S8M
S8M
    KLEINTOOLS
    1/4''MAGNETICNUTDRIVER-3''-
S8M 数据手册
Sheet Metal Tools/HVAC Klein's line of HVAC tools make it easy to work with sheet metal, ductwork and tubing. These job-matched tools are proven to stand the test of time with superior results. Sheet Metal Tools/HVAC Snips Soft touch grips for maximum control and comfort State-of-the-art, dual-material handles provide a better grip without sacrificing tool strength or durability Tip-Ident™ for easy identification Meets or exceeds ASME B107.16M performance standard Hard, colored material for toughness and durability Long-lasting serrated forged steel blades for superior strength and durability Premium corrosion – resistant plated handles Self opening latch US Patents: D623498, D631322 Aviation Snips Additional Features: J1100L, J1101R, J1102S Journeyman snips cut 18 gauge cold rolled steel and 22 gauge stainless steel J2103S Journeyman Bulldog snips cut 16 gauge cold rolled steel and 18 gauge stainless steel • • J1102S J1100L J1101R Cat. No. Cutting Pattern Snip Type Cutting Length Color Code J1100L J1101R J1102S J2103S Left/Straight Right/Straight Straight/Wide Curves Notch/Straight Aviation Aviation Aviation Bulldog 1-3/8" (34.9 mm) 1-3/8" (34.9 mm) 1-1/2" (38.1 mm) 7/8" (22.2 mm) Red/Black Green/Black Yellow/Black Yellow/Black Cutting Capacity: Cold Rolled/Stainless Steel 18 Gauge/22 Gauge 18 Gauge/22 Gauge 18 Gauge/22 Gauge 16 Gauge/18 Gauge Overall Length Weight 9-7/8" (250.8 mm) 9-7/8" (250.8 mm) 10-1/16" (255.6 mm) 9-7/16" (239.7 mm) 14.4 oz. (408 g) 14.7 oz. (417 g) 14.4 oz. (408 g) 13.9 oz. (394 g) Right Angle Snips Additional Features: J2104L, J2105R Journeyman snips cut straight, curves, and tight circles in 24 gauge cold rolled steel and 28 gauge stainless steel Makes cutting easier in confined spaces (in ductwork, reaching through openings or against a wall) • • Cat. No. J2104L Cutting Pattern Left Curves/Tight Circles/Straight J2105R Right Curves/Tight Circles/Straight Snip Type Right Angle Right Angle Cutting Length 1-1/4" (31.8 mm) 1-1/4" (31.8 mm) See page 310 for additional information on warnings. Color Code Red/ Black Green/ Black Cutting Capacity: Cold Rolled/Stainless Steel 24 Gauge/28 Gauge 24 Gauge/28 Gauge J2105R Overall Length 7-15/16" (201.6 mm) 7-15/16" (201.6 mm) Weight 14.4 oz. (408 g) 14.4 oz. (408 g) J2104L 229 www.kleintools.com Sheet Metal Tools/HVAC Cutting & Notching Tools Offset Snips Additional Features: J2100L, J2101R, J2102S and J2106S snips feature exclusive Klein Kurve™ handles for natural hand positioning and ease of use J2106S Journeyman snips cut 20 gauge cold rolled steel and 24 gauge stainless steel, with a 2-3/8" length of cut for faster cutting J2100L, J2101R, J2102S Journeyman snips cut 18 gauge cold rolled steel and 22 gauge stainless steel • • J2102S • J2100L J2101R Cat. No. J2100L J2101R J2102S J2106S J2106S Cutting Pattern Left/Straight Right/Straight Straight/Wide Curves Straight/Wide Curves Snip Type Offset Offset Offset Long Cut Offset Cutting Length 1-1/4" (31.8 mm) 1-1/4" (31.8 mm) 1-1/2" (38.1 mm) 2-3/8" (60.3 mm) Color Code Red/Black Green/Black Yellow/Black Yellow/Black Overall Length 9-1/2" (241.3 mm) 9-1/2" (241.3 mm) 9-1/2" (241.3 mm) 10-1/2" (266.7 mm) Cutting Capacity: Cold Rolled/Stainless Steel 18 Gauge/22 Gauge 18 Gauge/22 Gauge 18 Gauge/22 Gauge 20 Gauge/24 Gauge Weight 15.5 oz. (439 