DF49-20/RE-MD(61)
DF49-20/RE-MD(61)
    HRS(广濑)
    EXTRACT TOOL 20POS DF49 SERI
DF49-20/RE-MD(61) 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. 0.4 mm Pitch, Horizontal mating, Board- to-Fine Coaxial Cable Connectors DF49 Series Reliable connection 0.7±0.1 (Mated height) (0.5) Effective mating length Figure. 1 Mis-insertion Prevention ■Features 1.Ultra low-profile structure A low-profile and space-saving item, with a stacking height of 0.7mm (0.8mm MAX). The bend structure of the shell prevents the reverse insertion 2.Reliable electrical and mechanical connection Despite its small mated height, unique contact configuration assures highly reliable connection, with effective mating length of 0.5mm. 3.Enhanced shielding and ground connections Metal shells on the plug and receptacle connect to each other, assuring reliable ground connection and EMC protection. 4.Simplified lock structure with audible click Figure. 2 Audibly clicks into place thanks to the two-point lateral lock structure and optimized contact force. 5.Incorrect insertion prevention mechanism The bend structure of the shell prevents the reverse insertion of the plug connector and mating failure. 6.Solder wicking prevention Nickel barriers prevent solder wicking in the critical contact areas.(Receptacle) ■Connectors for conductivity tests We have a line-up of plug connectors for inspection, usable for electrical testing. 2010.9 1 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF49 Series●0.4 mm Pitch, Horizontal mating, Board- to-Fine Coaxial Cable Connectors ■Specifications Current rating Ratings Voltage rating Item AWG42 : 0.25A 電線サイズ AWG44 : 0.2A (Note 3) AWG46 : 0.15A AC30V Operating temperature range -35ç to 85ç (Note 1) Operating humidity range 20% to 80% Storage temperature range -10ç to 60ç (Note 2) Storage humidity range 40% to 70% (Note 2) Specification Conditions 1. Insulation resistance 50 Mø min. 100 V DC 2. Withstanding voltage No flashover or insulation breakdown 100 Vrms AC / 1 minute 3. Contact resistance Signal:80mø max, Ground 80mø max 100 mA,(DC or 1,000Hz) 4. Vibration No electrical discontinuity of 1 μs or longer 5.Humidity Contact resistance (change from initial value) 50 mø max. Insulation resistance: 25 Mø min. 6. Temperature cycle Contact resistance (change from initial value) 50 mø max. Insulation resistance: 25 Mø min. Frequency: 10 to 55 Hz, single amplitude of 0.75mm, 10 cycles in each of the 3 directions 96 hours at of 40 ±2°C, and humidity of 90 to 95% -55°C → 5 to 35°C → 85°C → 5 to 35°C Time: 30 min. → 2 to 3 min. → 30 min. → 2 to 3 min. 5 cycles 7. Durability Contact resistance (change from initial value) 50 mø max. 30 cycles 8. Resistance to soldering heat No deformation of affecting performance Reflow: At the recommended temperature profile Manual soldering: 350°C for 3 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for a long period prior to mounting and use. The operating temperature and humidity range covers the non-conducting condition of installed connectors in storage, shipment or during transportation after board mounting. Note 3: With only the connector portion at an elevated temperature level, the rated current value is set. Note 4: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Materials Product Part Receptacle Metal fittings Plug Shell 2 Material Finish Remarks Insulator LCP Color:Black UL94V-0 Contacts Phosphor bronze Gold plated --------- Phosphor bronze Tin plated --------- Insulator LCP Color:Black --------- Contacts Phosphor bronze Gold plated UL94V-0 Metal cover Phosphor bronze Tin plated --------- Metal cover Phosphor bronze Tin plated --------- The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF49 Series●0.4 mm Pitch, Horizontal mating, Board- to-Fine Coaxial Cable Connectors ■Ordering information lConnector DF 49 J − * S − 0.4 H (**) ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❽ DF 49 − * P − SHL ❶ ❷ ❹ ❺ ❶ Series name : DF ❾ ❻ Contact pitch:0.4mm ❷ Series No. :49 ❸ Connector style ❼ Termination type Receptacle/Shell H :Rightangle SMT J:Receptacle for conductivity tests SD : Fine coaxial cable plug