JBXOUTDC09
JBXOUTDC09
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    EXTRACTION TOOL
JBXOUTDC09 数据手册
JBX Push Pull Pull JBX Push Pull High reliability where quick, simple coupling mechanism is required Secure, quick confirmed mating Blind mate capability ✓ ✓ Tactile, Audible, Visual Mechanically keyed - prevents accidental engagement of wrong connector A versatile product ✓ Space Saving ✓ * Small footprint, allows access in tight applications * High density layouts 2 - 30 pins Economical ✓ ✓ Multiple cable collets / single part number www.souriau.com Rugged * Ergonomic design, fast and easy to use * Modular design * 5 shell sizes * Solder, crimp, PCB, R/A PCB contact terminations Metal shielding housing, high vibration and shock environments Push Pull Connectors Push Pull Connectors Part number system Contacts layouts JBX Basic series Shell type-Receptacle ER-EA-SR-PC-ED-EP-EZ-SA Shell type - Plug FD-FC-FF-FM-FN Shell size 00 - 0 - 1 - 2 - 3 Keying G-J-A-B Contact layout 02 ---------- 30 Contact type M : pin Contact termination FD 1 G 05 M C S D S M R Shell size 2 04 03 02 05 06 07 08 Male Insulator Wire Side Solder S S S S S S S C: crimp; S: solder; P*: straight PCB tails ; Q*: Right Angle PCB tails Crimp C C C C C C C Surface plating S : Outer shell brass alloy chrome over nickel plating PCB Straight Tails* XX XX P P P P P Q Q Q Q Q Obligatory Suffix Contact Size D : For all part numbers 1.3 1.3 1.3 0.9 Cable Backnut Option M : Connector with backnut for protective boot - Protective boot to order separately page 13 Key Identifier R : Red dot on shell for ED, ER, EZ, PC, SR, FC, FD, FF, FM & FN only F : socket N : Outer shell in brass alloy with black plating (consult Souriau USA) S : All contact diameters except .05 mm P : 0.5 mm contact dimensions only * For receptacles with female contacts only. Shell Types PCB Right Angle* Contact Diameter mm 1.3 1.3 1.3 10 12 16 S** Shell size 2 Male Insulator Wire Side 18 19 Technical characteristics ER : Front panel mount, fixed receptacle front flange FD : Straight plug EA : Front or rear panel mount with double nuts fixed receptacle Environmental Solder S S** * * * * Crimp C C C C C PCB Straight Tails* P P P P P PCB Right Angle* Q Q Q Contact Diameter mm 0.9 0.7 0.7 0.7 0.7 03 04 IP40 & IP 67/68 Temperature range: IP40 -40° - +125°C Temperature range: IP67/68 -40° - +80°C Shielding effectivity: 55dB up to 100MHg Mechanical EP : fixed receptacle, back panel mounting, fixed rear panel flange (appropriate with 90° contacts for PCB) FC : Right angle plug ED : Front mount protruding shell panel mount receptacle * * * * * * * * * Shell: Brass alloy Shell plating: Chrome over nickel Insulator: Peek Contact: Brass Contact plating: Gold Up to 8 key options 7 Color code options 5 Shell sizes >1,000 Mating cycles S** S** Shell size 3 07 08 10 14 18 22 30 S** Male Insulator Wire Side FN : Straight plug with lanyard Electrical SR : Front panel mount cable receptacle. fixed front flange PC : Inline cable receptacle FM : Right angle plug with lanyard EZ : PCB straight receptacle FF : Straight plug, no latch * Contact temination: Solder, Crimp PCB, R/A PCB * Contact rating: 0.5mm 2.0-2.5 Amp 0.7mm 5.0-7.0 Amp 0.9mm 7.0-10.0 Amp 1.3mm 11.0-15.0 Amp 1.6mm 15.0-17.0 Amp 2.0mm 25.0-30.0 Amp Solder S** S** S S S S S S** Crimp C C C C C C C C XX XX XX P P P P 2 2 1.6 1.3 1.3 0.9 PCB Straight Tails* P P 0.7 0.7 PCB Right Angle* Contact Diameter mm Please contact Souriau for additional technical information SA : Front or rear mount cable receptacle with double nuts, panel mount C 0.9 Push Pull Connectors Contacts layouts Push Pull Connectors KEYING • Voltage Test Procedure 04 in normal climatic conditions. The value is about 75% of the electrical breakdown voltage. The testing voltage level can be reached several times in connectors life, but never applied for a continuous duration. S - The working voltage corresponds to the maximum voltage the connector is able to withstand continuously during its life time, in real environmental conditions, even with high temperature. The value is around 1/3 of the testing voltage. Male Insulator Wire Side Solder J - The testing voltage corresponds to the maximum voltage the connector is able to withstand Shell size 00 Key Keying angle PCB Right Angle* Remark : If the current is applied on only one contact of the layout, then an increased current value can be achieved over a long duration. 