g) 15.7 oz. (445 g) 15.5 oz. (439 g) 1.1 lbs. (0.50 kg) Cutting & Notching Tools Aviation Snips - Regular/Offset/Bulldog • Forged and heat-treated steel blades for strength and durability and offset blades have the capacity of cutting 18 gauge cold-rolled • Regular sheet metal and 22 gauge stainless steel sheet metal blades provide ease of cutting tight curves and keep user's hand away • Offset from metal snips (Cat. No. 2103) for notching or trimming 16 gauge cold-rolled • Bulldog sheet metal and 18 gauge stainless steel sheet metal • Spring-loaded for self-opening action • Latch keeps jaws closed when not in use • Hardened handles for extra strength • Contoured plastic handles are comfortable and color-coded by cutting pattern Cat. No. 1100L 1101R 1102S 2100L 2101R 2102S 2103 Cutting Pattern Left/ Straight Right/ Straight Straight/ Wide Curves Left/ Straight Right/ Straight Straight/ Wide Curves Notch Snip Type Aviation Aviation Aviation Offset Offset Offset Bulldog Cutting Length 1-3/8" (34.9 mm) 1-3/8" (34.9 mm) 1-1/2" (38.1 mm) 1-1/4" (31.8 mm) 1-1/4" (31.8 mm) 1-1/2" (38.1 mm) 7/8" (22.2 mm) 230 www.kleintools.com Color Code Red Green Yellow Red Green Yellow Yellow Overall Length 9-3/4" (247.7 mm) 9-3/4" (247.7 mm) 10-1/8" (257.2 mm) 9-1/2" (241.3 mm) 9-1/2" (241.3 mm) 9-1/2" (241.3 mm) 9-1/4" (235 mm) Cutting Capacity 18 Gauge 18 Gauge 18 Gauge 18 Gauge 18 Gauge 18 Gauge 16 Gauge 2101R Weight 1102S 14.4 oz. (408 g) 14.7 oz. (417 g) 14.4 oz. (408 g) 15.5 oz. (439 g) 15.7 oz. (445 g) 15.5 oz. (439 g) 13.9 oz. (394 g) 2100L Replacement springs for aviation snips Cat. No. P-406 P-407 Description Replacement Spring, Cat. No. 1100L, 1102S Replacement Spring, Cat. No. 1101R See page 310 for additional information on warnings. Sheet Metal Tools/HVAC Cutting & Notching Tools Snap Lock Punch Hand Notcher quick, • Allows clean, 30° "V" shaped • Compound-leverage mechanism for greater • • • • • • • control and easy operation Drop-forged, steel jaw easily punches 3/8" (9.5 mm) wide impressions on metal edges to easily join pieces of sheet metal, duct, or pipe All-steel construction and nickel-chrome plated hardware provide long life and durability Vinyl grips with handle stops for added comfort and easy operation Cat. No. 86560 Overall Length 8" (203.2 mm) Handle Color Blue 86560 Weight 1.0 lbs. (0.45 kg) cuts in sheet metal Drop-forged, high-impact steel jaw with 13/16" (21 mm) maximum throat depth Jaws' hook design allows easy notching of corners and take-off tabs without slippage All steel construction with nickel-plate and black-oxide finish provides long life and durability Hardened steel handles include hand guards and are covered with vinyl grips for added comfort and easy operation Cat. No. 86551 Overall Length 8-1/2" (215.9 mm) Handle Color Blue 86551 Weight 1.0 lbs. (0.45 kg) Lightweight Tinner Snips hollow-ground cutting edge for cutting full 3-1/2" • 6°(89angled, mm) straight cuts and wide curves • Easily replaceable cutting blades made of high-carbon steel capacity: 22 gauge cold-rolled sheet metal; 26 gauge • Cutting stainless steel sheet metal. Do not use to cut hardened wire, nails, or any other rounded surface • Lightweight magnesium handles Cat. No. 3100 Cat. No. 3101 3100 Overall Length Handle Color 13" (330.2 mm) Gray Description Replacement Blades for Tinner Snips Weight 13.4 oz. (380 g) Seaming & Folding