PLASTIC
CONNECTORS
Precision modular connectors to suit your application
Since its creation in Switzerland in 1946 the LEMO Group has been recognized as a global leader of circular Push-Pull
connectors and connector solutions. Today LEMO and its affiliated companies, REDEL and COELVER, are active in more than
80 countries with the help of over 40 subsidiaries and distributors.
Over 5’000 REDEL connectors
The modular design of the REDEL range provides over 5’000 connectors from ø 14 mm to ø 21 mm, capable of handling cable
diameters up to 9.5 mm and up to 32 contacts.
This vast portfolio enables you to select the ideal connector configuration to suit almost any specific requirement in most
markets, including medical devices, test and measurement instruments, machinery, audio video broadcast, telecommunications and military.
REDEL’s Push-Pull Self-Latching Connection System
This self-latching system is renowned worldwide for its easy and quick mating and unmating features. It provides absolute
security against vibration, shock or pull on the cable, and facilitates operation in a very limited space.
Fv 7 N
The REDEL self-latching system allows the
connector to be mated by simply pushing
the plug axially into the socket.
Fv: average latching force (without contact)
Fa 110 N
Once firmly latched, connection cannot be
broken by pulling on the cable or any other
component part other than the outer release
sleeve.
Fa: average retention force (without contact)
Fd 9 N
When required, the connector is disengaged
by a single axial pull on the outer release
sleeve. This first disengages the latches and
then withdraws the plug from the socket.
Fd: average unmating force (without contact)
UL Recognition
REDEL connectors are recognized by the Underwriters Laboratories (UL). The approval of the complete system (REDEL
connector, cable and your equipment) will be easier because REDEL connectors are approved.
CE Marking
CE marking
means that the appliance or equipment bearing it complies with the protection requirements of one or
several European safety directives.
CE marking
applies to complete products or equipment, but not to electromechanical components, such as
connectors.
RoHS
REDEL connector specifications exceed the requirements of the RoHS directives (2002/95/EC) of the European Parliament
and the latest amendments. This directive specifies the restrictions of the use of hazardous substances in electrical and electronic
equipment marketed in Europe. LEMO guarantees that its connectors are free of mercury, cadmium, lead, hexavalent chromium
and polybromide biphenyl (PBB), polybromide diphenyl ether (PBDE), or DecaBDE.
Cover picture: PET-IRM scanner installed in Hôpitaux Universitaires de Genève (Switzerland).
www.lemo.com
Exploded view of the REDEL XP
Straight plug
backnut
insulator + contacts
cable collet
shell
Straight plug with bend relief
bend relief
backnut for
a bend relief
shell
cable collet
Fixed socket
collet nut
notched nut
shell
front nut
Free socket
backnut
www.lemo.com
cable collet
shell
1
XP Series
The REDEL XP connectors are plastic Push-Pull connectors. These circular plastic connectors are especially adapted for
applications such as medical electronics and test & measurement. The XP series offer additional features: the latch sleeve
is recessed into the connector body ensuring greater shock resistance of the product.
The complete connector can be assembled from spare parts (even the contact configuration) therefore offering good
flexibility in stock keeping. The outer shell in Proprietary sulfone enables extensive sterilisation cycles of the product. A large
choice of bend relief is available in different colour and size. REDEL XP series connectors are not compatible with the REDEL
1P or 2P series.
Features & Benefits
– Plastic shell made of Proprietary sulfone
– Blind mating, scoop proof
– Extended resistance to sterilisation
– Enhanced ergonomics «hand grip»
– Increased resistance to shock
– New patented Push-Pull system
– UL recognized (file E119802)
Applications
– Medical electronics
– Test & measurement
– Industrial electronics
Standard models
Straight plugs
Fixed sockets
XA●
XL●
XA●
XK●
Free sockets
XR●
XR●
XK●
2
www.lemo.com
Part numbering system
X
Plug
X A N
M 1
3
G L A
6 G
.M
Variant
Z = cable collet and nut
for fitting a bend relief
Collet nut colour table: (page 7)
Model: (pages 4-5)
G = grey
A = blue
J = yellow
Keying: (page 6)
Contact configuration (page 6)
Collet: 3 = (cable ø 2.5 mm - 3.9 mm)
5 = (cable ø 4.0 mm - 5.2 mm)
6 = (cable ø 5.3 mm - 6.5 mm)
7 = (cable ø 6.6 mm - 7.5 mm)
Number of contacts: (page 6)
Outershell colour: G = grey
N = black
B = white
Contact type: (page 7)
Insulator: L = PEEK
A = male to solder
C = male to crimp
Free socket
N = black
R = red
V = green
B = white
X R N
M 1
3
G L L
6 G
L = female to solder 1)
M = female to crimp 1)
Variant
Model: (pages 4-5)
G = grey
A = blue
J = yellow
Keying: (page 6)
N = black
B = white
Insulator: L = PEEK
A = male to solder 1)
C = male to crimp 1)
Fixed socket
N = black
R = red
V = green
B = white
X K N
M 1
3
G L
M = female to crimp
L G
Front nut colour table: (page 7)
Model: (pages 4-5)
Keying: (page 6)
N = black
B = white
G = grey
A = blue
J = yellow
N = black
R = red
V = green
B = white
D = male to print 1)
M= female to crimp
N = female to print
V = female 90° for print
Insulator: L = PEEK
XAN.M13.GLA.6G Straight plug with cable collet and alignment key (N), multipole type with 13 male contacts to solder, grey
Proprietary sulfone shell, PEEK insulator, collet for max cable ø 6.5 mm and grey collet nut.
