71658
71658
    WIHA(威汉)
    BIT TORXPLUS TR IPR30 0.98"
71658 数据手册
2013 Complete Program TORX For Tooling Professional Tools pg. 28 pg. 33 pg. 27 Toll Free: (800) 494-6104 2 TorxPlus® Index Torx® Index DESCRIPTION Page SoftFinish® 5 Cushion Grip 6 ESD Safe SoftFinish® Cushion Grip DESCRIPTION Page Wing Handle 18 Flag Handle 18 Insulated 7 PocketStar Fold Outs Cushion Grip 18 Powerhandle 7 SoftFinish® 19 7 T-handles 19 8 L-Keys Short/Long Arm 20 Proturn 9 TorqueControl Blade 24 3K Series 10 ESD Safe Precision 26 Stainless Steel Cushion Grip MicroFinish Non-Slip Grip Drive-Loc VI Blades Cushion Grip Bit-Selectors 31 11 T-handle & ComfortGrip 12-13 Insert Bits 38 L-Keys 13-14 Offset Screwdrivers 14 Power Bits 38 PocketStar Fold Outs 15 16 Wing Handle Flag Handle 16 TorqueControl Blades 24 Precision Tools SYSTEM 4 Micro Bits 26 27 27 28 SYSTEM  4 Blades 29 ESD Safe Standard PicoFinish Bit Sets 31 Insert & Power Bits 34-36 Bit Sockets & Sets 39-41 * Standard TORX® are not for use in TORXPlus® fasteners Bit Sockets & Sets 39,41 Ball End Torx® Index DESCRIPTION Page SoftFinish Drivers L-Keys 17 Power Bits Cushion Grip 17 17 www.wihatools.com 3 Security Torx® Index Screwdrivers Index DESCRIPTION Page SoftFinish® 6 Cushion Grip DESCRIPTION Page SoftFinish® CushionGrip 5-6,19,21 Torx®, Security Torx®, TorxPlus®, MagicSpring Drive-Loc VI Blades 11 L-Keys 14 ESD Safe SoftFinish® 6 Cushion Grip - Torx® Insulated 7 Cushion Grip - Torx® PocketStar Fold Outs 15 Powerhandle- Torx® 7 SYSTEM 4 Micro Bits 28 Stainless Steel 7 Bit Sets 32 MicroFinish 8 Insert Bits - 1/4” & 5/16” 37 Power Bits 37 Proturn - Torx® 9 Bit Sockets DESCRIPTION Page SoftFinish® Screw Holding 21 Offset Screwdrivers T-handle/ComfortGrip 12-15,19 ESD Safe Standard PicoFinish Screw Holding 24 Power Bits 38 Screw Holding Wing/Flag & L-keys Index DESCRIPTION Offset Screwdrivers Wing Handle 16,18,22 Torx®, TorxPlus® & MagicSpring Flag Handle Torx® & TorxPlus® 16,18 11 SoftFinish® Cushion Grip Drive-Loc VI Handle 11 Drive-Loc VI Handle 11 Drive-Loc VI Blades 11 ESD Safe Cushion Grip Page 14 DESCRIPTION Page Drive-Loc VI Handle MicroFinish Non-Slip Grip Torx / Security Torx ® L-Keys 13-14 26 27 27 Drive-Loc VI Interchangeable L-keys Screw Holding 22 TorqueControl Blades 14 Torx® & TorxPlus® Precision Tools PicoFinish Soft Grip 21 Wing Handle Screw Holding 22 10 Cushion Grip Non-Slip Grip - Torx® 3K Series - Torx® 39,41 MagicSpring Screw Holding Cushion Grip - Torx® ® Fold Outs Index DESCRIPTION Page PocketStars 15,18 Torx, Security Torx, TorxPlus Toll Free: (800) 494-6104 4 Bit Sets Index TorqueControl Index DESCRIPTION Page DESCRIPTION TorqueVario Handle BitFlip Sets Topra Bit Sets Six-in-One Bit Sets Bit Selector Sets Power Bit Belt Packs 31-32 SYSTEM 4 Sets 28-29 23 Torx® / TorxPlus® Blades 23 Insulated Torque Tools 30 30,32 24 Easy Torque Tools 24 ESD  Safe TorqueControl 24 ESD Safe Torx® Blades 24 T-handle Torque Tools 25 Interchangeable Blades For Torque T-handle TorqueControl Sets Page 25 30,32 31-32 Micro Bits & Interchangeable Blades XSelectors 31-32 25 See Bit Holders on Page 33 High Performance Bits Index Torx Dura Insert Bits Tungsten Carbide Coated Torx® Diamond Bits Torx® TiN Coated- DESCRIPTION 34 ® Interchangeable Blade Set 6 Titanium 34 Sockets Index DESCRIPTION Page Torx® Insert/Power Bits 35-36 Specialty Bits Index DESCRIPTION Page Ball End Torx ® DESCRIPTION Page Torx® 1/4” Drive 39 Torx® 3/8” - 5/16” Bits 39 39 Security Torx® 3/8”, 1/2” 17,38 37 6” Bit Sockets TorxPlus® Bits 38 Bit Socket Sets Insert/Power Bits Security Torx® Insert/Power Bits Insert/Power Bits 39 Torx® 3/8” Drive 36 Torx® Align Bits Page 34 Standard Bits Index ESD Blade Set Index DESCRIPTION Page External Torx® Sockets 40 1/4”, 3/8”, 1/2” 1/4” & 3/8” Drive 40 41 www.wihatools.com 5 Wiha SoftFinish® Screwdrivers - Ergonomic Cushion Grip Handle Extra large diameter to achieve high torque 362 Screwdriver, With Wiha-SoftFinish® Handle Round blade high alloy chrome-vanadium-molybdenum steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Wiha-SoftFinish® handle, multi-component, cushion grips. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 36264 T5 60 2.4 2.5 .098 164 6.5 .05 10 36266 T6 60 2.4 3.5 .139 164 6.5 .06 10 36268 T7 60 2.4 3.5 .139 164 6.5 .06 10 36270 T8 60 2.4 3.5 .139 164 6.5 .06 10 36272 T9 60 2.4 4.0 .157 171 6.7 .10 10 36274 T10 80 3.1 4.0 .157 191 7.5 .11 10 36276 T15 80 3.1 4.0 .157 191 7.5 .11 10 36278 T20 100 3.9 4.0 .157 211 8.3 .11 10 36280 T25 100 3.9 4.5 .177 211 8.3 .12 10 36282 T27 115 4.5 5.5 .216 233 9.2 .19 10 36284 T30 115 4.5 6.0 .236 233 9.2 .20 10 36286 T40 130 5.1 7.0 .275 254 10.0 .27 10 36288 T45 130 5.1 8.0 .315 254 10.0 .31 10 Flat surfaces give roll-off protection Improved torque zone. For all working conditions with molded on soft cushion grips 36294 Set 8 Pcs. Round blade high alloy CVM steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Wiha-SoftFinish® handle, multi-component, cushion grips. Item No. Size mm Size mm lbs. T6 60 T20 100 1.24 36266 36278 36294 T8 60 T25 100 36270 36280 T10 80 T27 115 36274 36282 T15 80 T30 115 36276 36284 #36291 #36201 36291 Set 6 Pcs. Round blade high alloy chrome-vanadium-molybdenum steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Wiha-SoftFinish® handle, multi-component, cushion grips. Item No. Size mm Size mm 36266 T6 60 36291 36272 T9 60 36268 T7 60 36274 T10 80 36270 T8 60 36276 T15 80 36201 Set 6 Pcs. Round blade high alloy chrome-vanadium-molybdenum steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Wiha-SoftFinish® handle, multi-component, cushion grips. Item No. Size mm Size mm 36201 36266 T6 60 36276 T15 80 36270 T8 60 36278 T20 100 36274 T10 80 36280 T25 100 lbs. .77 lbs. .83 Set 12 Pcs. Round blade high alloy CVM steel, 36267 hardened, hard chromed. Wiha-Chromtop finish on tips. Wiha-SoftFinish® handle, multi-component, cushion grips. Item No. Size mm Size mm lbs. 36267 2.03 36264 T5 60 36276 T15 80 36266 T6 60 36278 T20 100 36268 T7 60 36280 T25 100 36270 T8 60 36282 T27 115 36272 T9 60 36284 T30 115 36274 T10 80 36286 T40 130 Toll Free: (800) 494-6104 6 Wiha Security Drivers Wiha SoftFinish® ESD Safe Handle D 362 Security Screwdriver With Wiha-SoftFinish Handle Round blade high alloy chrome-vanadium-molybdenum steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Wiha-SoftFinish® handle, multi-component, cushion grips. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 36269 T7s 60 2.4 3.5 .139 164 6.5 .06 10 36271 T8s 60 2.4 3.5 .139 164 6.5 .06 10 36273 T9s 60 2.4 4.0 .157 171 6.7 .10 10 36275 T10s 80 3.1 4.0 .157 191 7.5 .11 10 36277 T15s 80 3.1 4.0 .157 191 7.5 .11 10 36279 T20s 100 3.9 4.0 .157 211 8.3 .11 10 36281 T25s 100 3.9 4.5 .177 211 8.3 .11 10 36283 T27s 115 4.5 5.5 .216 233 9.2 .19 10 36285 T30s 115 4.5 6.0 .236 233 9.2 .20 10 36287 T40s 130 5.1 7.0 .275 254 10.0 .28 10 ® ESD Safe (106-109 Ohm) ESD Safe Driver, With Wiha-SoftFinish® Handle 362 DIN EN 61340-5-1/ 61340-5-2 Round blade, CVM steel, hardened, hard chromed. Offers protection against electrostatic discharge. Dissipative SoftFinish® cushion grip handle, multi-component. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 36260 T3 60 2.4 3.5 .139 164 6.5 .06 10 36204 T4 60 2.4 3.5 .139 164 6.5 .06 10 36200 T5 60 2.4 3.5 .139 164 6.5 .06 10 36206 T6 60 2.4 3.5 .139 164 6.5 .06 10 36208 T8 60 2.4 3.5 .139 164 6.5 .06 10 36209 T9 60 2.4 4.0 .157 171 6.7 .10 10 36218 T10 80 3.1 4.0 .157 191 7.5 .11 10 36219 T15 80 3.1 4.0 .157 191 7.5 .11 10 36224 T20 100 3.9 4.0 .157 211 8.3 .11 10 D 36298 Set 7 Pcs. Security Item No. Size mm Size mm 36298 36269 T7s 60 36277 T15s 80 36271 T8s 60 36279 T20s 100 36273 T9s 60 36281 T25s 100 36275 T10s 80 36259 Set 10 Pcs. Security Item No. Size mm 36259 36279 36269 T7s 60 36281 36271 T8s 60 36283 36273 T9s 60 36275 T10s 80 36285 36277 T15s 80 36287 Size mm T20s 100 T25s 100 T27s 115 T30s 115 T40s 130 36289 Set 6 Pcs. ESD Safe Screwdrivers Item No. 36289 TORX: T6, T8, T9, T10, T15, T20 lbs. .81 lbs. .95 lbs. 1.5 Wiha Stainless Steel Screwdrivers 376 Screwdriver, With Wiha-SoftFinish® Handle High quality stainless steel. SoftFinish® cushion grip handle. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. T8 60 2.4 4.0 .139 164 5.3 .09 10 37608 T9 60 2.4 4.0 .157 171 5.5 .11 10 37609 T10 80 3.1 4.0 .157 191 6.7 .11 10 37610 T15 80 3.1 4.0 .157 191 6.7 .11 10 37615 T20 100 3.9 4.0 .157 218 7.9 .16 10 37620 T25 100 3.9 4.5 .177 218 7.9 .17 10 37625 T27 115 4.5 5.5 .216 233 8.5 .20 10 37627 T30 115 4.5 6.0 .236 233 8.9 .21 10 37630 T40 130 5.1 7.0 .276 254 10.0 .24 10 37640 37690 Set 5 Pcs. Stainless Steel Screwdrivers Item No. 37690 TORX: T6, T8, T9, T10, T15, T20 lbs. .81 www.wihatools.com 7 Wiha Insulated Screwdrivers 1000Volt Screwdriver, With Wiha-SoftFinish® Handle 325 Insulation According to ASTM F-1505-01, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E, up to 1000 Volt. Individually Tested. Blade high alloy cvm steel, hardened, black finish. Insulation molded directly onto blade. Item No. Size mm Inch mm Inch lbs. pkg. 32505 T5 60 2.4 164 6.5 .06 10 32511 T6 60 2.4 164 6.5 .06 10 32516 T7 60 2.4 164 6.5 .06 10 32521 T8 60 2.4 164 6.5 .06 10 32526 T9 60 2.4 164 6.5 .06 10 32531 T10 60 2.4 164 6.5 .06 10 32536 T15 80 3.1 191 7.5 .12 10 32541 T20 80 3.1 191 7.5 .12 10 32546 T25 80 3.1 198 7.8 .17 10 32551 T27 100 3.9 218 8.6 .20 10 32556 T30 100 3.9 218 8.6 .20 10 32561 T40 150 5.9 274 10.8 .30 10 Made in Germany 362 Screwdriver, With Wiha-Powerhandle CVM steel blade, hardened, hard chromed. Wiha-powerhandle cellulose-acetate. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. T5 50 2.0 2.5 .098 110 4.3 .03 10 36205 T6 50 2.0 3.5 .139 125 4.9 .06 10 36210 T7 50 2.0 3.5 .139 125 4.9 .06 10 36212 T8 60 2.4 3.5 .139 135 5.3 .06 10 36215 T9 60 2.4 4.0 .157 140 5.5 .09 10 36220 T10 80 3.1 4.0 .157 170 6.7 .13 10 36225 T15 80 3.1 4.0 .157 170 6.7 .13 10 36230 T20 100 3.9 4.0 .157 200 7.9 .17 10 36235 T25 100 3.9 4.5 .177 200 7.9 .18 10 36240 T27 115 4.5 5.5 .216 215 8.5 .20 10 36245 T30 115 4.5 6.0 .236 225 8.9 .28 10 36250 36292 8 Pc. Set With Wiha-Powerhandle Item No. Includes: T6, T8, T10, T15, lbs. 36292 T20, T25, T27, T30 1.45 1000Volt 32590 Wiha Powerhandle Set 6 Pcs. Item No. 32521 32590 32526 32531 Size mm Size mm lbs. T8 60 32536 T15 80 .83 T9 60 32541 T20 80 T10 60 32546 T25 80 1000Volt 6 Pc. Set With Wiha-Powerhandle 36293 Item No. Includes: T6, T7, T8, T9, lbs. T10, T15 .78 36293 Wiha ESD Safe Interchangeable Blade Set 32592 D Set 10 Pcs. Item No. 32511 32592 32516 32521 32526 32531 Size mm T6 60 T7 60 T8 60 T9 60 T10 60 32536 32541 32546 32551 32556 Size mm lbs. T15 80 1.2 T20 80 T25 80 T27 100 T30 100 In Durable Pouch 10893 ESD Safe Interchangeable Blade Set 5 Pc. Set Includes ESD Safe handle & 4 interchangeable blades. Item No. 10893 lbs. .75 TORX®: T6, T7, T8, T9, T10, T15, T20, T25 Wiha ESD Safe Handle Toll Free: (800) 494-6104 8 Wiha MicroFinish Handle Non-Slip Grip Wiha MicroFinish handle has a patented non-slip surface it won’t peel, crack or deteriorate when exposed to petroleum solvents. Oil and moisture flow away from the handle surface for a powerful, non-slip grip. You get maximum force and comfort with dry, oily or wet hands. Safe, high density material, eliminates risk of sharp objects becoming embedded in the handle Blades are hardened & hard chromed Exact fit precision ground tips 527 Screwdriver, With Wiha-MicroFinish Handle Blade high alloy chrome-vanadium-molybdenum steel, hardened, hard chromed. Wiha-MicroFinish handle, cellulose-acetate, impact resistant, non-slip, oil and grease resistant. Round blades. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. T9 60 2.4 4.0 .157 171 6.7 .15 10 52711 T10 80 3.1 4.0 .157 191 7.5 .15 10 52713 T15 80 3.1 4.0 .157 191 7.5 .15 10 52716 T20 100 3.9 4.0 .157 211 8.3 .15 10 52719 T25 100 3.9 4.5 .177 211 8.3 .16 10 52722 T27 115 4.5 5.5 .216 233 9.2 .25 10 52726 T30 115 4.5 6.0 .236 233 9.2 .27 10 52729 T40 130 5.1 7.0 .275 254 10.0 .40 10 52732 MicroFinish Handle with patented non-slip surface. Ergo handle shape for maximum comfort & exceptional torque transfer Blade CVM, hardened & tempered tool steel, gives exceptional tool life, wear resistance & high torque performance 52790 Set 5 Pcs. Blade chrome-vanadium-molybdenum steel, hardened, round blades hard chromed. Wiha-MicroFinish handle, cellulose-acetate, impact resistant, non-slip, oil and grease resistant. Item No. Size mm Size mm lbs. 52713 T10 80 52722 T25 100 1.0 52790 52716 T15 80 52729 T30 115 52719 T20 100 52791 Set 8 Pcs. Blade chrome-vanadium-molybdenum steel, hardened, round blades hard chromed. Wiha-MicroFinish handle, cellulose-acetate, impact resistant, non-slip, oil and grease resistant. Item No. Size mm Size mm lbs. 52722 T9 60 T25 100 1.89 52711 52791 52713 T10 80 52726 T27 115 52716 T15 80 52729 T30 115 52719 T20 100 52732 T40 130 www.wihatools.com 9 pro turn Wiha Proturn Screwdrivers #45592 #45591 45591 Through hardened for optimum wear resistance Set 6 Pcs. Item No. Size 45506 T7 45591 45511 T8 45516 T9 Molded on ergonomic handle proportioned to blade sizes High performance tool steel 45592 mm Size mm 50 45521 T10 80 60 45526 T15 80 60 45531 T20 100 lbs. .72 Set 8 Pcs. Item No. 45592 45511 45516 45521 45526 Size mm T8 60 45531 T9 60 45536 45541 T10 80 45546 T15 80 Size mm lbs. T20 100 1.07 T25 100 T27 115 T30 115 Black finish blades 45589 455 Screwdriver, With Wiha-Proturn Handle Blade high alloy CVM steel, hardened, black finish. Molded on ergonomic Wiha-Proturn handle, impact resistant. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 45505 T6 50 2.0 3.5 .139 129 5.1 .05 10 45506 T7 50 2.0 3.5 .139 129 5.1 .05 10 45511 T8 60 2.4 3.5 .139 139 5.5 .06 10 45516 T9 60 2.4 4.0 .157 149 5.8 .08 10 45521 T10 80 3.1 4.0 .157 170 6.7 .10 10 45522 T10 275 10.8 4.0 .157 363 14.2 .13 10 45526 T15 80 3.1 4.0 .157 170 6.7 .10 10 45531 T20 100 3.9 4.0 .157 190 7.5 .11 10 45536 T25 100 3.9 4.5 .177 190 7.5 .11 10 45541 T27 115 4.5 5.5 .216 215 8.4 .11 10 45546 T30 115 4.5 6.0 .236 215 8.4 .20 10 45551 T40 130 5.1 7.0 .275 240 9.4 .28 10 45556 T45 130 5.1 8.0 .315 240 9.4 .27 10 45561 T50 130 5.1 9.0 .354 240 9.4 .31 10 Set 14 Pcs. Item No. 45589 45505 45506 45511 45516 45521 45522 45526 Size mm T6 50 45531 T7 50 45536 T8 60 45541 T9 60 45546 T10 80 45551 T10 275 45556 T15 80 45561 Size mm lbs. T20 100 2.2 T25 100 T27 115 T30 115 T40 130 T45 130 T50 130 48400 1/4” Bit Holding Screwdriver, With Wiha-Proturn Handle Magnetic, holds bit and screw. Retainer out of stainless steel. Shaft CVM steel, nickel-plated. Handle, molded on, impact resistant. Item No. 48400 Size 1/4 mm Inch mm Inch 125 5.0 243 9.6 lbs. .24 pcs. 10 Toll Free: (800) 494-6104 10 Wiha 3K Series Drivers and Sets 3K Series Hole for hanging Molded on soft grip ergonomic handle, impact resistant Precision black tip 45598 Set 6 Pcs. Blade CVM steel, hardened, precision black tip. Wiha-3k Ergo handle, cushion grip. Blade high alloy CVM steel, hardened Item No. Size mm Size mm lbs. 45598 45504 T6 60 45509 T9 60 .88 45507 T7 60 45510 T10 80 45508 T8 60 45515 T15 80 455 Screwdriver, With Wiha-3K Series Handle Blade high alloy CVM steel, hardened, precision black tip. Molded on ergonomic Wiha-3K Series handle, impact resistant. Item No. 45504 45507 45508 45509 45510 45515 45520 45525 45527 45530 45540 45545 45550 Size mm Inch mm Inch mm Inch lbs. pkg. T6 60 2.4 3.2 9/64 145 5.7 .06 10 T7 60 2.4 3.5 9/64 129 5.1 .05 10 T8 60 2.4 3.5 9/64 139 5.5 .06 10 T9 60 2.4 4.0 5/32 149 5.8 .08 10 T10 80 3.1 4.0 5/32 170 6.7 .10 10 T15 80 3.1 4.0 5/32 190 7.5 .11 10 T20 100 3.9 5.5 7/32 215 8.4 .11 10 T25 100 3.9 6.0 1/4 215 8.4 .20 10 T27 115 4.5 7.0 9/32 240 9.4 .28 10 T30 115 4.5 6.0 1/4 233 9.1 .21 10 T40 130 5.1 7.0 9/32 248 9.7 .25 10 T45 130 5.1 8.0 5/16 249 9.8 .30 10 T50 130 5.1 9.0 3/8 249 9.8 .33 10 45595 Set 8 Pcs. Wiha-3k Ergo handle, cushion grip. Item No. Size mm Size mm lbs. 45595 45504 T8 60 45520 T20 100 1.36 45509 T9 60 45525 T25 100 45510 T10 80 45527 T27 115 45515 T15 80 45530 T30 115 45597 Set 11 Pcs. 3K Ergo Series Screwdriver Set Blade chrome-vanadium-molybdenum steel, hardened, precision black tip. Wiha-3k Ergo handle, cushion grip. 45593 Set 5 Pcs. Blade CVM steel, hardened, precision black tip. Wiha-3k Ergo handle, cushion grip. Item No. Size mm Size mm lbs. 45593 45508 T8 60 45520 T20 100 .86 45510 T10 80 45525 T25 100 45515 T15 80 Item No. Size mm Size mm lbs. 45504 T6 60 45520 T20 100 1.72 45597 45507 T7 60 45525 T25 100 45508 T8 60 45527 T27 115 45509 T9 60 45530 T30 115 45510 T10 80 45540 T40 130 45515 T15 80 www.wihatools.com 11 Drive-Loc VI For Adjustable Length Locking Blades Locking mechanism allows blade length to be adjusted from 40mm120mm. (1.7 to 4.7” In 1/8” increments) Blades high quality CVM steel, hard chrome finish. Ergonomic handles in ESD Safe, cushioned & non-slip grip. 28488 Drive-Loc VI Cushion Grip Handle Wiha-SoftFinish® impact resistant, with roll off protection. Advantages: Ergonomic cushion grip, Drive-Loc mechanism guarantees a secure hold and rapid blade exchange. Item No. mm mm Inch mm Inch lbs. 6.0 115 4.5 36.0 1.41 .20 28488 281 Drive-Loc VI Interchangeable Blade High alloy CVM steel, through hardened, hard chrome finish. Over all blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. Size + Size lbs. pkg. T6 T8 .09 1 28126 T7 T9 .09 1 28127 T10 T15 .10 1 28128 T20 T25 .10 1 28129 T30 T40 .10 1 28130 281 Security Drive-Loc VI Interchangeable Blade, high alloy CVM steel, through hardened, hard chrome finish. Over all blade length 150mm/5.9”. Blades fit all Drive-Loc VI handles. Item No. Size + Size lbs. pkg. 28132 T6s T8s .09 1 28133 T7s T9s .09 1 28134 T10s T15s .10 1 28135 T20s T25s .10 1 28136 T30s T40s .10 1 D ESD Safe Drive-Loc VI Cushion Grip Handle 28486 Wiha-SoftFinish® impact resistant, with roll off protection. Advantages: Ergonomic cushion grip, Drive-Loc mechanism guarantees a secure hold and rapid blade exchange. Static Dissipative. Item No. mm mm Inch mm Inch lbs. 6.0 115 4.5 36.0 1.41 .20 28486 Drive-Loc VI MicroFinish Non-Slip Grip Handle 28487 Wiha-MicroFinish handle, won’t peel, crack or deteriorate when exposed to petroleum solvents. Ideal for Hex, TORX® & Nut Drivers. Advantages: Ergonomic handle shape for maximum comfort, Drive-Loc mechanism guarantees a secure hold and rapid blade exchange. Item No. mm mm Inch mm Inch lbs. 6.0 115 4.5 36.0 1.41 .20 28487 28195 Drive-Loc VI Interchangeable Blade Set, 6 Pcs. In Durable Pouch Set includes Drive-Loc VI handle & 5 interchangeable blades. Item lbs. No. .85 28195 : T6&T8, T7&T9, T10&T15, T20&T25, T30&T40 Wiha SoftFinish® Cushion Grip Blade Lock Handle 28197 Drive-Loc VI Interchangeable Blade Set, 6 Pcs. In Durable Pouch Set includes Drive-Loc VI handle & 5 interchangeable blades. Item lbs. 28197 .83 No. Security : T6s+T8s, T7s+T9s, T10s+T15s, T20s+T25s, T30s+T40s & SoftFinish® Cushion Grip Blade Lock Handle Toll Free: (800) 494-6104 12 Wiha Insulated SlimLine Tools Wiha Soft Grip Dual Drive T-handle Two Tools In One! Insulation Test Standards: Insulation according to EN/IEC 60900, ASTM F-1505-01, VDE 0682/part 201, DIN 7437, NFPA70E & CSA specification Ideal for jobs where access is limited Integrated Slim Insulation molded directly onto blade Wiha SlimTECHNOLOGY Achieves blade diameters up to 33% narrower utilizing integrated insulation Insulation does not exceed screw head diameter High quality chrome vanadium steel, through-hardened Through the handle side driver Short and Long Arm In One Powerful Tool Maximum Comfort & Maximum Power Torx - Blades of CVM tool steel, through hardened durability, hard chrome finish Two component soft grip handle 1000Volt Rated 10,000Volt Tested 1000Volt 28301 SlimLine Blade Holder, With Wiha-SoftFinish® Handle Insulation According to VDE, ASTM F-1505-01 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Chrome-vanadium steel, through-hardened. Insulation molded directly onto blade. Quick release holder securely lock blades. Wiha-SoftFinish® handle, multi-component, cushion grip. Item No. Size mm Inch mm Inch lbs. pkg. 1/4” 50 2.0 160 6.3 .15 1 28301 Soft Grip T-handle 364 Blade CVM steel, through hardened, satin chrome finish. Soft grips are molded on and include through the handle side torque drive. Item No. Size mm lbs. pkg. T10 100 .08 10 36480 T15 100 .08 10 36481 T20 100 .13 10 36482 T25 150 .16 10 36483 T27 150 .19 10 36484 T30 150 .20 10 36486 T40 150 .24 10 36487 1.8” Insulated SlimLine Blades 283 High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Item Slim Working Max Inch/ No. Size mm Dia. Length Nm lbs. lbs. Pkg. 28339 T8 90 4.1 2.8” 1.3 11.5 .02 1 28340 T10 90 4.1 2.8” 3.8 33.7 .02 1 28341 T15 90 6.1 2.8” 5.5 48.8 .02 1 28342 T20 90 6.1 2.8” 5.5 48.8 .02 1 36497 Set 7 Pcs. Soft Grip T-handles Item No. Size mm Size mm 36480 T10 100 36484 T27 150 36497 36481 T15 100 36486 T30 150 36482 T20 100 36487 T40 150 36483 T25 150 lbs. 1.53 www.wihatools.com 13 Wiha T-handle with Wiha T-handles 364 Blade high alloy chrome-vanadium-molybdenum steel, hardened, hard chrome finish. Wiha T-handle high quality plastic, impact resistant. Item No. Size mm Inch mm Inch mm Inch lbs pkg. T9 100 3.9 4.0 5/32 80 3.1 .07 10 36409 T10 100 3.9 4.0 5/32 80 3.1 .07 10 36410 T15 100 3.9 4.0 5/32 80 3.1 .07 10 36415 T15 200 7.9 5.5 7/32 80 3.1 .13 10 36417 T20 100 3.9 4.0 5/32 100 3.9 .10 10 36420 T20 200 7.9 5.5 7/32 100 3.9 .17 10 36422 T25 100 3.9 4.0 5/32 100 3.9 .11 10 36425 T25 200 7.9 5.5 7/32 100 3.9 .17 10 36427 T27 100 3.9 5.5 7/32 100 3.9 .14 10 36430 T27 200 7.9 5.5 7/32 100 3.9 .17 10 36432 T30 100 3.9 7.9 6.0 100 3.9 .14 10 36435 T30 200 7.9 6.0 1/4 100 3.9 .19 10 36437 T40 100 3.9 7.0 9/32 100 3.9 .16 10 36440 T40 200 7.9 7.0 9/32 100 3.9 .23 10 36442 T45 150 5.9 8.0 5/16 120 4.7 .29 10 36445 T50 150 5.9 9.0 3/8 120 4.7 .30 10 36450 T50 250 9.8 9.0 3/8 120 4.7 .45 10 36452 #36490 #36492 36492 T-handle Set, 7 Pc. Equipped with T9, T10, T15, T20, T25, T27, T30 Item No. lbs. pkg. 36492 1.24 1 T-handle Set, 7 Pc. In Metal Stand 36490 Equipped with T10, T15, T20, T25, T30, T40, T50 Item No. lbs. pkg. 2.65 1 36490 • Blade high alloy CVM steel, hardened, hard chrome finish • Wiha T-handle high quality plastic, impact resistant 36494 T-handle Set, 8 Pc. In Metal Stand Equipped with T9, T10, T15, T20, T25, T27, T30, T40 Item No. lbs. pkg. 3.10 1 36494 Wiha Short Arm L-keys 363 L-key, Short Arm High alloy chrome-vanadium-molybdenum steel, hardened, black finish. Item No. Size mm Inch mm Inch lbs. pkg. T5 37 1.5 16 .6 .01 10 36305 T6 39 1.5 16 .6 .01 10 36306 T7 42 1.7 16 .6 .01 10 36307 T8 45 1.8 16 .6 .01 10 36308 T9 48 1.9 16 .6 .01 10 36309 T10 51 2.0 17 .7 .01 10 36310 T15 54 2.1 19 .7 .01 10 36315 T20 58 2.3 19 .7 .01 10 36320 T25 63 2.5 21 .8 .02 10 36325 T27 67 2.6 22 .9 .03 10 36327 T30 73 2.9 24 .9 .05 10 36330 T40 79 3.1 26 1.0 .06 10 36340 T45 82 3.2 28 1.1 .09 10 36345 T50 95 3.7 32 1.3 .13 10 36350 T55 108 4.3 35 1.4 .27 10 36355 T60 120 4.7 38 1.5 .40 10 36360 #36392 #36394 #36399 36392 Set, 7 Pc. In Plastic Holder Equipped with T6, T7, T8, T9, T10, T15, T20 Item No. lbs. pkg. 36392 .10 1 36394 Set, 9 Pc. In Plastic Holder Equipped with T8, T9, T10, T15, T20, T25, T27, T30, T40 Item No. lbs. pkg. 36394 .30 1 36399 Set, 16 Pc. Equipped with T5, T6, T7, T8, T9, T10, T15, T20, T25, T27, T30, T40, T45, T50, T55, T60 Item No. lbs. pkg. 1.14 1 36399 36390 Set, 9 Pc. In Metal Stand Equipped with T10, T15, T20, T25, T30, T40, T50, T55, T60 Item No. lbs. pkg. 1.86 1 36390 Toll Free: (800) 494-6104 14 Wiha Long Arm L-keys 366 L-key, Long Arm High alloy chrome-vanadium-molybdenum steel, hardened, black