110051538
110051538
    STEINEL
    HL2020EPROPLASTICWELDINGKIT
110051538 数据手册
Heat at work. Professional Tools for Professional Results Hot Air Barrel Tools Pistol Grip Hot Air Tools Hot Air Specials Precision Hot Air Tool Professional Heat Blower Hot Air Tool Accessories Gas Torches Hot-Melt Adhesive Systems from page 4 from page 18 from page 36 from page 44 from page 46 from page 50 from page 58 from page 72 HG 2620 E HG Scan PRO HG 2220 E HG 5000 E HG 2520 E HG Scan PRO HG 2320 E / ESD HL 2020 E HL 1920 E HL Scan HL 1820 S HL 1620 S HG 2320 E Kits HL 2020 E Kits HL 1920 E Kits HL 1820 E Kit HG 350 ESD HB 1750 Everything for welding floorings, plastics, tarpaulins and roof sheetings, removing and shaping, heat-shrinking, desoldering and spot heating, special accessories Ultimate Butane Kit TT 270 TT 175 TT 151 TT 30 TS 600 / TS 600 K TS 550 / TS 550 K TS 500 / TS 500 K TH 310 TM 6000 GF 3002 2 3 Hot Air Barrel Tools: Ideal for roofers and floor layers. Welding, heat-shrinking, shaping, removing – hot air makes all sorts of jobs incredibly easy. Jobs that demand precision, high performance and reliability. That's why professionals prefer barrel-type hot air tools from STEINEL. Professional Floor Layer “The STEINEL HG 2620 E is the best tool for floor laying.” 4 5 The art of understanding heat. Precision and control on hot air tools is imperative for a wide range of technical applications. STEINEL only uses top quality, long-lasting components that come from our development history. This is where our customers benefit from over 30 years of experience in developing and manufacturing hot air tools to give them a product that has been cleverly engineered in every last detail, only delivering heat where it is needed. Digital control system with LCD information display Precision-balanced impeller Easy-to-change power cord 1300 °F 3,000 Pa air pressure max. 13 cfm Including fine dust filter Hand-wound. long-life ceramic heater, easy to change 6 High-performance brushless motor  with a service life of over 10,000 hours Sturdy magnesium guard sleeve 7 Ideal for the trades and industry. Our flagship. Hot air tool HG 2620 E If you want the best when it comes to performance and precision: Delivering 1750 W of power, the HG 2620 E hot air tool is controlled by a toggle in 10 °F steps between 120 - 1300 °F while letting you set four individually tailored programs. The temperature is indicated on the LCD information display where it is easy to read at any time. The airflow rate is continuously variable between 2 – 13 cfm and is easy to adjust. Full air-pressure power is 3,000 Pa. The powerful brushless motor gives our flagship tool a working life of over 10,000 hours. Thanks to its robust design as well as the specially protected electronics with fine dust filter, four individually selectable programs and the heavy-duty H07 power cord, it is the safest, most dependable heat tool on any construction site. 1300 °F max. 13 cfm Also available in a convenient carrying case. Welding linoleum floors. 8 LCD display always in view Single-hand operation by toggle Magnesium guard sleeve, plug-in heating element Residual heat indicator Restart protection Includes fine dust filter Replaceable power cord Ergonomic soft grip handle Technical specifications Power: 1750 W Amps: 14.8 A Temperature: 120 - 1300 °F ( 50-700  °C ) Airflow rate: 2 - 13 cfm ( +/- 0.5 cfm ) Air pressure: 3,000 Pa Motor: brushless Motor life: 10,000 hours Temperature setting: on display, in 10 ° F steps by toggle Heating element: ceramic heating element Lockable Override Control ( LOC ): yes Create Preset Customizable Programs: yes Thermal cutout: yes Double Insulated: yes Power Cord: Industrial grade rubber Nozzle Diameter: 1.26" ( 32.00 mm ) Dimensions ( l × w × h ): 14.10" × 3.60" × 3.70" Voltage: 120 VAC, 50 / 60 Hz Weight: 1.85 lbs ( 29.63 oz ) Warranty: One year limited Ordering details 110025600 ( HG 2620 E in a folding box ), 3.26 lbs ( 52.10 oz ) 110047485 ( HG 2620 E in a case ), 5.17 lbs ( 82.65 oz ) Accessories 110033508 HG Scan PRO for HG 2620 E Professional STEINEL nozzles from page 50 HG Scan optional Fits all 1.26" dia­meter Industry Standard Nozzles DOUBLE INSULATED HEAT GUN 41HP 9 For safety and precision. Temperature scanner HG Scan PRO for HG 2620 E With the HG Scan PRO, you can be sure of the exact temperature at the work piece. It works in a range of 30 - 570 °F ( 0 - 300  °C ) with absolute precision – and informs you visually as well as audibly if the temperature exceeds or falls below the level you have set. The integrated laser technology ensures the ideal distance from the work piece. And being perfectly compatible with our top HG 2620 E and HG 2520 E tools, all relevant data are intelligently communicated between scanner and hot air tool. The particularly clever way to complement your set of tools. Visual warning: too hot = red Ideal temperature = green Visual warning: too cold = blue Technical specifications Power supplied from hot air tool Temperature detection range: 30 - 570 °F ( 0 - 300  °C ), adjustable in 10 °F steps Optimum distance from workpiece: 3.94" Emissivity level: user-selectable, adjustable from 0.10 to 0.99 Dimensions ( l × w × h ): 3.70" × 3.70" × 6.00" Weight: 0.26 lbs ( 4.23 oz ) Warranty: One year limited Ideal for all heat-sensitive materials Film, sheeting, foil Wood Plastic Leather Textiles Ordering details 110033508 ( folding box ), 0.37 lbs ( 6.00 oz ) Audible warning Laser techno­logy for maintaining perfect distance Intelligent data communication Hot air and temperature measurement with one hand. 10 11 Slim. Lightweight. Ergonomic. Hot air tool HG 2220 E The HG 2220 E weighs only 1.34 pounds ( 610 g ) and has a powerful 1500 W motor that heats the flow of air across a continuously variable temperature range of 167 - 1166 °F ( 80 - 630  °C ) via an easily adjustable thumbwheel. Nozzles are push-on and simple to attach. A perfect tool for all professionals with a preference for practical things – and, thanks to fine dust filter and long-life brush motor, who also want it to give them lasting service. Professional edgebanding. 12 Two-stage airflow Continuously variable temperature setting Ergonomic soft grip handle Replaceable power cord Fine dust filter included Technical specifications Power: 1500 W Amps: 12.5 A Temperature: 120 - 1100 °F ( 50-600 °C ) Airflow rate: 4-7/6-12 cfm ( +/- 0.5 cfm ) Temperature setting: thumbwheel Heating element: ceramic heating element Thermal cutout: yes Double Insulated: yes Power Cord: Industrial grade rubber, length: 6ft Nozzle Diameter: 1.34" ( 34.00 mm ) Dimensions ( l × w × h ): 13.30" × 3.00" × 3.50" Voltage: 120 VAC, 50/60 HZ Weight: 1.34 lbs ( 21.51 oz ) Warranty: One year limited Fits all 1.34" dia­meter Industry Standard Nozzles Ordering details 110025601 ( folding box ), 2.59 lbs ( 41.48 oz ) Accessories Pressure fit standard nozzles from page 53 DOUBLE INSULATED HEAT GUN 41HP 13 Our most powerful tool. 3400 W, 28 cfm. Hot air tool HG 5000 E Bursting with strength and staying power: with its powerful 3400 W brushless motor rated for 20,000 hours of service, the HG 5000 E delivers up to 800 litres of air a minute over an infinitely variable temperature range of 80-1100 °F ( 20-600 °C ). Its generously sized outlet nozzle reaches a pressure of 3,000 Pa. Making it the ideal tool for working on large surfaces. From fully electronic temperature and airflow adjustment to intelligent motor and temperature control and clearly structured LED segment display, it comes with everything that professionals need for working with hot air in industry. The mains power cord and heater are particularly easy to change. Changing the screw-on nozzle attachment is just as simple. Also available in a convenient carrying case. LED segment display Plug-in heating element Replaceable power cord Technical specifications Power: 3400 W Amps: 14.8 A Temperature: 80 - 1100 °F ( 20 - 600 °C ) Airflow rate: max. 28 cfm ( +/- 0.5 cfm ) Air pressure: 3,000 Pa Motor: brushless Motor life: 20,000 hours Temperature setting: continuiously variable in 10 °F steps Heating element: ceramic heating element Thermal cutout: yes Double Insulated: yes Power Cord: Industrial grade rubber ( European Plug ) Nozzle Diameter: 1.97" ( 50.00 mm ) Dimensions ( l × w × h ): 14.50" × 4.30" × 4.30" Voltage: 230 VAC, 50 HZ Weight: 2.62 lbs ( 41.98 oz ) Warranty: One year limited Fits Speciality STEINEL Nozzles Ordering details 104201504 ( folding box ), 3.70 lbs ( 59.20 oz ) 110049782 ( case ), 10.80 lbs ( 172.60 oz ) Overlap welding on a light dome. 14 Accessories Speciality STEINEL nozzles from page 50 15 Experts in every field. Summary of applications. There's a lot you can do with hot air. And take care of all sorts of jobs with ease, reliability and precision. This is where you will always find the right professional barrel air tool from STEINEL for a virtually unlimited range of applications in industry and the trades.  Welding linoleum HG 2620 E HG 2620 E HG 2220 E HG 5000 E Welding / repairing truck side curtains and advertising banners +++ + ++ Welding / repairing pond liner / landfill membranes, pool construction +++ + +++ + ( 1 ) + + +++ + +++ + + + ( 1 ) + + Car wrapping, window tinting, facade wrapping Welding plastics in tank and apparatus construction Smoothing leather HG 2620 E Smoothing leather Welding roof sheeting +++ Welding floorings +++ + Heat-shrinking +++ +++ +++ + + + ( 1 ) ++ +++ Desoldering components from circuit boards +++ + Shaping plastics +++ + +++ Stripping oil-based paints / removing sheeting, films and foils +++ ++ +++ Woodworking, edgebanding, redecorating work +++ ++ +++ Refurbishment work, removing tiles +++ Packaging / shrink-wrapping +++ Drying and heating Overlap welding HG 2620 E ( 1 ) 16 +++ +++ ++ +++ Using HG Scan PRO 17 Pistol Grip Hot Air Tool: Pulling out all the stops at work. Absolute precision is essential when working with a heat tool. It should fit perfectly in your hand and let you work without tiring. This is why we have focused on ergonomics when developing our pistol-type hot air tools. Long life, exact temperature settings, and ease of operation with just one hand are part of the standard repertoire at STEINEL. Professional Electrician “Precision is important in my line of work, so I need a heat gun that provides control and accuracy, so I chose STEINEL.” 18 19 1300 °F 700  °C max. 10,000 h 13 cfm More power. More heat. More life time with brushless motor Hot air tool HG 2520 E STEINEL's strongest pistol grip hot air tool is equipped with a powerful and extremely durable brushless motor that produces hot air up to 3,000 Pa with absolute precision. The temperature can be varied by toggle with one hand in 10 °F steps and read from the clear LCD information display at any time. It's just as easy to adjust the airflow rate between 2 - 13 cfm and select any of the four individually tailored programs. Weight in at a mere 1.85 lbs, this professional hot air tool is perfect for construction site use and uses professional standard nozzles. Also available in a convenient carrying case. Welding plastic in tank and apparatus construction. 