M60 Section 7 FREV1A1_11-2011 3/26/13 3:19 PM Page 123
MINIATURE TUBULAR TERMINALS
• Quick and Easy to Install • For Production or Prototype
• Postive Locking In-Hole • No Staking Required • Holds .010 (.25) to .050 (1.27) Diameter Wire
These terminals are often used for transistor and Bi-Pin lamp sockets. Terminals
Terminals 1236 and 1237 have tapered socket spring forming that will
snap into place and are firmly held without the need of staking. Wire leads can
hold multiple leads in place. Terminals are pre-tinned for easy soldering.
be inserted from either end.
INSERTION TOOL
.062 (1.57) — .067 (1.70)
Mounting Holes
For Arbor Press: CAT. NO. TL-11; For Hand Tool: CAT. NO. 1214
.080 [2.03]
DIA. FLANGE
.080 [2.03]
DIA. FLANGE
.050 [1.27]
I. DIA.
.065 [1.65]
DIA.
.080 [2.03]
DIA. FLANGE
.050 [1.27]
I. DIA.
.065 [1.65]
DIA.
.219
[5.6]
.188
[4.8]
MATERIAL:
.006 (.15) Matte Tin, Brass.
Pre-Tinned
.046 [1.17]
DIA. FLARE
CAT. NO. 1236
.188
[4.8]
Pre-Tinned
.047 [1.19]
CAT. NO. 1237
CAT. NO. 1238
“FLEA” CLIP
“IMP” TERMINAL
For subminiature applications where conventional terminals are too large or too
costly. Ideal for quick repairs of printed circuitry. Simply insert wire through hole
and it is held firmly by spring action assuring continued postive contact.
Excellent for point to point or feed thru wiring. Slot is serrated to grip
component leads. Multiple connections are made quick and easy.
.078 [1.98] REF.
.030 [.76]
.053
[1.35]
REF.
.375
.187 [9.6]
[4.8]
Mtg. Hole .062 (1.57)
Insertion Tool: CAT. NO. 1322
MATERIAL:
.008 (.20) Matte Tin, Beryllium
Copper, Tin Plate
.219
[5.6] .328
[8.4]
MATERIAL:
.058
[1.48]
.045
[1.14]
DIA.
.130
[3.3]
MATERIAL:
.064
[1.7]
Copper, Tin Plate
.053 [1.34]
CAT. NO. 1500
.437
.237 [11.1]
[6.0]
.052 [1.32]
CAT. NO. 1499FT
“MICRO” TERMINAL
CLAMP TERMINAL
Terminal for production or prototype use. Holds as many as 7 leads without
soldering, by spring action.
Easily press-fit into a .042 (1.07) diameter hole may be flared for permanent
installation. Ideally designed for use in circuitry to support components when
space is at a premium.
.234 [6.0]
REF.
.063 [1.6] REF.
.030 [.76]
.040
[1.02]
DIA.
.812 [20.6]
.100 [2.6]
.031 [.79]
DIA.
.260 [6.6]
.359
[9.1]
Mtg. Hole .093 (2.36)
.312 [7.9]
Insertion Tool: CAT. NO. 1323
MATERIAL:
.078 [1.98]
MATERIAL: .008 (.20) Matte Tin,
.015 (.38) Matte Tin, Spring Steel,
Tin Plate
.094 [2.39]
.062 [1.57]
.085 [2.16]
.032 [0.81]
.018 [.46]
DIA.
.046 [1.17]
Beryllium Copper,
Tin Plate
.167
[4.3]
PUSH-IN TERMINALS & PINS
Pre-Tinned
.065 [1.65]
DIA.
.469
[11.9]
.469
[11.9]
MATERIAL:
.050 [1.27]
I. DIA.
.219
[5.6]
.034 [.86]
.085 [2.16]
CAT. NO. 1495
CAT. NO. 1498CP
.025 SQUARE WIRE WRAP PINS
CONTACT PINS (SEAMLESS)
Completely burr free straight to within .003 (.08) per inch. Conical ends of square-wire with
smooth blend-in radius on corners assures ease of insertion with minimum damage to
pre-plated PCB holes.
CAT.
NO.
5070
5071
5072
5073
5074
5075
5076
L
Length
.400 (10.2)
.440 (11.2)
.515 (13.1)
.535 (13.6)
.600 (15.2)
.615 (15.6)
.625 (15.9)
CAT.
NO.
5077
5078
5079
5080
5081
5082
5083
L
Length
.642 (16.3)
.675 (17.1)
.720 (18.3)
.850 (21.6)
.916 (23.3)
.995 (25.3)
1.13 (28.7)
L
.034
[.86]
.003 R.
[.08 R]
60°
.010 [.25]
.025
[.64]
MATERIAL: Phosphor Bronze, Tin Plate
Tel (718) 956-8900 • Fax (718) 956-9040
(800) 221-5510 • kec@keyelco.com
Pins can be staked to .062 (1.57) and .093 (2.36) thick boards.
CAT. NO.
1223
1224
1226
1200
1210
1230
1231
A
.093 (2.36)
.093 (2.36)
.093 (2.36)
.125 (3.18)
.125 (3.18)
.156 (3.96)
.156 (3.96)
RoHS COMPLIANT ~ ISO 9001 CERTIFIED
B
.293 (7.4)
.357 (9.1)
.437 (11.1)
.379 (9.6)
.566 (14.4)
.379 (9.6)
.566 (14.4)
B
A
A
.125 [3.2]
MATERIAL: Brass, Nickel Plate
www.keyelco.com
31-07 20th Road – Astoria, NY 11105-2017
123
很抱歉,暂时无法提供与“1322”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+71.763951+9.32715
- 10+63.7650510+8.28754