finish. Item No. Size mm Inch mm Inch lbs. pkg. 36645 T5 71 2.8 12 .5 .06 10 36646 T6 78 3.1 13 .5 .07 10 36647 T7 87 3.4 16 .6 .10 10 36648 T8 99 3.9 18 .7 .13 10 36649 T9 106 4.2 18 .7 .17 10 36650 T10 118 4.6 21 .8 .23 10 36651 T15 131 5.2 23 .9 .33 10 36652 T20 144 5.7 25 1.0 .44 10 36653 T25 158 6.2 28 1.1 .65 10 36654 T27 169 6.7 30 1.2 .98 10 36655 T30 184 7.2 32 1.3 1.27 10 36659 T40 201 7.9 35 1.4 2.09 10 36660 T45 222 8.7 40 1.6 2.70 10 36661 T50 213 8.4 40 1.6 3.14 10 Wiha ErgoStar Ball End Long L-keys 25O 36689 ErgoStar Long Arm Set, 13 Pc. In Molded Holder Equipped with T5, T6, T7, T8, T9, T10, T15, T20, T25, T27, T30, T40, T45 Item No. lbs. pkg. 36689 1.08 1 Wiha Security L-keys Security Torx® L-Keys 36699 Long Arm Set, 13 Pc. in Molded Holder Equipped with T5, T6, T7, T8, T9, T10, T15, T20, T25, T27, T30, T40, T50 Item No. lbs. pkg. 36699 1.13 1 36698 Long Arm Set, 10 Pc. In Molded Holder Equipped with T6, T7, T8, T9, T10, T15, T20, T25, T27, T30 Item No. lbs. pkg. 36698 4.4 1 363 Security L-key, Short Arm High alloy CVM steel, hardened, black finish. Item No. Size mm Inch mm Inch lbs. pkg. 36321 T7s 42 1.7 16 .6 .01 10 36323 T8s 45 1.8 16 .6 .01 10 36326 T9s 48 1.9 16 .6 .01 10 36328 T10s 51 2.0 17 .7 .01 10 36329 T15s 54 2.1 19 .7 .01 10 36332 T20s 58 2.3 19 .7 .02 10 36335 T25s 63 2.5 21 .8 .02 10 36337 T27s 67 2.6 22 .9 .03 10 36339 T30s 73 2.9 24 .9 .04 10 36342 T40s 79 3.1 26 1.0 .06 10 36346 T45s 82 3.2 28 1.1 .09 10 36352 T50s 95 3.7 35 1.3 .13 10 36357 T55s 108 4.3 38 1.4 .27 10 Security Torx® L-Key Set 26 Piece Combo Pack Long Arm And Hex Inch 36694 L-key Sets, In Pouch Set includes: 36699-13pc set T5-T50 and 36991-13pc set .050 - 3/8” Item No. lbs. pkg. 2.13 1 36694 36393 Security Set, 9 Pcs. In Plastic Holder Equipped with T8s, T9s, T10s, T15s, T20s, T25s, T27s, T30s, T40s Item No. lbs. pkg. .30 1 36393 www.wihatools.com 15 Wiha Offset Screwdrivers 207 Offset Screwdriver With Molded Handle For working in confined spaces. Blade CVM special steel, hardened, black finish. Item No. Size lbs. pkg. 20756 T6 + T8 .02 1 20757 T7 + T9 .02 1 20758 T10 + T15 .02 1 20759 T20 + T25 .07 1 20760 T27 + T30 .10 1 Offset Screwdriver Set, 5 Pcs. 20799 With Molded Handle Blade CVM special steel, hardened, black finish. Item No. Set Includes: T6+T8, T7+T9, lbs. pkg. 20799 T10+T15, T20+T25, T27+T30 .24 1 Wiha PocketStar Fold Outs Blade length range 1.68 - 1.94” Blade length range 1.68 - 1.94” Push button key release Push button key release PocketStar Fold Outs, 7 Pc. Set 36396 High alloy CVM steel, hardened, molded ergonomic handle. OAL 3.8” Item No. 36396 PocketStar lbs. .22 : T7, T8, T9, T10, T15, T20, T25 Security PocketStar Fold Outs, 7 Pc. Set 36395 High alloy CVM steel, hardened, molded ergonomic handle. OAL 3.8” Item No. PocketStar lbs. .22 36395 TR : T7s, T8s, T9s, T10s, T15s, T20s, T25s Blade length range 1.95 - 2.39” Push button key release 36398 PocketStar Fold Outs, 8 Pc. Set High alloy CVM steel, hardened, molded ergonomic handle. OAL 4.74” Item No. 36398 PocketStar lbs. .24 : T9, T10, T15, T20, T25, T27, T30, T40 Blade length range 1.95 - 2.39” Push button key release 36397 Security PocketStar Fold Outs, 8 Pc. Set High alloy CVM steel, hardened, molded ergonomic handle. OAL 4.74” Item No. PocketStar lbs. .24 36397 TR : T9s, T10s, T15s, T20s, T25s, T27s, T30s, T40s Toll Free: (800) 494-6104 16 Wiha Tools Ideal for use with indexable carbide tooling and also for working in confined spaces Ideal for use with indexable carbide tooling and also for working in confined spaces 365 Screwdriver, With Wing Handle Blade high alloy CVM steel, hardened, black finish. Wing handle high quality plastic, impact resistant. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 36510 T6 35 1.4 70 2.7 40 1.6 .02 10 36512 T7 35 1.4 70 2.7 40 1.6 .02 10 36515 T8 40 1.6 75 2.9 40 1.6 .02 10 36520 T9 40 1.6 75 2.9 40 1.6 .02 10 36525 T10 40 1.6 75 2.9 40 1.6 .02 10 36530 T15 45 1.8 80 3.1 40 1.6 .02 10 36535 T20 45 1.8 80 3.1 40 1.6 .02 10 370 Screwdriver, With Flag Handle Blade high alloy CVM steel, hardened, black finish. Flag handle high quality plastic, impact resistant. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 37013 T5 35 1.4 63 2.6 15.0 .75 .01 10 37016 T6 35 1.4 63 2.6 15.0 .75 .01 10 37019 T7 35 1.4 67 2.6 19.0 .75 .01 10 37022 T8 40 1.6 72 2.8 19.0 .75 .01 10 37026 T9 40 1.6 74 2.9 23.5 .93 .01 10 37029 T10 40 1.6 74 2.9 23.5 .93 .01 10 37032 T15 45 1.8 80 3.1 28.0 1.10 .02 10 37036 T20 45 1.8 80 3.1 28.0 1.10 .02 10 36591 Wing Handle Set, 7 Pc. Set includes: T6, T7, T8, T9, T10, T15, T20 37091 Flag Handle Set, 7 Pc. Set includes: T6, T7, T8, T9, T10, T15, T20 wt. .16 36590 Wing Handle Set, 7 Pc. In Metal Stand Set includes: T6, T7, T8, T9, T10, T15, T20 wt. .32 wt. .14 37090 Flag Handle Set, 7 Pc. in Metal Stand Set includes: T6, T7, T8, T9, T10, T15, T20 wt. .31 www.wihatools.com 17 Wiha Ball End Screwdrivers Wiha Ball End L-keys • Ball End For 25O Angle Driving • Precision Machined Exact Fit Tips 25O • Through Hardened For Maximum Durability • WIHA High Performance CRM-72 Tool Steel 366 • Guaranteed Quality Made By Wiha 25O 362 Ball End Screwdriver, With Wiha-SoftFinish® Handle Blade high alloy chrome-vanadium-molybdenum steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Wiha-SoftFinish® handle, multi-component, cushion grips. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 36216 T9 60 2.4 4.0 .157 164 6.5 .10 10 36217 T10 60 2.4 4.0 .157 184 7.2 .11 10 36221 T15 80 3.1 4.0 .157 191 7.5 .11 10 36222 T20 80 3.1 4.0 .157 211 8.3 .11 10 36226 T25 100 3.9 4.5 .177 218 8.6 .12 10 36227 T27 115 4.5 5.5 .216 233 9.2 .19 10 36236 T30 115 4.5 6.0 .236 233 9.2 .20 10 Ball End L-key, Long Arm chrome-vanadium-molybdenum steel, hardened, black finish. High alloy Item No. 36631 36632 36633 36634 36635 36636 36637 36638 Size mm Inch T9 111 4.4 T10 121 4.8 T15 136 5.4 T20 148 5.8 T25 163 6.4 T27 176 6.9 T30 191 7.5 T40 210 8.3 36237 Set 7 Pcs. Blade high alloy CVM steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Wiha-SoftFinish® handle, multi-component, cushion grips. Item No. Size mm Size mm lbs. 36216 T9 60 36226 T25 100 1.24 36237 36217 T10 60 36227 T27 115 36221 T15 80 36236 T30 115 36222 T20 80 Inch lbs. pkg. .83 .17 10 .91 .23 10 1.1 .33 10 1.1 .44 10 1.3 .65 10 1.4 .98 10 1.5 1.27 10 1.7 2.09 10 25O 36692 Ball End L-key Set, 8 Pc. in Plastic Holder Equipped with T9, T10, T15, T20, T25, T27, T30, T40 Item No. lbs. pkg. 6.16 1 36692 Wiha Ball End 25O mm 21 23 27 29 33 36 38 43 Power Bits 745 Ball End Power Bits 1/4” Hex Drive, Length 2.0”/50mm Item No. Size mm pkg. lbs. T9 50 10 .18 74524 T10 50 10 .18 74526 T15 50 10 .18 74528 T20 50 10 .18 74532 T25 50 10 .18 74534 T27 50 10 .18 74537 T30 50 10 .18 74539 T40 50 10 .18 74541 Ball End Power Bit Packs, 1” 745 2 bit Item pack No. Size mm lbs. 74505 T9 50 .05 74520 T10 50 .05 74522 T15 50 .05 74543 T20 50 .05 74545 T25 50 .06 74547 T27 50 .06 74549 T30 50 .08 74550 T40 50 .08 Toll Free: (800) 494-6104 18 The Advantage The TorxPlus® Drive System offers 100% improvement in driver bit fatigue & 25% average improvement in driver bit torsional strength. In addition its unique design provides optimum torque transfer & eliminates the need for excessive end load pressure while driving the fastener. The TorxPlus® configuration also virtually eliminates tool “camout” & slippage that can damage the head of the fastener and cause reduced tool life. 0o 60o Not for use in standard Torx fasteners • Broad Surface For Driving • Features 0O Drive Angle Between The Fastener & Driver • Greater Engagement Depth Wiha PocketStar Fold Out Push button key release 36697 PocketStar Fold Outs, 8 Pc. Set High alloy CVM steel, hardened, molded ergonomic handle. Item No. PocketStar lbs. .31 36697 : IP6, IP7, IP8, IP9, IP10, IP15, IP20, IP25 Wiha Tools Not for use in standard Torx fasteners #37092 370 Screwdriver, With Flag Handle Ideal for use with indexable carbide tooling and also for working in confined spaces. Blade high alloy CVM steel, hardened, black finish. Flag handle high quality plastic, impact resistant. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 37040 IP5 35 1.4 63 2.6 15.0 .75 .01 10 37042 IP6 35 1.4 63 2.6 15.0 .75 .01 10 37044 IP7 35 1.4 67 2.6 19.0 .75 .01 10 37046 IP8 40 1.6 72 2.8 19.0 .75 .01 10 37048 IP9 40 1.6 74 2.9 23.5 .93 .01 10 37050 IP10 40 1.6 74 2.9 23.5 .93 .01 10 37052 IP15 45 1.8 80 3.1 28.0 1.10 .02 10 37054 IP20 45 1.8 80 3.1 28.0 1.10 .02 10 37092 Flag Handle Set, 7 Pc. in Metal Stand Set includes: wt. .31 IP6, IP7, IP8, IP9, IP10, IP15, IP20 Not for use in standard Torx fasteners 36592 7 Pc. Wing Handle Set In Metal Stand Equipped with IP6, IP7, IP8, IP9, IP10, IP15, IP20 Item No. lbs. pkg. 36592 .38 1 365 Screwdriver, With Wing Handle Blade high alloy CVM steel, hardened, black finish. Wing handle high quality plastic, impact resistant. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 36540 IP5 35 1.4 70 2.7 40 1.6 .02 10 36542 IP6 35 1.4 70 2.7 40 1.6 .02 10 36544 IP7 35 1.4 70 2.7 40 1.6 .02 10 36546 IP8 40 1.6 75 3.0 40 1.6 .02 10 36548 IP9 40 1.6 75 3.0 40 1.6 .02 10 36550 IP10 40 1.6 75 3.0 40 1.6 .02 10 36552 IP15 45 1.8 80 3.1 40 1.6 .02 10 36554 IP20 45 1.8 80 3.1 40 1.6 .02 10 www.wihatools.com 19 Wiha Cushion Grip Drivers Wiha T-handle Not for use in standard Torx fasteners 362 Screwdriver With Wiha SoftFinish Handle Round blade high alloy Chrome-vanadium-molybdenum tool steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 36211 IP6 60 2.4 3.5 .139 164 6.5 .06 10 36223 IP7 60 2.4 3.5 .139 164 6.5 .06 10 36228 IP8 60 2.4 4.0 .157 171 6.7 .10 10 36229 IP9 60 2.4 4.0 .157 171 6.7 .11 10 36233 IP10 80 3.1 4.0 .157 191 7.5 .11 10 36238 IP15 80 3.1 4.0 .157 191 7.5 .11 10 36239 IP20 100 3.9 4.5 .177 211 8.3 .11 10 36243 IP25 100 3.9 5.5 .216 211 8.3 .19 10 36248 IP27 115 4.5 6.0 .236 233 9.2 .20 10 36253 IP30 115 4.5 7.0 .275 233 9.2 .28 10 36255 IP40 130 5.1 7.0 .275 254 10.0 .28 10 Set 7 Pcs. Blade high alloy CVM steel, 36299 hardened, hard chromed. Wiha-SoftFinish handle, multi-component. Item No. Size mm Size mm lbs. 1.23 36228 IP8 60 36243 IP25 100 36299 36233 IP10 80 36253 IP30 115 36238 IP15 80 36255 IP40 130 36239 IP20 100 36296 Set 6 Pcs. Blade high alloy CVM steel, hardened, hard chromed. Wiha-SoftFinish handle, multi-component. Item No. Size mm Size mm 36296 36211 IP6 60 36229 IP9 60 36213 IP7 60 36233 IP10 80 36228 IP8 60 36238 IP15 80 lbs. .72 Not for use in standard Torx fasteners 364 Screwdriver, With Wiha T-handle Blade high alloy chrome-vanadium-molybdenum steel, hardened, hard chromed. Wiha T-handle high quality plastic, impact resistant. Item No. Size mm Inch mm Inch mm Inch lbs pkg. 36461 IP9 100 3.9 4.0 .157 80 3.1 .07 10 36463 IP10 100 3.9 4.0 .157 80 3.1 .07 10 36466 IP15 100 3.9 4.0 .157 80 3.1 .07 10 36469 IP20 100 3.9 4.0 .157 80 3.1 .10 10 36472 IP25 150 5.9 8.0 .315 120 4.7 .13 10 36474 IP27 150 5.9 8.0 .315 120 4.7 .14 10 36476 IP30 150 5.9 8.0 .315 120 4.7 .16 10 36478 IP40 150 5.9 8.0 .315 120 4.7 .20 10 36496 Set 6 Pc. T-handles Blade CVM steel, hardened, hard chromed. Chromtop blade tips. Wiha T-handle high quality plastic, impact resistant. Item No. Size mm Size mm lbs. 36472 IP25 150 36463 IP10 100 1.01 36496 36474 IP27 150 36466 IP15 100 36476 IP30 150 36469 IP20 100 Toll Free: (800) 494-6104 20 For Improved Torque and Longer Tool Life Not for use in standard Torx fasteners Not for use in standard Torx fasteners 361 L-key, Short Arm High alloy chrome-vanadium-molybdenum steel, hardened, black finish. Item No. Size mm Inch mm Inch lbs. pkg. 36106 IP6 39 1.5 16 .6 .01 10 36107 IP7 42 1.7 16 .6 .01 10 36108 IP8 45 1.8 16 .6 .01 10 36109 IP9 48 1.9 16 .6 .01 10 36110 IP10 51 2.0 17 .7 .01 10 36115 IP15 55 2.2 19 .7 .01 10 36120 IP20 58 2.3 19 .7 .01 10 36125 IP25 63 2.5 