0.5 Options • Protective boot 04 03 02 05 06 07 With each JBX connector, one protective boot can accept diverse cable diameters thus the end-user can manage various cable diameters without bothering with multiple part numbers. 08 Male Insulator Wire Side Solder S S S** S** Crimp C C C C PCB Straight Tails* P P P P PCB Right Angle* Q Q Q Q Contact Diameter mm 0.9 0.9 0.7 S** P S** 45° 37.5° 0° P 02 03 04 05 0.5 06 Solder S S S S S** Crimp C C C C PCB Straight Tails* P P P Q 1.3 PCB Right Angle* 1.3 Part number B* 30° 60° 0.5 07 08 S** S** C C C P P P P Q Q Q Q Q 0.9 0.9 0.7 0.7 0.7 **Inserts with fixed non removable contacts * For receptacles with female contacts. Note : Contact numbering mating faces receptacle view: counterclockwise from key at position 1 Contact numbering mating faces plug view: clockwise from key at position 1 Dimensions Shell size ØA Ø Cable L min max JBX 00 MPN 00 1.5 15 1 3.5 JBX 0 MP* 0 2.2 20 1.5 5.5 JBX 1 MP* 1 2.6 25 2 7.5 JBX 2 MP* 2 4 30 3.5 9.7 JBX 3 MP* 3 5 35 4.9 12 * Color code - See chart below / In size 00, available only in black P Color code 0.7 A S** 0.5 Shell size 1 Contact Diameter mm sizes 2 - 3 Receptacle Shell size 0 Male Insulator Wire Side sizes 0 - 1 - This indicated maximum current rating corresponds to the maximum current that can be applied simultaneously on each line of the connector mated pair, continuously during its life time, in normal climatic conditions. PCB Straight Tails Contact Diameter mm G Plug • Maximum current rating Crimp Dual Key Way 10 S** 12 0.5 A blue Material : ELASTOLLAN (PUR) B white Working temperature : G grey - 40°C ; + 80°C J yellow - 40°F ; + 176°F M brown N black R red V green O orange Parts that require a protective boot need to be ordered with an M suffix. Protective boots are ordered separately. S** • Caps : an efficient protection against dust P Colors P 0.5 Receptacle Caps Part number Shell Size Plug Caps Part number Shell Size JBX BF00 00 JBX BR0 0 JBX BF0 0 JBX BR1 1 JBX BF1 1 JBX BR2 2 JBX BF2 2 JBX BR3 3 JBX BF3 3 Push Pull Connectors Push Pull Connectors Dimensions - Receptacles EA : Double nut ER : Front mount EP : Rear mount Dimensions - Plugs FM : Right angle with lanyard FC : Straight Plug with Lanyard Size 00 0 1 2 3 Size A 14 19 21 24 28 A B 6 8 10 10 12 B C 0.8 1.2 1.5 1.8 2.0 C 2.5 ØD 8 10 14 18 22 ØD 0 1 2 19 21 6.7 8.3 3.2 12 3 Size 24 28 8 9.5 3.8 4.5 16 20 24 ED : Front mount, protruding SA : Double nut panel mount receptacle 0 1 A 19 21 24 B 4.5 6 6.5 C 2.5 3.2 3.8 ØD 12 2 16 20 SR : Front mount cable clamp Size 0 1 2 3 Size 0 1 2 3 Size 0 1 2 3 A 30.5 36.5 42.5 50.5 A 30.5 36.5 42.5 50.5 A 30.5 36.5 42.5 50.5 B 20.5 25.5 30.5 35.5 B 20.5 25.5 30.5 35.5 B 20.5 25.5 30.5 35.5 C 29.5 33.5 36.5 45 C 29.5 33.5 36.5 45 C 29.5 33.5 36.5 45 ØD 10 12 15 18 ØD 10 12 15 18 ØD 10 12 15 18 0 1 2 3 A 38 43 50 59 A 19 B - - 6.5 - B 3 C 2.5 3.2 3.8 - C 1.2 ØD 12 16 20 24 ØD 10 Size 0 2 Size 0 1 2 3 21 24 A 38 43 50 59 4.5 6.3 B 8 10 10 12 1.5 1.8 C 1.2 1.5 1.8 2 14 18 ØD 10 14 18 22 1 PC : In line receptacle EZ : PCB Size 00 0 1 2 FD : Straight FC : Right angle FN : Straight plug with lanyard Size FF : Straight, no latch 3 A 31 39 45 52 62 B 23 29 34 40 47 ØC 8 1 13 16 19 Size 0 1 2 3 A 30.5 36.5 42.5 50.5 B 20.5 25.5 30.5 35.5 C 29.5 33.5 36.5 ØD 10 12 15 Size 00 0 1 2 3 A 31 39 45 52 62 45 B 23 29 34 40 47 18 ØC 7 10 12 15 18 Range of cable diameters With the plastic collet set supplied with the standard product, a wide range of cable diameters is allowed. Find below the maximum and the minimum for each size of shell (for information only because it can change with the cable characteristics). Size 0 1 10 19 4 12 21 4 7.62 1.1 7.62 1.1 Size 0 1 2 3 A 38 43 50 59 ØA B C D ØB 10 13 16 19.5 ØE Size 00 0 1 2 3 Ø A min 1.1 1.5 2.0 3.5 4.9 Ø A Max 3.5 5.5 7.5 9.7 12.0
JBXOUTDC09 价格&库存
很抱歉,暂时无法提供与“JBXOUTDC09”相匹配的价格&库存,您可以联系我们找货
JBXOUTDC09
    • 1+3073.64254
    库存:2
