75395
75395
    WIHA(威汉)
    BITSETHEXW/CASE18PC
75395 数据手册
Complete Tech Tools Program Professional Tech Tools Toll Free: (800) 494-6104 2 Wiha Precision Screwdrivers Description Page Precision Slotted Drivers Wiha Precision Proturn Drivers Description Page Proturn Drivers & Blade Sets 4-5 Precision Phillips Drivers Slotted, Phillips, Torx, Chip Lifter 5 Wiha ESD Safe Precision Handles/Blades Precision Pozidriv® Drivers 6 Precision Hex Drivers 6 Precision Ball End Drivers 7 SYSTEM 4 Handles/Blades Precision Nut Drivers 8 SYSTEM 4 Sets Precision Torx® Drivers 9 Precision Chip Lifters Description Page 15-16 1 7-19 Wiha ESD Safe Precision Handle & Blades 9 Description Page Wiha Magnetizer/Demagnetizer Description Page Torque Cable Keys 14 SYSTEM 4 Drive-Loc Handle & Blades 17 SYSTEM 4 Drive-Loc Set 17 7 ESD Safe Micro Bit Handles, Bits & Sets Wiha Precision Screwdriver Accessories Description Page Precision Master Tech Set DESCRIPTION Page 9 Precision Pocket Clip 9 Precision Stand 9 Precision Pouch 8,13 Micro Bits Handles/Bits/Sets 20-22 ESD Safe Micro Bit Sets 23 Micro Bit Storage Handle Sets 23 Precision Electronic Pliers/Cutters Description Page Electronic Diagonal Cutters Wide Pointed Head Wiha Precision PicoFinish Drivers Description Page PicoFinish Screwdrivers 10-13 Slotted, Phillips, Torx, TorxPlus, Hex, MagicSpring, Ball End Hex, Chip Lifter & Nut Drivers 24 Electronic Diagonal Cutters 24 Wide Shape w/Wire Holding Spring Electronic Diagonal Cutters Narrow Shape 24 Electronic Diagonal Cutters Full Flush Cutters w/Wire Trapping Spring 25 Electronic Diagonal Cutters 25 48O Front Cutter/Long Nose Pliers Electronic Diagonal Cutters Oblique 30O Cutting Nippers 25 Description Page Electronic Diagonal Cutters Short Nose Precision Pliers 25 Magnetizer/Demagnetizer 13 Electronic Stripping Pliers 25 Wiha Magnetizer/Demagnetizer www.wihatools.com 3 Wiha Professional Tweezers Description Page ESD Safe Tweezers 26-28 Standard Tweezers 29-31 SMD Tweezers 38 Adjustable Cable Stripper 39 Adjustable Stripping Tool 39 CATV/Satellite Stripper 39 32 2 Step Stripping Tools 40 32 3 Step Stripping Tools 41 31 31 Super Thin Tweezers 31 Wafer Tweezers Cutting Tweezers 33 Self Closing Tweezers 34 Microscopy Tweezers 35 Isolated Tweezers 35 Inspection Mirrors 36 All Stainless Hooks 36 All Stainless Excavators 37 All Stainless Probes Description Page Self Adj. Cut & Strip Tools Long Tweezers w/Long Tips Guide Pin Tweezers Wiha Stripping Tools 37 Wiha ESD Safe Tech Tools ESD Safe Precision Drivers Slotted/Phillips/Torx®/ TorxPlus®/Hex/Nut Drivers/ Chip Lifter ESD Safe Ceramic Drivers ESD Safe SYSTEM 4 Handles/Blades/Sets ESD Safe Drive-Loc Handles/Blades/Sets ESD Safe Pliers & Cutters Catalog 99945.wo Toll Free: (800) 494-6104 4 Wiha Long Life Precision Series Rotating cap for precise turning and control with fingertip Precision handle high quality plastic, cadmium free Molded on tapered handle allows rapid rotation High performance blades chrome-vanadiummolybdenum steel, Hard chrome finished 260 Slotted Screwdriver, With Precision Handle Blade high alloy chrome-vanadium-molybdenum steel. Item No. mm Inch mm Inch mm Inch mm Inch lbs. pkg. 26008 .80 1/32 40 1.6 0.16 .01 120 4.7 .02 10 26010 1.0 .039 40 1.6 0.18 .01 120 4.7 .02 10 26012 1.2 3/64 40 1.6 0.20 .01 120 4.7 .02 10 26015 1.5 1/16 40 1.6 0.25 .01 120 4.7 .02 10 26018 1.8 .070 40 1.6 0.30 .01 120 4.7 .02 10 26020 2.0 5/64 40 1.6 0.40 .02 120 4.7 .02 10 26022 2.0 5/64 50 2.0 0.40 .02 145 5.7 .02 10 26023 2.0 5/64 100 3.9 0.40 .02 180 7.1 .03 10 26025 2.5 3/32 50 2.0 0.40 .02 145 5.7 .03 10 26027 2.5 3/32 100 3.9 0.40 .02 195 7.7 .03 10 26028 2.5 3/32 150 6.0 0.40 .02 245 9.6 .04 10 26030 3.0 1/8 50 2.0 0.50 .02 145 5.7 .03 10 26032 3.0 1/8 60 2.4 0.50 .02 170 6.7 .04 10 26033 3.0 1/8 100 3.9 0.50 .02 210 8.3 .04 10 26034 3.0 1/8 150 5.9 0.50 .02 260 10.2 .05 10 26035 3.5 9/64 60 2.4 0.60 .02 170 6.7 .05 10 26040 4.0 5/32 60 2.4 0.80 .03 170 6.7 .05 10 26041 4.0 5/32 100 3.9 0.80 .03 210 8.3 .06 10 26042 4.0 5/32 150 5.9 0.80 .03 260 10.2 .07 10 *Metric dimensions actual - Inch dimensions approximate 26090 6 Piece Precision Slotted Set Blade high alloy chrome-vanadiummolybdenum steel. Hard chrome finished. Item No. 26090 Slotted: lbs. 1.5, 2.0 x 40mm .27 2.5, 3.0 x 50mm 3.5, 4.0 x 60mm Tip precision ground for exact fit, hard chromed non-slip surface 26099 8 Piece Precision Slotted Set Blade high alloy chrome-vanadium-molybdenum steel. Hard chrome finished. In canvas storage pouch Item No. 26099 Slotted: 1.0, 1.2, 1.5, 2.0 x 40mm 2.5, 3.0 x 50mm, 3.5, 4.0 x 60mm lbs. .54 www.wihatools.com 5 Wiha Precision Slotted/Phillips Drivers 261 Phillips Screwdriver, With Precision Handle Blade high alloy chrome-vanadium-molybdenum steel. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 26102 000 40 1.6 2.0 .08 120 4.7 .02 10 26100 00 40 1.6 2.0 .08 120 4.7 .02 10 26101 00 75 3.0 2.0 .08 155 6.1 .02 10 26105 0 50 2.0 3.0 .12 145 5.7 .02 10 26108 0 75 3.0 3.0 .12 170 6.7 .03 10 26107 0 100 3.9 3.0 .12 195 7.6 .05 10 26109 0 150 5.9 3.0 .12 245 9.6 .06 10 26110 1 60 2.4 4.0 .16 170 6.7 .05 10 26113 1 80 3.1 4.0 .16 190 7.5 .05 10 26114 1 100 3.9 4.0 .16 210 8.2 .06 10 26115 1 150 5.9 4.0 .16 260 10.2 .07 10 *Metric dimensions actual - Inch dimensions approximate 7 Piece Precision Slotted & 26190 Phillips Set Blade high alloy chromevanadium-molybdenum steel. Item No. 26190 Slotted: lbs. 1.5 x 40mm .31 2.0, 2.5 x 50mm 3.0 x 60mm Phillips: 00 x 40mm 0 x 50mm , 1 x 60mm 26092 7 Piece Precision Slotted & Phillips Set Blade high alloy chromevanadium-molybdenum steel. Item No. 26092 Slotted: lbs. 2.5 x 50mm, .30 2.5, 3.0, 4.0 x 100mm 3.0, 4.0 x 150mm Phillips: 0 x 75mm 26194 4 Piece Precision Phillips Set Blade high alloy chrome-vanadium-molybdenum steel. Hard chrome finished. Item No. 26194 Phillips: 000, 00 x 40mm lbs. 0 x 50mm, 1 x 60mm .18 In canvas storage pouch 26199 8 Piece Precision Slotted/Phillips Set Blade high alloy CVM steel, hard chrome finished. Item No. 26199 Slotted: 1.0, 2.0 x 40mm, 3.0 x 50mm, 4.0 x 60mm Phillips: 000, 00 x 40mm, 0 x 50mm, 1 x 60mm lbs. .55 26192 5 Piece Precision Slotted & Phillips Set Blade high alloy chromevanadium-molybdenum steel. Item No. 26192 Slotted: lbs. 2.5, 3.0, 4.0 x 150mm .44 Phillips: 0, 1 x 150mm Toll Free: (800) 494-6104 6 Wiha Pozidriv® Precision Series Wiha Hex Inch Precision Series 262 Pozidriv Screwdriver, With Precision Handle Blade high alloy chrome-vanadium-molybdenum steel. Item No. Size mm Inch mm Inch mm Inch lbs. pkg. 26205 0 50 2.0 3.0 .12 145 5.7 .03 10 26210 1 60 2.4 4.0 .16 170 6.7 .05 10 *Metric dimensions actual - Inch dimensions approximate ® Wiha Hex Metric Precision Series 263 Metric Metric Hex Driver, With Precision Handle Metric sizes. Blade high alloy chrome-vanadium-molybdenum steel. Item No. mm Inch mm Inch mm Inch lbs. pkg. 26307 .71 .028 40 1.6 120 4.7 .02 10 26309 .89 .035 40 1.6 120 4.7 .02 10 26313 1.27 .050 40 1.6 120 4.7 .02 10 26315 1.5 - 50 2.0 145 5.7 .03 10 26320 2.0 5/64 50 2.0 145 5.7 .03 10 26325 2.5 - 60 2.4 170 6.7 .04 10 26330 3.0 - 60 2.4 170 6.7 .04 10 26340 4.0 - 60 2.4 170 6.7 .05 10 *Metric dimensions actual - Inch dimensions approximate 26390 7 Pc. Precision Hex Driver Set Metric Blade high alloy chrome-vanadiummolybdenum steel. Item No. 26390 Hex Metric: lbs. .71, .89, 1.27 x 40mm .28 1.5, 2.0 x 50mm 2.5, 3.0 x 60mm 263 Inch Inch Hex Driver, With Precision Handle Inch sizes. Blade high alloy chrome-vanadium-molybdenum steel. Item No. Inch mm mm Inch mm Inch lbs. pkg. 26307 .028 .71 40 1.6 120 4.7 .02 10 26309 .035 .89 40 1.6 120 4.7 .02 10 26313 .050 1.27 40 1.6 120 4.7 .02 10 26316 1/16 - 50 2.0 145 5.7 .03 10 26320 5/64 2.0 50 2.0 145 5.7 .03 10 26323 3/32 - 60 2.4 170 6.7 .04 10 26327 7/64 - 60 2.4 170 6.7 .04 10 26331 1/8 - 60 2.4 170 6.7 .04 10 26333 9/64 60 2.4 170 6.7 .05 10 26336 5/32 60 2.4 170 6.7 .05 10 *Metric dimensions actual - Inch dimensions approximate 26391 8 Pc. Precision Hex Driver Set Inch Blade high alloy chrome-vanadiummolybdenum steel. Item No. 26391 Hex Inch: lbs. .028, .035, .050 x 1.6” .32 1/16, 5/64 x 2.0” 3/32, 7/64, 1/8 x 2.4” 26399 8 Piece Precision Hex Driver Set - Inch Blade high alloy chrome-vanadium-molybdenum steel. Hard chrome finished. In canvas storage pouch Item No. 26399 Hex Inch: .028, .035, .050 x 1.6” 1/16, 5/64 x 2.0”, 3/32, 7/64, 1/8 x 2.4” lbs. .55 www.wihatools.com 7 Wiha Ball End Precision Series 30° 264 Inch Ball End Hex Inch Screwdriver With Precision Handle Angle entry up to 30°. Blade high alloy chrome-vanadium-molybdenum steel. Hard chrome finish. Item No. Inch mm Inch mm Inch lbs. pkg. 26413 .050 40 1.6 120 4.7 .02 10 26416 1/16 50 2.0 145 5.7 .03 10 26419 5/64 50 2.0 145 5.7 .03 10 26423 3/32 50 2.0 145 5.7 .03 10 26427 7/64 60 2.4 170 6.7 .03 10 26431 1/8 60 2.4 170 6.7 .05 10 26436 9/64 60 2.4 170 6.7 .05 10 26439 5/32 60 2.4 170 6.7 .05 10 *Metric dimensions actual - Inch dimensions approximate 26490 8 Piece Ball End Hex Driver Set inch Angle entry up to 30°. Blade high alloy chrome-vanadiummolybdenum steel. Item No. 26490 Hex Inch: lbs. .050 x 1.6” .28 1/16, 5/64, 3/32 x 2.0” 7/64, 1/8, 9/64, 5/32 x 2.4” 26499 8 Piece Ball End Hex Driver Set - Inch Blade high alloy chrome-vanadium-molybdenum steel. Hard chrome finished. In canvas storage pouch Item No. 26499 Ball End Hex Inch: lbs. .050 x 1.6”, 1/16, 5/64, 3/32 x 2.0” .62 7/64, 1/8, 9/64, 5/32 x 2.4” 30° 264 Metric Ball End Hex Metric Screwdriver With Precision Handle Angle entry up to 30°. Blade high alloy CVM steel. Item No. mm Inch mm Inch mm Inch lbs. pkg. 26413 1.27 .050 40 1.6 120 4.7 .02 10 26415 1.5 - 50 2.0 145 5.7 .03 10 26420 2.0 - 50 2.0 145 5.7 .03 10 26425 2.5 - 60 2.4 170 6.7 .04 10 26430 3.0 - 60 2.4 170 6.7 .05 10 26440 4.0 60 2.4 170 6.7 .05 10 *Metric dimensions actual - Inch dimensions approximate 26491 5 Piece Ball End Hex Driver Set - Metric Angle entry up to 30°. Blade high alloy chrome-vanadiummolybdenum-steel. Item No. 26491 Ball End Hex Metric: lbs. 1.27 x 40mm .25 1.5, 2.0 x 50mm 2.5, 3.0 x 60mm Wiha Torque Cable Keys 286 Torque Cable Key For Threaded Hex Connectors For torque controlled fastening of cable plug connectors with Hex heads. Used with Wiha-TorqueControl Screwdrivers. Item Max No. Size mm mm mm Nm pkg. lbs. 28620 8mm 4.0 78 218 1.0 1 .06 28622 9mm 4.0 78 218 1.0 1 .06 28624 11mm 4.0 78 218 1.5 1 .06 28626 12mm 4.0 78 218 1.5 1 .06 28627 13mm 4.0 78 218 1.5 1 .06 28629 14mm 4.0 78 218 1.5 1 .06 28632 17mm 4.0 78 218 1.5 1 .06 28633 18mm 4.0 78 218 1.5 1 .06 28637 22mm 4.0 90 233 2.0 1 .10 28638 24mm 4.0 90 233 2.0 1 .10 28644 Torque Cable Key For Threaded Hex Connectors - Inch Item Max No. Size mm mm mm Nm pkg. lbs. 28644 1/2” 4.0 78 218 1.5 1 .06 8 Toll Free: (800) 494-6104 Wiha Nut Driver Precision Series 265 Inch Inch Nut Driver With Precision Handle 265 Metric Metric Nut Driver With Precision Handle Metric sizes. Blade CVM steel. Hard chrome finished. Item No. mm mm inch mm Inch mm mm lbs. 26510 1.5 60 2.4 140 5.5 2.5 3.0 .03 26515 1.8 60 2.4 140 5.5 2.9 3.5 .03 26520 2.0 60 2.4 140 5.5 3.2 4.0 .04 26525 