21 .8 .01 10 36127 IP27 68 2.7 22 .9 .02 10 36130 IP30 73 2.9 24 .9 .03 10 36140 IP40 81 3.2 26 1.0 .05 10 366 L-key, Long Arm High alloy chrome-vanadium-molybdenum steel, hardened, black finish. Item No. Size mm Inch mm Inch lbs. pkg. IP6 64 2.5 14 .6 .01 10 36606 IP7 68 2.7 14 .6 .01 10 36607 IP8 74 2.9 15 .6 .01 10 36608 IP9 78 3.1 16 .6 .01 10 36609 IP10 83 3.3 18 .7 .01 10 36610 IP15 88 3.5 18 .7 .02 10 36615 IP20 94 3.7 18 .7 .02 10 36620 IP25 98 3.9 19 .7 .03 10 36625 IP27 107 4.2 23 .9 .05 10 36627 IP30 114 4.5 24 .9 .06 10 36630 IP40 118 4.6 27 1.0 .09 10 36640 36197 L-key, Short Arm, 7 Pc. Set In Holder High alloy chrome-vanadium-molybdenum steel, hardened, black finish. Item No. 36197 lbs. pkg. Set includes the following L-keys: .10 1 IP6, IP7, IP8, IP9, IP10, IP15, IP20 36690 L-key, Long Arm, 7 Pc. Set In Holder High alloy chrome-vanadium-molybdenum steel, hardened, black finish. Item No. lbs. pkg. Set includes the following L-keys: 36690 .22 1 IP6, IP7, IP8, IP9, IP10, IP15, IP20 36199 Item No. lbs. pkg. 36199 .30 1 36691 Item No. lbs. pkg. 36691 .35 1 L-key, Short Arm, 9 Pc. Set In Holder Set includes the following L-keys: IP8, IP9, IP10, IP15, IP20, IP25, IP27, IP30, IP40 L-key, Long Arm, 9 Pc. Set In Holder Set includes the following L-keys: IP8, IP9, IP10, IP15, IP20, IP25 IP27, IP30, IP40 www.wihatools.com 21 Wiha MagicSpring • Laser welded assembly • Holds screws securely Tools Screw Holding TORX® Laser Welded MagicSpring Assembly • Won’t damage screws • Doesn’t weaken tool • Exact fit tips • Hardened tool steel blades • Holds standard Torx screws* Stainless Rotary Spring 362 MagicSpring Screw Holding Driver, With WihaSoftFinish® Handle Round blade high alloy chrome-vanadiummolybdenum steel, hardened, hard chromed. Wiha-Chromtop finish on tips. Wiha-SoftFinish® handle, multi-component, cushion grips. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 36202 T6 60 2.4 3.5 .139 164 6.5 .07 10 36203 T7 60 2.4 3.5 .139 164 6.5 .07 10 36207 T8 60 2.4 3.5 .139 164 6.5 .07 10 36234 T9 60 2.4 4.0 .157 171 6.7 .11 10 36244 T10 80 3.1 4.0 .157 191 7.5 .11 10 36249 T15 80 3.1 4.0 .157 191 7.5 .11 10 36254 T20 100 3.9 4.0 .157 211 8.3 .16 10 36256 T25 100 3.9 4.5 .177 211 8.3 .17 10 36257 T27 115 4.5 5.5 .216 233 9.2 .20 10 36258 T30 115 4.5 6.0 .236 233 9.2 .21 10 267 MagicSpring Screw Holding Driver, With WihaPrecision PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. Molded on ergonomic Wiha-Pico Finish precision handle, molded on, soft grips. Item No. Size mm Inch mm Inch lbs. pkg. T6 40 1.6 140 5.5 .03 10 26721 T7 40 1.6 140 5.5 .03 10 26723 T8 40 1.6 140 5.5 .03 10 26725 26727 T9 50 2.0 150 5.9 .04 10 26729 T10 50 2.0 150 5.9 .04 10 26731 T15 60 2.4 160 6.3 .04 10 SoftFinish 36290 Set 6 Pcs. MagicSpring Screw Holding Screwdrivers Round blade high alloy chrome-vanadium-molybdenum steel, hardened, hard chromed. Wiha-Chromtop finish on tips. WihaSoftFinish® handle, multi-component, cushion grips. Molded on. Item No. Size mm Size mm lbs. 36207 T8 60 36254 T20 100 .98 36290 36244 T10 80 36256 T25 100 36249 T15 80 36258 T30 115 26798 Set 6 Pcs. MagicSpring Screw Holding Screwdriver, With Wiha-Precision PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. Molded on ergonomic Wiha-Pico Finish precision handle, molded on, soft grips. Item No. Size mm 26798 26721 T6 40 26727 26723 T7 40 26729 26725 T8 40 26731 *MagicSpring tools will hold Torx® screws made to CamCar Textron Torx® specifications Size mm lbs. T9 50 .45 T10 50 T15 60 Toll Free: (800) 494-6104 22 Wiha MagicSpring Tools 371 MagicSpring Screw Holding L-key, Long Arm High alloy chrome-vanadium-molybdenum steel, hardened, black finish. Item No. Size mm Inch lbs. pkg. T6 14 .55 .001 10 37106 T7 16 .63 .002 10 37107 T8 18 .71 .003 10 37108 T9 19 .75 .005 10 37109 T10 21 .83 .007 10 37110 T15 22 .87 .009 10 37115 T20 25 .98 .01 10 37120 T25 28 1.1 .02 10 37125 T27 30 1.2 .03 10 37127 T30 34 1.3 .04 10 37130 T40 36 1.4 .07 10 37140 Wiha MagicSpring Tools 365 MagicSpring Screw Holding driver, With Wing Handle Ideal for use with indexable carbide tooling and also for working in confined spaces. Blade high alloy CVM steel, hardened, black finish. Wing handle high quality plastic, impact resistant. Molded on. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 36556 T6 35 1.4 70 2.7 40 1.6 .01 10 36557 T7 35 1.4 70 2.7 40 1.6 .02 10 36558 T8 40 1.6 75 3.0 40 1.6 .02 10 36559 T9 40 1.6 75 3.0 40 1.6 .02 10 36560 T10 40 1.6 75 3.0 40 1.6 .02 10 36561 T15 45 1.8 80 3.1 40 1.6 .02 10 36562 T20 45 1.8 80 3.1 40 1.6 .02 10 MagicSpring Screw Holding 36598 7 Pc. in Metal Stand Equipped with T6, T7, T8, T9, T10, T15, T20 Wing Handle Set, .36 lbs. MagicSpring Long Arm Screw Holding Set, 37190 7 Pc. in Plastic Holder Equipped with T6, T7, T8, T9, T10, T15, T20 Item No. lbs. pkg. .20 1 37190 MagicSpring Long Arm Screw Holding Set, 37192 10 Pc. in Plastic Holder Equipped with T6, T7, T8, T9, T10, T15, T20, T25, T27, T30 Item No. lbs. pkg. .35 1 37192 Screw Holding Tools www.wihatools.com 23 Wiha TorqueControl Screwdrivers Molded cushion grip two component handles allow for maximum achievable torque to be reached with comfort Precise repeatability! All TorqueVario tools are tested and comply with: • EN ISO 6798 • BS EN 26789 • ASME B107.14M Each tool has unique serial number and certificate of calibration TorqueVario models include torque setting adjustment tool and Micro Bit holder See 4mm Micro Bits on Page 28 Direct Reading Scale +/-6% accuracy tolerance Certificate of calibration 285 Adjustable TorqueVario With Direct Reading Scale EN ISO 6798, BS EN 26789, ASME B107.14M. Ergonomic molded multi-component handle, light and compact. Handle sizes proportioned to optimize torque range. Audible and perceptible click when the torque setting has been attained, automatically resets for next torque cycle. Item Range No. Inch lbs. Increments mm lbs. pkg. 28501 15 - 80(in/oz) 2.5 Inch oz 122 - 127 .22 1 28502 5 - 10 .2 Inch lbs 122 - 127 .41 1 28504 7.5 - 20 .5 Inch lbs 126 - 131 .50 1 28506 10 - 50 2 Inch lbs 133 - 138 .59 1 28508 20 - 70 2 Inch lbs 137 - 142 .74 1 Above includes Micro Bit Holder 28583 * +/- 10% (This unit only) See 4mm Micro Bits on Page 28 Interchangeable Blades For TorqueFix & TorqueVario tip blades on narrow 5/32 Hex shafts. High alloy chromevanadium-molybdenum steel, hardened, satin hard chrome finish. Item Max. Torque No. Size mm mm lbs. Nm pkg. 28561 T5 175 4.0 .07 0.4 1 28562 T6 175 4.0 .07 0.6 1 28563 T7 175 4.0 .07 0.9 1 28564 T8 175 4.0 .07 1.3 1 28565 T9 175 4.0 .07 2.5 1 28566 T10 175 4.0 .07 3.5 1 28567 T15 175 4.0 .07 5.5 1 28568 T20 175 4.0 .07 8.0 1 28569 T25 175 4.0 .07 8.0 1 285 285 Blades For TorqueFix & TorqueVario tip blades on narrow 5/32 Hex shafts. Item Max. Torque No. Size mm mm lbs. Nm pkg. IP5 175 4.0 .07 0.5 1 28571 28572 IP6 175 4.0 .07 0.8 1 IP7 175 4.0 .07 1.3 1 28573 IP8 175 4.0 .07 2.0 1 28574 IP9 175 4.0 .07 3.0 1 28575 IP10 175 4.0 .07 4.5 1 28576 IP15 175 4.0 .07 6.6 1 28577 IP20 175 4.0 .07 8.0 1 28578 IP25 175 4.0 .07 8.0 1 28579 Interchangeable Blades For TorqueFix 285 MagicSpring & TorqueVario blades on narrow 5/32 Hex shafts. Item Max. Torque No. Size mm mm lbs. Nm pkg. T6 175 4.0 .07 0.6 1 28512 T7 175 4.0 .07 0.9 1 28527 Screw olding H T8 175 4.0 .07 1.3 1 28528 T9 175 4.0 .07 2.5 1 28529 T10 175 4.0 .07 3.8 1 28530 T15 175 4.0 .07 5.5 1 28531 T20 175 4.0 .07 8.0 1 28532 T25 175 4.0 .07 8.0 1 28533 +/-6% accuracy tolerance Certificate of calibration Adjustable TorqueVario-S Handle - In Newton Meter Scale 285 EN ISO 6798, BS EN 26789, ASME B107.14M. Ergonomic molded multi-component handle, light and compact. Handle sizes proportioned to optimize torque range. Audible and perceptible click when the torque setting has been attained, automatically resets for next torque cycle. Item Newton No. Meter Scale Increments mm lbs. pkg. 28550 0.1 - 0.6Nm .02 Nm 122 - 127 .35 1 28551 0.4 - 1.0Nm .05 Nm 122 - 127 .35 1 28552 0.8 - 2.0Nm .05 Nm 126 - 131 .45 1 28553 1.0 - 5.0Nm .20 Nm 133 - 138 .55 1 28554 2.0 - 8.0Nm .25 Nm 137 - 142 .70 1 * +/- 10% (This unit only) MagicSpring Interchangeable Blades For 286 TorqueFix & TorqueVario blades on narrow 5/32 Hex shafts. Item Max. Torque No. Size mm mm lbs. Nm pkg. 28611 IP6 175 4.0 .07 0.8 1 IP7 175 4.0 .07 1.3 1 28612 IP8 175 4.0 .07 2.0 1 28613 Screw g IP9 175 4.0 .07 3.0 1 28614 Holdin IP10 175 4.0 .07 4.5 1 28616 IP15 175 4.0 .07 6.6 1 28617 IP20 175 4.0 .07 8.0 1 28618 IP25 175 4.0 .07 8.0 1 28619 Toll Free: (800) 494-6104 24 Wiha Easy Torque Handles • • • • • • • Audible Click At Torque Replaceable Blades +/- 10% Repeatability Improve Productivity Reduces Waste Controls Costs Save Time! 292 Easy Torque Screwdriver Handle Easy Torque value pre-set. Release accuracy +/- 10%. SoftFinish cushion grip handle for good power transfer. Item Pre-Sets No. Inch/lbs. Nm mm Inch lbs. pkg. 29205 4.4 0.5 137 5.4 .20 1 29206 5.3 0.6 137 5.4 .20 1 29209 8.0 0.9 137 5.4 .20 1 29211 9.7 1.1 137 5.4 .20 1 29212 10.6 1.2 137 5.4 .20 1 29214 12.4 1.4 137 5.4 .20 1 29220 17.7 2.0 137 5.4 .20 1 29225 22.1 2.5 137 5.4 .20 1 29230 26.6 3.0 137 5.4 .20 1 29238 33.6 3.8 137 5.4 .20 1 29241 35.4 4.0 137 5.4 .20 1 29245 39.8 4.5 137 5.4 .20 1 29251 44.2 5.0 137 5.4 .20 1 * No Calibration Certificates ESD Safe Adjustable TorqueControl Tools Handle sizes proportioned to optimize torque range Wiha Insulated TorqueControl Tools 1000V Includes Certificate Insulated TorqueVario-S, With Window Scale Insulation 287 up to 1000 Volt. EN ISO 6798, BS EN 26789, ASME B107.14M, VDE, ASTM F-1505-01 & NFPA70E, +/- 6% Accuracy. Handle sizes proportioned to optimize torque range. Audible and perceptible click when torque setting has been attained. Includes SlimLine blade holder. Item Range No. Inch lbs. Increments mm lbs. pkg. 7.5 - 20 .5 Inch lbs 126 - 131 .43 1 28724 10 - 50 2 Inch lbs 133 - 138 .40 1 28726 20 - 70 2 Inch lbs 137 - 142 .69 1 28727 Each TorqueVario handle has unique serial number and certificate of calibration 287 Insulated TorqueVario-S Handle - In Newton Meter Scale Includes SlimLine blade holder. Item Range No. Nm mm lbs. pkg. 28734 0.6 - 2.0 131 .45 1 28736 1.0 - 5.0 138 .45 1 28737 2.0 - 8.0 142 .72 1 Each TorqueVario handle has unique serial number and certificate of calibration 1.8” D Includes Certificate 285 ESD Safe TorqueVario-S, With Window Scale EN ISO 6798, BS EN 26789, ASME B107.14M, +/- 6% Accuracy Ergonomic multi-component handle, light and compact. Audible and perceptible click when torque setting has been attained. Item Range No. Inch lbs. Increments mm lbs. pkg. 1 28522* 15 - 80(in/oz) 2.5 Inch oz 122 - 127 .33 28524 5 - 10 .2 Inch lbs 122 - 127 .34 1 28526 7.5 - 20 .5 Inch lbs 126 - 131 .42 1 * +/- 10% (This unit only) ESD Safe Interchangeable Blades For 288 TorqueVario-S tip blades on narrow 5/32” Hex shafts. High alloy chrome-vanadium-molybdenum steel, hardened, hard chromed. Item Max. Torque No. Size mm mm lbs. Nm pkg. 28825 T5 175 4.0 .07 0.4 1 28826 T6 175 4.0 .07 0.6 1 28827 T7 175 4.0 .07 0.9 1 28828 T8 175 4.0 .07 1.3 1 28829 T9 175 4.0 .07 2.5 1 28830 T10 175 4.0 .07 3.8 1 283 Insulated SlimLine Blades High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Item Slim Working Max Inch/ No. Size mm Dia. Length Nm lbs. lbs. Pkg. 28339 T8 90 4.1 2.8” 1.3 11.5 .02 1 28340 T10 90 4.1 2.8” 3.8 33.7 .02 1 28341 T15 90 6.1 2.8” 5.5 48.8 .02 1 28342 T20 90 6.1 2.8” 5.5 48.8 .02 1 www.wihatools.com 25 TorqueControl Tools T-handle TorqueControl Tools With Certificate of Calibration STplus Handle Ergonomic multi-component handle, light and compact. Includes Calibration Certificate 28597 Set 8 Pc. TorqueControl Set With Blades Certified to EN ISO 6798, BS EN 26789, ASME B107.14M lbs. : : T7, T8, T9, T10, T15, T20 1.01 28597 28506 Handle Range 10 - 50 Inch lbs. With