EPB-KRONE
EPB-KRONE
    JONARDTOOLS
    BLADEKRONEFORPUNCHDOWNTOOL
EPB-KRONE 数据手册
Premier Tool Manufacturer Since 1958 EPD Series Punchdown Tools | Data Sheet EPD Series Punchdown Tools Sleek ergonomic design for easy effective wire termination. Tested up to 100,000 cycles at high-impact setting. Use to properly set, seat and terminate wire. Simply position the wire, push tool, and listen for confirming click. Wire is properly seated. Features include: • Hi/Low impact setting • Combination Hook/Spudger stored in the chassis • Color coded yellow on the CUT side • Enlarged blade storage compartment • Lifetime Warranty (Essentially means unlimited impacts) Punchdown Tool Kits JONARD P/N EPD-914 EPD-91466 X EPD-914110 X EPD-914KR X EPD-914116 X EPD-91461 X EPD-9KRONE X EPD-914630 X EPB-66 EPB-110 EPB-116 EPB-KR EPB-630 EPB-KRONE X X X X X X X X Punchdown Tool Blades JONARD P/N DESCRIPTION EPB-66 66 Blade With & Without Cutter EPB-110 110 Blade With & Without Cutter EPB-116 66 & 110 Blade Combined With Cutter EPB-KR Krone Blade With & Without Cutter EPB-630 Punchdown Blade For 630 Modular Jack EPB-KRONE Krone Blade Scissor Style EPB-66 EPB-110 EPB-116 EPB-KR EPB-630 EPB-KRONE BIX Punchdown Tool - EP-16A This tool is designed to terminate cables, pigtails, and jumper wires on all GigaBIX, BIX and UMOXS cross-connect system connectors. This single action, spring activated tool will terminate 22-26 AWG plastic insulated solid copper conductors. Button on the handle adjusts the tool for seating only, or for seating and cutting the conductors. Tel 914.793.0700 | Fax 914.793.4527 | jonard.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Jonard Industries: EPB-66 EPB-116 EPB-KRONE EPB-630
EPB-KRONE
1. 物料型号:包括EPB-66、EPB-110、EPB-116、EPB-KR、EPB-630和EPB-KRONE等型号。 2. 器件简介:这些工具设计用于高效且容易地进行电线端接,经过高达10万次的高冲击测试。 3. 引脚分配:文档中没有明确提及引脚分配,但提到了66刀片和110刀片的组合。 4. 参数特性:特性包括高/低冲击设置、组合钩/撬棒存储在机体内、切割面为黄色编码、扩大的刀片存储室和终身保修。 5. 功能详解:工具使用时只需定位电线,按下工具,并听到确认的点击声即可正确放置电线。 6. 应用信息:适用于GigaBIX、BIX和UMOXS交叉连接系统连接器的电缆、猪尾线和跳线端接。 7. 封装信息:提供了不同型号的打线工具和刀片的JONARD部件编号。
EPB-KRONE 价格&库存
很抱歉,暂时无法提供与“EPB-KRONE”相匹配的价格&库存,您可以联系我们找货