20 Single-hand operation by toggle LCD information display always in view Residual heat indicator Plug-in heating element Non-slip standing surface Built in hanger Replaceable power cord Technical specifications Power: 1750 W Amps: 14.8 A Temperature: 120 - 1300 °F ( 50 - 700  °C ) Airflow rate: 2 - 13 cfm ( +/- 0.5 cfm ) Air pressure: 3,000 Pa Motor: brushless Motor life: 10,000 hours Temperature setting: on display, in 10 °F steps by toggle Heating element: ceramic heating element Lockable Override Control ( LOC ): yes Create Preset Customizable Programs: yes Thermal cutout: yes Double Insulated: yes Power Cord: Industrial grade rubber Nozzle Diameter: 1.26" ( 32.00 mm ) Dimensions ( l × w × h ): 11.20" × 3.80" × 8.20" Voltage: 120 VAC, 50/60 HZ Weight: 1.85 lbs ( 29.63 oz ) Warranty: One year limited Ordering details 110025599 ( HG 2520 E in a Case ), 5.15 lbs ( 82.44 oz ) Accessories 110033594 HG Scan PRO for HG 2520 E Professional STEINEL nozzles from page 50 HG Scan optional Fits all 1.26" dia­meter Industry Standard Nozzles DOUBLE INSULATED HEAT GUN 41HP 21 Absolute precision. From the word go. Temperature scanner HG Scan PRO for HG 2520 E Precise, reliable, intelligent: the HG Scan PRO is the ideal addition to the HG 2520 E hot air tool. Once fitted on the housing you will have complete control of current temperature and distance from the work surface. Interactive data communication between tool and scanner as well as audio and visual signals let you keep everything in the optimum range. To make your work even easier. Visual warning: too hot = red Ideal temperature = green Visual warning: too cold = blue Technical specifications Power supplied from hot air tool Temperature detection range: 30 - 570 °F ( 0 - 300  °C ), adjustable in 10 °F steps Optimum distance from workpiece: 3.94" Emissivity level: user-selectable, adjustable from 0.10 to 0.99 Dimensions ( l × w × h ): 3.50" × 2.20" × 3.00" Weight: 0.19 lbs ( 2.30 oz ) Warranty: One year limited Ideal for all heat-sensitive materials Film, sheeting, foil Wood Plastic Leather Textiles Ordering details 110033594 ( HG Scan PRO in a folding box ), 0.40 lbs ( 6.49 oz ) Audible warning Laser technology for maintaining perfect distance Intelligent data communication Smoothing leather with the HG Scan PRO. 22 23 Digital precision. Heat gun HG 2320 E Cutting-edge technology for perfect results: The HG 2320 E generates an impressive 1,600  watts of power and delivers hot air between 120 and 1,200 °F. Temperature is very easy to control via toggle, giving you absolute precision. Together with the residual heat indicator, the LCD information display ensures additional certainty while the four individually selectable and customizable programs provide maximum flexibility. At the same time, all tool settings can be locked using the LOC function to rule out any accidental changes. In conjunction with the various push-on nozzles from the range of accessories, the HG 2320 E is an excellent choice for working on heat-sensitive objects. The heat gun is also available in an ESD version for use in electrostatically sensitive areas. ESD Version Shrinking cable sleeves in distribution cabinet 24 Two-stage airflow Temperature easy to set with toggle LCD display and programs Residual heat indicator Replaceable power cord Optimised weight balance Rubber stand Built in hanger Technical specifications Power: 1600 W Amps: 13.5 A Temperature: 120 - 1200 °F ( 50 - 650  °C ) Airflow rate stage 1: 4-7 ( +/- 0.5 cfm ) stage 2: 8-13 cfm ( +/- 0.5 cfm ) Temperature setting: on display, in 10° F steps by toggle Heating element: ceramic heating element Lockable Override Control ( LOC ): yes Create Preset Customizable Programs: yes Thermal cutout: yes Thermostat: yes Double Insulated: yes Power Cord: Industrial grade rubber Nozzle Diameter: 1.34" ( 34.00 mm ) Dimensions ( l × w × h ): 10.00" × 3.40" × 7.90" Voltage: 120 VAC, 50/60 HZ Weight: 1.66 lbs ( 26.63 oz ) Warranty: One year limited Ordering details 110025598 ( HG 2320 E in a folding box ), 2.60 lbs ( 41.66 oz ) 110025697 ( HG 2320 ESD in a folding box ), 2.60 lbs ( 41.66 oz ) Kits see on page 38/39 Accessories 110048403 HL Scan 110028647 fine dust filter 110047650 HL Light Pressure fit standard nozzles from page 53 HL Scan optional Fits all 1.34" dia­meter Industry Standard Nozzles HL Light optional Fine dust filter optional DOUBLE INSULATED HEAT GUN 41HP 25 Conquers any challenge. Heat gun HL 2020 E Experts prefer the sturdy HL 2020 E heat gun. The electronically controlled heat tool delivering 1,600 watts of power is easily operated via toggle, regulates temperature between 120 to 1,150 °F and provides convenient handling with its LCD display. The residual heat indicator warns the user that the outlet nozzle is still hot. The precision adjustable heat and powerful blower make the HL 2020 E the ideal choice for virtually any application – heat shrinking tubes and sleeves onto cables, welding and many other challenging jobs. Desoldering components from circuit boards with pinpoint accuracy. 26 Three-stage airflow Temperature easy to set with toggle LCD display Residual heat indicator Replaceable power cord Optimised weight balance Rubber stand Built in hanger Technical specifications Power: 1600 W Amps: 13.3 A Temperature: 120 - 1150 °F ( 50 - 620  °C ) Airflow rate stage 1: 4 cfm ( +/- 0.5 cfm ) stage 2: 4-8 cfm ( +/- 0.5 cfm ) stage 3: 6-13 cfm ( +/- 0.5 cfm ) Temperature setting: on display, in 10° F steps by toggle Heating element: ceramic heating element Thermal cutout: yes Thermostat: yes Double Insulated: yes Power Cord: Industrial grade rubber Nozzle Diameter: 1.34" ( 34.00 mm ) Dimensions ( l × w × h ): 10.00" × 3.40" × 7.90" Voltage: 120 VAC, 50/60 HZ Weight: 1.94 lbs ( 31.04 oz ) Warranty: One year limited Ordering details 110025597 ( folding box ), 2.60 lbs ( 41.66 oz )  ) Kits see on page 40/41 Accessories 110048403 HL Scan 110028647 fine dust filter 110047650 HL Light Pressure fit standard nozzles from page 53 HL Scan optional Fits all 1.34" dia­meter Industry Standard Nozzles HL Light optional Fine dust filter optional DOUBLE INSULATED HEAT GUN 41HP 27 For challenging jobs. Heat gun HL 1920 E Finished to a high level of quality with optimum weight balance and long life, the HL 1920 E heat gun is an absolute “must" for anyone attaching importance to quality. The multi-talented tool impresses with 1,500 watts of power, infinitely variable temperature adjustment from 120 to 1,150 °F and airflow control in three stages. And if it ever gets too hot when welding plastic or stripping paint, the automatic cut-out protects the tool from overheating. Using heat for getting plastic into exactly the right shape. 28 Three-stage airflow Continuously variable temperature Rubber stand Built in hanger Optimised weight balance Technical specifications Power: 1500 W Amps: 13.2 A Temperature: 120 - 1100 °F ( 50-600 °C ) Airflow rate stage 1: 4 ( +/- 0.5 cfm ) stage 2: 4-8 ( +/- 0.5 cfm ) stage 3: 6-13 cfm ( +/- 0.5 cfm ) Temperature setting: in 9 steps by thumbwheel Heating element: ceramic heating element Thermal cutout: yes Double Insulated: yes Power Cord: Industrial grade rubber, length: 6ft Nozzle Diameter: 1.34" ( 34.00 mm ) Dimensions ( l × w × h ): 10.00" × 3.30" × 7.90" Voltage: 120 VAC, 50/60 HZ Weight: 1.85 lbs ( 29.63 oz ) Warranty: One year limited Ordering details 110025596 ( folding box ), 2.31 lbs ( 36.93 oz ) Kits see on page 42 Accessories 110048403 HL Scan 110028647 fine dust filter 110047650 HL Light Pressure fit standard nozzles from page 53 HL Scan optional Fits all 1.34" dia­meter Industry Standard Nozzles HL Light optional Fine dust filter optional DOUBLE INSULATED HEAT GUN 41HP 29 Hot. But never too hot. Temperature scanner HL Scan for HG 2320 E – HL 1820 S The right solution for every need. And for every tool. To ensure the right working tem­ perature on heat-sensitive work pieces at all times, this is why we offer a solution for our pistol grip hot air tools that is no less intelligent. For practical single-handed operation: simply fitted to the housing of an HG 2320 E / ESD or HL  2020 E / 1920 E / 1820 S the HL Scan provides the user with all relevant information: the precision digital display and audio signals reliably show whether the temperature is too hot, ideal or too cold. Visual warning: too hot = red Visual warning: too cold = blue Ideal temperature = green Technical specifications Temperature detection range: 32 - 572 °F ( 0-300 °C ) Work area marking: by LED light beam Optimum distance from workpiece: 5.90" Dimensions ( l × w × h ): 5.77" × 2.00" × 1.70" Voltage: 9 V battery Special features: adjustable emissivity leveles and tolerance ranges Weight: 0.36 lbs ( 5.82 oz ) Warranty: One year limited Ideal for all heat-sensitive materials Film, sheeting, foil Wood Plastic Leather Textiles Ordering details 110048403 ( folding box ), 0.58 lbs ( 9.28 oz ) Audible warning Ideal for carwrapping. 30 TESTING EQUIPMENT 4VR8 31 Multi-purpose heat gun. Heat gun HL 1820 S On the HL 1820 S, the temperature not only adjusts from 120 to 750 to 1,100 °F in three stages – the airflow does too ( 4, 7 and 13 cfm ). The optimized weight balance virtually rules out fatigue while working. The ergonomically shaped hangle with soft inlay ensures optimum handling and the intagrated thermal cut-out prevents over heating. The tool can be used with all industry standard nozzles, making all sorts of different applications even easier – for example, de-icing, drying, shaping, heat shrinking and much more. Three-stage airflow Thawing frozen pipes. 32 Optimised weight balance Technical specifications Power: 1400 W Amps: 12 A Temperature stage 1: 120 °F ( 50 °C ) stage 2: 750 °F ( 400 °C ) stage 3: 1100 °F ( 600 °C ) Airflow rate stage 1: 4 cfm ( +/- 0.5 cfm ) stage 2: 7 cfm ( +/- 0.5 cfm ) stage 3: 13 cfm ( +/- 0.5 cfm ) Temperature setting: 3 stages Heating element: ceramic heating element Thermal cutout: yes Double Insulated: yes Power Cord: Industrial grade rubber, length: 6ft Nozzle Diameter: 1.34" ( 34.00 mm ) Dimensions ( l × w × h ): 10.00" × 3.40" × 7.90" Voltage: 120 VAC, 50/60 HZ Weight: 1.76 lbs ( 28.22 oz ) Warranty: One year limited Ordering details 110025541 ( folding box ), 2.18 lbs ( 34.92 oz ) Kit see on page 43 Accessories 110048403 HL Scan 110028647 fine dust filter 110047650 HL Light Pressure fit standard nozzles from page 53 HL Scan optional Fits all 1.34" dia­meter Industry Standard Nozzles HL Light optional Fine dust filter optional DOUBLE INSULATED HEAT GUN 41HP 33 Entry level, big advantages. Heat gun HL 1620 S Drying plaster work, heat shrinking tubes and sleeves onto cables, thawing frozen water or stripping paint – the HL 1620 S makes light work of any job, with it’s weight of just 1.48 pounds. Adjustable in two stages of heat and airflow (  575 or 950˚F, 8 or 13 cfm ) the HG 1620 S comes with an optimized weight balance for fatigue free working as well as integrated thermal cut-out. Two-stage airflow Optimised weight balance Technical specifications Power: 1300 W Amps: 10.9 A Temperature stage 1: 575 °F ( 300  °C ) stage 2: 950 °F ( 500 °C ) Airflow rate stage 1: 8 cfm ( +/- 0.5 cfm ) stage 2: 13 cfm ( +/- 0.5 cfm ) Heating element: micanite heating element Thermal cutout: yes Double Insulated: yes Power Cord: Industrial grade rubber, length: 6ft Nozzle Diameter: 1.34" ( 34.00 mm ) Dimensions ( l × w × h ): 10.00" × 3.40" × 7.90" Voltage: 120 VAC, 50/60 HZ Weight: 1.48 lbs ( 23.63 oz ) Warranty: One year limited Fits all 1.34" dia­meter Industry Standard Nozzles Ordering details 110023455 ( folding box ), 2.06 lbs ( 32.98 oz ) Accessories Pressure fit standard nozzles from page 53 Stickers are easy to remove with hot air. 34 DOUBLE INSULATED HEAT GUN 41HP 35 For car mechanics and auto body. What once had to be repaired or completely replaced at great expense