20022
20022
    WIHA(威汉)
    WRENCHOPENEND22MM7.72"
20022 数据手册
Wiha Quality Tools 96 Go To Numerical Index Go To Image Index See Product Category Index Toll Free: (800) 494-6104 NEW 1000Volt From Wiha SHOP I N D E X 200 Metric Open-Ended Spanners, With Insulated Handle Insulation According to VDE Specification 0680 and EN/IEC 60900, DIN 7446, up to 1000 Volt. Individually Tested. Chrome-vanadium steel, hardened. Angled 15O. Item OAL OAL No. mm mm Inch lbs. pkg. 200 06 6 97 3.8 .04 1 200 07 7 98 3.9 .05 1 200 08 8 104 4.1 .07 1 200 09 9 108 4.3 .07 1 200 10 10 107 4.2 .08 1 200 11 11 118 4.6 .11 1 200 12 12 129 5.1 .11 1 200 13 13 137 5.4 .17 1 200 14 14 150 5.9 .19 1 200 15 15 151 5.9 .17 1 200 16 16 164 6.5 .22 1 200 17 17 162 6.4 .24 1 200 18 18 173 6.8 .33 1 200 19 19 178 7.0 .32 1 200 22 22 196 7.7 .39 1 200 24 24 211 8.3 .58 1 200 27 27 218 8.6 .60 1 200 30 30 235 9.3 .90 1 200 32 32 237 9.3 .93 1 SHOP 1000Volt 200 91 Item No. 200 91 Set 15 Pcs. Metric Open OAL mm mm 200 06 6 97 200 07 7 98 200 08 8 104 200 09 9 108 200 10 10 107 200 11 11 118 200 12 12 129 200 13 13 137 End Insulated Spanners OAL mm mm lbs. 200 14 14 150 3.0 200 15 15 151 200 16 16 164 200 17 17 162 200 19 19 178 200 22 22 196 200 24 24 211 SHOP 1000Volt 200 93 Item No. 200 93 Set 8 Pcs. Metric Open OAL mm mm 200 06 6 97 200 07 7 98 200 08 8 104 200 10 10 107 End Insulated Spanners OAL mm mm 200 13 13 137 200 14 14 150 200 17 17 162 200 19 19 178 lbs. 1.4 Use & Care Guide For Insulated Tools: Store tools to minimize risk of damage to insulation, always wear approved eye protection, Inspect insulation prior to each use of any insulated tool. Use insulated tools where the ambient temperature is between -20 to +70O C. Have a qualified safety technician visually inspect insulation on tools annually for safe use. WARNING! Insulated Tools are intended to provide protection against accidental contact with charged energized circuits. For maximum safety we recommend de-energizing all circuits whenever possible before starting work on electrical apparatus or conductors. Always visually inspect insulation on tools before use, do not use tools if insulation shows signs of wear or damage to the insulated areas of the tool. Wear appropriate eye protection when using hand tools. Use NFPA70E certified insulated protective outer wear when appropriate. PREVIOUS NEXT
20022 价格&库存
很抱歉,暂时无法提供与“20022”相匹配的价格&库存,您可以联系我们找货
  • 1+386.988601+50.30727
