MKDSSCS4123
MKDSSCS4123
    JST
    DIE SET FOR MKL
MKDSSCS4123 数据手册
APPLICATION TOOLING 5-A Crimping tools and machines Strip-crimp applicator for side feeding terminals Model No.: MKS-SC 1 (W x L x H)198 x 186 x 203mm (7.8"X7.3"X8.0") •Weight: 6.5kg(14.3lb) •Applicable terminals: Side-feeding terminals for wires AWG #20 to #30 •Accessories: Vacuum unit (optional) •Both-foot-swich-operated type and touch-sensor-operated type are available. •Dimensions: Fully automatic crimping machine ATM-4 (Refer to page 534.) 7 Crimping applicator for end-feeding terminals Model No.: MK-L 2 Hand crimp tools 6 YC Crimping applicator for side-feeding terminals Model No.: MKS-L 3 Dimensions: (WxL)70x296mm(2.8"x11.7") YRS Dimensions: (WxL)72x220mm(2.8"x8.7") 2 Crimping tools and machines The arrow mark indocates the press that is applicable to the applicator. Compact crimping applicator for side-feeding terminals Electric press Model No.: MKS-LS Model No.: AP-K2N 4 8 •Dimensions: •Weight: •Power source: •Pressure output: •Dies: (W x L x H)(280 x 480 x 505mm) 11.0" X18.9" X19.9" 90kg(198lb) 100/115/220/240V AC, 50/60Hz 14.7kN [ 1,500kg (3307lb) ] Applicator replacement Crimping applicator for end-feeding flag terminals Model No.: MKF-L 5 ID applicator for discrete wires Model No.: MKD-LP 12 3 Crimping tools and machines 5-B Crimping tools and machines JST offers semi-automatic and fullyautomatic crimping machines. Semiautomatic crimping machines (presses) connect a wire to a chain terminal each time a footswitch is pressed. Fully-automatic crimping machines measure, cut, strip and connect numerous wire to chain terminals. We also offer hand tools that connect wires to loose-piece terminals. Semi-automatic press: AP-K2N Standard (crimp applicator) MK-L 2 MKS-L 3 MKF-L 5 MKS-LS 4 Strip-crimp applicator MKS-SC 1 Terminals and parts model number in alphabetical order Applicator Die set Applicator Die set — GEC-SC1112 MKS-L MK-DS GEC11 — GEC-SC1212 MKS-L MK-DS GEC12 — — MKS-L MK-DS JK-SP/SS2 MKS-SC-JK MKS-SC-DS JK-SP/SS2 JK-FL15B-11.3 MKS-RG MK-DS JK-MC15 — — J-FL15B-10.5 MKS-RG MK-DS J-MC15 — — MKS-L MK-DS J-SP/SS1 MKS-SC MKS-SC-DS J-SP/SS1 MKS-L MK-DS J-SP/SS2 MKS-SC MKS-SC-DS J-SP/SS2 MD-PCC8T-S1 MKS-L MK-DS MD-PCC8T-S1 — — MD-PCC8T-S2 MKS-L MK-DS MD-PCC8T-S2 — — JK-SP 2*** JK-SS 2*** J-SP 1*** J-SS 1*** J-SP 2*** J-SS 2*** 6 Crimping tools and machines Semi-automatic press Fully-automatic machime AP-K2N 8 ATM-4 7 Note 1 on Hand tools: These hand tools are applicable to the wire with the outside diameters of insulation conforming to UL1007. Special wires may not be crimped. Each YC tool has two crimping sections (A and B). These sections must be used properly. Since the dies are fixed, the crimping height cannot be adjusted. Therefore, some of the applicable wires described in this catalog may not be crimped properly. Before use, check for proper crimping (such as tensile strength, terminal/contact deformation). When