and painstaking effort can now be returned to perfect shape. Hot air provides the key. STEINEL has the right technology with high-quality tools that fit perfectly in your hand. Engineered to meet all the needs of automotive an auto body mechanics. STEINEL provides the right accessory for a one stop shop for precision results every time. Car Mechanic “STEINEL offers a full line of precision tools which end up in quality work.” 36 37 HG 2320 E Kits. Auto Body Welding Kit with Temp Scanner Auto Body Welding Kit Deluxe Plastic Welding Kit with Temp Scanner Deluxe Plastic Welding Kit Electronics Kit Multi Purpose Kit HG 2320 E Heat Tool HL Scan Welding Iron Reduction Nozzle 9mm Reduction Nozzle 20mm 2 pcs Wire Mesh 16 pcs ThermoFlexx Welding Rod Temperature Guard Auto Body Repair Guide Auto Body Welding DVD Catalog Heavy Duty Carrying Case HG 2320 E Heat Tool Welding Iron Reduction Nozzle 9mm Reduction Nozzle 20mm 2 pcs Wire Mesh 16 pcs ThermoFlexx Welding Rod Temperature Guard Auto Body Repair Guide Auto Body Welding DVD Catalog Heavy Duty Carrying Case HG 2320 E Heat Tool HL Scan TS 600 Soldering Iron TS 600 Welding Iron Welding Iron Reduction Nozzle 9mm Reduction Nozzle 20mm 2 pcs Wire Mesh 16 pcs ThermoFlexx Welding Rod Temperature Guard Deluxe Auto Body Repair Guide Auto Body Welding DVD Catalog Heavy Duty Carrying Case HG 2320 E Heat Tool TS 600 Soldering Iron Welding Iron Reduction Nozzle 9mm Reduction Nozzle 20mm 2 pcs Wire Mesh 16 pcs ThermoFlexx Welding Rod Temperature Guard Catalog Heavy Duty Carrying Case HG 2320 E Heat Tool Reflector Nozzle 9mm Reflector Nozzle 14mm Reflector Nozzle 39mm Reduction Nozzle 9mm Catalog Heavy Duty Carrying Case HG 2320 E Heat Tool Reflector Nozzle 9mm Reflector Nozzle 14mm Reflector Nozzle 39mm Reduction Nozzle 9mm Welding Nozzle Plastic Welding Rod Assortment Plastic Welding Booklet Catalog Heavy Duty Carrying Case Ordering details 110051530 Ordering details 110051531 Ordering details 110051536 Ordering details 110051533 Ordering details 110051534 Ordering details 110051535 38 39 HL 2020 E Kits Automotive Kit with Temp Scanner Automotive Kit Plastic Welding Kit Silver Kit Platinum Kit Multi Purpose Kit HL 2020 E Heat Tool HL Scan Reflector Nozzle 14mm Reflector Nozzle 39mm Reduction Nozzle 9mm Reduction Nozzle 20mm Window Nozzle 75mm Welding Nozzle PP Plastic Welding Rods Plastic Welding Book Auto Body Welding DVD Catalog Heavy Duty Carrying Case HL 2020 E Heat Tool Reflector Nozzle 14mm Reflector Nozzle 39mm Reduction Nozzle 9mm Reduction Nozzle 20mm Window Nozzle 75mm Welding Nozzle PP Plastic Welding Rods Plastic Welding Book Auto Body Welding DVD Catalog Heavy Duty Carrying Case HL 2020 E Heat Tool Welding Nozzle Lap Welding Slit Nozzle 20mm Reduction Nozzle 9mm Reflector Nozzle 39mm 2 pcs Wire Mesh Plastic Welding Rod Assortment Plastic Welding Booklet Catalog Heavy Duty Carrying Case HL 2020 E Heat Tool Spreader Nozzle 75mm Reflector Nozzle 14mm Reflector Nozzle 39mm Reduction Nozzle 9mm Welding Nozzle Plastic Welding Rod Assortment Shrink Tubes Plastic Welding Booklet Catalog Silver Case HL 2020 E Heat Tool Spreader Nozzle 75mm Reflector Nozzle 14mm Reflector Nozzle 39mm Reduction Nozzle 9mm Shrink Tubes Catalog Silver Case HL 2020 E Heat Tool Reflector Nozzle 9mm Reflector Nozzle 14mm Reflector Nozzle 39mm Reduction Nozzle 9mm Welding Nozzle Welding Rod Assortment Plastic Welding Booklet Catalog Heavy Duty Carrying Case Ordering details 110051550 40 Ordering details 110051537 Ordering details 110051538 Ordering details 110051541 Ordering details 110051542 Ordering details 110051539 41 HL 1920 E Kits HL 1820 S Industrial Kit Platinum Kit Classic Kit Multi Purpose Kit General Purpose Kit HL 1920 E Heat Tool Reflector Nozzle 14mm Reflector Nozzle 39mm Reduction Nozzle 9mm Reduction Nozzle 20mm Spreader Nozzle 75mm Catalog Heavy Duty Carrying Case HL 1920 E Heat Tool Spreader Nozzle 75mm Reflector Nozzle 14mm Reflector Nozzle 39mm Reduction Nozzle 9mm Shrink Tubes Catalog Silver Case HL 1920 E Heat Tool Reflector Nozzle 14mm Reflector Nozzle 39mm Reduction Nozzle 9mm Catalog Silver Case HL 1820 S Heat Tool Reduction Nozzle 20mm Spreader Nozzle 75mm Reflector Nozzle 39mm Window Nozzle 75mm Catalog Heavy Duty Carrying Case Ordering details 110051543 Ordering details 110051545 HL 1920 E Heat Tool Reflector Nozzle 9mm Reflector Nozzle 14mm Reflector Nozzle 39mm Reduction Nozzle 9mm Welding Nozzle Welding Rod Assortment Plastic Welding Booklet Catalog Heavy Duty Carrying Case Ordering details 110051546 Ordering details 110051547 Ordering details 110051544 42 43 Making easy work of soldering, de-soldering, heat-shrinking. Heat gun HG 350 ESD The high-tech HG 350 ESD heat gun impresses with maximum precision and optimized ergonomics. The temperature can reach 750 °F as well as 930 °F when using a reduction nozzle. A temperature indicator shows whether the outlet tube is too hot to touch, this tool also comes with an integrated LED light that always provides optimum illumination and perfect visibility. The tool is also ESD-safe, also making it suitable for use in electrostatically sensitive areas. This tool is compact and includes a lightweight design. Also available in a convenient carrying case. Integrated LED work light Optimised weight balance Ergonomically shaped softgrip handle Technical specifications Power: 300 W Amps: 2.5 A Temperature: 750 - 930 °F ( 400-500 °C ) Airflow rate: 3.5 cfm Power Cord: Industrial grade rubber, length: 6ft Nozzle Diameter: 0.75" ( 19 mm ) Dimensions ( l × w × h ): 9.00" × 11.50" × 3.00" Voltage: 120 VAC, 50/60 HZ Weight: 1.50 lbs ( 24.00 oz ) Warranty: One year limited Ordering details 109964900 ( folding box ), 2.05 lbs ( 32.80 oz ) 110049739 ( Precision Heat Gun Kit ), silver case, including Reduction Nozzle 7 mm, Reducer with Guard 5 mm, Reflector Nozzle 10 mm, Precision Reflector Nozzle, Reflector Nozzle 40 mm, Solder Dispenser, Shrink Tube Assortment Off / cold / hot Ideal for desoldering 44 Built in hanger Accessories Push-on nozzles on page 52 HEAT GUN 41HP 45 More is better. Heat blower HB 1750 Maximum power for perfect results: The HB 1750 delivers almost 30 percent more air than conventional heat blowers. This makes particularly fast and efficient work of any job – whether drying paint, shaping plastic, heating shrink film or heat shrinking tubes and sleeves onto cables. Five interchangeable color coded keys can be used for selecting the perfect temperature for any job from 100 to 1,200 °F. Comes complete with an adjustable support stand, this extremely quiet tool is suitable for stationary use. The support stand also provides a practical place to keep the color coded keys that are not being used. The soft grip handle guarantees maximum comfort even after long periods of use. Also available in a convenient carrying case. Adju stab 90° le Adjustable Stand Simple change of temperature keys Drying plasterwork faster with hot air. 46 Baffle Adjusts Air and Temperature within Range Cool Air Stage Quick and easy field changeable element Technical specifications Power: 1750 W Amps: 14.6 A Temperature: 200° - 1200 °F ( 95° - 650 °C ) all 5 keys Airflow rate: up to 23 cfm, adjustable with baffle Power Cord: Industrial grade rubber, length: 6ft Nozzle Diameter: 1.70" ( 43.50 mm ) Dimensions ( l × w × h ): 10.80" × 5.80" × 9.50" Voltage: 120 VAC, 50/60 HZ Weight: 2.90 lbs ( 46.40 oz ) Warranty: One year limited Ordering details 109486800 HB 1750 with all 5 keys ( folding box ), 3.60 lbs ( 57.60 oz ) 110049973 HB 1750 with blue key ( folding box ) 110049974 HB 1750 with gray key ( folding box ) 110049975 HB 1750 with yellow key ( folding box ) 110049976 HB 1750 with orange key ( folding box ) 110049977 HB 1750 with red key ( folding box ) 110049745 HB 1750 Kit ( case, including Quick Lock Stand, 5 Temperature Keys, Large Reflector, Spare Element ) Accessories on page 53 HB 1750 200 - 1200 °F ( 95 - 650 °C ) HB 1750 B 200 -  300 °F ( 95 - 150 °C ) HB 1750 G 300 -  500 °F ( 150 - 260 °C ) HB 1750 Y 500 -  750 °F ( 260 - 400 °C ) HB 1750 O 750 - 1000 °F ( 400 - 540 °C ) HB 1750 R 1000 - 1200 °F ( 540 - 650 °C ) DOUBLE INSULATED HEAT GUN 41HP 47 Professional down to every last detail. Summary of applications. Welding plastic in tank and apparatus construction. HG 2520 E Welding water tank HG 2320 E STEINEL has the right pistol grip hot air tool for every need, whichever you choose: its only really complete with the right accessories. This is where we can give you a virtually unlimited range of options. HG 2520 E HG 2320 E/ESD HL 2020 E HL 1920 E HL1820S HL 1620 S Welding / repairing truck side curtains and advertising banners +++ +++ +++ + Welding / repairing pond liner / landfill membranes, pool construction +++ +++ +++ + Window tinting +++ +++ +++ ++ +++( 2 ) +++( 3 ) +++( 3 ) +( 1,3 ) + + +++ +++ +++ +++ ++ +++( 2 ) +++( 3 ) +++( 3 ) ++( 3 ) + + ++ Welding floorings +++ +++ +++ ++ Heat Shrink Tubing / Solder Sleeves +++ +++ +++ +++ ++ ++ +++ ++ Drying and heating +++ +++ +++ +++ ++ ++ ++ +++ Desoldering and Soldering components from circuit boards +++ +++ +++ +++ +++ + Shaping plastics / Prosthetics +++ +++ +++ ++ + + ++ +++ Stripping oil-based paints / removing sheeting, films and foils +++ +++ +++ ++ + + +++ Woodworking, edgebanding, redecorating work +++ +++ +++ ++ + + ++ Refurbishment work, removing tiles +++ +++ +++ ++ + + + Packaging / shrink-wrapping +++ +++ +++ ++ + + Heat atcivated Adhesives ( with HG Scan Pro ) +++ +++ +++ ++ + + Composites +++ +++ +++ ++ + + +++ ++ Inflatable Repair +++ +++ +++ ++ + + +++ + Medical / Clean Room Applications +++ +++ +++ ++ + + +++ Vehicle wrapping, wrapping facades Welding plastics in tank and apparatus construction, Smoothing & Repairing leather / Vinyl ( with HG Scan PRO ) ( 1 ) HG 350 ESD + HB 1750 +++ ++ Version with 7.5 m mains power cord, ( 2 ) using HG Scan PRO, ( 3 ) using HL Scan 48 49 Accessories for HG 2620 E, HG 2520 E Welding floorings or spot heating For welding roof membranes,- sheetings and -tarpaulins Speed Welding Nozzle 3 mm Speed Welding Nozzle 4 mm Speed Welding Nozzle 5 mm Flat Angled Nozzle 20x2 mm Flat Angled Nozzle 20x2 mm, straight Flat Angled Nozzle 20x2 mm, 100° Flat Angled Nozzle 30x2 mm, 60° 110038331 110038332 110038333 110049713 110037580 106934900 110039176 ( Pushes onto round nozzle 5mm ) ( Pushes onto round nozzle 5mm ) ( Pushes onto round nozzle 5mm ) Speed Welding Nozzle, 3 mm, with narrow air slot Speed Welding Nozzle, 4 mm, with narrow air slot Speed Welding Nozzle, 5 mm, with narrow air slot 110038676 110039076 110039166 ( Pushes onto round nozzle 5mm ) Flat Nozzle 40x2 mm perforated Flat Nozzle 60x2 mm for bitumen Fillet Weld Feeder ( Pushes onto round nozzle 5mm ) Flat Angled Nozzle 40x2 mm Tarpaulin Scissors ( Pushes onto round nozzle 5mm ) 110038728 110039165 110049712 110038670 110038674 Round Nozzle 5 mm Round Nozzle, extended 5 mm Round Nozzle 10 mm Quarter Moon Knife Weld Slide 110014089 110049703 Pressure Roller Ø 45 mm Pressure Roller Ø 35 mm Pressure Roller Ø 50 mm Pressure Roller Ø 33 mm 110048652 110038668 110048653 110049584 110031646 110038455 110048203 ( with ball bearing, single arm, silicone roller ) ( with ball bearing, single arm, silicone roller ) ( with ball bearing, single arm, rubber roller ) ( with ball bearing, single arm, teflon roller ) Speed Welding Nozzle Speed Welding Nozzle with narrow air slot Heat-shrinking sleeves on cables, joints and mouldings Jointing Plane, including replacement blade Scriber 110049706 110038478 Diamond