IF-850052
IF-850052
    INDUSTRIALFIBER
    CARD DETECTOR INFRARED 850NM
IF-850052 数据手册
IR (infrared) Detection Card 850nm - IF 850052 - Industrial Fiber Optics, Inc. Page 1 of 1 You Are Here: Home > Tools/Test Equipment > Miscellaneous > IR (infrared) Detection Card 850nm IR (infrared) Detection Card 850nm Credit card size indicator for viewing IR light. An IR detection card is a great addition to any technician's tool box who works with fiber optic systems using infrared (IR) light. This card will quickly visually indicate if an IR LED is producing light (radiation) without having to use larger and bulkier tools. Each card has a 1.5 X 1.5 cm active area that is sensitive to IR light. The illuminated area glows or produces a blueish green light when illuminated with IR light. It creates this glow by dislodging charged molecular electrons in the phosphor material which produces photons which is light with a blueish green color. Part Number: IF 850052 Charging - phosphor stores energy when exposed to the UV wavelengths found in sunlight or light from fluorescent lamps - IR releases it as a phosphorescent glow. Sensitivity peaks at 800 nm and at 1300 nm (sensitivity at 1300 nm approx. 55 % of sensitivity at 800 nm). Suitable for low intensity LED light sources as used in fiber optics. High powered light sources may quickly deplete the stored energy in the phosphor material, after which recharging is required. * Spectral bandwidth (S = 10 % of Smax) 600 - 1500 nm Copyright 2000-11, All Rights Reserved Industrial Fiber Optics 3/31/2011
IF-850052 价格&库存
很抱歉,暂时无法提供与“IF-850052”相匹配的价格&库存,您可以联系我们找货