hand crimping board-in terminals (SAN, SCN, SDN, SIN, SZN), care should be taken not to contaminate the solder tails of the terminals, as with greasy or oily fingers. If a solder problem arises, some cleaning of the tips of the terminal is advisable. Note 2 on Extraction and Insertion tools: Extraction tools are used to extract contacts improperly inserted in the housing. Insertion tools allow contacts be inserted in the housing. This tool greatly increases efficiency especially when thin wires are used. Hand tools (See the Note above) Fully-automatic machine: ATM-4 Crimp applicator AMK-R for chain teminals for loose piece terminals YRS series 6 YC series 6 (See Note above) Extraction and Insertion tools Extraction tool Insertion tool (See Note above) AMKS-L Applicator Die set YRS series YC series Terminal model No. Extraction tool Insettion tool — — — — — — — — — — — — — — — — YRS-370 — — KEJ-07 — KEJ-0.4 — — — — — — — — — — — — — — — — YRS-440 YC-440 DEJ-0.3 — DEJ-0.3 — J-BP 1*** J-BS 1*** — — YRS-330 — — — — — — — — — — — — — — — — — 7 Crimping tools and machines Terminals and parts model number in alphabetical order Standard crimp applicator Die set Applicator Die set MD-PCC9T-S3 MKS-L MK-DS MD-PCC9T-S3 — — MD-PS8SL MKS-LS-RG MK-DS MD-PS8SR — — MD-PS8ASR MKS-LS-RG MK-DS MD-PS8SR — — MD-PS8BSR MKS-LS-RG MK-DS MD-PS8SR — — MD-PS8SR MKS-LS-RG MK-DS MD-PS8SR MD-SP 12** MKS-L MK-DS MD-SP12 MKS-SC MKS-SC-DS MD-SP12 MD-SP 22** MKS-L MK-DS MD-SP22 MKS-SC-JK MKS-SC-DS MD-SP22 PSL-40(T) MKS-L (Note 1) MK-DS PSL40 — — PSL-60(T) MKS-L (Note 1) MK-DS PSL60 — — PSL-80(T) MKS-L (Note 1) MK-DS PSL80 RA-SC1290 MKS-L MK-DS RA-SC12 RF-SC 22** MKS-L MK-DS RF-SC22 — — SAA-21(T)-** MK-L MK-DS SAA21 — — SAA-50(T)-** MK-L MK-DS SAA50 — — SAA-51(T)-** MK-L MK-DS SAA51 — — SAB-51(T)-** MK-L MK-DS SAB51 — — SAD-01T-** MK-L MK-DS SAD01 — — SAN-002T-0.8A MKS-L MKS-LS MK-DS SAN002-08 MKS-SC MKS-SC-DS SAN002-08 SAN-002T-0.8K SBH-001T-P0.5 MKS-L MK-DS SBH001-05 — — SBT-31(T)-001 MKS-L MK-DS SBT31-001 — — SBT-31(T)-002 MK-L MKS-L MK-DS SBT31-002 — — MKS-L MK-DS SCN001-10 MKS-SC MKS-SC-DS SCN001-10 MK-L MK-DS SCS41-23 — — MKS-L MK-DS SDF01-13 — — SDN-21T-P1.5 MKS-L MK-DS SDN21-15 — — SDY-01T-P1.6ASV MKS-L MK-DS SDY01-16AS — — SEH-001T-P0.6 MKS-L MKS-LS MK-DS SEH001-06 MKS-SC MKS-SC-DS SEH001-06 SEH-003T-P0.6L MKS-L-10 MK-DS SEH003-06 MKS-SC MKS-SC-DS SEH003-06L SFO-1.0(T)-250N MKS-L-FO MK-DS SFO1.0-250N — — SFO-2.5(T)-250N MKS-L-FO MK-DS SFO2.5-250N — — SFO-41(T)-187N MKF-L-187 MK-DS SFO41-187N — — SFO-61(T)-250A MKF-L-250 MK-DS SFO61-250A — — SFO-41T-2.3 MKF-L-2.3 MK-DS SFO41-23 — — SFPS-41T-187 MKF-L-SP187 MK-DS SFPS41-187 — — SFPS-61T-250 MKF-L-SP250 MK-DS SFPS61-250 — — SFT-61T-250N MKS-L MK-DS SFT61-250N — — SGF-21(T)-5 MK-L MK-DS SGF21-5 — — SGF-41(T)-4 MK-L MK-DS SGF41-4 — — MK-L MK-DS SGF51-5 — — SBT-31(T)-003 SCN-001T-1.0K Applicator Strip-crimp applicator — — MKS-SC — — MKS-SC-DS RA-SC12 SCN-001T-P1.0 SCS-41T-2.3 SDF-01T-1.0A SDF-01T-1.3AS SGF-51(T)-5 SGF-51T-5A (Note 1) The safety cover specification for this applicator is different from that of the other MKS-L applicators. Use the model number “MKS-L2 WITH SAFETY COVER” when ordering one “with safety cover .” 