2.5 60 2.4 155 6.1 4.0 4.0 .04 26530 3.0 60 2.4 155 6.1 5.0 5.0 .05 26532 3.2 60 2.4 155 6.1 5.0 5.0 .05 26535 3.5 60 2.4 155 6.1 5.3 6.0 .05 26540 4.0 60 2.4 155 6.1 5.5 6.0 .05 26545 4.5 60 2.4 155 6.1 6.2 7.0 .05 26550 5.0 60 2.4 155 6.1 6.8 7.0 .05 26555 5.5 60 2.4 170 6.7 7.6 8.0 .06 26560 6.0 60 2.4 170 6.7 8.2 9.0 .06 26570 7.0 60 2.4 170 6.7 9.6 10.0 .06 *Metric dimensions actual - Inch dimensions approximate pkg. 10 10 10 10 10 10 10 10 10 10 10 10 10 26590 8 Pc. Precision Nut Driver Set Metric Blade CVM steel. Item No. 26590 Metric Nut Drivers: lbs. .48 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5, 6.0 x 60mm 26592 Set 7 Pcs. Nut Driver Metric Item No. 26592 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Inch sizes. Blade CVM steel. Hard chrome finished. Item No. Inch mm inch mm Inch Inch Inch lbs. pkg. 26523 3/32 60 2.4 155 6.1 .16 .16 .04 10 26527 7/64 60 2.4 155 6.1 .20 .20 .05 10 26531 1/8 60 2.4 155 6.1 .20 .20 .05 10 26536 9/64 60 2.4 155 6.1 .21 .24 .05 10 26539 5/32 60 2.4 155 6.1 .22 .24 .05 10 26547 3/16 60 2.4 155 6.1 .25 .28 .05 10 26556 7/32 60 2.4 170 6.7 .30 .32 .06 10 26563 1/4 60 2.4 170 6.7 .34 .36 .06 10 *Metric dimensions actual - Inch dimensions approximate 26591 8 Pc. Precision Nut Driver Set Inch Blade CVM steel. Item No. 26591 Inch Nut Drivers: lbs. 47 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” x 2.4” 8 Pc. Precision Nut Driver Set - Inch 26599 Blade high alloy chrome-vanadium-molybdenum steel. Hard chrome finished. In canvas storage pouch Item No. Inch Nut Drivers: lbs. 26599 3/32, 7/64, 1/8, 9/64, 5/32, .72 3/16, 7/32, 1/4” x 2.4” Wiha Precision Chip Lifter 26598 8 Pc. Precision Nut Driver Set - Metric Blade high alloy chrome-vanadium-molybdenum steel. Hard chrome finished. In canvas storage pouch Item No. 26598 Metric Nut Drivers: lbs. 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, .70 5.5, 6.0 x 60mm 26810 Precision Chip Lifter Blade chrome-vanadium-molybdenum steel, hardened, chrome-plated. Precision handle high quality plastic, impact resistant. Standard handle Item No. mm mm mm mm Inch lbs. pkg. 26810 1 3.5 50 145 5.7 .07 1 *Metric dimensions actual - Inch dimensions approximate www.wihatools.com 9 Wiha Precision Series Screwdriver, With Precision Handle 267 Blade high alloy chrome-vanadium-molybdenum steel. Item No. Size mm Inch mm Inch lbs. pkg. 26701 T1 40 1.6 120 4.7 .01 10 26702 T2 40 1.6 120 4.7 .02 10 26703 T3 40 1.6 120 4.7 .02 10 26704 T4 40 1.6 120 4.7 .02 10 26705 T5 40 1.6 120 4.7 .02 10 26706 T6 40 1.6 120 4.7 .02 10 26707 T7 40 1.6 120 4.7 .02 10 26708 T8 40 1.6 120 4.7 .03 10 26709 T9 50 2.0 145 5.7 .03 10 26710 T10 50 2.0 145 5.7 .03 10 26715 T15 60 2.4 170 6.7 .05 10 26720 T20 60 2.4 170 6.7 .05 10 *Metric dimensions actual - Inch dimensions approximate 92190 Master Technicians Bench Top Set Metal frame. Equipped with 50 precision drivers. 26790 6 Pc. Screwdriver Set Blade high alloy chrome-vanadiummolybdenum steel. Item No. 26790 : lbs. T6, T7, T8 x 40mm .30 T9, T10 x 50mm T15 x 60mm Screwdriver Set 26791 Set 8 Pcs. Item No. 26791 T1, T2, T3, T4, T5, T6, T7, T8 Item No. 92190 lbs. 2.86 Slotted: .8, 1.0, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0 Phillips: #000, #00, #0, #1 : T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 Metric Hex: 1.27, 1.5, 2.0, 2.5, 3.0 Inch Hex: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Metric Nut Drivers: 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5 26810 Chip Lifter 92191 51 Piece Precision Tool Tray Set Tool box tray. Equipped with 51 precision drivers. Item No. Slotted: .8, 1.0, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0 92191 Phillips: #000, #00, #0, #1 Torx®: T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 lbs. 3.14 Metric Hex: 1.27, 1.5, 2.0, 2.5, 3.0, 4.0 Inch Hex: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Metric Nut Drivers: 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5 Screwdriver Set 26799 8 Pc. Blade high alloy chrome-vanadium-molybdenum steel. Hard chrome finished. In canvas storage pouch Item No. 26799 : T3, T4, T5, T6, T7, T8 x 40mm T9 x T10 x 50mm lbs. .50 Screwdriver Set 26792 7 Pc. Blade high alloy chrome-vanadiummolybdenum steel. Item No. 26792 : lbs. T5, T6, T7, T8 x 40mm .33 T9, T10 x 50mm T15 x 60mm 26810 Chip Lifter 26001 Pocket clip for precision screwdrivers Tool clips turn Precision Screwdrivers into Pocket Screwdrivers. Item No. lbs. pkg. 26001 Fits all Precision handles .0035 1 26000 plastic Precision Tool Rack Rack holds 6 precision screwdrivers, can be set on workbench. Also has holes for hanging. Made from high quality plastic. Item No. lbs. pkg. 26000 Rack for 6 Precision screwdrivers .08 1 10 Toll Free: (800) 494-6104 Wiha Soft Grip PicoFinish Precision Screwdrivers The Comfortable Precision Screwdriver CVM tool steel blade, hardened, hard chrome finish Color coded symbols on rotating cap gives easy recognition of individual styles & sizes 260 Slotted Precision Screwdriver, With PicoFinish Handle Blade CVM steel, hardened, hard chromed. Item No. mm Inch mm Inch mm Inch Pkg. 26050 0.8 .03 40 1.6 134 5.3 10 26051 1.0 .04 40 1.6 134 5.3 10 26052 1.2 .05 40 1.6 134 5.3 10 26053 1.5 .06 40 1.6 134 5.3 10 26054 1.5 .06 60 2.4 154 6.1 10 26055 1.8 .07 40 1.6 134 5.3 10 26056 1.8 .07 60 2.4 154 6.1 10 26060 2.0 .08 40 1.6 140 5.5 10 26061 2.0 .08 60 2.4 160 6.3 10 26063 2.0 .08 100 3.9 200 7.9 10 26065 2.5 .09 50 2.0 150 5.9 10 26066 2.5 .09 75 3.0 175 6.9 10 26068 2.5 .09 100 3.9 200 7.9 10 26070 3.0 .13 50 2.0 150 5.9 10 26072 3.0 .13 100 3.9 200 7.9 10 26073 3.0 .13 150 5.9 250 9.8 10 26074 3.5 .14 60 2.4 160 6.3 10 26076 4.0 .16 60 2.4 160 6.3 10 26079 4.0 .16 100 3.9 200 7.9 10 26080 4.0 .16 150 5.9 250 9.8 10 *Metric dimensions actual - Inch dimensions approximate 26093 8 Pc. Slotted Precision Screwdriver Set, With Soft PicoFinish Handle In storage pouch Item No. 26093 Slotted: .8, 1.2, 1.5, 2.0 x 40mm lbs. 2.5, 3.0 x 50mm, 3.5, 4.0 x 60mm .54 Soft Grip Handle Ergonomic multicomponent handle with rotating cap for maximum user comfort and precise control 261 Phillips Precision Screwdriver, With Soft PicoFinish Precision Handle Blade high alloy chrome-vanadium-molybdenum steel. Hard chrome finished. Item No. Size mm Inch mm Inch mm Inch pkg. 26130 000 40 1.6 2.0 .08 134 5.3 10 26132 00 40 1.6 2.0 .08 134 5.3 10 26133 00 60 2.4 2.0 .08 154 6.1 10 26135 0 50 2.0 3.0 .12 150 5.9 10 26136 0 75 3.0 3.0 .12 175 6.9 10 26140 1 60 2.4 4.0 .16 160 6.3 10 26142 1 80 3.1 4.0 .16 180 7.1 10 26145 1 150 5.9 4.0 .16 250 9.8 10 *Metric dimensions actual - Inch dimensions approximate 26193 8 Pc. Slotted & Phillips Precision Driver Set, With Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. ChromTop finish on tip for a perfect fit. In storage pouch Item No. 26193 Slotted: 1.0, 1.5, 2.0 x 40mm lbs. 2.5 x 50mm, 3.5 x 60mm .55 Phillips: 00 x 40mm 0 x 50mm, 1 x 60mm www.wihatools.com 11 Wiha Pico Soft Grip Screw Holding Wiha Pico Soft Grip Screwdriver, With Precision Soft PicoFinish Handle 267 Blade high alloy chrome-vanadium-molybdenum tool steel, hardened, hard chrome finish. Item No. Size mm Inch mm Inch pkg. 26732 T1 40 1.6 134 5.3 10 26733 T2 40 1.6 134 5.3 10 26735 T3 40 1.6 134 5.3 10 26736 T4 40 1.6 134 5.3 10 26737 T5 40 1.6 134 5.3 10 26739 T6 40 1.6 140 5.5 10 26741 T7 40 1.6 140 5.5 10 26743 T8 40 1.6 140 5.5 10 26745 T9 50 2.0 150 5.9 10 26747 T10 50 2.0 150 5.9 10 26749 T15 60 2.4 160 6.3 10 26751 T20 60 2.4 160 6.3 10 *Metric dimensions actual - Inch dimensions approximate Screwdriver, With 267 MagicSpring Screw Holding Wiha-Precision Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. Molded on ergonomic Wiha-PicoFinish precision handle, molded on, soft grips. Item No. Size mm Inch mm Inch lbs. pkg. 26721 T6 40 1.6 140 5.5 .03 10 26723 T7 40 1.6 140 5.5 .03 10 26725 T8 40 1.6 140 5.5 .03 10 26727 T9 50 2.0 150 5.9 .04 10 26729 T10 50 2.0 150 5.9 .04 10 26731 T15 60 2.4 160 6.3 .04 10 *Metric dimensions actual - Inch dimensions approximate 26798 6 Pc. MagicSpring Screw Holding Screwdriver Set, With Wiha-Precision Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. Molded on ergonomic Wiha-PicoFinish precision handle, molded on, soft grips. In storage pouch 26793 8 Pc. Precision Driver Set, With Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. ChromTop finish on tip for a perfect fit. In storage pouch Item No. 26793 : T1, T2, T3, T4, lbs. T5, T6, T7, T8 x 40mm .50 Item No. 26798 MagicSpring : T6, T7, T8 x 40mm T9, T10, T15 x 50mm lbs. .45 Pico Soft Grip Precision Chip Lifter 26815 Soft PicoFinish Precision Chip Lifter Blade chrome-vanadium-molybdenum steel, hardened, hard chromed. Item No. 26815 26796 8 Pc. Precision Driver Set, Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. ChromTop finish on tip for a perfect fit. In storage pouch Item No. 26796 : T5, T6, T7, T8 x 40mm lbs. T9, T10 x 50mm, T15, T20 x 60mm .57 mm mm mm mm Inch lbs pkg. 1 3.5 50 150 5.9 .03 1 Standard Soft PicoFinish handle 91118 Rugged Polyester Canvas Storage Pouch Holds 8 Precision Tools up to 170mm in length. Folding pouch. Has security flaps and velcro closer. Item No. Size lbs. pkg. 91118 14 1/2” W x 7 3/4” L .13 1 12 Toll Free: (800) 494-6104 Pico Soft Grip Hex Inch & Metric Pico Soft Grip Ball End Inch & Metric 263 Hex Inch Screwdriver, With Precision Soft PicoFinish Handle Blade high alloy CVM tool steel, hardened, hard chrome finish. Item No. Inch mm Inch mm Inch pkg. 26341 .028(.71) 40 1.6 134 5.3 10 26343 .035(.89) 40 1.6 134 5.3 10 26345 .050(1.27) 40 1.6 134 5.3 10 26349 5/64(2.0) 50 2.0 150 5.9 10 26363 1/16 50 2.0 144 5.7 10 26367 3/32 60 2.4 160 6.3 10 26369 7/64 60 2.4 160 6.3 10 26371 1/8 60 2.4 160 6.3 10 *Metric dimensions actual - Inch dimensions approximate In storage pouch 26392 8 Piece Hex Inch Precision Driver Set, Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. Item No. 26392 Hex Inch: .028, .035, .050 x 1.6” lbs. 5/64, 1/16 x 2.0”, 3/32, 7/64, 1/8 x 2.4” .24 263 Hex Metric Driver, With Precision Soft PicoFinish Handle Blade high alloy CVM tool steel, hardened, hard chrome finish. Item No. mm mm Inch mm Inch pkg. 26341 .71(.028) 40 1.6 134 5.3 10 26343 .89(.035) 40 1.6 134 5.3 10 26345 1.27(.050) 40 1.6 134 5.3 10 26347 1.5 50 2.0 144 5.7 10 26349 2.0(5/64) 50 2.0 150 5.9 10 26351 2.5 60 2.4 160 6.3 10 26353 3.0 60 2.4 160 6.3 10 *Metric dimensions actual - Inch dimensions approximate In storage pouch 7 Piece Hex Metric Precision Driver Set, Soft PicoFinish 26393 Handle Blade high alloy CVM steel, hardened, hard chromed. Item No. 26393 Hex Metric: .71, .89, 1.27 x 40mm lbs. 1.5, 2.0 x 50mm, 2.5, 3.0 x 60mm .22 264 Ball End Hex Inch Screwdriver, With Precision Soft PicoFinish Handle Blade high alloy chrome-vanadium-molybdenum tool steel, hardened, hard chrome finish. Item No. Inch Inch mm Inch mm pkg. 26455 1/16 2.0 50 5.9 150 10 26457 5/64 2.0 50 5.9 150 10 26459 3/32 2.0 50 5.9 150 10 26461 7/64 2.4 60 6.3 160 10 26463 1/8 2.4 60 6.3 160 10 26465 9/64 2.4 60 6.3 160 10 26467 5/32 2.4 60 6.3 160 10 *Metric dimensions actual - Inch dimensions