1 31714 13/16 .23 1 31715 7/8 .27 1 31716 15/16 .35 1 31718 1 .33 1 31720 1-1/8 .44 1 31722 1-1/4 .58 1 *Sockets must be used with insulated ratchets & extensions 1000Volt 31790 24 Piece Insulated 1/2” Drive Socket Set - Inch CV steel, forged, oil-hardened sockets. Insulated to EN/IEC 60900. Item No. Set includes the following: 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1” Sockets 31790 1/2” x 125mm Extension Bar lbs. 1/2” x 250mm Extension Bar 11.41 1/2” Ratchet - 260mm Insulated Electrician’s Knife - 50mm Slotted: 3.5, 4.5, 6.5mm & Phillips: 1, 2, 3 6.3” Long Nose Pliers 8.0” Combo Pliers 6.3” Diagonal Cutters Each tool individually tested to 10,000 volts & certified to 1000 Volt ac or 1500 Volt dc Individually Tested 1000Volt 316 Insulated 1/2” Drive Sockets - Metric Insulation According to VDE, DIN 7448 & CSA Specification, Up To 1000 Volt. Item No. mm lbs. pkg. 31608 8.0 .15 1 31609 9.0 .15 1 31610 10.0 .16 1 31611 11.0 .16 1 31612 12.0 .16 1 31613 13.0 .17 1 31614 14.0 .17 1 31615 15.0 .17 1 31616 16.0 .19 1 31617 17.0 .19 1 31618 18.0 .20 1 31619 19.0 .21 1 31620 20.0 .25 1 31621 21.0 .25 1 31622 22.0 .28 1 31623 23.0 .29 1 31624 24.0 .30 1 31626 26.0 .37 1 31627 27.0 .41 1 31628 28.0 .44 1 31630 30.0 .51 1 31632 32.0 .55 1 *Sockets must be used with insulated ratchets & extensions Metric 1000Volt 31691 24 Piece Insulated 1/2” Drive Socket Set - Metric CV steel, forged, oil-hardened sockets. Insulated to EN/IEC 60900. Item No. Set includes the following: 31691 8, 9, 10, 12, 13, 14, 15, 17, 19, 22, 24mm Sockets 1/2” x 125mm Extension Bar lbs. 1/2” x 250mm Extension Bar 11.39 1/2” Ratchet - 260mm Insulated Electrician’s Knife - 50mm Slotted: 3.5, 4.5, 6.5mm & Phillips: 1, 2, 3 6.3” Long Nose Pliers 8.0” Combo Pliers 6.3” Diagonal Cutters 1000Volt 12326 Insulated 1/2” Drive Breaker Bar, IEC/EN 60900 & CSA Chrome-Vanadium steel. Item OAL OAL No. Inch mm Inch lbs. pkg. 12326 1/2” 250 9.8 1.04 1 www.wihatools.com 15 Wiha Insulated 1/2” Socket accessories Wiha Insulated Cable Cutters For cutting solid aluminum & copper conductors 1000Volt 12853 Insulated 1/2” Drive Ratchet, IEC/EN 60900 & CSA Chrome-Vanadium steel. Reversible. Item OAL OAL No. Inch mm Inch lbs. pkg. 12853 1/2” 260 10.2 1.55 1 1000Volt 128 Insulated 1/2” Extension Bars, EN/IEC 60900 & CSA Chrome-vanadium steel. Item OAL OAL No. Inch mm Inch lbs. pkg. 12858 1/2” 125 4.9 .45 1 12859 1/2” 250 9.8 .91 1 1000Volt 29012 Insulated 1/2” Drive T-handle, With Insulated Handle Insulation according to EN/IEC 60900 & CSA Specification, Up To 1000 Volt. Individually Tested. Blade VC steel, hardened. Item OAL OAL No. Inch mm Inch lbs. pkg. 29012 1/2 200 7.9” .68 1 Uses standard 12” blade 1000Volt 19767 Hacksaw, With Insulated Handle Insulation According to EN/IEC 60900, DIN ISO 8976, ASTM F-1505 & CSA Specification, Up To 1000 Volt. Individually Tested. Item OAL OAL No. mm Inch lbs. pkg. 19767 457mm 18.0” 1.92 1 1000Volt 29240 Waterpump Pliers, With Insulated Handle Insulation According to EN/IEC 60900, DIN ISO 8976, ASTM F-1505 & CSA Specification, Up To 1000 Volt. Individually Tested. Box joint. Chrome-vanadium steel, drop forged, oil hardened. Item OAL OAL Capacity No. mm Inch mm lbs. pkg. 29240 240 9.5 7/8” 1.1 1 1000Volt 11950 Cable Cutter, With Insulated Handle Insulation According to EN/IEC 60900, ASTM F-1505 & CSA Specification, Up To 1000 Volt. Individually Tested. Blade alloyed tool steel. Induction hardened. Item OAL OAL Capacity No. mm Inch mm Inch lbs. pkg. 500 19.6 12 1/2” 3.0 1 11950 For cutting multi strand aluminum & copper cables 31.5” 1000Volt 40800 Large Capacity Cable Cutter, With Insulated Handle Insulation According to EN/IEC 60900, ASTM F-1505 & CSA Specification, Up to 1000 Volt. Individually Tested. Easy cutting blades, dropped forged, oil hardened. Cuts cable diameters up to 50mm. Not to be used on steel rods. Item OAL OAL Capacity No. mm Inch mm Inch lbs. pkg. 40800 800 31.5 50 2” 8.0 1 For cutting solid aluminum, copper & medium hard wires 1000Volt 29250 End Cutters, With Insulated Handle. Insulation According to EN/IEC 60900, DIN ISO 8976, ASTM F-1505 & CSA Specification. Individually Tested. Blade alloyed tool steel. Induction hardened. Item OAL OAL Capacity No. mm Inch mm lbs. pkg. 250 10 7/8” 1.1 1 29250 1000Volt Waterpump Pliers, With Insulated Handle 116 Insulation According to EN/IEC 60900, DIN ISO 8976, ASTM F-1505 & CSA Specification, Up To 1000 Volt. Individually Tested. Chrome-vanadium steel, drop forged, oil hardened. Item OAL OAL No. mm Inch lbs. pkg. 250 10.0” 1.2 1 11625 300 12.0” 1.8 1 11630 Toll Free: (800) 494-6104 16 Wiha Insulated Ratcheting Cable Cutters Wiha Insulated Serrated Tweezers Meets EN/IEC Insulation Standards Two layer high contrast insulated coatings Slip guards at tips for user safety 1000Volt High Voltage Double-Insulated Ratcheting Cable Cutters 119 Insulation According to EN/IEC 60900, DIN ISO 8976, ASTM F-1505 & CSA Specification, Up To 1000 Volt. Individually Tested. High leverage ratchet cable cutter with shear type blades cuts stranded and flexible copper and aluminum cable. Not for use on steel. Features built in safety release in all cutting positions, and high-visibility comfort grip handles. Item OAL OAL up to Inch No. mm Inch MCM Dia. Capacity lbs. pkg. 11960 250 10.0” 500 1.25” 32ml 1.58 1 11975 280 11.0” 750 2.0” 52ml 2.02 1 Carbon steel with chrome nickel plated 1000V 10,000 Volt tested 1000Volt rated Wiha Insulated Serrated Tweezers 1000Volt 1000Volt 75205 Insulated Serrated Straight Fine Tip Tweezers, IEC/EN 60900 & CSA Standards, 10,000 Volt Tested Item OAL OAL No. mm Inch lbs. pkg. 75205 130 5.0 .06 1 1000Volt 75210 Insulated Serrated Straight Blunt Tip Tweezers, IEC/EN 60900 & CSA Standards, 10,000 Volt Tested Item OAL OAL No. mm Inch lbs. pkg. 75210 130 5.0 .08 1 1000Volt 75215 Insulated Serrated Straight Blunt Tip Tweezers, IEC/EN 60900 & CSA Standards, 10,000 Volt Tested Item OAL OAL No. mm Inch lbs. pkg. 75215 145 6.0 .10 1 75220 Insulated Serrated Straight Blunt Tip Tweezers, IEC/EN 60900 & CSA Standards, 10,000 Volt Tested Item OAL OAL No. mm Inch lbs. pkg. 75220 200 8.0 .18 1 1000Volt 75302 Insulated Serrated Angled Fine Tip Tweezers, IEC/EN 60900 & CSA Standards, 10,000 Volt Tested Item OAL OAL No. mm Inch lbs. pkg. 75302 145 6.0 .08 1 1000Volt 75304 Insulated Serrated Angled Blunt Tip Tweezers, IEC/EN 60900 & CSA Standards, 10,000 Volt Tested Item OAL OAL No. mm Inch lbs. pkg. 75304 200 8.0 .16 1 www.wihatools.com 17 Wiha Insulated T-handles Each tool individually tested to 10,000 volts and rated to 1000 Volt ac or 1500 Volt dc Insulation Test Standards: Insulation according to EN/IEC 60900, ASTM F-1505-01, VDE 0682/part 201, DIN 7437, NFPA70E & CSA specification Responds to OSHA’s use specification 29 CFR1910 Insulation Molded directly onto blade for permanent bonding Blade CVM tool steel, hardened to average 58/60RC 1000V 1000Volt 334 Inch T-handle, With Wiha-Molded Handle. Insulation According to ASTM F-1505-01, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000Volt. Individually Tested. Blade CVM steel, hardened. Insulation molded directly onto blade. Wiha-SoftFinish® handle, multi-component. Item No. Inch Inch Inch mm lbs. pkg. 33481 5/32 5.9 6.9 176 .09 10 33482 3/16 5.9 6.9 176 .15 10 33483 7/32 5.9 6.9 176 .19 10 33485 1/4 5.9 7.1 176 .20 10 33486 5/16 5.9 7.1 176 .26 10 33487 3/8 5.9 7.1 176 .44 10 1000Volt 33490 Item No. 33490 6 Piece Inch T-handle Hex Set Inch: 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” lbs. 1.66 1000Volt 334 Metric T-handle, With Wiha-Molded Handle. Insulation According to ASTM F-1505-01, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000Volt. Individually Tested. Blade CVM steel, hardened. Insulation molded directly onto blade. Wiha-SoftFinish® handle, multi-component. Item No. mm mm Inch mm Inch lbs. pkg. 33441 4.0 150 5.9 176 6.9 .09 10 33443 5.0 150 5.9 182 7.1 .15 10 33445 6.0 150 5.9 182 7.1 .18 10 33447 8.0 150 5.9 182 7.1 .26 10 33449 10.0 150 5.9 191 7.5 .46 10 33478 5 Piece Metric T-handle Hex Set Item No. Metric: 33478 4.0, 5.0, 6.0, 8.0, 10.0mm lbs. 1.20 Toll Free: (800) 494-6104 18 Wiha Multi-Bit Screwdrivers Six Tools in One! Wiha Insulated TorqueControl Tools Includes Certificate Insulated Bit Holder Tested to 10,000 Volts 1000Volt Includes SlimLine blade holder 287 Insulated TorqueVario-S, With Window Scale Insulation up to 1000 Volt. EN/IEC 60900 EN ISO 6798, BS EN 26789, ASME B107.14M &CSA, +/- 6% Accuracy. Ergonomic multi-component handle, light & compact. Handle sizes proportioned to optimize torque range. Audible & perceptible click when torque setting has been attained. Insulation meets EN/IEC 60900 380 Sets Multi-Bit Screwdriver Sets with Wiha Powerhandle, cellulose-acetate, impact resistant. Snap-lock rotatable cap. Chambered bit holder equipped with transparent selector and 6 bits. 1/4” Bit holder, stainless steel. Shaft chrome-vanadium-molybdenum steel, hardened, chrome-plated. Packaged in clear blister package. Blade Length = 120mm (4.7”) Overall Length = 230mm (9”) 38006 