8 Crimping tools and machines Applicator for fully automatic machine Hand tools Extraction and Insertion tools Applicator Die set YRS series YC series Terminal model No. Extraction tool Insertion tool — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — YRS-470 — — MEJ-06 — — — YRS-460 — — MEJ-06 — — — — — — — — — — — — — — — — — — — — — — — — YRS-231 — — EJ-RA — AMKS-L — AMK-DS RF-SC22 — — (Note3) RF BC22** — — — YC-141 LAA 21(T) ** — — AMK-R AMK-DS SAA50 — YC-182 LAA 50(T) ** — — AMK-R AMK-DS SAA51 — YC-142 LAA 51(T) ** — — — — — YC-142 LAB 51(T) ** — — — — — — — — — YRS-220 — — — PHJ-05 AMKS-L AMK-DS SAN002-08 — — — YC-670R BBH-001T-P0.5 — — — — — — — — — AMKS-L AMK-DS SBT31-002 — — — — — AMKS-L AMK-DS SCN001-10 YRS-191 — — — — — — — — CSJ-23 — — YC-045 LDF-01T-1.3A — — LDF-01T-1.3AS — — — AMKS-L AMK-DS SDF01-13 — — — — — — — — — — — — YLJ-0.5 — YRS-260 YC-260R BEH-001T-P0.6 — — — — — — — — — AMKS-L AMK-DS SEH001-06 — — AMKS-L-FO AMK-DS SFO1.0-250N AMKS-L-FO AMK-DS SFO2.5-250N AMKF-R AMK-DS SFO41-187N — — — — — AMKF-R AMK-DS SFO61-250N — — — — — — — — — — — — — — — — — — — — — — — — — — — — YRS-510 YC-510 — — — — — — — YC-055 LGF-41(T)-4 — — LGF-51(T)-5 — — LGF-51-5A — — AMK-R — AMK-R AMK-DS SGF21-5 — AMK-DS SGF51-5 (Note 2) — (Note 2) Contact J.S.T. Europe N.V. for the applicable hand tools. YC-065 BFT-61T-250N — (Note 3) YC series for this contact is not available.Use YRM-230 instead. 9 Crimping tools and machines Terminals and parts model number in alphabetical order Standard crimp applicator Applicator Die set SGM-21(T)-5 MK-L MK-DS SGM21-5 — — SGM-51(T)-4 MK-L MK-DS SGM51-4 — — SGM-51(T)-5 MK-L MK-DS SGM51-5 — — MKS-L-HC MK-DS SHC21-001 — — MK-DS SHF001-08S MKS-SC SHF-002T-0.8BS MKS-L MKS-LS MKS-L MKS-LS MK-DS SHF002-08S MKS-SC MKS-SC-DS SHF002-08S SHR-001T-P0.6 MKS-L MK-DS SHR/MR001-06 MKS-SC MKS-SC-DC-SHR/MR001-06 SIM-1.0(T)-250D MK-L-IM MK-DS SIM1.0-250D — — SIM-2.5(T)-250D MK-L-IM MK-DS SIM2.5-250D — — SIM-01(T)-110A MK-L MK-DS SIM01-110A — — SIM-21(T)-250 MK-L MK-DS SIM21-250 — — SIM-41(T)-110B MK-L MK-DS SIM41-110B — — SIM-51(T)-250N MK-L MK-DS SIM51-250N — — SIN-001T-1.2 MKS-L MK-DS SIN001-12 MKS-SC MKS-SC-DS SIN001-12 SIN-001T-1.2B MKS-L MK-DS SIN001-12B MKS-SC MKS-SC-DS SIN001-12B SIN-002T-1.0 MKS-L MK-DS SIN002-10 MKS-SC MKS-SC-DS SIN002-10 SIN-002T-1.0S MKS-L-IN MK-DS SIN002-10S — SIN-002T-1.2N MKS-L MK-DS SIN002-12N MKS-SC MKS-SC-DS SIN002-12N SIN-01T-1.2 MKS-L MK-DS SIN01-12 MKS-SC MKS-SC-DS SIN01-12 SIN-01T-1.8(N) MKS-L MK-DS SIN01-18 MKS-SC MKS-SC-DS SIN01-18 SIN-21T-1.8 MKS-L MK-DS SIN21-18 — SIN-21T-1.8S MKS-L-SIN MK-DS SIN21-18S MKS-SC SIN-41T-2.4S MKS-L-SIN MK-DS SIN41-24S — — SIN-61T-2.6S MKS-L-SIN