CSR-2
CSR-2
    JONARDTOOLS
    CSRREPLACEMENTBLADESET
CSR-2 数据手册
Tools for Telecom, Fiber Optics CATV, Satellite, Security & Alarm, Wireless and Electronics Industries Catalogue No. 114 MADE FOR LIFE® WE ARE JONARD TOOLS Just scan the link to see the new more user friendly Jonard Website. Notice our new name – JONARD TOOLS. This isn’t simply a cosmetic change, this is a dramatic metamorphosis of our business and how user friendly our new website is to use. Find what you’re looking for with jonard.com our new and improved search options. Get greater details including tool specifications, helpful videos, enhanced quality photos, complementary products and more. And best of all you still get the GREAT QUALITY you’ve grown to expect from Jonard. Find out for yourself why our tools are MADE FOR LIFE®. WHAT’S NEW? Since 2007 Jonard Industries has introduced well over 250 new tools. Follow us on Facebook, Twitter and sign up for our newsletter for exciting events and new product announcements. BLOG THIS! Yes, Jonard Tools now has a blog with interesting and entertaining news, happenings and other pertinent information. Just go to our website and click the blog icon for the latest blog as well as our previous postings. WARRANTY Lifetime warranty – see details on our website www.jonard.com CUSTOMER SERVICE Our distribution network is present in all 50 states and over 100 countries. Check the “Where to Buy” section of our website to locate a dealer near you. Jonard Industries maintains stock in depth, provides technical support and we will meet your individual service requirements. JonardTools www.facebook.com/JonardTools Jonard Industries 134 Marbledale Road, Tuckahoe, New York 10707 • email: sales@jonard.com Phone: (914) 793-0700 • Fax: (914) 793-4527 Website: www.jonard.com © Copyright 2014 Jonard Tools TABLE OF CONTENTS Pliers 4-10 Fiber Optic Tools 11-15 Wrenches 16-19 CATV/Satellite Tools & Kits 16-28 Scissors 29-30 Punchdown Tools 31-32 Screwdrivers 33-34 Insulated Tools 35 Electrical Tools 33-37 Wire Fishing & Sewing 37-39 Wire & Cable Strippers 40-43 Kynar Wire 44 Connector Tools 45 Burnishers 46 Alignment Tools 47-48 Force Gauges 49 Wire Wrapping 50-57 IC Insertion Extraction Tools 58 Fume Absorbers & Desolder Pumps 59 3 Crimping & Coax Pliers COMBO CRIMPER LONG NOSE PLIERS Five tools in one, combines crimper for UR/UY/UG, AMP tel splice connectors, 709 series connectors, crimping "B" type connectors and a long nose pliers. With a crusher, cutter, .030" stripping hole, and yellow plastic handle. Made of chrome vanadium steel. JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JAW THICKNESS CUTTER LENGTH JIC-22148 6 7/8” 1 7/8” 13/16” 3/8” 13/32” WEIGHT 5.4 oz JIC-22148 JIC-891 CONNECTOR-CRIMPING PLIERS WITH SIDE CUTTERS Connector-Crimping Pliers with Side Cutters designed to press UG, UR, UY, 709 series connectors, crimping "B" type connectors, and AMP tel splice connectors. A special stop behind cut out prevents damage to connectors. Utilized on combinations of plastic and pulp insulated 19, 22, 24 and 26 gauge copper conductors as well as 20 gauge plastic insulated copper steel wire. Comes with side cutter and yellow plastic handle. JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JAW THICKNESS CUTTER LENGTH WEIGHT JIC-891 5 3/16” 1” 13/16” 3/8” 1/2” 5.9 oz COAX CABLE CUTTER STEEL A plier designed specifically for coax cables with a steel center conductor. This plier has been tested (over 25,000 cuts) on cables with steel centers, and specifically CCSC (copper clad steel center) conductor cables without degradation to the cutting blades. Made from chrome vanadium steel. Plier will also cut many other cable types. JIC-725 JONARD PART NO. LENGTH JAW THICKNESS JAW WIDTH WEIGHT JIC-725 6 1/4” 1/4” 1.0” 6.5 oz 3/ 4” COAX CABLE CUTTER Also known as a Banana Cutter, this cutter is designed to cut 3/ 4” coaxial cable. Tool cuts cleanly without compressed or frayed ends. Functions like a tube cutter – eliminates cable distortion during cable prep. NOT designed to cut steel cable. Yellow plastic handles. Made of chrome vanadium steel. JIC-750 JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JAW THICKNESS WEIGHT JIC-750 8 3/4” 1 1/4” 5/8” 1/4” 12.6 oz HEAT COIL PLIERS Designed for installing and extracting heat coils, fuses from line amplifiers and other cylindrical shaped components. The thin nosed jaw allows easy access to tight restricted areas. Yellow plastic handle. PLS-5 4 JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JAW THICKNESS WEIGHT PLS-5 5” 1 13/16” 1/2” 5/16” 3.4 oz jonard.com Ӏ Diagonal Pliers JIC-7858 TELECOM DIAGONAL CUTTER PLIERS Tapered nose diagonal cutting pliers with standard-bevel knives with .030" and .045" skinning holes, with crusher used for multi-purpose wire work, with two V-shaped stripping notches. Red plastic handle. Made of chrome vanadium steel. JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JAW THICKNESS WEIGHT JIC-7858 6 1/2” 7/8” 3/4” 3/8” 6.4 oz DIAGONAL PLIERS – CRUSHING & SLITTING Used for cutting soft copper conductors. Has a “V” shaped notch between jaws, near the joint, for crushing the flameproof type of insulation on distributing frame wire. Also provides a “W” shaped notch on the plier jaws for slitting textile insulation. Red plastic handle. Made of chrome vanadium steel. DIABVNOTCH JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JAW THICKNESS WEIGHT DIABVNOTCH 6 3/16” 13/16” 1/2” 11/32” 4.3 oz DIAGONAL GENERAL USE PLIERS These are plain diagonal pliers for general use, for cutting soft copper conductors. Red plastic handle. Made of chrome vanadium steel. DIAGB5 JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JAW THICKNESS WEIGHT DIAGB5 5 1/8” 13/16” 1/2” 11/32” 4.3 oz DIAGONAL PLIERS – SKINNING & STRIPPING Tapered nose diagonal cutting pliers with standard-bevel knives with one .045” skinning hole, crusher used for multipurpose wire work, and two V shaped stripping notches. Red plastic handle. Made of chrome vanadium steel. DIAGB6 JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JAW THICKNESS WEIGHT DIAGB6 6 1/2” 7/8” 3/4” 3/8” 6.4 oz 5 Heavy Duty Pliers HIGH LEVERAGE DIAGONAL CUTTER ANGLED HEAD 13o angled head for heavy-duty wire cutting and crafted for heavy duty wire cutting. Made from chrome vanadium steel. with improved heat treatment to the cutting edges for increased strength. Use for the most demanding applications, precision machined cutting edges provide exceptionally smooth action. JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JAW THICKNESS WEIGHT JIC-2488 8 5/8” 13/16” 1 3/16” 3/8” 13.8 oz JIC-2488 HIGH LEVERAGE DIAGONAL CUTTER Crafted for heavy duty wire cutting. Made from chrome vanadium steel. with improved heat treatment to the cutting edges for increased strength. Use for the most demanding applications, precision machined cutting edges provide exceptionally smooth action. JIC-2288 JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JAW THICKNESS JIC-2288 8 1/4” 7/8” 1 3/16” 