35293
35293
    MASTERAPPLIANCECO(晨星半导体)
    ATTACHMENT5/8"REDUCER
35293 数据手册
MASTER Heat Guns COMPACT, LIGHTWEIGHT, EASY-TO-USE, PROFESSIONAL QUALITY Our complete line of Proheat Heat Guns makes any job easier and faster. Choose from four Models: The Quicktouch™ Model PH-1000 features a momentary contact switch, the Dualtemp Model PH-1100 offers two heat settings, the Varitemp Model PH-1200 delivers variable temperature control and the Variair Model PH-1300 combines variable temperature and variable airflow control. Model PH-1200 Check out our Proheat LCD Heat Gun brochure for electronic heat guns with LCD temperature and airflow display and other innovative features. ALL MODELS FEATURE: • RUGGED THERMOPLASTIC HOUSING. Protects against accidental damage for long life. • • ENCLOSED CERAMIC HEATING ELEMENT. Delivers high temperature, flameless heat. • CONVENIENT HANGING LOOP. Easy to hang and use with balancers. • PROTECTED, WRAP AROUND AIR INTAKE. Easily draws intake air even in an upright position. • EASY GRIP HANDLE. Balanced, ergonomic design prevents operator fatigue. PROTECTIVE HAND & SWITCH GUARD. Protects both hand and switch. • BUILT-IN STAND. Provides stability for handsfree use. • 3-WIRE GROUNDED CORDSET. Oil resistant neoprene. Provides flexibility and ease of use. • A COMPLETE LINE OF AVAILABLE ATTACHMENTS. Adds versatility. • ASSEMBLED IN USA USING DOMESTIC & FOREIGN PARTS. ® Variair Heat Gun ™ PH-1300 FEATURES: • DIAL-IN INDEPENDENTLY VARIABLE TEMPERATURE & AIRFLOW. Select just the right temperature and airflow for every job. Variable temperature from 130°F to 1000°F and variable airflow 4 to 16 CFM. • PRECISE TEMPERATURE & AIRFLOW SETTINGS. Use to heat temperature sensitive material, including specialty connectors, solder performs, shrink tubing and more. • ELECTRONIC CLOSED LOOP TEMPERATURE CONTROL SYSTEM. Maintains constant temperature when varying airflow or using restrictive attachments. Prevents heat back-up. • AVAILABLE IN A PROFESSIONAL KIT. PH-1300K features a rugged storage / carrying case and five versatile attachments: Shrink No. 35017, Reducer No. 35293, Reducer No. 35294, Specialty Connector No. 35292 and Spreader No. 35016. Separate temperature and airflow controls Desolder Circuit Boards PH-1300K Professional Kit with 5 versatile attachments ORDERING INFORMATION Model No. Description PH-1300 Proheat Variair Heat Gun PH-1300K Proheat Variair Heat Gun Kit SPECIFICATIONS Temperature: Variable 130°F - 1000°F (50°C - 540°C) Output: 1300W Volts: 120VAC / 60Hz, 11 Amps Max. Air Volume: Variable 4 - 16 CFM Air Velocity: Variable 734 - 4000 FPM Nozzle Opening: .88” Dia. (22.35 mm) Nozzle Diameter: 1.31” Dia. (33.27 mm) Element: Enclosed Ceramic Switch: 3 position rocker (Off - Cool - Hot) Cordset: 6 ft, 3 wire grounded, oil resistant neoprene Motor: Permanent Magnet Dimensions: 8.2” x 3.0” x 7.3” (L x W x H) Net Weight Tool: 1.6 Lbs. (794g) Single Pack: Dimensions: 9.5” x 9” x 3” (L x W x H) Weight: 3 Lbs. Single Kit Pack: Dimensions: 15” x 16.7” x 3.5” (L x W x H) Weight: 7 Lbs. Warranty: One Year Limited Users should independently evaluate the suitability of the product for their application. ® Varitemp Heat Gun ® MODEL PH-1200 FEATURES: • DIAL-IN VARIABLE TEMPERATURE. Select just the right temperature for every job. Infinitely variable temperature from 130°F to 1000°F at 16 CFM. • PRECISE TEMPERATURE SETTINGS. Use to heat temperature sensitive materials, including specialty connectors, solder performs, shrink tubing and more. • ELECTRONIC CLOSED LOOP TEMPERATURE CONTROL SYSTEM. Maintains constant temperature when varying airflow or using restrictive attachments. Prevents heat back-up. • AVAILABLE IN A PROFESSIONAL KIT. PH-1200K features a rugged storage / carrying case and five versatile attachments: Shrink No. 35017, Reducer No. 35293, Reducer No. 35294, Specialty Connector No. 35292 and