Sharpener 110049705 50 Pressure Roller Ø 30 mm Brass roller 110048202 ABS Plastic Welding Rods 16 pcs PP Plastic Welding Rods 16 pcs HDPE Plastic Welding Rods 16 pcs PVC Plastic Welding Rods 16 pcs 110048756 110048757 110048753 110048754 Soldering Reflector Nozzle Reflector Nozzle 20mm Reflector Nozzle 35mm 110039169 110039167 110039168 Sieve Reflector Nozzle 35x20mm Sieve Reflector Nozzle 50x35mm 110038726 110038725 Shell Reflector Nozzle 150x25mm 110039170 ( After use, the hot air tool must be securely placed in a holder with nozzle attached ) 51 Accessories for HG 2620 E, HG 2520 E Accessories for HB 1750 Temperature scanner Drying and heat-shrinking Temperature Scanner HG Scan PRO Temperature Scanner HG Scan PRO 110033594 110033508 ( HG 2520 E ) ( HG 2620 E ) Accessories for HG 5000 E Welding roof sheeting Heat-shrinking plastics Reducer 7mm Spreader 200mm Large Reflector 50mm Small Reflector 20mm Key Set ( 5 pcs ) 110049693 110049696 110049694 110049695 110050796 Blue Key 200 - 300 °F ( 95 - 150  °C ) Gray Key 300 - 500 °F ( 150 - 260  °C ) Yellow Key 500 - 750 °F ( 260 - 400  °C ) Orange Key 750 - 1000 °F ( 400 - 540  °C ) Red Key 1000 - 1200 °F ( 540 - 650  °C ) 110050525 110050526 110050527 110050528 110050529 Accessories for HG 2220 E, HG 2320 E/ESD, HL 2020 E, HL 1920 E, HL 1820 S, HL 1620 S Removing, shaping and heat-shrinking Flat Nozzle 70x10mm Flat Angled Nozzle 74x3mm 110049715 110049716 Sieve Reflector Nozzle 85 x 85 mm Hinged Reflector Nozzle 72 x 70 mm Shell Reflector Nozzle 250 x 45 mm 110039174 110039171 110039175 ( After use, the hot air tool must be securely placed in a holder with nozzle attached ) Special accessories Heavy Duty Metal Case Metal Heat Gun Stand 103944400 110049032 Spreader Nozzle 50 mm Spreader Nozzle 75 mm Window Nozzle 50 mm Window Nozzle 75 mm Lap Welding Slit Nozzle 20 mm 110048643 110048644 110048750 110048749 110048649 Reduction Nozzle 20 mm Reflector Nozzle 75 mm Reflector Nozzle 39 mm 110048751 110048650 110048645 Accessories for HG 350 ESD Soldering, de-soldering and spot heating Reducer with Guard 5 mm Reflector Nozzle 40 mm Reflector Nozzle 10 mm 110048651 110049699 110049698 52 Precision Reflector Nozzle 110049697 Reduction Nozzle 7 mm 110050181 53 Accessories for HG 2220 E, HG 2320 E/ESD, HL 2020 E, HL 1920 E Soldering, spot heating and heat-shrinking Auto Body repair accessories Reduction Nozzle 6 mm Set Reduction + Reflector Nozzle 9 mm Reduction Nozzle 14 mm 110037033 110048646 110048647 Temperature Guard Wire Mesh ThermoFlexx Welding Rod Welding Iron 110049677 110049676 110049675 110050171 Reduction Nozzle 9mm 110037435 Special accessories Pinpoint Reducer 110049668 Reflector Nozzle 14 mm Sieve Reflector Nozzle 50 x 35 mm 110048752 110038724 Welding plastics, tarpaulins and sheetings Temperature Scanner HL Scan HL Light Fine Dust Filter 110047650 110028647 110048403 ( HG 2320 E, HL 2020 E, HL 1920 E, HL 1820 S ) Plastic Hanger 110045172 ( HG 2320 E, HL 2020 E, HL 1920 E, HL 1820 S ) Welding Nozzle Welding Nozzle Angle Slit Nozzle 40 mm Wide-Slit Nozzle 110048648 110048747 110048748 102270901 ( Pushes onto Reduction Nozzle 9 mm ) ( Pushes onto Reduction Nozzle 9 mm ) Hot Air Tool Stand with Magnetic Base ( HG 2320 E, HL 2020 E, HL 1920 E, HL 1820 S ) 110049586 110049588 ( HG 2320 E, HL 2020 E, HL 1920 E, HL 1820 S, HL 1620 S ) ( HG 2320 E, HL 2020 E, HL 1920 E, HL 1820 S, HL 1620 S ) Heavy Duty Carrying Case Metal Heat Gun Stand Wire Protection Tube 110049790 110049032 110049678 ( Pushes onto Reduction Nozzle 14mm ) Pressure Roller Ø 45 mm Pressure Roller Ø 35 mm Pressure Roller Ø 50 mm Pressure Roller Ø 33 mm 110049584 110031646 110038455 110048203 ( with ball bearing, single arm, silicone roller ) ( with ball bearing, single arm, silicone roller ) ( with ball bearing, single arm, rubber roller ) ( with ball bearing, single arm, teflon roller ) ABS Plastic Welding Rods 16 pcs PP Plastic Welding Rods 16 pcs HDPE Plastic Welding Rods 16 pcs PVC Plastic Welding Rods 16 pcs 110048756 110048757 110048753 110048754 54 Hot Air Tool Stand with Suction Base Tarpaulin Scissors 110038728 55 Products at a glance Hot air tools HG 2620 E HG 2220 E HG 5000 E HG 2520 E HG 2320 E / ESD HL 2020 E HL 1920 E HL 1820 E HL 1620 E HG 350 ESD HB 1750 1750 W 1500 W 3400 W 1750 W 1600 W 1600 W 1500 W 1400 W 1300 W 300 W 1750 W 120 - 1300 °F ( 50-700 °C ) 120 - 1100 °F ( 50-600 °C ) 80-1100 °F ( 20-600 °C ) 120 - 1300 °F ( 50-700 °C ) 120 - 1200 °F ( 50-650 °C ) 120 - 1150 °F ( 50-620 °C ) 120 - 1100 °F ( 50-600 °C ) 120/750/1100 °F ( 50/400/600 °C ) 575/950 °F ( 300/500 °C ) 750 - 930 °F ( 400-500 °C ) 200° - 1200 °F ( 95° - 650 °C ) all 5 keys 13 cfm ( +/- 0.5 cfm ) 12 cfm ( +/- 0.5 cfm ) 28 cfm ( +/- 0.5 cfm ) 13 cfm ( +/- 0.5 cfm ) 13 cfm ( +/- 0.5 cfm ) 13 cfm ( +/- 0.5 cfm ) 13 cfm ( +/- 0.5 cfm ) 13 cfm ( +/- 0.5 cfm ) 13 cfm ( +/- 0.5 cfm ) 3.5 cfm 23 cfm Air pressure 3,000 Pa - 3,000 Pa 3,000 Pa - - - - - - - Motor brushless - brushless brushless - - - - - - - ceramic ceramic ceramic ceramic ceramic ceramic ceramic ceramic ceramic ceramic - Motor life 10,000 hours - 20,000 hours 10,000 hours - - - - - - - Cool air stage 120 °F ( 50  °C ) - 80 °F ( 20  °C ) 120 °F ( 50  °C ) 120 °F ( 50  °C ) 120 °F ( 50  °C ) 120 °F ( 50  °C ) 120 °F ( 50  °C ) - - - Temperature setting continuously variable 9-stage continuously variable continuously variable continuously variable continuously variable 9-stage 3-stage 2-stage 2-stage 5 coded keys Airflow setting continuously variable 2-stage continuously variable continuously variable continuously variable 3-stage 3-stage 3-stage 2-stage 2-stage continuously variable 1.85 lbs ( 29.63 oz ) 1.34 lbs ( 21.51 oz ) 2.62 lbs ( 41.98 oz ) 1.85 lbs ( 29.63 oz ) 1.66 lbs 26.63 oz ) 1.94  lbs ( 31.04 oz ) 1.85 lbs ( 29.63 oz ) 1.76 lbs ( 28.22 oz ) 1.48 lbs ( 23.63 oz ) 1.50 lbs ( 24.00 oz ) 2.90 lbs ( 46.40 oz ) Industrial Grade Rubber Industrial Grade Rubber, length: 6ft Industrial Grade Rubber ( European Plug ) Industrial Grade Rubber Industrial Grade Rubber Industrial Grade Rubber Industrial Grade Rubber, length: 6ft Industrial Grade Rubber, length: 6ft Industrial Grade Rubber, length: 6ft Industrial Grade Rubber, length: 6ft Industrial Grade Rubber, length: 6ft Power cord replacement • • • • • • Plug-in heating element • • • Residual heat indicator • • • • LOC function for saving settings • • • Four memory programs • • • Restart protection • • Suitable for construction site use • • Thermal cut-out • • • • • • • Power Temperature Max. airflow rate Heating element Weight without power cord Power cord • • • Overheating protection Professional STEINEL Nozzles Pressure Fit Standard Nozzles 56 • • • • • • • • • • • 57 Gas Torches: Red-hot perfection. Professionals know how important the right tool is. But we don’t just want to offer you a tool for the job you are doing – we want to offer you the best one. This is why we are working on making our gas torches even more powerful, efficient and convenient to use. The consistent use of innovative technologies and high-quality materials lets us make sure that you can rely on the portable torches from STEINEL in any situation. Whether for the odd minor repair or for everyday use in industry 58 59 Ready for anything. Ultimate Butane Kit. The ultimate solution for any conceivable challenge: The kit includes no fewer than three professional tools as well as a wide range of accessories. The cordless TT 175, TT 30 and TS 550 gas torches reach their respective operating temperatures within a maximum of just 20 seconds and are suitable for virtually any application – from soldering or de-soldering to working on foam and heating heat-shrinkable tubing. Providing maximum flexibility, the kit contains a wide selection of attachments that can be changed quickly and easily. Also included in the Ultimate Butane Kit are two gas bottles, cleaning tools and a selection of heat-shrinkable tubes – all perfectly packed in a high-quality tool case. Available in a convenient carrying case. Technical specifications Temperature: TS 550: 480 - 1000 °F ( 250 - 550 °C ) soldering tip 2400 °F ( 1316 °C ) torch 1400 °F ( 750 °C ) flamesless heat TH 310: Catalytic Tip 1400 °F ( 750 °C ) TT 175: 2400 °F ( 1316 °C ) TT 30: 2400 °F ( 1316 °C ) Operation Time: T  S 550: 160 min TT 175: 120 min TT 30: 30 min Fuel Capacity: TS 550: 25 ml TT 175: 60 ml refillable fuel tank TT 30: 5 ml refillable see-trough fuel tank Fuel Type: Standard butane fuel Dimensions ( l × w × h ): 12.60" × 4.20" × 12.30" Weight: 4.80 lbs ( 76.80 oz ) Warranty: One year limited Heat Chemicals with the ThermaTorch™ 270 60 Ordering details 110049879 ( silver case, including TT 175 Torch, TT 30 Torch, TS 550 Soldering Iron, TS 21 Conical Tip ( installed ), 2 - 1 oz Butane Canisters, TH 310 Flameless Catalytic Tip, TS 20 Deflector, TS 25 Hot Knife, TS 23 Chisel, TS 27 Heat Blower, TS 29 Spare Orifice, Hands-Free Stand, Tip Cleaning Sponge, Solder Dispenser, Shrink Tube Assortment ) 61 Top model for the most exacting of demands. Gas torch TT 270 Preferred choice for hundreds of applications. Gas torch TT 175 The ThermaTorch™ 270 keeps even the most extreme of temperatures perfectly under control: It produces a 2,500 °F flame that burns steadily and evenly all the time. The flame intensity can be infinitely varied. Featuring a refillable tank holding 60 milliliters of butane gas, the TT 270 can be operated continuously for up to 120 minutes. This makes it the ideal tool for challenging jobs whenever maximum performance is required. From automotive repairs and plumbing jobs to industrial use, the ThermaTorch™ 175 makes very easy work of heating, soldering and de-soldering. The steady flame reaches a temperature of 2,400 °F and, like the airflow rate, can be adjusted to suit any application. In addition to its exceptional quality finish, the tool also leaves no margin of doubt with its 60-milliliter tank that enables over 120 minutes of uniterrupted use. Technical specifications Temperature: 2500 °F (  1300 °C ) Operation Time: Up to 120 min (  90 min at mid setting ) Fuel Capacity: 60 ml refillable fuel tank Fuel Type: Standard butane fuel Ignition: Water proof piezo electronic system Dimensions ( l × w × h ): 6.25" × 4.70" × 2.50" Weight: 0.64 lb ( 10.24 oz ) Warranty: One year limited Solder joints on copper piping 62 Technical specifications Temperature: 2400 °F ( 1316 °C ) Operation Time: 120 min continuous use Fuel Capacity: 60 ml refillable fuel tank Fuel Type: Standard butane fuel Ignition: Water proof piezo electronic system Dimensions ( l × w × h ): 5.25" × 4.00" × 1.50" Weight: 0.59 lb ( 9.44 oz ) Warranty: One year limited Butane optional Ordering details 110049861 ( folding box ) Single Sell Pack Dimensions: 9.50" × 5.60" × 3.00" Single Sell Pack Weight: 0.87 lb ( 13.92 oz ) Ordering details 110049860 ( folding box ) Single Sell Pack Dimensions: 7.40" × 5.50" × 1.75" Single Sell Pack Weight: 0.78 lb ( 12.48 oz ) Accessories 110049855 BT 01 Triple filtered Butane 1 oz ( 28.4 gm ) 110049856 BT 05 Triple filtered Butane 5 oz ( 142 gm ) Accessories 110049855 BT 01 Triple filtered Butane 1 oz ( 28.4 gm ) 110049856 BT 05 Triple filtered Butane 5 oz ( 142 gm ) Butane optional Repair, bend and mold prosthetics 63 More ergonomics, less weight. Gas torch TT 151 Mini-tool providing maximum performance. Gas torch TT 30 The ThermaTorch™ 151 weighs in at a mere 0.3 pounds but is still packed with powerful advantages: The temperature of the butane flame reaches 2,400 °F and can be