Tools Seamers - Straight and Offset mechanism easily and accurately bends, seams, and • Compound-leverage flattens sheet metal and non-ferrous metals • Jaw marked in 1/4" (6 mm) increments for precise bending measurements construction and nickel-chrome plated hardware provide long life • All-steel and durability • Vinyl grips with handle stops for added comfort and easy operation • Straight-handle model is used for most general applications • Offset-handle model (not pictured) is for use in overhead or confined areas • Broader jaw model for forming wider folds • Folds 22 gauge CRSM and 24 gauge SSSM Cat. No. 86553 86552 Type Straight-Hand Seamer Offset-Hand Seamer Jaw Size 3" (76.2 mm) 3" (76.2 mm) See page 310 for additional information on warnings. Overall Length 8-3/8" (212.7 mm) 8" (203.2 mm) Handle Color Blue Blue 86553 Weight 1.5 lbs. (0.68 kg) 1.5 lbs. (0.68 kg) 231 www.kleintools.com Sheet Metal Tools/HVAC Seaming & Folding Tools Folding Tools • Two folding depths: 3/8" (10 mm) and 1" (25 mm) • Handy sight gauges for accurate depth alignment • Made of heavy-duty 16 gauge steel for folding strength Cat. No. 88981 Overall Length 18" (457.2 mm) Folds 24 Gauge CRSM and 28 Gauge SSSM 88981 Weight 2.0 lbs. (0.91 kg) Tube Benders & Cutters Professional 4-in-1 Tube Bender • Bends four popular tube sizes • Calibrated markings for accurate left-hand, right-hand, and offset bends up to 90° • For soft copper, aluminum, and steel tubing • Bends 3/16", 1/4", 5/16" and 3/8" (6 mm and 8 mm) O.D. tubing 89030 Cat. No. 89030 Closed Overall Length 10" (254 mm) Weight 1.0 lbs. (0.45 kg) Professional Tube Cutter • Accurate 4 roller tracking system - no spiraling • Professional reaming tool for stainless steel tubing • Extra cutting wheel included in handle Cat. No. 88904 Cat. No. 88905 Overall Length Cuts 6-1/32" (153.2 mm) 1/8" to 1-3/8" (3.2 to 34.9 mm) Steel and Copper Tubing Description Replacement Wheel for Tube Cutter Weight 1.3 lbs. (0.59 kg) Weight 1.3 oz. (37 g) 88904 Professional Mini Tube Cutter • Perfect for tight space cutting. Requires only 1-3/8" (34.9 mm) swing radius • Smooth feed mechanism for precise, right angle cutting action • For copper and aluminum tubing; not designed for cutting stainless steel or hard tempered tubing 88978 Cat. No. 88977 Cat. No. 88978 Cuts 1/8" to 5/8" (3.2 to 15.9 mm) O.D. Tubing Description Wheels and Screw for Mini Tube Cutter 232 www.kleintools.com Overall Length 1-3/4" (44.5 mm) 88977 Weight 2.5 oz. (71 g) Weight 2.5 oz. (71 g) See page 310 for additional information on warnings. Sheet Metal Tools/HVAC Swaging Tool – Punch Type Professional 6-in-1 Swaging Punch • Swages six sizes of tubing • Hex design for ease of extraction • Precision machined surface for ease of forming • High-alloy steel, heat-treated for strength and durability Cat. No. 66400 Swages 3/16" (4.8 mm), 1/4" (6.4 mm), 5/16" (7.9 mm), 3/8" (9.5 mm), 1/2" (12.7 mm), 5/8" (15.9 mm) O.D. Tubing 66400 Overall Length 5-13/16" (147.6 mm) Weight 5.9 oz. (167 g) Duct Stretcher Duct Stretcher and pulls ductwork together, • Aligns easing installation of drive cleats • Offset handle protects hand Cat. No. 89565 Overall Length 16" (406.4 mm) 89565 Weight 12.0 oz. (340 g) Crimping Tools 5-Blade Crimper • Produces factory-precision indentations in stove pipe and round duct with just a squeeze mechanism, heavy-duty jaw/handle