XRN.M13.GLL.6G Free socket with cable collet and alignment key (N), multipole type with 13 female contacts to solder, grey
XKN.M13.GLLG Fixed socket with two nuts and alignment key (N), multipole type with 13 female contacts to solder, grey
Proprietary sulfone shell, PEEK insulator and grey plastic front nut.
Note: 1) contacts delivered only with S or T keying (inverted contacts).
www.lemo.com
3
Standard models (IP50)
.M
X
Fixed socket
Straight plug
6
2
4
3
5
5
1
4
2
1
6
3
1 Outershell
1 Outershell
2 Insulator
2 latch sleeve
3 Female contact
3 Backnut
4 Notched nut
4 Insulator
5 Front nut
5 Contact
6 Collet nut
6 Cable collet
Value
Standards
Average retention force when
pulling on the cable 1N = 0.102 kg
110
IEC 60512-8 test 15f
Cable retention force (depends on
cable construction) 1N = 0.102 kg
~130
Characteristics
XAN
Characteristics
Endurance (latching)
Working temperature range
(Proprietary sulfone)
Value
Standards
> 1000 cycles
IEC 60512-5 test 9a
-50/+170°C
IEC 60512-9 test 17c
Straight plug, key (N) or keys (P, S and T), with cable collet
Part Number
XAN.M••.GLA.3G
XAN.M••.GLA.5G
XAN.M••.GLA.6G
XAN.M••.GLA.7G
Cable ø
min
max
2.5
4.0
5.3
6.6
3.9
5.2
6.5
7.5
Note: replace •.• by contact configuration (see page 6).
ø 16.5
~46
XAN
Straight plug, key (N) or keys (P, S and T), with cable collet and nut for fitting a bend relief
Part Number
XAN.M••.GLA.3GZ
XAN.M••.GLA.5GZ
XAN.M••.GLA.6GZ
XAN.M••.GLA.7GZ
Cable ø
min
max
2.5
4.0
5.3
6.6
3.9
5.2
6.5
7.5
The bend relief must be ordered separately (see page 10).
ø 16.5
~48.0
XLN
Fixed socket, key (N) or keys (P, S and T), nut fixing
a
Part Number
23.5
5.2
XLN.M••.GLLG
Contact
Solder
Crimp
a max (mm)
a (mm)
2.2
ø 18.5
M14 x 1
S12.5
7.5 maxi
Note: all dimensions are in millimeters.
4
www.lemo.com
X
XKN
.M
Fixed socket, key (N) or keys (P, S and T) with two nuts (back panel mounting)
a
Part Number
23.5
3
4
Contact
Solder
Crimp
a max (mm)
a (mm)
XKN.M••.GLLG
ø 18.5
M14 x 1
Fixed socket, key (N) or keys (P, S and T) with two nuts (back panel mounting) and with straight print contact
a
Part Number
23.5
3
4
Contact
Solder
Crimp
a max (mm)
a (mm)
XKN.M••.GLNG
4.1
ø 18.5
M14 x 1
S12.5
XRN
8.5 maxi
S12.5
XKN
2.2
8.5 maxi
Free socket, key (N) or keys (P, S and T), with cable collet
Part Number
XRN.M••.GLL.3G
XRN.M••.GLL.5G
XRN.M••.GLL.6G
XRN.M••.GLL.7G
Cable ø
min
max
2.5
4.0
5.3
6.6
3.9
5.2
6.5
7.5
ø 15.7
~44.7
XRN
Free socket, key (N) or keys (P, S and T), with cable collet and nut for fitting a bend relief
Part Number
XRN.M••.GLL.3GZ
XRN.M••.GLL.5GZ
XRN.M••.GLL.6GZ
XRN.M••.GLL.7GZ
Cable ø
min
max
2.5
4.0
5.3
6.6
3.9
5.2
6.5
7.5
ø 15.7
~46.7
www.lemo.com
5
Alignment key
X
.M
Verify the third digit of the part number in order to select the right keying. The standard keying is «N» coded.
