6966EK
6966EK
    ATG
    6966EK HOT AIR GUN 230V
6966EK 数据手册
Hot Air Stations 700 W Hot Air Stations / Hot Air Heat Gun Accessory for WHA 3000V and WHA 3000P NEW NEW Order No. 005 87 367 80 Description Manual control panel 005 87 577 70 Foot switch 2-stages 005 15 049 99 Nozzle change tool 005 87 557 82 005 31 190 99 Thermoelement type K, Ø 0,1 mm Thermoelement type K, Ø 0,5 mm 005 15 048 99 Depositing rack for up to 6 hot air nozzles 005 87 578 94 Nozzle/reflektor, 30 mm 005 87 578 93 Nozzle/reflektor, 15 mm 005 87 578 92 Preheat plate NEW Hot Air Heat Gun The hot air heat gun can be used for heat shrink applications or drying and to detect faulty components on circuit boards. Cooling is also possible because the air flow is independent of the heater. Temperature range ca. 400°C– 430°C. Order No. 6966EK Model 6966EK Description Hot air heat gun 210 W / 230 V 6964 6957 6958 Hot air heat gun 230 V 0,2" Reflector 1,5" Reflector Shrinking nozzle consists of: 6964 6957 6958 Accessory for 6966E: 6965A 6965A Holder for gun Hot Air Stations 133
6966EK 价格&库存
很抱歉,暂时无法提供与“6966EK”相匹配的价格&库存,您可以联系我们找货
