32108
    WIHA(威汉)
    INSULATEDPICOFINISHPHILLIPS#1
32108 数据手册
www.wihatools.com 19 Wiha Insulated Pop-Up SlimLine Sets Wiha Insulated SlimLine Tools Blades High quality CV steel, through-hardened Certified to VDE, EN ISO, BS EN, ASME specifications Bit holder securely locks blades in place for precise fastening Integrated Slim Insulation molded directly onto blade High quality CV steel, throughhardened 1000Volt Rated 10,000 Volt Tested Wiha SlimTECHNOLOGY Insulation does not exceed screw head diameter Achieves blade diameters up to 33% narrower utilizing integrated insulation Insulation Test Standards: Insulation according to EN/IEC 60900, ASTM F-1505, VDE 0682/part 201, DIN 7437, NFPA70E & CSA specification 1000Volt 1000Volt Rated 10,000 Volt Tested 28393 Insulated Pop-Up Bit Holder Set With Slotted/Phillips SlimLine Blades Insulated SoftFinish multi-component handle. ClicFix Bit holder Locks all SlimLine Blades securely. Convenient rotating cap. Set includes the following 1/4” blades: 28393 Slotted: 3.0, 4.0, 5.5, 6.5mm lbs. Phillips: 1, 2 .38 1000Volt 28394 Insulated Pop-Up Bit Holder Set With Slotted/Phillips/Sq. SlimLine Blades Insulated SoftFinish multi-component handle. ClicFix Bit holder Locks all SlimLine Blades securely. Convenient rotating cap. Set includes the following 1/4” blades: 28394 Slotted: 3.0, 4.0mm lbs. Phillips: 1, 2 .38 Square: 1, 2 1000Volt 28395 Insulated Pop-Up Bit Holder Set With SlimLine Blades Insulated SoftFinish multi-component handle. ClicFix Bit holder Locks all SlimLine Blades securely. Convenient rotating cap. Set includes the following 1/4” blades: 28395 Slotted: 3.0, 4.0mm lbs. Phillips: 1, 2 .38 Terminal Xeno: 1, 2 Each SlimLine bit can be taken in and out of the holder easily and conveniently VDE-GS Certified 1000Volt 28301 SlimLine Blade Holder, With Wiha-SoftFinish® Handle Insulation According to VDE, ASTM F-1505 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Chrome-vanadium steel, through-hardened. Insulation molded directly onto blade. Quick release holder securely lock blades. Wiha-SoftFinish® handle, multi-component, cushion grip. Item No. Size mm Inch mm Inch lbs. pkg. 1/4” 50 2.0 160 6.3 .15 1 28301 283 Insulated Slotted SlimLine Blades SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Item Slim Max Inch/ No. mm Inch Inch Dia. Nm lbs. lbs. Pkg. 28307 2.5 .098 3/32 4.0 0.4 3.5 .02 1 28308 3.0 .118 1/8 4.0 0.6 5.3 .02 1 28309 4.0 .157 5/32 4.0 2.5 22.1 .02 1 28312 5.5 .216 7/32 6.0 3.8 33.6 .02 1 28315 6.5 .255 1/4 6.0 5.5 48.6 .02 1 Insulated Phillips SlimLine Blades SlimLine blades have up 283 to 33% narrower insulation diameter then standard insulated tools. Item Slim Max Inch/ No. Size Dia. Nm lbs. lbs. Pkg. 1 4.0 3.8 33.7 .02 1 28317 2 6.0 5.5 48.8 .02 1 28319 283 Insulated Pozidriv® SlimLine Blades SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Item Slim Max Inch/ No. Size Dia. Nm lbs. lbs. Pkg. 28330 1 4.0 3.8 33.7 .02 1 28331 2 6.0 5.5 48.8 .02 1 www.wihatools.com 21 Wiha Insulated PicoFinish Precision Screwdrivers Individually Tested Protective Insulation 1000Volt AC, VDE and GS Tested 1000Volt 320 Insulated Slotted PicoFinish Screwdrivers. Individually Tested Protective Insulation 1000Volt AC, VDE & GS Tested. Item No. mm Inch mm mm Pkg. lbs. 1.5 .06 40 154 1 .05 32000 2.0 .08 40 154 1 .07 32001 2.5 .10 60 160 1 .07 32002 3.0 .12 60 160 1 .08 32003 3.5 .14 60 160 1 .08 32004 1000Volt 8 Piece Slotted & Phillips PicoFinish Set 32088 Item No. Slotted: 1.5, 2.0, 2.5, 3.0, 3.5 Phillips: #00, #0, #1 32088 1000Volt 1000Volt Insulated Phillips PicoFinish Screwdrivers. Individually 321 Tested Protective Insulation 1000Volt AC, VDE & GS Tested. Item No. Size mm mm Pkg. lbs. 32106 00 40 154 1 .05 32107 0 60 160 1 .07 32108 1 60 160 1 .08 lbs. .35 High quality CV steel, through hardened, black finish Rotating cap for precise turning & control with fingertip 5 Piece Slotted & Phillips PicoFinish Set 32085 Item No. Slotted: 1.5, 2.5, 3.5 lbs. 32085 Phillips: #0, #1 .26 Wiha Insulated SlimLine Screwdrivers 1.4” Insulation Test Standards: Insulation according to EN/IEC 60900, ASTM F-1505, VDE 0682/part 201, DIN 7437, NFPA70E & CSA specification 321 Insulated Phillips SlimLine Screwdrivers Insulation According to ASTM F-1505, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested to 10,000Volts. Ideal for jobs where access is limited Integrated Slim Insulation molded directly onto blade 1000Volt Rated 10,000 Volt Tested Wiha SlimTECHNOLOGY Achieves blade diameters up to 33% narrower utilizing integrated insulation 1.4” Insulated Slotted SlimLine Screwdrivers 320 Insulation According to ASTM F-1505, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested to 10,000Volts. High quality CV steel, through hardened. SlimLine blades have up to 33% narrower insulation diameter then standard insulated tools. Wiha-SoftFinish® handle, multi-component, cushion grip. Item Slim No. mm Inch Inch Dia. mm mm lbs. Pkg. 3.5 .139 9/64 3.5 100 204 .07 1 32046 4.0 .157 5/32 4.0 100 211 .12 1 32049 4.5 .177 3/16 4.5 125 211 .14 1 32052 5.5 .216 7/32 5.5 125 243 .21 1 32055 6.5 .255 1/4 6.5 150 268 .25 1 32058 Item Slim No. Size Dia. mm mm lbs. Pkg. 32145 1 4.5 80 204 .12 1 32146 2 6.0 100 211 .21 1 1.4” Insulated Xeno SlimLine Screwdrivers For Terminal Screws 307 Insulation According to ASTM F-1505, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested to 10,000Volts. Item Slim No. Size Dia. mm mm lbs. Pkg. 30746 1 4.5 80 191 .12 1 30747 2 6.0 100 218 .21 1 1.4” Insulated Square SlimLine Screwdrivers 358 Insulation According to ASTM F-1505, New VDE Specification 0682/part 201 and EN/IEC 60900, NFPA70E & CSA, up to 1000 Volt. Individually Tested to 10,000Volts. Item Slim No. Size Dia. mm mm lbs. Pkg. 1 4.0 100 218 .12 1 35844 2 4.5 125 243 .19 1 35845
32108 价格&库存
很抱歉,暂时无法提供与“32108”相匹配的价格&库存,您可以联系我们找货
