Instruction Sheet
Mini Mate Connector Series:
STS-N-001
Rev. F
IPD1 Series
CAT-EX-179-01 - Extraction Tool
Date: 8/11/2014
FIGURE 1
1. INTRODUCTION
Contacts can be safely removed from a housing cavity by using the extraction tool shown in Figure 1. This
instruction sheet covers the use of the SAMTEC Extraction Tool CAT-EX-179-01. These tools are intended to
aid in the removal of the CC79, Mini Mate ® contacts from the housing.
2. CUSTOMER SERVICE
Further tooling and product application assistance is available by contacting the Samtec Application
Service Line - (+1-800-726-8329 (+1-812-944-6733)) 8:00 AM to 5:00 PM eastern time. To expedite
your inquiry, have the pertinent part numbers for the product and tooling.
Page 1 of 2
This is a controlled document and is subject to change (printed versions are not controlled)
Instruction Sheet
STS-N-001
Rev. F
IPD1 Series
Date: 8/11/2014
3. DESCRIPTION
Each tool handle is marked with the tooling number. Make sure it matches the tooling number specified in
this document.
The CC79 Mini Mate ® contact has a retaining lance that can be released through an access window located on
the outside of the housing as shown in Figure 2. The Extraction tool has a tip that is inserted into the
window to depress the lance the correct amount for contact removal.
CAUTION - Do not use any unintended tools to release the lance. This can cause damage to the lance and
weaken its ability to retain the reinserted contact in the housing.
4. EXTRACTION PROCEDURE
The following steps are recommended:
1.
Push the desired lead forward to the bottom of its cavity. This will provide clearance for the lance to
be depressed.
2.
Engage the tip of the Extraction Tool in the lance window as shown in Figure 2. With downward
pressure, push the tool toward the back of the window to release the lance.
3.
Maintain downward pressure on the tool tip then grip the lead and pull the contact from its cavity.
FIGURE 2
Page 2 of 2
很抱歉,暂时无法提供与“CAT-EX-179-01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+380.691761+49.31290