Spreader No. 35016. Easy access heat control PH-1200-1 Heat Shrink System shown with 35292 attachment and 35216 stand PH-1200K Professional Kit with 5 versatile attachments ORDERING INFORMATION Model No. Description PH-1200 Proheat Varitemp Heat Gun PH-1200-1 Proheat Varitemp Heat Shrink System PH-1200K Proheat Varitemp Heat Gun Kit SPECIFICATIONS Temperature: Variable 130°F - 1,000°F (50°C - 540°C) Volts: 120VAC / 60Hz, 11 Amps Max. Output: 1300W Air Volume: 16 CFM Air Velocity: 4000 FPM Nozzle Opening: .88” Dia. (22.35 mm) Nozzle Diameter: 1.31” Dia. (33.27 mm) Element: Enclosed Ceramic Switch: 3 position rocker (Off - Cool - Hot) Motor: Permanent Magnet Cordset: 6 ft, 3 wire grounded, oil resistant neoprene Dimensions: 8.2” x 3.0” x 7.3” (L x W x H) Net Weight Tool: 1.6 Lbs. (794g) Single Pack: Dimensions: 9.5” x 9” x 3” (L x W x H) Weight: 3 Lbs. Single Kit Pack: Dimensions: 15” x 16.7” x 3.5” (L x W x H) Weight: 7 Lbs. Warranty: One Year Limited Users should independently evaluate the suitability of the product for their application. ® Dualtemp Heat Gun ™ MODEL PH-1100 FEATURES: • A GENERAL PURPOSE HEAT GUN. Delivers cost effective heat for basic heat applications. • TWO HEAT SETTINGS, 500°F & 1000°F. Meets temperature requirements for most materials. • PROFESSIONAL QUALITY PERFORMANCE. Activates adhesives, bends plastics and dry filler material, shrinks tubing and for many other applications that need a fast, portable heat source. • AVAILABLE IN A PROFESSIONAL KIT. PH-1100K features a rugged storage / carrying case, Shrink attachment No. 35017 and Spreader attachment No. 35016. Strip Paint ® Quick-Touch Heat Gun ™ MODEL PH-1000 FEATURES: • QUICK-TOUCH MOMENTARY CONTACT SWITCH. Quickly turns unit on by depressing switch. Heat gun turns off when switch is released. • EASY GRIP HANDLE. Balanced, ergonomic design prevents operator fatigue. • CONVENIENT HANGING LOOP. Easy to hang and use with balancers. • PROFESSIONAL QUALITY PERFORMANCE. Perfect for shrink packaging and many other applications. PH-1100K Professional Kit with 2 versatile attachments Shrink Packaging ORDERING INFORMATION Model No. Description PH-1000 Proheat Quick-Touch Heat Gun PH-1100 Proheat DualTemp Heat Gun PH-1100K Proheat DualTemp Heat Gun Kit SPECIFICATIONS Temperature: PH-1100: 500°F or 1,000°F (260°C or 540°C) / PH-1000: 1,000°F (540°C) Volts: 120VAC / 60Hz, 11 Amps Max. Output: 1300W Air Volume: 16 CFM Air Velocity: 4000 FPM Nozzle Opening: .88” Dia. (22.35 mm) Nozzle Diameter: 1.31” Dia. (33.27 mm) Element: Enclosed Ceramic Warranty: One Year Limited Motor: Permanent Magnet Cordset: 6 ft, 3 wire grounded, oil resistant neoprene Switch: PH-1100: 3 position rocker (Off - Hot 1 - Hot 2) / PH1000 - Momentary Contact, (Off-On) Dimensions: 8.2” x 3.0” x 7.3” (L x W x H) Net Weight Tool: 1.6 Lbs. (794g) Single Pack: Dimensions: 9.5” x 9” x 3” (L x W x H) Weight: 3 Lbs. Single Kit Pack: Dimensions: 15” x 16.7” x 3.5” (L x W x H) Weight: 7 Lbs. Users should independently evaluate the suitability of the product for their application. PROHEAT Attachments & Accessories Professional quality attachments and accessories add versatility to your Proheat Heat Guns. Direct, concentrate or reflect heat to allow more versatile and precise applications for your heat tool. REDUCER ATTACHMENTS SPREADER ATTACHMENTS 35294* 35293* 35270 35260 35016 3/8” (9 mm) Reducer Concentrates air flow. Also used with weld tips 5/8” (14 mm) Reducer Provides concentrated air flow 3/4” (20 mm) Reduction Nozzle Concentrated air flow 2” (50mm) Spreader Nozzle Spreads air evenly over wide area 3” (75 mm) Spreader Spreads air evenly over wide areas REFLECTOR ATTACHMENTS 35272 35264 35292* 3/8” (9 mm) Reflector, Shrink Attachment For shrinking small diameter tubing Use with PN35294 3/8” Reducer 3/8” (9 mm) Reflector, Shrink Attachment For shrinking small diameter tubing 5/8” (14 