77715
77715
    WIHA(威汉)
    BITDBLENDEDSLOTTED3MM4.5MM
77715 数据手册
M60 Section 3 FREV2:11-2011 11/20/11 2:15 PM Page 65 METRIC PC SCREW TERMINALS These easy-to-mount, multipurpose screw type terminals are a practical, low-cost alternative to PC screw type edge connectors, barrier blocks, terminal boards and terminal strips. Steadfast and easy to install, will accommo- date solid or stranded wire, crimp type terminals or lugs. Multi- placement of these low-profile terminals make them ideally suited for high density packaging. Supplied unassembled or with screw installed and captivated. PRINCIPAL FEATURES • Stable, no-rock design with exclusive anti-rotational feature • Easily mounts with four legs into pre-drilled or punched holes • Accepts 14-22 AWG solid or stranded wire, crimp type terminals or lugs • Ideally suited for high-density packaging • Easy accessibility for PC board testing • Binding screw is positioned above board level to avoid wicking during wave soldering COLOR SELECTION: Select desired screw terminal and add color suffix to the screw terminal Cat. No. HEAD COLOR RED BLACK WHITE BLUE GREEN YELLOW NICKEL SUFFIX -2 -3 -4 -5 -6 -7 none Refer to page 133 for color screws only HORIZONTAL TYPE SPECIFICATIONS 6.00 LONG SCREW Rated: 15 Amps Terminal: .081 (2.05) Brass, Matte Tin Plate Screw: Brass, Nickel Plate 11.50 7.11 7.90 SNAP-IN PC MOUNT 11.507693-5 7.90 5.10 Mounting Detail 1.52 6.60 5.00 5.08 PC MOUNT 5.10 1.52 7.81 M3 THREAD M4 THREAD CAT. NO. CAT. NO. 7790 No Screw Supplied 7792 7689* Screw Supplied Unassembled 7793 7695* Screw Installed & Captivated 7794 5.00 1.85 DIA. HOLE (4) PLS Color coded screws available (add color screw suffix to Cat. No.) *Available with color Coded Screws 5.00 5.08 7.50 M3 THREAD M4 THREAD CAT. NO. CAT. NO. 7760 No Screw Supplied 7764 7661* Screw Supplied Unassembled 7765 7662* Screw Installed & Captivated 7766 *Available with color Coded Screws VERTICAL TYPE 8.00 8.00 6.00 LONG SCREW 6.00 LONG SCREW SPECIFICATIONS 8.00 Rated: 15 Amps Terminal: .081 (2.05) Brass, Matte Tin Plate Screw: Brass, Nickel Plate 6.45 8.00 6.45 5.00 4.75 1.52 SNAP-IN PC MOUNT 1.52 PC MOUNT 5.00 7.00 5.00 7.00 Mounting Detail 7.00 M3 THREAD M4 THREAD CAT. NO. CAT. NO. 7788 No Screw Supplied 7795 7698* Screw Supplied Unassembled 7796 7696* Screw Installed & Captivated 7797 5.00 1.85 DIA. HOLE (4) PLS Color coded screws available (add color screw suffix to Cat. No.) *Available with color Coded Screws M3 THREAD M4 THREAD CAT. NO. CAT. NO. 7770 No Screw Supplied 7767 7771* Screw Supplied Unassembled 7768 7772* Screw Installed & Captivated 7769 *Available with color Coded Screws 30 AMP - VERTICAL TYPE M4 M5 M4 x 6.00 L. SCREW 7.87 METRIC SCREW TERMINALS 7.11 6.00 LONG SCREW 11.94 PRINCIPAL FEATURES • Compact, heavy duty design • Six snap-in legs for total stability • Serrated top surface secures connection M5 x 10.00 L. SCREW 11.94 12.88 SNAP-IN PC MOUNT 17.02 11.68 7.00 1.52 SPECIFICATIONS Rated: 30 Amps Terminal: .80 Brass, Matte Tin Plate Screw: Brass, Nickel Plate CAT. NO. 7798 7799 7800 SNAP-IN PC MOUNT 11.51 6.35 10.00 Mounting Detail 10.00 5.00 SPECIFICATIONS 1.52 10.80 Rated: 30 Amps Terminal: 1.14 Brass, Matte Tin Plate Screw: Brass, Nickel Plate 10.41 Mounting Detail 10.41 5.21 10.80 No Screw Supplied Screw Supplied Unassembled Screw Installed & Captivated Color coded screws available (add color screw suffix to Cat. No.) Tel (718) 956-8900 • Fax (718) 956-9040 (800) 221-5510 • kec@keyelco.com 7.00 1.93 DIA. HOLE (6) PLS CAT. NO. 7807 7808 No Screw Supplied Screw Supplied Unassembled ® RoHS COMPLIANT ~ ISO 9001 CERTIFIED 2.57 DIA. HOLE (6) PLS www.keyelco.com 31-07 20th Road – Astoria, NY 11105-2017 65 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Keystone Electronics: 7771-2 7771-3 7771-4 7771-5 7771-6 7772-5 7772-6 7772-7 7689-2 7689-3 7689-5 7689-6 7689-7 7695-2 7695-3 7695-4 7695-5 7695-6 7695-7 7696-2 7696-3 7696-4 7696-5 7696-6 7696-7 7698-2 7698-3 7698-5 7698-6 7698-7 7689-4 7698-4
77715 价格&库存
很抱歉,暂时无法提供与“77715”相匹配的价格&库存,您可以联系我们找货