7/16” WEIGHT 13.8 oz LINEMAN’S B SIDE CUT PLIERS Designed for heavy duty use in construction and maintenance work. These pliers are high leverage for cutting bolts, nails, and many gauges of wire including high-strength wire. Induction hardened cutting edges cut clean and remain sharp. Precision machined handles and hot riveted joint provide smooth movement with no side play. The cushioned-grip, comfortable handles are red plastic to approximately .007”. Made of chrome vanadium steel. JIC-683 JIC-685 6 JONARD PART NO. LENGTH JAW LENGTH JIC-683 9 1/2” 1 19/32” JAW JAW CUTTER WIDTH THICKNESS LENGTH 1 1/4” 5/8” 13/16” WEIGHT 14.4 oz LINEMAN PLIER WITH CRIMPER & FISH TAPE PULLER Designed for heavy duty use in construction and maintenance work. These pliers are high leverage for cutting bolts, nails, and many gauges of wire including high-strength wire. Cutting edges cut clean and remain sharp. Fish tape pulling feature easily pulls 1/8” or 1/4” steel fish tape without damaging the tape. Built in crimper feature works best on non-insulated connectors, lugs and terminals. Cushioned grip, comfortable handles are yellow plastic coated to approximately .007”. Made of chrome vanadium steel. JONARD PART NO. LENGTH JAW LENGTH JIC-685 9 1/2” 1 19/32” JAW JAW CUTTER WIDTH THICKNESS LENGTH 1 1/4” 5/8” 3/4” WEIGHT 14.4 oz jonard.com Ӏ Heavy Duty Pliers HIGH LEVERAGE CABLE CUTTERS High leverage design for superior cutting ability. Designed with a shear-type jaw for cutting aluminum and soft copper. Not for use on steel or ACSR type cables. Cuts up to 100-pair cables. Red plastic handle. Made of chrome vanadium steel. JONARD PART NO. LENGTH JIC-63050 9 1/4” JAW JAW WIDTH THICKNESS 13/16” 1/2” JAW LENGTH WEIGHT 1 3/8” 15.8 oz JIC-63050 RATCHETING CABLE CUTTER Cuts up to 600 mcm stranded copper cable, 750 mcm stranded aluminum cable. Maximum capacity is 1 3/4" (45mm) diameter. Cleanly cut copper or aluminum & multiconductor cable up to 600 mcm. Unique design to hold and cut cable quickly, easily with minimum effort. Spring design to hold cutter in the open position when needed. Quick release for easy opening. Large ergonomic handle design (Not designed for cutting ACSR or steel) RC-600 JONARD PART NO. LENGTH RC-600 12” DESCRIPTION WEIGHT Ratcheting Cable Cutter 34.0 oz TABBING SHEAR Also known as a cable sheath shear. Designed for making longitudinal cuts in the cable sheath and the metallic shield for placement of inner sheath bond clamps. Made of chrome vanadium steel with a special hardening process for durability, with a precision ground blade for superior cutting. Plastic formed ergonomic handles for safety and comfort and a latch to keep the handles closed when not in use. The volute spring allows for easy opening and closing. TS-850 JONARD PART NO. LENGTH DESCRIPTION WEIGHT TS-850 8 1/2” Tabbing Shear 10.5 oz SLIP JOINT SIDE CUT PLIERS For heavy-duty use. Polished head, red plastic handles and flush bolt. Machined gripping teeth and 3/8” hardened wire cutter. BCOMB JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JAW THICKNESS CUTTER LENGTH WEIGHT BCOMB 7 5/8” 1 3/4” 1 1/4” 3/8” 3/8” 9.8 oz 7 Long Nose Pliers TELECOM LONG NOSE D PLIERS Pliers are for general use looping, bending and cutting. Grips small wires and parts and reaches into tight spaces. Jaws are knurled, serrated and have side cutting blades. Cushion gripped yellow plastic handle. JONARD PART NO. LENGTH JAW LENGTH JIC-842 6 3/4” 1 7/8” JAW JAW CUTTER WEIGHT WIDTH THICKNESS LENGTH 11/16” 3/8” 1/2” 6.5 oz JIC-842 LONG NOSE SWITCHBOARD PLIER Pliers are for general use looping, bending and cutting. Grips small wires and parts and reaches into tight spaces. Jaws are knurled, serrated and have side cutting blades. Two stripping holes for 19 & 22 AWG wire. Cushion gripped yellow plastic handle. Made of chrome vanadium steel. JONARD PART NO. JIC-203 JIC-203 STRIP HOLES AWG LENGTH WEIGHT 19 & 22 6 7/8" 6.5 oz TELECOM LONG NOSE PLIERS Long nose have side cutting blades, a crushing slot, one .030” stripping hole, and a thin knurled nose to facilitate handling of the wire at the terminals. Cushion gripped yellow plastic handle. Made of chrome vanadium steel. JONARD PART NO. LENGTH JAW LENGTH JIC-21257 6 7/8” 1 7/8” JAW JAW CUTTER WIDTH THICKNESS LENGTH 13/16” 3/8” 1/2” WEIGHT 6.6 oz JIC-21257 LONG NOSE CUT CRUSH STRIP L3 PLIERS Long nose with side cutter, crushing slot, one .030” stripping hole and a thin knurled nose to facilitate handling wire at the terminals. Cushion gripped yellow plastic handle. KS21257L3 8 JONARD PART NO. LENGTH JAW LENGTH KS21257L3 6 1/2” 1 1/2” JAW JAW CUTTER WIDTH THICKNESS LENGTH 3/4” 3/8” 7/16” WEIGHT 6.1 oz jonard.com Ӏ Long & Curved Nose Pliers CURVED LONG NOSE PLIER Nose is bent 70° for maximum visibility. Used in confined areas. Design includes knurled jaws for sure wrapping and looping. Comfortable ergonomic yellow plastic handles. JIC-3026 JIC-3385 JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JAW THICKNESS WEIGHT JIC-3026 6 7/8” 2” 11/16” 3/8” 7.2 oz CURVED NEEDLE NOSE PLIER Nose is bent 60° for maximum visibility. Used in confined areas for bending and forming fine wire. Inside jaws and jaw edges are polished to prevent nicking the wire. Plier has a spring loaded ergonomic design. With a dark blue plastic handle. JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JAW THICKNESS WEIGHT JIC-3385 5 1/2” 1 1/2” 1/2” 1/4” 3.2 oz LONG NOSE GENERAL USE PLIERS Chain nose pliers for general use. Inner surface of the jaws are knurled near the end to facilitate gripping wire, binding post nuts etc. Orange plastic handle. BLONGNOSE JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JAW THICKNESS WEIGHT BLONGNOSE 6 7/8” 1 1/2” 3/4” 3/8” 6.1 oz LONG NOSE GRIPPING PRESSING PLIERS Long nose pliers for gripping and pressing. Inner surface of the jaws are knurled near the end to facilitate gripping wire, binding post nuts etc. Aluminum oxide insulation coating on the outside nose surface. The inside gripping jaws are provided with mated grooves near the joint for use in pressing .032/.035” brass sleeves. One stripping hole .054” diameter Orange plastic handle. JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JAW THICKNESS WEIGHT ELONGNOSE 6 7/8” 1 7/8” 11/16” 3/8” 6.1 oz ELONGNOSE SHORTNOSE PLIERS Intended for use in skinning 22-24 AWG wire and crushing insulation in nose slot. The front portion of the jaws are narrowed, and a portion of the inner face of one jaw is relieved to skin insulation from wire. The inner surface of the jaws are serrated to facilitate gripping wire. Orange plastic handle. JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JAW THICKNESS WEIGHT BSHORTNOSE 6 1/2” 1 1/2” 3/4” 3/8” 6.1 oz BSHORTNOSE 9 Flush Cut & Pump Pliers PUMP PLIERS Manufactured with a secure tongue and groove design for a non-slip grip (even under heavy pressure). The jaws provide a wide range of openings with a smooth, positive interlock between halves. Handles are plastic coated,but are not insulated and do not protect