approximate 7 Piece Inch Ball End Hex Precision Driver Set, With 26493 Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. ChromTop finish on tip for a perfect fit. In storage pouch Item No. 26493 Ball End Hex Inch: lbs. 1/16, 5/64, 3/32 x 2.0” .27 7/64, 1/8, 9/64, 5/32 x 2.4” 264 Ball End Hex Metric Screwdriver, With Precision Soft PicoFinish Handle. Blade high alloy chrome-vanadium-molybdenum tool steel, hardened, hard chrome finish. Item No. mm mm Inch mm Inch pkg. 26441 1.27 40 1.6 134 5.3 10 26443 1.5 50 2.0 150 5.9 10 26445 2.0 50 2.0 150 5.9 10 26447 2.5 60 2.4 160 6.3 10 26449 3.0 60 2.4 160 6.3 10 *Metric dimensions actual - Inch dimensions approximate www.wihatools.com 13 Pico Soft Grip Nut Drivers Inch & Metric Inch Nut Drivers, With Precision Soft PicoFinish Handle 265 Blade high alloy chrome-vanadium-molybdenum tool steel, hardened, hard chrome finish. Item No. Inch Inch mm Inch mm pkg. 26571 3/32 2.4 60 6.3 160 10 26572 7/64 2.4 60 6.3 160 10 26573 1/8 2.4 60 6.3 160 10 26574 9/64 2.4 60 6.3 160 10 26575 5/32 2.4 60 6.3 160 10 26576 3/16 2.4 60 6.3 160 10 26577 7/32 2.4 60 6.3 160 10 26578 1/4 2.4 60 6.3 160 10 *Metric dimensions actual - Inch dimensions approximate 8 Piece Inch Nut Driver Set, With Precision Soft 26593 PicoFinish Handle Blade high alloy CVM tool steel, hardened, hard chrome finish. Chrom-Top finish on tip for a perfect fit. In storage pouch Item No. 26593 Inch Nut Drivers: 3/32, 7/64, 1/8, lbs. 9/64, 5/32, 3/16, 7/32, 1/4” x 2.4” .72 265 Metric Nut Drivers, With Precision PicoFinish Handle Blade high alloy chrome-vanadium-molybdenum tool steel, hardened, hard chrome finish. Item No. mm mm Inch mm Inch pkg. 26579 1.5 60 2.4 160 6.3 10 26581 2.0 60 2.4 160 6.3 10 26582 2.5 60 2.4 160 6.3 10 26583 3.0 60 2.4 160 6.3 10 26584 3.5 60 2.4 160 6.3 10 26585 4.0 60 2.4 160 6.3 10 26586 4.5 60 2.4 160 6.3 10 26587 5.0 60 2.4 160 6.3 10 26588 5.5 60 2.4 160 6.3 10 26589 6.0 60 2.4 160 6.3 10 *Metric dimensions actual - Inch dimensions approximate 8 Piece Metric Nut Driver Set, With Precision Soft 26596 PicoFinish Handle Blade high alloy CVM tool steel, hardened, hard chrome finish. Chrom-Top finish on tip for a perfect fit. In storage pouch Item No. 26596 Metric Nut Drivers: lbs. 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5 x 60mm .66 Wiha Magnetizer/Demagnetizer Magnetize or Demagnetize tools and small parts instantly Shatterproof Box is made from high quality plastic Uses 2 C8 industrial permanent magnets (+) to Magnetize (-) to Demagnetize 91118 Rugged Polyester Canvas Storage Pouch Holds 8 Precision Tools up to 170mm in length. Folding pouch. Has security flaps and velcro closer. Item No. Size lbs. pkg. 91118 14 1/2” W x 7 3/4” L .13 1 40010 Magnetizer and Demagnetizer To magnetize and demagnetize steel screwdriver blades, tweezers and similar tools. Box high quality plastic, shock-resistant, green, cadmium free. Application: To magnetize, lead tool slowly through the (+) opening, to demagnetize guide tool slowly through the (-) opening. Item No. Dimensions lbs. 40010 2.1” x 2.0” x 1.1” .30 (Parts under 1” Length or 1/8” Diameter may not demagnetize) Toll Free: (800) 494-6104 14 Wiha Proturn Precision Screwdrivers n r u t o pr Rotating cap for precise turning and control with fingertip Tapered handle allows rapid rotation Tip precision ground for exact fit Blade CVM steel, black finish blades Molded on ergonomic handle 95190 6 Piece Slotted/Phillips Proturn Precision Screwdriver Set Molded on precision handle. Blade high alloy chrome-vanadiummolybdenum tool steel, black finish. Item No. mm mm Size mm lbs. 95190 Slotted: 1.5mm 40 Phillips: 00 40 .27 2.5mm 50 0 50 3.5mm 60 1 60 62990 precision 62990 5 Piece Slotted & Phillips Pocket Pack Set Wiha Proturn ball retainer handle & 4 Wiha interchangeable blades. Set includes the following blades: Slotted: 1.5, 2.0, 3.0, 4.0 Phillips: #000, #00, #0, #1 lbs. .15 62993 9 Piece Slotted/Phillips/ Work Station Set Wiha Proturn precision ball retainer handle & 8 Wiha interchangeable blades. 62993 Set includes the following blades: Slotted: 1.5, 2.0, 3.0, 4.0 Phillips: #000, #00, #0, #1 : T6, T7, T8, T9, T10, T15, T20 lbs. .64 #62995 65090 9 Piece Slotted/Phillips Proturn Precision Screwdriver Set Molded on precision handle. Blade high alloy chrome-vanadiummolybdenum tool steel, black finish. Item No. mm mm mm mm Size mm 65090 Slotted: 1.5 40 3.0 60 Phillips: 00 40 2.0 50 3.5 60 0 50 2.5 60 4.0 60 1 60 96800 Proturn Precision Chip Lifter Molded on precision handle. Blade chrome-vanadium-molybdenum tool steel, hardened, black finish. Item No. Size mm mm Inch lbs. pkg. 96800 1.0 50 145 5.7 .07 1 #62994 62995 22 Piece Slotted/Phillips/ /Ball End Hex Inch & Metric Tech Pack Wiha Proturn precision ball retainer handle & 21 Wiha interchangeable blades. Set in canvas storage pouch 62995 Set includes the following blades: Slotted: 1.5, 2.0, 3.0, 4.0 Phillips: #000, #00, #0, #1 : T6, T7, T8, T9, T10, T15, T20 Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Hex Metric: 1.5, 2.0, 2.5, 3.0, 4.0mm lbs. .87 62994 14 Piece Inch/Metric Ball End Hex Work Tech Pack Proturn precision ball retainer handle & 13 Wiha interchangeable blades. 62994 Set includes the following blades: Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Hex Metric: 1.5, 2.0, 2.5, 3.0, 4.0mm lbs. .66 Set in canvas storage pouch www.wihatools.com 15 Wiha SYSTEM 4 Precision Handles and Blades Rotating Cap for precise turning & control Tapered Handle allows rapid rotation, requires less clearance Blades chrome-vanadiummolybdenum steel, hardened, hard chromed. On 4mm Hex shafts Tips Exact fit, precision machined Precision Handle high quality plastic, cadmium free. ESD Safe or Standard styles 28000 ESD Safe Dissipative Precision Handle with rotating control cap. Surface resistant 106-109 Ohms. 4 mm hex retainer for all SYSTEM 4 interchangeable blades. Tapered handle, high quality plastic, impact resistant. Ball retainer hold. 110mm/4.3” OAL Item No. mm Inch mm Inch lbs. 28000 4.0 .1574 14.0 .55 .04 269 SYSTEM 4 Combined Slotted/Phillips Reversible Blade High alloy CVM steel, hardened, hard chromed. Item No. mm Size mm Inch lbs. 26971 1.5 + 000 120 4.7 .05 26972 2.0 + 00 120 4.7 .05 26973 3.0 + 0 120 4.7 .05 26974 4.0 + 1 120 4.7 .06 28001 ESD Safe Dissipative Precision Adjustable Handle with rotating control cap. Advantages: • Use in ESD sensitive applications. Surface resistant 106-109 Ohms. • Collet lock allows for quick & easy adjustment. • Holds blade securely in place. Accepts all SYSTEM 4 blades. 110mm/4.3” OAL Item No. mm Inch mm Inch lbs. 28001 4.0 .1574 14.0 .55 .04 269 SYSTEM 4 Pozidriv® Reversible Blade High alloy CVM steel, hardened, hard chromed. Wiha vapor Chrome-Top finish on tips. Item No. Size Size mm Inch lbs. 26922 0 + 1 120 4.7 .03 15mm Collet Lock Handle adjustable blade length from 15 to 95mm/ .6” to 3.75” 95mm 26900 SYS 4 Standard Precision Handle, with rotating control cap. Accepts all SYSTEM 4 interchangeable blades. Wiha Precision handle, tapered, impact resistant. Ball retainer hold. 110mm/4.3” OAL Item No. mm Inch mm Inch lbs. 26900 4.0 .1574 14.0 .55 .04 26901 SYSTEM 4 Standard Precision Adjustable handle with rotating control cap. Advantages: • Allows adjustable blade from 15 to 95mm. • Collet lock allows for quick & easy adjustment. • Holds blade securely in place. Accepts all SYSTEM 4 blades. 110mm/4.3” OAL Item No. mm Inch mm Inch lbs. 26901 4.0 .1574 14.0 .55 .06 269 SYSTEM 4 Slotted Reversible Blade High alloy CVM steel, hardened, hard chromed. Wiha vapor Chrome-Top finish on tips. Item No. mm mm mm Inch lbs. 26903 1.5 + 3.0 120 4.7 .05 26904 2.0 + 3.5 120 4.7 .05 26905 2.5 + 4.0 120 4.7 .06 Reversible Blade 269 SYS 4 High alloy CVM steel, hardened, vapor chrome protected, Wiha vapor Chrome-Top finish on tips. 120mm/4.7” OAL. Item No. Size Size lbs. 26951 T6 + T8 .03 26952 T7 + T9 .03 26953 T10 + T15 .03 26954 T15 + T20 .03 269 SYSTEM 4 Phillips Reversible Blade High alloy CVM steel, hardened, hard chromed. Wiha vapor Chrome-Top finish on tips. Item No. Size Size mm Inch lbs. 26911 000 + 00 120 4.7 .03 26912 0 + 1 120 4.7 .03 269 SYSTEM 4 Interchangeable Blade High alloy CVM steel, hardened, Wiha vapor Chrome-Top finish on tips. 120mm/4.7” OAL Item No. Size lbs. 26955 T3 .03 26956 T4 .03 26957 T5 .03 16 Toll Free: (800) 494-6104 Wiha SYSTEM 4 Precision Blades For angle entry 269 SYSTEM 4 Inch Hex Sizes, Interchangeable Blade High alloy CVM steel, hardened, corrosion protected. Item No. Inch mm Inch lbs. 26921 .050 120 4.7 .06 26923 1/16 120 4.7 .06 26924 5/64 120 4.7 .06 26925 3/32 120 4.7 .06 26926 7/64 120 4.7 .06 26927 1/8 120 4.7 .06 26928 9/64 120 4.7 .06 26929 5/32 120 4.7 .06 269 SYSTEM 4 Metric Hex Sizes, Interchangeable Blade High alloy CVM steel, hardened, corrosion protected. Item No. mm mm Inch lbs. 26913 .71 120 4.7 .06 26914 .89 120 4.7 .06 26915 1.27 120 4.7 .06 26916 1.5 120 4.7 .06 26917 2.0 120 4.7 .06 26918 2.5 120 4.7 .06 26919 3.0 120 4.7 .06 26920 4.0 120 4.7 .06 280 SYSTEM 4 Inch Ball End Hex Interchangeable Blade High alloy tool steel, hardened, corrosion protected. Ball end works at 30° angle entry for easy access to fasteners. Item No. Inch mm Inch lbs. 28021 .050 120 4.7 .06 28023 1/16 120 4.7 .06 28024 5/64 120 4.7 .06 28025 3/32 120 4.7 .06 28026 7/64 120 4.7 .06 28027 1/8 120 4.7 .06 28028 9/64 120 4.7 .06 28029 5/32 120 4.7 .06 For angle entry 280 SYSTEM 4 Metric Ball End Hex Interchangeable Blade High alloy tool steel, hardened, corrosion protected. Ball end works at 30° angle entry for easy access to fasteners. Item No. mm mm Inch lbs. pkg. 28033 1.5 120 4.7 .06 1 28034 2.0 120 4.7 .06 1 28035 2.5 120 4.7 .06 1 28036 3.0 120 4.7 .06 1 28037 4.0 120 4.7 .06 1 269 SYS 4 Metric Ball End & Standard Hex, Reversible Blade CVM steel, hardened, hard chromed. Wiha vapor Chrome-Top finish on tips. One side hex, other side ballpoint hex. Item No. mm mm mm Inch lbs. 26932 1.27+ 1.27 120 4.7 .05 26933 1.5 + 1.5 120 4.7 .05 26934 2.0 + 2.0 120 4.7 .06 26935 2.5 + 2.5 120 4.7 .06 26936 3.0 + 3.0 120 4.7 .06 26937 4.0 + 4.0 120 4.7 .06 269 SYSTEM 4 Nut Driver Inch, Interchangeable Blade High alloy chromevanadium-molybdenum steel, hardened, corrosion protected. 120mm/4.7” OAL Item No. Inch Inch Inch lbs. 26962 3/32 .16 .16 .04 26963 7/64 .20 .20 .04 26964 1/8 .20 .20 .04 26965 9/64 .21 .24 .04 26966 5/32 .22 .24 .04 26967 3/16 .26 .28 .04 26968 7/32 .30 .32 .04 26969 1/4 1.34 .36 .04 269 SYSTEM 4 Nut Driver Metric, Interchangeable Blade High alloy chromevanadium-molybdenum steel, hardened, corrosion protected. 