30°
60°
50°
90°
N
P
S
male
female
male
female
Keying (plug front view)
Reference
Contact type for plug
Contact type for socket
T
female
male
female
male
Insert configuration
Contact
type
Female solder contacts
Air clearance min 2) (mm)
Creepage distance min 3) (mm)
Rated current (A)
Test voltage (kV rms)1)
Contact-contact
Rated current (A)
Female crimp contacts
Contact-contact
3
Print (elbow)
4
Solder / Crimp / Print (straight)
1
M04
4
1.3
1.10
1.40
184)
1.60
0.95
11.5
1.80
1.35
11.5
M06
6
0.9
0.80
1.10
24
1.50
0.95
8.5
1.90
1.35
8.5
M08
8
0.9
0.80
1.10
24
1.50
0.75
5.0
1.50
1.1
5.0
M10
10
0.7
0.80
0.80
22 4)
24
26
1.16
0.70
4.2
1.53
1.1
4.2
M13
13
0.7
0.80
0.80
22 4)
24
26
1.05
0.50
4.0
1.30
0.9
4.0
M16
16
0.5
0.45
0.45
28
30
32
0.75
0.45
3.0
1.35
0.8
3.0
M18
18
0.5
0.45
0.45
28
30
32
0.74
0.47
2.5
1.16
0.8
2.5
M22
22
0.5
0.45
0.45
28
30
32
0.60
0.40
2.0
1.30
0.8
2.0
AWG max-min
6
Crimp bucket ø (mm) 4)
4
Solder bucket ø (mm) 4)
3
Crimp
Contact ø A (mm)
6
Solder
Number of contacts
Multipole
Male crimp contacts
1
.M
Reference
øA
øA
Male solder contacts
X
Note: 1) depending on specific application and related standard, more restrictive operating voltage may apply. We suggest operating voltage = 1/3 test voltage, see page 15.
2) shortest distance in air between two conductive parts.
3) shortest distance along the surface of the insulating material between two conductive parts.
4) for a given AWG, the diameter of some stranded conductor design is larger than the solder cup diameter (see page 14).
6
www.lemo.com
Outer shell material
Proprietary
sulfone
Ref.
Material
X
Colour
Temperature
G
N
B
Grey
Black
White
-50° / +170°C
.M
.M
Note: adapted for sterilisation satured steam (120°C or 134°C).
Contact type
X
Select the type of contact: solder or crimp?
When should I use crimp rather than solder contacts ?
Plug
Soldering
• recommended for small volumes
• requires little amount of tooling (soldering iron)
• requires more time
Socket
Type
solder
crimp
Male
Female
A
C
L1)
M1)
Type
solder
crimp
print
print 90°
Male
Female
A1)
D1)
L
M
N
V
Crimping
• recommended for large volumes
• no heat is required to make the connection
• for contacts with high density
• for use in high temperature environment (max. 170°C)
• requires extra tooling (crimping tools)
Note: 1) only for S or T keying.
Colour coding
Reference
RAL code
grey
G
7001
blue
A
5015
X
yellow
J
1016
Colours
black
N
9005
red
R
3020
green
V
6019
white
B
9003
.M
Note: the RAL colours are indicative and depend on raw material and production process.
Colour may differ.
Easy identification with the assistance of colour coding. Outershell is only available in grey, black or white.
www.lemo.com
7
Accessories
XAN / XLN
Insulator and male or female crimp contacts
Contact
nb. of
configuration contacts
ø contact
(mm)
Kit contact part
number
Male
male / black marking
XAN / XLN
M04
M06
M08
M10
M13
M16
M18
M22
female / black marking
4
6
8
10
13
16
18
22
1.3
0.9
0.9
0.7
0.7
0.5
0.5
0.5
XAN.M04.ZLC
XAN.M06.ZLC
XAN.M08.ZLC
XAN.M10.ZLC
XAN.M13.ZLC
XAN.M16.ZLC
XAN.M18.ZLC
XAN.M22.ZLC
Female
XLN.M04.ZLM
XLN.M06.ZLM
XLN.M08.ZLM
XLN.M10.ZLM
XLN.M13.ZLM
XLN.M16.ZLM
XLN.M18.ZLM
XLN.M22.ZLM
Insulator with male or female solder contacts
Contact
nb. of
ø contact
(mm)
Kit contact part
number
Male
XAl.100.lZZ
Kit contact part
number
M04
M06
M08
M10
M13
M16
M18
M22
4
6
8
10
13
16
18
22
1.3
0.9
0.9
0.7
0.7
0.5
0.5
0.5
XAN.M04.ZLA
XAN.M06.ZLA
XAN.M08.ZLA
XAN.M10.ZLA
XAN.M13.ZLA
XAN.M16.ZLA
XAN.M18.ZLA
XAN.M22.ZLA
Kit contact part
number
Female
XLN.M04.ZLL
XLN.M06.ZLL
XLN.M08.ZLL
XLN.M10.ZLL
XLN.M13.ZLL
XLN.M16.ZLL
XLN.M18.ZLL
XLN.M22.ZLL
Plug outershell kit (no contacts)
Part Number
Colours
~36
XA•.100.GZZ
XA•.100.BZZ
XA•.100.NZZ
grey
white
black
Note: replace • by alignment key (N, P, S or T).