mm) Special Connector Use to terminate shrink, solder & crimp connectors DEFLECTOR ATTACHMENTS 35261 35017 3” (75mm) Large Reflector For shrinking large diameter tubing 1 1/4” Shrink Attachment Reflects air around surface’s such as tubing or pipe WELDING ATTACHMENTS 35262 35263 35295 35271 35296 2” (50mm) Window Nozzle Deflector Deflects heat away from windows 3” (75mm) Window Nozzle Deflector Deflects heat away from windows Plastic Welding Rod Nozzle w/ 7mm intake For use with welding rod, use with 3/8” reducer Plastic Welding Rod Slit Nozzle Use to melt plastic welding rod, use w/ 3/8” reducer 3/4” (20 mm) Lap Welding Nozzle For lap welding plastic materials, use with 3/8” reducer WELDING ATTACHMENTS ATTACHMENT KIT 35266 35267 35268 1 1/2” 40mm Angle Slit Nozzle Lap welds roofing materials 3” (75mm) Teflon Coated Butt Welding Heat Disc For butt welding PVC pipes 1 1/2” (40mm) Lap Welding Slit Nozzle For lap welding PVC Sheeting 35309 Attachment Kit Kit of 5 most popular attachments ACCESSORIES 35026 35216 35291 35351 Nozzle Shield Prevents nozzle contact Bench Stand To position guns for various applications Seam Roller with ball bearings For lap welding, edging tape and roofing applications Storage Case Transport & store in a rugged plastic case 35297 35298 35299 35300 35301 ABS Welding Rod Acrylonitrile Butadiene Styne (Pkg. of 16) Round, 1/8” Dia. x 9” Long, Natural, for welding ABS plastics PP Welding Rod Polypropylene (Pkg. of 16) Round, 1/8” Dia. x 9” Long, Natural, for welding PP plastics PVC Welding Rod Polyvinyl Chloride (Pkg of 16) Round, 1/8” Dia. x 9” Long, Grey, for welding PVC plastics LDPE Welding Rod Low Density Polyethylene (Pkg of 16) Round, 1/8” Dia. x 9” Long, Natural, for welding LDPE plastics HDPE Welding Rod High Density Polyethylene (Pkg. of 16) Round, 1/8” Dia. x 9” Long, Black, for welding HDPE plastics * Not for use with Model PH-1100. MSDS information is available for welding rods. Master Proheat Heat Guns provide safe, dependable heat for a wide variety of applications. Activate Adhesives Repair Windshield Moldings Dry Filler Material Shrink Tubing Weld Roofing Membrane Bend Plastics and PVC Dry/Seal Insulation Remove Decals Desolder Terminate Specialty Connectors Solder Copper Pipe Shrink Packaging FOR MASTER PRODUCTS CONTACT: Loosen Bolts Strip Paint As with all electrical equipment and tools, for your safety, read the instruction manual before using. All information including illustrations, is believed to be reliable. Users, however, should independently evaluate the suitability of this product for their application. The only obligations of Master Appliance are those in the Standard Terms and Conditions of Sale for this product. In no case will Master Appliance be liable for any incidental indirect, or consequential damages arising from the sale, resale, use or misuse of this product. Master Appliance Corp. • 2420 18th St. • Racine, WI 53403 • Phone 800-558-9413 • Fax 262-633-9745 Web Site: www.masterappliance.com E-mail: sales@masterappliance.com FORM# 58000 REV A
35293
物料型号: - PH-1000: Proheat Quick-Touch Heat Gun - PH-1100: Proheat DualTemp Heat Gun - PH-1200: Proheat Varitemp Heat Gun - PH-1300: Proheat Variair Heat Gun
器件简介: MASTER Proheat Heat Guns是一系列专业品质的热风枪,具有紧凑、轻便、易用的特点。它们适用于各种工业用途,包括激活粘合剂、修理挡风玻璃、收缩管道、焊接塑料等。
引脚分配: 文档中未提供具体的引脚分配信息,但提到了热风枪具有多种附件和配件,用于不同的应用。
参数特性: - 温度范围:130°F至1000°F(50°C至540°C) - 电压:120VAC / 60Hz,最大11安培 - 输出功率:1300W - 风量:可变4至16立方英尺每分钟(CFM) - 风速:可变734至4000英尺每分钟(FPM) - 喷嘴直径:0.88英寸(22.35毫米)至1.31英寸(33.27毫米) - 加热元件:封闭式陶瓷 - 开关类型:3位置摇杆开关(关-冷-热)或瞬时接触开关
功能详解: - PH-1300型号提供独立可变的温控和风量调节。 - PH-1200型号提供无限可变的温控。 - PH-1100型号提供两种热量设置(500°F和1000°F)。 - PH-1000型号具有瞬时接触开关,提供1000°F的热量。
应用信息: 热风枪适用于激活粘合剂、修理挡风玻璃、收缩管道、焊接塑料、剥离油漆、脱除贴纸、脱焊电路板等多种应用。
封装信息: 热风枪具有坚固的热塑性外壳,封闭式陶瓷加热元件,人体工程学设计的易握手柄,以及保护手和开关的保护罩。此外,还具有方便的悬挂环和内置支架,以及油耐性的3线接地电源线。
35293 价格&库存
很抱歉,暂时无法提供与“35293”相匹配的价格&库存,您可以联系我们找货