Certificate of Calibration 28598 Set 8 Pc. TorqueControl Set With Blades Certified to EN ISO 6798, BS EN 26789, ASME B107.14M lbs. 28598 : IP7, IP8, IP9, IP10, IP15, IP20 1.00 28506 Handle Range 10 - 50 Inch lbs. With Certificate of Calibration 28599 14 Pc. TorqueControl Set With & Blades Certified to EN ISO 6798, BS EN 26789, ASME B107.14M. Set includes Ergonomic multi-component adjustable TorqueVario-S handle, 12 blades & Torque adjustment tool. Packed in a durable canvas pouch. Item No. lbs. 28599 : T7, T8, T9, T10, T15, T20 1.25 : IP7, IP8, IP9, IP10, IP15, IP20 28506 - Handle Range 10 - 50 Inch lbs. * (1 Nm 8.8507) 289 Item No. 28903 28904 28905 28906 28907 28908 289 With Certificate of Calibration With Certificate of Calibration Screw g Holdin 289 TorqueFix T-handle EN ISO 6798, BS EN 26789, ASME B107.14M, +/- 6% Accuracy. Item Torque Torque No. In-lbs. Nm mm x mm lbs. pkg. 28931 6 56 x 120 .81 1 53.1 28933 70.8 8 56 x 120 .82 1 28935 88.5 10 56 x 120 .79 1 28937 106.2 12 56 x 120 .79 1 28938 110.6 12.5 56 x 120 .80 1 28939 123.9 14 56 x 120 .80 1 28940 Adjustable TorqueVario STplus T-handle Item Torque Torque No. In-lbs. Nm mm x mm lbs. pkg. 44.3-123.9 5-14 56 x 120 .81 1 28940 Certified to EN ISO 6798, BS EN 26789, ASME B107.14M 28690 Set 8 Pc. TorqueControl Set With MagicSpring Screw Holding Blades MagicSpring : 28690 T7, T8, T9, T10, T15, T20 lbs. 28506 Handle Range 10 - 50 Inch lbs. 1.00 Item No. 28910 28911 28912 28913 28914 28915 Interchangeable Blades For TorqueFix T-Handle tip blades on 6mm Hex shafts. Size mm Inch mm lbs. T15 130 5.1 6.0 .07 T20 130 5.1 6.0 .07 T25 130 5.1 6.0 .07 T27 130 5.1 6.0 .07 T30 130 5.1 6.0 .07 T40 130 5.1 6.0 .07 pkg. 1 1 1 1 1 1 Interchangeable Blades For TorqueFix T-Handle tip blades on 6mm Hex shafts. Size mm Inch mm lbs. pkg. IP15 130 5.1 6.0 .07 1 IP20 130 5.1 6.0 .07 1 IP25 130 5.1 6.0 .07 1 IP27 130 5.1 6.0 .07 1 IP30 130 5.1 6.0 .07 1 IP40 130 5.1 6.0 .07 1 Toll Free: (800) 494-6104 26 Precision ESD Safe Drivers 278 Screwdriver, With Precision ESD Safe Dissipative Handle Blade high alloy CVM steel. Hard chrome finished. Handle impact resistant, dissipative material. ESD standard IEC 61340-5-1 Item No. Size mm Inch mm Inch lbs. pkg. 27801 T1 40 1.6 120 4.7 .03 10 27802 T2 40 1.6 120 4.7 .03 10 27803 T3 40 1.6 120 4.7 .03 10 27804 T4 40 1.6 120 4.7 .03 10 27805 T5 40 1.6 120 4.7 .03 10 27811 T6 40 1.6 120 4.7 .03 10 27817 T7 40 1.6 120 4.7 .03 10 27823 T8 40 1.6 120 4.7 .03 10 27829 T9 50 2.0 145 5.7 .04 10 27835 T10 50 2.0 145 5.7 .04 10 27841 T15 60 2.4 170 6.7 .07 10 27847 T20 60 2.4 170 6.7 .07 10 *Metric dimensions actual - Inch dimensions approximate Precision ESD Safe Drivers D 278 Driver, With Precision ESD Safe Dissipative Handle Blade high alloy CVM steel, hardened, hard chromed. Handle impact resistant, dissipative material. ESD standard IEC 61340-5-1 Item No. Size mm Inch mm Inch lbs. pkg. IP4 40 1.6 120 4.7 .03 10 27850 IP5 40 1.6 120 4.7 .03 10 27851 IP6 40 1.6 120 4.7 .03 10 27852 IP7 40 1.6 120 4.7 .03 10 27853 IP8 40 1.6 120 4.7 .03 10 27854 IP9 50 2.0 145 5.7 .04 10 27855 IP10 50 2.0 145 5.7 .04 10 27856 IP15 60 2.4 170 6.7 .07 10 27857 *Metric dimensions actual - Inch dimensions approximate ESD standard IEC 61340-5-1 ESD standard IEC 61340-5-1 D D 27890 Set 7 Pcs. Precision ESD Safe Dissipative Handle Blade high alloy CVM steel, hardened, hard chromed. Handle manufactured from impact resistant, dissipative material. Item No. Size mm Size mm lbs. 27890 27804 T4 40 27823 T8 40 .31 27805 T5 40 27829 T9 50 27811 T6 40 27835 T10 50 27817 T7 40 ESD standard IEC 61340-5-1 Precision ESD Safe Dissipative 27894 Set 7 Pcs. Handle Blade high alloy CVM steel, hardened, hard chromed. Item No. Size mm Size mm lbs. 27851 IP5 40 27855 IP9 50 .32 27894 27852 IP6 40 27856 IP10 50 27853 IP7 40 27857 IP15 60 27854 IP8 40 Wiha Precision Series D Set 8 Pcs. Precision ESD Safe Dissipative 27899 Handle Set In Pouch Blade high alloy CVM steel, hardened, hard chromed. Handle impact resistant, dissipative material. Item No. Size mm Size mm lbs. 27899 27801 T1 40 27805 T5 40 .30 27802 T2 40 27806 T6 40 27803 T3 40 27807 T7 40 27804 T4 40 27920 Chip Lifter 26799 Set 8 Pcs. Drivers In Canvas Pouch Blade high alloy chrome-vanadium-molybdenum steel. Hard chrome finished. In storage pouch Item No. Size mm Size mm lbs. 26703 T3 40 26707 T7 40 .50 26799 26704 T4 40 26708 T8 40 26705 T5 40 26709 T9 50 26706 T6 40 26710 T10 50 www.wihatools.com 27 Wiha 267 Precision Series Screwdriver, With Precision Handle Blade high alloy chrome-vanadium-molybdenum steel. Item No. Size mm Inch mm Inch lbs. pkg. 26701 T1 40 1.6 120 4.7 .01 10 26702 T2 40 1.6 120 4.7 .02 10 26703 T3 40 1.6 120 4.7 .02 10 26704 T4 40 1.6 120 4.7 .02 10 26705 T5 40 1.6 120 4.7 .02 10 26706 T6 40 1.6 120 4.7 .02 10 26707 T7 40 1.6 120 4.7 .02 10 26708 T8 40 1.6 120 4.7 .03 10 26709 T9 50 2.0 145 5.7 .03 10 26710 T10 50 2.0 145 5.7 .03 10 26715 T15 60 2.4 170 6.7 .05 10 26720 T20 60 2.4 170 6.7 .05 10 *Metric dimensions actual - Inch dimensions approximate Set 6 Pcs. Driver 26790 Blade high alloy CVM steel. Item No. Size mm lbs. 26790 26706 T6 40 .25 26707 T7 40 26708 T8 40 26709 T9 50 26710 T10 50 26715 T15 60 Wiha Pico Soft Grip 267 Screwdriver, With Precision Soft PicoFinish Handle Blade high alloy chrome-vanadium-molybdenum tool steel, hardened, hard chrome finish. Item No. Size mm Inch mm Inch pkg. 26732 T1 40 1.6 134 5.3 10 26733 T2 40 1.6 134 5.3 10 26735 T3 40 1.6 134 5.3 10 26736 T4 40 1.6 134 5.3 10 26737 T5 40 1.6 134 5.3 10 26739 T6 40 1.6 140 5.5 10 26741 T7 40 1.6 140 5.5 10 26743 T8 40 1.6 140 5.5 10 26745 T9 50 2.0 150 5.9 10 26747 T10 50 2.0 150 5.9 10 26749 T15 60 2.4 160 6.3 10 26751 T20 60 2.4 160 6.3 10 *Metric dimensions actual - Inch dimensions approximate 26793 Set 8 Pcs. Precision Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. ChromTop finish on tip for a perfect fit. In storage pouch Item No. Size mm Size mm lbs. 26793 26732 T1 40 26737 T5 40 .50 26733 T2 40 26739 T6 40 26735 T3 40 26741 T7 40 26736 T4 40 26743 T8 40 26791 Set 8 Pcs. Screwdriver Set Item No. 26791 T1, T2, T3, T4, T5, T6, T7, T8 Set 7 Pcs. Driver 26792 Blade high alloy CVM steel. Item No. Size mm lbs. 26705 T5 40 .27 26792 26706 T6 40 26707 T7 40 26708 T8 40 26709 T9 50 26710 T10 50 26715 T15 60 26796 Set 8 Pcs. Precision Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. ChromTop finish on tip for a perfect fit. In storage pouch Item No. Size mm Size mm lbs. 26796 26737 T5 40 26745 T9 50 .57 26739 T6 40 26747 T10 50 26741 T7 40 26749 T15 60 26743 T8 40 26751 T20 60 Toll Free: (800) 494-6104 28 Wiha SYSTEM 4 Handle, Bits & Sets D SYSTEM 4 Handles & Micro Bits Tips Exact fit, precision machined Rotating Cap for precise turning & control Tapered Handle allows rapid rotation, requires less clearance. Static Dissipative 106 - 109 ohms Bits CVM steel, hardened Use bits directly in handle or with 4” bit extension High alloy CVM steel, hardened, on 4 mm stock 757 Item No. 75703 75704 75705 75706 75707 75708 75709 75710 75715 75720 SYSTEM 4 Micro Bits Size mm Inch lbs. T3 28 1.1 .01 T4 28 1.1 .01 T5 28 1.1 .01 T6 28 1.1 .01 T7 28 1.1 .01 T8 28 1.1 .01 T9 28 1.1 .01 T10 28 1.1 .01 T15 28 1.1 .01 T20 28 1.1 .01 High alloy CVM steel, hardened, on 4 mm stock 757 Item No. 75727 75728 75729 75735 75739 75742 SYSTEM 4 Security Size mm Inch T7s 28 1.1 T8s 28 1.1 T9s 28 1.1 T10s 28 1.1 T15s 28 1.1 T20s 28 1.1 Micro Bits 75801 SYSTEM 4 ESD Safe Dissipative Precision Bit Handle with rotating control cap. For Wiha Micro Bits. Micro Bit Advantages: Holder • For working in ESD sensitive applications Surface resistant 106-109 Ohms 100mm length • Ball retainer holds bits securely in place • Accepts all SYSTEM 4 Series bits Item #75900 • 110mm/4.3” OAL Item No. mm Inch mm Inch lbs. 4.0 .1574 14.0 .55 .06 75801 75792 SYSTEM 4 Precision Interchangeable Bit Set, 11 Pcs. In Compact Fold Out Box Set includes your choice of Wiha precision handle, bit extension and 9 Wiha interchangeable bits. Item SYSTEM 4 No. Bit Sets 75792 Set with ESD Safe Precision Handle Set includes the following bits: Sizes: T3, T4, T5, T6, T7, T8, T9, T10, T15 100mm Bit Extension 11 lbs. .64 SYSTEM 4 Slotted, Phillips, 75093 Compact ESD Precision Interchangeable Bit Set, 16 Pcs. Item No. Combination Bit Set 75093 Set with Standard Precision Handle Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: 00, 0, 1 : T6, T7, T8, T9, T10, T15, T20 100mm Bit Extension lbs. .17 Pc. Se t D lbs. .01 .01 .01 .01 .01 .01 75985 Micro Bit Handle Storage Bit Set, 7 Pcs. Wiha precision storage handle & 6 interchangeable bits. Item No. Set with Precision Storage Handle : T3, T4, T5, T6, T7, T8 75985 lbs. .08 www.wihatools.com 29 ESD Safe SYSTEM 4 Blade Sets ESD Safe Precision Handles & Blades D D 28000 ESD Safe Dissipative Precision Handle with rotating control cap. Surface resistant 106-109 Ohms. 4 mm hex retainer for all SYSTEM 4 interchangeable blades. Tapered handle, high quality plastic, impact resistant. Ball retainer hold. 110mm/4.3” OAL Item No. mm Inch mm Inch lbs. 4.0 .1574 14.0 .55 .04 28000 26995 Precision Interchangeable Blade Set, 5 Pcs. Wiha ESD Safe precision collet lock handle & 4 interchangeable blades. Set includes the following blades: 26995 Sizes: T6, T7, T8, T9, T10, T15, T20 lbs. .54 D 28001 ESD Safe Dissipative Precision Adjustable Handle with rotating control cap. • Use in ESD sensitive applications. Surface resistant 106-109 Ohms. • Collet lock allows for quick & easy adjustment. • Holds blade securely in place. Accepts all SYSTEM 4 blades. 110mm/4.3” OAL Item No. mm Inch mm Inch lbs. 28001 4.0 .1574 14.0 .55 .04 269 SYSTEM 4 Reversible Blade High alloy CVM steel, hardened, vapor chrome protected, Wiha vapor Chrome-Top finish on tips. 120mm/4.7” OAL. Item No. Size Size lbs. T6 + T8 .03 26951 T7 + T9 .03 26952 T10 + T15 .03 26953 T15 + T20 .03 26954 D 26987 Precision Interchangeable Blade Set, 8 Pcs. Wiha ESD Safe precision collet lock handle and 7 interchangeable blades. 26987 Set includes the following blades: Sizes-standard blades: T3, T4, T5 Sizes-reversible blades: T6, T7, T8, T9, T10, T15, T20 lbs. .53 ESD Safe SYS 4 Drive-Loc Handle & Blades D 269 SYSTEM 4 Interchangeable Blade High alloy CVM steel, hardened, Wiha chrome-Top finish on tips. 120mm/4.7” OAL Item No. Size lbs. 26955 T3 .03 26956 T4 .03 26957 T5 .03 26961 ESD Safe Dissipative Precision Drive-Loc Handle Surface resistant 106-109 Ohms. 4 mm hex retainer for all SYSTEM 4 interchangeable blades. Ball retainer hold. 110mm/4.3” OAL Item No. mm Inch mm Inch lbs. 4.0 .1574 23 .91 .08 26961 ESD Safe D 28087 Precision Interchangeable Blade Set, 8 Pcs. Wiha ESD Safe precision collet lock handle & 7 Wiha blades. Set includes the following blades: 28087 Sizes on standard blades: T3, T4, T5 Sizes on reversible blades: T6, T7, T8, T9, T10, T15, T20 lbs. .31 269 Item No. 26977 26978 26979 26980 26981 26982 SYSTEM 4 Size T1 + T3 + T5 + T6 + T7 + T10 + Size T2 T4 T6 T8 T9 T15 Drive-Loc Reversible Blades lbs. .03 .03 .03 .03 .03 .03 Toll Free: (800) 494-6104 30 Wiha CushionGrip Stubby Bit Holders Wiha BitFlip Bit Set BitFlip Standard 38045 SoftFinish® CushionGrip Stubby Bit Holder with Wiha cushion grip handle and CVM tool steel shaft. Set includes the following 1/4” bits: Sizes: T8, T10, T15, T20, T25, T30 lbs. .20 38028 BitFlip Standard with Wiha cushion grip handle and insulated shaft. Set includes the following 1/4” bits: Sizes: T8, T10, T15, T20, lbs. T25, T27, T30, T40 .44 Wiha Multi-Bit Screwdriver Sets 38047 Security SoftFinish® CushionGrip Stubby Bit Holder with Wiha cushion grip handle and CVM tool steel shaft. Set includes the following 1/4” bits: Security Sizes: lbs. T8s, T10s, T15s, T20s, T25s, T30s .20 (bits not included) 28103 1/4” Magnetic Bit Holder With Wiha SoftFinish® Stubby Handle Works in confined spaces. Stainless steel with strong magnet. Item No. Inch mm Inch lbs. pkg. 1/4” 57 2.2 .11 1 28103 Wiha Topra Ratchet Handle Sets 28295 Topra Ratchet Bit Set, 12 Pcs. Set Includes Topra Handle, Magnetic Bit Holder & The Following Bits: Sizes: T7, T8, T9, T10, T15, T20, T25, T27, T30, T40 lbs. . 