XRl.200.ll
Free socket outershell kit (no contacts)
Part Number
~35
XR•.200.RG
XR•.200.RB
XR•.200.RN
Colours
grey
white
black
XLl.200.lZZl Socket outershell kit (nut fixing), (no contacts)
Part Number
Colours
ø 18.5
23.5
8
XL•.200.GZZG
XL•.200.BZZB
XL•.200.NZZN
grey
white
black
www.lemo.com
XKl.200.lZZl Socket outershell kit (with two nuts), (no contacts)
Part Number
Colours
23.5
ø 18.5
XK•.200.GZZG
XK•.200.BZZB
XK•.200.NZZN
XAN
Collet
Part Number
21.5
XAN.739.RG
XAN.752.RG
XAN.765.RG
XAN.775.RG
max ø 9.8
XAM.130.ll
Cable ø (mm)
min. max.
2.5
4.0
5.3
6.6
3.9
5.2
6.5
7.5
Nut for fitting a GMA.1B bend relief
Part Number
ø 10
ø 12.5
20.3
XLN
grey
white
black
XAM.130.RG
XAM.130.RB
XAM.130.RN
Colours
grey
white
black
Note: only for XA•, XR• models.
Notched nut
Part Number
18.5
M14 x 1
4
XLN.240.RG
Colours
grey
XLN
Collet nut
M11 x 0.75
Part Number
4.5
XLN.230.RG
Colours
grey
12.5
XLN
Plastic front nut for XLl models
Part Number
18.5
M14 x 1
www.lemo.com
5.2
XLN.220.RG
XLN.220.RB
XLN.220.RR
XLN.220.RN
XLN.220.RJ
XLN.220.RA
XLN.220.RV
Colours
grey
white
red
black
yellow
blue
green
9
XKN
Plastic front nut for XKl models
Part Number
18.5
M14 x 1
GMA.1B
XKN.220.RG
XKN.220.RB
XKN.220.RR
XKN.220.RN
XKN.220.RJ
XKN.220.RA
XKN.220.RV
4
Colours
grey
white
red
black
yellow
blue
green
Bend relief
A bend relief absorbs the angular force that may be exerted on
cables.
These are designed for plugs and free sockets with cable collet and nut.
The Colours of these bend reliefs are not identical to the RAL
coulours of the socket’s front nut.
øA
L
Part Number
Dimensions (mm)
Bend relief
Cable ø
A
L
max. min.
GMA.1B.025.DG
GMA.1B.030.DG
GMA.1B.035.DG
GMA.1B.040.DG
GMA.1B.045.DG
GMA.1B.054.DG
GMA.1B.065.DG
2.5
3.0
3.5
4.0
4.5
5.4
6.5
30
30
30
30
30
30
30
2.9
3.4
3.9
4.4
4.9
6.0
7.0
2.5
3.0
3.5
4.0
4.5
5.4
6.5
GMA.1B.025.RG
GMA.1B.030.RG
GMA.1B.035.RG
GMA.1B.040.RG
GMA.1B.045.RG
GMA.1B.051.RG
GMA.1B.057.RG
GMA.1B.063.RG
2.5
3.0
3.5
4.0
4.5
5.1
5.7
6.3
34
34
34
34
34
34
34
34
2.9
3.4
3.9
4.4
5.0
5.6
6.2
7.0
2.5
3.0
3.5
4.0
4.5
5.1
5.7
6.3
Temperature range
Material
Desmopan
786
Polyurethane
elastomer
Silicone
elastomer
VMQ
in dry atmosphere
in water steam
-40°C, +80°C
-60°C, +200°C
+140°C
Reference
Colours
A
B
G
J
M
N
R
S
V
blue
white
grey
yellow
brown
black
red
orange
green
Note: the selection of pigments, which should
remain stable at high temperature, is limited
by the new regulations. For this reason, some
colours will be a shade different from those
used for Desmopan bend reliefs.
The selected solutions represent the best possible compromise.
Note: the last letter «G» of the part number indicates a grey colour, see the adjacent table and replace letter «G» by the letter of the colour required.
All dimensions are in millimeters.
