PH-2200-1-A5
PH-2200-1-A5
    MASTERAPPLIANCECO(晨星半导体)
    HEAT GUN W/SHRINK ATTCHMNT 230V
PH-2200-1-A5 数据手册
® HEAT GUNS Compact • Light Weight • Easy-to-Use Professional Quality Heat Guns Easy Grip Handle Protective Hand/Switch Guard Hanging Loop 3-Wire Grounded Cordset Airflow Control Off-Dry-Hot Switch Temperature Control Built-in Stand Protected Air Intake Designers and Manufacturers of Heat Tools for Industry ® VARIAir ™ HEAT GUN • • • • • • • Compact, light weight, easy-to-use design Variable temperature 130°F to 900°F (54°C to 482°C) Variable airflow 6 to 15 CFM Special electronic closed loop temperature control system maintains constant temperature when varying airflow or using specialty attachments Use to heat temperature sensitive materials including specialty connectors, solder preforms, shrink tubing and more Base provides built-in stand for hands free use Made in the USA PH-1300K PH-1300-1 Separate temperature and airflow controls Terminate specialty connectors Rugged storage case with 5 specialty attachments ORDERING INFORMATION Model No. Description PH-1300 Proheat Variair Heat Gun PH-1300-1 Proheat Variair Heat Shrink System includes heat gun, stand and attachment (35292) PH-1300K Proheat Variair Heat Gun Kit, includes heat gun, 5 attachments (35309) and storage case TECHNICAL SPECIFICATIONS Voltage: 120V, 60Hz, 11A Output: 1300W maximum Temperature: Variable 130°F - 900°F (54°C - 482°C) Airflow Volume: Variable 6 - 15 CFM Airflow Velocity: 1425 - 3550 FPM Agency Approvals: UL, CUL Nozzle opening: Cordset: Dimensions: .87” diameter 6 ft, 3-wire grounded 8.2”L x 3.0”W x 7.3”H Net Weight: 28 oz (794 g) Motor: Permanent magnet Protected by Patent No’s. 5349161 Users should independently evaluate the suitability of the product for their application. ® VARITEMP ® HEAT GUN • • • • • • • Compact, light weight, easy-to-use design Variable temperature 130°F to 840°F (54°C to 449°C) Special electronic closed loop temperature control system maintains constant temperature Protects unit from overheating when using specialty attachments Patented heat controls and housing design Base provides built-in stand for hands free use Made in the USA PH-1200K PH-1200-1 Easy access heat control Terminate specialty connectors Rugged storage case with 5 specialty attachments ORDERING INFORMATION Model No. Description PH-1200 Proheat Varitemp Heat Gun PH-1200-1 Proheat Varitemp Heat Shrink System includes heat gun, stand and attachment (35292) PH-1200K Proheat Varitemp Kit includes heat gun, attachments (35309) and storage case PH-2200 Proheat Varitemp Heat Gun 220V, 50Hz, 5.8A maximum PH-2200-1 Proheat Varitemp Shrink System includes heat gun, stand and attachment (35292) PH-2200K Proheat Varitemp Kit includes heat gun, attachments (35309) and storage case TECHNICAL SPECIFICATIONS PH-1200, PH-1200-1, PH-1200K Voltage: 120V, 60Hz, 11A Output: 1300W maximum Temperature: Variable 130°F - 840°F (49°C - 449°C) Airflow Volume: 15 CFM Airflow Velocity: 3584 FPM Agency Approvals: UL, CUL, CSA PH-2200, PH-2200-1, PH-2200K Voltage: 220V, 50Hz, 5.8A Output: 1280W maximum Temperature: Variable 130°F - 815°F (49°C - 435°C) Airflow Volume: 16 CFM Airflow Velocity: 4000 FPM Nozzle opening: .87” diameter Net Weight: 26 oz (737 g) Cordset: 6 ft, 3-wire grounded Motor: Permanent magnet Dimensions: 8.2”L x 3.0”W x 7.3”H Protected by Patent No’s. 5349161 Users should independently evaluate the suitability of the product for their application. ® HEAT GUN • • • • • • • • • Compact light weight, easy-to-use design Two heat settings 430°F and 840°F (221°C and 449°C) Base provides built-in stand for hands free use Convenient hanging loop Easy grip handle Protective switch