against electric shock. JIC-5026 JONARD PART NO. MAX. JAW OPENING NUMBER POSITIONS WEIGHT LENGTH JIC-5026 JIC-50210 JIC-50212 6” 10” 12” 1” 1 3/4” 2 1/4” 4 6 7 7.8 oz 14.4 oz 24.0 oz JIC-50210 JIC-50212 SEMI-FLUSH CUT PLIERS A close cutting plier used to trim conductors from the 710 connector modules without leaving exposed conductors. Ideal for close trimming of gates and sprue on injection molded plastic parts. Jaw design aids in use in confined areas. Turquoise color handle. Plier made from chrome vanadium steel. JIC-453 JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JIC-453 4 1/2” 5/8” 7/16” JAW WEIGHT THICKNESS 1/4” 2.4 oz FLUSH CUT PLIER Made of high carbon steel, this lightweight flush cutter can be used on wire up to 18 AWG while minimizing fly-off. Cantilevered spring automatically opens the plier, and the head fits easily in confined work areas. JIC-2755 JONARD PART NO. LENGTH JAW LENGTH JAW WIDTH JIC-2755 5” 1/2” 1/2” JAW WEIGHT THICKNESS 1/16” 2.2 oz All Jonard Industries Pliers come with a LIFETIME WARRANTY. For complete details see our website 10 jonard.com Ӏ Fiber Optic Tools PATENTED PATENTED CST-1900 FOD-2000 FIBER OPTIC DROP CABLE SLITTER The FOD-2000 Fiber Optic Drop Cable Slitter is a Patented tool that simplifies the slitting of drop cable jackets at the end of the cable or mid-span. Designed for .250” flat drop cable. The FOD-2000 puts a slit on both sides of the jacket allowing easy access to the fiber or strength member. The ease of use makes this tool truly unique. To use just position the tool around the cable, pull and slit. A simple solution for a vital task. The FOD-2000 comes completely assembled with two blades, which can be reversed once the blades are worn. JONARD P/N FOD-2000 DESCRIPTION Fiber Optic Drop Cable Slitter FOD-RB25 Replacement Blades 25/pk ROUND CABLE STRIPPER The CST-1900 is designed for fast and precise jacket removal of PVC, rubber, PE and other jacket materials, and works well on round cables with diameters ranging from 3/16" to 1-1/8" (4.5-29 mm). This is a Triple Action Tool, cutting longitudinally for end stripping, spiral for end stripping and mid-span cuts, and circular for jacket removal. A simple versatile easy to use tool your customers will love. The Replaceable Cutting Blade is spring loaded, adjustable for various cable diameters, provides a 90° blade rotation and is designed for long life. JONARD P/N DESCRIPTION CST-1900 Round Cable Stripper CST-7915 Replaceable Cutting Blade JIC-1022 FIBER JACKET STRIPPER The Wire Stripper and Cutter is designed to strip and cut the most commonly used stranded and solid wire gauges 10 to 22 AWG and 1.6-3 mm fiber jackets. Fiber Jacket Stripper F4 .139 .134 .190 UCD-2685 UC-8039 UNIVERSAL CRIMPER WITH FIBER OPTIC DIE Fully ratcheted crimper designed for minimal closing force. JONARD P/N DESCRIPTION UC-8039 Universal Crimper with Fiber Optic Die UC-2685 Fiber Optic Crimping Die OPTICAL FIBER CABLE SHEATH STRIPPER & RING TOOL This Cable Sheath Stripper is used to ring-cut many types of tight buffer, loose tube buffer, breakout cables and other types of jacketed fiber cables. A slitting blade is built into the tool and can be used to slit open the cable sheath if needed. Depth of the cut has two adjustments for .018" or .031" thick plastic, rubber or fabric insulation, and can handle cable diameters from 1/8" to 3/8". One spare blade of each style is included with the tool. Also known as CT2860. .058 .252 .178 .151 RB-2878 .350 JIC-1022 JIC-4366 .324 DESCRIPTION F4 JONARD P/N RB-2060 JONARD P/N JIC-4366 RB-2060/6 RB-2878/6 DESCRIPTION Optical Fiber Sheath Stripper & Ring Tool Pkg. of 6 Replacement Blades for ring feature of tool Pkg. 6 replacement blades for stripper feature of tool 11 Fiber Optic Tools JIC-375 FIBER OPTIC STRIPPER THREE HOLE Three hole Fiber Optic Stripper performs all common fiber stripping functions. Strips the 1.6-3 mm fiber jacket down to the 900 micron buffer coating. The second hole strips the 600900 micron buffer coating down to the 250 micron coating and the third hole is used to strip the 250 micron cable down to the 125 micron glass fiber. JIC-375 is 6” long. JONARD P/N DESCRIPTION JIC-375 Fiber Optic Stripper- 3 Hole ERGONOMIC FIBER OPTIC STRIPPER Used for stripping the 250 micron coating from the 125 micron optical fiber. Preset at the factory so no adjustments are necessary. Yellow plastic formed handles, tool is 6” long. JIC-175 JONARD P/N DESCRIPTION JIC-175 Fiber Optic Stripper Ergonomic FIBER OPTIC STRIPPER For stripping 250 micron buffer coating from 125 micron optical fiber. Preset at the factory so no adjustments are necessary. Yellow plastic dipped handles 5 3/16” long JIC-125 JONARD P/N DESCRIPTION JIC-125 Fiber Optic Stripper MID SPAN SLITTER Designed to provide easy access to optical fibers in loose buffer tubes 1.2mm – 3.3mm diameter. With 6 precision grooves buffer tube slitting is done without damage to the fiber. The blades are replaceable. Easy to use: Select the correct groove for the cable being slit Place the cable in the proper channel, squeeze and pull. MS-6 12 JONARD P/N DESCRIPTION MS-6 MSB-1533 Mid Span Slitter Replacement Blade 1.2 – 3.3 mm (pkg of 2) jonard.com Ӏ Fiber Optic Tools THREE PIECE FIBER OPTIC KIT Kit includes the JIC-375 Fiber Optic Stripper three hole, ES-1964 Electrician's Scissor, and convenient molded plastic pouch made of durable PVC material and will accommodate belts up to 2” in width. JIC-375 H-35 ES-1964 JONARD P/N DESCRIPTION TK-375 3 Piece Fiber Optic Kit H-35 Plastic Molded Pouch JIC-375 Fiber Optic Stripper- 3 Hole ES-1964 Electrician Scissor FIBER KIT WITH KEVLAR CUTTER Kit includes the JIC-375 Fiber Optic Stripper Three Hole, JIC-186 Ergonomic Fiber Optic Kevlar Cutter and the convenient H-60 molded plastic pouch with metal clip. JIC-375 H-60 JONARD P/N DESCRIPTION TK-350 Fiber Kit with Kevlar Cutter H-60 Plastic Moulded Pouch JIC-375 Fiber Optic Stripper- 3 Hole JIC-186 Ergonomic Fiber Optic Kevlar Cutter JIC-186 VFL-25125 VFL-25 TECHNICAL SPECIFICATIONS Light Source: Class Laser Diode Wavelength: 650nm Battery Life: 60 Hours Connector: 2.5mm universal Working Temperature: -4F (-20C) to 140F (60C) Storage Temperature: -40F (-40C) to 185F (85C) Power: 2 AAA Batteries VISUAL FAULT LOCATOR This pen style VFL is specially designed for field personnel who need a portable light source tool for fiber tracing, fiber routing, continuity testing, to locate breakpoints (bending or cracking in fiber optic cables), and poor connections. The VFL works in an OTDR dead zone and is used for endto-end visual fiber identification. Operates in either CW (continuous wave) or pulsed mode. Not recommended For use on dark colored or armored cables. JONARD P/N VFL-25 VFL-150 DESCRIPTION Visual Fault Locator and 2 AAA Batteries Visual Fault Locator Kit - Includes: VFL-25, 2 AAA Batteries, VFL-25125 FC/LC Adapter VFL-25125 FC/LC Adapter 13 Fiber Optic Tools THERMAL FIBER OPTIC STRIPPER FIXED BLADE Thermo-mechanically remove coatings