adjusted in any way to suit the job in hand. In addition its compact size, the multi-purpose tool impresses with its ergonomically designed grip handle and stable standing surface. The refillable butane gas tank holds 20 milliliters and produces approximately 60 minutes of work with a medium flame. Small, practical, reliable – the ThermaTorch™ 30 not only fits into any pocket, it also does a great job even under difficult conditions. The flame even burns in strong winds at an adjustable temperature of up to 2,400 °F. The ignition system is watertight. And the self-closing cap protects the tool from soiling. This makes the TT 30 a great helper in the field – whether for professional or personal use. Technical specifications Temperature: 2400 °F ( 1316 °C ) Operation Time: 60 min at mid setting Fuel Capacity: 20 ml refillable fuel tank Fuel Type: Standard butane fuel Ignition: Water proof piezo electronic system Dimensions ( l × w × h ): 5.50" × 4.00" × 2.50" Weight: 0.31 lb ( 4.96 oz ) Warranty: One year limited Technical specifications Temperature: 2400 °F ( 1316 °C ) Operation Time: 30 min Fuel Capacity: 5 ml refillable see-through fuel tank Fuel Type: Standard butane fuel Dimensions ( l × w × h ): 0.88" × 0.63" × 1.50" Weight: 0.11 lb ( 1.76 oz ) Warranty: One year limited Butane optional Ordering details 110049857 ( blister ) Single Sell Pack Dimensions: 6.00" × 4.00" × 1.63" Single Sell Pack Weight: 0.15 lb ( 2.40 oz ) Ordering details 110049860 ( folding box ) Single Sell Pack Dimensions: 8.00" × 4.88" × 2.63" Single Sell Pack Weight: 0.50 lb ( 8.00 oz ) Accessories 110049855 BT 01 Triple filtered Butane 1 oz ( 28.4 gm ) 110049856 BT 05 Triple filtered Butane 5 oz ( 142 gm ) Accessories 110049855 BT 01 Triple filtered Butane 1 oz ( 28.4 gm ) 110049856 BT 05 Triple filtered Butane 5 oz ( 142 gm ) Caramelize Crème Brule easily 64 Butane optional Thaw Frozen Locks with a wind proof flame. 65 The authority in its field. Gas soldering iron TS 600 / TS 600 K One tool – countless options. Gas soldering iron TS 550 / TS 550 K The ThermaSolder™ 600 lets you get more done. Its tank has a capacity of 38 milliliters, providing an amazing 200 minutes of use. But these are not the only top specifications the gas soldering iron can offer. It also produces a powerful output of 30 to 125 watts as well as temperatures of up to 2,400 °F. The wide range of accessories makes it ideal for countless applications. The TS 600 K kit contains a heat blower tip that generates flameless heat of 1,400 °F, a soldering tip that can be heated to 1,000 °F and many other attachments for getting virtually any job done professionally and quickly. Prepared for anything: The powerful and quality-crafted Therma­ Solder™ 550 gas soldering iron delivers a temperature of 2,400 °F – and top results in numerous applications. The TS 550 Kit features accessories that are ideal for soldering at up to 1,000 °F, cutting foam, repairing jewelry and working on many other materials with ease. The gas soldering iron can be used continuously for approximately 160 minutes on a single butane gas filling of 25 milliliters. It generates an output of 30 to 125 watts – without any power cords to get in the way. As with the TS 600, it features a reliable piezo igniter and reaches its optimum operating temperature in a mere 15 seconds. Create an even seal on solder sleeves 66 Technical specifications Soldering Iron Tip: 480 - 1000 °F ( 250 - 550 °C ) Torch: 2400 °F ( 1316 °C ) Flameless Heat: 1400 °F ( 750 °C with available hot air blower tip ) Operation Time: 200 min Fuel Capacity: 38 ml refillable fuel tank Butane Fuel Type: Standard butane fuel optional Ignition: Piezo electronic system with 15 sec. heat-up Dimensions ( l × w×h ): 9.75" × 1.20" × 1.25" Weight: 0.34 lbs ( 5.44 oz ) Warranty: One year limited Kit Contents: TS 600 Soldering Iron, Heat Blower Tip, Reflector Tip, Hot Knife Tip, Chisel Tip, Soldering Tip, Spare Orifice, Solder with Dispenser, Tip Cleaning Sponge, Protective Cap and Case Technical specifications Soldering Iron Tip: 480 - 1000 °F ( 250 - 550 °C ) Torch: 2400 °F ( 1316 °C ) Flameless Heat: 1400 °F ( 750 °C with available hot air blower tip ) Operation Time: 160 min Fuel Capacity: 25 ml refillable fuel tank Butane Fuel Type: Standard butane fuel optional Ignition: Piezo electronic system with 15 sec. heat-up Dimensions ( l × w × h ): 9.00" × 1.20" × 1.22" Weight: 0.20 lb ( 3.20 oz ) Warranty: One year limited Kit Contents: TS 550 Soldering Iron, Heat Blower Tip, Reflector Tip, Hot Knife Tip, Chisel Tip, Soldering Tip, Spare Orifice, Solder with Dispenser, Tip Cleaning Sponge, Protective Cap and Case Ordering details TS 600: 110049875 ( blister ) TS 600 K: 110049876 ( case ) Single Sell Pack Dimensions: TS 600 12.00" × 4.00" × 1.25" TS 600 K 12.00" × 6.60" × 2.00" Single Sell Pack Weight: TS 600 0.50 lb ( 8.00 oz ) TS 600 K 1.47 lbs ( 23.52 oz ) Ordering details TS 550: 110049873 ( blister ) TS 550 K: 110049874 ( case ) Single Sell Pack Dimensions: TS 550 12.00" × 4.00" × 1.35" TS 550 K 13.50" × 5.70" × 2.10" Single Sell Pack Weight: TS 550 0.35 lb ( 5.60 oz ) TS 550 K 1.41 lbs ( 22.56 oz ) Accessories 110049855 BT 01 Triple filtered Butane 1 oz ( 28.4 gm ) 110049856 BT 05 Triple filtered Butane 5 oz ( 142 gm ) Jewelry repair and fine detailed work Accessories 110049855 BT 01 Triple filtered Butane 1 oz ( 28.4 gm ) 110049856 BT 05 Triple filtered Butane 5 oz ( 142 gm ) 67 A whole raft of benefits. Gas soldering iron TS 500 and TS 500 K STEINEL quality to take with you. Gas torch TH 310 Heat up for 20 seconds – work for 120 minutes: The cordless ThermaSolder™ 500 has a 20-milliliter butane tank that enables uninterrupted use of the gas soldering iron even over prolonged periods. The gas soldering iron flame reaches a temperature of 2,400 °F while producing an output of 25 to 80 watts. The medium-sized TS 500 K contains the most important extras for professional soldering or de-soldering, for modeling plastics, cutting foam, fitting plug connectors and more. As with the TS 600 K and TS 550 K, all parts come in a practical case that ensures space-saving and safe storage. Whether in the workshop or in the field, the portable highperformance ThermaHeat™ 310 gas torch is always handy and reaches an operating temperature of 1,400 °F in just 15 seconds. It generates flameless heat that can be used for all manner of applications. The TH 310 comes with a convenient piezo igniter and a butane gas tank with a ca­pacity of 38 milliliters, and can be operated for a full 120 minutes on a single tank. It also comes with an attach­ able deflector for working with heat-shrinkable tubing. Including deflector Technical specifications Soldering Iron Tip: 410 - 850 °F ( 210 - 450 °C ) Torch: 2400 °F ( 1316 °C ) Flameless Heat: 1400 °F ( 750 °C with available hot air blower tip ) Operation Time: 120 min Fuel Capacity: 20 ml refillable fuel tank Butane Fuel Type: Standard butane fuel optional Ignition: Manual ignition Dimensions ( l × w × h ): 8.50" × 1.00" × 1.00" Weight: 0.14 lb ( 2.24 oz ) Warranty: One year limited Kit Contents: TS 500 Soldering Iron, Heat Blower Tip, Reflector Tip, Hot Knife Tip, Blow Torch Tip, Soldering Tip, Tip Cleaning Sponge, Protective Cap and Case Technical specifications Flameless Heat: 1400 °F ( 750 °C ) Operation Time: Up to 120 min continuous use Fuel Capacity: 38 ml refillable fuel tank Fuel Type: Standard butane fuel Ignition: Piezo electronic system with 15 sec. heat-up Dimensions ( l × w × h ): 8.75" × 1.20" × 1.25" Weight: 0.23 lb ( 3.68 oz ) Warranty: One year limited Ordering details 110049877 ( blister including deflector ) Single Sell Pack Dimensions: 12.00" x 4.00" × 1.50" Single Sell Pack Weight: 0.30 lb ( 4.80 oz ) Accessories 110049855 BT 01 Triple filtered Butane 1 oz ( 28.4 gm ) 110049856 BT 05 Triple filtered Butane 5 oz ( 142 gm ) Ordering details TS 500: 110049871 ( blister ) TS 500 K: 110049872 ( case ) Single Sell Pack Dimensions: TS 500 10.00" × 4.00" × 1.10" TS 500 K 10.75" × 10.40" × 1.90" Single Sell Pack Weight: TS 500 0.23 lb ( 3.68 oz ) TS 500 K 0.87 lbs ( 13.92 oz ) Desolder and solder circuit boards with precision 68 Accessories 110049855 BT 01 Triple filtered Butane 1 oz ( 28.4 gm ) 110049856 BT 05 Triple filtered Butane 5 oz ( 142 gm ) Butane optional Work on dental products with accuracy 69 Products at a glance Gas Torches TT270 Solder joints on copper piping TS 500 Desolder and solder circuit boards with precision TT 270 TT 175 TT 151 TT 30 TS 600 TS 550 TS 500 TH 310 2500 °F (  1300 °C ) 2400 °F (  1316 °C ) 2400 °F (  1316 °C ) 2400 °F (  1316 °C ) - - - - Soldering Iron Tip - - - - 480° - 1000 °F ( 250 - 550 °C ) 480° - 1000 °F ( 250 - 550 °C ) 410° - 850 °F ( 210 - 450 °C ) - Torch - - - - 2400 °F (  1316 °C ) 2400 °F (  1316 °C ) 2400 °F (  1316 °C ) - Flamesless Heat - - - - 1400 °F ( 750 °C ) with availabele hot air blower tip 1400 °F ( 750 °C ) with availabele hot air blower tip 1400 °F ( 750 °C ) with availabele hot air blower tip 1400 °F ( 750 °C ) 60 ml refillable 60 ml refillable 20 ml refillable 5 ml refillable see-through 38 ml refillable 25 ml refillable 20 ml refillable 38 ml refillable Up to 120 min (  90 min at mid setting ) 120 min continuous use 60 min at mid setting 30 min 200 min 160 min 120 min Up to 120 min continuous use Standard butane fuel Standard butane fuel Standard butane fuel Standard butane fuel Standard butane fuel Standard butane fuel Standard butane fuel Standard butane fuel Water proof piezo electronic system Water proof piezo electronic system Water proof piezo electronic system Water proof automatic ignition system Piezo electronic system with 15 sec. heat-up Piezo electronic system with 15 sec. heat-up Manual ignition Piezo electronic system with 15 sec. heat-up 0.87" ( 22.1 mm ) 0.78" ( 19.8 mm ) 0.79" ( 20.0mm ) 0.66" ( 16.75 mm ) 0.06" ( 1.52 mm ) 0.06" ( 1.52 mm ) 0.06" ( 1.52 mm ) 0.78" ( 19.9 mm ) 6.25" × 4.70" × 2.50" 5.25" × 4.00" × 1.50" 5.50" × 4.00" × 2.50" 0.88 × 0.63" × 1.50" 9.75" × 1.200" × 1.25" 9.00" × 1.20" × 1.22" 8.50" × 1.00" × 1.00" 8.75" × 1.20" × 1.25" Weight 0.64 lb ( 10.24 oz ) 0.59 lb ( 9.44 oz ) 0.31 lb ( 4.96 oz ) 0.11 lb ( 1.76 oz ) 0.34 lb ( 5.44 oz ) 0.20 lb ( 3.20 oz ) 0.14 lb ( 2.24 oz ) 0.23 lb ( 3.68 oz ) Warranty One year limited One year limited One year limited One year limited One year limited One year limited One year limited One year limited Adjustable airflow setting - yes - - - - - - Adjustable flame control - yes yes yes - - - - Adjustable heat output - - - - - - - yes Temperature Fuel Capacity fuel tank Operation Time Fuel Type Ignition Nozzle Diameter / Tip Dimensions Dimensions ( l × w × h ) 70 71 The declaration of independence for professionals. Hot-melt glue applicator TM 6000 Full freedom of movement rather than an annoying cable: Operating on butane gas, the TM 6000 requires no electrical power source which means it can be used virtually anywhere. The extremely sturdy hot-melt glue applicator reaches its operating temperature in just 3 minutes. Its fuel cells are based on innovative LEC™ technology. The cells can be quickly changed in just a few seconds and enable continuous use for up to 100 minutes. At the same time, the TM 6000 impresses with a fast, even flow of glue during use – and stops the glue from flowing immediately afterwards. This reduces dripping to a minimum. The professional tool is suitable for glue cartridges with a diameter of 1/2 inch and a melting temperature of 320 to 464 °F. Instant Glue Flow Cut-Off Sturdy Metal Stand LEC™ Fuel Cell Ignition Button Technical specifications Melt Temperature: 320 °F - 464 °F ( 160 °C - 240 °C ) Operating Time: 100 min Fuel Type: standard butane fuel Ignition: Piezo electronic system Nozzle Diameter: 0.08" ( 2 mm ) Dimensions ( l × w × h ): 9.00" × 7.50" × 2.00" Weight: 0.75 lbs ( 12.00 oz ) Warranty: One year limited Ordering details 110049878 ( blister ), 1.30 lbs ( 43.52 oz ) Single Sell Pack Dimensions: 12.50" × 12.50" × 2.20" Single Sell Pack Weight: 1.30 lbs ( 43.52 oz ) Accessories Glue sticks with 1/2" diameter on page 76 Glue packaging with ease and efficiency. 