10
www.lemo.com
Tooling
XOP.019.HN
Spanners with notch for securing
the notched nut
XOB.186.GN
XOB.187.GN
Spanners for nut XLN.220Rl
Spanners for nut XKN.220Rl
ø 20
76.7
30
28
Material: Black polyamide. For notched nut XLN.240.RG.
DPC.91.701.V
XOE
Crimping tool
Positioners for crimp contacts
male
DCF
female
Automatic extraction tools for crimp contacts
Configuration
M04
M06/M08
M10/M13
M16/M18/M22
Contact ø
(mm)
Conductor
AWG
1.3
0.9
0.7
0.5
18-20
20-22-24
22-24-26
28-30-32
Positioner part number
Male contact
Female contact
XOE.130.VC
XOE.090.VC
XOE.070.VC
XOE.050.VC
XOE.130.VM
XOE.090.VM
XOE.070.VM
XOE.050.VM
Selector No
Setting
6-5-5
6-5-5
6-5-5
4-3-3
Part number extractor
Male contact
DCF.93.131.4LT
DCF.93.090.4LT
DCF.93.070.4LT
DCF.91.050.2LT1)
Female contact
DCF.93.131.4LT
DCF.93.090.4LT
DCF.93.070.4LT
DCF.91.050.2LT1)
Note: the variance in conductor stranding diameter for the minimum AWG is such that some can have a cross section which is not sufficient to guarantee crimping as per
IEC 60352-2 standard.
1) With this extractor, the user must remove the insulator from the outer shell.
www.lemo.com
11
Panel hole
For XLl and XKl
ø 14.0 + 0.1
12.6 ± 0.05
Note: Socket mounting nut torque = 1 Nm.
23.5 min.
PCB drilling pattern
+ 0.1
0.65
1.5
M10
1.32
M08
M13
16 x ø 0.6
+ 0.1
M16
1.4
18 x ø 0.6
1.6
1.7
0.65
M18
1.7
0.65
22 x ø 0.6
+ 0.1
+ 0.1
0.66
1.65
1.3
1.6
1.65
1.3
1.6
+ 0.1
1.1
10 x ø 0.8
1.74
1.78
13 x ø 0.8
2.1
1.1
2.1
1.35
1.5
1.32
1.3
1.6
1.5
1.81
0.67
1.97
8 x ø 0.8
1.97
1.2
M06
0.87
2.1
2.65
1.2
0.66
+ 0.1
6 x ø 0.8
M04
1.78
2.65
2.4
2.4
1.1
1.6
1.1
0.8
+ 0.1
4 x ø 0.8
0.8
2.3 2.3
0.8
1.35
For straight contacts
1.81
0.67
M22
12
www.lemo.com
Assembly instructions
Solder contacts / Crimp contacts
➀
➁
➂
➄ ➅
➆
1. Slide the collet nut ➀ and then the collet ➁ onto the cable.
L
Configuration
Dimensions (mm)
Solder contacts
Crimp contacts
L
T
L
T
M04
M06, M08
M10, M13
11.5
13.0
13.0
3.5
3.0
3.0
15.0
15.0
15.0
3.5
3.5
3.5
M16 to M22
12.5
2.5
14.5
2.5
2. Strip the cable according to the lengths given in the table.
Tin the conductors.
T
3. Solder conductors into contacts, starting with the center
contacts, making sure that neither solder nor flux gets onto
the insulator or cable insulation.
solder / crimp
Fix the appropriate positioner in the crimping tool. Set
selector to the number corresponding to the conductor
AWG as indicated on the positioner label. Fit conductor
into contact and make sure it is visible through the inspection hole in the crimp barrel. Slide conductor-contact combination into the open crimping tool; make sure that the
contact is fully pushed into the positioner. Close the tool.
Remove from crimping tool and check that conductor is
secure in contact and shows in inspection hole.
4. Slide the collet ➁ forward and locate both tags ➂ in the
slots ➄ on the insulator ➅.
Push collet ➁ and insulator ➅ assembly into the shell ➆
whilst turning it to ensure that the tag ➂ locates in the
inside slot of the shell.
5. Slide collet nut ➀ over collet ➁ and tighten the collet nut ➀
to the maximum torque of 0.3 Nm.
