500-12-000
500-12-000
    AMPHENOLSVMICROWAVE(安费诺MAO)
    SMPFEMALEBULLETREMOVALTOOL
500-12-000 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION DATE APPROVED - DCN 38041 02/11 STW A REV. DCN 38604 10/13/11 STW B REV. DCN 39055 05/07/12 STW REV PRODUCT DATA DRAWING 3.4 86.52 .8 19.05 1.5 38.10 MATERIAL: SHAFT, TIP & TUBE: STAINLESS STEEL PER ASTM A564, ALLOY UNS S17400, TYPE 630, COND. A FINGER GRIP: BRASS PER ASTM B16, ALLOY UNS No. C36000 COLLET: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 COMPRESSION SPRING : STAINLESS STEEL PER ASTM A313, TYPE 302 KNOB: PLASTIC FINISH: COLLET: NICKEL PER SAE AMS 2404, CLASS 1 MATERIAL: FINISH: FINGER GRIP: NICKEL PER AMS-QQ-N-290 SEE NOTES SEE NOTES SURFACE AREA: SHAFT, TIP & TUBE: PASSIVATED PER AMS-2700 COMPRESS TO OPEN COLLET, RELEASE TO CLOSE COLLET, PULL TO REMOVE BULLET N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: FED 02/28/11 CHECKED: APPROVED: STW 02/28/11 STW 02/28/11 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMP BULLET REMOVAL TOOL SIZE CAGE CODE DWG. NO. B 95077 SCALE: 2:1 500-12-000 SHEET 1 OF 1
500-12-000 价格&库存
很抱歉,暂时无法提供与“500-12-000”相匹配的价格&库存,您可以联系我们找货