72 73 Combines simplicity and high-tech. Hot-melt glue applicator GF 3002 Designed for making gluing work even easier: The GlueFix™ 3002 weighs just 0.7 pounds, impresses with intuitive operation and enables fatigue-free working over long periods. It produces a constant, precision flow of glue which is instantly interrupted by the anti-drip nozzle after use. Made of die-cast aluminum, the heating chamber stores heat to optimize throughput. At the same time, the unique PTC ( positive temperature control ) electronic heating system constantly ensures the ideal gluing temperature – throughout the entire period of use. Given its exceptional level of performance, the GF 3002 is appreciated both in industry as well as in the trades where it is used for bonding all kinds of materials. Ready for use in 7 min Interchangeable gluing nozzles Technical specifications Melt Temperature: 400 °F ( 204 °C ) Melting Capacity: High 7.5 gm / minute Warm Up Time: Quick 7 minutes Nozzle Diameter: 0.08" ( 2mm ) Dimensions ( l × w × h ): 8.00" × 7.00" × 1.85" Weight: 0.71 lb ( 11.36 oz ) Warranty: One year limited Ordering details 110049902 ( folding box ) Single Sell Pack Dimensions: 10.25" × 6.75" × 1.75" Single Sell Pack Weight: 1.10 lbs ( 17.60 oz ) Accessories Interchangeable nozzles and glue sticks: 1/2" diameter on page 76 Glue woodwork with precision 74 75 Better gluing results with the right glue. The right stick for any demand. 1/2" dia. glue sticks for TM 6000 and GF 3002 Interchangeable nozzles for GF 3002 G 200 C - Clear Glue Sticks GF 14 - Carton Glue Sticks GF 23 - Wood Glue Sticks 110049649, 1 lb 110049794, 1 kg 110049643, 1 lb 110049644, 11 lbs 110049637, 1 lb 110049638, 11 lbs Nozzle 2 mm Ideal for all normal gluing jobs 110049583 GF 213 - Laminate Glue Sticks GF 232 - General Purpose Glue Sticks GF 260 - High Strength Glue Sticks 110049640, 1 lb 110049641, 11 lbs 110049634, 1 lb 110049635, 11 lbs 110049646, 1 lb 110049647, 11 lbs 2.8 mm Fine Tip Nozzle Precision metering at hard-to-reach places 1 mm Nozzle Exact metering for high-precision gluing applications 110049582 110019581 12 mm Spreader Nozzle Wide nozzle for carton sealing 110049580 Application Glue Guide Open TIme ABS PP / PC / HDPE / LDPE Polystyrene PVC Glass Reinforced Plastic Aluminum Stainless Steel EPS Foam Wood Sand Mold Glass Cardboard Medium + + +++ + + + ++++ ++ ++ +++ +++ GF 14 Carton Fast + + ++ + ++ +++ ++ + ++++ + ++++ GF 23 Wood Long ++ + +++ + ++ +++ +++ ++++ ++++ + +++ GF 213 Laminate Long + + +++ +++ ++ +++ +++ ++ ++ + +++ HG 260 Hi Strength Long +++ + +++ ++ +++ +++ ++ ++++ + +++ +++ GF 232 General + Poor 76 ++ Fair +++ Good ++++ Very Good 77 Summary of order numbers Precision Hot Air Tool Heat gun HG 350 ESD........................................................... 109964900 ( folding box )........................................................ 45 Heat gun HG 350 ESD .......................................................... 110049739 ( Precision Heat Gun Kit )....................................... 45 Professional Heat Blower Hot Air Barrel Tools HG 2620 E............................................................................. 110025600 ( folding box )........................................................... 9 HG 2620 E............................................................................. 110047485 ( case )..................................................................... 9 Temperature scanner HG Scan PRO for HG 2620 E.............. 110033508 ( folding box )......................................................... 11 HG 2220 E............................................................................. 110025601 ( folding box )......................................................... 13 HG 5000 E............................................................................. 104201504 ( folding box )......................................................... 15 HG 5000 E............................................................................. 110049782 ( case )................................................................... 15 Heat blower HB 1750............................................................. 109486800 HB 1750 with all 5 keys ( folding box )................... 47 Heat blower HB 1750 ............................................................ 110049973 HB 1750 with blue key ( folding box )..................... 47 Heat blower HB 1750 ............................................................ 110049974 HB 1750 with gray key ( folding box )..................... 47 Heat blower HB 1750 ............................................................ 110049975 HB 1750 with yellow key ( folding box ).................. 47 Heat blower HB 1750 ............................................................ 110049976 HB 1750 with orange key ( folding box )................. 47 Heat blower HB 1750 ............................................................ 110049977 HB 1750 with red key ( folding box )....................... 47 Heat blower HB 1750 ............................................................ 110049745 HB 1750 Kit ( case )............................................... 47 Pistol Grip Hot Air Tool Hot Air Tool Accessories HG 2520 E............................................................................. 110025599 ( case )................................................................... 21 Temperature scanner HG Scan PRO for HG 2520 E.............. 110033594 ( folding box )......................................................... 23 HG 2320 E............................................................................. 110025598 ( folding box )......................................................... 25 HG 2320 E ESD..................................................................... 110025697 ( folding box )......................................................... 25 HL 2020 E.............................................................................. 110025597 ( folding box )......................................................... 27 HL 1920 E.............................................................................. 110025596 ( folding box )......................................................... 29 Temperature scanner HL Scan for HG 2320 E – HL 1820 S... 110048403 ( folding box )......................................................... 31 HL 1820 S.............................................................................. 110025541 ( folding box )......................................................... 33 HL 1620 S.............................................................................. 110023455 ( folding box )......................................................... 35 Accessories for HG 2620 E, HG 2520 E Speed Welding Nozzle 3 mm.................................................. 110038331.............................................................................. 50 Speed Welding Nozzle 4 mm.................................................. 110038332............................................................................. 50 Speed Welding Nozzle 5 mm.................................................. 110038333............................................................................. 50 Speed Welding Nozzle, 3 mm, with narrow air slot................. 110038676.............................................................................. 50 Speed Welding Nozzle, 4 mm, with narrow air slot................. 110039076.............................................................................. 50 Speed Welding Nozzle, 5 mm, with narrow air slot................. 110039166.............................................................................. 50 Round Nozzle 5 mm............................................................... 110048652.............................................................................. 50 Round Nozzle, extended 5mm............................................... 110038668............................................................................. 50 Round Nozzle 10 mm............................................................. 110048653............................................................................. 50 Quarter Moon Knife ............................................................... 110014089.............................................................................. 50 Weld Slide ............................................................................. 110049703.............................................................................. 50 Jointing Plane, including replacement blade........................... 110038478.............................................................................. 50 Scriber................................................................................... 110049706.............................................................................. 50 Pressure Roller Ø 30 mm Brass roller..................................... 110048202.............................................................................. 50 Diamond Sharpener............................................................... 110049705.............................................................................. 50 ABS Plastic Welding Rods 16 pcs.......................................... 110048756.............................................................................. 50 PP Plastic Welding Rods 16 pcs............................................ 110048757.............................................................................. 50 HDPE Plastic Welding Rods 16 pcs........................................ 110048753.............................................................................. 50 PVC Plastic Welding Rods 16 pcs.......................................... 110048754.............................................................................. 50 Flat Angled Nozzle 20x2 mm.................................................. 110049713.............................................................................. 51 Flat Angled Nozzle 20x2 mm, straight.................................... 110037580.............................................................................. 51 Flat Angled Nozzle 20x2 mm, 100°........................................ 106934900............................................................................. 51 Flat Angled Nozzle 30x2 mm, 60°.......................................... 110039176.............................................................................. 51 Flat Angled Nozzle 40x2 mm ................................................. 110049712 ............................................................................. 51 Flat Nozzle 40x2 mm perforated............................................ 110038670.............................................................................. 