from optical fibers. High strength thermal stripper supports standard 125µm optical fibers, including 250 µm, 400 µm, and 900 µm coated fibers. The heater is adjustable to 200°C and facilitates stripping difficult and baked-on coatings. Adjustable temperature and time settings to adapt to a variety of different coatings. Compact design, weighs less than a pound. Includes A/C power supply, cord and cleaning brush. Platforms supplied separately. TSAB-40 TSPE-125 TSUC-40 TSPF-125 For Fitel, Fujikura and Ericsson fiber holders use the corresponding platforms, for LDF and all others without fiber holders use the Jonard Universal Clamp. THERMAL FIBER OPTIC STRIPPER ADJUSTABLE BLADE Thermo-mechanically remove coatings from optical fibers. High strength thermal stripper with adjustable stripping blade, which supports cladding diameters 30µm to 1000 µm acrylate coated fibers with buffer diameters up to 1200 µm. The heater is adjustable to 200°C and facilitates stripping difficult and baked-on coatings. Adjustable temperature and time settings to adapt to a variety of different coatings. Compact design, weighs less than a pound. Includes A/C power supply, cord and cleaning brush. Platforms supplied separately. JONARD P/N DESCRIPTION TSPE-125 Ericsson Style Platform JONARD P/N DESCRIPTION TSPF-125 Fitel/Fujikura Style Platform TSFB-125 Thermal Stripper Fixed Blade TSUC-40 Universal Clamp TSAB-40 Thermal Stripper Adjustable Blade TSUC-510 TSUC-5000 ULTRASONIC CLEANER The Jonard Industries TSUC-5000, compact, low maintenance Ultrasonic Cleaner is a purpose-built ultrasonic fiber cleaner that has been designed specifically for fiber splicing applications. The unit comes with a power supply, power cord, alcohol dispenser and user manual. Easy to use, an audible and visual indicator will signify when the fiber should be removed. Versatile settings allow user to adjust for cycle duration and intensity levels for maximum results. Options include a solid lid to reduce evaporation, and custom rails that can be adapted to the most popular fiber holders such as Fitel, Fujikura and Ericsson. JONARD P/N TSUC-5000 TSUC-510 TSUC-512 TSUC-516 TSUC-518 TSUC-518 14 TSUC-516 TSUC-512 DESCRIPTION Ultrasonic Cleaner Ultrasonic Cleaner Cover Ultrasonic Cleaner 12mm Ericsson Rail Ultrasonic Cleaner 16mm Fitel Fujikura Rail Ultrasonic Cleaner 18mm Fitel Rail jonard.com Ӏ Fiber Optic Tools ERGONOMIC FIBER OPTIC KEVLAR® CUTTER High carbon stainless steel blades designed to cut Kevlar®, cabling insulation, tape, cable ties and other material. Ergonomic handles for user comfort and durability. Adjustable joint screw under protective cap, serrated blades grip material, sharp and durable 6” long. JIC-186 JONARD P/N DESCRIPTION JIC-186 Wire & Kevlar Cutting Shears COMMUNICATION SCISSOR High carbon stainless steel blades, 1/4" notch for cutting & stripping, two stripping notches for 18 & 22 AWG wire, one serrated non-slip blade, dual component handle. High carbon stainless steel blades that are both sharp and durable with serrated blade that grips and holds the wire. Ergonomic dual component nylon & santoprene handles, for user comfort and durability. Designed with an adjustable joint screw under the protective cap. JIC-195 SD-63 ST-500 JONARD P/N DESCRIPTION JIC-195 Communication Scissor SCREWDRIVER, JEWELER'S TYPE Used to terminate the battery backup in the fiber ONT. Screwdriver has concaved swivel knob to fit the finger and hexagonal shape to prevent rolling. Solid blade made of high quality hardened tool steel. .100" blade width. 4” long. JONARD P/N DESCRIPTION SD-63 Jeweler’s Screwdriver ADJUSTABLE PRECISION FIBER STRIPPER This adjustable stripping tool is designed to strip 0.3mm–1.0mm diameter cable. It is capable of stripping the 900 micron buffer coating from optical fiber cables. Made with specially hardened blades (RC58) for long life. Easy to use, just squeeze and pull. JONARD P/N DESCRIPTION ST-500 Adjustable Precision Fiber Stripper CABLE SLIT AND RING TOOL The CSR-1575 is designed to slit and ring UTP, STP, Coax and other cables, buffer tubes and Jackets on fiber optic cables up to 7.5mm (0.3”) in diameter. The tool features an easily adjustable slit blade and ring blade for nick-free strips. The removable/ reversible V block accommodates smaller and larger diameter cables. CSR-1575 JONARD P/N DESCRIPTION CSR-1575 Cable Slit and Ring Tool CSR-2 Replacement Blades – set of 2 15 Can, Booth, Security Wrenches CAN SOCKET WRENCH Double end can socket wrench, 3/8" and 7/16" hex, orange plastic handle in either our standard or ergonomic design. Used in placing fuses in cable terminals and connecting wires to fuses and binding posts. The walls on both sockets are thin enough so they can be used to work locking devices on most terminals and cabinets. 7" long. M-216C/EX JONARD P/N M-216C/EX M-216C/REX M-216C/REX M-216C/RX M-216CS22 M-216CKIT M-216C/RX DESCRIPTION Ergonomic 1” Dia. Handle, Hex Outer Socket Ergonomic 1” Dia. Handle, Round Outer Socket Standard Handle, Round Outer Socket Ergonomic 1” Dia. Handle, Hex Outer Socket with 22 AWG Stripper Blade Ergonomic 1” Dia. Handle, Hex Outer Socket with 22 AWG Stripper Blade Can Wrench and Security Key Insert SECURITY KEY INSERT Designed with a double-ended hex adapter for two sizes of pin-in-head security fasteners. Simply slip the key into the 3/8" side of a can wrench and you are ready for either a 5/16" or 5/32" hex security screw. This is a reversible insert tool. One end is for SLC Cabinets and the other is for most network interface boxes. M-216CS22 JONARD P/N SK-51632 M-216CKIT SK-51632 DESCRIPTION Security Key Insert BOOTH WRENCH Tamperproof hex screwdriver, also known as a booth wrench or security wrench. It features a 1" diameter screwdriver handle, 5/32" hex shaft with a hole drilled in the tip for use with security tamperproof screws used for telephone and CATV applications. BW-532 Booth Wrench is 9" long and the BW-532-3 Booth Wrench is 6" long. BW-532 JONARD P/N BW-532 BW-532-3 DESCRIPTION Booth Wrench -Ergonomic design 9” Booth Wrench -Ergonomic design 6” BW-532-3 T HANDLE SECURITY WRENCH 5/16” T handle tamper proof 5/16” wrench for use on tamper-proof cross-connect cabinets, MESA and CATV closures. Recessed at both ends and they are 1/4” deep. Red plastic handle for user comfort BW-516 16 JONARD P/N DESCRIPTION BW-516 T Handle Security Wrench HOLE DIA. 0.15” LENGTH RECESS 7.5” 1/4” jonard.com Ӏ Wrenches LINEMAN’S B WRENCH Forged and heat treated, this wrench is used on pole line hardware. It is open-end double-end type with two sizes of openings at each end and an oval hole for turning pole steps. The end openings accommodate nuts for 3/8”, 1/2”, 5/8” and 3/4” bolts and the head of the 1/2” drive screw. The faces of the wrench openings are offset to provide handle clearance. JIC-650 JONARD P/N DESCRIPTION JIC-650 Lineman’s B Wrench ADJUSTABLE WRENCHES WITH EXTRA WIDE JAW All wrenches are made of chrome vanadium steel with a chrome plated finish. Wrenches are