Slotted/Phillips Multi-Bit Screwdriver With Wiha Powerhandle and insulated shaft. Set includes the following 1/4” bits: Slotted Sizes: 5.5, 6.5mm lbs. Phillips Sizes: 0, 1, 2, 3 .39 38007 Slotted/Phillips/Square Multi-Bit Screwdriver With Wiha Powerhandle and insulated shaft. Set includes the following 1/4” bits: Slotted Sizes: 6.5, 8.0mm lbs. Phillips Sizes: 1, 2 .41 Square Sizes: 1, 2 38025 Magnetic Bit Holder, 1/4” Wiha Powerhandle and insulated shaft. Holder only can hold up to 6 bits. lbs. .26 Item Range No. Inch lbs. Increments mm lbs. pkg. 7.5 - 20 .5 Inch lbs 126 - 131 .43 1 28724 10 - 50 2 Inch lbs 133 - 138 .40 1 28726 20 - 70 2 Inch lbs 137 - 142 .69 1 28727 287 Insulated TorqueVario-S Handle - In Newton Meter Scale Item Range No. Nm mm lbs. pkg. 0.6 - 2.0 131 .45 1 28734 1.0 - 5.0 138 .45 1 28736 2.0 - 8.0 142 .72 1 28737 Each TorqueVario handle has unique serial number & certificate of calibration 1000Volt 28350 Insulated SlimLine Torque Blade Holder Chrome-vanadium-molybdenum steel. Through hardened black finish. ClicFix quick release holder securely locks bits. Item OAL OAL No. mm mm Inch lbs. pkg. 28350 6.0 170 6.7 .02 1 Wiha Insulated TorqueControl & SlimLine Tool Sets 1000Volt 1000Volt 28791 8 Piece Insulated TorqueControl Set With Slotted & Phillips SlimLine Blades Certified to EN ISO 6798, BS EN 26789, ASME B107.14M. Set includes Insulated multi-component adjustable TorqueVario-S handle, 5 SlimLine blades, SlimLine blade holder & Torque adjustment tool. Item No. lbs. SlimLine Slotted: 3.0, 4.0, 5.5mm .87 28791 SlimLine Phillips: #1, #2 28726 - Handle Range 10-50 Inch/lbs. SlimLine Blade Holder With Certificate of Calibration 28792 16 Piece Insulated TorqueControl Set With SlimLine Blades Certified to EN ISO 6798, BS EN 26789, ASME B107.14M. Set includes Insulated multi-component adjustable TorqueVario-S handle, 13 SlimLine blades, SlimLine blade holder & Torque adjustment tool. Item No. lbs. 28792 SlimLine Slotted: 4.0, 5.5, 6.5mm 1.27 SlimLine Phillips: #1, 2 SlimLine Terminal Xeno: #1, 2 SlimLine : T8, T10, T15, T20 SlimLine Square: #1, 2 28727 - Handle Range 20-70 Inch/lbs. SlimLine Blade Holder With Certificate of Calibration www.wihatools.com 19 Wiha Insulated SlimLine Tools Insulation Test Standards: Insulation according to EN/IEC 60900, ASTM F-1505-01, VDE 0682/part 201, DIN 7437, NFPA70E & CSA specification Wiha SlimTECHNOLOGY Achieves blade diameters up to 33% narrower utilizing integrated insulation Ideal for jobs where access is limited Integrated Slim Insulation molded directly onto blade High quality chrome vanadium steel, through-hardened Insulation does not exceed screw head diameter 1000Volt Rated 10,000 Volt Tested Wiha Insulated SlimLine Handle Wiha Insulated SlimLine Blades 1.8” 1000Volt 28301 SlimLine Blade Holder, With Wiha-SoftFinish® Handle Insulation According to VDE, ASTM F-1505-01 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Chrome-vanadium steel, through-hardened. Insulation molded directly onto blade. Quick release holder securely lock blades. Wiha-SoftFinish® handle, multi-component, cushion grip. Item No. Size mm Inch mm Inch lbs. pkg. 1/4” 50 2.0 160 6.3 .15 1 28301 283 Insulated Slotted SlimLine Blades High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Working length 2.8” Item Slim Max Inch/ No. mm Inch Inch mm Dia. Nm lbs. lbs. Pkg. 28308 3.0 .118 1/8 90 4.1 0.6 5.3 .02 1 28309 4.0 .157 5/32 90 4.1 2.5 22.2 .02 1 28312 5.5 .216 7/32 90 6.1 3.8 33.7 .02 1 28315 6.5 .255 1/4 90 6.1 5.5 48.8 .02 1 1.8” 33% narrower insulation diameter Insulated Phillips SlimLine Blades 283 High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Item Slim Working Max Inch/ No. Size mm Dia. Length Nm lbs. lbs. Pkg. 1 90 4.1 2.8” 3.8 33.7 .02 1 28317 2 90 6.1 2.8” 5.5 48.8 .02 1 28319 Slim Diameter Toll Free: (800) 494-6104 20 Wiha Insulated SlimLine Blades Wiha Insulated SlimLine Blade Sets 1.8” 283 Insulated Xeno Slotted & Phillips SlimLine Blades High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Item Slim Working Max Inch/ No. Size mm Dia. Length Nm lbs. lbs. Pkg. 28327 1 90 4.1 2.8” 3.8 33.7 .02 1 28329 2 90 6.1 2.8” 5.5 48.8 .02 1 1.8” SlimLine Blades 283 Insulated High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Item Slim Working Max Inch/ No. Size mm Dia. Length Nm lbs. lbs. Pkg. 28339 T8 90 4.1 2.8” 1.3 11.5 .02 1 28340 T10 90 4.1 2.8” 3.8 33.7 .02 1 28341 T15 90 6.1 2.8” 5.5 48.8 .02 1 28342 T20 90 6.1 2.8” 5.5 48.8 .02 1 1000Volt 28391 8 Piece Insulated SlimLine Blade Set High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Cushion grip handle with quick release holder to securely lock blades. In roll up pouch Item No. lbs. 28391 Slotted: 4.0, 6.5 x 90mm .45 Phillips: #1, #2 x 90mm Xeno: #2 x 90mm : T15, T20 x 90mm 28301 - SlimLine Cushion Grip Blade Holder 1.8” 283 Insulated Square SlimLine Blades High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Item Slim Working Max Inch/ No. Size mm Dia. Length Nm lbs. lbs. Pkg. 28346 1 90 4.1 2.8” 3.8 33.7 .02 1 28347 2 90 6.1 2.8” 5.5 48.8 .02 1 1000Volt 28390 15 Piece Insulated SlimLine Blade Set High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Cushion grip handle with quick release holder to securely lock blades. In roll up pouch Item No. lbs. Slotted: 3.0, 4.0, 5.5, 6.5 x 90mm .56 28390 Phillips: #1, #2 x 90mm Xeno: #1, #2 x 90mm : T8, T10, T15, T20 x 90mm Square: #1, #2 x 90mm 28301 - SlimLine Cushion Grip Blade Holder www.wihatools.com 21 Wiha Insulated SlimLine Screwdrivers Insulation Test Standards: Insulation according to EN/IEC 60900, ASTM F-1505-01, VDE 0682/part 201, DIN 7437, NFPA70E & CSA specification Wiha SlimTECHNOLOGY Achieves blade diameters up to 33% narrower utilizing integrated insulation Integrated Slim Insulation molded directly onto blade Ideal for jobs where access is limited 1000Volt Rated 10,000 Volt Tested 1.4” 1.4” 320 Insulated Slotted SlimLine Screwdrivers Insulation According to ASTM F-1505-01, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested to 10,000Volts. High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Wiha-SoftFinish® handle, multi-component, cushion grip. Item Slim No. mm Inch Inch Dia. mm mm lbs. Pkg. 3.5 .139 9/64 3.5 100 204 .07 1 32046 4.0 .157 5/32 4.0 100 211 .12 1 32049 4.5 .177 3/16 4.5 125 211 .14 1 32052 5.5 .216 7/32 5.5 125 243 .21 1 32055 6.5 .255 1/4 6.5 150 268 .25 1 32058 1.4” 321 Insulated Phillips SlimLine Screwdrivers Insulation According to ASTM F-1505-01, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested to 10,000Volts. High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Wiha-SoftFinish® handle, multi-component, cushion grip. Item Slim No. Size Dia. mm mm lbs. Pkg. 32145 1 4.5 80 204 .12 1 32146 2 6.0 100 211 .21 1 Insulated Xeno SlimLine Screwdrivers For Terminal Screws 307 Insulation According to ASTM F-1505-01, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested to 10,000Volts. High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Wiha-SoftFinish® handle, multi-component, cushion grip. Item Slim No. Size Dia. mm mm lbs. Pkg. 30746 1 4.5 80 191 .12 1 30747 2 6.0 100 218 .21 1 1.4” Insulated Square SlimLine Screwdrivers 358 Insulation According to ASTM F-1505-01, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested to 10,000Volts. High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Wiha-SoftFinish® handle, multi-component, cushion grip. Item Slim No. Size Dia. mm mm lbs. Pkg. 1 4.0 100 218 .12 1 35844 2 4.5 125 243 .19 1 35845 Toll Free: (800) 494-6104 22 Wiha Insulated SlimLine Screwdriver Sets 1000Volt 1000Volt 32198 11 Piece Insulated SlimLine Slotted, Phillips, Xeno & Square Screwdrivers. Insulation According to ASTM F-1505-01, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested to 10,000Volts. High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Wiha-SoftFinish® handle, multi-component, cushion grip. Item No. Size mm mm mm lbs. Slotted 3.5 100 1.75 32198 Phillips 1 80 Slotted 4.0 100 Phillips 2 100 Slotted 4.5 125 Slotted 5.5 125 Square 1 100 Slotted 6.5 150 Square 2 125 Xeno 1 80 Xeno 2 100 1000Volt 32197 8 Piece Insulated SlimLine Slotted, Phillips & Square Screwdrivers. Insulation According to ASTM F-1505-01, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested to 10,000Volts. High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Wiha-SoftFinish® handle, multi-component, cushion grip. Item No. Size mm mm mm lbs. Slotted 3.5 100 1.18 Phillips 1 80 32197 Slotted 4.0 100 Phillips 2 100 Slotted 4.5 125 Slotted 5.5 125 Square 1 100 Square 2 125 32196 6 Piece Insulated SlimLine Slotted, Phillips & Square Screwdrivers. Insulation According to ASTM F-1505-01, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested to 10,000Volts. High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Wiha-SoftFinish® handle, multi-component, cushion grip. Item No. Size mm mm mm lbs. Slotted 4.5 125 32196 1.02 Phillips 1 80 Slotted 6.5 150 Phillips 2 100 Square 1 100 Square 2 125 1000Volt 32189 2 Piece Insulated SlimLine Slotted & Phillips Screwdrivers Insulation According