65 38003 Multi-Bit Screwdriver with Wiha Powerhandle Set includes the following 1/4” bits: Sizes: lbs. T5, T6, T7, T8, T9, T10 .36 38004 Multi-Bit Screwdriver with Wiha Powerhandle Set includes the following 1/4” bits: Sizes: lbs. T8, T9, T10, T15, T20, T25 .36 38008 Multi-Bit Screwdriver with Wiha Powerhandle Set includes the following 1/4” bits: Sizes: lbs. T10, T15, T20, T25, T30, T40 .36 38009 Security Screwdriver With Wiha Powerhandle Set includes the following 1/4” bits: Security Sizes: lbs. T7s, T8s, T9s, T10s, T15s, T20s .36 38010 Security Screwdriver With Wiha Powerhandle Set includes the following 1/4” bits: Security Sizes: lbs. T10s, T15s, T20s, T25s, T30s, T40s .36 (bits not included) 28297 Security Topra Ratchet Bit Set, 12 Pcs. Set Includes Topra Handle, Magnetic Bit Holder & The Following Bits: lbs. Security Sizes: .65 T7s, T8s, T9s, T10s, T15s, T20s, T25s, T27s, T30s, T40s 38015 Item No. 38015 1/4” Magnetic Bit Holder, Cavity holds up to 6 bits. Size mm Inch mm Inch lbs. pkg. 1/4” 120 4.7 230 9.0 .25 1 www.wihatools.com 31 Wiha Power Bit Belt Packs Wiha Insert Bit Selectors 79242 79245 Bit-Selector With Bits Set includes magnetic 1/4” bit holder and the following 10 bits: Sizes: T5, T6, T7, T8, T9, T10, T15, T20, T25, T30 Bit-Selector With Bits Set includes magnetic 1/4” bit holder and the following 10 bits: Sizes: T7, T8, T9, T10, T15, T20, T25, T27, T30, T40 lbs. .32 74985 79247 Bit-Selector With Security Bits Set includes magnetic 1/4” bit holder and the following 10 bits: lbs. Security Sizes: .32 T7s, T8s, T9s, T10s, T 15s, T20s, T25s, T27s, T30s, T40s 70190 Bit-Selector With Security Bits Set includes the following 7 bits: Security Sizes: lbs. T7s, T8s, T9s, T10s, T 15s, T20s, T25s .21 lbs. .32 74981 Power Bit Belt Pack With Bits Set includes the following 10 bits: l bs. Sizes: T6, T7, T8, T9, .28 T10, T15, T20, T25, T27, T30 Power Bit Belt Pack With Align Bits Set includes the following 10 bits: Sizes: T6, T7, T8, T9, lbs. T10, T15, T20, T25, T27, T30 .28 Power Bit Belt Pack With Security Bits 74987 Set includes the following 10 bits: Security Sizes: T7s, T8s, T9s, lbs. T10s, T15s, T20s, T27s, T25s, T30s, T40s .29 71690 Bit-Selector With Bits Set includes magnetic 1/4” bit holder and the following 10 bits: lbs. Sizes: .31 IP7, IP8, IP9, IP10, IP15, IP20, IP25 IP27, IP30, IP40 71692 Bit-Selector With Bits Set includes magnetic 1/4” bit holder and the following 10 bits: lbs. Sizes: .31 IP3, IP4, IP5, IP6, IP7, IP8, IP9, IP10, IP15, IP20 74982 Power Bit Belt Pack With Bits Set includes the following 10 bits: Sizes: IP6, IP7, IP8, IP9, lbs. IP10, IP15, IP20, IP25, IP30 .28 Toll Free: (800) 494-6104 32 Wiha XSelector Bit Sets Easy bit access with hinged cover Includes Clicfix quick release holder 79445 XSelector Bit Set With Bits Set Includes Quick Release Holder lbs. and the following 10 bits: .29 Sizes: T7, T8, T9, T10, T15, T20, T25, T27, T30, T40 XSelector Pocket Sized 3 1/8” x 2 1/8” x 1/2” XSelector Bit Set With Security Bits 79447 Set Includes Quick Release Holder lbs. and the following 10 bits: .27 Security Sizes: T7s, T8s, T9s, T10s, T15s, T20s, T25s, T27s, T30s, T40s Wiha Insert PokitPaks 71195 79283 PokitPak Insert Bits In Molded Case Set includes 6 - 1/4” Insert Bits & Magnetic Bit Holder : lbs. T8, T10, T15, T20, T25, T30 .15 PokitPak Align Coated Insert Bits In Molded Case Set Includes 6 - 1/4” Insert Bits Align: T10, T15, T20, T25, T30, T40 lbs. .12 Wiha 1/4” Bit Holders Magnetic 1/4” Magnetic Bit Holding Screwdrivers, With Wiha384 SoftFinish® Handle Ergonomic cushion grip, magnetic, holds bit and screw. Retainer out of stainless steel. Shaft CVM steel, nickel-plated. Item No. Size mm Inch mm Inch lbs. pkg. 1/4” 125 5.0 240 9.46 .23 1 38450 1/4” 300 11.8 400 15.69 .37 1 38460 Adjustable Blade Length Magnetic Bit Holder 28489 Drive-Loc VI Bit Holder High alloy CVM steel, through hardened, hard chrome finish. Wiha-SoftFinish® handle multi-component, cushion grips. Item No. Inch Extends lbs. pkg. 28489 1/4” 1-3/4” to 4-7/8” .36 1 714 ClicFix Bit Holder, Magnetic For Insert Bits. Quick release Item No. Size Size mm Inch 71490 1/4” 1/4” 60 2.4 71491 1/4” 1/4” 75 2.9 71480 CentroFix Bit Holder For Power Bits Quick release Item No. Size Size mm Inch 1/4” 1/4” 60 2.3 71480 71470 Auto Lock Magnetic Bit Holder, Spring Loaded Bit Ejection, 1/4” For Insert & Power Bits Item No. Size Size mm Inch lbs. 71470 1/4” 1/4” 60 2.4 .08 www.wihatools.com 33 Wiha Terminator Up To 30X Performance Over Standard Screwdriver Bits Impact Bits - Insert & Power Impact rated bits for long life in impact applications 1/4” Drive Insert & Power Bits Provide up to 30 times impact performance over standard bits Standard 1/4” drive - No special adaptor required Wiha enhanced bi-material torsion zone Precision machined exact fit tips Dual material impact absorbing torsion zone Wiha exclusive CVM tool steel Guaranteed to out perform impact imposters 768 Terminator Impact Bits, 1/4” Insert - 2 bit pack Item No. Size mm pkg. 76810 T10 29 2 76811 T15 29 2 76812 T20 29 2 76813 T25 29 2 76816 T30 29 2 76817 T40 29 2 10 pc. bit pack! 768 Terminator Impact Bits, 1/4” Power - 2 bit pack Item No. Size mm pkg. 76853 T10 49 2 76854 T15 49 2 76855 T20 49 2 76856 T25 49 2 76858 T30 49 2 76859 T40 49 2 10 pc. bit pack! 765 Terminator Impact Bits, 1/4” Insert - 10 Pack Item No. Size mm pkg. 76510 T10 29 10 76511 T15 29 10 76512 T20 29 10 76513 T25 29 10 76516 T30 29 10 76517 T40 29 10 765 Terminator Impact Bits, 1/4” Power - 10 Pack Item No. Size mm pkg. T10 49 10 76553 T15 49 10 76554 T20 49 10 76555 T25 49 10 76556 T30 49 10 76558 T40 49 10 76559 76895 7 Pc. Bit Buddy Set With Terminator Impact Insert Bits - 29mm Set includes the following bits: 76895 Torx®: T10, T15, T20, T25 (2), T30, T40 76896 7 Pc. Bit Buddy Set With Terminator Impact Power Bits - 49mm Set includes the following bits: 76896 Torx®: T10, T15, T20, T25 (2), T30, T40 Toll Free: (800) 494-6104 34 Stainless Steel 1/4” Insert & Power Bits and 1/4” Bit Holder Dura Torsion Insert Bits 704 Stainless Steel Power Bits 1/4” Hex Drive, Length 2.0”/50mm Item No. Size mm pkg. 70411 T15 50 10 70413 T20 50 10 70414 T25 50 10 70416 T30 50 10 70417 T40 50 10 Stainless Steel Bits, 1/4” 715 Item No. Size mm pkg. T8 25 10 71500 T9 25 10 71501 T10 25 10 71502 T15 25 10 71503 T20 25 10 71504 T25 25 10 71511 T30 25 10 71512 T40 25 10 71513 Stainless Steel High-quality, non-rusting stainless steel, completely vacuum-hardened. 71596 PokitPak Dura Insert Bits In Molded Case Set Includes 6 - 1/4” Insert Bits T10, T15, T20, T25, T30, T40 lbs. .36 Dura Torsion Insert Bits With the Dura bit Wiha has again proved it’s power of innovation. The extra hard, elastic Quattro Torsion bit is equipped with an extremely wear resistant tungsten carbide coating that grips the screw head. Torsion Zone Positive location in the screw head with decrease of: • necessary pressure forces • working time • costs • wear & tear of bits & screw heads • anti-cam-out effect 71494 Stainless Steel Bit Holder, 1/4” For Insert Bits Internal C-ring for bit holding & magnet. Item No. Size Size mm Inch lbs. 1/4” 1/4” 54 2.1” .05 71494 Diamond Torsion Insert Bits Diamond bits supplement Wiha’s range of high-quality special bits. When used with machines, the increased tool life of the Wiha Diamond bit reduces cost. The abbreviation TiN stands for TitaniumNitride, which has a hardness up to 85 HRC. This coating guarantees a high wear and tear resistance. Torsion Zone • High wear resistance • Micro particle coating with sapphire and diamond contents • Optimized torsion zone Reduction of: • pressure forces to be applied • wear and tear of bit and screw head • working time & costs • Cam-out effect The ideal bit even for the most difficult of applications 715 Dura Bits, 1/4” Item No. Size mm lbs. 71574 T10 25 .02 71576 T15 25 .02 71578 T20 25 .02 71580 T25 25 .02 71582 T30 25 .02 71584 T40 25 .03 TiN Coated Insert Bits Diamond Bits, 1/4” 715 Item No. Size mm lbs. 71516 T10 25 .02 71517 T15 25 .02 71518 T20 25 .02 71519 T25 25 .02 71521 T30 25 .02 71522 T40 25 .03 Torsion Zone • Tough, hard torsion quality with very hard TiN coating • Optimized torsion zone • High wear resistance 715 TiN Coated Insert Bits, 1/4” Item No. Size mm lbs. T5 25 .02 71585 T6 25 .02 71586 T7 25 .02 71587 T8 25 .02 71588 T9 25 .02 71562 T10 25 .02 71563 T15 25 .02 71564 T20 25 .02 71565 T25 25 .02 71566 T27 25 .02 71569 T30 25 .02 71567 T40 25 .02 71568 TiN - Titanium Nitride www.wihatools.com Bits The ideal multi-purpose bits for all around quality & performance Made in Germany Production Quality Highly resistant to wear and tear for a long tool life 35 5/16” 725 Bits, 5/16” Item No. Size mm pkg. lbs. T25 35 10 .27 72525 T27 35 10 .27 72527 T30 35 10 .27 72530 T40 35 10 .28 72540 T45 35 10 .31 72545 T50 35 10 .32 72550 T55 35 10 .52 72555 2 bit pack 725 Impact resistant modified CVM, tool steel, hardened Suitable for all applications for both manual and machine Hardness HRC 59-61 715 Bits, 1/4” Item No. Size mm pkg. lbs. 71523 T3 25 10 .12 71524 T4 25 10 .12 71505 T5 25 10 .12 71506 T6 25 10 .12 71507 T7 25 10 .12 71508 T8 25 10 .12 71509 T9 25 10 .12 71510 T10 25 10 .12 71515 T15 25 10 .12 71520 T20 25 10 .12 71525 T25 25 10 .12 71527 T27 25 10 .13 71530 T30 25 10 .14 71540 T40 25 10 .15 Bits, 1/4” Bulk Packs 725 Item No. Size mm pkg. lbs. T8 25 30 .36 72573 T10 25 30 .36 72575 T15 25 30 .36 72576 T20 25 30 .36 72577 T25 25 30 .36 72578 T27 25 30 .36 72579 T30 25 30 .36 72580 T40 25 30 .36 72581 Item No. 72531 72541 72546 72551 72556 Insert Bit Packs, 5/16” Size mm T30 35 T40 35 T45 35 T50 35 T55 35 lbs. .28 .28 .31 .32 .52 Power Bits 745 1/4” Hex Drive, Length 2.0”/50mm Item No. Size mm pkg. lbs. T6 50 10 .18 74511 T7 50 10 .18 74512 T8 50 10 .18 74513 T9 50 10 .18 74517 T10 50 10 .18 74519 T15 50 10 .18 74521 T20 50 10 .18 74523 T25 50 10 .18 74529 T27 50 10 .18 74531 T30 50 10 .18 74533 T40 50 10 .18 74535 Power Bits 745 1/4” Hex Drive, Length 2.75”/70mm Item No. Size mm pkg. lbs. T6 70 1 .02 74536 T7 70 1 .02 74538 T8 70 1 .02 74542 T9 70 1 .02 74544 T10 70 1 .02 74546 T15 70 1 .02 74548 T20 70 1 .03 74551 T25 70 1 .03 74553 T27 70 1 .04 74556 T30 70 1 .04 74558 T40 70 1 .04 74561 745 Power Bits 1/4” Hex Drive, Length 3.5”/90mm Item No. Size mm pkg. lbs. T6 90 10 .03 74563 T7 90 10 .03 74565 T8 90 10 .03 74567 T9 90 10 .03 74569 T10 90 10 .03 74571 T15 90 10 .03 74573 T20 90 10 .04 74575 T25 90 10 .04 74577 T27 90 10 .04 74579 T30 90 10 .04 74581 T40 90 10 .04 74583 745 Power Bits 1/4” Hex Drive, Length 6.0”/150mm Item No. Size mm pkg. lbs. 74586 T10 150 10 .04 74587 T15 150 10 .04 74588 T20 150 10 .04 74589 T25 150 10 .04 74590 T27 150 10 .04 74591 T30 150 10 .04 Wiha Bit Packs 2 bit pack Insert Bit Packs 715 1” CVM S2 modified tool steel. Item No. Size mm lbs. T3 25 .03 71548 T4 25 .03 71549 T5 25 .03 71550 T6 25 .03 71551 T7 25 .03 71552 T8 25 .03 71553 T9 25 .03 71554 T10 25 .03 71555 T15 25 .03 71556 T20 25 .03 71557 T25 25 .03 71558 T27 25 .04 71559 T30 25 .04 71560 T40 25 .04 71561 Toll Free: (800) 494-6104 36 Wiha Wiha Bit Packs Align Insert Bits and Power Bits Torx® Align Insert Bit Packs, 1” CVM 71571 S2 modified tool steel. Extra hard with natural finish. Exact fit machined tips. 6 pc. bit pack. 71571 Set includes the following bits: Sizes: T15, T20, T25, T27, wt. .08 T30, T40 x 1” (25mm) Insert Bit Packs, 1” CVM 71570 S2 modified tool steel. Extra hard with natural finish. Exact fit machined tips. 6 pc bit pack. Set