39701
39701
    WIHA(威汉)
    SCREWDRIVER PHILLIPS #1
39701 数据手册
Butt Contact Pushbutton Switches SERIES 39 Miniature Limit FEATURES • Adjustable Location Setting • Plunger Sealed Version DIMENSIONS in inches (and millimeters) SPST–Normally Open, With Overtravel E.I.A. DATE CODE .136 – .005 (3,45 – 0,13) DIA. 5/16-32 UNEF-2A THREAD 39-101 A HEX. NUT (2) .093 (2,36) THICK .437 (11,10) ACROSS FLATS .287 (7,29) MAX. Pushbutton Switches .072 – .005 (1,83 – 0,13) A 1.050 .800 (26,67) ±.032 REF. (20,32 ± 0,81) B A = .250 ± .015 (6,35 ± 0,38) B = .600 ± .015 (15,24 ± 0,38) .072 ± .005 (1,83 ± 0,13) SPST–Normally Closed, Sealed Actuator XXXX B CIRCUITRY SPSt n.O. A XXXX B Specifications Rating Criteria .775 .610 – .032 (19,69) REF. (15,5 – 0,81) Contact Resistance: 25 milliohms maximum on a new switch Voltage Breakdown: 1,000 Vac between mutually insulated parts Insulation Resistance: 1,000 megohms minimum Operating Temperature: -40°C to +85°C Operations at Rated Load Part Number /2 Amp 1/4 Amp 500,000 39-101 Button Color Nat. Nylon Over Travel Total Travel Actuating Action Force (oz.) +3 .187 ± .015 .060 (1,52) Min. Momentary 5 –2 (4,75 ± 0,38) from top of bushing Rating at 115 Vac Resistive Rating at 220 Vac Resistive 150 mA 75 mA Operations Part at Rated Number Load 30,000 39-102 Nat. Nylon 150 mA 75 mA 100,000 39-701 Nat. Nylon /2 Amp 1/4 Amp Total Travel Action Button Color 30,000 39-103 Nat. Nylon Over Travel Actuating Force (oz.) Momentary .250 ± .015 (6,35 ± 0,38) 39-102 and 39-103: .200 (5,08) Nominal. from top of bushing 6.8 ± 5 Momentary .187 ± .015 (4,75 ± 0,38) 39-701: .060 (1,52) Min. from top of bushing 8±4 Rating at 115 Vac Resistive 1 Rating at 220 Vac Resistive .100 – .005 (2,54 – 0,13) .060 – .005 (1,52 – 0,13) Part Number Total Travel Over Travel .042 ± .010 Momentary None (1,07 ± 0,25) Bushing and Mounting Nuts: Brass, tin zinc Insulation Sleeve: Molded polyester for 39-101, 39-102, 39-103 and 39-701: phenolic per MIL-M-14 type CFG for 39-702 Base: Thermoset plastic Terminals: Commercial bronze, gold plated over nickel for 39-101, 39-102, 39-103 and 39-701; silver for 39-702 Springs: Tinned music wire Contacts: Commercial bronze, gold-plated for 39-101, 39-102, 39-103 and 39-701; fine silver for 39-702 Button: Thermoplastic O-Ring: (39-701 & 39-702) Silicone Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois Operations at Rated Load /4 Amp 1/8 Amp 100,000 39-702 Action .100 (2,54) MAX. Materials and Finishes SPSt n.C. Rating at 220 Vac Resistive .110 – .005 (2,79 – 0,13) DIA. Mounting Nuts per above. .040 (1,02) REF. .987 .800 (25,07) –.032 REF. (20,32 – 0,81) .068 – .015 (1,73 – 0,38) .072 – .005 (1,83 – 0,13) 5/16-32 UNS-2A THREAD .020 (0,51) REF. 1 1 A A = .187 – .015 (4,75 – 0,38) B = .600 – .015 (15,24 – 0,38) E.I.A. DATE CODE A = .165 +.035 .015 (4,19 +0,89 0,38) B = .410 – .015 (10,41 – 0,38) 39-702 .110 – .005 (2,79 – 0,13) DIA. E.I.A. DATE CODE 5/16-32 UNEF-2A THREAD .068 ± .015 (1,73 ± 0,38) Mounting Nuts per above. Rating at 115 Vac Resistive Terminals are not oriented to bushing flat 39-701 .110 ± .005 (2,79 ± 0,13) DIA. XXXX .068 – .015 (1,73 – 0,38) SPST–Normally Open, With Overtravel, Sealed Actuator SPST–Normally Open, With Extended Overtravel E.I.A. DATE CODE 5/16-32 UNEF-2A THREAD .837 .650 – .032 (21,26) (16,51 REF. – 0,81) B A = .187 – .015 (4,75 – 0,38) B = .450 – .015 (11,43 – 0,38) Mounting Hole .339 (8,61) Diameter ‘D’ shape per above. 39-102 39-103 XXXX Button Color Nat. Nylon Actuating Force (oz.) 8 ± 4 STANDARD OPTIONS Optional plating: gold-plated contacts for dry circuit conditions, contact Grayhill. Ordering Information Part No. 39-101 39-102 39-103 39-701 39-702 SPST, N.O. With Overtravel SPST, N.O. With Extended Overtravel SPST, N.O. With Extended Overtravel SPST, N.O. With Overtravel, Sealed SPST, N.C. Sealed Description 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Grayhill: 39-101 39-102 39-103 39-701 39-701-EW 39-702 39-701-E 39-702-E 39-102-EW 39-103-EW
39701 价格&库存
很抱歉,暂时无法提供与“39701”相匹配的价格&库存,您可以联系我们找货