guard Multiple attachments available Use to activate adhesives, bend plastics, dry filler material, etc. Made in the USA PH-1100K Activate Adhesives ORDERING Model No. PH-1100 PH-1100K PH-2100 PH-2100K Strip Paint Professional Kit with attachments INFORMATION Description Proheat Heat Gun Proheat Kit includes heat gun, attachments (35016, 35017) and storage case Proheat Heat Gun 220V, 50Hz, 5.8A maximum Proheat Kit includes heat gun, attachments (35016, 35017) and storage case TECHNICAL SPECIFICATIONS PH-1100, PH-1100K Voltage: 120V, 60Hz, 6 & 11A Temperature: 430°F and 840°F (221°C Airflow Volume: 15 CFM Agency Approvals: UL, CUL, CSA PH-2100, PH-2100K Voltage: 220V, 50Hz, 3.6 & 5.8A Temperature: 480°F and 815°F (249°C Airflow Volume: 16 CFM Nozzle opening: .87” diameter Cordset: 6 ft, 3-wire grounded Dimensions: 8.2”L x 3.0”W x 7.3”H Output: 656W and 1300W and 449°C) Airflow Velocity: 3584 FPM Output: 670W and 1200W - 435°C) Airflow Velocity: 4000 FPM Net Weight: 26 oz (737 g) Motor: Permanent magnet Protected by Patent No’s. 5349161 Users should independently evaluate the suitability of the product for their application. Proheat Attachments and Accessories Professional quality attachments and accessories add versatility to your Proheat Heat Guns. Shrink Attachment For shrink tubing Part No. 35017 Spreader Attachment For spreading air over larger area Part No. 35016 Specialty Connector Attachment For terminating tubing and specialty connectors Part No. 35292* 5/16” Pinpoint Attachment Pinpoint hot air source for desoldering and welding PVC Part No. 35294* 9/16” Reducer Attachment Direct hot air source for desoldering and welding PVC Part No. 35293* Nozzle Shield Prevents nozzle contact Part No. 35026 Bench Stand To position heat guns for various applications Part No. 35216 Storage Case Transport and storage in a rugged plastic case Part No. 35351 MADE IN Attachment Kit Five attachments Part No. 35309 Located in a modern manufacturing facility in Racine, Wisconsin, Master Appliance introduced the first industrial quality heat gun to the worldwide marketplace in 1958. Now, with over 45 years of performance and experience, the Master name stands for uncommon expertise in heat technology, dependable quality products and unsurpassed service. Users should independently evaluate the suitability of the product for their application. * Not for use with Models PH-1100 or PH-2100. Master Appliance Corp. • 2420 18th St. • Racine, WI 53403 • Phone 800-558-9413 • Fax 262-633-9745 Web Site: www.masterappliance.com E-mail: sales@masterappliance.com Activate Adhesives Repair Windshield Moldings Dry Fill Material Shrink Tubing Weld Roofing Felt Bend Plastics and PVC Dry/Seal Insulation Remove Decals Desolder Terminate Specialty Connectors Solder Copper Pipe Shrink Package Designers and Manufacturers of Heat Tools for Industry FOR MASTER PRODUCTS CONTACT: Loosen Bolts Strip Paint As with all electrical equipment and tools, for your safety, read the instruction manual before using. All information including illustrations, is believed to be reliable. Users, however, should independently evaluate the suitability of this product for their application. The only obligations of Master Appliance are those in the Standard Terms and Conditions of Sale for this product. In no case will Master Appliance be liable for any incidental indirect, or consequential damages arising from the sale, resale, use or misuse of this product. Master Appliance Corp. • 2420 18th St. • Racine, WI 53403 • Phone 800-558-9413 • Fax 262-633-9745 Web Site: www.masterappliance.com E-mail: sales@masterappliance.com FORM# 58000
PH-2200-1-A5 价格&库存
很抱歉,暂时无法提供与“PH-2200-1-A5”相匹配的价格&库存,您可以联系我们找货