forged and heat treated for greater strength. Handles are covered with a red transparent plastic for user comfort. The knurl is precision formed and the operation is smooth and trouble free. For accurate adjustments use the metric or English scales on either side of the jaws. AW-10 RF-12 JONARD PART NO. DESCRIPTION LENGTH JAW CAPACITY WEIGHT AW-6 Adjustable Wrench 6" 6" (152 mm) 15/16" (24mm) 5.2 oz AW-8 Adjustable Wrench 8" 8" (203mm) 1 1/8" (29mm) 10.6 oz AW-10 Adjustable Wrench 10" 10" (254mm) 1 5/16" (33mm) 14.6 oz AW-12 Adjustable Wrench 12" 12" (305 mm) 1 1/2" (38mm) 24.0 oz TK-6810 Wrench set-3 piece includes 6”, 8” & 10” F CONNECTOR TOOL Designed to provide easy access to connectors in high-density locations. The head measures 7/16” and is used specifically for “F” connectors and BNC connectors. The socket extends 8” from the handle, the overall length is 12” and the back of the handle has an insertion device to aid in making connections. Will also work with BNC connectors. JONARD P/N DESCRIPTION RF-12 F Connector Tool BNC CONNECTOR TOOL Designed to provide easy access to connectors in high density locations. The head is formed specifically for a wide variety of BNC connectors. The socket extends 8” from the handle and the overall length is 12”. RBNC-12 JONARD P/N DESCRIPTION RBNC-12 BNC Connector tool 17 CATV & Satellite Wrenches RATCHETING SPEED WRENCH Speed head makes tightening and loosening quick and easy while the ratcheting box end offers 12 points of contact. Polished to a high gloss finish and made of chrome vanadium steel. ASW-R716 - Combination wrench measures 7/16" at both ends. This is the perfect tool for cable and satellite installers. Designed to work on F Connectors, on splitters, and all 7/16" connections. ASW-R12 Combination wrench measures 1/2" at both ends. ASW-R716 ASW-R12 JONARD P/N DESCRIPTION ASW-R716 Ratcheting Speed Wrench 7/16" (works on F Connectors) 6 1/2” ASW-R12 Ratcheting Speed Wrench 1/2" 6 1/2” ASWS-R716 Ratcheting Speed Wrench 7/16” Stubby LENGTH 4” ASWS-R716 PATENTED ASW-716 ASW-916 SPEED WRENCH DOUBLE ENDED–PATENTED ASW-716 measures 7/16" at both ends. ASW-12 measures 1/2” at both ends and ASW-916 measures 9/16” at both ends. Speed head makes tightening and loosening quick and easy, plus head is angled (15°) to ease access. Speed wrenches are 6 1/2” long with a hole on the handle for a clip or other hanging device. High gloss chrome finish, and made of high carbon alloy steel. JONARD P/N DESCRIPTION ASW-12 Speed Wrench double Ended 1/2” 6 1/2” ASW-716 Speed Wrench double Ended 7/16” 6 1/2” ASW-916 Speed Wrench double Ended 9/16” 7 1/2” ASW-7916 Speed Wrench double Ended 7/16” + 9/16” 7 1/2” ASWS-716 Speed Wrench Double Ended 7/16” Stubby 4” LENGTH ASW-7916 ASWS-716 COMBINATION WRENCH Wrench measures 7/16” at both the open end and box end. Both ends have an angle offset (15°) to ease access in confined areas. The box end offers 12 points of contact. High gloss chrome finish and made of chrome vanadium steel. CW-716 18 JONARD P/N DESCRIPTION CW-716 Combination Wrench LENGTH WEIGHT 6 5/8” 2.88 oz jonard.com Ӏ CATV & Satellite Wrenches Full Head Speed Head TWAF-71620 TORQUE WRENCH Designed for "F" Connectors, these wrenches help prevent over tightening. An audible click tells you the connection has been properly achieved. These wrenches all have angle heads, and are designed with an ergonomic cushioned handle for user comfort and protection. The last two digits of the part number indicate the inch pounds of torque (either 20, 30 or 40 inch pounds) and the first four letters indicate whether the head is a speed head or a full head (TWAF is full and TWAS is speed). Note that these wrenches work in tightening mode only. Full Head - is a full size open end wrench that behaves like a traditional open end wrench. Speed Head - is designed to act like a ratcheting wrench. The tool skips over the corners of the bolt or nut being turned so no repositioning of the tool is required (allowing continuous turning). TORQUE WRENCHES 7/16” TWAS-71620 JONARD P/N DESCRIPTION TWAF-71620 TWAS-71620 TWAF-71630 TWAS-71630 TWAF-71640 Torque Wrench Full Head Torque Wrench Speed Head Torque Wrench Full Head Torque Wrench Speed Head Torque Wrench Full Head TORQUE TORQUE IN INCH-LBS IN NEWTON METERS 20 20 30 30 40 2.26 2.26 3.39 3.39 4.52 TORQUE WRENCHES 1/2” & 9/16” TWAFST-71630 JONARD P/N DESCRIPTION TORQUE TORQUE IN INCH-LBS IN NEWTON METERS TWAF-1220 Torque Wrench Full Head 1/2” 20 2.26 TWAF-91620 TWAF-91630 Torque Wrench Full Head 9/16” 20 Torque Wrench Full Head 9/16” 30 2.26 3.39 TORQUE WRENCH WITH SECURITY SHIELD ATTACHED Torque wrench is set at 30 in./lb. with security shield attached. Security shield measures 4 ¾” (120mm), is permanently attached and pivots in 90 degree increments. Ideal for hard to reach shielded F connector fittings where a pre-set torque is required. JONARD P/N DESCRIPTION TWAFST-71630 Torque Wrench with 7/16” Security Shield Attached TORQUE WRENCH SWIVEL HEAD Used to properly torque cable shield bond connectors and other ground connections. Head swivels 90° in 2 directions and is factory set for 40 in./Lb. Can be used with any 3/8” drive sockets. Audible click when proper torque is achieved. JONARD P/N TWSW-40 TWSW-40 TWS-38/10 DESCRIPTION Torque Wrench Swivel Head 40 inch pounds 3/8” Socket for TWSW-40 (Pkg. of 10) TWS-38 19 CATV & Satellite Terminator & Locking Tools TT-7 TERMINATOR TOOLS Tool is used for various locking terminators including the Gilbert Engineering GTP (Morlock), PRC (Production Products Company), LFT, PCT (International Technology), TPG, TR 75 GTL (Viewsonics), and SVLT & SV-LTA (Signal Vision) locking terminators. Ergonomic handle provides greater leverage and a superior grip. Available in three sizes 4 1/2", 8", and 9" Pronged locking terminators. Ergonomic handle provides greater leverage and a superior grip. JONARD P/N TT-4 TT-7 TT-7V TT-7V TT-4 DESCRIPTION Terminator Tool 2 1/2” shaft, overall length 4 1/2” Terminator Tool 4” shaft, overall length 8” Pronged Terminator Tool 4” shaft, overall length 9” CAM STYLE LOCKING TERMINATOR TOOL A Cam Style locking terminator tool for Corning Gilbert style terminators. Works on Gilbert NS-5762-3 (plus -9, -11, -13 & -15 terminators). High quality aluminum construction, blue color. TTCG-6270-5 JONARD P/N TTCG-6270-5 TTCG-6270-9 DESCRIPTION Locking Terminator Tool Locking Terminator Tool LENGTH 5 inches 9 inches WEIGHT 1.75 oz 7.50 oz TTCG-6270-9 BARREL LOCK PLUNGER KEY This barrel lock plunger key is compatible with several types of Highfield and Innertite barrel locks with inside diameters ranging from 0.176” to 0.196”. Key is made of high carbon steel with smooth plunger and heavy duty spring for strength and durability. Serialized for added protection for authorized personnel only. JONARD P/N TTB-6 TTB-6 TTK-225 P KEY FOR SELF LOCK PEDESTAL LOCK This P Key is designed to work with Channell Locks and other similar pedestal locks. This P key fits many popular pedestals and opens