MK-DS SIN61-26S — — SLC-21T-2.0 MKS-L MK-DS SLC21-20 — — SLC-22T-2.0 MKS-L MK-DS SLC22-20 SLF/M-01T-P1.3E MKS-L MK-DS SLF/M01-13E MKS-SC MKS-SC-DS SLF/M01-13E SLF/M-41T-P1.3E MKS-L MK-DS SLF/M41-13E MKS-SC MKS-SC-DS SLF/M41-13E SLF/M-42T-P1.3E MKS-L MK-DS SLF/M42-13E — — SMF-01T-1.0 MKS-L MK-DS SMF01-10 — — SMF-01T-1.3 MKS-L MK-DS SMF01-13 — — SMM-003T-0.5 MKS-L MKS-LS MK-DS SMM003-05 SMR-001T-0.6 MKS-L MK-DS SHR/MR001-06 — — SOM-21(T)-187 MK-L MK-DS SOM21-187 — — SOM-51(T)-250 MK-L MK-DS SOM51-250 — — SPC-01(T) MKS-L (Note 1) MK-DS SPC01 — — SPC-20(T) MKS-L (Note 1) MK-DS SPC20 — — SHC-21(T)-001 Applicator Die set Strip-crimp applicator SHC-21(T)-002 SHF-001T-0.8BS — MKS-SC MKS-SC-DS SHF001-08S — — MKS-SC-DS SIN21-18S — MKS-SC-DS SMM003-05 (Note 1) The safety cover specification for this applicator is different from that of the other MKS-L applicators. Use the model number “MKS-L2 WITH SAFETY COVER” when ordering one “with safety cover .” 10 Crimping tools and machines Applicator for fully automatic machine Applicator AMK-R — AMK-R Die set AMK-DS SGM21-5 — AMK-DS SGM51-5 Extraction and Insertion tools Hand tools YRS series YC series Terminal model No. Extraction tool Insertion tool — — — — YC-056 LGM-51(T)-4 — — — YC-056 LGM-51(T)-5 — — — — — — — — — — AMKS-L AMK-DS SHF001-08S YRS-122 YC-122R BHF-001T-0.8BS SMJ-06 — AMKS-L — AMK-DS SHF002-08S YRS-300 — — SMJ-06 — — — YRS-580 YC-580R BHR-001T-P0.6 — — AMK-R-IM AMK-DS SIM1.0-250D — — AMK-R-IM AMK-DS SIM2.5-250D — — AMK-R AMK-DS SIM01-110A — LIM-01(T)-110A — — — — — — — AMK-R AMK-DS SIM41-110B — YC-067 LIM-41(T)-110B — — AMK-R AMK-DS SIM51-250N — YC-321 LIM-51(T)-250N — — — (Note 2) YC-054 — AMKS-L AMK-DS SIN001-12 YRS-034 —| — — — AMKS-L AMK-DS SIN001-12B — — — — — AMKS-L AMK-DS SIN002-10 — — — — — — YRS-035 — — — — AMKS-L AMK-DS SIN002-12N — — — — — AMKS-L AMK-DS SIN01-12 — — — — — AMKS-L AMK-DS SIN01-18 — — — — — AMKS-L AMK-DS SIN21-18 — — — — — — — — — — — — — — — — — — — — — — — — — — — — AMKS-L — AMK-DS SLC21-20 — — YC-310 LLC-21T-2.0 — — — — AMKS-L AMK-DS SLF/M01-13E — YC-202 LLF/M-01T-P1.3E LEJ-13 LIT-2013 AMKS-L AMK-DS SLF/M41-13E — YC-203 LLF/M-41T-P1.3E — — — — — — — — AMKS-L — — — — YC-081 LMF-01T-1.0 — — — — — YC-082 LMF-01T-1.3 — — — — YRS-800 — — — — — — — YC-580R BMR-001T-0.6E HRWJ — — — — YC-680 LOM-21(T)-187 — — — — — YC-066 LOM-51(T)-250 — — — — — — — — — — — — — — — — AMK-DS SMF-01-10 (Note 2) Contact J.S.T. Europe N.V. for the applicable hand tools. 11 Crimping tools and machines Terminals and parts model number in alphabetical order Standard crimp applicator Applicator Die set SPC-40(T) MKS-L (Note 1) MK-DS SPC40 — — SPB-1.0(T)-250N MKS-L-PB MK-DS SPB1.0-250N — — SPB-2.5(T)-250N MKS-L-PB MK-DS SPB2.5-250N — — SPC-1.0(T) MK-L-PC MK-DS SPC1.0 — — SPC-2.5(T) MK-L-PC MK-DS SPC2.5 — — SPF-01T-2.5C MK-L MK-DS SPF01-25C — — SPH-002T-P0.5S MKS-L MKS-LS MK-DS SPH002-05S MKS-SC MKS-SC-DS SPH002-05S SPH-004T-P0.5S MKS-L-10 MK-DS