51 Flat Nozzle 60x2 mm for bitumen........................................... 110038674.............................................................................. 51 Tarpaulin Scissors ................................................................. 110038728.............................................................................. 51 Fillet Weld Feeder .................................................................. 110039165.............................................................................. 51 Hot Air Tool Specials HG 2320 E Auto Body Welding Kit with Temp Scanner.......... 110051530.............................................................................. 38 HG 2320 E Auto Body Welding Kit......................................... 110051531.............................................................................. 38 HG 2320 E Deluxe Plastic Welding Kit with Temp Scanner.... 110051535.............................................................................. 38 HG 2320 E Deluxe Plastic Welding Kit.................................... 110051536.............................................................................. 39 HG 2320 E Electronics Kit...................................................... 110051533.............................................................................. 39 HG 2320 E Multi Purpose Kit.................................................. 110051534.............................................................................. 39 HL 2020 E Automotive Kit with Temp Scanner ...................... 110051550.............................................................................. 40 HL 2020 E Automotive Kit ..................................................... 110051537.............................................................................. 40 HL 2020 E Plastic Welding Kit ............................................... 110051538.............................................................................. 40 HL 2020 E Silver Kit............................................................... 110051541.............................................................................. 41 HL 2020 E Platinum Kit ......................................................... 110051542.............................................................................. 41 HL 2020 E Multi Purpose Kit ................................................. 110051539.............................................................................. 41 HL 1920 E Industrial Kit.......................................................... 110051543.............................................................................. 42 HL 1920 E Platinum Kit.......................................................... 110051545.............................................................................. 42 HL 1920 E Classic Kit ............................................................ 110051546.............................................................................. 42 HL 1920 E Multi Purpose Kit ................................................ 110051544.............................................................................. 43 HL 1820 S General Pupose Kit............................................... 110051547.............................................................................. 43 78 79 Pressure Roller Ø 45 mm....................................................... 110049584............................................................................. 51 Pressure Roller Ø 35 mm....................................................... 110031646.............................................................................. 51 Pressure Roller Ø 50 mm....................................................... 110038455............................................................................. 51 Pressure Roller Ø 33 mm....................................................... 110048203.............................................................................. 51 Soldering Reflector Nozzle..................................................... 110039169.............................................................................. 51 Reflector Nozzle 20mm.......................................................... 110039167.............................................................................. 51 Reflector Nozzle 35mm.......................................................... 110039168.............................................................................. 51 Sieve Reflector Nozzle 35x20mm........................................... 110038726.............................................................................. 51 Sieve Reflector Nozzle 50x35mm........................................... 110038725.............................................................................. 51 Shell Reflector Nozzle 150x25mm.......................................... 110039170.............................................................................. 51 Accessories for HG 2620 E, HG 2520 E Temperature Scanner HG Scan PRO for HG 2520 E.............. 110033594............................................................................. 52 Temperature Scanner HG Scan PRO for HG 2620 E.............. 110033508............................................................................. 52 Accessories for HG 5000 E Flat Nozzle 70x10mm............................................................. 110049715.............................................................................. 52 Flat Angled Nozzle 74x3mm................................................... 110049716.............................................................................. 52 Sieve Reflector Nozzle 85x85mm........................................... 110039174.............................................................................. 52 Hinged Reflector Nozzle 72x70mm........................................ 110039171.............................................................................. 52 Shell Reflector Nozzle 250x45mm.......................................... 110039175.............................................................................. 52 Heavy Duty Metal Case.......................................................... 103944400............................................................................. 52 Metal Heat Gun Stand ........................................................... 110049032............................................................................. 52 Accessories for HG 350 ESD Reducer with Guard 5mm...................................................... 110048651.............................................................................. 52 Reflector Nozzle 40mm.......................................................... 110049699............................................................................. 52 Reflector Nozzle 10mm.......................................................... 110049698............................................................................. 52 Precision Reflector Nozzle...................................................... 110049697.............................................................................. 52 Reduction Nozzle 7mm.......................................................... 110050181.............................................................................. 52 Accessories for HB 1750 Reducer 7mm........................................................................ 110049693............................................................................. 53 Spreader 200mm................................................................... 110049696............................................................................. 53 Large Reflector 50mm............................................................ 110049694............................................................................. 53 Small Reflector 20mm............................................................ 110049695............................................................................. 53 Key Set ( 5 pcs )...................................................................... 110050796.............................................................................. 53 Blue Key 200 - 300 °F ( 95 - 150  °C )......................................... 110050525.............................................................................. 53 Gray Key 300 - 500 °F ( 150 - 260  °C )....................................... 110050526.............................................................................. 53 Yellow Key 500 - 750 °F ( 260 - 400  °C ).................................... 110050527.............................................................................. 53 Orange Key 750 - 1000 °F ( 400 - 540  °C )................................ 110050528.............................................................................. 53 Red Key 1000 - 1200 °F ( 540 - 650  °C ).................................... 110050529.............................................................................. 53 80 Accessories for HG 2220 E, HG 2320 E/ESD, HL 2020 E, HL 1920 E, HL 1820 S, HL 1620 S Spreader Nozzle 50mm......................................................... 110048643............................................................................. 53 Spreader Nozzle 75mm.......................................................... 110048644............................................................................. 53 Window Nozzle 50mm........................................................... 110048750.............................................................................. 53 Window Nozzle 75mm........................................................... 110048749.............................................................................. 53 Lap Welding Slit Nozzle 20mm............................................... 110048649............................................................................. 53 Reduction Nozzle 20mm........................................................ 110048751.............................................................................. 53 Reflector Nozzle 75mm.......................................................... 110048650............................................................................. 53 Reflector Nozzle 39mm.......................................................... 110048645............................................................................. 53 Accessories for HG 2220 E, HG 2320 E/ESD, HL 2020 E, HL 1920 E Reduction Nozzle 6mm.......................................................... 110037033.............................................................................. 54 Set Reduction + Reflector Nozzle 9mm ................................. 110048646............................................................................. 54 Reduction Nozzle 14mm........................................................ 110048647.............................................................................. 54 Pinpoint Reducer................................................................... 110049668............................................................................. 54 Reflector Nozzle 14mm.......................................................... 110048752.............................................................................. 