120mm/4.7” OAL Item No. mm mm Inch Inch lbs. 26940 1.5 + 1.8 .12 .12 .03 26941 2.0 + 2.5 .16 .16 .03 26938 1.5 - .11 .11 .04 26939 1.8 - .12 .12 .04 26949 2.0 - .13 .13 .06 26950 2.5 - .16 .16 .06 26942 3.0 - .20 .20 .06 26943 3.2 - .20 .20 .06 26944 3.5 - .22 .24 .06 26945 4.0 - .22 .24 .06 26946 4.5 - .25 .28 .06 26947 5.0 - .27 .28 .06 26948 5.5 - .30 .32 .06 www.wihatools.com 17 Wiha SYSTEM 4 Drive-Loc Precision Locking Tools 280 SYSTEM 4 Pozidriv® Drive-Loc Reversible Locking Blades On 4mm Hex blades Item No. Size Size lbs. 28002 0 + 1 .02 D 26961 ESD Safe Dissipative Precision Drive-Loc Handle Surface resistant 106-109 Ohms. 4 mm hex retainer for all SYSTEM 4 interchangeable blades. Ball retainer hold. 105mm/4.13” OAL Item No. mm Inch mm Inch lbs. 26961 4.0 .1574 23 .91 .08 269 SYSTEM 4 Slotted Drive-Loc Reversible Locking Blades On 4mm Hex blades Item No. mm mm lbs. 26958 1.5 + 3.0 .02 26959 2.0 + 3.5 .02 26960 2.5 + 4.0 .02 269 SYSTEM 4 Phillips On 4mm Hex blades Item No. Size 26975 000 + 26976 0 + Drive-Loc Reversible Locking Blades 269 SYSTEM 4 On 4mm Hex blades Item No. Size 26977 T1 + 26978 T3 + 26979 T5 + 26980 T6 + 26981 T7 + 26982 T10 + Drive-Loc Reversible Locking Blades Size 00 1 Size T2 T4 T6 T8 T9 T15 lbs. .02 .02 lbs. .02 .02 .02 .02 .02 .02 280 SYSTEM 4 Metric Hex Drive-Loc Reversible Locking Blades On 4mm Hex blades Item No. mm mm lbs. 28003 1.3 + 1.3 .02 28004 1.5 + 1.5 .02 28005 2.0 + 2.0 .02 28006 2.5 + 2.5 .02 28007 3.0 + 3.0 .02 28008 4.0 + 4.0 .02 280 SYSTEM 4 Metric Nut Drivers Drive-Loc Reversible Locking Blades On 4mm Hex blades Item No. mm mm lbs. 28009 1.5 + 1.8 .02 28010 2.0 + 2.5 .02 28011 3.0 + 3.0 .02 28012 3.2 + 3.2 .02 28013 3.5 + 3.5 .02 28014 4.0 + 4.0 .02 28015 4.5 + 4.5 .02 28016 5.0 + 5.0 .02 28017 5.5 + 5.5 .02 26985 12 Piece SYSTEM 4 Precision ESD Drive-Loc Set In storage pouch Item No. 26985 ESD Safe Drive-Loc Handle Slotted: 1.5x3.0, 2.0x3.5, 2.5x4.0 lbs. .44 Phillips: 000x00, 0x1 : T1xT2, T3xT4, T5xT6, T6xT8, T7xT9, T10xT15 Toll Free: (800) 494-6104 18 Wiha Canvas Pouch Sets Canvas Pou ch D 26990 4 Piece Slotted & Phillips Precision Interchangeable Blade Set Wiha ESD Safe precision collet lock handle and 3 Wiha interchangeable blades. 26990 Set includes the following blades: Slotted: 2.0, 3.0, 4.0mm Phillips: 00, 0, 1 lbs. .17 Canvas Pou ch D 26991 6 Piece Slotted & Phillips Precision Interchangeable Blade Set Wiha ESD Safe precision collet lock handle and 5 Wiha interchangeable blades. In canvas pouch. 26991 Set includes the following blades: Slotted: 1.5, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: 000, 00, 0, 1 lbs. .29 D 28080 22 Piece Slotted, Phillips, & Hex Precision Interchangeable Blade Set Wiha ESD Safe precision collet lock handle and 20 Wiha interchangeable blades. 28080 Set includes the following blades: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex: .028, .035 Ball Hex: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Proturn Chip Lifter - #96800 lbs. .33 Canvas P ouch ESD Technicians Kit Precision Screwdrivers & Tweezers D D 26992 17 Pc. Slotted, Phillips and Ball End Canv as Pouch Hex Metric/Inch Precision Interchangeable Blade Set Wiha ESD Safe precision collet lock handle and 15 Wiha interchangeable blades. 26992 Set include the following blades: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 Ball End Hex Inch: .050,1/16, 5/64, 7/64, 3/32,1/8” Ball End Hex Metric: 1.5, 2.0, 2.5, 3.0, 4.0mm Proturn Chip Lifter - #96800 lbs. .63 Slotted, Phillips, 44590 12 Pc. Slotted, Phillips and Precision Interchangeable Blade Set Wiha ESD Safe precision collet lock handle, 7 Wiha interchangeable blades & 4 ESD Safe Tweezers. 44590 Set includes the following blades: Slotted: 2.0, 3.0, 4.0mm Phillips: 00, 0, 1 : T6, T7, T8, T9, T10, T15 ESD Safe Precision Tweezers: 44501 Fine Point - AA SA 44509 Extra Fine Point - 5 SA 44505 Flat and Blunt - 2a SA 44510 Curved Fine Point - 7a SA lbs. .60 Slotted & Phillips Set In Steel Box Set In Steel Box D 28094 11 Piece Slotted, Phillips & Precision Interchangeable Blade Set Wiha ESD Safe precision collet lock handle and 10 Wiha interchangeable blades. 28094 Set includes the following blades: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 lbs. 1.51 Canvas P ouch D 26993 6 Piece Slotted & Phillips Precision Interchangeable Blade Set Wiha ESD Safe precision collet lock handle and 5 Wiha interchangeable blades. 26993 Set includes the following blades: Slotted: 1.5, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: 000, 00, 0, 1 lbs. .87 www.wihatools.com 19 ESD Anti-Static Vinyl Pouch Set D ESD Safe D 28091 6 Piece Slotted & Phillips Precision Interchangeable Blade Set Wiha-ESD Safe precision collet lock handle and 5 Wiha interchangeable blades. 28091 Set includes the following blades: Slotted: 1.5, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: 000, 00, 0, 1 lbs. .25 D ESD Safe D 28097 9 Piece Slotted, Phillips and Precision Interchangeable Blade Set Wiha ESD Safe precision collet lock handle and 8 Wiha Interchangeable blades. 28097 Set includes the following blades: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 : T5, T6, T7, T8, T9, T10, T15 lbs. .33 D 28084 13 Piece Slotted, Phillips and Ball End Hex Inch Precision Interchangeable Blade Set Wiha ESD Safe precision collet lock handle and 12 Wiha interchangeable blades. 28084 Set includes the following blades: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 Ball End Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” lbs. .44 26996 5 Piece Slotted & Phillips Precision Interchangeable Blade Set Wiha ESD Safe precision collet lock handle and 4 Wiha interchangeable blades. 26996 Phillips: 000, 00, 0, 1 Slotted: 1.5, 2.0, 3.0, 3.5mm lbs. .54 ESD Safe 26997 9 Pc. Slotted, Phillips and Precision Interchangeable Blade Set Wiha ESD Safe precision collet lock handle and 8 Wiha Interchangeable blades. 26997 Phillips: 000, 00, 0, 1 Slotted: 1.5, 2.0, 2.5, 3.0, 3.5, 4.0mm : T6, T7, T8, T9, T10, T15 lbs. .64 D 26999 9 Piece Hex Metric Precision Blade Set Wiha ESD Safe precision collet lock handle and 8 Wiha interchangeable blades. 26999 Hex Metric: .71, .89, 1.27, 1.5, 2.0, 2.5, 3.0, 4.0mm lbs. .66 D 26989 9 Piece Hex Inch Precision Blade Set Wiha ESD Safe precision collet lock handle and 8 Wiha interchangeable blades. 26989 Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” lbs. .64 D 26995 D 28087 8 Piece Precision Interchangeable Blade Set Wiha-ESD Safe precision collet lock handle and 7 Wiha interchangeable blades. 28087 Set includes the following blades: Sizes on standard blades: T3, T4, T5 Sizes on reversible blades: T6, T7, T8, T9, T10, T15, T20 lbs. .29 ESD Safe 5 Piece Precision Blade Set Wiha ESD Safe precision collet lock handle and 4 interchangeable blades. 26995 : T6, T7, T8, T9, T10, T15, T20 lbs. .52 D 26987 8 Piece Precision Blade Set Wiha ESD Safe precision collet lock handle and 7 interchangeable blades. 26987 Set includes the following blades: standard blades: T3, T4, T5 reversible blades: T6, T7, T8, T9, T10, T15, T20 lbs. .62 Toll Free: (800) 494-6104 20 Wiha SYSTEM 4 Micro Bits SYSTEM 4 Handles & Micro Bits Tips Exact fit, precision machined Rotating Cap for precise turning and control Bits CVM steel, hardened Tapered Handle allows rapid rotation, requires less clearance Use bits directly in handle or with 4” bit extension 75800 SYSTEM 4 Standard Precision Bit Handle Rotating control cap for precise turning and control. Wiha Precision handle, tapered, high quality plastic, impact resistant, ball retainer. Accepts all SYSTEM 4 Series bits. 110mm/4.3” OAL Item No. mm Inch mm Inch lbs. 75800 4.0 .1574 14.0 .55 .06 750 SYSTEM 4 Slotted Micro Bits High alloy CVM steel, hardened, on 4 mm hex stock. Item No. mm mm Inch lbs. 75008 0.8 28 1.1 .01 75012 1.2 28 1.1 .01 75015 1.5 28 1.1 .01 75018 1.8 28 1.1 .01 75020 2.0 28 1.1 .01 75025 2.5 28 1.1 .01 75030 3.0 28 1.1 .01 75035 3.5 28 1.1 .01 75040 4.0 28 1.1 .01 751 SYSTEM 4 Phillips Micro Bits High alloy chrome-vanadiummolybdenum steel, hardened, on 4 mm hex stock. Item No. Size mm Inch lbs. 75105 000 28 1.1 .01 75110 00 28 1.1 .01 75115 0 28 1.1 .01 75120 1 28 1.1 .01 D Dissipative Precision Bit Handle 75801 SYSTEM 4 ESD Safe with rotating control cap. Wiha precision handle, tapered, high quality plastic, impact resistant. 110mm/4.3” OAL Advantages: • For working in ESD sensitive applications Surface resistant 106-109 Ohms • Ball retainer holds bits securely in place • Accepts all SYSTEM 4 Series bits Item No. mm Inch mm Inch lbs. 75801 4.0 .1574 14.0 .55 .06 SYSTEM 4 Micro Bit Extension Blades 75900 Extension Blade For SYSTEM 4 Micro Bits Shaft CVM steel, hardened, corrosion protected. Ball retainer bit extension for 4mm bits. Item No. Size mm mm lbs. 75900 4.0 100 4.0 .07 75901 Magnetic Bit Extension Blade For SYSTEM 4 Micro Bits Shaft Chrome-vanadium-molybdenum steel, hardened, corrosion protected. Magnetic bit holder. Item No. Size mm mm lbs. 75901 4.0 100 4.0 .04 753 SYSTEM 4 Hex Metric Micro Bits High alloy CVM steel, hardened, on 4 mm hex stock. Item No. mm mm Inch lbs. 75307 .71 28 1.1 .01 75309 .89 28 1.1 .01 75313 1.27 28 1.1 .01 75315 1.5 28 1.1 .01 75320 2.0 28 1.1 .01 75325 2.5 28 1.1 .01 75330 3.0 28 1.1 .01 75340 4.0 28 1.1 .01 753 SYSTEM 4 Hex Inch Micro Bits High alloy chromevanadium-molybdenum steel, hardened, on 4 mm hex stock. Item No. Inch mm Inch lbs. 75307 .028 28 1.1 .01 75309 .035 28 1.1 .01 75313 .050 28 1.1 .01 75350 1/16 28 1.1 .01 75352 5/64 28 1.1 .01 75354 3/32 28 1.1 .01 75356 7/64 28 1.1 .01 75358 1/8 28 1.1 .01 75360 9/64 28 1.1 .01 75340 5/32 28 1.1 .01 www.wihatools.com 21 Wiha SYSTEM 4 Micro Bits Proturn Precision Power Driver Bit Set Micro Bits 757 SYSTEM 4 High alloy CVM steel, hardened, on 4 mm stock. Item No. Size mm Inch lbs. 75703 T3 28 1.1 .01 75704 T4 28 1.1 .01 75705 T5 28 1.1 .01 75706 T6 28 1.1 .01 75707 T7 28 1.1 .01 75708 T8 28 1.1 .01 75709 T9 28 1.1 .01 75710 T10 28 1.1 .01 75715 T15 28 1.1 .01 75720 T20 28 1.1 .01 757 SYSTEM 4 Security Micro Bits High alloy CVM steel, hardened, on 4 mm stock. Item No. Size mm Inch lbs. 75727 T7s 28 1.1 .01 75728 T8s 28 1.1 .01 75729 T9s 28 1.1 .01 75735 T10s 28 1.1 .01 75739 T15s 28 1.1 .01 75742 T20s 28 1.1 .01 753 SYSTEM 4 Metric Security Hex Micro Bits High alloy CVM steel, hardened, on 4 mm hex stock. Item No. mm mm Inch lbs. 75322 2.0 28 1.1 .01 75327 2.5 28 1.1 .01 75332 3.0 28 1.1 .01 75342 4.0 28 1.1 .01 753 SYSTEM 4 Security Hex Inch Micro Bits Item No. Inch mm Inch lbs. 75362 5/64 28 1.1 .01 75364 3/32 28 1.1 .01 75366 7/64 28 1.1 .01 75368 1/8 28 1.1 .01 75370 9/64 28 1.1 .01 75372 5/32 28 1.1 .01 Micro Bit 1/4” Drive Power Tool Adapter 75902 Micro Bit 1/4” Drive Power Tool Adapter Shaft CVM steel, hardened, corrosion protected. For 4mm bits. 2.3” OAL Item No. Size mm mm lbs. 75902 4.0 60 4.0 .07 75989 SYSTEM 4 Proturn Precision Power Screwdriver Set W/Micro Bits, 40 Pcs. In Storage Box. Includes Wiha precision handle, Proturn Power Screwdriver & 38 interchangeable Micro bits. Item SYSTEM 4 No. Combination Bit Set 75989 Set with System 4 Standard Precision Handle Set includes the following bits: Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex Metric: 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” lbs. 1.18 SYSTEM 4 Interchangeable Bit Set 75990 SYSTEM 4 Interchangeable Bit Set, 40 Pcs. In Canvas Pouch. Includes Wiha precision handle, bit extension & 38 interchangeable bits. Item SYSTEM 4 No. Combination Bit Set 75990 Set with ESD Safe Precision Handle Set includes the following bits: Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex Metric: 1.27, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .028(.7), .035(.9), .