SPH004-05S — — SPHD-001T-P0.5 MKS-L-10 MKS-LS-10 MKS-L-10 MKS-LS-10 MK-DS SPH001-05 MKS-SC-10 MKS-SC-DS SPHD001-05 MK-DS SPHD002-05 MKS-SC-10 MKS-SC-DS SPHD002-05 SPHD-002T-P0.5 SPJ-002T-1.2 Applicator Die set Strip-crimp applicator MKS-L MK-DS SPJ002-14/N12 or MK-DS SPJ002-14/N16 — — SPS-01T-110 MK-L-SPS MK-DS SPS01-110 — — SPS-01T-187 MK-L-SPS MK-DS SPS01-187 — — SPS-41T-110 MK-L-SPS MK-DS SPS41-110 — — SPS-51T-187 MK-L-SPS MK-DS SPS51-187 — — SPS-61T-250 MK-L-SPS MK-DS SPS61-250 — — SPS-61T-250S MK-L-SPS MK-DS SPS61-250 — — SPS-91T-250S MK-L-SPS MK-DS SPS91-250 — — SRA-01(T)-** MK-L MK-DS SRA01 — — SRA-20(T)-** MK-L MK-DS SRA20 — — SRA-21(T)-** MK-L MK-DS SRA21 — — SRA-50(T)-** MK-L MK-DS SRA50 — — SRA-51(T)-** MK-L MK-DS SRA51 — — MK-L MK-DS SRB1.0-W8 — — MK-L MK-DS SRB1.0 W9.5 — — MK-L MK-DS SRB2.5 W8 — — MK-L MK-DS SRB2.5 W9.5 — — SRB-50(T)-** MK-L MK-DS SRB50 — — SRB-51(T)-** MK-L MK-DS SRB51 — — SRC-01(T)-** MK-L MK-DS SRC01 — — SRC-50(T)-** MK-L MK-DS SRC50 — — SRC-51(T)-** MK-L MK-DS SRC51 — — SRD-20(T)-** MK-L MK-DS SRD20 — — SRGB-002T-0.3J MKS-L MK-DS SRGB002-03J MKS-SC MKS-SC-DS SRGB002-03 SRF-51(T)-** MK-L MK-DS SRF51 — — SRT-1.0T/N-M5S MK-L MK-DS SRT1.0-M5 — — SRT-2.5T/N-M5S MK-L MK-DS SRT2.5-M5 — — SPJ-002T-1.4 SRB-1.0(T)-M3/4 SRB-1.0(T)-M5-W8 SRB-1.0(T)-M3/4-W9.5 SRB-1.0(T)-M5/6 SRB-2.5(T)-M3/4 SRB-2.5(T)-M5-W8 SRB-2.5(T)-M3/4-W9.5 SRB-2.5(T)-M5/6 (Note 1) The safety cover specification for this applicator is different from that of the other MKS-L applicators. Use the model number “MKS-L2 WITH SAFETY COVER” when ordering one “with safety cover .” 12 Crimping tools and machines Applicator for fully automatic machine Die set YRS series YC series — — — — AMKS-L-PB AMK-DS SPB1.0-250N AMKS-L-PB AMK-DS SPB2.5-250N AMK-R-PC AMK-DS SPC1.0 AMK-R-PC AMK-DS SPC2.5 YRS-241 — AMKS-L — AMK-DS SPH002-05S Extraction and Insertion tools Hand tools Applicator Terminal model No. Extraction tool Insertion tool — — — YC-043R LPF-01T-2.5C — — YRS-240 — — PHJ-05 — — — — PHJ-05 — (Note 2) — — — — — YC-610R BPHD-001T-P0.5 EJ-PHD — — — YRS-620 — — EJ-PHD — — — — — — — — AMK-R AMK-DS SPS01-110 — AMK-R AMK-DS SPS01-187 — AMK-R AMK-DS SPS41-110 — AMK-R AMK-DS SPS51-187 — AMK-R AMK-DS SPS61-250 — AMK-R AMK-DS SPS61-250 — — AMK-R AMK-DS SPS91-250 — AMK-R AMK-DS SRA01 — AMK-R AMK-DS SRA20 AMK-R AMK-DS SRA21 AMK-R AMK-R AMK-R AMK-DS SRB1.0-W8 AMK-R AMK-DS SRB1.0-W9.5 — — — 5) LPS-01T-187 EJ-PS187 — — — — 6) LPS-51T-187 EJ-PS187 — 7) LPS-61T-250 EJ-PS250 — — — — — — — — — — — — — YC-181 LRA-20(T)-** — — — YC-141 LRA-21(T)-** — — AMK-DS SRA50 — YC-182 LRA-50(T)-** — — AMK-DS SRA51 — YC-142 LRA-51(T)-** — — — YC730 YC731 (Note — YC710 YC711 (Note YC720 YC721 (Note (Note 2) AMK-R AMK-DS SRB2.5-W8 AMK-R AMK-DS SRB2.5-W9.5 — — — — — — — AMK-R AMK-DS SRB51 — YC-142 LRB-51(T)-** — — AMK-R AMK-DS SRC01 — YC-033 LRC-01(T)-** — — AMK-R AMK-DS SRC50 — YC-183 LRC-50(T)-** — — AMK-R AMK-DS SRC51 — YC-142 LRC-51(T)-** — — AMK-R — — — — RGB-EJ-A,RGB-EJ-B — — — — — — — — — — — YC-142 — — — — — — LRF-51(T)-** (Note 2) (Note 2) Contact J.S.T. Europe N.V. for the applicable hand tools. (Note 5) YC-730 is for AWG#26 and #22 wires, while YC-731 is for AWG#24 and #20 wires. (Note 6) YC-710 is for AWG#20 and #16 wires, while YC-711 is for AWG#18 and #14 wires. (Note 7) YC-720 is for AWG#18 and #16 wires, while YC-721 is for AWG#14 wires. 