WRENCH SET,RATCHET 7 PC-METR
7-Piece Combination Ratcheting Wrench Set - Metric
Cat No:
0354-02
UPC No:
783310892748
Description
Compact reversible switch allows a 15° offset of the boxend for clearance of obstacles
Five-degree ratcheting design for versatility and ease of use in tight spaces
Polished chrome finish forsuperior corrosion resistance
Precision heads for accurate fastener fit
Hardened for durability and longer life
Exceeds ASME/ANSI specifications
Lifetime limited warranty
Note: This is not an insulated tool
Specifications
Finish : Polished Chrome
Includes : 7.000 MM, 9.000 MM, 10.000 MM, 11.000 MM, 13.000 MM, 14.000MM And 15.000 MM
Wrench Sizes
Package : 7/Pack
Standard : ASME/ANSI
Type : Metric, Combination
Weight : 1.300 LB (0.600 KG)
很抱歉,暂时无法提供与“0354-02”相匹配的价格&库存,您可以联系我们找货