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 100mm Bit Extension lbs. .65 D 40 Pc . Set 22 Toll Free: (800) 494-6104 Wiha SYS 4 Micro Bits & Compact Bit Sets 75999 SYSTEM 4 Slotted, Phillips, Hex Inch & Metric Precision Interchangeable Bit Set, 26 Pcs. In Compact Fold Out Box. Wiha precision handle, bit extension & 24 interchangeable bits. Item No. Combination Bit Set 75999 Set with Standard Precision Handle Set includes the following bits: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 Hex Metric: .71, .89, 1.27, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 100mm Bit Extension lbs. .64 75395 SYSTEM 4 Hex Inch & Metric Precision Interchangeable Bit Set, 18 Pcs. In Compact Fold Out Box. Wiha precision handle, bit extension and 16 Wiha interchangeable bits. Item No. Combination Bit Set 75395 Set with Standard Precision Handle Includes the following bits: Hex Metric: .71, .89, 1.27, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 100mm Bit Extension lbs. .58 Precision 75792 SYSTEM 4 Interchangeable Bit Set, 11 Pcs. In Compact Fold Out Box. Sets includes Wiha precision handle, bit extension and 9 Wiha interchangeable bits. Item SYSTEM 4 Bit Set No. Set with ESD Safe Precision Handle 75792 and the following bits: : T3, T4, T5, T6, T7, T8, T9, T10, T15 100mm Bit Extension lbs. .54 11 Pc. Set 26 Pc. Set 18 P c. Se 75996 SYSTEM 4 Interchangeable Bit Set, 40 Pcs. In Storage Box. Includes Wiha precision handle, bit extension & 38 interchangeable bits. Item SYSTEM 4 No. Combination Bit Set 75996 Set with ESD Safe Precision Handle Set includes the following bits: Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex Metric: 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm 40 P Hex Inch: .028, .035, .050, c. 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 100mm Bit Extension lbs. 1.04 D t Set 759 sets SYSTEM  4 Slotted/Phillips/Hex Inch/ Precision Interchangeable Bit Set, 27 Pcs. In Compact Fold Out Box. Sets include your choice of Wiha precision handle, bit extension and 25 Wiha interchangeable bits. Item Handle Options for SYSTEM 4 No. Combination Bit Sets 75991 Set with Standard Precision Handle 75992 Set with ESD Safe Precision Handle Sets include the following bits: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 100mm Bit Extension lbs. .64 75994 SYSTEM 4 Slotted/Phillips/Hex Metric/ Precision Interchangeable Bit Set, 27 Pcs. In Compact Fold Out Box. Set includes Wiha precision handle, bit extension and 25 Wiha interchangeable bits. Item SYSTEM 4 No. Combination Bit Set 75994 Set with ESD Safe Precision Handle Set includes the following bits: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex Metric: .71, .89, 1.27, 1.5, 2.0, 2.5, 3.0, 4.0mm 100mm Bit Extension lbs. .64 27 P c. Se 27 Pc t . Set www.wihatools.com 23 Technicians MicroBit Sets • Micro Precision Bits on 4mm Hex Drive • Bits of Exclusive CRM-72 Tool Steel • Handle uses non-magnetic ball retainer • Use bits in extension only • Standard extension adds 4” to length • Non-magnetic bit extension Rotation cap Light weight & compact Handle tapered for precise control Micro Bit Handle Stoarge Sets Micro precision bits on 4mm hex drive Storage handle Surface resistance of handles is 106 - 109 Ohms Bits hardened for extreme durability Bits of exclusive CRM-72 tool steel Compact ESD 75093 SYSTEM 4 Slotted, Phillips, Precision Interchangeable Bit Set, 16 Pcs. Wiha precision handle, bit extension & 14 interchangeable bits. Item No. Combination Bit Set 75093 Set with ESD Safe Precision Handle Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: 00, 0, 1 : T6, T7, T8, T9, T10, T15, T20 100mm Bit Extension lbs. .17 75094 SYSTEM 4 Slotted, Phillips, Hex Inch Compact ESD Precision Interchangeable Bit Set, 16 Pcs. Wiha precision handle, bit extension & 14 interchangeable bits. Item No. Combination Bit Set 75094 Set with ESD Safe Precision Handle Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: 00, 0, 1 Hex Inch: .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8” 100mm Bit Extension lbs. .17 75095 SYSTEM 4 Slotted, Phillips, Hex Metric Compact ESD Precision Interchangeable Bit Set, 16 Pcs. Wiha precision handle, bit extension & 14 interchangeable bits. Item No. Combination Bit Set 75095 Set with ESD Safe Precision Handle Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: 00, 0, 1 Hex Metric: .89, 1.27, 1.5, 2.0, 2.5, 3.0, 4.0mm 100mm Bit Extension lbs. .17 D 75096 SYSTEM 4 Hex Inch & Metric Compact ESD Precision Interchangeable Bit Set, 16 Pcs. Wiha precision handle, bit extension & 14 interchangeable bits. Item No. Combination Bit Set 75096 Set with ESD Safe Precision Handle Hex Inch: 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Hex Metric: .89, 1.27, 1.5, 2.0, 2.5, 3.0, 4.0mm 100mm Bit Extension lbs. .17 Bits hardened for extreme durability 75981 Micro Bit Handle Storage Slotted & Phillips Bit Set, 7 Pcs. Wiha precision storage handle & 6 interchangeable bits. Item No. Set with Precision Storage Handle 75981 Slotted: 1.2, 1.5, 2.0mm Phillips: 000, 00, 0 lbs. .08 75983 Micro Bit Handle Storage Hex Inch Bit Set, 7 Pcs. Wiha precision storage handle & 6 interchangeable bits. Item No. Set with Precision Storage Handle 75983 Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8” lbs. .08 Bit Set, 7 Pcs. 75985 Micro Bit Handle Storage Wiha precision storage handle & 6 interchangeable bits. Item No. Set with Precision Storage Handle 75985 : T3, T4, T5, T6, T7, T8 lbs. .08 Toll Free: (800) 494-6104 24 Wiha Precision Electronic Pliers & Cutters Electronics pliers with cutting edges are designed especially for cutting soft to medium hard wires. The Comfortable Precision Pliers & Cutters C70 tool steel HR60 hardness Velvet soft ergonomically designed multi component handle Glare free black finish Lay-on, riveted precision joint Precision ground cutting edges for smooth cuts Light weight design for maximum user comfort in production work Electronic Diagonal Cutters 56818 Precision Electronic Diagonal Cutters, Wide Pointed Head Cutting edge - full flush. With return spring. C70 special tool steel. For an absolutely flush cut of copper wire. #56818 mm 138 Inch 5.5 Cut Capacity 1.3mm/16AWG Pkg. lbs. 5 .22 Full Flush Electronic Diagonal Cutters 56815 Precision Electronic Diagonal Cutters, Wide Pointed Head Cutting edge - semi flush. With return spring. C70 special tool steel. Universal small diagonal cutter for cutting copper wires. Item No. Cut Medium #56815 mm Inch Capacity Hard Wire 138 5.5 2.0mm/12AWG 0.8 Pkg. lbs. 5 .23 Semi Flush Electronic Diagonal Cutters 56825 Precision Electronic Diagonal Cutters, Wide Shape With Wire Holding Spring Wide, Pointed head. Cutting edge - full flush. With return spring & fixture for holding ends of wires that have been cut off. C70 special tool steel. For an absolutely flush cut of copper wire. #56825 Wire Holding Spring mm 138 Inch 5.5 Cut Capacity 1.3mm/16AWG Pkg. 5 lbs. .23 Full Flush Electronic Diagonal Cutters 56812 Precision Electronic Diagonal Cutters, Narrow Shape Extra narrow, short head for working in particularly restricted spaces. Cutting edge - full flush. With return spring. C70 special tool steel. For absolutely flush cutting of copper wires in difficult to access locations. #56812 Full Flush mm 118 Inch 4.5 Cut Capacity 0.8mm/20AWG Pkg. 5 lbs. .19 www.wihatools.com 25 Electronic Diagonal Cutters Wire Holding Spring 56813 Precision Electronic Diagonal Full Flush Cutters With Wire Trapping Spring Extra narrow, short head for working in particularly restricted spaces. Cutting edge - full flush. With return spring. C70 special tool steel. For absolutely flush cutting of copper wires in difficult to access locations. Full Flush Electronic Oblique 48O Cutter #56813 mm 128 Inch 5.0 Cut Capacity 1.0mm/18AWG Pkg. 5 lbs. .19 56833 Electronic Oblique 48O Cutter Wide pointed head. Cutting edge - full flush. With cutting edge at 48O for cutting obliquely from above or from the side. C70 special tool steel. For absolutely flush cutting of copper wires in difficult to access locations. #56833 mm 138 Inch 5.5 Cut Capacity 1.3mm/16AWG Pkg. lbs. 5 .22 Full Flush Narrow Front Cutter/Long Nose Pliers Full Flush Electronic Pointed Pliers 56830 Electronic Narrow 30O Front Cutter / Long Nose Pliers Extremely narrow, short head for working in particularly restricted spaces. Cutting edge - full flush. Edge at 30O to face end of pliers for cutting obliquely from above or form the side. C70 special tool steel. For absolutely flush cutting of copper wires in difficult to access locations. #56830 Inch 4.5 Cut Capacity 0.6mm/22AWG Pkg. lbs. 5 .19 56801 Electronic Short Nose Precision Pliers Narrow, short head. Smooth jaws. Width at tip is only 1.2mm. C70 special tool steel. For holding small components as well as for holding and angling wires. #56801 Electronic Stripping Pliers mm 118 mm Inch 138 5.5 Pkg. lbs. 5 .23 56871 Electronic Stripping Pliers Wide long head with ridged gripping surface, shears blade and firm wire stripping stations. With opening spring and locking mechanism. Wire stripping stations 0.81 / 1.0 / 1.3 / 1.6 / 2.0 / 2.59mm, AWG 20 / 18 / 16 / 14 / 12 / 10. #56871 mm Inch Ø 180 7.0 0.81-2.59 AWG Pkg. lbs. 20-10 5 .15 26 D Toll Free: (800) 494-6104 Professional Quality ESD Tweezers ESD SAFE • STATIC DISSIPATIVE • HYPO ALLERGENIC COATED • TEXTURED GRIPPING SURFACE Universal Fine Point Tweezers Item No. Description wt. 44501 AA SA ESD - 130mm .09 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Sturdy Long, Fine Round Points Item No. Description wt. 44502 GG SA ESD - 130mm .09 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Long Narrow Body Low Force Item No. Description wt. 44503 SS SA ESD - 135mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Reduced Body To Medium Point Item No. Description wt. 44504 2 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Flat Round Tip Smooth Sides Item No. Description wt. 44505 2a SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Fine Round Points For Assembly Item No. Description wt. 44506 3 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Fine Round Points Shorter Item No. Description wt. 44507 3c SA ESD - 110mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Very Fine Points/Tapered To Tip Item No. Description wt. 44508 4 SA ESD - 110mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Extra Fine Points/Tapered To Tip Item No. Description wt. 44509 5 SA ESD - 110mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Curved Extra Fine Rounded Tips Item No. Description wt. 44510 7a SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. www.wihatools.com 27 Wiha Professional Quality ESD Safe Tweezers Holds 0.8 to 2mm Diameter Item No. Description wt. 44511 50 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Holds 1.5 to 3mm Diameter Item No. Description wt. 44512 51 SA ESD - 130mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Holds 3.5 to 7mm