54 Sieve Reflector Nozzle 50x35mm........................................... 110038724.............................................................................. 54 Welding Nozzle ..................................................................... 110048648............................................................................. 54 Welding Nozzle...................................................................... 110048747.............................................................................. 54 Angle Slit Nozzle 40 mm........................................................ 110048748.............................................................................. 54 Wide-Slit Nozzle..................................................................... 102270901............................................................................. 54 Pressure Roller Ø 45 mm....................................................... 110049584............................................................................. 54 Pressure Roller Ø 35 mm....................................................... 110031646.............................................................................. 54 Pressure Roller Ø 50 mm....................................................... 110038455............................................................................. 54 Pressure Roller Ø 33 mm....................................................... 110048203.............................................................................. 54 ABS Plastic Welding Rods 16 pcs.......................................... 110048756.............................................................................. 54 PP Plastic Welding Rods 16 pcs............................................ 110048757.............................................................................. 54 HDPE Plastic Welding Rods 16 pcs........................................ 110048753.............................................................................. 54 PVC Plastic Welding Rods 16 pcs.......................................... 110048754.............................................................................. 54 Tarpaulin Scissors.................................................................. 110038728.............................................................................. 54 Temperature Guard................................................................ 110049677.............................................................................. 55 Wire Mesh.............................................................................. 110049676.............................................................................. 55 ThermoFlexx Welding Rod..................................................... 110049675.............................................................................. 55 Welding Iron .......................................................................... 110050171.............................................................................. 55 Reduction Nozzle 9mm ......................................................... 110037435.............................................................................. 55 Temperature Scanner HL Scan.............................................. 110048403............................................................................. 55 HL Light................................................................................. 110047650.............................................................................. 55 Fine Dust Filter....................................................................... 110028647.............................................................................. 55 Hot Air Tool Stand with Suction Base..................................... 110049586............................................................................. 55 Hot Air Tool Stand with Magnetic Base.................................. 110049588............................................................................. 55 Plastic Hanger........................................................................ 110045172.............................................................................. 55 Heavy Duty Carrying Case..................................................... 110049790.............................................................................. 55 Metal Heat Gun Stand............................................................ 110049032............................................................................. 55 Wire Protection Tube.............................................................. 110049678.............................................................................. 55 81 Gas Torches Ultimate Butane Kit................................................................ 110049879 ( silver case ).......................................................... 61 TT 270.................................................................................... 110049861 ( folding box )......................................................... 62 TT 175 ................................................................................... 110049860 ( folding box )......................................................... 63 TT 151.................................................................................... 110049860 ( folding box )......................................................... 64 TT 30 .................................................................................... 110049857 ( blister ) ................................................................ 65 TS 600................................................................................... 110049875 ( blister )................................................................. 66 TS 600 K................................................................................ 110049876 ( case )................................................................... 66 TS 550................................................................................... 110049873 ( blister )................................................................. 67 TS 550 K................................................................................ 110049874 ( case )................................................................... 67 TS 500................................................................................... 110049871 ( blister )................................................................. 68 TS 500 K................................................................................ 110049872 ( case )................................................................... 68 TH 310................................................................................... 110049877 ( blister including deflector )................................... 69 Gas Torches Accessories Triple filtered Butane 1 oz ( 28.4 gm )....................................... 110049855 Triple filtered Butane 5 oz ( 142 gm )........................................ 110049856 Hot-Melt Adhesive Systems Hot-melt glue applicator TM 6000 ......................................... 110049878 ( blister )................................................................. 73 Hot-melt glue applicator GF 3002 ......................................... 110049902 ( folding box ) ........................................................ 75 Hot-Melt Adhesive Systems Accessories G 200 C - Clear Glue Sticks, 1 lb............................................ 110049649............................................................................. 76 G 200 C - Clear Glue Sticks, 1 kg........................................... 110049794.............................................................................. 76 GF 14 - Carton Glue Sticks, 1 lb.............................................. 110049643............................................................................. 76 GF 14 - Carton Glue Sticks, 11 lbs........................................... 110049644............................................................................. 76 GF 23 - Wood Glue Sticks, 1 lb............................................... 110049637.............................................................................. 76 GF 23 - Wood Glue Sticks, 11 lbs............................................ 110049638............................................................................. 76 GF 213 - Laminate Glue Sticks, 1 lb........................................ 110049640............................................................................. 76 GF 213 - Laminate Glue Sticks, 11 lbs..................................... 110049641.............................................................................. 76 GF 232 - General Purpose Glue Sticks, 1 lb............................ 110049634............................................................................. 76 GF 232 - General Purpose Glue Sticks, 11 lbs......................... 110049635............................................................................. 76 GF 260 - High Strength Glue Sticks, 1 lb................................. 110049646............................................................................. 76 GF 260 - High Strength Glue Sticks, 11 lbs ............................. 110049647.............................................................................. 76 Nozzle 2 mm.......................................................................... 110049583............................................................................. 77 2.8 mm Fine Tip Nozzle ......................................................... 110049582.............................................................................. 77 1 mm Nozzle ......................................................................... 110019581.............................................................................. 77 12 mm Spreader Nozzle ........................................................ 110049580............................................................................. 77 82 Quality and service. STEINEL Brand STEINEL Customer Service • STEINEL has been brand leader in hot air tools for over 30 years • German engineering • Produced in Europe • Phone: ( 952 ) 888-5950 ( 800 ) 852-4343 • Fax: ( 952 ) 888-5132 • Monday – Friday 7 a.m. – 5 p.m. www.steinel.net Certified Quality All products from STEINEL comply with European safety standards. Despite involving a huge effort and not always easy from a technical point of view, we're never deterred. Because it's all worth it. So you get certified quality – every step of the way. • Product overview • Operating instructions for downloading • Product videos STEINEL Replacement Parts Service • Availability guaranteed for genuine STEINEL parts STEINEL Warranty Our management system holds certification under Quality Standard DIN EN ISO 9001 and Environmental Management Systems Standard DIN EN ISO 14001. The warranty for STEINEL heat tools is one year from the date of original purchase. 83 Steinel America, Inc. | 9051 Lyndale Ave. South | Bloomington, MN 55420 | USA Support: ( 800 ) 852-4343 | Office: ( 952 ) 888-5950 | Fax:( 952 ) 888-5132 sales@steinel.net | www.steinel.net 110051509 09/2016 6700 Subject to technical modifications Adresse?
110051538 价格&库存
很抱歉,暂时无法提供与“110051538”相匹配的价格&库存,您可以联系我们找货
