700-10013
700-10013
    PARALLAXINC.
    TOOL KIT PRO SOLDERING
700-10013 数据手册
Pro Soldering Tool Kit Page 1 of 1 Pro Soldering Tool Kit This is a complete DIY Soldering kit that includes a Panavise circuit board holder and has instructional "How to Solder" directions etched right on its base. The kit includes a Hakko #FX888 soldering station, small pair of diagonal cutters, a tip cleaning pad, roll of (leaded) solder, hand-held vacuum solder sucker, four rubber mounting feet, a standoff holder for the solder roll, and mounting hardware. Parallax recommends soldering in a well ventilated area and always using proper eye protection. Features: „ „ „ Item code 700-10013 „ „ „ Everything you need to "solder like a Pro"! "How to Solder" instructions etched right on the Base Plate - perfect for beginners or in a classroom environment Includes a wire-pad to keep the soldering iron tip clean, and hence, produce better solder joints Diagonal cutters are "flush cutting" which provides for superior lead clipping Solder is NOT "lead free". It contains lead, producing more consistant solder joints PanaVise Jr. holds your project solidly, an yet allows for easy "angle adjustment" when soldering complex circuits Kit Includes: „ „ „ „ „ „ „ „ (1) Handy storage/carrying case (1) Hakko #FX888 Soldering Iron (1) Precision laser cut Base Plate with soldering instructions etched right on the plate (1) Hand-held vacuum solder sucker (1) roll of solder (lead) (1) PanaVise Jr. circuit board/component holder (mounts to the Base Plate) (1) Pair of diagonal cutters (1) Pair of safety glasses Specifications: „ „ „ „ Voltage requirements 120 vac Current requirements .60 amps Dimensions: 7 x 8 x 10.5 in (17.8 x 20.3 x 26.7 cm) Operating temp range: 32 to +150 °F (0 to +66 °C) Kit In Storage Case: http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/700-10013/List/0/SortField/4/ProductID/856/De... 4/2/2013
700-10013 价格&库存
很抱歉,暂时无法提供与“700-10013”相匹配的价格&库存,您可以联系我们找货