Diameter Item No. Description wt. 44513 52 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Holds 6.5 to 10mm Diameter Item No. Description wt. 44514 53 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Angled 3.5 to 7mm Diameter Item No. Description wt. 44515 54 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Narrow Rounded Tip Serrated, Guide Pin Item No. Description wt. 44518 22 SA ESD - 150mm .10 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Universal Blunt Tip Serrated Item No. Description wt. 44520 40 SA ESD - 145mm .11 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. MicroTip 45O Hook 1x1x2mm Item No. Description wt. 44521 12 SA-SMD ESD - 120mm .09 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. MicroTip For Chips Angled 1.6 x 1 x 1mm Item No. Description wt. 44522 13 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Long Rounded to 1.0mm Wide No Serration Item No. Description wt. 44523 PSF SA ESD - 125mm .09 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Toll Free: (800) 494-6104 28 Wiha Professional Quality ESD Safe Tweezers Flat Bent 35O, 3mm Diameter Grip Item No. Description wt. 44524 58 SA-SMD ESD - 117mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Curved Extra Fine, 3mm Long Straight Tip Item No. Description wt. 44525 7abb SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Narrow Body Low Force Bent 35O - 3mm Tip Item No. Description wt. 44526 SSbb SA ESD - 140mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Angled Extra Fine Points Bent 30O - 3mm Long Tips Item No. Description wt. 44527 5abb SA ESD - 117mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Extra Fine Points Bent 30O - 3mm Long Tips Item No. Description wt. 44528 5bb SA ESD - 107mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. MicroTip Bent 30O 1.6mm Item No. Description wt. 44529 8b SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Flat Bent 35O - 2mm Diameter Grip Radius Item No. Description wt. 44530 59 SA-SMD ESD - 117mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. ESD Safe General Purpose Fine Point Item No. Description wt. 44531 1 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Heavy Duty Strong Tweezers Tapered To Strong Point Item No. Description wt. 44532 00 SA ESD - 120mm .09 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Angled & Slightly Bent With Extra Fine Tips Item No. Description wt. 44533 7 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. www.wihatools.com 29 Professional Quality Tweezers In Standard & Special Sizes Narrow Body Low Force Bent 35O - 3mm Long Tip Blunt Tip, Serrated Item No. Description 43010 40 - 145mm Carbon steel tweezers. Nickel-plated finish. wt. .11 Heavy Duty Forming Tweezers Item No. Description 43800 8 SA - 120mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .09 Curved Extra Fine, 3mm Long Angled Tip Item No. Description 46950 7abb SA - 120mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .07 Fine Points Angled With 40O - Tip Bend Item No. Description 46970 5abb SA - 117mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .07 wt. .10 Extra Fine Points Bent 30O - 3mm Long Tip Item No. Description 46972 5bb SA - 107mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .10 Long Tapered to Fine Tip Serrated Item No. Description 45010 30 - 145mm Carbon steel tweezers. Nickel-plated finish. Item No. Description 46971 SSbb SA - 140mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .07 Fine Hooked & Tapered Tips Item No. Description 46987 6 SA - 120mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 Blunt 1mm Wide Tip Serrated Item No. Description 49185 PSF - 125mm Carbon steel tweezers. Nickel-plated finish. wt. .08 Flat Round Tip Bent 30O Smooth Sides Item No. Description 49368 2ab SA - 120mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 Toll Free: (800) 494-6104 30 Professional Quality Tweezers In Standard & Special Sizes Angled Upward Extra Fine Tips Item No. Description 49375 7 SA - 120mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 Fine Points for Assembly Item No. Description 49383 3 SA - 120mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 Blunt Tips - 1.0mm Wide Serrated Flat Round Tip Smooth Sides Item No. Description 49378 2a SA - 120mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .07 Item No. Description 49385 PSF SA - 125mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .09 Long Narrow Body Low Force Item No. Description 49387 SS SA - 140mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .07 Reduced Body to Medium Point Item No. Description 49381 2 SA - 120mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 Strong, Long Tapered Fine Tips Item No. Description 49388 GG SA - 130mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .09 Flat and Broad Tips 3mm Wide Item No. Description 49382 F SA - 120mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 Flat Round Tip Smooth Sides Item No. Description 49478 2a SA T - 120mm Stainless steel, anti-magnetic and acid resistant. Teflon finish tweezers made from Vommaloy. wt. .08 www.wihatools.com 31 Professional Quality Tweezers In Standard & Special Sizes Longer Narrow Body Low Force Item No. Description 49487 SSL SA - 160mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .10 Very Fine Round Points & Tapered To Tip Item No. Description 49779 4 SA - 110mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 Fine Round Points Shorter Item No. Description 49783 3c SA - 110mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 Very Fine Points Tapered Long Item No. Description 49879 4L SA - 140mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 Professional SMD Tweezers COMPONENT POSITIONING & DESOLDERING TWEEZERS Flat Bent 35O 3mm Dia. Milled Slot Item No. Description 42142 58 SA SMD - 117mm Stainless steel, anti-magnetic and acid resistant. Brushed Finish tweezers made from Vommaloy. wt. .08 Holds 6.5 to 10mm Diameter Item No. Description 42150 53 SA - 120mm Stainless steel, anti-magnetic and acid resistant. Brushed Finish tweezers made from Vommaloy. wt. .08 Vertical Long, Holds 2.5 to 5mm Diameter Item No. Description 43414 64 SA - 145mm Stainless steel, anti-magnetic and acid resistant. Brushed Finish tweezers made from Vommaloy. wt. .10 Bent Long, Holds 3.5 to 7mm Diameter Item No. Description 43419 63 SA - 145mm Stainless steel, anti-magnetic and acid resistant. Brushed Finish tweezers made from Vommaloy. wt. .10 Super Thin Foil Tweezers Blunt, Thin .035”, Very Low Force Item No. Description 49215 112 SA - 100mm Stainless steel, anti-magnetic and acid resistant. Polished finish tweezers made from Vommaloy. wt. .05 Toll Free: (800) 494-6104 32 Professional Quality Wafer Tweezers 16mm Wide With Back Stop Back Stop, Top 2.4 Bottom 7mm Item No. Description 43799 37 SA - 120mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. Item No. Description 44159 49 SA - 125mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 9mm Wide With Back Stop Pins Item No. Description 43948 89 SA - 125mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. 12mm Wide With Back Stop Pins Item No. Description 43949 89a SA - 125mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 Bent Large 20mm Wide, Back Stop Item No. Description 46069 61 SA - 125mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 wt. .08 wt. .11 Long Flat Straight 5mm Wide Item No. Description 49584 39 SA - 125mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 Flat Angled 5mm Wide Angled 4 Pin 12mm Wide Item No. Description 44149 16 SA - 125mm Stainless steel, anti-magnetic and acid resistant. Wafer tweezers made from Vommaloy. wt. .09 Item No. Description 49587 38a SA - 103mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 Cutting Tweezers End Cutting Tweezers Item No. Description 46500 D - 95mm Carbon steel. UnPlated finish. wt. .11 Curved Very Fine Cutting Tweezers Item No. Description 48307 C7 - 115mm Carbon steel made from Vommaloy. Brushed finish. wt. .08 www.wihatools.com 33 Professional Quality Guide Pins Tweezers Fine Tip Straight, Guide Pin, Fine Serrated Item No. Description 42012 17 - 120mm Carbon steel. Nickel-plated finish. wt. .08 Narrow Body, Bent, Long, Guide Pin, Serrated Tweezers Item No. Description 49154 22b S - 155mm Stainless steel. Natural finish. wt. .09 Narrow Body, Straight, Long, Guide Pin, Serrated Tweezers Bent, Long, Guide Pin, Fine Serrated Tweezers Item No. Description 45113 33b - 165mm Carbon steel. Nickel-plated finish. wt. .10 Item No. Description 49159 22 SA - 155mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .10 Universal Straight Guide Pin, Fine Serrated Item No. Description 45212 35 SA - 120mm Stainless steel, anti-magnetic and acid resistant. Brushed Finish tweezers made from Vommaloy. wt. .08 Fine Bent, Guide Pin, Serrated Item No. Description 45213 35B SA - 145mm Stainless steel, anti-magnetic and acid resistant. Brushed Finish tweezers made from Vommaloy. wt. .08 Long Pointed, Angled Tip, Guide Pin & Lock Item No. Description 49150 20S - 150mm Stainless steel. Polished finish. wt. .10 Isolated Tweezers With Dipped Handles Universal Pointed Tip Isolated Item No. Description 48100 AA isol - 130mm Carbon steel. Nickel-plated finish. wt. .10 Narrow Pointed & Straight Isolated Serrated Item No. Description 49158 22 isol - 155mm Carbon steel. Nickel-plated finish. wt. .10 Toll Free: (800) 494-6104 34 Professional Quality Self Closing Tweezers Long Straight Tweezers Item No. Description 43270 R29 S - 160mm Stainless steel, anti-magnetic and acid resistant. Brushed Finish tweezers made from Vommaloy. wt. .11 Long Bent Tweezers Item No. Description 43271 R29b SA - 160mm Stainless steel, anti-magnetic and acid resistant. Brushed Finish tweezers made from Vommaloy. wt. .12 Pointed Self Closing Long Straight Item No. Description 43272 R29 - 160mm Carbon steel. Nickel-plated finish. wt. .11 Long Bent Tweezers Item No. Description 43273 R29b - 160mm Carbon steel. Nickel-plated finish. wt. .12 Reverse 2 Flat Round Tip Smooth Sides Item No. Description 45802 R2a SA - 115mm Stainless steel, anti-magnetic and acid resistant. Brushed Finish tweezers made from Vommaloy. wt. .08 Reverse 3 Fine Round Points For Assembly Item No. Description 45803 R3 SA - 115mm Stainless steel, anti-magnetic and acid resistant. Brushed Finish tweezers made from Vommaloy. wt. .08 Chip Holding Curved Fine Micro Tip Item No. Description 46610 R10 SA SMD - 117mm Stainless steel, anti-magnetic and acid resistant. Brushed Finish tweezers made from Vommaloy. wt. .07 Straight Flat Square End 5mm Wide Item No. Description 48050 R50 SA - 105mm Stainless steel, anti-magnetic and acid resistant. Brushed Finish tweezers made from Vommaloy. wt. .07 Strong With Square Ends Deep Serrated Item No. Description 48075 R30 - 160mm Carbon steel. Nickel-plated finish. wt. .13 www.wihatools.com 35 Microscopy Tweezers MicroTip Straight & 0.5mm Slot Milled MicroTip 30O Bend & 0.5mm Slot Milled Item No. Description 46611 11SA SMD - 117mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. Item No. Description 