to ASTM F-1505-01, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested to 10,000Volts. High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Item No. Size mm mm mm lbs. 32189 2 100 4.5 125 .37 Wiha Slim TECHNOLOGY Achieves blade diameters up to 33% narrower utilizing Wiha integrated insulation www.wihatools.com 23 Wiha Insulated Screwdrivers with SoftFinish® Cushion Grip Handle Each tool individually tested to 10,000 volts and rated to 1000 Volt ac or 1500 Volt dc Insulation Test Standards: Insulation according to EN/IEC 60900, ASTM F-1505-01, New VDE 0682/part 201, DIN 7437, NFPA70E & CSA SoftFinish ® handle solid molded core with soft outer cushion grip. 40% more torque than conventional handles Responds to OSHA’s use specification 29 CFR1910 #32892 Insulation Molded directly onto the blade for permanent bonding Blade CVM tool steel, hardened to average 58/60RC 1000V page 32 1000Volt 1000Volt 320 Slotted Screwdriver, With Wiha-SoftFinish® Handle Insulation According to ASTM F-1505-01, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested. Item No. mm Inch Inch mm Inch mm Inch lbs. pkg. 2.0 .078 5/64 60 3.0 164 6.5 .05 10 32005 2.5 .098 3/32 75 3.0 179 7.1 .06 10 32010 3.0 .118 1/8 100 4.0 204 8.0 .07 10 32012 3.5 .139 9/64 100 4.0 204 8.0 .07 10 32015 4.0 .157 5/32 100 4.0 211 8.3 .12 10 32017 4.5 .177 3/16 100 4.0 211 8.3 .12 10 32023 4.5 .177 3/16 125 5.0 236 9.3 .12 10 32024 4.5 .177 3/16 150 6.0 261 10.2 .14 10 32027 4.5 .177 3/16 175 7.0 286 11.2 .13 10 32025 4.5 .177 3/16 200 8.0 311 12.3 .15 10 32028 5.5 .216 7/32 125 5.0 243 9.5 .15 10 32031 5.5 .216 7/32 175 7.0 293 11.5 .21 10 32026 32034 6.0 .236 15/64 150 6.0 268 10.6 .21 10 6.5 .255 1/4 150 6.0 268 10.6 .21 10 32039 8.0 .315 5/16 175 7.0 299 11.8 .34 10 32042 32045 10.0 .393 3/8 200 8.0 318 12.5 .39 10 Phillips Screwdriver, With Wiha-SoftFinish® Handle 321 Insulation According to ASTM F-1505-01, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested. Item No. Size mm Inch mm Inch lbs. pkg. 32100 0 60 2.4 164 6.5 .06 10 32101 1 80 3.0 191 7.5 .12 10 32102 2 100 4.0 218 8.6 .20 10 32103 3 150 6.0 268 10.6 .34 10 32104 4 200 8.0 318 12.5 .39 10 1000Volt 32092 6 Piece Slotted & Phillips Set Item No. lbs. 32092 Slotted: 3.5, 4.5, 6.5 Phillips: 1, 2, 3 1.38 32091 5 Piece Slotted & Phillips Set Item No. lbs. Slotted: 3.0, 4.5, 6.5 Phillips: 1, 2 1.31 32091 1000Volt 32090 32188 7 Piece Slotted & Phillips Set Item No. 32188 Slotted: 2.0, 2.5, 3.0, 3.5, 4.0 Phillips: 0, 1 lbs. .92 4 Piece Slotted & Phillips Set Item No. Slotted 32090 Slotted mm mm mm Size mm 3.5 100 0.6 Phillips 1 80 4.5 125 1.0 Phillips 2 100 .76 lbs. 1000Volt Toll Free: (800) 494-6104 24 Wiha Insulated Screwdriver Sets Wiha Insulated Hex Mertic Screwdrivers 1000Volt 1000Volt 32094 13 Piece Slotted & Phillips Set Item No. 32094 Slotted: 2.0, 2.5, 3.0, 3.5, 4.5, 5.5, 6.5, 8.0, 10.0mm Phillips: 0, 1, 2, 3 lbs. 2.3 323 Hex Metric Screwdriver, With Wiha-SoftFinish® Handle Insulation According to ASTM F-1505-01, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested. Blade high alloy CVM steel, hardened, black finish. Insulation molded directly onto blade. Wiha-SoftFinish® handle, multi-component, cushion grip. Item No. Size mm Inch mm Inch lbs. pkg. 2.5 75 3.0 179 7.0 .06 10 32302 3.0 75 3.0 179 7.0 .08 10 32303 4.0 75 3.0 186 7.3 .12 10 32304 5.0 75 3.0 186 7.3 .15 10 32305 6.0 100 3.9 218 8.6 .24 10 32306 8.0 100 3.9 218 8.6 .34 10 32308 1000Volt 1000Volt 32093 10 Piece Slotted & Phillips Set Item No. 32093 Slotted: 2.0, 2.5, 3.0, 3.5, 4.5, 6.5 Phillips: 0, 1, 2, 3 32366 6 Piece Insulated Hex Metric Screwdriver Set Item No. lbs. 32366 Hex Metric: 2.5, 3.0, 4.0, 5.0, 6.0, 8.0mm 1.06 lbs. 1.63 1000Volt Wiha Insulated Square Tip Screwdrivers 1000Volt 32190 15 Piece Slotted, Phillips & Inch Nut Drivers Set Item No. Slotted: 2.0, 2.5, 3.0, 3.5, 4.5, 6.5, 8.0mm 32190 Phillips: 1, 2, 3 Nut Drivers Inch: 1/4, 5/16, 3/8, 7/16, 1/2” lbs. 5.9 358 Square Tip Screwdriver, With Wiha-SoftFinish® Handle Insulation According to ASTM F-1505-01, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E and CSA, up to 1000 Volt. Individually Tested. Blade high alloy CVM steel, hardened, black finish. Insulation molded directly onto blade. Item No. Size mm Inch mm Inch lbs. pkg. 35811 1 100 4.0 210 8.2 .12 10 35812 2 150 6.0 268 10.5 .19 10 1000Volt 1000Volt Tool box set in blow molded tray 32095 19 Piece Slotted, Phillips, Square, Xeno Screwdriver Set Insulated Screwdriver set in a light weight tool box tray. Item No. Slotted: 2.5, 3.0, 3.5, 4.0, 4.5, 5.5, 6.0, 6.5, 8.0, 10.0mm 32095 Phillips: #0, #1, #2, #3 Square: #1, #2 lbs. Xeno Terminal: #1, #2 4.92 Single Pole Voltage Detector 110V to 250V 35890 6 Piece Insulated Slotted, Phillips & Square Screwdrivers Item No. 35890 Slotted: 4.5 x 125mm, 6.5 x 150mm lbs. Phillips: 1 x 80mm, 2 x 100mm .83 Square: 1 x 100mm, 2 x 150mm 35891 6 Piece Insulated Slotted, Phillips & Square Screwdrivers 35891 Item No. lbs. Slotted: 3.0, 5.5mm Phillips: 1, 2 Square: 1, 2 .83 www.wihatools.com 25 Wiha Insulated Nut Drivers 1000Volt 322 Metric Nut Drivers, With Wiha-SoftFinish® Handle Insulation According to ASTM F-1505-01, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested. Blade CVM steel, hardened. Insulation molded directly onto blade. Deep drawn 1” socket. Wiha-SoftFinish® handle, multi-component. Item No. mm mm mm Inch lbs. pkg. 32206 4.0 125 236 9.3 .15 10 32209 5.0 125 236 9.3 .16 10 32212 5.5 125 236 9.3 .16 10 32215 6.0 125 236 9.3 .16 10 32218 7.0 125 243 9.6 .25 10 32221 8.0 125 243 9.6 .25 10 32224 9.0 125 243 9.6 .25 10 32227 10.0 125 243 9.6 .27 10 32230 11.0 125 243 9.6 .37 10 32233 12.0 125 243 9.6 .38 10 32236 13.0 125 243 9.6 .39 10 32238 14.0 125 243 9.6 .39 10 32239 15.0 125 243 9.6 .40 10 32240 16.0 125 243 9.6 .42 10 32241 17.0 125 243 9.6 .44 10 322 Item No. 32255 32258 32261 32264 32267 32268 32270 32273 32276 32278 32280 Inch Nut Drivers, With Wiha-SoftFinish® Handle Inch Inch mm Inch lbs. pkg. 5/32 5.0 236 9.3 .15 10 3/16 5.0 236 9.3 .15 10 7/32 5.0 236 9.3 .16 10 1/4 5.0 243 9.5 .24 10 5/16 5.0 243 9.5 .25 10 11/32 5.0 242 9.5 .26 10 3/8 5.0 243 9.5 .26 10 7/16 5.0 243 9.5 .36 10 1/2 5.0 243 9.5 .39 10 9/16 5.0 243 9.5 .39 10 5/8 5.0 243 9.5 .41 10 1000Volt 32291 5 Piece Nut Driver Set - Metric Sizes Item No. mm mm mm mm 32291 6.0 125 9.0 125 7.0 125 10.0 125 8.0 125 lbs. 1.36 1000Volt 32293 7 Piece Nut Driver Set - Metric Sizes Item No. mm mm mm mm 5.0 125 8.0 125 32293 5.5 125 10.0 125 6.0 125 13.0 125 7.0 125 lbs. 2.05 1000Volt 32292 5 Piece Item No. 32292 Nut Driver Set - Inch Sizes Inch 7/32 1/4 5/16 Inch Inch Inch 5.0 3/8 5.0 5.0 1/2 5.0 5.0 lbs. 1.52 1000Volt 32296 11 Piece Nut Driver Set - Inch Sizes Item No. Inch Inch Inch Inch 32296 5/32 5.0 3/8 5.0 3/16 5.0 7/16 5.0 7/32 5.0 1/2 5.0 1/4 5.0 9/16 5.0 5/16 5.0 5/8 5.0 11/32 5.0 1000Volt lbs. 3.00 32294 7 Piece Nut Driver Item No. Inch 3/16 32294 7/32 1/4 5/16 Set - Inch Sizes Inch Inch Inch 5.0 3/8 5.0 5.0 7/16 5.0 5.0 1/2 5.0 5.0 lbs. 2.24 Toll Free: (800) 494-6104 26 Wiha Insulated Inch Nut Driver Set Wiha Insulated Screwdrivers 1000Volt 1000Volt 32288 9 Piece Nut Driver Set - Inch Sizes. In roll-up pouch Item No. Inch Inch Inch Inch lbs. 3/16 5.0 7/16 5.0 3.16 32288 1/4 5.0 1/2 5.0 5/16 5.0 9/16 5.0 11/32 5.0 5/8 5.0 3/8 5.0 Insulated Single-Pole Voltage Detector 1000Volt 25511 Insulated Single-Pole Voltage Detector. 110-250 Volts. Insulation According To DIN 57860/6 And DIN VDE 0680-6, GS Tested. Blade CVM steel, hardened, nickel-plated. Insulation molded directly onto blade. Amber LED light. 10,000Volt tested. Item No. mm mm mm Inch lbs. pkg. 3.0 65 145 5.7 .04 1 25511 Insulated Terminal Block Xeno Screwdrivers Combination Slotted/Phillips Terminal Block Drivers 1000Volt 325 Screwdriver, With Wiha-SoftFinish® Handle Insulation According to ASTM F-1505-01, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E and CSA, up to 1000 Volt. Individually Tested. Blade high alloy cvm steel, hardened, black finish. Insulation molded directly onto blade. Item No. Size mm Inch mm Inch lbs. pkg. 32505 T5 60 2.4 164 6.5 .06 10 32511 T6 60 2.4 164 6.5 .06 10 32516 T7 60 2.4 164 6.5 .06 10 32521 T8 60 2.4 164 6.5 .06 10 32526 T9 60 2.4 164 6.5 .06 10 32531 T10 60 2.4 164 6.5 .06 10 32536 T15 80 3.0 191 7.5 .12 10 32541 T20 80 3.0 191 7.5 .12 10 32546 T25 80 3.0 198 7.8 .17 10 32551 T27 100 4.0 218 8.6 .20 10 32556 T30 100 4.0 218 8.6 .20 10 32561 T40 150 6.0 274 10.8 .30 10 1000Volt 32590 6 Piece Set Item No. Size mm Size mm lbs. 32590 T8 60 T15 80 .83 T9 60 T20 80 T10 60 T25 80 Slotted & Phillips 307 Combination Terminal Block Xeno Screwdriver, With Wiha SoftFinish® Handle. Insulation According to ASTM F-1505-01, VDE, 0682/part 201, EN/IEC 60900, NFPA70E & CSA specification. Individually Tested. Blade CVM steel, hardened, black finish. Insulation molded directly onto blade. Wiha-SoftFinish® handle, multi-component, cushion grip. For combination Slotted/Phillips head terminal screws. Item No. Size mm mm Inch lbs. pkg. 30700 1 80 191 7.5 1.23 10 30701 2 100 218 8.6 1.23 10 1000Volt 