SV-CB1
SV-CB1
    SCS
    STATIC, CLEAN ROOM SUPPLIES
SV-CB1 数据手册
3M™ Moisture Barrier Bag Dri-Shield 2000 Product Data Sheet Product Data Sheet 3M™ Electronics Vacuum 497 Series The Electronics Vacuum 497 Series is a self-contained unit that is designed for highefficiency cleanup of most business equipment, including removing toner and dust. Portability, quick setup and efficient safe operation are key features of this vacuum. Contains a one horsepower, six amp motor and ESD safe attachments. The Electronics Vacuum 497 comes with a Type 2 Filter, a detachable cord and plastic hose (approximately 10 feet). Features: • Detachable power cord for easy storage • Attachments that quickly dissipate static charge • Lightweight and easy to setup • Complete attachment offering including: stretch hose, crevice tool, wand and brush • Dimensions: 7.8 in. x 17.8 in. x 9.3 in. Property Typical Value Test Method Model 497AJM 120VAC, 50/60 Hz, 6.0 amps Supplier Model 497ABF 220/240VAC, 50/60 Hz, 4.25 amps Supplier Length 17.8 inches (45.2 cm) 3M Internal Width 7.8 inches (19.7 cm) 3M Internal Height 9.3 inches (23.5 cm) 3M Internal Weight 11 lbs. 3M Internal Sound pressure Level 74.0 dBA ISO Standard 11201; 1st edition 1995-12-15 Motor 1 HP Dimensions Continuous duty rated with one sealed ball bearing and one sleeve bearing lubricated for life. Thermally protected with automatic reset. Electronics Vacuum 497 Series comes complete with: Hose, lO ft SV-SH32 – 78-8063-2418-8 Wand, SV-WA2 – 78-8063-1540-0 Crevice Tool, SV-CN1 – 80-6104-7958-8 Crevice Tool Brush, SV-CB1 – 80-6104-7957-0 Needle Nozzle – 78-8063-1549-1 (Needle Nozzle not included with 3M ™ Service Vacuum 497 Series) 3M™ Moisture Barrier Bag Dri-Shield 2000 Product Data Sheet Product Data Sheet 3M™ Electronics Vacuum 497 Series Replacement Parts and Accessories Image Part No. Description SV-MPF2 Image Part No. Description High Performance Filter, Type 2 for medium particles. Specifically designed for collecting unwanted toner from copiers and laser printers. SV-CN1 Crevice Nozzle SV-SPF1 Fine Particle Filter, Type 1. This filter has a more concentrated weave for collecting extremely fine particles. SV-CB1 Crevice Brush SV-CS1 Carrying Strap Assembly SV-WA2 Curved Wand Nozzle SV-SH32 Vacuum Hose Assembly. This 32 inch hose stretches to approximately 10 feet. SV-NN Needle Nose Nozzle SV-LRP Long Red Filter Plug. This plug is used to cover the filter inlet for storage when the vacuum cleaner is not in use. SV-DBSD1 Dusting Brush SV-SRP Short Red Filter Plug. This plug is used to cover the filter inlet for disposal. 3M™ Moisture Barrier Bag Dri-Shield 2000 Product Data Sheet Product Data Sheet 3M™ Electronics Vacuum 497 Series, Filters 3M offers two filter types for its vacuum cleaners to better fit your cleaning applications. 3M™ Filter, Type 1 for fine particles, is the premium choice for filter media. Constructed with a concentrated weave, the Type 1 Filter is ideal for trapping fine particles to 0.3 microns. This pleated filter is encased in plastic making it durable and easily disposable. The vacuum can be used in laser printer and copier cleaning applications and around highly sensitive equipment. 3M™ Filter, Type 2 for dust, is used for general dry pick-up in a wide variety of applications. This pleated filter is encased in plastic making it durable and easily disposable. Replacing a full filter is easy and clean. 3M™ Filter, Type 1 3M™ Filter, Type 2 Property Typical Value Test Method SV-SPF1 Type 1 (Glass Media) Efficiency 99.977%, Size Range 0.3 - 0.5 (µm) CFM 40 cubic feet per minute Loading 1,700 - 1,800 grams DHOD-97HP26 SV-MPF2 Type 2 (Paper Media) Efficiency 99.2%, Size Range 3.0 - 5.0 (µm) CFM 40 cubic feet per minute Loading 1,700 - 1,800 grams DHOD-97HP26 Product Data Sheet Product Data Sheet 3M™ Electronics Vacuum 497 Series 3M is a trademark of 3M Company. All other trademarks are owned by their respective companies. Important Notice All statements, technical information, and recommendations related to 3M’s products are based on information believed to be reliable, but the accuracy or completeness is not guaranteed. Before using this product, you must evaluate it and determine if it is suitable for your intended application. You assume all risks and liability associated with such use. Any statements related to the product which are not contained in 3M’s current publications, or any contrary statements contained on your purchase order shall have no force or effect unless expressly agreed upon, in writing, by an authorized officer of 3M. Warranty; Limited Remedy; Limited Liability. This product will be free from defects in material and manufacture for three years from the time of purchase. 3M MAKES NO OTHER WARRANTIES INCLUDING, BUT NOT LIMITED TO, ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. If this product is defective within the warranty period stated above, your exclusive remedy shall be, at 3M’s option, to replace or repair the 3M product or refund the purchase price of the 3M product. Except where prohibited by law, 3M will not be liable for any indirect, special, incidental or consequential loss or damage arising from this 3M product, regardless of the legal theory asserted. 3 Electronics Materials Solutions Division Static Control Products 926 JR Industrial Drive Sanford, NC 27332-9733 Toll-Free: 866-722-3736 International: 919-718-0000 Email: 3mstaticinfo@mmm.com www.3Mstatic.com Please recycle. Printed in USA. © 3M 2014. All rights reserved. 78-9102-1469-7 JHA Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: SCS: SV-CB1
SV-CB1 价格&库存
很抱歉,暂时无法提供与“SV-CB1”相匹配的价格&库存,您可以联系我们找货
SV-CB1
    • 1+94.79716
    库存:115