13 Crimping tools and machines Terminals and parts model number in alphabetical order SRT-51T-3FE Standard crimp applicator Applicator Die set Strip-crimp applicator Applicator Die set MK-L MK-DS SRT51 – – SSF/M-01T-P1.4 MKS-L MK-DS SSF/M01-14 – – SSF/M-21T-P1.4 MKS-L MK-DS SSF/M21-14 – – STB-01T-001 MKS-L MK-DS STB01-001 – – STB-001T-P MKS-L MK-DS STB001-P – – MK-L MK-DS STI-1.0-250D/N – – MK-L MK-DS STI-2.5-250D/N – – STI-01(T)-110N MK-L MK-DS STI01-110N – – STI-41(T)-110N MK-L MK-DS STI41-110N – – STI-51(T)-250N MK-L MK-DS STI51-250N – – MK-L MK-DS STO1.0-110N – — MK-L MK-DS STO1.0-187N – – STO-1.0(T)-250N MK-L MK-DS STO1.0-250N – – STO-2.5(T)-250N MK-L MK-DS STO2.5-250N – – STO-6.0(T)-250N MK-L MK-DS STO6.0-250N – – STO-01(T)-110N(-8) MK-L MK-DS STO01-110N – – STO-01(T)-187N(-8) MK-L MK-DS STO01-187N – – STO-21(T)-205N(-5) MK-L MK-DS STO21-205N – – STO-21(T)-250N MK-L MK-DS STO21-250N – – STO-41(T)-110N(-8) MK-L MK-DS STO41-110N – – STO-41(T)-187N(-8) MK-L MK-DS STO41-187N – – STO-41T-187S MK-L MK-DS STO41-187S – – STO-61(T)-250N MK-L MK-DS STO61-250N – – STO-62T-187N MK-L MK-DS STO62-187N – – STO-62T-250N MK-L MK-DS STO62-250N – – STO-81(T)-250N MK-L MK-DS STO81-250N – – STO-82T-187N MK-L MK-DS STO82-187N – – SVA-41T-P1.1 MKS-L MK-DS SVA41-11 MKS-SC MKS-SC-DS SVA41-11 SVF-01T-1.5A MK-L MK-DS SVF01-15A – – MKS-L MK-DS SVF01-15N – – SVF-01T-2.36LN MKS-L MK-DS SVF01-236LN – – SVF-01T-2.36N MK-L MK-DS SVF01-236N – – SVF-42T-P2.0 MKS-L MK-DS SVF/M42-20 SVF/M-61T-P2.0 MKS-L MK-DS SVF/M61-20 – – SVF/M-81T-P2.0 MKS-L MK-DS SVF/M81-20 SVH-21T-P1.1 MKS-L MK-DS SVH21-11 MKS-SC MKS-SC-DS SVH21-11 SVT-41T-P1.1 MKS-L MK-DS SVT41-11 – – SWS-40-01 MK-L MK-DS SWS40-01 – – SRT-51T-4FE STI-1.0(T)-250D STI-1.0(T)-250N STI-2.5(T)-250D STI-2.5(T)-250N STO-1.0(T)-110N-5 STO-1.0(T)-110N-8 STO-1.0(T)-187N-5 STO-1.0(T)-187N-8 SVF-01T-1.5N SVF-01T-1.5S (Note 1) The safety cover specification for this applicator is different from that of the other MKS-L applicators. Use the model number “MKS-L2 WITH SAFETY COVER” when ordering one “with safety cover .” 14 Crimping tools and machines Applicator for fully automatic machine Applicator – Die set – Hand tools YRS series YC series – YC-143R Extraction and Insertion tools Terminal model No. Extraction tool Insertion tool LRT-51T-3FE – – LRT-51T-4FE – – AMKS-L AMK-DS SSF/M01-14 – YC-500 BSF/M-01T-P1.4 SLJ-1.4 ITBL-08V AMKS-L AMK-DS SSF/M21-14 – YC-550 BSF/M-21T-P1.4 SLJ-1.4 – AMKS-L AMK-DS STB01-001 – – – – – – – – – – – – – – – – – AMK-R – AMK-DS STI1.0-250 D/N (Note 2) AMK-R AMK-DS STI2.5-250 D/N – – AMK-R AMK-DS STI01-110N – YC-041 LTI-01(T)-110N – – AMK-R AMK-DS STI41-110N – YC-063 LTI-41(T)-110N – – AMK-R AMK-DS STI51-250N – YC-322 LTI-51(T)-250N – – AMK-R AMK-DS STO1.0-110N – – – – AMK-R AMK-DS STO1.0-187N – – – – AMK-R AMK-DS STO1.0-250N – – AMK-R AMK-DS STO2.5-250N – – – – – – (Note 2) – AMK-R AMK-DS STO01-110N – YC-041 LTO-01(T)-110N(-8) – AMK-R AMK-DS STO01-187N – YC-042 LTO-01(T)-187N(-8) – – AMK-R AMK-DS STO21-205N – – – – – AMK-R AMK-DS STO21-250N – YC-102 LTO-21(T)-250N – – AMK-R AMK-DS STO41-110N – YC-062 LTO-41(T)-110N(-8) – – AMK-R AMK-DS STO41-187N – YC-051 LTO-41T-187N – – – YC-064 LTO-41T-187S – – AMK-R – AMK-R – – – – YC-047 LTO-61(T)-250N – – – – – – – – – – – – – – – YC-280 LTO-81(T)-250N – – – – – AMK-DS STO61-250N AMK-DS STO81-250N AMK-R – – – – – – YC-450 BVA-41T-P1.1 EJ-SMP – – YC-044 LVF-01T-1.5A – – – YC-151 LVF-01T-1.5N – – – AMK-DS SVF01-15A AMKS-L AMK-DS SVF01-15N AMKS-L AMK-DS SVF01-236LN AMK-R AMK-DS SVF01-236N AMKS-L AMK-DS SVF/M42-20 – – – – YC-152 – – – – – – LVJ-08 – LVJ-08 – LVF-01T-2.36N – – – VLJ-20 – – YC -590 BVF/M-61T-P2.0 VLJ-20 – AMKS-L AMK-DS SVF/M81-20 – (Note 4) BVF/M-81T-P2.0 VLJ-20 – AMKS-L AMK-DS SVH21-11 – YC-160R BVH-21T-P1.1 EJ-NV – LVT-41T-P1.1 EJ-VT – – – – – – YC-630 – – – – (Note 2) Contact J.S.T. Europe N.V. for the applicable hand tools. – (Note 4) YC series for this contact is not available. Use YRF-591 instead. 15 Crimping tools and machines Terminals and parts model number in alphabetical order Standard crimp applicator Die set Applicator SXA-001T-P0.6 MKS-L MK-DS SXA/M001-06 MKS-SC MKS-SC-DS-SXA/M-001-06 SXA-01T-P0.6 MKS-L MK-DS SXA/M01-06 — — SXF-01T-P0.7 MKS-L MK-DS SXF01-07 — — SXF-41T-P0.7 MKS-L MK-DS SXF41-07 MK-DS SXH001-06 MKS-SC MKS-SC-DS SXH001-06 SXH-002T-P0.6 MKS-L MKS-LS MKS-L MKS-LS MK-DS SXH002-06 MKS-SC MKS-SC-DS SXH002-06 SXM-001T-P0.6 MKS-L MK-DS SXA/M001-06 MKS-SC MKS-SC-DS SXA/M-001-06 SYF-001T-P0.6 MKS-L MK-DS SYF001-06 — SYF/M-01T-P0.5A MKS-L MK-DS SYF/M01-05 MKS-SC-YL MKS-SC-DS SYF/M01-06 SYF/M-41T-P0.5A MKS-L MK-DS SYF/M41-05 MKS-SC-YL MKS-SC-DS SYF/M41-05 SYM-001T-P0.6 MKS-L MKS-LS MK-DS SYM001-06 MKS-SC MKS-SC-DS SYM001-06 SYM-01T-P0.7 MKS-L MK-DS SYM01-07 — — SYM-41T-P0.7 MKS-L MK-DS SYM41-07 — — SZF/M-01T-P0.7 MKS-L MK-DS SZF/M01-07 — — SZF/M-41T-P0.7 MKS-L MK-DS SZF/M41-07 — — SZH-002T-P0.5 MKS-L MK-DS SZH002-05 — SZH-003T-P0.5 MKS-L MK-DS SZH003-05 SZN-002T-P0.7K MKS-L MKS-LS MK-DS SZN002-07 — MK-DS SZN003-07 MKS-SC SXH-001T-P0.6 SZN-003T-P0.7K Applicator Strip-crimp applicator Die set — — MKS-SC — — MKS-SC-DS SZH003-05 — MKS-SC-DS SZN003-07 ATM-4 5-C 7 Fully automatic crimping machine. Features–––––––––––––––––––––––– • The machine is controlled via a new touch sensitive visual display interface which is user friendly, and helps the operator program the machine in a simple step-by-step sequence. • The strip length and cutter depth information is programmed