Blank:Standard ❹ Number of positions: 20,30,40 ❽ Packaging (51):Embossed tape packaging ❺ Connector type S:Receptacle P:Plug ❾ Installation item(separate) SHL:Metal cover ■Combinations [Standard use] DF49-*S-0.4H(**) + DF49-*P-ASSY DF49-*P-0.4SD(**) DF49-*P-SHL Note: T he product specification of the above combination is shown on page 2. [Receptacle conductivity test] DF49-*S-0.4H(**) + DF49J-*P-ASSY••(Note) DF49J-*P-0.4SD(**) DF49-*P-SHL Note: T  his harness item is only usable for the receptacle test. For the product specification of the above combination, please contact our sales department. [Plug conductivity test] DF49-*S-0.4H(**) + DF49-*P-ASSY DF49-*P-0.4SD(**) DF49-*P-SHL Note: For the product specification, please contact our sales department. π : ASSY means a harness item. 3 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF49 Series●0.4 mm Pitch, Horizontal mating, Board- to-Fine Coaxial Cable Connectors 3.43±0.2 1.33±0.15 ■Receptacles (SMT) A±0.2 B±0.15 0.08±0.03 P=0.4±0.1 Contact No.n Contact No.1 CAV No. 0.7±0.1 ■Recommended PCB mounting pattern B±0.02 (0.25) C±0.02 D±0.02 GND pad 0.5±0.03 0.8±0.02 Contact No.1 1.9±0.02 0.2±0.02 P=0.4±0.02 Contact pad [Specification number] - **, (**) (51):Embossed tape packaging (7,000 pieces per reel)  Unit : mm Part Number CL No. Number of contacts A DF49-20S-0.4H(**) 662-5503-4-** 20 DF49-30S-0.4H(**) Under planning 30 DF49-40S-0.4H(**) 662-5500-6-** 40 Note 1: Tape and reel packaging (7,000 pieces/reel). Order by number of reels. 4 B C 12.8 7.6 12.03 16.8 11.6 16.03 20.8 15.6 20.03 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF49 Series●0.4 mm Pitch, Horizontal mating, Board- to-Fine Coaxial Cable Connectors ■Plugs 3.55±0.2 A±0.2 B±0.2 0.57±0.1 P=0.4±0.1 C±0.1 CAV No. Contact No.1 [Specification number] - **, (**) (51):Embossed tape packaging (7,000 pieces per reel)  Unit : mm Part Number CL No. Number of contacts A B C D DF49-20P-0.4SD(**) 662-5504-7-** 20 11.32 7.6 8.9 8.7 DF49-30P-0.4SD(**) Under planning 30 15.32 11.6 12.9 12.7 DF49-40P-0.4SD(**) 662-5501-9-** 40 19.32 15.6 16.9 16.7 Inner conductor (Pre-L soldering required) D±0.1 B±0.15 0.8±0.05 P=0.4±0.07 0.5±0.05 0.2MAX(Insulator) 0.7±0.05 E(FREE) 0.05MAX ■Recommended Fine Coaxial Cable Preparation Outer shield (for individual conductor) Note 1: Tape and reel packaging (7,000 pieces/reel). Order by number of reels. Note 2: The metal cover (DF49-*P-SHL) is required for fine coaxial cable termination. 0.1MAX E 0.31MAX(Jacket) 0.44±0.03 (Ground bar) 5 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF49 Series●0.4 mm Pitch, Horizontal mating, Board- to-Fine Coaxial Cable Connectors ■Metal cover 0.65±0.1 2.48±0.1 * P=3±0.1 A±0.15 0.6±0.1 1±0.1 Pin No. 0.2±0.1 0.6±0.1 0.85±0.1 0.5±0.1 B±0.15 C±0.1 [Specification number] - **, (**) (51):Embossed tape packaging (10,000 pieces per reel)  Unit : mm CL No. Number of contacts A B C DF49-20P-SHL Part Number 662-5505-0 20 4.0 10.1 11.18 DF49-30P-SHL Under planning 30 π 14.1 15.18 DF49-40P-SHL 662-5502-1 40 12.0 18.1 19.18 Note 1 : Tape and reel packaging (10,000 pieces/reel). Order by number of reels. Note 2 : π dimensions will be set separately during development. 6 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF49 Series●0.4 mm Pitch, Horizontal mating, Board- to-Fine Coaxial Cable Connectors ■Packaging Specification 2±0.15 4±0.1 (1.45) B±0.1 +0 0 .1 .75 Unreeling direction R0 0.2±0.05 C±0.3 A±0.1 Ø1 .5 +0 0 .1 8±0.1 1.75±0.1 lEmbossed Carrier Tape Dimensions lReel Dimensions Part number label Ø1 3± 0. Ø2 Ø382MAX 2± 1± 0. 