– Socket mounting nut torque = 1 Nm.
www.lemo.com
13
Technical tables
Table of American Wire Gauge
Construction
AWG
2
4
6
8
8
10
10
10
12
12
12 1)
12
14
14
14 1)
14
16 1)
16
16
16 1)
16
18 1)
18 1)
18
18
18
18
20 1)
22
22
24 1)
24
24
24
26
26
26
28 1)
28
28
30
30
32
32
34
36
38
40
14
Table of wire gauges according to IEC-60228 standard
ø wire max
Wire section
Strand
nb
AWG/
strand
(mm)
(in)
(mm2)
(sq in)
259
817
259
133
133
168
133
105
37
1
37
19
7
1
41
19
7
1
65
26
19
7
1
65
42
19
16
7
1
42
19
10
7
1
19
7
1
42
19
7
1
19
7
1
19
7
1
7
1
7
1
1
1
1
1
24
30
26
25
27
30
29
30
26
10
28
25
30
27
22
14
34
30
29
24
16
36
34
30
30
26
18
36
32
30
28
30
22
40
36
32
24
38
34
26
40
36
28
38
30
40
32
34
36
38
40
11.277
9.702
8.89
6.9596
5.5118
4.4450
4.3942
3.3020
2.9210
2.6162
2.3114
2.3622
2.5400
2.0828
2.0574
1.8542
2.0828
1.6510
1.5748
1.5748
1.4986
1.5494
1.3208
1.2700
1.2700
1.3208
1.2954
1.2700
1.0414
1.0160
1.0414
1.0160
0.9906
0.8382
0.8382
0.7874
0.6604
0.6604
0.6858
0.6350
0.5588
0.5588
0.5080
0.4318
0.4318
0.4064
0.3302
0.3302
0.2794
0.2794
0.2286
0.1693
0.127
0.1016
0.078
0.444
0.382
0.35
0.274
0.217
0.175
0.173
0.13
0.115
0.103
0.091
0.093
0.10
0.082
0.081
0.073
0.082
0.065
0.062
0.062
0.059
0.061
0.052
0.05
0.05
0.052
0.051
0.05
0.041
0.04
0.041
0.04
0.039
0.033
0.033
0.031
0.026
0.026
0.027
0.025
0.022
0.022
0.02
0.017
0.017
0.016
0.013
0.013
0.011
0.011
0.009
0.007
0.005
0.004
0.003
52.90
41.40
33.20
21.5925
13.5885
8.5127
8.6053
5.3204
4.7397
5.2614
2.9765
3.0847
3.6321
3.3081
2.0775
1.9413
2.2704
2.0820
1.3072
1.3174
1.2293
1.4330
1.3076
0.8234
0.8447
0.9627
0.8107
0.8967
0.8229
0.5320
0.6162
0.5067
0.5631
0.5189
0.3821
0.3547
0.3243
0.2045
0.2407
0.2270
0.2047
0.1540
0.1408
0.1281
0.0925
0.0887
0.0804
0.0568
0.0507
0.0341
0.0324
0.0201
0.0127
0.0081
0.0049
0.0820
0.0641
0.0514
0.0335
0.0211
0.0132
0.0133
0.0082
0.0073
0.0082
0.0046
0.0048
0.0056
0.0051
0.0032
0.0030
0.0035
0.0032
0.0020
0.0020
0.0019
0.0022
0.0020
0.0013
0.0013
0.0015
0.0013
0.0014
0.0013
8.2x10-4
0.0010
7.9x10-4
8.7x10-4
8.0x10-4
5.9x10-4
5.5x10-4
5.0x10-4
3.2x10-4
3.7x10-4
3.5x10-4
3.2x10-4
2.4x10-4
2.2x10-4
2.0x10-4
1.4x10-4
1.4x10-4
1.2x10-4
8.8x10-5
7.9x10-5
5.3x10-5
5.0x10-5
3.1x10-5
2.0x10-5
1.3x10-5
7.5x10-6
Conductor no
x ø (mm)
196x0.40
7x2.14
125x0.40
7x1.72
1x4.50
80x0.40
7x1.38
1x3.60
84x0.30
7x1.50
1x2.76
56x0.30
7x0.86
1x2.25
50x0.25
7x0.68
1x1.78
30x0.25
7x0.52
1x1.4
32x0.20
7x0.43
1x1.15
42x0.15
28x0.20
1x1.0
28x0.15
16x0.20
1x0.80
7x0.25
1x0.60
14x0.15
7x0.20
18x0.10
14x0.10
21x0.07
14x0.10
Max ø
(mm)
Max ø
(in)
Section
(mm2)
Section
(sq in)
7.50
6.10
6.00
4.90
4.50
4.70
3.95
3.60
3.70
3.15
2.76
2.80
2.58
2.25
2.15
2.04
1.78
1.60
1.56
1.40
1.35
1.29
1.15
1.20
1.15
1.00
0.95
0.90
0.80
0.75
0.60
0.75
0.65
0.50
0.40
0.40
0.40
0.295
0.240
0.236
0.192
0.177
0.155
0.155
0.141
0.145
0.124
0.108
0.110
0.098
0.082
0.084
0.080
0.070
0.062
0.061
0.055
0.053
0.050
0.045
0.047
0.045
0.039
0.037
0.035
0.031
0.029
0.023
0.029
0.023
0.019
0.015
0.015
0.015
25.00
25.00
16.00
16.00
16.00
10.00
10.00
10.00
6.00
6.00
6.00
4.00
4.00
4.00
2.50
2.50
2.50
1.50
1.50
1.50
1.00
1.00
1.00
0.75
0.75
0.75
0.50
0.50
0.50
0.34
0.28
0.25
0.22
0.14
0.11
0.09
0.09
0.0387
0.0387
0.0248
0.0248
0.0248
0.0155
0.0155
0.0155
0.0093
0.0093
0.0093
0.0062
0.0062
0.0062
0.0038
0.0038
0.0038
0.0023
0.0023
0.0023
0.0015
0.0015
0.0015
0.0011
0.0011
0.0011
7.7x10-4
7.7x10-4
7.7x10-4
5.2x10-4
4.3x10-4
3.8x10-4
3.4x10-4
2.1x10-4
1.7x10-4
1.3x10-4
1.3x10-4
Note: 1) not included in the standard
www.lemo.com
Product safety notice
PLEASE READ AND FOLLOW ALL INSTUCTIONS CAREFULLY AND CONSULT ALL RELEVENT NATIONAL AND
INTERNATIONAL SAFETY REGULATIONS FOR YOUR APPLICATION.
