75995
75995
    WIHA(威汉)
    BITSETASSORTEDW/CASE26PC
75995 数据手册
www.wihatools.com 3 Wiha SYS 4 Micro Bits & Compact Bit Sets Micro Bit Sets - Premium Tool Steel Standard & ESD Safe Sets SALE 33% OFF Wiha Premium Pro quality Micro Bits Micro Bits Made in Germany • Small, rugged & compact • Sets include indexed steel storage box • Spring clip bit holding 4” bit extension • Bits fit directly in handle or extension • Hardened bits Chrome-V-Moly super tool steel • Handles Static Dissipative ESD Safe material ideal for work on static sensitive electronic components 75999 SYSTEM 4 Slotted, Phillips, Hex Inch & Metric Precision Interchangeable Bit Set, 26 Pcs. In Compact Fold Out Box. Wiha precision handle, bit extension & 24 interchangeable bits. Item No. Combination Bit Set 75999 Set with Standard Precision Handle Set includes the following bits: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 Hex Metric: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 100mm Bit Extension lbs. .64 Each $49.98 S A L E $33.50 75395 SYSTEM 4 Hex Inch & Metric Precision Interchangeable Bit Set, 18 Pcs. In Compact Fold Out Box. Wiha precision handle, bit extension and 16 Wiha interchangeable bits. Item No. Combination Bit Set 75395 Set with Standard Precision Handle Includes the following bits: Hex Metric: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 100mm Bit Extension lbs. .58 Each $39.98 S A L Sale Prices Good Through E December 31st 2015 $26.80 26 Pc . Set 18 Pc. Set 75995 SYSTEM 4 Precision Interchangeable Bit Set, 26 Pcs. In Compact Fold Out Box Sets includes Wiha precision handle, bit extension & 24 Wiha interchangeable bits. Item SYSTEM 4 Micro Bit Set No. Set with ESD Safe Precision Handle 75995 and the following bits: : T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 5Point: PS1, PS2, PS3, PS4, PS5, PS6 Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: #000, 00, 0, 1 100mm Bit Extension lbs. .54 S A L $ 37.52 759 sets SYSTEM  4 Slotted/Phillips/Hex Inch/ Precision Interchangeable Bit Set, 27 Pcs. In Compact Fold Out Box. Sets include your choice of Wiha precision handle, bit extension and 25 Wiha interchangeable bits. Item Handle Options for SYSTEM 4 No. Combination Bit Sets 75991 Set with Standard Precision Handle 75992 Set with ESD Safe Precision Handle Sets include the following bits: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 100mm Bit Extension lbs. .64 Each $49.98 S A L E $33.50 75994 SYSTEM 4 Slotted/Phillips/Hex Metric/ Precision Interchangeable Bit Set, 27 Pcs. In Compact Fold Out Box. Set includes Wiha precision handle, bit extension and 25 Wiha interchangeable bits. Item SYSTEM 4 No. Combination Bit Set 75994 Set with ESD Safe Precision Handle Set includes the following bits: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex Metric: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm 100mm Bit Extension Each $49.98 lbs. .64 S A L E $33.50 26 Pc. Set 27 Pc. Set 27 Pc. Set
75995 价格&库存
很抱歉,暂时无法提供与“75995”相匹配的价格&库存,您可以联系我们找货
