HW-UW-224-1
HW-UW-224-1
    JONARDTOOLS
    HW-UW-224-1
HW-UW-224-1 数据手册
Premier Tool Manufacturer Since 1958 Wrap-Unwrap Tools | Data Sheet HW-UW-224 HW-UW-224-1 These two sided wire wrapping and unwrapping tool are intended to be two tools in one. They are designed to produce perfect wire wrapping connections. Precision, long-lasting tools for use where occasional wire wraps are required or where power wire-wrapping tools are not practical. Compact and convenient. To switch from wire wrapping to unwrapping takes only seconds - just a quick change of the cap from one end to the other. Wrapping Side: Regular Wrap. SPECIFICATIONS HW-UW-224 HW-UW-224-1 WRAP TYPE Regular Regular WIRE GAUGE 22-24 AWG (0.65-0.50 mm) 22-24 AWG (0.65-0.50 mm) WRAP TERMINAL HOLE DIAMETER .075" (1.90mm) .075” (1.90mm) WRAP TERMINAL HOLE DEPTH .807" (20.50mm) 1” (25.40mm) WRAP OUTSIDE DIAMETER .218" (6.35mm) .218” (6.35mm) WRAP POST SIZE 0.045" (1.14 mm) 0.045” (1.14 mm) UNWRAP WIRE GAUGE 20-26 AWG (0.80-0.40 mm) 20-26 AWG (0.80-0.40 mm) UNWRAP TERMINAL HOLE DIAMETER .070" (1.77mm) .070” (1.77mm) UNWRAP TERMINAL HOLE DEPTH 1" (25.40mm) 1” (25.40mm) UNWRAP OUTSIDE DIAMETER .156" (3.96mm) .156” (3.96mm) HANDLE TYPE Aluminum Aluminum WEIGHT 0.125 lbs (56.70g) 0.150 lbs (68.04g) UPC NO. 811490010499 811490013131 Tel 914.793.0700 | Fax 914.793.4527 | jonard.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Jonard Industries: HW-UW-224 HW-UW-2426 HW-UW-30 HW-UW-18-19 HW-UW-20 HW-UW-224-1
HW-UW-224-1 价格&库存
很抱歉,暂时无法提供与“HW-UW-224-1”相匹配的价格&库存,您可以联系我们找货
