PA3580
PA3580
    GREENLEECOMMUNICATIONS(格林利)
    TOOL PUNCHDOWN NON-IMP 110 PDT
PA3580 数据手册
MADE FOR THE TRADE!™ Can Wrench Communications • • • • • Strips PVC insulation. Strips outer jacket of AWG 22/4 and 24/4 telephone cable. Strips insulation of AWG 22 (.34 mm2) and AWG 24 (.20 mm2) wire. 3/8” (9.5 mm) and 7/16” (11 mm) hex sockets for accessing panels. Durable shock-resistant design. CAT. NO. DESCRIPTION: HEAVY DUTY KEYSTONE TIP- PA1900 Can Wrench SPECIFICATIONS Overall Length 7.87" (200 mm) Weight 5 oz.(.140 g) Punchdown Stripper • • • • Self-regulating strip depth. Fast and easy to use. Great for CAT-5, CAT-5e, and CAT-6 data cable. Built-in 110 punchdown (punch only). CAT. NO. DESCRIPTION PA1913 Punchdown stripper SPECIFICATIONS CANADA 2 oz. (57 g) 4” (102 mm) Tel: +1.815.397.7070 Fax: +1.815.397.9247 Length Tel: 800.435.0786 Fax: 800.524.2853 INTERNATIONAL Weight Non-Impact Punchdown Tools with Fixed Blades PA3580 • • • • • • • • Non-impact, low-cost punchdown tools for 110, 66 & BIX. Works with 28-22 AWG (.08 - .5 mm2). Solid or stranded, single insulation wire. Comfortable rubber handle grip. Performs both cut and punch functions. Perfect for small jobs and the do-it-yourself installer. Fits in the palm of your hand. Typically lower in cost than replacement blades for punchdown tools. USA Tel: 800.435.0786 Fax: 800.451.2632 PA3581 DESCRIPTION PA3580 PA3581 PA3582 110 Punchdown Tool 66 Punchdown Tool BIX™ Punchdown Tool SPECIFICATIONS PA3582 260 CAT. NO. Weight Length 3 oz. (86 g) 4” (102 mm)
PA3580 价格&库存
很抱歉,暂时无法提供与“PA3580”相匹配的价格&库存,您可以联系我们找货