linkage, and closing stop provide • Compound-leverage easy operation and consistent crimps for virtually leak-proof connections steel handles include hand guards covered with vinyl grips for added comfort • Hardened and easy operation • All steel construction and nickel-plating provide long life and consistent crimp profile Cat. No. 86550 Crimps 24 Gauge CRSM and 28 Gauge SSSM Overall Length 9" (228.6 mm) Handle Color Blue Weight 1.0 lbs. (0.45 kg) 86550 Refrigeration Wrenches Ratcheting Refrigeration Wrenches • Fully reversible for refrigeration-packing gland nuts, valve stem sockets and beam-clamp installation • Compact in size, with clearly marked sockets for four nut sizes • Quick-flip reversing lever permits instant ratchet reversal • Ruggedly built with polished chrome finish for smooth edges for comfort Cat. No. 68309 68310 Socket Size 3/16" and 1/4" Sq. x 1/2" and 9/16" Hex 3/16" and 5/16" Sq. x 1/4" and 3/8" Sq. See page 310 for additional information on warnings. Overall Length 6-13/16" (173.0 mm) 5-1/2" (139.7 mm) 68310 Weight 6.9 oz. (196 g) 3.2 oz. (91 g) 233 www.kleintools.com Sheet Metal Tools/HVAC Magnetic Hex Drivers Magnetic Hex Drivers • For driving sheet metal screws • Strong Rare Earth magnets for maximum holding • 1/4" (6.4 mm) hex shank with quick release groove Cat. No. 86602 Description Overall Length Weight 1/4" Magnetic Hex Drivers Pk 3 5/16" Magnetic Hex Drivers 3 pack 3/8" Magnetic Hex Drivers 3 pack 1-3/4" (44.5 mm) 1-3/4" (44.5 mm) 1-3/4" (44.5 mm) 1.9 lbs. (0.86 kg) 2.2 oz. (62 g) 2.6 oz. (74 g) 1-3/4" (44.5 mm) 1-3/4" (44.5 mm) 1-3/4" (44.5 mm) 6.9 oz. (196 g) 7.8 oz. (221 g) 9.1 oz. (258 g) 3-Pack 86600 86601 86602 10-Pack Punch Card for Individual Sale 8660010 8660110 8660210 1/4" Magnetic Hex Drivers Pk 10 5/16" Magnetic Hex Drivers 10 pack 3/8" Magnetic Hex Drivers 10 pack Nylon Tie Tensioning Tools Nylon Tie Tensioning Tools • Designed for work with ties rated at 120 - 250 lbs. (54 - 113 kg) • Tensions up to 65 lbs. of force (30 kg) • Maximum tie width of 15/32" (12 mm) • Handle grips for comfort • Excess tie material is automatically cut off (Cat. No. 86571 only) Cat. No. 86570 86571 Description Nylon Tie Tensioning Tool Nylon Tie Tensioning Tool Auto Cutoff 86571 Weight 13.9 oz. (395 g) 1.0 lbs. (0.45 kg) 86570 Special-Purpose Knife Special-Purpose Knife • Cuts duct board and flexible duct • Double-edged knife: regular and serrated • Cushion-grip handle for comfort • Includes puncture resistant nylon sheath with belt loop Cat. No. DK06 Blade Material Stainless Steel 234 www.kleintools.com Blade Length 5-1/2" (139.7 mm) DK06 Weight 8.5 oz. (241 g) See page 310 for additional information on warnings. Sheet Metal Tools/HVAC Specialty Screwdrivers 15-in-1 Screwdriver/Nut Drivers • Multi-bit driver includes 14 different screwdriver tips plus a 1/4" (6.4 mm) nut driver • Internal storage for screwdriver bits NEW! 32290 Internal Storage Cat. No. Description 32292 NEW! HVAC Multi-Bit Screwdriver 15 Pc Shank Length 4" (101.6 mm) Slotted Bits 4 mm, 6 mm Phillips Bits #0, #1, #2, #3 Square Bits #1, #2 Nut Driver Sizes 1/4" TORX Bits #10, #15, #20, #25 Other Bits Schrader® Valve Insertion, Core Removal Overall Length 8-1/2" (215.9 mm) Weight 8.0 oz. (227 g) Schrader® is a registered trademark of Schrader-Bridgeport International, Inc. 11-in-1 Screwdriver/Nut Driver with Schrader® Valve