46615 8SA SMD - 120mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 wt. .08 Uncoated MicroTip Bent 30 - 1.6mm MicroTip 40 Hook 1x1x2mm Long O O Item No. Description 46612 12SA SMD - 120mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 Item No. Description 46616 8b SA SMD - 120mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. MicroTip 40O Hook 1.6x1x1mm Wide Item No. Description 46613 13SA SMD - 120mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 MicroTip 30O Bent & Angled With 0.5 Slot Item No. Description 46619 19 SA SMD - 120mm Stainless steel, anti-magnetic and acid resistant. Brushed finish tweezers made from Vommaloy. wt. .08 wt. .08 Mirrors-Clean Room Quality For Visual Checks and Fault Finding at Inaccessible Locations 26mm 20mm Magnifying, Boilable 40420 - #3 40426 - #6 Inspection Mirror - Stainless 20mm Inspection Mirror - Stainless 26mm Item No. Description 40420 #3 IM - 205mm Item No. Description 40426 #6 IM - 215mm wt. .09 wt. .10 Natural Finish, Stainless Steel 10mm 30mm 22mm 40410 - #0 40430 - #8 40422 - #4 Inspection Mirror - Stainless 10mm Inspection Mirror - Stainless 22mm Inspection Mirror - Stainless 30mm Item No. Description 40410 #0 IM - 185mm Item No. Description 40422 #4 IM -175mm Item No. Description 40430 #8 IM - 215mm wt. .09 Short Stem wt. .10 wt. .10 24mm 14mm 40424 - #5 40414 - #0 Inspection Mirror - Stainless 14mm Item No. Description 40414 #0 IM - 200mm wt. .09 Inspection Mirror - Stainless 24mm Short Stem Item No. Description 40424 #5 IM - 175mm wt. .10 Disposable Inspection Mirrors Item No. Description wt. 40425 5 Pack - Plastic .10 Set includes: White disposable inspection mirror #5 Inspection Mirrors - 24mm x 146mm Toll Free: (800) 494-6104 36 Quality Excavators & Probes 43228 43227 43226 43225 43224 43223 43222 43221 One Piece All Stainless Probes One Piece All Stainless Hooks Sculpting & Scribing HooksClean Room Quality • • • • • Sharp Hooks For Cutting & Marking Surgical Stainless Steel Natural Finish For Work on PCB’s, Modeling All Stainless Single Piece Construction Approx. 5mm Wide Short Tapered & Curved Item No. Description 43236 3230.6-60 Hook - 155mm wt. .10 All Stainless Single Piece Construction-Clean Room Quality Approx. 4mm Wide Squared & Curved Stainless Steel Probe Item No. Description wt. 3220.1-07 Probe - 170mm .08 43221 Stainless steel, polished finish. Stainless Steel Probe Item No. Description wt. 3220.2-06 Probe - 170mm .07 43222 Stainless steel, polished finish. Stainless Steel Probe Item No. Description wt. 3220.5-09 Probe - 170mm .07 43225 Stainless steel, polished finish. Stainless Steel Probe Item No. Description wt. 3220.6-10 Probe - 170mm .07 43226 Stainless steel, polished finish. Item No. Description wt. 43235 3230.5-59 Hook - 155mm .10 One Piece All Stainless Excavators Excavators-Clean Room Quality • • • • Can Be Used as Mini-Spatulas For Work on PCB’s, Modeling Surgical Stainless Steel, Polished Finish Single Piece Construction #43251 Stainless Steel Probe Item No. Description wt. 3220.3-05 Probe - 170mm .07 43223 Stainless steel, polished finish. Stainless Steel Probe Item No. Description wt. 3220.8-02 Probe - 170mm .08 43228 Stainless steel, polished finish. 1mm Excavator Item No. Description 43251 3225.1-39 - 165mm wt. .09 #43252 Probes-Clean Room Quality Stainless Steel Probe Item No. Description wt. 3220.4-16 Probe - 170mm .07 43224 Stainless steel, polished finish. Stainless Steel, For Work on PCB’s, Modeling, Polished Finish 2mm Excavator Item No. Description 43252 3225.2-35 - 165mm wt. .09 For Levering & Removing Components Stainless Steel Straight Probe Item No. Description wt. 3220.9-11 Probe - 170mm .07 43229 #43253 2.5mm Excavator Item No. Description 43253 3225.3-31 - 165mm wt. .10 www.wihatools.com 37 Wiha Ratchet Crimpers Ratchet End Sleeve Crimper 5 die nests side entry crimp Ratchet Crimper Push On Terminals Crimp Profile “F”/”B” 43612 Ratchet End Sleeve Crimper Crimps Insulated & non-insulated end sleeves. 6 crimp positions range AWG 26-18, 18-16, 14, 12, 10, 8. Soft grip non-slip handles. Factory set auto release at end of crimp cycle. 43624 Ratchet Crimper Push On Terminals Crimps Insulated & non-insulated terminals. 4 crimp positions range AWG 22-20, 20-16, 16-14, 12-10. Soft grip non-slip handles. Factory set auto release at end of crimp cycle. Item No. 43612 Item No. 43624 Inch AWG Length Range lbs. Pkg. 220mm/8.6” 26-8 1.18 1 Ratchet Crimper For Standard Connectors Inch AWG Length Range lbs. Pkg. 220mm/8.6” 22-10 1.06 1 Ratchet Crimper For Eye Terminals Self adjusting side entry crimp Crimp Profile 43618 Ratchet Crimper For Standard Connectors Crimps Insulated & non-insulated connectors. 3 crimp positions range AWG 20-16 red, 16-14 blue, 12-10 yellow. Soft grip non-slip handles. Factory set auto release at end of crimp cycle. 43643 Ratchet Crimper For Eye Terminals Crimps Insulated & non-insulated terminals. 4 crimp positions range AWG 26-20, 20-14, 12-10, 8-6. Soft grip non-slip handles. Factory set auto release at end of crimp cycle. Item No. 43618 Item No. 43643 Inch AWG Length Range lbs. Pkg. 220mm/8.6” 20-10 1.06 1 Inch AWG Length Range lbs. Pkg. 220mm/8.6” 26-6 1.02 1 Toll Free: (800) 494-6104 38 Automatic Stripping Tool Interchangeable stripping blade cassettes Cuts & strips up to 10mm2/8 AWG - Strips PVC, THHW, TEFLON insulations Self Adjusting Cut & Strip Tool Ergonomic design with non-slip two component handles Easy/snag free wire removal from tool - jaws stay open after strip 44212 Self Adjusting Cutting & Stripping Tool Easily interchangeable stripping cassettes enables a wide range of insulations from PVC to PTFE. Light weight soft grip handle qualified for high volume production and portable/field usage. Straight Blade Cassette Stripping Range 0.02 - 10.0mm2 #44212 mm Inch AWG Strip Dim. 191 7.5 34 - 8 0.02-10mm2 lbs. .30 Pkg. 1 Cables: Conduit wire, Flex mains cable, Equipment wire, Flat modplug cable etc. 34-8 AWG Replaceable Cassette - Straight Blade Straight Straight Blade Cassette Stripping Range 0.02 - 10.0mm2 #44214 34-8 AWG Replaceable Cassette - 4-16mm2 Radius Blade Stripping Range 4-16mm2 VBC for PTFE 28-12 AWG AWG 34 - 8 Strip Range 0.02-10mm2 lbs. .02 Pkg. 1 44269 Replaceable Cassette, 4-16mm Stripping Range Fine adjustability ensures that thin insulations can be stripped without damage to conductors. At the end of the stripping function, the stripping blades open and remain open during the return phase of the strip cycle facilitating easy/snag free wire removal from the tool. #44269 10-5 AWG Replaceable Cassette - “V” Blade “V” Blade Stripping Range 0.1 - 4mm2 44214 Straight Blade Cassette, PVC Insulations Fine adjustability ensures that thin insulations can be stripped without damage to conductors. At the end of the stripping function, the stripping blades open and remain open during the return phase of the strip cycle facilitating easy/snag free wire removal from the tool. AWG 10 - 5 Strip Range 4-16mm2 lbs. .02 Pkg. 1 44213 Replaceable VBC or PTFE Cassette, “V” Blade Fine adjustability ensures that thin insulations can be stripped without damage to conductors. At the end of the stripping function, the stripping blades open and remain open during the return phase of the strip cycle facilitating easy/snag free wire removal from the tool. #44213 AWG 28 - 12 Strip Range 0.1-4mm2 lbs. .02 Pkg. 1 www.wihatools.com 39 Heavy Duty Adjustable Cable Stripper Circular + Straight Window Strip Circular + Spiral Strip 44217 Jacket Stripper - Heavy Duty Adjustable Professional stripping tool for cables of all insulations types. Positive locking positions for circular, lengthways and spiral strips. Interchangeable cable retention hooks give cable stripping capacity of up to 40mm/1.57 inch diameter. Replacement cutting blades can be stored within the tool. #44217 Cables: Power cable. Multiconductor control, fiber optic and copper trunk cables mm Inch Strip Range Strip Dim. lbs. Pkg. 168 6.6 4.5-40mm2 0-4.5mm .26 1 Replacement Blade Replacement Blade For 44217 Stripper 44218 Interchangeable cable retention hooks give cable stripping capacity of up to 40mm/1.57 inch diameter. Replacement cutting blades can be stored within the tool. #44218 Replacement Blade For lbs. Pkg. 44217 Stripper .01 1 Precision Adjustable Stripping Tool 44220 Precision Adjustable Stripping Tool Professional stripping tool removes the outer cable jacket from signal, telephone, audiovisual, instrumentation and data transmission copper and fiber optic cables up to 11mm/0.43” diameter. The tool features a 9 position indexed blade height adjustment wheel ensuring accurate & repeatable stripping results. Simply squeeze together to open the stripping cavity - insert cable, rotate once and pull off the scrap insulation. Smooth, Lightweight and pocket size. No open blade, replacement blades encased within cassette. Replacement cutting blades can be stored within the tool Replaceable Blade Cables: Multi core cable, Modplug cable. Fiber optic cable etc. Replacement Blade #44220 mm Inch Strip Range Strip Range lbs. Pkg. 90.5 3.6 2.5-11mm .10”/0.43” .06 1 44221 Replacement Blade For 44220 Stripper Stripping capacity of up to 2.5-11mm/0.43” diameter. #44221 Strip Range 2.5-11mm Strip Dim. 11mm/0.43” lbs. Pkg. .01 1 Replacement Blade CATV/Satellite Stripper 44206 CATV/Satellite Stripper Quickly & simply strips RG59 & RG6 coaxial cables for CATV “F” type connectors giving industry standard strip lengths of 6.35mm/.25” for both the braid and the conductor. Patented spring-like action and built-in stop eliminates the need for manual adjustment for different cables. #44206 Strips: RG59 & RG6 CATV coaxial cables mm Inch Strip Length lbs. Pkg. 6.35mm/.25” Braid/Conductor .05 1 83 3.3” Toll Free: (800) 494-6104 40 2 Step A 4 Cable V-blocks Adjustable Screw For Precise Blade Positioning Reversible Cassettes Long Life Blue Cassette Stripping Tool Kit 2 Step Stepped Stripping Depth For Reduced Friction “B” mm “B” Inch “A” B 44237 44238 44239 44240 Blue Red Yellow Orange 6.8 6.0 12.0 9.2 0.27” 0.24” 0.47” 0.36” User adjusted 44227 Blue Cassette Hand-Stripping Tool Kit Accurate & versatile coaxial hand-stripping tool, designed to provide 2 strip steps on chosen cable. Enclosed V-blocks make stripper useful for cables in range of 2.5-7.6mm. Universal tool body accepts all cassettes. High quality steel blade cassettes with razor sharp edges for long, effective use. #44227 mm Inch Strip Range Strip Dim. lbs. Pkg. 90 3.54 1.87-7.6mm 6.8mm .09 1 0.10”-0.30” 0.27” Cables: RG 58/59/62/174/180/188/ 195/316/6/ Belden 8281 2 Step Red Cassette Stripping Tool Kit 2 Step 44222 2 Step Red Cassette Hand-Stripping Tool Kit Accurate & versatile coaxial hand-stripping tool, designed to provide 2 strip steps on chosen cable. Enclosed V-blocks make stripper useful for cables in range of 6.0mm/.24”. Universal tool body accepts all cassettes. High quality steel blade cassettes with razor sharp edges for long, effective use. #44222 mm Inch Strip Range Strip Dim. lbs. Pkg. 90 3.54 1.87-7.6mm 6.0mm .09 1 0.10”-0.30” 0.24” Cables: RG 58/59/62/174/180/188/ 195/316/6/ Belden 8281 2 Step Yellow Cassette Stripping Tool Kit 2 Step 44224 2 Step Yellow Cassette Hand-Stripping Tool Kit Accurate & versatile coaxial hand-stripping tool, designed to provide 2 strip steps on chosen cable. Enclosed V-blocks make stripper useful for cables in range of 12.0mm/.47”. Universal tool body accepts all cassettes. High quality steel blade cassettes with razor sharp edges for long, effective use. #44224 mm Inch Strip Range Strip Dim. lbs. Pkg. 90 3.54 1.87-7.6mm 12.0mm .09 1 0.10”-0.30” 0.47” Cables: RG 58/59/62/174/180/188/ 195/316/6/ Belden 8281 2 Step Replacement Stripping Cassettes Cables: RG 58/59/62/174/180/ 188/195/316/6/ Belden 8281 442 2 Step Replacement Stripping Cassettes High quality steel blade cassettes with razor sharp edges for long, effective use. Item No. 44237 44238 44239 44240 Color Blue Red Yellow Orange Strip Range Strip Dim. lbs. 1.87-7.6mm 6.8(0.27”) .01 1.87-7.6mm 6.0(0.24”) .01 1.87-7.6mm 12.0(0.47”) .01 1.87-7.6mm 9.2(0.36”) .01 Pkg. 1 1 1 1 Stripping Tool - No Cassette Stripping Tool Set 44200 Cassette Hand-Stripping Tool Accurate & versatile coaxial hand-stripping tool. Holds all 2 or 3 step cassettes. 