Product data sheet
HL 2020 E
NEW!
Available October 2016
Technical Specifications
Voltage:
Output:
Amps:
Temperature:
Airflow rate:
Stages:
Highlights:
Power cord:
Motor:
Heating element:
Motor lifetime:
Accessories:
Dimensions:
Net Weight:
Single Sell Pack:
Country of origin:
Warranty:
120 VAC / 60Hz
1600 watts
13.3
120 – 1150 °F (50 – 620 °C)
4 / 4-8 / 6-13 cfm.
3
Higher durability (+20 %), optimized weight
balance, LCD-Display, heat build-up warning,
hanging ring, easily replaceable power cord,
residual heat indicator, optional temperature
scanner and fine dust filter
Industrial grade rubber, length: 6ft
Brush motor
Ceramic heating element
600h
Use of our standard accessories
9.96“ x 3.37“ x 7.87“ (l x w x h)
2.19 lbs (35.10 oz)
Dimensions: 10.20“ x 3.54“ x 9.33“
Weight: 2.60 lbs (41.66 oz)
Romania
One year limited
UPC-Code
Prod. No.
018139375500
110025597
STEINEL, 9051 Lyndale Avenue South, Bloomington, MN 55420 - (800) 852-4343 www.steinel.net
很抱歉,暂时无法提供与“110025597”相匹配的价格&库存,您可以联系我们找货