into the machine via the touch sensitive visual display, and no longer requires the adjustment of spacer blocks. This development also has the advantage of allowing semi-strip operations to be processed on the machine. • The in-out position of the stripped wire in relationship with the crimping position is adjustable via the touch sensitive screen, this feature eliminates manually moving the press forwards and backwards to obtain the correct wire placement in the terminal. • The ATM-4 has a memory function enabling the set-up specifications of 250 jobs to be stored in the memory, so that frequently used set-ups can be recalled without re-setting the machine. • The MCB-2 crimping presses on the ATM-4 have been developed to incorpoate electromagnetic clutches which have the advantage of reducing noise generated by the machine. 16 Crimping tools and machines Applicator for fully automatic machine Extraction and Insertion tools Hand tools Terminal model No. Applicator Die set YRS series YC series — — — YC-690R — — — — YC-251 BXF-01T-(P)0.7 LEJ-7 — — BXA-001T-P0.6 — Extraction tool EJ-XMP — Insertion tool IT-XA — AMKS-L AMK-DS SXF01-07 AMKS-L AMK-DS SXF41-07 — YC-252 BXF-41T-(P)0.7 LEJ-7 — AMKS-L AMK-DS SXH001-06 YRS-110 YC-110R BXH-001T-P0.7 XJ-06 — AMKS-L AMK-DS SXH002-06 YRS-480 — — XJ-06 — — — — YC-690R BXM-001T-P0.6 EJ-XMR — AMKS-L AMK-DS SYF001-06 — — — AMKS-L AMK-DS SYF/M01-05 — YC-520 BYF/M-01T-P0.5 YLJ-0.5 — AMKS-L AMK-DS SYF/M41-05 — YC-530 BYF/M-41T-P0.5 YLJ-0.5 — AMKS-L AMK-DS SYM001-06 — YC-121R BYM-001T-(P)0.6 SMJ-06 — AMKS-L AMK-DS SYM01-07 — YC-251 BYM-01T-(P)0.7 LEJ-7 — AMKS-L AMK-DS SYM41-07 — YC-252 BYM-41T-(P)0.7 LEJ-7 — AMKS-L AMK-DS SZF/M01-07 — YC-390R BZF/M-01T-(P)0.7 ZLJ-07(S) — AMKS-L AMK-DS SZF/M41-07 — YC-380R BZF/M-41T-(P)0.7 ZLJ-07(S) — AMKS-L AMK-DS SZH002-05 — — — — — AMKS-L AMK-DS SZH003-05 YRS-490 — — — — AMKS-L AMK-DS SZN002-07 — — — — — AMKS-L AMK-DS SZN003-07 YRS-540 — — — — — — ATM-4 Specifications ––––––––––––––––––– Productivity The productivity of the ATM-4 is dependent on the length of the wires to be processed. Production rate(leads per minute, using standard viny I wire) Length mm(in.) 70 (2.756) 100 (3.937) 200 (7.874) Speed 84 83 80 300 500 750 1000 (11.811) (19.685) (29.528) (39.370) 69 59 54 50 1500 2000 2500 3000 3500 (59.055) (78.740) (98.425) (118.100) (137.795) 45 41 37 35 32 • Dimensions: (WXLXH)1,800X2,300 X1,840mm(71" X91" X59") • Weight: 1,050kg • Power source: 415V AC, 3-phase, 50/60Hz • Pneumatic supply: 5kg/cm2 • Maximum crimping capacity:5,100 wires/hour • Cutting length: 80 to 20,000mm(3.150" to 787.4") (Note1) • Wire lenght accuracy: ±1.0mm(.039") on programmed length • Strip length: 2 to 13mm(.079" to .512")(front end) 2 to 18mm(.079" to .709")(rear end) Note1: It may be possible to process shorter lengths than 80mm depending on the wire type. Contact JST for details. 17
MKDSSCS4123 价格&库存
很抱歉,暂时无法提供与“MKDSSCS4123”相匹配的价格&库存,您可以联系我们找货