32592 10 Piece Item No. 32592 Size T6 T7 T8 T9 T10 Set mm 60 60 60 60 60 Size T15 T20 T25 T27 T30 mm lbs. 80 1.2 80 80 100 100 www.wihatools.com 27 Wiha Insulated “BitFlip” Sets “8-In-1 Bit Sets” BitFlip standard SoftFinish® handle, multi-component, cushion grip, easy access & 8 bit storage 8-in-1 Bit Sets Tested to 10,000Volts Insulated Each insulated tool individually tested to 10,000 volts 38017 Insulated BitFlip With Slotted/Phillips/TORX® Bits Wiha cushion grip handle and insulated shaft. Tested to 10,000 volts. Blade CVM tool steel, hardened lbs. .45 8-in-1 Bit Sets 8-in-1 Bit Sets Tested to 10,000 Volts Tested to 10,000 Volts Insulated Insulated 38016 Insulated BitFlip With Slotted/Phillips/Square Bits Wiha cushion grip handle and insulated shaft. Tested to 10,000 volts. Set includes the following 1/4” bits: Slotted: 4.5, 6.5mm Phillips: 1, 2 TORX® : T10, T15, T20, T25 Set includes the following 1/4” bits: Slotted: 4.5, 6.5mm Phillips: 0, 1, 2, 3 Square: 1, 2 lbs. .45 Use & Care Guide For Insulated Tools: Store tools to minimize risk of damage to insulation, always wear approved eye protection, Inspect insulation prior to each use of any insulated tool. Use insulated tools where the ambient temperature is between -20 to +70O C. Have a qualified safety technician visually inspect insulation on tools annually for safe use. 38018 Insulated BitFlip With Slotted/Phillips Bits Wiha cushion grip handle and insulated shaft. Tested to 10,000 volts. Set includes the following 1/4” bits: Slotted: 4.5, 5.5, 6.5, 8.0mm Phillips: 0, 1, 2, 3 lbs. .45 WARNING! Insulated Tools are intended to provide protection against accidental contact with charged energized circuits. For maximum safety we recommend de-energizing all circuits whenever possible before starting work on electrical apparatus or conductors. Always visually inspect insulation on tools before use, do not use tools if insulation shows signs of wear or damage to the insulated areas of the tool. Wear appropriate eye protection when using hand tools. Use NFPA70E certified insulated protective outer wear when appropriate. Toll Free: (800) 494-6104 28 Wiha Insulated Belt Pack Pouch Sets Insulation Test Standards: Insulation according to EN/IEC 60900, ASTM F-1505-01, New VDE 0682/part 201, DIN 7437, NFPA70E & CSA 1000Volt 32871 3 Piece Insulated Pliers/Cutters & Multi-Bit Set In Belt Pack Pouch Tools meet EN/IEC, ASTM, VDE, NFPA70E & CSA standards. Pliers chrome finish for long lasting corrosion protection. Soft grip ergo designed handle body, safety slip guard. Insulated multi-bit screwdriver includes Slotted, Phillips & Square bits. Item No. Pliers/Cutters & Multi-Bit Set 32871 6.3” / 160mm Diagonal Cutters 8.0” / 200mm Long Nose Pliers Set includes Bit Holder and the following bits: Slotted: 4.5, 6.5mm • Phillips: 1, 2 • Square: 1, 2 lbs. 1.67 1000Volt 32872 5 Piece Insulated Pliers/Cutters & Screwdrivers In Belt Pack Pouch Tools meet EN/IEC, ASTM, VDE, NFPA70E & CSA standards. Pliers chrome finish for long lasting corrosion protection. Soft grip ergo designed handle body, safety slip guard. Insulated cushion grip drivers, multi-component. Blade CVM tool steel, hardened. Item No. Insulated Pliers/Cutters & Screwdrivers 6.3” / 160mm Diagonal Cutters 32872 8.0” / 200mm Long Nose Pliers Insulated Screwdrivers: Slotted: 3.0, 4.5mm • Phillips: 2 lbs. 1.77 1000Volt 32875 5 Piece Insulated Pliers/Cutters & SlimLine Screwdrivers In Belt Pack Pouch Tools meet EN/IEC, ASTM, VDE, NFPA70E & CSA standards. Pliers chrome finish for long lasting corrosion protection. Soft grip ergo designed handle body, safety slip guard. Insulated cushion grip drivers, multi-component. Blade CVM tool steel, hardened. Item No. Insulated Pliers/Cutters & Screwdrivers 32875 9.0” / 225mm Lineman’s Pliers 8.0” / 200mm Long Nose Pliers Insulated SlimLine Screwdrivers: Slotted: 4.5, 6.5mm • Phillips: 2 lbs. 2.26 1000Volt 32873 3 Piece Insulated Pliers/Cutters In Belt Pack Pouch Tools meet EN/IEC, ASTM, VDE, NFPA70E & CSA standards. Pliers chrome finish for long lasting corrosion protection. Soft grip ergo designed handle body, safety slip guard. Item No. Insulated Pliers & Cutters 32873 6.3” / 160mm Diagonal Cutters 8.0” / 200mm Long Nose Pliers 8.0” / 200mm Combination Pliers lbs. 2.07 www.wihatools.com 29 Wiha Insulated Tools-Comfort Grip Handles All Tools In Dedicated Positions For Quick Storage & Easy Location Tracking 1000Volt 32800 80 Piece Insulated Master Electrician’s Tool Set In Rolling Water Tight Traveling Tool Box - 10,000Volt Tested, 1000Volt Rated Insulated Phillips #0 Insulated Slotted 2.5mm Item# 32800 Set Includes: lbs. 33.9 Insulated Phillips #1 Insulated Slotted 3.0mm 6.3” Long Nose Pliers 6.3” Diagonal Cutters Insulated Phillips #2 Insulated Slotted 3.5mm 8.0” Long Nose Pliers 8.0” High Leverage Cutters Insulated Phillips #3 Insulated Slotted 4.0mm 6.3” Bent Nose Pliers 6.3” Cable Cutters Insulated Slotted 4.5mm 6.3” Long Flat Nose Pliers 6.3” Stripping Pliers Insulated Slt/Ph Terminal #1 Insulated Slotted 5.5mm 9.0” Combo Pliers/Crimpers 8.0” Adjustable Wrench Insulated Slt/Ph Terminal #2 Insulated Nut Driver 7/32” Insulated Socket 1/2” Insulated Square #1 Insulated Slotted 6.0mm Insulated Nut Driver 1/4” Insulated Socket 9/16” Insulated Square #2 Insulated Slotted 6.5mm Insulated Nut Driver 5/16” Insulated Socket 5/8” Insulated Torx T6 Insulated Slotted 8.0mm Insulated Nut Driver 3/8” Insulated Socket 11/16” Insulated Torx T7 Insulated Slotted 10.0mm Insulated Nut Driver 7/16” Insulated Socket 3/4” Insulated Torx T8 Insulated T-handle Hex 5/32” Insulated Socket 13/16” Insulated Torx T9 Insulated Nut Driver 5.0mm Insulated T-handle Hex 3/16” Insulated Socket 7/8” Insulated Torx T10 Insulated Nut Driver 5.5mm Insulated T-handle Hex 7/32” Insulated Socket 13mm Insulated Torx T15 Insulated Nut Driver 6.0mm Insulated T-handle Hex 1/4” Insulated Socket 14mm Insulated Torx T20 Insulated Nut Driver 7.0mm Insulated T-handle Hex 5/16” Insulated Socket 15mm Insulated Torx T25 Insulated Nut Driver 8.0mm Insulated T-handle Hex 3/8” Insulated Socket 17mm Insulated Torx T30 Insulated Nut Driver 10.0mm Insulated T-handle Hex 4.0mm Insulated Socket 19mm Insulated Nut Driver 13.0mm Insulated T-handle Hex 5.0mm Insulated L-key 10mm Insulated Socket 20mm Insulated Cable Knife 50mm Insulated T-handle Hex 6.0mm Insulated L-key 1/2” Insulated Socket 22mm 2 Meter Ruler In/MM Insulated T-handle Hex 8.0mm Single Pole Voltage DetectorInsulated Ratchet 3/8” Drive 110V to 250V Insulated 4.9” Extension 3/8” Dr. Use & Care Guide For Insulated Tools: Store tools to minimize risk of damage to insulation, always wear approved eye protection, Inspect insulation prior to each use of any insulated tool. Use insulated tools where the ambient temperature is between -20 to +70O C. Have a qualified safety technician visually inspect insulation on tools annually for safe use. WARNING! Insulated Tools are intended to provide protection against accidental contact with charged energized circuits. For maximum safety we recommend de-energizing all circuits whenever possible before starting work on electrical apparatus or conductors. Always visually inspect insulation on tools before use, do not use tools if insulation shows signs of wear or damage to the insulated areas of the tool. Wear appropriate eye protection when using hand tools. Use NFPA70E certified insulated protective outer wear when appropriate. Toll Free: (800) 494-6104 30 Wiha 1000Volt Insulated Tool Sets - Comfort Grip Handles Master Electrician’s Set 80 Pc. BIGGEST SET 66 Pc. BIGGER SET 1000Volt 1000Volt 32877 80 Piece Insulated Master Electrician’s Set Item# 32877 Set Includes: lbs. 27.0 6.3” Long Nose Pliers 6.3” Diagonal Cutters 6.3” Bent Nose Pliers 8.0” High Leverage Cutters 8.0” Long Nose Pliers 8.0” Cable Cutters 6.3” Long Flat Nose Pliers 6.3” Stripping Pliers 9.0” Combo Pliers/Crimpers 8.0” Adjustable Wrench Insulated Nut Driver 7/32” Insulated Slotted 2.0mm Insulated Nut Driver 1/4” Insulated Slotted 2.5mm Insulated Nut Driver 5/16” Insulated Slotted 3.0mm Insulated Nut Driver 3/8” Insulated Slotted 3.5mm Insulated Nut Driver 7/16” Insulated Slotted 4.0mm Insulated Slotted 4.5mm Insulated Nut Driver 5.0mm Insulated Slotted 5.5mm Insulated Nut Driver 5.5mm Insulated Slotted 6.0mm Insulated Nut Driver 6.0mm Insulated Slotted 6.5mm Insulated Nut Driver 7.0mm Insulated Slotted 8.0mm Insulated Nut Driver 8.0mm Insulated Slotted 10.0mm Insulated Nut Driver 10.0mm Insulated Phillips #0 Insulated Nut Driver 13.0mm Insulated Phillips #1 Insulated T-handle Hex 5/32” Insulated Phillips #2 Insulated T-handle Hex 3/16” Insulated Phillips #3 Insulated T-handle Hex 7/32” Insulated Slt/Ph Terminal #1 Insulated T-handle Hex 1/4” Insulated Slt/Ph Terminal #2 Insulated T-handle Hex 5/16” Insulated T-handle Hex 3/8” Insulated Torx T6 Insulated Insulated Insulated Insulated Insulated Insulated Insulated Insulated Insulated Insulated Insulated Insulated Insulated Insulated Insulated Insulated Insulated Torx T7 Torx T8 Torx T9 Torx T10 Torx T15 Torx T20 Torx T25 Torx T30 Square #1 Square #2 Socket 1/2” Socket 9/16” Socket 5/8” Socket 11/16” Socket 3/4” Socket 13/16” Socket 7/8” Insulated Insulated Insulated Insulated T-handle T-handle T-handle T-handle Hex Hex Hex Hex 4.0mm 5.0mm 6.0mm 8.0mm Insulated L-key 10mm Insulated L-key 1/2” Insulated Cable Knife 50mm 2 Meter Ruler In/MM Insulated Ratchet 3/8” Dr. Insulated 4.9” Extension Insulated Socket 13mm Insulated Socket 14mm Insulated Socket 15mm Insulated Socket 17mm Insulated Socket 19mm Insulated Socket 20mm Insulated Socket 22mm 32876 66 Pc. Master Electrician’s Set. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. Pliers drop-forged from special tool steel, individually high frequency induction hardened, chrome/nickel plated, mirror-polished. Item# Set Includes: 32876 8.0” Long Nose 6.3” Long Flat Nose 9.0” Combo Pliers/Crimpers 8.0” Cable Cutters Insulated Nut Driver 1/4” Insulated Nut Driver 5/16” Insulated Nut Driver 11/32” Insulated Nut Driver 3/8” Insulated Nut Driver 7/16” Insulated T-handle Hex 4.0mm Insulated T-handle Hex 5.0mm Insulated T-handle Hex 6.0mm Insulated T-handle Hex 8.0mm Insulated T-handle Hex 5/32” Insulated T-handle Hex 3/16” Insulated T-handle Hex 7/32” Insulated T-handle Hex 1/4” Insulated T-handle Hex 5/16” Insulated T-handle Hex 3/8” Insulated Hex L-key 10.0mm Insulated Hex L-key 1/2” Insulated Socket 1/2” Insulated Socket 9/16” Insulated Socket 5/8” Insulated Socket 11/16” Insulated Socket 3/4” Insulated Socket 13/16” Insulated Socket 7/8” Insulated Socket 8.0mm Insulated Socket 10.0mm Insulated Socket 13.0mm Insulated Socket 14.0mm Insulated Socket 15.0mm lbs. 21.5 6.3” Side Cutters 8.0” High Leverage Cutters 6.3” Stripping Pliers 8.0” Adjustable Wrench Insulated Slotted 2.0mm Insulated Slotted 2.5mm Insulated Slotted 3.0mm Insulated Slotted 4.0mm Insulated Slotted 4.5mm Insulated Slotted 5.5mm Insulated Slotted 6.0mm Insulated Slotted 8.0mm Insulated Slotted 10.0mm Insulated Phillips #0 Insulated Phillips #1 Insulated Phillips #2 Insulated Phillips #3 Insulated Torx T8 Insulated Torx T10 Insulated Torx T15 Insulated Torx T20 Insulated Torx T25 Insulated Torx T30 Insulated Square #1 Insulated Square #2 Insulated Slt/Ph Terminal #1x80 Insulated Slt/Ph Terminal #2x100 Insulated Cable Knife 50mm Insulated Extension 4.9” Insulated Ratchet 3/8” Driver Insulated Socket 17.0mm Insulated Socket 19.0mm Insulated Socket 22.0mm www.wihatools.com 31 Wiha 1000Volt Insulated Tool Sets - Comfort Grip Handles 25 Pc. Set 1000Volt 48 Pc. BIG SET 1000Volt 32874 48 Piece Insulated Tool Set. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. Pliers drop-forged from special tool steel, individually high frequency induction hardened, chrome/nickel plated, mirror-polished. Cushion Grip Insulated handles. Canvas tool bag. 32874 Item# Set Includes: lbs. 19.4 6.3” Long Nose Pliers 6.3” Side Cutters 8.0” Long Nose Pliers 8.0” High Leverage Cutters 6.3” Combination Pliers 6.3” Stripping Pliers 9.0” Combo Pliers/Crimpers 8.0” Adjustable Wrench Slotted: 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.5, 6.0, 6.5, 8.0mm Phillips: #0, 1, 2, 3 Square: #1, 2 Slt/Ph Terminal: #1, 2 TORX: T8, T9, T10, T15, T20, T25, T27, T30 Hex Inch: 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Nut Driver Inch: 7/32, 1/4, 5/16, 3/8, 7/16, 1/2” Insulated Cable Knife & 2 Meter In/MM 32879 25 Piece Pliers & Screwdriver Set. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. Pliers drop-forged from special tool steel, individually high frequency induction hardened, chrome/nickel plated, mirror-polished. In tool box. Item# 32879 Set Includes: lbs. 11.92 8.0” Long Nose 6.3” Stripping Pliers 9.0” Combination Pliers Inch & Metric Folding Ruler 8.0” High Leverage Cutters 8.5” Insulated Knife Slotted: 3.0, 4.5, 6.0mm Phillips: #1, #2 Square: #1, #2 Terminal Block Driver: #1, #2 Inch Nut Driver: 1/4, 5/16, 11/32, 3/8, 7/16, 1/2” Metric Nut Driver: 7.0, 8.0, 10.0, 13.0mm 31 Pc. Set 13 Pc. Set 1000Volt 1000Volt 32878 13 Piece Pliers & Screwdriver Set. In canvas tool bag Item# 32878 Set Includes: lbs. 6.60 8.0” Long Nose 9.0” Combo Pliers/Crimpers 8.0” High Leverage Cutters 50mm Cable Stripping Knife Insulated Slotted: 3.0mm Insulated Phillips: #1 Insulated Slotted: 4.5mm Insulated Phillips: #2 Insulated Slotted: 6.0mm Insulated Square: #1 Insulated Slt/Ph Terminal: #1 Insulated Square: #2 Insulated Slt/Ph Terminal: #2 32896 31 Piece Pliers & Screwdriver Set. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. Pliers drop-forged from special tool steel, individually high frequency induction hardened, chrome/nickel plated, mirror-polished. Set includes 6ft. Fiber glass folding ruler. Item# 32896 Set Includes: lbs. 12.85 6.3” Long Nose Pliers 6.3” Side Cutters 8.0” Long Nose Pliers 8.0” High Leverage Cutters 7.0” Linemans Pliers 6.3” Stripping Pliers 9.0” Combination Pliers 6.3” Round Nose Pliers Slotted: 2.0, 2.5, 3.0, 3.5, 4.5, 5.5, 6.5, 8.0, 10.0mm Phillips: #0, #1, #2, #3 Inch Nut Driver: 5/32, 3/16, 7/32, 1/4, 5/16, 3/8, 7/16, 1/2, 9/16” Toll Free: (800) 494-6104 32 Wiha Insulated Pliers with High Visibility Comfort Grip Handle 1000Volt 1000Volt • Pliers drop-forged from special tool steel, individually high frequency induction hardened, chrome and nickel plated, mirror-polished. • In zipper carry case 32891 10 Piece Pliers & Screwdriver Set Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. Item# 32891 Set Includes: lbs. 5.54 8.0” Combination Pliers 8.0” Long Nose 8.0” Side Cutters 8.0” Cable Cutters 6.3” Universal Wire Stripper Insulated Phillips #1 Insulated Slotted 4.5mm Insulated Phillips #2 Insulated Slotted 6.5mm Insulated Phillips #3 • Pliers drop-forged from special tool steel, individually high frequency induction hardened, chrome and nickel plated, mirror-polished. • In zipper carry case 1000Volt 32895 14 Piece Pliers & Screwdriver Set Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. Item# 32895 Set Includes: lbs. 6.60 8.0” Long Nose 6.3” Side Cutters 9.0” Combination Pliers 8.0” High Leverage Cutters 6.3” Stripping Pliers Insulated Slotted 2.5mm Insulated Phillips #1 Insulated Slotted 3.0mm Insulated Phillips #2 Insulated Slotted 3.5mm Insulated Phillips #3 Insulated Slotted 4.5mm Insulated Slotted 2.0mm Insulated Slotted 6.5mm 32888 11 Piece Pliers & Screwdriver Set In Canvas Pouch Item# 32888 Set Includes: lbs. 3.58 6.3” Long Nose 6.3” Side Cutters 8.0” Combination Pliers 6.3” Stripping Pliers Insulated Slotted 2.5mm Insulated Phillips #0 Insulated Slotted 3.5mm Insulated Phillips #1 Insulated Slotted 4.5mm Insulated Phillips #2 Insulated Slotted 6.0mm 1000Volt 32892 10 Piece Pliers & Screwdriver Set. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. Pliers drop-forged from special tool steel, individually high frequency induction hardened, chrome and nickel plated, mirror-polished. In canvas tool bag Item# 32892 Set Includes: lbs. 6.64 8.0” Bent Nose 8.0” Combination Pliers 6.3” Long Nose 6.3” Side Cutters Insulated Phillips #0 Insulated Slotted 3.0mm Insulated Phillips #1 Insulated Slotted 4.5mm Insulated Phillips #2 Insulated Slotted 6.5mm 1000Volt 32894 12 Piece Pliers & Screwdriver Set In canvas tool bag Item# 32894 Set Includes: lbs. 8.60 8.0” Bent Nose 8.0” Combination Pliers 6.3” Long Nose 6.3” Side Cutters Insulated Slotted 4.5mm Insulated Nut Driver 1/4” Insulated Slotted 6.5mm Insulated Nut Driver 5/16” Insulated Phillips #1 Insulated Nut Driver 3/8” Insulated Phillips #2 Insulated Nut Driver 1/2” www.wihatools.com 33 Wiha Insulated Pliers with High Visibility Comfort Grip Handle • Pliers drop-forged from special tool steel, individually high frequency induction hardened, chrome and nickel plated, mirror-polished. 1000Volt 32889 8 Piece Pliers & Cutters Set Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. Item# 32889 Set Includes: lbs. 4.63 6.3” Long Nose Pliers 8.0” Long Nose Pliers 6.3” Lineman’s Pliers 6.3” Diagonal Cutters 9.0” Lineman’s Pliers 8.0” High Lev. Cutters 6.3” Wire Stripping Pliers Electrician’s Knife 1000Volt 1000Volt 32869 14 Piece Pliers/Cutters & Screwdrivers Set Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. Item# 32869 Set Includes: lbs. 6.52 9.0” Lineman’s Pliers 8.0” High Leverage Cutters 8.0” Cable Cutters 8.0” Long Nose Pliers 6.0” Stripping Pliers 10-20 AWG SlimLine Slotted 3.0mm SlimLine Phillips #1 SlimLine Slotted 4.5mm SlimLine Phillips #2 SlimLine Slotted 6.5mm SlimLine Terminal #2 SlimLine Square #1 Single Pole Tester SlimLine Square #2 1000Volt 32867 10 Piece Pliers & Screwdriver Set In Canvas Pouch Item# 32867 Set Includes: lbs. 4.06 6.3” Diagonal Cutters 9.0” Combo Pliers 6.3” Long Nose Pliers 6.3” Wire Strippers 7.0” Crimping Pliers Insulated Slotted 4.5mm Insulated Phillips #1 Insulated Slotted 6.0mm Insulated Phillips #2 Insulated Square: #2 32868 10 Piece Pliers & Screwdriver Set In Canvas Pouch Item# 32868 Set Includes: lbs. 4.24 7.0” Diagonal Cutters 9.0” Combo Pliers 8.0” Long Nose Pliers 6.3” Wire Strippers 7.0” Crimping Pliers Insulated Slotted 3.0mm Insulated Phillips #1 Insulated Slotted 4.5mm Insulated Phillips #2 Insulated