IMPROPER HANDLING, CABLE ASSEMBLY, OR WRONG USE OF CONNECTORS CAN RESULT IN HAZARDOUS
SITUATIONS.
1. SHOCK AND FIRE HAZARD
Incorrect wiring, the use of damaged components, presence of foreign objects (such as metal debris), and / or residue
(such as cleaning fluids), can result in short circuits, overheating, and / or risk of electric shock.
Mated components should never be disconnected while live as this may result in an exposed electric arc and local
overheating, resulting in possible damage to components.
2. HANDLING
Connectors and their components should be visually inspected for damage prior to installation and assembly. Suspect
components should be rejected or returned to the factory for verification.
Connector assembly and installation should only be carried out by properly trained personnel. Proper tools must be used
during installation and / or assembly in order to obtain safe and reliable performance.
3. USE
Connectors with exposed contacts should never be live (or on the current supply side of a circuit). Under general
conditions voltages above 30 VAC and 42 VDC are considered hazardous and proper measures should be taken to
eliminate all risk of transmission of such voltages to any exposed metal part of the connector.
4. TEST AND OPERATING VOLTAGES
The maximum admissible operating voltage depends upon the national or international standards in force for the
application in question. Air and creepage distances impact the operating voltage; reference values are indicated in the
catalog however these may be influenced by PC board design and / or wiring harnesses.
The test voltage indicated in the catalog is 75% of the mean breakdown voltage; the test is applied at 500 V/s and the
test duration is 1 minute.
5. CE MARKING
CE marking
CE marking
connectors.
6. PRODUCT IMPROVEMENTS
The LEMO Group reserves the right to modify and improve to our products or specifications without providing prior
notification.
www.lemo.com
15
Notes
16
www.lemo.com
LEMO complete product range
B
S
K
E
F
00
01
0A
3T
4A
4M
3K.
1D
93C
Y
05
5G
2G
2C
L
H
M
R
N
03
V
W
F
P
D
K/S
01 DIN
Unipole
Multipole
Coaxial 50 Ω
Coaxial 75 Ω
Multi Coaxial
Mixed Coax + LV
Triaxial 50 Ω
Triaxial 75 Ω
Mixed Triax + LV
Quadrax
High Voltage
Multi High Voltage
Mixed HV + LV
Fibre Optic
Multi Fibre Optic
Mixed FO + LV
Thermocouple
Fluidic
Multi Fluidic
Mixed Fluidic + LV
Most frequently used in darker colour
B Series Keyed
S Series
K Series Keyed
E Series
F Series Keyed
00 Series
01 Series
0A Series
3T Series
4A Series
4M Series Keyed
3K.93C Series Keyed
1D Series
Y Series
05 Series
5G Series Keyed
2G Series Keyed
2C Series
L Series Keyed
H Series
M Series Keyed
R Series Keyed
N Series Keyed
03 Series Keyed
V Series
W Series Keyed
Cable assembly
K/S Series Keyed
REDEL F Series
P REDEL Series Keyed
D REDEL Series
01 Series Keyed
VAA Series
SAA Series
TAA Series
No reproduction or use without express permission of editorial or pictorial content, in any manner.
LEMO SA reserves the right to modify and improve specifications, at all times, without any notification.