most heavy duty spring lock cabinets. Also referred to as a skeleton key, made of brass and fits easily on a key chain. JONARD P/N TTK-225 20 DESCRIPTION Barrel Lock Plunger Key DESCRIPTION P Key for Self Lock Pedestal Locks LENGTH WEIGHT 2.25" 0.75 oz 20 jonard.com Ӏ CATV & Satellite Tools SST-716AT SECURITY SHIELD TOOL 7/16” Used with 7/16" hex shielded F Connectors. Design includes extended 7/16" shank for ease of use with Torque Wrenches in security shield applications. Machined and heat-treated steel for maximum durability with black oxide finish. Knurled handle for secure gripping and includes a steel loop for turning leverage and carrying. Note: SST-716AT is designed for use where security shield applications for PPC AquaTight® EX Series and Gilbert GF URS-6 connectors are used. SST-716 SST-916 TTS-716 SECURITY SHIELD TRAP TOOL 9/16” Used with 9/16” Hex shielded F connectors (RG11 connectors). Machined and heat treated high carbon steel for maximum durability with nickel plated finish. Loop attachment to allow for connecting to your key ring or carabiner for easy access. Shaft Length 1.625” JONARD P/N DESCRIPTION SST-716 SST-716AT SST-916 Security Shield Tool 7/16” Security Shield-Aqua Tight Tool Security Shield Tool 9/16” TRAP SECURITY COMBO TOOL Two tools in one - a trap wrench with a security wrench. The perfect tool for all standard traps and equally adaptable for all sizes of metal security shields (The security wrench fits all metal 7/16" hex fittings). Made of lightweight aluminum with a security socket made of hardened steel for longer life. Lightweight just 2 oz. (57g) and just 7 1/2" long JONARD P/N TTS-716 DESCRIPTION Trap Security Combo Tool LENGTH 7.5" WEIGHT 2 oz FUSE PULLER PLIERS Designer for installing and extracting fuses from line amplifiers and other cylindrical shaped components including heat coils. The thin nosed jaw allows easy access to tight restricted areas. Handle is yellow colored plastic. JONARD P/N FP-600 FP-600 LENGTH JAW LENGTH JAW WIDTH JAW THICKNESS WEIGHT 5” 1 13/16” 1/2” 5/16” 3.4 oz FLARING & INSERTION TOOL The flaring end of the tool facilitates the expansion of the cable providing easier insertion of “F” connectors. The insertion end makes “F” connector insertion fast and easy, even in cold weather. This tool is recommended for use on polyethylene jacketed cables and plenum cables, and is especially helpful when using tri-shield and quad-shield cables. 4 1/4” long FT-6 JONARD P/N DESCRIPTION FT-6 Flaring & Insertion Tool 21 CATV & Satellite Cable Stripping Tools UNIVERSAL CABLE STRIPPING TOOL Use for Coax, Round Network Cables and Flat Cables - This versatile tool is five tools in one. Simply reverse the blade for RG59/6 & 7/11 Coax Cables. Insert the Round Cable into the second hole (adjustable) for a fast and easy strip. Will strip CAT6 cables with outside diameter up to 0.250". The third hole is for cutting all styles of cable while the fourth hole is designed for Flat Cable and 4P/6P style cable. The perfect wire stripper for most stripping applications. Includes Velcro strip for holding back the braided shield of the cable. UST-500 JONARD P/N UST-500 UST-525 UST-596 UST-205 UST-210 UST-215 UST-220 UST-225 UST-215 UST-205 BLADE DESCRIPTION INCLUDED Coaxial Cable Stripper (RG59/6 & 7/11) UST-205 Coaxial Cable Stripper with cable stop UST-225 Universal Cable Stripping Tool (59/6) UST-210 REPLACEMENT BLADES Repl Blade for RG59/6 & 7/11 Repl Twin Blade RG59/6 with Cable Stop. Repl Blade for RG59/6 with Cable Stop & Untwisted Pair Repl Blade for UST-175 Mini-coax only Repl Blade for RG59/6 & RG7/11 with Cable Stop UST-210 UST-225 JONARD P/N UST-100 UST-125 UST-150 UST-100 UST-150 UST-175 22 DESCRIPTION Coaxial Cable Stripper (RG59/6 & 7/11) Coaxial Cable Stripper with UST-225 Blade Coaxial Cable Stripper with UST-215 Blade BLADE INCLUDED UST-205 UST-225 UST-215 UST-175 Mini-Coaxial Cable Stripper UST-220 UST-1596 Coaxial Cable Stripper (59/6) w/Twin Blade UST-210 MINI-COAX CABLE STRIPPER The UST-175 is a three level coax stripper for mini-coax cables (CommScope73508, Belden 735A1 and similar cables). The mini strips 0.625” of the outer jacket in the first level, the second level strips the braid exposing 0.156” of dielectric, and the third level strips the dielectric exposing 0.156” of the 26 AWG center conductor. Includes Velcro strip for holding back the braided shield of the cable. UST-1596 UST-220 COAXIAL CABLE STRIPPER TOOL The UST 100 Series strips a multitude of cables. Virtually all the blades are interchangeable with the exception of the UST-220. This blade is matched exclusively to the UST-175 handle. For replacement blades or complete tools see table above. Includes Velcro strip for holding back the braided shield of the cable. JONARD P/N DESCRIPTION UST-175 UST-220 Mini-Coax Cable Stripper Replacement Blade for the UST-175 jonard.com Ӏ Compression & Crimping Tools UNIVERSAL COMPRESSION TOOL CT-200 This universal compression tool is designed for use on F Connectors (RG59, RG6, & RG11), BNC Connectors (RG59 & RG6) and RCA Connectors (RG59 & RG6). BNC connectors must be over 1.5” in length. Tool is designed with a dual head and adjustment dial for each unique connector application. COMPATIBLE CONNECTORS: PPC - CMP6, CMP62, CMP59Q, CMP11, EX6XL, EX59XL, EX59XLHE, EX6XLW9, EX7, EX7N716, EX11, EX11N716, EX320QR, EX320N716. T & B - Snap -n-Seal Digicon - DS6, DS59, DS59Q, DS11, DS7 Gilbert UE - GF-UE-59, GF-UE-59Q, GF-UE-6, GF-UE-6Q, GF-UE-5.1, RCA-UE, BNC-UE Plus many other brands and styles including F, RCA & BNC Types. CT-200 FIXED COMPRESSION TOOL CFT-200 Compression tool with a fixed design for use on many manufacturers longer style F Connectors. Some compatible connectors are Thomas & Betts: Snap-N-Seal, Digicon: DS6, DS59, DS6Q, DS59Q, DS11, DS7, Gilbert UltraEase: GF-UE-59, GF-UE-59Q, GF-UE-6, GF-UE-6Q, GF-UE-5.1, PPC: CMP6, CMP6Q, CMP59, CMP59Q, CMP11, EX6XL, EX59XL, EX59XLHE, EX6XLWS, EX6LP, EX7, EX7N716, EX11, EX11N716, EX320QR, EX320N716 CTF-200 FIXED COMPRESSION TOOL CTF-300 Compression tool with a fixed designed for use on the shorter style F connectors (Such as PPC® Aquatight Connector EX or shorter connectors and other similar length connectors). PPC: EX6/59, EX6W9, EX59HE, EX6P, EX7, EX7N716, EX11, EX11N716, EX320QR, EX320N716 CTF-300 PATENTED UC-864 JONARD P/N DESCRIPTION CT-200 CTF-200 CTF-300 Universal Compression Tool Fixed Compression Tool - for longer style F connectors Fixed Compression Tool - for shorter style F connectors MODULAR CRIMPING TOOL This modular crimping/stripping connector tool for voice and data applications. Designed to cut, strip and crimp paired conductor cables (round STP/UTP and flat satin phone cables). Crimps: 4, 6, 8, position modular connectors (RJ22, RJ11, RJ45) JONARD P/N DESCRIPTION UC-864 Modular Crimping tool 6 in 1 23 CATV Testing & Satellite Tools MCT-468 MODULAR CABLE TESTER The MCT-468 is designed to check and troubleshoot the pin connections of cables with RJ45, RJ11 and RJ12 connectors. It is also ideal for testing the continuity of these cables prior to installation. FEATURES INCLUDE: 1. Can test RJ45 and RJ11 and RJ12 connected cables. 