SV-CN1
SV-CN1
    SCS
    CREVICE TOOL
SV-CN1 数据手册
403248 12/21/07 10:32 AM Page 1 Service and Electronic/Vacuum Operating Instructions 8020746_Service Vac Manual.indd 1 6/10/08 12:05:18 PM 8020746_Service Vac Manual.indd 2 6/10/08 12:05:18 PM 403248 12/21/07 10:33 AM Page 4 WARNING! Power Cord Replacement: To reduce the risk of fire or electric shock, use appliance only with 3M Part No. SV-PC8 or SV-PC15 supply cord. If cord is damaged or lost, replace only with 3M Part No. SV-PC8 or SV-PC15 supply cord. SV-PC8 Stock No. 80-6104-7964-6 SV-PC15 Stock No. 80-6104-7965-3 120 Continuous duty rated sealed ball bearings lubricated for life. Internal U.L. Listed (U.S. and Canada) 2 3M™ Service Vacuum Operating Instructions 8020746_Service Vac Manual.indd 3 © 3M 2008 6/10/08 12:05:21 PM 403248 12/21/07 10:33 AM Page 5 Step 4 Attach selected accessory to hose (insert crevice brush as shown). Insert other end of hose into inlet. © 3M 2008 8020746_Service Vac Manual.indd 4 3M™ Service Vacuum Operating Instructions 3 6/10/08 12:05:25 PM 403248 12/21/07 10:33 AM Page 6 1. Unplug the power cord from the outlet and the vacuum. 4. Detach the hose nozzle from the base. 2. Open the lid and retrieve the L-15X filter plug. 5. Place the hose, power cord and attachments into the lid and close the accessory door. 3. Remove the hose from the inlet and insert the L-15X filter plug. 4 3M™ Service Vacuum Operating Instructions 8020746_Service Vac Manual.indd 5 6. Close the lid and securely fasten the latches. © 3M 2008 6/10/08 12:05:29 PM 403248 12/21/07 10:33 AM Page 7 15 12 Store service technician tools in tool pockets in top tool pallet and second tool pallet. Use second tool pallet as a workstation. 1 2 3 4 5 6 8 9 10 11 12 13 14 15 © 3M 2008 8020746_Service Vac Manual.indd 6 80-6104-7963-8 78-8063-1874-3 80-6104-7964-6 78-8063-2418-8 80-6104-7958-8 78-8063-1540-0 78-8005-5350-1 80-6104-7957-0 78-8079-9435-1 80-6104-7960-4 80-6104-7961-2 80-6104-7640-2 80-6104-7639-4 80-6104-7962-0 Power Cord Receptacle (SV-PCR) Power Cord Receptacle with RFI Filter (SV-PCR3) Power Cord, 8 foot (SV-PC8) Vacuum Hose (SV-SH32) Crevice Nozzle (SV-CN1) Curved Wand Nozzle (SV-WA2) Type 2 Filter, Toner/Dust (SV-MPF2) Crevice Brush (SV-CB1) Needle Nose Nozzle (SV-NN) Dusting Brush (SV-DBSD1) Handle (SV-H) Short Red Filter Plug L-14X (SV-SRP) Long Red Filter Plug L-15X (SV-LRP) Latch (SV-LS) Service Electronics Service/Electronics Service/Electronics Service/Electronics Service/Electronics Service/Electronics Service/Electronics Electronics Electronics Service/Electronics Service/Electronics Service/Electronics Service/Electronics 3M™ Service Vacuum Operating Instructions 5 6/10/08 12:05:38 PM 403248 12/21/07 10:33 AM Page 8 3M™ Dusting Brush, Static Dissipative (SV -DBSD1) 80-6104-7960-4. Used for applications involving static sensitive electronic components (such as circuit boards) to prevent static buildup. 3M™ T ype 1 Filter, Fine Particle (SV-SPF1) 78-6969-6211-3. A thinner, more concentrated weave (HEPA media) for trapping extremely fine particles to 0.3 microns. Typical applications are color laser printers, color copiers and highly sensitive equipment. (Disposable) 80-6104-7958-8. Used for general cleaning of loose materials in accessible areas. Prevents static buildup. 3M™ Crevice Brush (SV -CB1) 80-6104-7957-0. Used with crevice nozzle for general cleaning where a brush is needed to loosen foreign material. (NOT static dissipative.) 3M™ T ype 2 Filter, Toner/Dust (SV-MPF2) 78-8005-5350-1. Specifically designed for trapping unwanted toner from copiers and laser printers. Also ideal for cleaning data processing equipment. (Disposable) 3M™ Crevice Nozzle, Static Dissipative (SV-CN1) 3M™ Needle Nose Nozzle, Static Dissipative (SV-NN) 78-8079-9435-1. Used primarily for cleanign circuit boards. Needle nose design permits cleaning in very small areas, and static dissipative properties prevent static buildup. 3M™ Cur ved Wand Nozzle, Static Dissipative (SV-WA2) 78-8063-1540-0. Used for general cleaning on hard to reach areas. Static dissipative properties prevent static buildup. 3M™ Stretch Hose, 32-Inch (SV -SH32) 78-8063-2418-8. Used for general applications. Stretches to approximately 10 feet. 3M™ Stretch Hose, 50-Inch (SV -SH50) 78-8068-5818-5. Used where vacuum cannot be brought close to the object or area being cleaned. 6 3M™ Service Vacuum Operating Instructions 8020746_Service Vac Manual.indd 7 © 3M 2008 6/10/08 12:05:45 PM 403248 12/21/07 10:33 AM Page 9 3M™ Carr ying Strap (SV-CS1) 80-6104-7959-6. Used where handsfree transport of vacuum is preferred. 3M™ Power Cord, 8-Foot (SV-PC8) 80-6104-7964-6. Standard power cord supplied with vacuum. 