Removal/Installation Bit • Great for HVAC and other industrial applications unique style bit for installation/removal of common TR-4 Schrader • Includes valves and aggressive thread extractor tip for backing out broken cores 32527 ® Cat. No. 32527 Shank Length 4" (101.6 mm) Slotted Bits Phillips Bits 1/4" (6.4 mm) and #1 and #2 3/16" (4.8 mm) Square Bits #1 and #2 Nut Driver Sizes 3/8", 5/16" and 1/4" Other Bits Schrader® Valve Core Removal/ Installation - Extractor Overall Length 7-3/4" (196.9 mm) Weight 7.0 oz. (198 g) Schrader® is a registered trademark of Schrader-Bridgeport International, Inc. 2-in-1 Hex Head Screwdriver • 1/4" and 5/16" six-point hex nut driver • Powerful magnets for maximum fastener retention • Solid build quality; feels like a conventional nut driver • Color coded bands for easy identification • Wrench-assist to help remove stubborn fasteners Cat. No. 65064 NEW! Tip Type Hex NEW! 65064 Tip Size 1/4" x 5/16" (6.4 x 7.9 mm) Shank Length 3-5/8" (92.1 mm) 10-in-1 Folding Screwdriver/Nut Driver • Conveniently folds up for easy storage or to fit into your pocket • Each driver arm contains four interchangeable bit styles and two nut drivers each driver arm up to a full 180° for straight on driving power, or at 90° for • Unfold extra leverage on stubborn fasteners • The quick release button easily unlocks a fully extended driver arm Cat. No. 32534 Handle Color Blue Slotted Bits 1/4" (6.4 mm) and 3/16" (4.8 mm) Phillips Bits #1 and #2 Square Bits #1 and #2 Overall Length 8" (203.2 mm) Weight 7.2 oz. (204 g) TM 32534 Nut Driver Sizes 5/16" and 1/4" Other Bits Valve Core Removal/ Installation - Extractor Weight 5.9 oz. (167 g) Schrader® is a registered trademark of Schrader-Bridgeport International, Inc. TORX® is a registered trademark of Acument Intellectual Properties, LLC. See page 310 for additional information on warnings. 235 www.kleintools.com Sheet Metal Tools/HVAC Hammers Setting Hammer epoxy resin handle helps to protect neck from fraying and • Durable splintering if incorrectly struck or over struck • High-strength fiberglass shaft absorbs shock and keeps head tight • Cushioned, PVC grip bonded to handle high-carbon steel, octagon shaped head with flat striking • Special surface and rounded cross peen Cat. No. 820-16 Head Weight 16.0 oz. (454 g) 820-16 Overall Length 13" (330.2 mm) Weight 1.6 lbs. (0.73 kg) Riveting Hammer • High-carbon steel round head is forged and hardened • Flat striking surface with rounded cross peen • Straight-grain American hickory handle is stained and lacquered 821-12 Cat. No. 821-12 Head Weight 12.0 oz. (340 g) Overall Length 12-1/4" (311.2 mm) Dead Blow Hammers • Durable, abrasion resistant non-marring hammer face • Increased striking force with zero impact rebound • Design isolates user from striking impact and reduces fatigue • 40% more driving power than othe rdead blow hammers • Protects job surface from damage HVAC, metal fabrication, electronics, oil and • Applications: mining, wood and metal assembly, automotive, aerospace Cat. No. 811-16 811-32 Head Weight 16.0 oz. (454 g) 32.0 oz. (907 g) 236 www.kleintools.com Overall Length 12-1/2" (317.5 mm) 18" (457.2 mm) Weight 1.1 lbs. (0.50 kg) 811-16 Weight 1.4 lbs. (0.64 kg) 1.8 lbs. (0.82 kg) See page 310 for additional information on warnings.
很抱歉,暂时无法提供与“S8M”相匹配的价格&库存,您可以联系我们找货
S8M
  • 1+138.044821+17.85295
库存:1
