1323
1323
    KEYSTONE
    TOOL INSERTION FOR SLDRLESS TERM
1323 数据手册
M60 Section 7 FREV1A1_11-2011 3/26/13 3:19 PM Page 123 MINIATURE TUBULAR TERMINALS • Quick and Easy to Install • For Production or Prototype • Postive Locking In-Hole • No Staking Required • Holds .010 (.25) to .050 (1.27) Diameter Wire These terminals are often used for transistor and Bi-Pin lamp sockets. Terminals Terminals 1236 and 1237 have tapered socket spring forming that will snap into place and are firmly held without the need of staking. Wire leads can hold multiple leads in place. Terminals are pre-tinned for easy soldering. be inserted from either end. INSERTION TOOL .062 (1.57) — .067 (1.70) Mounting Holes For Arbor Press: CAT. NO. TL-11; For Hand Tool: CAT. NO. 1214 .080 [2.03] DIA. FLANGE .080 [2.03] DIA. FLANGE .050 [1.27] I. DIA. .065 [1.65] DIA. .080 [2.03] DIA. FLANGE .050 [1.27] I. DIA. .065 [1.65] DIA. .219 [5.6] .188 [4.8] MATERIAL: .006 (.15) Matte Tin, Brass. Pre-Tinned .046 [1.17] DIA. FLARE CAT. NO. 1236 .188 [4.8] .006 (.15) Matte Tin, Brass. Pre-Tinned .047 [1.19] CAT. NO. 1237 CAT. NO. 1238 “FLEA” CLIP “IMP” TERMINAL For subminiature applications where conventional terminals are too large or too costly. Ideal for quick repairs of printed circuitry. Simply insert wire through hole and it is held firmly by spring action assuring continued postive contact. Excellent for point to point or feed thru wiring. Slot is serrated to grip component leads. Multiple connections are made quick and easy. .078 [1.98] REF. .030 [.76] .053 [1.35] REF. .375 .187 [9.6] [4.8] Mtg. Hole .062 (1.57) Insertion Tool: CAT. NO. 1322 MATERIAL: .008 (.20) Matte Tin, Beryllium Copper, Tin Plate .219 [5.6] .328 [8.4] MATERIAL: .058 [1.48] .045 [1.14] DIA. .130 [3.3] Mtg. Hole .062 (1.57) Insertion Tool: CAT. NO. 1322 MATERIAL: .064 [1.7] .008 (.20) Matte Tin, Beryllium Copper, Tin Plate .053 [1.34] CAT. NO. 1500 .437 .237 [11.1] [6.0] .052 [1.32] CAT. NO. 1499FT “MICRO” TERMINAL CLAMP TERMINAL Terminal for production or prototype use. Holds as many as 7 leads without soldering, by spring action. Easily press-fit into a .042 (1.07) diameter hole may be flared for permanent installation. Ideally designed for use in circuitry to support components when space is at a premium. .234 [6.0] REF. .063 [1.6] REF. .030 [.76] .040 [1.02] DIA. .812 [20.6] .100 [2.6] .031 [.79] DIA. .260 [6.6] .359 [9.1] Mtg. Hole .093 (2.36) .312 [7.9] Insertion Tool: CAT. NO. 1323 MATERIAL: Insertion Tool: CAT. NO. 1322 .078 [1.98] MATERIAL: .008 (.20) Matte Tin, .015 (.38) Matte Tin, Spring Steel, Tin Plate .094 [2.39] .062 [1.57] .085 [2.16] .032 [0.81] .018 [.46] DIA. .046 [1.17] Beryllium Copper, Tin Plate .167 [4.3] PUSH-IN TERMINALS & PINS .006 (.15) Matte Tin, Brass. Pre-Tinned .065 [1.65] DIA. .469 [11.9] .469 [11.9] MATERIAL: .050 [1.27] I. DIA. .219 [5.6] .034 [.86] .085 [2.16] CAT. NO. 1495 CAT. NO. 1498CP .025 SQUARE WIRE WRAP PINS CONTACT PINS (SEAMLESS) Completely burr free straight to within .003 (.08) per inch. Conical ends of square-wire with smooth blend-in radius on corners assures ease of insertion with minimum damage to pre-plated PCB holes. CAT. NO. 5070 5071 5072 5073 5074 5075 5076 L Length .400 (10.2) .440 (11.2) .515 (13.1) .535 (13.6) .600 (15.2) .615 (15.6) .625 (15.9) CAT. NO. 5077 5078 5079 5080 5081 5082 5083 L Length .642 (16.3) .675 (17.1) .720 (18.3) .850 (21.6) .916 (23.3) .995 (25.3) 1.13 (28.7) L .034 [.86] .003 R. [.08 R] 60° .010 [.25] .025 [.64] MATERIAL: Phosphor Bronze, Tin Plate Tel (718) 956-8900 • Fax (718) 956-9040 (800) 221-5510 • kec@keyelco.com Pins can be staked to .062 (1.57) and .093 (2.36) thick boards. CAT. NO. 1223 1224 1226 1200 1210 1230 1231 A .093 (2.36) .093 (2.36) .093 (2.36) .125 (3.18) .125 (3.18) .156 (3.96) .156 (3.96) ® RoHS COMPLIANT ~ ISO 9001 CERTIFIED B .293 (7.4) .357 (9.1) .437 (11.1) .379 (9.6) .566 (14.4) .379 (9.6) .566 (14.4) B A A .125 [3.2] MATERIAL: Brass, Nickel Plate www.keyelco.com 31-07 20th Road – Astoria, NY 11105-2017 123
很抱歉,暂时无法提供与“1323”相匹配的价格&库存,您可以联系我们找货