includes the following bits: 71570 Sizes: T5, T6, T7, T8, T9, wt. .07 T10 x 1” (25mm) 2 bit pack Power Bit Packs, 2” 745 CVM S2 modified tool steel Item No. Size mm lbs. T6 50 .05 74501 T7 50 .05 74502 T8 50 .05 74503 T9 50 .05 74504 T10 50 .05 74506 T15 50 .05 74508 T20 50 .05 74510 T25 50 .06 74514 T27 50 .06 74515 T30 50 .06 74516 T40 50 .06 74518 Torx Profiles ® Torx® Security TorxPlus® Torx® Security TorxPlus® Ball End Torx® Impact resistant modified chrome-vanadiummolybdenum, tool steel, hardened Tapered For Snug Fit In Screw Made in Germany Production Quality Highly resistant to wear and tear for a long tool life Suitable for all applications for both manual and machine Hardness HRC 59-61 715 Align Bits, 1/4” Item No. Size mm pkg. lbs. 71536 T6 25 10 .12 71537 T7 25 10 .12 71538 T8 25 10 .12 71539 T9 25 10 .12 71541 T10 25 10 .12 71542 T15 25 10 .12 71543 T20 25 10 .12 71544 T25 25 10 .13 71545 T27 25 10 .13 71546 T30 25 10 .14 71547 T40 25 10 .15 *Also Known As Torx Wedge Fit Align Bits, 1/4” Hex Drive, 747 Length 2.0”/50mm Item No. Size mm pkg. lbs. 74711 T6 50 10 .18 74714 T7 50 10 .18 74717 T8 50 10 .18 74721 T9 50 10 .18 74724 T10 50 10 .18 74728 T15 50 10 .20 74732 T20 50 10 .22 74736 T25 50 10 .22 74739 T27 50 10 .22 74742 T30 50 10 .22 *Also Known As Torx Wedge Fit 2 bit pack 2 bit pack 733 Align Insert Bit Packs, 1” CVM S2 modified tool steel Item No. Size mm lbs. T6 25 .03 73310 T7 25 .03 73311 T8 25 .03 73312 T9 25 .03 73313 T10 25 .03 73314 T15 25 .03 73315 T20 25 .03 73316 T25 25 .03 73317 T27 25 .03 73318 T30 25 .03 73319 T40 25 .04 73320 747 Item No. 74760 74761 74762 74763 74764 74765 74766 74767 74768 74769 Align Power Bit Packs, 2” Size mm lbs. T6 50 .05 T7 50 .05 T8 50 .05 T9 50 .05 T10 50 .05 T15 50 .05 T20 50 .06 T25 50 .06 T27 50 .06 T30 50 .06 www.wihatools.com 37 Wiha Security Insert Bits and Power Bits Security Torx® Impact resistant modified CVM tool steel, hardened Highly resistant to wear and tear for a long tool life Made in Germany Production Quality Suitable for all applications for both manual and machine Hardness HRC 59-61 701 Security Bits, 1/4” Item No. Size mm pkg. lbs. T7s 25 10 .12 70127 T8s 25 10 .12 70128 T9s 25 10 .12 70129 T10s 25 10 .12 70135 T15s 25 10 .12 70139 T20s 25 10 .12 70142 T25s 25 10 .12 70148 T27s 25 10 .13 70160 T30s 25 10 .13 70163 T40s 25 10 .14 70168 2 bit pack 701 Security Insert Bit Packs, 1” CVM S2 modified tool steel. Item No. Size mm lbs. 70150 T7s 25 .03 70151 T8s 25 .03 70152 T9s 25 .03 70153 T10s 25 .03 70154 T15s 25 .03 70155 T20s 25 .03 70156 T25s 25 .03 70157 T27s 25 .03 70158 T30s 25 .03 70159 T40s 25 .03 5/16” 705 Security Power Bits, 1/4” Hex Drive, Length 2.0”/50mm Item No. Size mm pkg. lbs. T7s 50 10 .18 70507 T8s 50 10 .18 70508 T9s 50 10 .18 70509 T10s 50 10 .19 70510 T15s 50 10 .19 70515 T20s 50 10 .21 70520 T25s 50 10 .23 70525 T27s 50 10 .23 70527 T30s 50 10 .23 70530 T40s 50 10 .23 70540 T45s 50 10 .33 70545 T50s 50 10 .37 70550 T55s 50 10 .37 70555 725 Security Bits, 5/16” Item No. Size mm pkg. lbs. T40s 35 10 .28 72542 T45s 35 10 .32 72547 T50s 35 10 .34 72552 T55s 35 10 .52 72557 2 bit pack 705 Item No. 70556 70557 70558 70559 70560 70561 70562 70563 70564 70565 70566 70567 70568 Power Bit Packs, 2” Security Size T7s T8s T9s T10s T15s T20s T25s T27s T30s T40s T45s T50s T55s mm lbs. 50 .07 50 .07 50 .07 50 .07 50 .07 50 .07 50 .07 50 .07 50 .07 50 .07 50 .07 50 .07 50 .07 Wiha Security Insert Bit 716 Security Insert Bits, 1/4” Hex, 1” OAL Item No. Size mm pkg. lbs. IPR8 25 1 .11 71648 IPR10 25 1 .11 71650 IPR15 25 1 .11 71652 IPR20 25 1 .12 71654 IPR25 25 1 .13 71656 IPR27 25 1 .13 71657 IPR30 25 1 .14 71658 IPR40 35 1 .14 71660 2 bit pack XSelector Pocket Sized 3 1/8” x 2 1/8” x 1/2” Bits, 5/16” 2 Bit Pack 725 Security Item No. Size mm lbs. 72562 T40s 35 .28 72563 T45s 35 .29 72564 T50s 35 .30 72567 T55s 35 .32 XSelector Bit Set With Security Bits Set Includes Quick Release Holder lbs. and the following 7 bits: .18 Security Sizes: IPR8, IPR10, IPR15, IPR20, IPR25, IPR27, IPR30 79450 Toll Free: (800) 494-6104 38 Wiha Insert Bits and Power Bits Impact resistant modified chrome-vanadium-molybdenum, tool steel, hardened Made in Germany Production Quality Suitable for all applications for both manual and machine Hardness HRC 59-61 2 bit pack 716 Insert Bit Packs, 1” CVM S2 modified tool steel Item No. Size mm lbs. IP3 25 .03 71631 IP4 25 .03 71632 IP5 25 .03 71633 IP6 25 .03 71634 IP7 25 .03 71635 IP8 25 .03 71636 IP9 25 .03 71637 IP10 25 .03 71638 IP15 25 .03 71639 IP20 25 .03 71641 IP25 25 .03 71642 IP27 25 .03 71643 IP30 25 .03 71644 IP40 25 .04 71645 2 bit pack 746 Power Bits, 1/4” Hex, 2” Item No. Size mm pkg. lbs. 74601 IP5 50 10 .18 74602 IP6 50 10 .18 74603 IP7 50 10 .18 74604 IP8 50 10 .18 74608 IP9 50 10 .18 74612 IP10 50 10 .20 74616 IP15 50 10 .20 74620 IP20 50 10 .20 74624 IP25 50 10 .20 74628 IP27 50 10 .25 74632 IP30 50 10 .25 74636 IP40 50 10 .25 Bits See additional Ball End TORX Tools on Page 17 Wiha MagicSpring Screw Holding Power Bits Screw Holding TORX Bits Highly resistant to wear and tear for a long tool life 716 Insert Bits, 1/4” Hex, 1” Item No. Size mm pkg. lbs. 71603 IP3 25 10 .12 71604 IP4 25 10 .12 71605 IP5 25 10 .12 71606 IP6 25 10 .12 71607 IP7 25 10 .12 71608 IP8 25 10 .12 71609 IP9 25 10 .12 71610 IP10 25 10 .12 71615 IP15 25 10 .12 71620 IP20 25 10 .12 71625 IP25 25 10 .12 71627 IP27 25 10 .13 71630 IP30 25 10 .13 71640 IP40 25 10 .15 Wiha Ball End Power Bit Packs, 2” 746 Item No. Size mm lbs. 74659 IP5 50 .05 74660 IP6 50 .05 74661 IP7 50 .05 74662 IP8 50 .05 74663 IP9 50 .05 74664 IP10 50 .05 74665 IP15 50 .05 74666 IP20 50 .05 74667 IP25 50 .05 74668 IP27 50 .05 74669 IP30 50 .05 74670 IP40 50 .05 Stainless rotary spring 2 bit pack MagicSpring Screw Holding 745 Power Bits, 1/4” Hex Drive, 2.0”/50mm OAL Item No. Size mm pkg. lbs. 74552 T10 50 2 .05 74554 T15 50 2 .05 74555 T20 50 2 .05 74557 T25 50 2 .05 74562 T30 50 2 .05 74564 T40 50 2 .05 Wiha Double End 744 Double End Bits 1/4” Hex Drive, Length 2.56”/65mm Item No. Size Size mm pkg. lbs. 74411 T6 T6 65 10 .32 74413 T7 T7 65 10 .32 74415 T8 T8 65 10 .32 74417 T9 T9 65 10 .32 74419 T10 T10 65 10 .32 74421 T15 T15 65 10 .32 74423 T20 T20 65 10 .32 74429 T25 T25 65 10 .33 74431 T27 T27 65 10 .34 74433 T30 T30 65 10 .35 74435 T40 T40 65 10 .38 2 bit pack Double End Bits 744 1/4” Hex Drive, Length 2.56”/65mm Item No. Size Size mm lbs. 74460 T6 T6 65 .05 74461 T7 T7 65 .05 74462 T8 T8 65 .05 74463 T9 T9 65 .05 74464 T10 T10 65 .05 74465 T15 T15 65 .05 74466 T20 T20 65 .05 74467 T25 T25 65 .05 74468 T27 T27 65 .05 74469 T30 T30 65 .05 74470 T40 T40 65 .05 Bits www.wihatools.com 39 Wiha Sockets Set Screw Replaceable Bit 761 Sockets 1/4” Square Drive Item No. Size mm lbs. T6 38 .04 76106 T7 38 .04 76107 T8 38 .04 76109 T9 38 .04 76111 T10 38 .04 76113 T15 38 .04 76117 T20 38 .04 76119 T25 38 .04 76121 T27 38 .04 76123 T30 38 .05 76129 T40 38 .05 76131 Sockets 1/4” Square Drive, Set Screw Replaceable Bit. 1/4” bits Item No. Size mm lbs. 71661 IP6 38 .04 71662 IP7 38 .04 71663 IP8 38 .04 71664 IP9 38 .04 71665 IP10 38 .04 71666 IP15 38 .04 71667 IP20 38 .04 71668 IP25 38 .04 71669 IP27 38 .04 71670 IP30 38 .04 71671 IP40 38 .04 716 Set Screw Replaceable Bit 701 Security Sockets 3/8” Square drive, 1/4” bits. 2” OAL Item No. Size mm lbs. 70107 T7s 42 .09 70108 T8s 42 .09 70109 T9s 42 .09 70110 T10s 42 .09 70113 T15s 42 .09 70115 T20s 42 .09 70117 T25s 42 .09 70119 T27s 42 .09 70121 T30s 42 .09 70123 T40s 42 .09 Set Screw Replaceable Bit 763 Sockets 3/8” Square Drive, Set Screw Replaceable Bit. 1/4” bits Item No. Size mm lbs. 76312 T9 42 .09 76314 T10 42 .09 76316 T15 42 .09 76318 T20 42 .09 76322 T25 42 .09 76324 T27 42 .09 76326 T30 42 .09 76328 T40 42 .09 716 Sockets 3/8” Square Drive, Set Screw Replaceable Bit. 1/4” bits Item No. Size mm lbs. IP9 42 .09 71673 IP10 42 .09 71674 IP15 42 .09 71675 IP20 42 .09 71676 IP25 42 .09 71677 IP27 42 .09 71678 IP30 42 .09 71680 IP40 42 .09 71681 Set Screw Replaceable Bit 763 Sockets 3/8” Square Drive, Set Screw Replaceable Bit. 5/16” Bit. 2” OAL Item No. Size mm lbs. T40 51 .11 76346 T45 51 .11 76348 T50 51 .11 76352 T55 51 .13 76354 763 Security Sockets 1/4” Square drive, 1/4” bits Item No. Size mm T7s 38 76329 T8s 38 76330 T9s 38 76331 T10s 38 76332 T15s 38 76333 T20s 38 76334 T25s 38 76335 T27s 38 76335 T30s 38 76337 T40s 38 76338 763 Security Sockets 3/8” Square drive, 5/16” bits Item No. Size mm T40s 51 76339 T45s 51 76340 T50s 51 76341 T55s 51 76342 1/2” Square Drive Sockets Set Screw Replaceable Bit 764 Sockets 1/2” Square Drive Item No. Size mm lbs. pkg. T30 59 .10 1 76403 T40 59 .10 1 76404 T45 59 .10 1 76405 T50 59 .10 1 76406 T55 59 .11 1 76407 Set Screw Replaceable Bit 764 Security Sockets 1/2” Square Drive Item No. Size mm lbs. pkg. T40s 59 .11 1 76411 T45s 59 .11 1 76412 T50s 59 .11 1 76413 T55s 59 .12 1 76414 Toll Free: (800) 494-6104 40 Wiha Long Blade Sockets 771 1/4” Drive Item No. 77151 77153 77152 77154 77156 77158 77160 77162 77164 77193 771 Sockets 3/8” Drive 6” Long Bit Socket. Item No. Size Inch lbs. 77101 T8 6 .12 77103 T9 6 .12 77105 T10 6 .12 77107 T15 6 .12 77109 T20 6 .12 77111 T25 6 .12 77113 T27 6 .12 77115 T30 6 .12 77117 T40 6 .12 77195 9 Pc. Socket Blade Set : T8, T9, T10, T15, T20, T25, T27, T30, T40 wt. 93 Sockets 6” Long Bit Socket. Size Inch lbs. T8 6 .12 T9 6 .12 T10 6 .12 T15 6 .12 T20 6 .12 T25 6 .12 T27 6 .12 T30 6 .12 T40 6 .12 7 Pc. Socket Blade Set : T10, T15, T20, T25, T27, T30, T40 wt. .69 Wiha External Sockets 773 External Sockets 1/4” Square drive socket. Item No. Size mm lbs. 77304 E4 25 .03 77305 E5 25 .03 77306 E6 25 .03 77307 E7 25 .04 77308 E8 25 .04 77310 E10 25 .04 773 External Sockets 3/8” Square drive socket. Item No. Size mm lbs. 77331 E8 28 .07 77333 E10 28 .07 77335 E12 28 .07 77337 E14 28 .08 773 External Sockets 1/2” Square drive socket. Item No. Size mm lbs. E12 37 .12 77341 E14 37 .12 77343 E16 37 .14 77345 E18 37 .14 77347 E20 37 .15 77349 E24 40 .26 77353 77390 22 pc. Set 1/4” Drive Socket Ratchet 5.5”, extension 2” & 4”, swivel and hand driver in steel box. Hard chromed and polished. Item No. 77390 lbs. Set includes the following: 2.14 E4, E5, E6, E7, E8, E10, T6, T7, T8, T9, T10, T15, T20, T25, T27, T30, T40 Wiha E-TORX® Socket Set On Molded Rails 8 pc. ESocket Set 77391 Item No. 77391 lbs. Set includes the following: .62 1/4” drive: E6, E7, E8, E10 3/8” drive: E12, E14 1/2” drive: E16, E18 www.wihatools.com 41 Wiha Socket Sets On Molded Rails 76191 10 pc. Socket Set 1/4” Square Drive Replaceable Bit Socket. Bits CVM tool steel. OAL 1.5” Item No. 76191 lbs. Set includes the following: .48 T7, T8, T9, T10, T15, T20, T25, T27, T30, T40 Security Torx® 70195 10 pc. Security Socket Set 1/4” Square drive replaceable bit socket. 1/4” Bits CVM tool steel. Item No. lbs. Set includes the following: 70195 .48 T7s, T8s, T9s, T10s, T15s, T20s, T25s, T27s, T30s, T40s 76194 6 pc. Socket Set 1/4” Square Drive Replaceable Bit Socket. Bits CVM tool steel. Item No. lbs. Set includes the following: 76194 .20 T10, T15, T20, T25, T27, T30 9 pc. Security Socket Set 76397 3/8” Sq. Drive Replaceable Bit Socket. 1/4” & 5/16” Bits CVM tool steel. Item No. 76397 lbs. Set includes the following: .85 1/4”: T10s, T15s, T20s, T27s, T30s 3/8”: T40s (1/4” bit) 3/8”: T45s, T50s (5/16” bit) 76395 8 pc. Socket Set 3/8” Square Drive Replaceable Bit Socket. Bits CVM tool steel. OAL 1.5” Item No. lbs. Set includes the following: 76395 .75 T9, T10, T15, T20, T25, T27, T30, T40 76399 12 pc. Security Socket Set 1/4” & 3/8” Square Drive Replaceable Bit Socket. 1/4” & 5/16” Bits CVM tool steel. Item No. 76399 lbs. Set includes the following: 1/4”: T7s, T8s, T10s, T15s, T20s, T25s, T27s, T30s, T40s .77 5/16”: T45s, T50s, T55s 8 pc. Socket Set 3/8” Square Drive Replaceable 76396 Bit Socket. 