35004
35004
    MASTERAPPLIANCECO(晨星半导体)
    HEAT ELEMENT KIT 120V
35004 数据手册
Proheat® Heat Gun, Kit & Accessories Rugged dual temperature heat gun  New 230 Volt CE Certified model available with four cordset options  Compact, lightweight, easy-to-use  Balanced ergonomic design prevents operator fatigue  Two heat settings 430°F or 840°F (221°C or 449°C)  Base provides built-in stand for hands-free use  Protective hand/switch guard and hanging loop  UL Listed or CE Certified, Made in USA PH-1100 PH-2100  Use to activate adhesives, bend plastics, dry filler material, shrink tubing and more 35016 35017 35216 35026 35351 PH-1100K PH-2100K MODEL NO. DESCRIPTION PH-1100 430°F or 840°F 221°C or 449°C 15 CFM 120V 60 Hz PH-1100K 430°F or 840°F 221°C or 449°C 15 CFM 120V 60 Hz with storage case and 2 attachments (35016 and 35017) PH-2100 430°F or 840°F 221°C or 449°C 16 CFM 230V 50/60 Hz PH-2100K 430°F or 840°F 221°C or 449°C 16 CFM 230V 50/60 Hz with storage case and all 2 attachments (35016 and 35017) 11A 11A 656 or 1300W 656 or 1300W 6.2A 6.2A 705 or 1410W 705 or 1410W Optional Accessories PART NO. 35016 35017 35216 DESCRIPTION PART NO. DESCRIPTION 3-1/2” spreader attachment 35026 Nozzle shield 1-3/8” heat shrink attachment 35351 Storage/carrying case Bench stand Proheat with rugged storage case and 2 specialty attachments Specifications  Air Volume: 15 CFM  Air Velocity: 3584 FPM (PH-1100), 4000 FPM (PH-2100)  Motor: Permanent Magnet  Nozzle Opening: .88" I.D., 1.31” O.D.  Cordset: 6 ft., 3-wire grounded  Dimensions: 8.2" L x 3.0" W x 7.3" H  Tool Net Weight: 1.6 lbs.  Shipping Weight Tool: 2 lbs.  Shipping Weight Kit: 7 lbs. NOTE: Users should independently evaluate the suitability of the product for their application. Heat Adhesives 10 Strip Paint Replacement Heating Element 120V 35004 220V 35022 Loosen Bolts Master Appliance Corp. • 2420 18th St. • Racine, WI 53403 • Phone 800-558-9413 • Fax 262-633-9745
35004 价格&库存
很抱歉,暂时无法提供与“35004”相匹配的价格&库存,您可以联系我们找货
    • 1+556.930291+72.02623