LEMO HEADQUARTERS
SWITZERLAND
LEMO SA
Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens
Tel. (+41 21) 695 16 00 - Fax (+41 21) 695 16 02 - e-mail: info@lemo.com
SUBSIDIARIES
AUSTRIA
LEMO Elektronik GesmbH
Lemböckgasse 49/E6-3
1230 Wien
Tel: (+43 1) 914 23 20 0
Fax:(+43 1) 914 23 20 11
sales@lemo.at
NETHERLANDS / BELGIUM
LEMO Connectors Benelux
De Trompet 2108
1967 DC Heemskerk
Tel. (+31) 251 25 78 20
Fax (+31) 251 25 78 21
info@lemo.nl
CHINA
LEMO Trading (Shanghai) Co., Ltd
LEMO Electronics (Shanghai) Co., Ltd
5th Floor, Block 6, City of ELITE,
1000 Jinhai Road, Pudong
Shanghai, China 201206
Tel: (+86 21) 5899 7721
Fax: (+86 21) 5899 7727
cn.sales@lemo.com
NORWAY / ICELAND
LEMO Norway A/S
Stanseveien 6B
0975 Oslo
Tel: (+47) 22 91 70 40
Fax: (+47) 22 91 70 41
info-no@lemo.com
DENMARK
LEMO Denmark A/S
Gammel Mosevej 46
2820 Gentofte
Tel: (+45) 45 20 44 00
Fax: (+45) 45 20 44 01
info-dk@lemo.com
FRANCE
LEMO France Sàrl
24/28 Avenue Graham Bell
Bâtiment Balthus 4
Bussy Saint Georges
77607 Marne la Vallée Cedex 3
Tel: (+33 1) 60 94 60 94
Fax: (+33 1) 60 94 60 90
info-fr@lemo.com
GERMANY
LEMO Elektronik GmbH
Hanns-Schwindt-Str. 6
81829 München
Tel: (+49 89) 42 77 03
Fax: (+49 89) 420 21 92
info@lemo.de
HONG KONG
LEMO Hong Kong Ltd
Unit 1207, 12/F, Corporation Square,
8 Lam Lok Street, Kowloon Bay,
Kowloon - Hong Kong
Tel: (+852) 2174 0468
Fax: (+852) 2174 0492
hk.sales@lemo.com
HUNGARY
REDEL Elektronika Kft
Nagysándor József u. 6-12
1201 Budapest
Tel: (+36 1) 421 47 10
Fax: (+36 1) 421 47 57
redelemo@lemo.hu
ITALY
LEMO Italia srl
Viale Lunigiana 25
20125 Milano
Tel: (+39 02) 66 71 10 46
Fax: (+39 02) 66 71 10 66
sales.it@lemo.com
JAPAN
LEMO Japan Ltd
4-10-3, Takaido Higashi,
Suginami-ku, Tokyo, 168-0072
Tel: (+81 3) 53 44 39 33
Fax: (+81 3) 53 44 39 35
lemoinfo@lemo.co.jp
LEMO
SINGAPORE
LEMO Asia Pte Ltd
4 Leng Kee Road,
#06-09 SiS Building
Singapore 159088
Tel: (+65) 6476 0672
Fax: (+65) 6474 0672
sg.sales@lemo.com
SPAIN / PORTUGAL
IBERLEMO S.A.
Brasil, 45, 08402 Granollers
Barcelona
Tel: (+34 93) 860 44 20
Fax: (+34 93) 879 10 77
info-es@lemo.com
Madrid Office
Antonio López, 96, 28019 Madrid
Tel: (+34 91) 469 99 19
Fax: (+34 91) 469 99 59
SWEDEN / FINLAND
LEMO Nordic AB
Mariehällsvägen 39A
168 65 Bromma
Tel: (+46 8) 635 60 60
Fax: (+46 8) 635 60 61
info-se@lemo.com
SWITZERLAND
LEMO Verkauf AG
Grundstrasse 22 B
6343 Rotkreuz
Tel: (+41 41) 790 49 40
Fax: (+41 41) 790 49 43
ch.sales@lemo.com
UNITED KINGDOM
LEMO UK Ltd
12-20 North Street
Worthing
West Sussex, BN11 1DU
Tel: (+44 1903) 23 45 43
Fax: (+44 1903) 20 62 31
lemouk@lemo.com
USA
LEMO USA Inc
P.O. Box 2408
Rohnert Park, CA 94927-2408
Tel: (+1 707) 578 88 11
(+1 800) 444 53 66
Fax:(+1 707) 578 08 69
info@lemousa.com
DISTRIBUTORS
AUSTRALIA, BRAZIL, CANADA, CZECH REPUBLIC, GREECE, INDIA, ISRAEL,
NEW ZEALAND, PAKISTAN, POLAND, RUSSIA, SOUTH AFRICA, SOUTH KOREA,
TAIWAN, TURKEY, UKRAINE
18
www.lemo.com
© CAT.XP.REN.P1010, updated October, 2011
LEMO