2. Tests for opens, shorts and miswiring. 3. Full LED indication lights on both main and remote unit 4. Auto tests when switched on. Move switch to S to slowdown auto test feature for greater visibility. 5. Small size and lightweight 6. Carrying case and 9V battery included MTC-468 JONARD P/N DESCRIPTION MCT-468 Modular Cable Tester CABLE MAPPER & TONER - CM-8 FIND & IDENTIFY MULTIPLE COAX CABLES IN MAIN CABLE BOXES For use on Coax Cables for CATV, Satellite Installations, Audio Video Equipment, CCTV and Security & Alarm Installations. The CM-8 Coax Cable Mapper & Toner is designed to quickly find and identify multiple cables and easily map runs to and from a central cable bundle. FEATURES INCLUDE: 1. Eight numbered & color coded cable identifiers. #1 White, #2 Red, #3 Black, #4 Blue, #5 Green, #6 Yellow, #7 Purple & #8 Brown. 2. Two Alligator clip sets 1x F-Male coax adapter 1x F-Female coax adapter 3. Built-in tone generator 4. Auto power off 30 minutes in "Tone" mode CM-8 5. Test for Opens and shorts 6. Auto power off 12 seconds after Pass/Fail results 7. Maximum cable length for testing 5,000 feet 8. Powered by two 3V CR2032 batteries 9. Low battery warning light 10. Maximum DC cable resistance 100 Ohms CM-8 Kit contains: 11. Live Voltage detection Cable Mapper & Toner 8 Cable Identifiers NOTE: This Cable Mapper & Toner will not test (Numbered & color coded) cable runs with AC or DC voltage present, 2 Alligator Clip Sets Power Amplifiers, Isolation Splitters, Cordura Case Attenuators, Directional Line Tap, Power Instruction Sheet CMI-SET8 CM-17 Kit contains: Contents of the CM-8 kit 9 RJ45 connectors CMI-RJ45 24 Dividers or Matching Transformers & DC blocking devices JONARD P/N CM-8 DESCRIPTION Cable Mapper & Toner CMI-SET8 8 Cable Identifiers (Numbered & Color Coded) CM-17 CMI-RJ45 Cable mapper and tower for Coax and LAN Nine RJ45 adapters jonard.com Ӏ CATV Testing & Satellite Tools MULTI-FUNCTION CABLE TESTER TONER & PROBE KIT Ideal for VDV (voice – data – video) professionals in telecommunications, network and digital communications. This is a multi-function cable tester for RJ45 LAN cable, BNC/F coaxial cable, 6P2C/4P2C jacks and provides tone generation. Kit includes: cable tester, tone tracing probe, (2) BNC male to F female connectors, BNC cable terminator 50Ω, RJ45 jumper, two 9V batteries, nylon bag, belt clip, user’s manual TETP-900 PT-300 JONARD P/N TETP-900 DESCRIPTION Multi-Function Cable Tester Toner & Probe Kit TET-700 Multi-Function Cable Tester & Toner TEP-200 Tone Tracing Probe TET-6 Accessory Kit for TET-700 POCKET CONTINUITY TESTER AND TONER Drop cable continuity tester - accurate up to 5,000 feet (1,500 m). Identify cables in an MDU, and detect troublesome short circuits. FEATURES 1. Loud tone identifies line carrying signal 2. LED light indicates splitters, DC shorts and other self grounding devices in cable 3. Right angle male push-on connector for working in confined areas 4. Accurate up to 5,000 feet (1,500 m) 5. Common AAA battery for operation 6. Voltage protected to 52V DC 7. Just 5" long, weighs 2 oz. (57 g) 8. Built in on/off switch Comes complete with LED light indicator, detachable tone detector, female push-on connector and 1.5V AAA battery. PT-350 JONARD P/N PT-300 DESCRIPTION Pocker Continuity Tester and Toner PT-350 Pocker Tester Replacement Speaker UNIVERSAL CRIMPER This fully ratcheted crimper is designed for minimal closing force (higher crimp force). DESCRIPTION UC-8012 Universal Crimper with COAX Die F4 .350 .139 .134 .324 .178 .151 .058 .252 F4 JONARD P/N .190 UCD-2045 UC-8012 JONARD P/N UCD-2045 COAX DIE SPECIFICATIONS CABLE SIZE .068”/.262”/.324”/.360” CATV “F” Connectors 1.73mm/6.65mm/8.23mm/9.14mm RG59/RG6 25 CATV & Satellite Tool Kits FIVE PIECE TELECOM INSTALLERS KIT The perfect kit for simple installations–includes the basic necessities. Kit includes the M-216CS22 Can Wrench, KN-7 Ergonomic Cable Splicing Knife, ES-1964 Electrician’s Scissors, JIC-22035 Spudger and the H-50 Pouch made of durable PVC material with metal clip. ES-1964 H-50 KN-7 JONARD P/N TK-50 H-50 KN-7 M-216CS22 JIC-22035 ES-1964 DESCRIPTION Five Piece Telecom Installers Kit Plastic Molded Pouch Ergonomic Cable splicing Knife Can Wrench with 22 AWG wire stripper Probe Pick Spudger Electrician Scissor TK-50 M-216CS22 JIC-22035 TELEPHONE INSTALLER SPLICER KIT Designed for stripping, splicing and crimping. The perfect kit for telephone installers. Kit contains the ES-1964 Electrician’s Scissors, JIC-22148 Combo Crimper Long Nose Plier and the H-36 Pouch made of durable PVC material with metal clip. JONARD P/N TK-22148 H-36 JIC-22148 ES-1964 TK-22148 H-36 JIC-22148 ES-1964 DESCRIPTION Telephone Installer Splicer Kit Plastic Molded Pouch Combo Crimper Long Nose Plier Electrician Scissor SPLICER’S KIT This compact kit contains an ergonomic splicers knife, scissor and leather pouch. The knife features a 1 3/4” tough, cutlerysteel blade and a non-slip handle. The scissors are made of high carbon steel with scraper and file on one side and 2 stripping notches on the other. Both items fit securely in the leather pouch which can be mounted on belts up to 2” wide. TK-400 ES-1964 KN-7 H-40 JONARD P/N DESCRIPTION TK-400 H-40 KN-7 ES-1964 3 Piece Splicer’s Kit Leather Pouch Ergonomic Cable Splicing Knife Electrician Scissor FIBER KIT WITH KEVLAR CUTTER Kit includes the JIC-375 Fiber Optic Stripper Three Hole, JIC-186 Ergonomic Fiber Optic Kevlar Cutter and the convenient H-60 molded plastic pouch with metal clip. TK-350 26 JIC-375 H-60 JIC-186 JONARD P/N DESCRIPTION TK-350 Fiber Kit with Kevlar Cutter H-60 Plastic Moulded Pouch JIC-375 Fiber Optic Stripper- 3 Hole JIC-186 Ergonomic Fiber Optic Kevlar Cutter jonard.com Ӏ CATV & Satellite Tool Kits COAX TOOL KITS A CATV technician’s service kit designed for repair and maintenance of CATV cable networks JONARD PART NO. TK-82 TK-83 TK-85 TK-82 DESCRIPTION Coax Tool Kit with CTF-200 Compression Tool – Long Style Coax Tool Kit with CTF-300 Compression Tool – short style Coax Tool Kit with CT-200 Compression Tool – Universal Each Kit Contains: TK-83 TK-85 TWAF-71630 SD-61 CT-200 (for kit TK-85) JIC-2288 JONARD PART NO. DESCRIPTION FL-2000 JIC-2288 SD-61 PT-300 TWAF-71630 UST-125 H-85 CT-200 CTF-200 CTF-300 Flashlight High Leverage Diagonal Cutter Screwdriver 6-in-1 Pocket Continuity Tester & Toner Torque Wrench 7/16” 30 in./lb. Cable Stripper RG59/6 cable stop Pouch Universal Compression Tool Compression Tool–Long Style Compression Tool–Short Style FL-2000 CFT-200 (for kit TK-82) UST-125 TK-82 TK-83 TK-85 X X X X X X X X X X X X X X X X X X X X X X X X PT-300 H-85 CFT-300 (for kit TK-83) 27 CATV & Satellite Tool Kits NETWORK INSTALLATION SERVICE KIT The affordable and reliable punchdown tool kit that features six tools performing over 21 functions to complete any installation or repair. Kit