W-HT-2285
W-HT-2285
    GCELECTRONICS
    TOOL EXTRACTOR HT-2285 .062
W-HT-2285 数据手册
Extractor Tool for 1.57mm (.062") Diameter, Standard .062" & EconoLatch® Pin and Socket Crimp Terminals Extractor Tool (HT2285) Application Tooling Specification Sheet Order No. 11-03-0002 FEATURES This Extractor Tool is for the removal of 1.57mm (.062") Diameter & EconoLatch® pin and socket terminals from both plug and receptacle housings. SCOPE Products: 1.57mm (.062") Diameter, Standard .062" & EconoLatch® Pin and Socket Crimp Terminals. Terminal Series No. 1560 1561 1778 1779 1786 1787 1854 1855 2189 2190 4529 4559 7291 150180 150181 Doc No: ATS-011030002 Revision: E 02-06-2101 02-06-6102 02-06-2103 02-06-6103 02-06-6100 02-06-6104 02-06-6101 02-06-6105 02-06-1101 02-06-5100 02-06-1103 02-06-5101 02-06-1118 02-06-5102 02-06-4101 02-06-6121 02-06-4102 02-06-6122 02-06-5141 02-06-5146 02-06-2201 02-06-6201 02-06-2202 02-06-6202 02-06-1201 02-06-3200 02-06-1202 02-06-3201 02-06-2131 02-06-6130 02-06-2132 02-06-6135 02-06-2134 02-06-6136 02-06-1131 02-06-5116 02-06-1132 02-06-5130 02-06-1141 02-06-5135 02-06-1143 02-06-5136 02-06-1231 02-06-1233 02-06-1232 02-06-3202 02-06-2231 02-06-2232 02-06-1104 02-06-1106 02-06-1105 02-06-1116 02-06-1109 02-06-1111 02-06-1110 02-06-5209 02-06-1139 1501801016 1501801020 1501811016 1501811020 Release Date: 04-23-03 Revision Date: 12-07-16 Terminal Order No. 02-06-6112 04-01-0805 02-06-6116 04-01-0807 02-06-6118 39-00-0278 02-06-6119 39-00-0327 02-06-5103 02-06-5108 02-06-5104 02-06-5109 02-06-5105 04-01-0806 02-06-6123 02-06-6125 02-06-6124 02-06-6126 02-06-7103 02-06-7104 02-06-6205 02-06-6211 02-06-6206 02-06-6212 02-06-5201 02-06-5205 02-06-5202 02-06-5206 02-06-6137 02-06-6143 02-06-6138 02-06-6144 02-06-6139 02-06-6145 02-06-5137 02-06-5148 02-06-5138 04-01-0810 02-06-5139 04-01-0812 02-06-5147 39-00-0338 02-06-3203 02-06-5204 02-06-5203 02-06-5212 02-06-4202 02-06-4203 02-06-5117 02-06-5119 02-06-5118 02-06-5207 02-06-5210 02-06-5213 02-06-5211 02-06-5214 39-00-0328 39-00-0329 39-00-0330 04-01-0808 39-00-0332 39-00-0279 39-00-0333 39-00-0331 39-00-0334 02-06-8103 02-06-8104 02-06-7105 04-010809 04-010811 39-000280 39-000339 39-000340 39-000341 02-066207 02-065208 02-065217 02-065215 UNCONTROLLED COPY 39-00-0335 39-00-0336 39-00-0337 02-06-5218 Page 1 of 2 Extractor Tool for 1.57mm (.062") Diameter, Standard .062" & EconoLatch® Pin and Socket Crimp Terminals OPERATION: RETRACTABLE SPRING LOADED TUBE HANDLE TERMINAL RETRACTABLE SPRING LOADED TUBE TERMINAL PUSH-OUT PIN (SOLID) TERMINAL LOCKING TABS Figure 1 Figure 2 CONNECTOR HOUSING CONNECTOR HOUSING 1. The Extractor Tool must be In Line with the terminal as shown. Push terminal forward in arrow direction before using the Extractor Tool. See Figure 1. 2. The Retractable Spring Loaded Tube must depress the Locking Tabs on the terminal before it contacts the Terminal Push out pin. Grip and rotate Retractable Spring Loaded Tube while inserting over terminal to help depress locking tabs. See Figure 2. TERMINAL PUSH-OUT PIN (SOLID) RETRACTABLE TUBE 3. The terminal push-out pin (solid) pushes the terminal back through the connector hole as the retractable tube recedes into the handle. Always re-spread the locking tabs when reinserting the same terminal. Note: All figures in this document are a generic representation and may not be the exact products listed in the scope. Figure 3 CONNECTOR HOUSING TERMINAL Molex does not offer repair parts for Extractor Tools due to the inexpensive nature of these tools. CAUTION: This extractor tool should be used to extract the terminal only. Using it for unintended purposes may cause injury or damage to parts. Be careful not to deform the end of the terminal. CAUTION: Molex specifications are valid only when used with Molex terminals, applicators and tooling. Contact Information For more information on Molex application tooling please contact Molex at 1-800-786-6539. Visit our Web site at http://www.molex.com Doc No: ATS-011030002 Revision: E Release Date: 04-23-03 Revision Date: 12-07-16 UNCONTROLLED COPY Page 2 of 2
W-HT-2285 价格&库存
很抱歉,暂时无法提供与“W-HT-2285”相匹配的价格&库存,您可以联系我们找货