8 0.5 (Ø79) 2 D +2 0 E MAX  Unit : mm Part Number CL No. Number of contacts A B C D E DF49-20S-0.4H(51) 662-5503-4-51 20 11.5 − 24.0 24.4 30.4 DF49-30S-0.4H(51) Under planning 30 14.2 28.4 32.0 32.4 38.4 DF49-40S-0.4H(51) 662-5500-6-51 40 20.2 40.4 44.0 44.4 50.4 Note 1 : Embossed tape will have perforated feed holes on single side (20pos.) 7 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF49 Series●0.4 mm Pitch, Horizontal mating, Board- to-Fine Coaxial Cable Connectors ■Packaging Specification 4±0.1 2±0.1 5 8±0.1 (1.4) +0.1 0 5 C±0.3 Unreeling direction R0.7 0.2±0.05 B±0.1 A±0.1 . Ø1 1 0. + 0 1.75±0.1 lPlugs lReel Dimensions Part number label Ø1 3± 0. Ø2 1 Ø382MAX 2± ±0 .8 0.5 (Ø79) 2 D +2 0 E MAX  Unit : mm Part Number CL No. Number of contacts A B C D E DF49-20P-0.4SD(51) 662-5504-7-51 20 11.5 − 24.0 24.4 30.4 DF49-30P-0.4SD(51) Under planning 30 14.2 28.4 32.0 32.4 38.4 DF49-40P-0.4SD(51) 662-5501-9-51 40 14.2 28.4 32.0 32.4 38.4 Note 1 : Embossed tape will have perforated feed holes on single side (20pos.) 8 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF49 Series●0.4 mm Pitch, Horizontal mating, Board- to-Fine Coaxial Cable Connectors ■Extraction tool For details about the extraction tool, please contact your Hirose sales representative. ■Precautions 1.Recommended temperature profile Temperature (ç) 250ç 250 220ç 200 60sec max 180ç 150 150ç 90 to 120sec 100 50 Room temperature 0 50 100 150 200 250 300 Time (sec.) Solder composition : Paste, 96.5%Sn/3.0%Ag/0.5%Cu Note 1: U  p to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2: The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals. 2.Recommended manual soldering Manual soldering: 350ç for 3 seconds Do NOT use flux compound when manual soldering. 3.Recommended screen thickness and open area ratio (Pattern area ratio) Standard thickness 0.1mm Open area ratios: Lead terimnal 100% :Ground terminal 75% 4.Board warpage Maximum of 0.02mm at the connector center, with both ends of the connector as reference points. 5.Cleaning conditions Refer to “Nylon Connector Use Handbook”. 9 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF49 Series●0.4 mm Pitch, Horizontal mating, Board- to-Fine Coaxial Cable Connectors ■Precautions Precautions Mating / un-mating Please work according to the following operational procedure: ① Confirmation of insertion direction Upon insertion, please check the front and rear of the connector at the cable side. On the front side, the ∆ mark, HRS mark and the display of the pole number are stamped. △ mark HRS mark CAV No. Number of contacts indicator ② Confirmation of temporary insertion Please lay the plug into the receptacle gently and insert up to the temporary insertion position. * If inserted up to the temporary insertion position, the connection can be correctly ensured. Receptacle shell dual-end surface Connection direction Plug shell end surface Receptacle shell dual-end surface Plug shell end surface With temporary insertion Before temporary insertion ③ Confirmation of insertion From the temporary insertion position, please push on both sides of the plug simultaneously and with equal force, to confirm the insertion. Push in both sides of the plug. Confirmed insertion 10 Mating The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. DF49 Series●0.4 mm Pitch, Horizontal mating, Board- to-Fine Coaxial Cable Connectors Precautions un-mating Use a dedicated extraction tool to un-mate the plug. Insert the tool under either end of the plug and pull as illustrated bellow.   Insert the tool under either pull out the plug   end of the plug. (for the horizontal direction) Finish • Do not mate / un-mate the connectors when receptacle is not mounted on the board. • In the manual soldering process, don't carry out the flux coating which will cause a flux blister on the connector. • Excessive scoop insertion or extraction may result in damage. 11 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Hirose Electric: DF49-40/RE-MD DF49-20/RE-MD(61) DF49-20/RE-MD DF49-40/RE-MD(61)
DF49-20/RE-MD(61)
物料型号:DF49系列
器件简介: - 该系列连接器具有超低剖面结构,堆叠高度仅为0.7mm(最大0.8mm)。 - 独特的接触配置确保了即使在小的配合高度下也能实现高度可靠的连接,有效配合长度为0.5mm。 - 金属壳体在插头和插座之间连接,确保了可靠的接地连接和EMC保护。 - 简化的锁结构带有可听到的点击声,由于两点侧锁结构和优化的接触力,可以听到点击声。 - 防止反向插入的机制,壳体的弯曲结构防止了插头连接器的反向插入和配合失败。 - 防止焊锡上爬的机制,镍屏障防止在关键接触区域的焊锡上爬(仅限插座)。
引脚分配:文档中提供了详细的引脚分配图和推荐PCB布局图案。
参数特性: - 电流额定值:AWG42为0.25A,AWG44为0.2A(注3),AWG46为0.15A。 - 工作温度范围:-35℃至85℃。 - 电压额定值:AC30V。 - 绝缘电阻:最小50 MΩ,100V直流。 - 耐电压:100Vrms交流电,1分钟无闪络或绝缘击穿。 - 接触电阻:信号最大80mΩ,地线最大80mΩ。
功能详解: - 提供了详细的操作说明,包括插入和拔出连接器的正确方法。
应用信息: - 适用于需要细同轴电缆连接的应用。
封装信息: - 提供了详细的封装尺寸和材料信息,包括插座和插头的尺寸、材料和表面处理。
DF49-20/RE-MD(61) 价格&库存
很抱歉,暂时无法提供与“DF49-20/RE-MD(61)”相匹配的价格&库存,您可以联系我们找货
