PA4336
PA4336
    GREENLEECOMMUNICATIONS(格林利)
    SCREWDRIVER CORDLESS 120VAC
PA4336 数据手册
KIT CORDLESS SD SOCKET-SET - Greenlee - Made for the Trade™ 769328104134 Page 1 of 2 Sub SEARCH Supplier Center Distributor Center BROWSE PRODUCTS Category: -- Select -- Brand: -- Select -- PRODUCTS Bending VDV Tools > VDV Other > VDV Other Hand Tools > KIT CORDLESS SD SOCKET-SET Bolt Cutters KIT CORDLESS SD SOCKET-SET Cable Termination CATV/Broadband Instruments Related Products Images Connectors Electric Test Instruments Fasteners Fiber Connections Fiber Optic Instruments Fishing Holemaking Hydraulic Tools Material Handling Power Tools Professional Hand Tools Pulling User Reviews Safety Products (No Reviews Yet.) Storage Telco Instruments Cat No: PA4336 UPC No: 769328104134 VDV Instruments VDV Termination Description VDV Tools Specifications Wire Termination • AC adapter input : 120 VAC, 50 - 60 HZ • Battery Life : Approximately 600 CY • Charging Time : 3 - 6 HR • Consists Of : ◦ 3.6 V Rechargeable Battery ◦ 14-Piece 3/16 -1/2 IN (6.000 - 12.000 MM) Socket ◦ 26-Piece Driver Bits: 3 Slotted, 5 Torx, 3 Phillips, 3 Robertson, 12 Hex • Max Torque : 21.700 IN-LB (2.400 N-M) • Motor : 3.6 VDC • NoLoad Speed : 170 RPM • Number Of Pieces : 40 • Power Requirement : 3.6 V Nickel Cadmium Battery • Size : 9.520 IN (242.000 MM) Length • Type : Cordless • Weight : 1.380 LB (0.630 KG) 0 About Us Manuals News & Events Contact Us Company Store Careers Submit an Idea CA Transparency in Supply Chains Act | Environmental Responsibility | Privacy Policy | Terms of Use | Textron | Site Map http://www.greenlee.com/products/KIT-CORDLESS-SD-SOCKET%2540dSET.html?pro... 8/13/2012
PA4336 价格&库存
很抱歉,暂时无法提供与“PA4336”相匹配的价格&库存,您可以联系我们找货