44290 10 Piece Set, Cassette Hand-Stripping Tool Accurate & versatile coaxial hand-stripping tool, designed to provide 2 strip steps on chosen cable. Universal tool body accepts all cassettes. #44200 lbs. Pkg. .07 1 #44290 Set includes: Stripping Tool, L-key, 4 Cable V-blocks & 4 Stripping Cassettes .10 1 lbs. Pkg. www.wihatools.com 41 3 Step A 4 Cable V-blocks Adjustable Screw For Precise Blade Positioning Reversible Cassettes Long Life 3 Step Brown Cassette Kit A 3 Step B C Cables: RG 58/59/62/174/180/188/ 195/316/6/ Belden 8282 3 Step B C Cables: RG 58/59/62/174/180/188/ 195/316/6/ Belden 8283 3 Step White Cassette Kit 3 Step A “C” mm “B” mm “A” C 44251 44255 44259 44260 44261 Brown Green White Dk. Brown Black 8.3 6.0 6.8 7.5 5.5 2.7 6.0 2.5 3.5 5.5 User adjusted 44241 3 Step Brown Cassette Kit Accurate & versatile coaxial hand-stripping tool, designed to provide 3 strip steps on chosen cable. Enclosed V-blocks make stripper useful for cables in range of 2.5-7.6mm. Universal tool body accepts all cassettes. High quality steel blade cassettes with razor sharp edges for long, effective use. #44241 mm Inch Strip Range Strip Dim. lbs. Pkg. 90 3.54 1.87-7.6mm 8.3mm(B) .08 1 0.10”-0.30” 2.7mm(C) 3 Step Green Cassette Kit A Stepped Stripping Depth For Reduce Friction B B C Cables: RG 58/59/62/174/180/188/ 195/316/6/ Belden 8284 44245 3 Step Green Cassette Kit Accurate & versatile coaxial hand-stripping tool, designed to provide 3 strip steps on chosen cable. Enclosed V-blocks make stripper useful for cables in range of 2.5-7.6mm. Universal tool body accepts all cassettes. High quality steel blade cassettes with razor sharp edges for long, effective use. #44245 mm Inch Strip Range Strip Dim. lbs. Pkg. 90 3.54 1.87-7.6mm 6.0mm(B) .08 1 0.10”-0.30” 6.0mm(C) 44249 3 Step White Cassette Kit Accurate & versatile coaxial hand-stripping tool, designed to provide 3 strip steps on chosen cable. Enclosed V-blocks make stripper useful for cables in range of 2.5-7.6mm. Universal tool body accepts all cassettes. High quality steel blade cassettes with razor sharp edges for long, effective use. #44249 mm Inch Strip Range Strip Dim. lbs. Pkg. 90 3.54 1.87-7.6mm 6.8mm(B) .08 1 0.10”-0.30” 2.5mm(C) 3 Step Replacement Stripping Cassettes Cables: RG 58/59/62/174/180/188/ 195/316/6 Stripping Tool Set 442 3 Step Replacement Stripping Cassettes Accurate & versatile coaxial hand-stripping tool, designed to provide 3 strip steps on chosen cable. High quality steel blade cassettes with razor sharp edges for long, effective use. Item No. Color Strip B Strip C lbs. Pkg. 44251 Brown 2.7mm/.11” 8.3mm/.33” .01 1 44255 Green 6.0mm/.24” 6.0mm/.24” .01 1 44259 White 2.5mm/.10” 6.8mm/.27” .01 1 Dk.Brown 3.5mm/.14” 7.5mm/.30” .01 1 44260 44261 Black 5.5mm/.22” 5.5mm/.22” .01 1 44292 11 Piece Set, Cassette Hand-Stripping Tool Accurate & versatile coaxial hand-stripping tool, designed to provide 3 strip steps on chosen cable. Universal tool body accepts all cassettes. #44292 Set includes: Stripping Tool, L-key, 4 Cable V-blocks, 5 Stripping Cassettes .11 1 lbs. Pkg. Toll Free: (800) 494-6104 42 Item No. Page 26000 9 26001 9 26008 4 26010 4 26012 4 26015 4 26018 4 26020 4 26022 4 26023 4 26025 4 26027 4 26028 4 26030 4 26032 4 26033 4 26034 4 26035 4 26040 4 26041 4 26042 4 26050 10 26051 10 26052 10 26053 10 26054 10 26055 10 26056 10 26060 10 26061 10 26063 10 26065 10 26066 10 26068 10 26070 10 26072 10 26073 10 26074 10 26076 10 26079 10 26080 10 26090 4 26092 5 26093 10 26099 4 26100 5 26101 5 26102 5 26105 5 26107 5 26108 5 26109 5 26110 5 26113 5 26114 5 26115 5 26130 10 26132 10 26133 10 Item No. Page 26135 10 26136 10 26140 10 26142 10 26145 10 26190 5 26192 5 26193 10 26194 5 26199 5 26205 6 26210 6 26307 6 26309 6 26313 6 26315 6 26316 6 26320 6 26323 6 26325 6 26327 6 26330 6 26331 6 26333 6 26336 6 26340 6 26341 12 26343 12 26345 12 26347 12 26349 12 26351 12 26353 12 26363 12 26367 12 26369 12 26371 12 26390 6 26391 6 26392 12 26393 12 26399 6 26413 7 26415 7 26416 7 26419 7 26420 7 26423 7 26425 7 26427 7 26430 7 26431 7 26436 7 26439 7 26440 7 26441 12 26443 12 26445 12 26447 12 Item No. Page Item No. Page Item No. Page Item No. Page 26449 12 26455 12 26457 12 26459 12 26461 12 26463 12 26465 12 26467 12 26490 7 26491 7 26493 12 26499 7 26510 8 26515 8 26520 8 26523 8 26525 8 26527 8 26530 8 26531 8 26532 8 26535 8 26536 8 26539 8 26540 8 26545 8 26547 8 26550 8 26555 8 26556 8 26560 8 26563 8 26570 8 26571 13 26572 13 26573 13 26574 13 26575 13 26576 13 26577 13 26578 13 26579 13 26581 13 26582 13 26583 13 26584 13 26585 13 26586 13 26587 13 26588 13 26589 13 26590 8 26591 8 26592 8 26593 13 26596 13 26598 8 26599 8 26701 9 26702 9 26703 9 26704 9 26705 9 26706 9 26707 9 26708 9 26709 9 26710 9 26715 9 26720 9 26721 11 26723 11 26725 11 26727 11 26729 11 26731 11 26732 11 26733 11 26735 11 26736 11 26737 11 26739 11 26741 11 26743 11 26745 11 26747 11 26749 11 26751 11 26790 9 26791 9 26792 9 26793 11 26796 11 26798 11 26799 9 26810 9 26815 11 26900 15 26901 15 26903 15 26904 15 26905 15 26911 15 26912 15 26913 16 26914 16 26915 16 26916 16 26917 16 26918 16 26919 16 26920 16 26921 16 26922 15 26923 16 26924 16 26925 16 26926 16 26927 16 26928 16 26929 16 26932 16 26933 16 26934 16 26935 16 26936 16 26937 16 26938 16 26939 16 26940 16 26941 16 26942 16 26943 16 26944 16 26945 16 26946 16 26947 16 26948 16 26949 16 26950 16 26951 15 26952 15 26953 15 26954 15 26955 15 26956 15 26957 15 26958 17 26959 17 26960 17 26961 17 26962 16 26963 16 26964 16 26965 16 26966 16 26967 16 26968 16 26969 16 26971 15 26972 15 26973 15 26974 15 26975 17 26976 17 26977 17 26978 17 26979 17 26980 17 26981 17 26982 17 26985 17 26987 19 26989 19 26990 18 26991 18 26992 18 26993 18 26995 19 26996 19 26997 19 26999 19 28000 15 28001 15 28002 17 28003 17 28004 17 28005 17 28006 17 28007 17 28008 17 28009 17 28010 17 28011 17 28012 17 28013 17 28014 17 28015 17 28016 17 28017 17 28021 16 28023 16 28024 16 28025 16 28026 16 28027 16 28028 16 28029 16 28033 16 28034 16 28035 16 28036 16 28037 16 28080 18 28084 19 28087 19 28091 19 28094 18 28097 19 28620 7 28622 7 28624 7 28626 7 28627 7 28629 7 28632 7 28633 7 28637 7 28638 7 28644 7 40010 13 40410 35 40414 35 40420 35 40422 35 40424 35 www.wihatools.com 43 Item No. Page Item No. Page Item No. Page Item No. Page 40425 35 40426 35 40430 35 42012 33 42142 31 42150 31 43010 29 43221 36 43222 36 43223 36 43224 36 43225 36 43226 36 43228 36 43229 36 43235 36 43236 36 43251 36 43252 36 43253 36 43270 34 43271 34 43272 34 43273 34 43414 31 43419 31 43612 37 43618 37 43624 37 43643 37 43799 32 43800 29 43948 32 43949 32 44149 32 44159 32 44200 40 44206 39 44212 38 44213 38 44214 38 44217 39 44218 39 44220 39 44221 39 44222 40 44224 40 44227 40 44237 40 44238 40 44239 40 44240 40 44241 41 44245 41 44249 41 44251 41 44255 41 44259 41 44260 41 44261 41 44269 38 44290 40 44292 41 44501 26 44502 26 44503 26 44504 26 44505 26 44506 26 44507 26 44508 26 44509 26 44510 26 44511 27 44512 27 44513 27 44514 27 44515 27 44518 27 44520 27 44521 27 44522 27 44523 27 44524 28 44525 28 44526 28 44527 28 44528 28 44529 28 44530 28 44531 28 44532 28 44533 28 44590 18 45010 29 45113 33 45212 33 45213 33 45802 34 45803 34 46069 32 46500 32 46610 34 46611 35 46612 35 46613 35 46615 35 46616 35 46619 35 46950 29 46970 29 46971 29 46972 29 46987 29 48050 34 48075 34 48100 33 48307 32 49150 33 49154 33 49158 33 49159 33 49185 29 49215 33 49368 29 49375 30 49378 30 49381 30 49382 30 49383 30 49385 30 49387 30 49388 30 49478 30 49487 31 49584 32 49587 32 49779 31 49783 31 49879 31 56801 25 56812 24 56813 25 56815 24 56818 24 56825 24 56830 25 56833 25 56871 25 62990 14 62993 14 62994 14 62995 14 65090 14 75008 20 75012 20 75015 20 75018 20 75020 20 75025 20 75030 20 75035 20 75040 20 75093 23 75094 23 75095 23 75096 23 75105 20 75110 20 75115 20 75120 20 75307 20 75309 20 75313 20 75315 20 75320 20 75322 21 75325 20 75327 21 75330 20 75332 21 75340 20 75342 21 75350 20 75352 20 75354 20 75356 20 75358 20 75360 20 75362 21 75364 21 75366 21 75368 21 75370 21 75372 21 75395 22 75703 21 75704 21 75705 21 75706 21 75707 21 75708 21 75709 21 75710 21 75715 21 75720 21 75727 21 75728 21 75729 21 75735 21 75739 21 75742 21 75792 22 75800 20 75801 20 75900 20 75901 20 75902 21 75981 23 75983 23 75985 23 75989 21 75990 21 75991 22 75992 22 75994 22 75996 22 75999 22 91118 8,13 92190 9 92191 9 95190 14 96800 14 Notes: (800) 494-6104 fax: (800) 494-7456 email: cservice@wihatools.com Wiha Quality Tools 1348 Dundas Circle Monticello, MN 55362 tel: 763.295.6591 fax: 763.295.6598 Wiha Tools Canada Ltd. www.wihatools.ca Brampton, ONT L6T 4X4 tel: 866.494.0096 or 763.295.6591 fax: 763.295.6598 To: Catalog Item No. 99006 .wo version - 5/15/13 Subject to change without notice ©2013 Willi Hahn Corporation ®Torx is a registered trademark of Acument Intellectual Properties LLC. 99060.wo - Product Guide 99004.wo - Shop Tools Catalog 99001.wo - TorqueControl Catalog 99934.wo - Hex Tools Catalog 99914.wo - TORX Catalog 99002.wo - Screwdrivers Catalog 99951.wo - Bits Catalog 99919.wo - Insulated Catalog 99945.wo - ESD Catalog 99977.wo - Pliers/Crimpers Catalog Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Wiha: 28025 44227 26971 43272 43419 42142 28638 28633 44222 44249 44259 28626 28632 26938 26949 26054 49368 49587 44217 44237 26956 49383 49478 49159 49378 26958 26976 44290 43270 45010 46069 48050 49375 28027 44224 44240 44260 26957 26963 26968 26911 26940 26954 26941 26945 26947 28023 28029 26959 40425 75395 46616 46950 26922 42150 43221 43252 43799 43949 46619 46971 48100 49154 49382 49783 49879 45213 46611 49150 92190 44206 28644 26943 44221 43271 45113 49158 49381 49385 49388 49779 26708 62993 28637 26967 43273 46610 75989 40422 44159 45802 46613 28622 44261 44218 44292 56871 43253 43414 44200
75395 价格&库存
很抱歉,暂时无法提供与“75395”相匹配的价格&库存,您可以联系我们找货