Slotted 6.0mm WARNING! Insulated Tools are intended to provide protection against accidental contact with charged energized circuits. For maximum safety we recommend de-energizing all circuits whenever possible before starting work on electrical apparatus or conductors. Always visually inspect insulation on tools before use, do not use tools if insulation shows signs of wear or damage to the insulated areas of the tool. Wear appropriate eye protection when using hand tools. Use NFPA70E certified insulated protective outer wear when appropriate. Use & Care Guide For Insulated Tools: Store tools to minimize risk of damage to insulation, always wear approved eye protection, Inspect insulation prior to each use of any insulated tool. Use insulated tools where the ambient temperature is between -20 to +70O C. Have a qualified safety technician visually inspect insulation on tools annually for safe use. Toll Free: (800) 494-6104 34 Wiha Insulated Pliers & Cutters Insulation Standards: EN/IEC 60900, ASTM F-1505-01, and or According to VDE 0682/part 201, NFPA70E and CSA 1000V Cutters additionally induction hardened Soft grip ergonomically designed handle body Safety slip guard Hard chrome finish for long lasting corrosion protection Tools Meet 10,000 Volt Test Standards Rated to 1000 Volt ac or 1500 Volt dc Insulated Linemans Pliers With Crimpers 5-In-1 Lineman’s Pliers 1000volt With Lower Crimping Jaw Insulated High Leverage Combination Pliers Lineman’s 1000volt Insulated Combination Lineman’s Pliers 1000volt 32821 Insulated Lineman’s Pliers “5-In-1” Professional Design Insulation According to EN/IEC, ASTM, NFPA70E & CSA, up to 1000 volt. Individually Tested. Deep cut radius conduit jaws for non-slip handling. Sure grip knurled & cross hatched flat jaw for non-slip griping. Extra long induction hardened precision matched cutting edges. Lower crimping jaw accepts most standard non-insulated electrical connectors. Large head with square anvil surface on each side. Made from premium CV tool steel forgings. Two component cushion grips for best user comfort. Item No. 32821 Cutting Capacity Copper AWG mm Inch 225 9.0 #4 Pkg. wt. 1 .88 32820 High Leverage Combination Pliers. Insulation According to EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. DIN ISO 5746 Extra long cutting edge for flat and round cables. Serrated jaws. Cutting edges additionally induction hardened to approx. 64HRC. C 60 Special tool steel. Use for gripping, pulling & holding as well as cutting wires and cables ranging in hardness from soft to extremely hard. Two component soft grip ergonomic handles. Item No. 32820 Cutting Capacity Copper AWG mm Inch 225 9.0 #4 Pkg. wt. 1 .86 328 Combination Pliers. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. DIN ISO 5746 Extra long cutting edge for flat & round cables. Serrated jaws. Cutting edges additionally induction hardened to approx. 60HRC. Special CV tool steel forgings, Chrome finish. Use for gripping and holding as well as cutting soft and hard wires and cables. Two component soft grip ergonomic handles. Item No. 32814 32816 32818 Cutting Capacity mm 160 180 200 Copper AWG Inch 6.3 #10 7.0 #9 8.0 #8 Pkg. wt. 1 .53 1 .58 1 .72 www.wihatools.com 35 Insulated Diagonal Cutters Item No. 32830 32832 32834 1000volt Insulated High Leverage Diagonal Cutters New dynamic joint provides 40% easier cuts and significantly longer tool life 1000volt Insulated Electrician’s Diagonal Cutters Strips AWG #10 & #14 1000volt Insulated Serrated Edge Cable Cutters 1000volt Insulated Crimping Pliers 328 Diagonal Cutters. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. DIN ISO 5749 Low wear lap joint, riveted and able to withstand high levels of load. Lightweight action, clean cutting. Long term cutting is achieved through additional inductive hardening to approx. 60 HRC. Special tool steel hardened and tempered. For soft & medium hard wire. 32832 & 32834 for soft, hard & piano wire. Cutting Capacity Copper AWG mm Inch 140 5.5 #6 160 6.3 #6 180 7.0 #6 Pkg. 1 1 1 wt. .47 .49 .62 328 High Leverage Diagonal Cutters. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. DIN ISO 5749 Semi-circular. Low wear lap joint, riveted and able to withstand high levels of load. Lightweight action, clean cutting. Long term cutting is achieved through additional inductive hardening to approx. 64 HRC. C 60 special tool steel hardened and tempered to high quality. For soft, hard and piano wire, lay-on joint, optimized power transmission. Item No. 32835 32836 32838 Cutting Capacity Copper AWG mm Inch 160 6.3 #6 180 7.0 #5 200 8.0 #4 Pkg. wt. 1 .64 1 .67 1 .80 32861 Diagonal Cutters W/Stripping Holes. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. Drop-forged from special tool steel, cutters additionally induction hardened (approx. 60 HRC), chrome-nickel plated, mirror-polished. Ergo comfort grip with slip guard. Holes in the cutting edge for stripping copper wire of Ø 1.5 and 2.5. Item No. 32861 Cutting Capacity Copper AWG mm Inch 160 6.3 #6 Pkg. wt. 1 .55 328 Serrated Edge Cable Cutters. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E and CSA, up to 1000 Volt. Individually Tested. Light, clean cutting ground precision cutting edges. Durable cutting is achieved through additional inductive hardening to approx. 62 HRC. Special tool steel, hardened & tempered. For cutting of copper & aluminum cables without crushing. Item No. mm Inch Ø mm2 Pkg. lbs. 32826 160 6.3 16 50 1 .42 32828 200 8.0 20 60 1 .67 32841 Insulated Crimping Pliers. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E and CSA, up to 1000 Volt. Individually Tested. Semi-circular profiles for secure connection between end sleeve and conductor. Long life is achieved through additional induction hardening to 64 HRC. CV 60 special tool steel hardened & tempered. Item No. 32841 mm Inch mm2 AWG Pkg. wt. 180 7.0 0.25-2.5 6-30 1 .57 Toll Free: (800) 494-6104 36 Insulated Long Nose Pliers 328 Long Nose Pliers With Cutters. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. Drop-forged from special tool steel, cutters additionally induction hardened (approx. 60 HRC), chromenickel plated, mirror-polished, ergonomic comfort grip with slip guard, half-round jaws, serrated gripping surface. Item No. 32806 32808 1000volt Insulated Bent Nose Pliers Angled 40O Round Nose Pliers Pkg. wt. 1 .32 1 .42 328 Bent Nose Pliers With Cutters. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. Drop-forged from special tool steel, cutters additionally induction hardened (approx. 60 HRC), chrome-nickel plated, mirror-polished. Ergonomic comfort grip with slip guard. Half-round jaws, serrated gripping surface, nose bent 40o. Item No. 32804 32807 1000volt Cutting Capacity Copper AWG mm Inch 160 6.3 #10 200 8.0 #8 Cutting Capacity Copper AWG mm Inch 200 8.0 #8 160 6.3 #10 Pkg. wt. 1 .43 1 .32 32870 Round Nose Pliers. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. Drop-forged from special tool steel, individually induction hardened, chrome and nickel plated, mirror-polished. Ergonomic comfort grip with slip guard. Serrated jaws. 1000volt Item No. 32870 Insulated Long Flat Nose Pliers 32810 Long Flat Nose Pliers. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. DIN ISO 5745 Extra long head. Serrated Jaws are induction hardened. Special CV tool steel forgings, Chrome finish. Two component Soft Grip handles. Use for Gripping and right-angle bending of wires and sheet metal parts. Item No. 32810 1000volt mm Inch Pkg. wt. 160 6.3 1 .34 mm Inch 160 6.3 Pkg. wt. 1 .39 Insulated Stripping Pliers Wiha Canvas Pliers Holster 1000volt 32860 Stripping Pliers. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E and CSA, up to 1000 volt. Individually Tested. Heavy duty forged, induction hardened cutting edges for even stripping of insulation. Drop-forged from special tool steel, chrome and nickel plated, mirror-polished. Spring and adjusting screw, for stripping up to Ø 5mm/#4 Awg. Item No. 32860 Stripping Capacity Copper AWG mm Inch 160 6.3 #4 - #28 Pkg. wt. 1 .50 · Canvas holster with belt clip and belt loop · Security pliers strap · Screwdriver holder in the front 91256 Item No. 91256 Pliers Canvas Holster Width Height Size Size lbs. pkg. 3.5 x 6.75 .15 1 www.wihatools.com 37 Insulated Stripping Pliers Wiha Inomic 1000Volt Insulated Pliers Award winning ergonomic design with head mounted at 23° angle to grip for reduced user fatigue Each tool includes a convenient jaw lock & handle return spring 1000Volt 10250 Insulated Stripping Pliers. Insulation According to EN/IEC 60900, DIN ISO 8976, ASTM F-1505 & CSA Specification. Individually Tested. Wide long head with ridged gripping surface, shears blade and firm wire stripping stations. Wire stripping stations 0.81 / 1.0 / 1.3 / 1.6 / 2.0 / 2.59mm, AWG 20 / 18 / 16 / 14 / 12 / 10. Item No. mm Inch Ø AWG Pkg. lbs. 10250 160 6.3” 0.81-2.59 20-10 5 .26 Heads drop forged CV premium tool steel Switch Cabinet Key 32850 32852 32854 Tools Meet 10,000 Volt Test Standards Rated to 1000 Volt ac or 1500 Volt dc 1000volt 21103 Switch Cabinet