1/4” & 5/16” Bits CVM tool steel. OAL 1.65” Item No. 76396 lbs. Set includes the following: .84 1/4”: T20, T25, T27, T30, T40 5/16”: T45, T50, T55 8 pc. Socket Set On Rail 71698 In Vinyl Pouch 1/4” & 3/8” Square Drive Replaceable Bit Socket. Bits Chrome-vanadium-molybdenum tool steel. Item No. 71698 lbs. Set includes the following: .60 1/4”: IP9, IP10, IP15, IP20 3/8”: IP25, IP27, IP30, IP40 Toll Free: (800) 494-6104 42 Item No. Page 10893 7 20756 15 20757 15 20758 15 20759 15 20760 15 20799 15 26701 27 26702 27 26703 27 26704 27 26705 27 26706 27 26707 27 26708 27 26709 27 26710 27 26715 27 26720 27 26721 21 26723 21 26725 21 26727 21 26729 21 26731 21 26732 27 26733 27 26735 27 26736 27 26737 27 26739 27 26741 27 26743 27 26745 27 26747 27 26749 27 26751 27 26790 27 26791 27 26792 27 26793 27 26796 27 26798 21 26799 26 26951 29 26952 29 26953 29 26954 29 26955 29 26956 29 26957 29 26961 29 26977 29 26978 29 26979 29 26980 29 26981 29 26982 29 26987 29 26995 29 27801 26 27802 26 27803 26 27804 26 27805 26 27811 26 27817 26 27823 26 27829 26 27835 26 27841 26 27847 26 27850 26 27851 26 27852 26 27853 26 27854 26 27855 26 Item No. Page 27856 26 27857 26 27890 26 27894 26 27899 26 28000 29 28001 29 28087 29 28103 33 28126 11 28127 11 28128 11 28129 11 28130 11 28132 11 28133 11 28134 11 28135 11 28136 11 28195 11 28197 11 28295 30 28297 32 28301 12 28339 12,24 28340 12,24 28341 12,24 28342 12,24 28486 11 28487 11 28488 11 28489 33 28501 23 28502 23 28504 23 28506 23 28508 23 28512 23 28522 24 28524 24 28526 24 28527 23 28528 23 28529 23 28530 23 28531 23 28532 23 28533 23 28550 23 28551 23 28552 23 28553 23 28554 23 28561 23 28562 23 28563 23 28564 23 28565 23 28566 23 28567 23 28568 23 28569 23 28571 23 28572 23 28573 23 28574 23 28575 23 28576 23 28577 23 28578 23 28579 23 28597 25 28598 25 28599 25 28611 23 28612 23 28613 23 28614 23 Item No. Page 28616 23 28617 23 28618 23 28619 23 28690 25 28724 24 28726 24 28727 24 28734 24 28736 24 28737 24 28825 24 28826 24 28827 24 28828 24 28829 24 28830 24 28903 25 28904 25 28905 25 28906 25 28907 25 28908 25 28910 25 28911 25 28912 25 28913 25 28914 25 28915 25 28931 25 28933 25 28935 25 28937 25 28938 25 28939 25 28940 25 29205 24 29206 24 29209 24 29211 24 29212 24 29214 24 29220 24 29225 24 29230 24 29238 24 29241 24 29245 24 29251 24 32505 7 32511 7 32516 7 32521 7 32526 7 32531 7 32536 7 32541 7 32546 7 32551 7 32556 7 32561 7 32590 7 32592 7 36106 20 36107 20 36108 20 36109 20 36110 20 36115 20 36120 20 36125 20 36127 20 36130 20 36140 20 36197 20 36199 20 36200 6 36201 5 Item No. Page 36202 21 36203 21 36204 6 36205 7 36206 6 36207 21 36208 6 36209 6 36210 7 36211 19 36212 7 36215 7 36216 17 36217 17 36218 6 36219 6 36220 7 36221 17 36222 17 36223 19 36224 6 36225 7 36226 17 36227 17 36228 19 36229 19 36230 7 36233 19 36234 21 36235 7 36236 17 36237 17 36238 19 36239 19 36240 7 36243 19 36244 21 36245 7 36248 19 36249 21 36250 7 36253 19 36254 21 36255 19 36256 21 36257 21 36258 21 36259 6 36260 6 36264 5 36266 5 36267 5 36268 5 36269 6 36270 5 36271 6 36272 5 36273 6 36274 5 36275 6 36276 5 36277 6 36278 5 36279 6 36280 5 36281 6 36282 5 36283 6 36284 5 36285 6 36286 5 36287 6 36288 5 36289 6 36290 21 36291 5 36292 7 36293 7 Item No. Page Item No. Page Item No. Page 36294 5 36296 19 36298 6 36299 19 36305 13 36306 13 36307 13 36308 13 36309 13 36310 13 36315 13 36320 13 36321 14 36323 14 36325 13 36326 14 36327 13 36328 14 36329 14 36330 13 36332 14 36335 14 36337 14 36339 14 36340 13 36342 14 36345 13 36346 14 36350 13 36352 14 36355 13 36357 14 36360 13 36390 13 36392 13 36393 14 36394 13 36395 15 36396 15 36397 15 36398 15 36399 13 36409 13 36410 13 36415 13 36417 13 36420 13 36422 13 36425 13 36427 13 36430 13 36432 13 36435 13 36437 13 36440 13 36442 13 36445 13 36450 13 36452 13 36461 19 36463 19 36466 19 36469 19 36472 19 36474 19 36476 19 36478 19 36480 12 36481 12 36482 12 36483 12 36484 12 36486 12 36487 12 36490 13 36492 13 36494 13 36496 19 36497 12 36510 16 36512 16 36515 16 36520 16 36525 16 36530 16 36535 16 36540 18 36542 18 36544 18 36546 18 36548 18 36550 18 36552 18 36554 18 36556 22 36557 22 36558 22 36559 22 36560 22 36561 22 36562 22 36590 16 36591 16 36592 18 36598 22 36606 20 36607 20 36608 20 36609 20 36610 20 36615 20 36620 20 36625 20 36627 20 36630 20 36631 17 36632 17 36633 17 36634 17 36635 17 36636 17 36637 17 36638 17 36640 20 36645 14 36646 14 36647 14 36648 14 36649 14 36650 14 36651 14 36652 14 36653 14 36654 14 36655 14 36659 14 36660 14 36661 14 36689 14 36690 20 36691 20 36692 17 36694 14 36697 18 36698 14 36699 14 37013 16 37016 16 37019 16 37022 16 37026 16 37029 16 37032 16 37036 16 37040 18 37042 18 37044 18 37046 18 37048 18 37050 18 37052 18 37054 18 37090 16 37091 16 37092 18 37106 22 37107 22 37108 22 37109 22 37110 22 37115 22 37120 22 37125 22 37127 22 37130 22 37140 22 37190 22 37192 22 37608 6 37609 6 37610 6 37615 6 37620 6 37625 6 37627 6 37630 6 37640 6 37690 6 38003 30 38004 30 38008 30 38009 32 38010 32 38015 33 38028 30 38045 30 38047 32 38450 33 38460 33 45504 10 45505 9 45506 9 45507 10 45508 10 45509 10 45510 10 45511 9 45515 10 45516 9 45520 10 45521 9 45522 9 45525 10 45526 9 45527 10 45530 10 45531 9 45536 9 45540 10 45541 9 45545 10 45546 9 45550 10 45551 9 45556 9 45561 9 45589 9 45591 9 45592 9 45593 10 45595 10 45597 10 45598 10 48400 9 www.wihatools.com 43 Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page 52711 8 52713 8 52716 8 52719 8 52722 8 52726 8 52729 8 52732 8 52790 8 52791 8 70107 39 70108 39 70109 39 70110 39 70113 39 70115 39 70117 39 70119 39 70121 39 70123 39 70127 37 70128 37 70129 37 70135 37 70139 37 70142 37 70148 37 70150 37 70151 37 70152 37 70153 37 70154 37 70155 37 70156 37 70157 37 70158 37 70159 37 70160 37 70163 37 70168 37 70190 32 70195 41 70411 34 70413 34 70414 34 70416 34 70417 34 70507 37 70508 37 70509 37 70510 37 70515 37 70520 37 70525 37 70527 37 70530 37 70540 37 70545 37 70550 37 70555 37 70556 37 70557 37 70558 37 70559 37 70560 37 70561 37 70562 37 70563 37 70564 37 70565 37 70566 37 70567 37 70568 37 71130 33 71131 33 71195 30 71470 33 71474 33 71475 33 71476 33 71477 33 71478 33 71479 33 71480 33 71490 33 71491 33 71492 33 71493 33 71494 34 71500 34 71501 34 71502 34 71503 34 71504 34 71505 35 71506 35 71507 35 71508 35 71509 35 71510 35 71511 34 71512 34 71513 34 71515 35 71516 34 71517 34 71518 34 71519 34 71520 35 71521 34 71522 34 71523 35 71524 35 71525 35 71527 35 71530 35 71536 36 71537 36 71538 36 71539 36 71540 35 71541 36 71542 36 71543 36 71544 36 71545 36 71546 36 71547 36 71548 35 71549 35 71550 35 71551 35 71552 35 71553 35 71554 35 71555 35 71556 35 71557 35 71558 35 71559 35 71560 35 71561 35 71562 34 71563 34 71564 34 71565 34 71566 34 71567 34 71568 34 71569 34 71570 36 71571 36 71574 34 71576 34 71578 34 71580 34 71582 34 71584 34 71585 34 71586 34 71587 34 71588 34 71596 34 71603 38 71604 38 71605 38 71606 38 71607 38 71608 38 71609 38 71610 38 71615 38 71620 38 71625 38 71627 38 71630 38 71631 38 71632 38 71633 38 71634 38 71635 38 71636 38 71637 38 71638 38 71639 38 71640 38 71641 38 71642 38 71643 38 71644 38 71645 38 71648 37 71650 37 71652 37 71654 37 71656 37 71657 37 71658 37 71660 37 71661 39 71662 39 71663 39 71664 39 71665 39 71666 39 71667 39 71668 39 71669 39 71670 39 71671 39 71673 39 71674 39 71675 39 71676 39 71677 39 71678 39 71680 39 71681 39 71690 31 71692 31 71698 41 72525 35 72527 35 72530 35 72531 35 72540 35 72541 35 72542 37 72545 35 72546 35 72547 37 72550 35 72551 35 72552 37 72555 35 72556 35 72557 37 72562 37 72563 37 72564 37 72567 37 72573 35 72575 35 72576 35 72577 35 72578 35 72579 35 72580 35 72581 35 73310 36 73311 36 73312 36 73313 36 73314 36 73315 36 73316 36 73317 36 73318 36 73319 36 73320 36 74411 38 74413 38 74415 38 74417 38 74419 38 74421 38 74423 38 74429 38 74431 38 74433 38 74435 38 74460 38 74461 38 74462 38 74463 38 74464 38 74465 38 74466 38 74467 38 74468 38 74469 38 74470 38 74501 36 74502 36 74503 36 74504 36 74505 17 74506 36 74508 36 74510 36 74511 35 74512 35 74513 35 74514 36 74515 36 74516 36 74517 35 74518 36 74519 35 74520 17 74521 35 74522 17 74523 35 74524 17 74526 17 74528 17 74529 35 74531 35 74532 17 74533 35 74534 17 74535 35 74536 35 74537 17 74538 35 74539 17 74541 17 74542 35 74543 17 74544 35 74545 17 74546 35 74547 17 74548 35 74549 17 74550 17 74551 35 74552 38 74553 35 74554 38 74555 38 74556 35 74557 38 74558 35 74561 35 74562 38 74564 38 74563 35 74565 35 74567 35 74569 35 74571 35 74573 35 74575 35 74577 35 74579 35 74581 35 74583 35 74586 35 74587 35 74588 35 74589 35 74590 35 74591 35 74601 38 74602 38 74603 38 74604 38 74608 38 74612 38 74616 38 74620 38 74624 38 74628 38 74632 38 74636 38 74659 38 74660 38 74661 38 74662 38 74663 38 74664 38 74665 38 74666 38 74667 38 74668 38 74669 38 74670 38 74711 36 74714 36 74717 36 74721 36 74724 36 74728 36 74732 36 74736 36 74739 36 74742 36 74760 36 74761 36 74762 36 74763 36 74764 36 74765 36 74766 36 74767 36 74768 36 74769 36 74950 37 74981 31 74982 31 74985 31 74987 32 75093 28 75703 28 75704 28 75705 28 75706 28 75707 28 75708 28 75709 28 75710 28 75715 28 75720 28 75727 28 75728 28 75729 28 75735 28 75739 28 75742 28 75792 28 75801 28 75985 28 76106 39 76107 39 76109 39 76111 39 76113 39 76117 39 76119 39 76121 39 76123 39 76129 39 76131 39 76191 41 76194 41 76312 39 76314 39 76316 39 76318 39 76322 39 76324 39 76326 39 76328 39 76329 39 76330 39 76331 39 76332 39 76333 39 76334 39 76335 39 76336 39 76337 39 76338 39 76339 39 76340 39 76341 39 76342 39 76346 39 76348 39 76352 39 76354 39 76395 41 76396 41 76397 41 76399 41 76403 39 76404 39 76405 39 76406 39 76407 39 76411 39 76412 39 76413 39 76414 39 76510 33 76511 33 76512 33 76513 33 76516 33 76517 33 76553 33 76554 33 76555 33 76556 33 76558 33 76559 33 76810 33 76811 33 76812 33 76813 33 76816 33 76817 33 76853 33 76854 33 76855 33 76856 33 76858 33 76859 33 76895 33 76896 33 77101 40 77103 40 77105 40 77107 40 77109 40 77111 40 77113 40 77115 40 77117 40 77151 40 77152 40 77153 40 77154 40 77156 40 77158 40 77160 40 77162 40 77164 40 77193 40 77195 40 77304 40 77305 40 77306 40 77307 40 77308 40 77310 40 77331 40 77333 40 77335 40 77337 40 77341 40 77343 40 77345 40 77347 40 77349 40 77353 40 77390 40 77391 40 79242 31 79245 31 79247 32 79283 31 79445 31 79447 32 79450 37 (800) 494-6104 fax: (800) 494-7456 email: cservice@wihatools.com www.wihatools.com Wiha Quality Tools 1348 Dundas Circle Monticello, MN 55362 tel: 763.295.6591 fax: 763.295.6598 Catalog Item No. 99914 .wo version - 6/1/13 Wiha Tools Canada Ltd. www.wihatools.ca Brampton, ONT L6T 4X4 tel: 866.494.0096 or 763.295.6591 fax: 763.295.6598 To: Subject to change without notice ©2013 Willi Hahn Corporation ®Torx is a registered trademark of Acument Intellectual Properties LLC. 99060.wo - Product Guide 99004.wo - Shop Tools Catalog 99001.wo - TorqueControl Catalog 99934.wo - Hex Tools Catalog 99919.wo - Insulated Catalog 99002.wo - Screwdrivers Catalog 99951.wo - Bits Catalog 99006.wo - Tech Tools Catalog 99945.wo - ESD Catalog 99977.wo - Pliers/Crimpers Catalog Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Wiha: 74602 52732 70151 71563 75742 76131 76853 76895 76896 76856 76512 71524 76553 76855 76817 77156 71512 76516 76556 71548 76812 74669 76113 76129 76194 76346 76348 77390 28103 70564 74462 74508 74510 74548 75705 38047 71475 26982 28195 74433 74529 74569 74579 74589 74624 74987 76340 77113 76336 76339 76411 72552 72564 72576 74539 74541 74982 76324 76333 76342 76399 77101 72547 73314 73316 74435 74533 74536 76312 71478 72577 74537 71690 72556 73311 74522 74528 74549 76330 76332 76414 71680 75706 75715 75728 76111 52791 71571 71607 71671 71674 71675 71677 74557 71503 37625 71567 71637 71552 74768
71658 价格&库存
很抱歉,暂时无法提供与“71658”相匹配的价格&库存,您可以联系我们找货
