31517
31517
    WIHA(威汉)
    SOCKET 12 POINT 17MM
31517 数据手册
Go To Image Index Wiha Quality Tools Go To Numerical Index Germany www.wihatools.com 101 Wiha Insulated 3/8” Sockets & Sets NEW From 1000Volt Inch - 6 & 12 Point Wiha SHOP 314 Insulated 3/8” Drive Sockets - 6 & 12 Point, Insulation according to EN/IEC 60900, DIN 7448 specification, up to 1000 Volt. Individually Tested. Chrome-vanadium steel, forged, oil-hardened. Item No. Inch lbs. pkg. 314 25 1/4 .07 1 314 28 9/32 .07 1 314 29 5/16 .07 1 314 30 11/32 .07 1 314 31 3/8 .07 1 314 32 7/16 .07 1 314 33 1/2 .09 1 314 34 9/16 .09 1 314 35 5/8 .10 1 314 36 11/16 .13 1 314 37 3/4 .14 1 314 38 13/16 .16 1 314 39 7/8 .18 1 *Sockets must be used with insulated ratchets & extensions 1000Volt SHOP 314 93 10 Pc. Insulated 3/8” Drive Socket Set - Inch CV steel, forged, oil-hardened sockets. Insulated to EN/IEC 60900. Item No. 314 93 Set includes the following: 5/16, 3/8, 7/16, 1/2, lbs. 2.4 9/16, 5/8, 11/16, 3/4” 12856 3/8” x 125mm Extension Bar 12852 3/8” Ratchet - 280mm I N D E X 1000Volt 1000Volt Metric - 12 Point SHOP 315 Insulated 3/8” Drive Sockets - 12 Point, Insulation according to VDE, EN/IEC 60900, DIN 7448 specification, up to 1000 Volt. Individually Tested. Chrome-vanadium steel, forged, oil-hardened. Item No. mm lbs. pkg. 315 06 6 .07 1 315 07 7 .07 1 315 08 8 .07 1 315 09 9 .07 1 315 10 10 .07 1 315 11 11 .08 1 315 12 12 .10 1 315 13 13 .10 1 315 14 14 .10 1 315 15 15 .10 1 315 16 16 .10 1 315 17 17 .11 1 315 18 18 .12 1 315 19 19 .14 1 315 20 20 .15 1 315 21 21 .17 1 315 22 22 .18 1 315 24 24 .26 1 *Sockets must be used with insulated ratchets & extensions PREVIOUS SHOP 315 90 10 Pc. Insulated 3/8” Drive Socket Set - Metric CV steel, forged, oil-hardened sockets. Insulated to EN/IEC 60900. Item No. 315 90 Set includes the following: 8, 10, 11, 12, 13, 14, 17, 19mm lbs. 2.41 12856 3/8” x 125mm Extension Bar 12852 3/8” Ratchet - 280mm 1000Volt SHOP 314 91 16 Pc. Insulated 3/8” Drive Socket Set - Inch/Metric CV steel, forged, oil-hardened sockets. Insulated to EN/IEC 60900. Item No. 314 91 Set includes the following: 5/16, 3/8, 7/16, 1/2, lbs. 2.01 9/16, 5/8, 11/16, 3/4” 8, 10, 11, 12, 13, 14, 17, 19mm NEXT
31517
1. 物料型号:文档列出了两种套筒套装的型号,分别是31493和31590,以及单独的套筒型号,如31425至31439和31506至31524。
2. 器件简介:这些套筒由CV钢锻造、油硬化制成,并根据EN/IEC 60900标准绝缘,可承受高达1000伏的电压。
3. 引脚分配:文档中没有明确提到引脚分配,但列出了套筒套装中包含的不同尺寸的套筒。
4. 参数特性:套筒具有绝缘特性,适用于高达1000伏的电压环境。它们是单独测试的,并且有英制和公制两种尺寸。
5. 功能详解:文档强调了套筒的绝缘特性和材料质量,但没有提供更深入的功能描述。
6. 应用信息:套筒必须与绝缘扳手和延长杆一起使用。
7. 封装信息:文档中没有提供封装信息,但列出了套筒的包装数量。
31517 价格&库存
很抱歉,暂时无法提供与“31517”相匹配的价格&库存,您可以联系我们找货
  • 3+249.430503+32.23870