3M™ Power Cord, 15-Foot (SV-PC15) 80-6104-7965-3. Used where electrical outlet cannot be reached with standard 8-foot cord. Optional. © 3M 2008 8020746_Service Vac Manual.indd 8 3M™ Service Vacuum Operating Instructions 7 6/10/08 12:05:47 PM 403248 12/21/07 10:33 AM Page 10 3M™ Service Vacuum Cleaner and Tool Case Limited Warranty and Limitation of Liability Limited Warranty: To the first user purchasing this 3M Service Vacuum Cleaner and Tool Case, 3M warrants that the 3M Service Vacuum will be free of defects in material and manufacture for a period of three (3) years from the time of purchase and the Tool Case will be free of defects in material and manufacture for a period of one (1) year from the date of purchase. Should any failure to conform to this warranty appear within this period upon notice to 3M within said three (3) years for the service vacuum cleaner and one (1) year for the tool case from the date of purchase, and upon proof of purchase, 3M shall, at its option, either repair or replace the defective product. It will be the purchaser’s responsibility to return the product, freight prepaid, to the service location specified by 3M. These remedies are the purchaser’s exclusive remedies for breach of this warranty. Exclusions to Warranty Coverage: The above warranty shall not apply to any 3M Service Vacuum Cleaner that has been modified without the approval of 3M, or has been damaged by negligence, misuse, accident, failure to follow 3M’s written operating instructions or use of any filter which does not meet 3M specifications. Consumable supplies, such as filters, are not covered by the above warranty. Disclaimer of Warranty: EXCEPT FOR THE IMPLIED WARRANTIES OF TITLE AND AGAINST PATENT INFRINGEMENT, 3M MAKES NO OTHER WARRANTIES WITH RESPECT TO THE 3M SERVICE VACUUM CLEANER, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. Limitation of Liability: 3M SHALL NOT BE LIABLE UNDER ANY CIRCUMSTANCES FOR ANY INCIDENTAL, SPECIAL, OR CONSEQUENTIAL DAMAGES, OR ECONOMIC LOSS, BASED UPON BREACH OF WARRANTY, BREACH OF CONTRACT, NEGLIGENCE, STRICT LIABILITY IN TORT OR ANY OTHER LEGAL THEORY, EVEN IF 3M HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES INCLUDING, BUT NOT LIMITED TO LOSS OF PROFITS, REVENUE, EQUIPMENT USE, DATA OR INFORMATION OF ANY KIND. THE LIABILITY OF 3M SHALL NOT UNDER ANY CIRCUMSTANCES, EXCEPT AS EXPRESSLY PROVIDED HEREIN, EXCEED THE PRICE OF THE 3M SERVICE VACUUM CLEANER. These limitations do not apply to damages caused by breach of the implied warranties of title and against infringement, nor to claims for personal injury. Some states have laws which require liability rights different from those stated above. In such states, the minimum required liability terms shall apply. 8 3M™ Service Vacuum Operating Instructions 8020746_Service Vac Manual.indd 9 © 3M 2008 6/10/08 12:05:50 PM 403248 12/21/07 10:33 AM Page 3 Keep cord away from heated surfaces. © 3M 2008 8020746_Service Vac Manual.indd 10 3M™ Service Vacuum Operating Instructions 1 6/10/08 12:05:53 PM 8020746_Service Vac Manual.indd 11 6/10/08 12:05:53 PM 403248 12/21/07 10:34 AM Page 20 3M is a trademark of 3M Company. Important Notice All statements, technical information, and recommendations related to 3M's products are based on information believed to be reliable, but the accuracy or completeness is not guaranteed. Before using this product, you must evaluate it and determine if it is suitable for your intended application. You assume all risks and liability associated with such use. Any statements related to the product which are not contained in 3M's current publications, or any contrary statements contained on your purchase order shall have no force or effect unless expressly agreed upon, in writing, by an authorized officer of 3M. Warranty; Limited Remedy; Limited Liability This product will be free from defects in material and manufacture from the time of purchase. 3M MAKES NO OTHER WARRANTIES INCLUDING, BUT NOT LIMITED TO, ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. If this product is defective within the warranty period stated above, your exclusive remedy shall be, at 3M's option, to replace or repair the 3M product or refund the purchase price of the 3M product. Except where prohibited by law, 3M will not be liable for any indirect, special, incidental or consequential loss or damage arising from this 3M product, regardless of the legal theory asserted.  Electronic Solutions Division Interconnect Products 6801 River Place Blvd. Austin, TX 78726-9000 8020746_Service Vac Manual.indd 12 Please recycle. Printed in U.S.A. © 3M 2008. All rights reserved. 78-6970-4155-2 Rev. G 6/10/08 12:05:54 PM Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: 3M: SV-PCR3
SV-CN1 价格&库存
很抱歉,暂时无法提供与“SV-CN1”相匹配的价格&库存,您可以联系我们找货
SV-CN1
    • 1+90.29839
    库存:13
    SV-CN1
      • 1+114.50912
      • 10+113.00226
      • 20+112.99040
