700-10011
700-10011
    PARALLAXINC.
    SOLDERING KIT PARALLAX BASIC
700-10011 数据手册
Parallax Basic Soldering Kit Page 1 of 1 Parallax Basic Soldering Kit This complete soldering kit includes everything you need to solder your electronics projects. The kit even includes a Panavise Jr. vise holder and includes instructional "How to Solder" directions etched right on the acrylic vise base. The kit also includes a Hakko #508 soldering iron, small pair of diagonal cutters, a tip cleaning sponge, a roll of (leaded) solder, a roll of solder wick, four rubber mounting feet, a standoff holder for the solder roll, and mounting hardware. This kit include everything you need to assemble our mini Scribbler 2 LED Badge as well as our many board kits. Key Features: „ „ „ Item code 700-10011 „ „ „ Includes everything you need to start soldering up those DIY projects that require soldering "How to Solder" instructions etched right on the Base Plate - perfect for beginners or a classroom environment Includes a sponge to keep the soldering iron tip clean to produce better solder joints Diagonal cutters are "flush cutting" which provides for superior lead clipping Solder is NOT "lead free". It contains lead, and as such, allows for much more consistant solder joints Panavise holds your project solidly, an yet allows for easy "angle adjustment" when soldering complex circuits Kit Contents: „ „ „ „ „ „ „ „ (1) Clear plastic storage/carrying case (1) Hakko #508 soldering iron (1) Precision laser cut acrylic vice base with soldeirng instructions etched right on the plate (1) Roll of solder wick (1) Roll of leaded solder (1) Panavise Jr. circuit board/component vise (mounts to the base plate) (1) Pair of diagonal cutters (1) Pair of safety glasses Specifications: „ „ „ „ Voltage requirements 120 vac Current requirements 0.33 amps Dimensions: 6 x 6 x 11 in (15.2 x 15.2 x 28 cm) Operating temp range: 32 to +150 °F (0 to +66 °C) Kit in Storage Case: http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/700-10011/List/0/SortField/4/ProductID/855/De... 4/2/2013
700-10011 价格&库存
很抱歉,暂时无法提供与“700-10011”相匹配的价格&库存,您可以联系我们找货