Keys For applications with all common switch cabinets and locking systems. Diecast Zinc Item No. mm Inch Pkg. lbs. 76 3.0” 5 .22 21103 Proturn Insulated Electrician’s Shears 32951 Proturn Insulated Electrician’s Shears Insulation meets VDE, ASTM F1505, EN/IEC 60900, CSA, NFPA 70E, OSHA Specifications. Made from stainless 420 grade steel Item No. mm Inch Pkg. lbs. 32951 160 6.3 1 .22 Inomic Canvas Holster Width Height Size Size lbs. pkg. 4.0 x 4.5 .05 1 Cutting Capacity Item Copper AWG No. mm Inch 32850 180 7.0 #6 32852 Inomic Long Nose Pliers Cutting Capacity Item Copper AWG No. mm Inch 32852 160 6.3 #6 32854 Inomic Diagonal Cutters Cutting Capacity Item Copper AWG No. mm Inch 32854 160 6.3 #6 Pkg. lbs. 1 .46 Pkg. lbs. 1 .43 Pkg. lbs. 1 .41 Insulation Standards: EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA 1000Volt Tools Meet 10,000 Volt Test Standards Rated to 1000Volt ac or 1500 Volt dc 91230 Item No. 91230 32850 Inomic Combo Pliers. Insulation According to EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. DIN ISO 5749 Precision machined forged head. Induction hardened for longest tool life. Cross hatched flat jaw & deep cut radius jaws for secure gripping of the work piece. Cutting edges are matched for precise cutting action. Award winning ergonomic design with head mounted at 23° angle to grip for reduced user fatigue. Palm side of grip has molded soft panel for added comfort in prolonged use. Holds any Inomic Pliers 32859 3 Pc. Insulated Inomic Pliers/Cutters Set Three Award winning ergonomic design with head mounted Holsters Included at 23° angle to grip for reduced user fatigue. Item# 32859 Set Includes: lbs. 1.45 32850 - Combo Pliers 32854 - Diagonal Cutters 32852 - Long Nose Pliers 91230 - Inomic Holster (Includes 3) Toll Free: (800) 494-6104 38 Insulated Industrial Pliers & Cutters 1000V Tools meet ASTM, IEC, VDE, EN, NFPA & CSA standards Induction hardened jaws and cutters to 60 HRC 10,000 Volt tested 1000 Volt Rated Industrial brushed finish Two component ergo cushion grip handles Insulated Lineman’s Pliers With Crimpers Long life high performance dynamic 60/40 joint Insulated Long Nose Pliers With Cutters Insulated Diagonal Cutters Insulated Stripping Pliers 1000volt Cutting Capacity Copper AWG mm Inch 225 9.0 #4 Pkg. wt. 1 .98 329 Insulated Industrial Long Nose Pliers With Cutters. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. Drop-forged from special tool steel, cutters additionally induction hardened (approx. 60 HRC), half-round jaws, serrated gripping surface. Industrial brushed finish. Ergonomic comfort grip with slip guard. Item No. 32926 32923 1000volt Long life high performance dynamic 60/40 joint 32917 Insulated Industrial Lineman’s Pliers “5-In-1” Professional Design Insulation According to EN/IEC, ASTM, NFPA70E & CSA, up to 1000 volt. Individually Tested. Deep cut radius conduit jaws for non-slip handling. Sure grip knurled & cross hatched flat jaw for non-slip griping. Extra long induction hardened precision matched cutting edges. Lower crimping jaw accepts most standard non-insulated electrical connectors. Large head with square anvil surface on each side. Premium CV tool steel forgings. Item No. 32917 1000volt New dynamic joint provides 40% easier cuts & significantly longer tool life Cutting Capacity Copper AWG mm Inch 160 6.3 #10 200 8.0 #8 Pkg. wt. 1 .36 1 .46 329 Insulated Industrial Diagonal Cutters. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. DIN ISO 5749 Low wear lap joint, riveted and able to withstand high levels of load. Lightweight action, clean cutting. Long term cutting is achieved through additional inductive hardening to approx. 60 HRC. Special tool steel hardened and tempered. Industrial brushed finish. For soft, medium hard wire & piano wire. 1000volt Item No. 32933 32929 Cutting Capacity Copper AWG mm Inch 160 6.3 #6 200 8.0 #6 Pkg. wt. 1 .64 1 .80 32947 Insulated Industrial Stripping Pliers. Insulation According to VDE 0682/part 201, DIN 7437, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, 1000 volt rated. Individually Tested. DIN ISO 5745 Made from Premium CV tool steel forgings. Induction hardened jaws and cutters to 60 HRC. Industrial brushed finish. Two component ergo cushion grips for best user comfort. Spring & adjusting screw, for stripping up to Ø 5mm/#4 Awg. Item No. 32947 Stripping Capacity Copper AWG mm Inch 160 6.3 #4 - #28 Pkg. wt. 1 .46 www.wihatools.com 39 Insulated Combo Pliers With Dynamic Joint 1000volt Long life high performance dynamic 60/40 joint Insulated Heavy Duty Cable Cutters 32930 Insulated Industrial High Leverage Combination Pliers. Insulation According to EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. DIN ISO 5746 Extra long cutting edge for flat and round cables. Serrated jaws. Cutting edges additionally induction hardened to approx. 60HRC. Use for gripping, pulling & holding as well as cutting wires and cables ranging in hardness from soft to extremely hard. Industrial brushed finish. Two component soft grip ergonomic handles. Item No. 32930 Cutting Capacity Copper AWG mm Inch 200 8.0 #4 Pkg. wt. 1 .92 32927 Insulated Industrial Serrated Edge Cable Cutters. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E and CSA, up to 1000 Volt. Individually Tested. Light, clean cutting ground precision cutting edges. Durable cutting is achieved through additional inductive hardening to approx. 60 HRC. Premium CV tool steel forgings. For cutting of copper & aluminum cables without crushing. Two component ergo cushion grips for best user comfort. Item No. mm Inch Ø mm2 Pkg. lbs. 32927 200 8.0 20 60 1 .78 1000volt Insulated Crimpers 1000volt Insulated Water Pump Pliers 1000volt Insulated Push Button Water Pump Pliers 1000volt 32945 Insulated Industrial Crimping Pliers. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E and CSA, up to 1000 Volt. Individually Tested. Semi-circular profiles for secure connection between end sleeve and conductor. Long life is achieved through additional induction hardening to 60 HRC. Industrial brushed finish. Two component ergo cushion grips for best user comfort. Crimps 6 - 30 AWG Connectors. Item No. 32945 mm Inch mm2 AWG Pkg. wt. 180 7.0 0.25-2.5 6-30 1 .64 32954 Insulated Industrial Water Pump Pliers. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E and CSA, up to 1000 Volt. Individually Tested. 10 opening settings provides optimal adjustment to objects being gripped. Long life achieved through additional induction hardening of jaws to approx. 62HRC. Chrome-vanadium tool steel forgings, hardened and tempered. Black finish. Capacities Item Round Hex No. mm Inch 32954 250 10.0 1 3/4 2 Pkg. wt. 1 .90 32956 Insulated Industrial Push Button Water Pump Pliers. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E and CSA, up to 1000 Volt. Individually Tested. Extra narrow head for working in small spaces. Rapid and simple push button setting & locking. Long life achieved through additional induction hardening of jaws to approx. 62HRC. Finger jam protection for safe operation at all settings. CVM tool steel forgings, hardened & tempered. Capacities Item Round Hex No. mm Inch 32956 250 10.0 1 3/4 2” Pkg. wt. 1 .90 Toll Free: (800) 494-6104 40 Wiha Insulated Industrial Tool Sets Tools meet ASTM, IEC, VDE, EN, NFPA & CSA standards In Belt Pack Pouch Individually Tested 1000Volt Tools meet ASTM, IEC, VDE, EN, NFPA & CSA standards 32981 3 Pc. Insulated Industrial Pliers & Cutters Item No. Insulated Pliers & Cutters 32981 8.0” Combo Pliers, 8.0” Long Pliers, 8.0” Diagonal Cutters lbs. 2.18 1000Volt Tools meet ASTM, IEC, VDE, EN, NFPA & CSA standards 32985 7 Pc. Insulated Industrial Pliers/Cutters & Screwdrivers Item No. Insulated Pliers/Cutters & Screwdrivers 32985 8.0” Combo Pliers, 6.3” Long Nose, 6.3” Diagonal Cutters Insulated Drivers: Slotted: 3.0, 4.5mm • Phillips: #1, #2 lbs. 2.30 Individually Tested 1000Volt Tools meet ASTM, IEC, VDE, EN, NFPA & CSA standards 32983 5 Pc. Insulated Industrial Diagonal Cutters & Screwdrivers Item No. Insulated Diagonal Cutters & Screwdrivers 32983 6.3”/160mm Diagonal Cutter Insulated Drivers: Slotted: 3.0, 4.5mm • Phillips: #1, #2 lbs. 1.17 Tools meet ASTM, IEC, VDE, EN, NFPA & CSA standards Tool box set in blow molded tray Individually Tested 1000Volt 32999 9 Piece Insulated Industrial Pliers & Cutters Set Insulated pliers & cutters set in a light weight tool box tray. Item No. 9.0” Lineman’s Pliers 8.0” High Leverage Combo Pliers 32999 6.3” Long Nose Pliers 8.0” Cable Cutters 8.0” Long Nose Pliers 6.3” Stripping Pliers lbs. 6.3” Diagonal Cutters 7.0” Crimping Pliers 6.34 8.0” Diagonal Cutters Wiha Insulated Tool Tray Sets Tools meet ASTM, IEC, VDE, EN, NFPA & CSA standards Tool box set in blow molded trays 1000Volt 1000Volt 32984 6 Pc. Insulated Industrial Combo Pliers & Screwdrivers Item No. Insulated Combination Pliers & Screwdrivers 32984 8.0” Combination Pliers & 8” Long Nose Pliers Drivers: Slotted: 3.0, 4.5mm • Phillips: #2 • Square: #2 lbs. 2.06 32989 28 Piece Insulated Industrial Pliers & Cutters Set Insulated pliers & cutters set in a light weight tool box tray. Item No. Set Includes: 9.0” Lineman’s Pliers lbs. 32989 8.0” High Leverage Combo Pliers 6.34 6.3” & 8.0” Long Nose Pliers 8.0” Cable Cutters 6.3” & 8.0” Diagonal Cutters 6.3” Stripping Pliers 7.0” Crimping Pliers Slotted: 2.5, 3.0, 3.5, 4.0, 4.5, 5.5, 6.0, 6.5, 8.0, 10.0mm Phillips: #0, #1, #2, #3 Xeno Slotted/Phillips: #1, #2 & Square: #1, #2 Voltage Detector 3.0mm 110-225Volts www.wihatools.com 41 Wiha Insulated Industrial Tool Sets In Roll Out Pouch Now in canvas tool bag 1000Volt 32986 11 Pc. Pliers & Screwdriver Set. Insulation According to VDE 0682/part 201, DIN EN 60900, EN/IEC 60900, ASTM F-1505-01, NFPA70E, up to 1000 volt. Individually Tested. In Roll Out Pouch Item# 32986 Set Includes: lbs. 3.62 6.3” Long Nose Pliers 6.3” Diagonal Cutters 8.0” Combination Pliers 6.3” Stripping Pliers Insulated Slotted: 3.0, 4.5, 5.5mm Insulated Phillips: #1, #2 Insulated Square: #1, #2 In Roll Out Pouch 1000Volt 32390 11 Pc. Pliers & Driver Set. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. In canvas tool bag Item# 32390 Set Includes: lbs. 6.30 8.0” Linemans Pliers 6.3” Long Nose Pliers W/Cutter 8.0” Long Nose Pliers W/Cutter 6.3” Diagonal Cutter 8.0” High Leverage Cutter Insulated Phillips #0 Insulated Slotted 3.0mm(1/8”) Insulated Phillips #1 Insulated Slotted 4.5mm(3/16”) Insulated Phillips #2 Insulated Slotted 6.5mm(1/4”) 1000Volt 32987 8 Pc. Pliers & Cutters Set. Insulation According to VDE 0682/part 201, DIN EN 60900, EN/IEC 60900, ASTM F-1505-01, NFPA70E, up to 1000 volt. Individually Tested. In Roll Out Pouch Item# 32987 Set Includes: lbs. 5.52 6.3” Long Nose Pliers 6.3” Diagonal Cutters 8.0” Long Nose Pliers 8.0” H.D. Diagonal Cutters 9.0” Lineman’s w/Cutters 6.3” Stripping Pliers 8.0” Cable Cutters 7.0” Crimpers 1000Volt In Roll Out Pouches 32988 22 Pc. Pliers & Cutters Set. Insulation According to VDE 0682/part 201, DIN EN 60900, EN/IEC 60900, ASTM F-1505-01, NFPA70E, up to 1000 volt. Individually Tested. In Roll Out Pouches Item# 32988 Set Includes: lbs. 5.74 8.0” Long Nose Pliers 6.3” Diagonal Cutters 9.0” Lineman’s w/Cutters 8.0” H.D. Diagonal Cutters 8.0” Cable Cutters 6.3” Stripping Pliers 7.0” Crimping Pliers 15 Pc. SlimLine Blade Set includes: Insulated SlimLine Blade Holder Slotted: 3.0, 4.0, 5.5, 6.5 Phillips: #1, #2 Xeno: #1, #2 : T8, T10, T15, T20 Square: #1, #2 1000Volt 32973 22 Pc. Pliers & Driver Set. Insulation According to VDE 0682/part 201, EN/IEC 60900, ASTM F-1505-01, NFPA70E & CSA, up to 1000 volt. Individually Tested. In molded tool box Item# 32973 Set Includes: lbs. 8.70 9.0” Linemans Pliers W/Cutters 8.0” Long Nose Pliers W/Cutter 8.0” Diagonal Cutters 50mm Cable Stripping Knife Insulated Slim Phillips #1 Insulated Slim Slotted 3.5mm(9/64”) Insulated Slim Phillips #2 Insulated Slim Slotted 4.5mm(3/16”) Insulated Slim Xeno #1 Insulated Slim Square #1 Insulated Slim Xeno #2 Insulated Slim Square #2 Insulated T-handle Hex Inch: 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Insulated Inch Nut Drivers: 3/8, 7/16, 1/4, 5/16” WARNING! Insulated Tools are intended to provide protection against accidental contact with charged energized circuits. For maximum safety we recommend de-energizing all circuits whenever possible before starting work on electrical apparatus or conductors. Always visually inspect insulation on tools before use, do not use tools if insulation shows signs of wear or damage to the insulated areas of the tool. Wear appropriate eye protection when using hand tools. Use NFPA70E certified insulated protective outer wear when appropriate. Toll Free: (800) 494-6104 42 Numerical Index by Item Number Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page 10250 37 11625 15 11630 15 11950 15 11960 16 11975 16 12326 14 12327 13 12851 10 12852 13 12853 15 12854 11 12855 11 12856 13 12857 13 12858 15 12859 15 13650 9 13651 9 13652 9 13653 9 13654 9 13655 9 13656 9 13657 9 13658 9 13659 9 13662 9 13663 9 13664 9 13665 9 13666 9 13667 9 13668 9 13669 9 13670 9 13671 9 13672 9 13673 9 13690 9 13691 9 13693 9 13694 9 15000 8 15003 8 15050 8 19767 15 20006 5 20007 5 20008 5 20009 5 20010 5 20011 5 20012 5 20013 5 20014 5 20015 5 20016 5 20017 5 20018 5 20019 5 20020 5 20022 5 20024 5 20027 5 20030 5 20032 5 20091 4 20093 4 20131 5 20133 5 20135 5 20136 5 20137 5 20138 5 20140 5 20141 5 20142 5 20144 5 20145 5 20146 5 20147 5 20148 5 20149 5 20190 4 20192 4 20194 5 20196 5 21008 7 21009 7 21010 7 21011 7 21012 7 21013 7 21014 7 21015 7 21017 7 21019 7 21020 7 21022 7 21024 7 21027 7 21030 7 21032 7 21040 7 21042 7 21044 7 21046 7 21048 7 21050 7 21052 7 21054 7 21056 7 21057 7 21058 7 21060 7 21062 7 21064 7 21066 7 21068 7 21093 7 21094 7 21095 7 21096 7 21103 37 21208 6 21210 6 21212 6 21213 6 21214 6 21217 6 21219 6 21290 6 21325 6 21327 6 21329 6 21331 6 21333 6 21335 6 21391 6 25511 26 28301 19 28308 19 28309 19 28312 19 28315 19 28317 19 28319 19 28327 20 28329 20 28339 20 28340 20 28341 20 28342 20 28346 20 28347 20 28350 18 28390 20 28391 20 28724 18 28726 18 28727 18 28734 18 28736 18 28737 18 28791 18 28792 18 29006 11 29009 13 29012 15 29240 15 29250 15 30700 26 30701 26 30746 21 30747 21 31326 10 31327 10 31328 10 31329 10 31330 10 31331 10 31332 10 31333 10 31334 10 31335 10 31336 10 31337 10 31338 10 31339 10 31340 10 31341 10 31342 10 31343 10 31344 10 31345 10 31390 11 31391 11 31394 11 31395 11 31425 12 31428 12 31429 12 31430 12 31431 12 31432 12 31433 12 31434 12 31435 12 31436 12 31437 12 31438 12 31439 12 31491 12 31493 12 31495 13 31496 13 31506 12 31507 12 31508 12 31509 12 31510 12 31511 12 31512 12 31513 12 31514 12 31515 12 31516 12 31517 12 31518 12 31519 12 31520 12 31521 12 31522 12 31524 12 31590 12 31592 13 31595 13 31608 14 31609 14 31610 14 31611 14 31612 14 31613 14 31614 14 31615 14 31616 14 31617 14 31618 14 31619 14 31620 14 31621 14 31622 14 31623 14 31624 14 31626 14 31627 14 31628 14 31630 14 31632 14 31691 14 31703 14 31704 14 31705 14 31707 14 www.wihatools.com 43 Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page 31708 14 31709 14 31710 14 31712 14 31713 14 31714 14 31715 14 31716 14 31718 14 31720 14 31722 14 31790 14 31805 10 31807 10 31809 10 31811 10 31813 10 31815 10 31817 10 31890 10 32005 23 32010 23 32012 23 32015 23 32017 23 32023 23 32024 23 32025 23 32026 23 32027 23 32028 23 32031 23 32034 23 32039 23 32042 23 32045 23 32046 21 32049 21 32052 21 32055 21 32058 21 32090 23 32091 23 32092 23 32093 24 32094 24 32095 24 32100 23 32101 23 32102 23 32103 23 32104 23 32145 21 32146 21 32188 23 32189 22 32190 24 32196 22 32197 22 32198 22 32206 25 32209 25 32212 25 32215 25 32218 25 32221 25 32224 25 32227 25 32230 25 32233 25 32236 25 32238 25 32239 25 32240 25 32241 25 32255 25 32258 25 32261 25 32264 25 32267 25 32268 25 32270 25 32273 25 32276 25 32278 25 32280 25 32288 26 32291 25 32292 25 32293 25 32294 25 32296 25 32302 24 32303 24 32304 24 32305 24 32306 24 32308 24 32366 24 32390 41 32505 26 32511 26 32516 26 32521 26 32526 26 32531 26 32536 26 32541 26 32546 26 32551 26 32556 26 32561 26 32590 26 32592 26 32800 29 32804 36 32806 36 32807 36 32808 36 32810 36 32814 34 32816 34 32818 34 32820 34 32821 34 32826 35 32828 35 32830 35 32832 35 32834 35 32835 35 32836 35 32838 35 32841 35 32850 37 32852 37 32854 37 32859 37 32860 36 32861 35 32867 33 32868 33 32869 33 32870 36 32871 28 32872 28 32873 28 32874 31 32875 28 32876 30 32877 30 32878 31 32879 31 32888 32 32889 33 32891 32 32892 32 32894 32 32895 32 32896 31 32917 38 32923 38 32926 38 32927 39 32929 38 32930 39 32933 38 32945 39 32947 38 32951 37 32954 39 32956 39 32973 41 32981 40 32983 40 32984 40 32985 40 32986 41 32987 41 32988 41 32989 40 32999 40 33441 17 33443 17 33445 17 33447 17 33449 17 33478 17 33481 17 33482 17 33483 17 33485 17 33486 17 33487 17 33490 17 35811 24 35812 24 35844 21 35845 21 35890 24 35891 24 38006 18 38007 18 38016 27 38017 27 38018 27 38025 18 40800 15 75205 16 75210 16 75215 16 75220 16 75302 16 75304 16 76208 8 76210 8 76212 8 76215 8 76290 8 91230 37 91256 36 (800) 494-6104 fax: (800) 494-7456 email: cservice@wihatools.com Insulation Test Cold Impact Test Material Integrity Test Puncture Test Flame Resistance Test Adhesion Test Subject to change without notice ©2013 Willi Hahn Corporation ®Torx is a registered trademark of Acument Intellectual Properties LLC. Wiha Quality Tools 1348 Dundas Circle Monticello, MN 55362 tel: 763.295.6591 fax: 763.295.6598 Wiha Tools Canada Ltd. www.wihatools.ca Brampton, ONT L6T 4X4 tel: 866.494.0096 or 763.295.6591 fax: 763.295.6598 To: Catalog Item No. 99919 .wo version - 6/1/13 99060.wo - Product Guide 99004.wo - Shop Tools Catalog 99001.wo - TorqueControl Catalog 99934.wo - Hex Tools Catalog 99914.wo - TORX Catalog 99002.wo - Screwdrivers Catalog 99951.wo - Bits Catalog 99006.wo - Tech Tools Catalog 99945.wo - ESD Catalog 99977.wo - Pliers/Crimpers Catalog Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Wiha: 32239 20194 21057 32238 20196 32240 32989 21020 21103 32241 12327 32973
32973 价格&库存
很抱歉,暂时无法提供与“32973”相匹配的价格&库存,您可以联系我们找货