contains: EPD-914116 punchdown tool with 66 & 110 blades, UST-500 multipurpose Universal Cable Stripping Tool, ES-1964ERG Ergonomic Electrician Scissor, JIC-22035 Spudger, M-216CS22 Can Wrench with 22 AWG Wire Stripper, JIC-22148 multipurpose needle nose crimping plier with cutter and the H-1000 Cordura Pouch. JONARD P/N TK-21 DESCRIPTION TK-21 Network Installation Service Kit M-216CS22 JIC-22148 UST-500 JIC-22035 EPD-914116 1964-ERG CATV/TELECOM INSTALLERS KIT Assembled in a convenient, easy to carry Cordura case, this kit contains the basic service tools essential for equipment installation, repairs and cable preparations. Whether it's Fiber Optic, Coax, or Copper this versatile kit contains the perfect tools for today's demanding technician. The TK-450M Kit is perfect for the VOIP installer, Fiber Technician or Communications Specialist and comes with Jonard's lifetime warranty. Each Kit contains: ASW-716, CT-200, UST-500, ES-1964, KN-7, JIC-683, JIC-22148, JIC-22035, JIC-1626, JIC-750, TWAF-71630, M-216CS22, SK-51632, TT-7V, SST-716, PT-300 & secured in a convenient easy to carry Cordura case. TK-450M UST-500 ES-1964 JIC-22035 28 CT-200 JIC-1626 M-216CS22 KN-7 JIC-683 JIC-750 SK-51632 H-1000 JONARD P/N DESCRIPTION TK-450M CATV/Telecom Installers Kit ASW-716 JIC-22148 TT-7V SST-716 PT-300 TWAF-71630 jonard.com Ӏ Scissors & Knives FREE-FALL ELECTRICIAN’S SCISSOR A Free-Fall Electrician's Scissor, designed for heavy duty use and loose enough to allow fingertip operation. Drop forged High Quality steel for greater durability. Notched to strip 18-20 and 2224 AWG wire and one blade is serrated. A scraper and file are on the back of the blade. ES-1964DS JONARD P/N DESCRIPTION ES-1964DS Free-Fall Electrician's Scissor ELECTRICIAN SCISSOR The Electrician Scissors are designed for heavy duty use. Made of high carbon steel with a special hardening process for greater durability and nickel plated for that professional look. Notched to strip 18-20 and 22-24 AWG wire and one blade is serrated. A scraper and file are on the back of the blade. ES-1964 JONARD P/N DESCRIPTION ES-1964 Electrician Scissor ERGONOMIC ELECTRICIAN SCISSOR These Ergonomic Electrician scissors are designed for heavy duty use. Made of high carbon steel with a special hardening process for greater durability and nickel plated for that professional look. Notched to strip 18-20 and 22-24 AWG wire and one blade is serrated. A scraper and file are on the back of the blade. JONARD P/N DESCRIPTION ES-1964ERG Ergonomic Electrician Scissor ES-1964ERG KNIFE & SCISSOR SHARPENER Sharpen knives and scissors with one convenient sharpener. Made of high-grade tungsten-carbide steel and diamond polished. Will restore the edge on either scissors or knives with 3-4 simple strokes. Safety finger guard, lightweight compact design makes this the ideal tool for all your sharpening needs. KSS-1 JONARD P/N DESCRIPTION KSS-1 Knife & Scissor Sharpener SPLICER’S KIT This compact kit contains an ergonomic splicers knife, scissor and leather pouch. The knife features a 1 3/4” tough, cutlery-steel blade and a non-slip handle. The scissors are made of high carbon steel with scraper and file on one side and 2 stripping notches on the other. Both items fit securely in the leather pouch which can be mounted on belts up to 2” wide. TK-400 ES-1964 KN-7 H-40 JONARD P/N DESCRIPTION TK-400 H-40 KN-7 ES-1964 3 Piece Splicer’s Kit Leather Pouch Ergonomic Cable Splicing Knife Electrician Scissor 29 Scissors & Knives ERGONOMIC FIBER OPTIC KEVLAR® CUTTER High carbon stainless steel blades designed to cut Kevlar®, cabling insulation, tape, cable ties and other material. Ergonomic dual component handles polypropylene and TPR for user comfort and durability. Adjustable joint screw under protective cap, serrated blades grip material, sharp and durable 6” long. JIC-186 JONARD P/N DESCRIPTION JIC-186 Wire & Kevlar Cutting Shears TK-325 JIC-186 Scissor & Pouch with Belt Clip H-25 Pouch Only for JIC-186 or JIC-195 TK-325 HEAVY DUTY SCISSOR WITH WIRE STRIPPER Heavy duty multi-function scissor designed to cut copper, aluminum, leather, plastic and other materials. Not designed to cut stainless steel or other hardened/heat treated metals. Three stripping holes for 18, 14 & 12 AWG wire. One blade serrated for a secure grip and handles are dual component polypropylene and TPR. Includes safety locking mechanism and adjustment screw. JONARD P/N DESCRIPTION JIC-183 Heavy Duty Scissor with Wire Stripper JIC-183 COMMUNICATION SCISSOR High carbon stainless steel blades, 1/4" notch for cutting & stripping, two stripping notches for 18 & 22 AWG wire, one serrated non-slip blade, dual component handle. High carbon stainless steel blades that are both sharp and durable with serrated blade that grips and holds the wire. Ergonomic dual component nylon & santoprene handles, for user comfort and durability. Designed with an adjustable joint screw under the protective cap. JONARD P/N DESCRIPTION JIC-195 Communication Scissor JIC-195 CABLE SPLICING KNIFE The tough cutlery steel blade is extremely sharp and cuts easily through many types of insulation. It holds its edge with repeated use and features a non-slip easy grip handle for better control and reduced hand fatigue. Blade length is 1 3/4” and overall length is 6 1/4”. JONARD KN-7 30 JONARD P/N DESCRIPTION KN-7 Cable Splicing Knife jonard.com Ӏ Punchdown Tools EPD SERIES PUNCHDOWN TOOLS Sleek ergonomic design for easy effective wire termination. Tested up to 100,000 cycles at high-impact setting. Use to properly set, seat and terminate wire. Simply position the wire, push tool, and listen for confirming pop. Wire is properly seated. Features include: • • • • • EPD-91461 Hi/Low impact setting Combination Hook/Spudger stored in the chassis Color coded yellow on the CUT side Enlarged blade storage compartment Lifetime Warranty (Essentially means unlimited impacts) JONARD PART NO. DESCRIPTION EPD-914 EPD-91466 EPD-914110 Punchdown Tool Punchdown Tool with 66 Blade Punchdown Tool with 110 Blade EPD-914KR EPD-914116 EPD-91461 EPD-9Krone EPD-914630 Punchdown Tool with Krone Blade Punchdown Tool with Combination Blade 66 & 110 Punchdown Tool with two Blades 66 & 110 Punchdown Tool with the EPB-Krone Blade Punchdown Tool with 630 Modified Jack Blade EPB STANDARD DOUBLE-ENDED BLADES EPB-66 EPB-110 EPB-116 EPB-KR JIC-22148 SD-61 TK-17 EPD-914116 FL-2000 Kit contains: CST-1i Cyclops UTP/STP Cable Stripper EPD-914 Punchdown Tool EPB-66 Punchdown 66 Blade with & without cutter EPB-110 Punchdown 110 Blade with & without cutter FL-2000 LED Flashlight with Zoom Lens JIC-22035 Probe Pick Spudger JIC-22148 Combo Crimper Long Nose Plier SD-61 6-In-1 Screwdriver H-75 Molded Pouch EPB-630 EPB-KRONE JIC-22035 JONARD PART NO. DESCRIPTION EPB-66 66 Blade with & without cutter EPB-110 110 Blade with & without cutter EPB-116 Combination 66 & 110 blade EPB-KR Krone Blade with & without cutter EPB-630 Blade for 630 Modified Jack EPB-KRONE Krone blade scissor style CST-1i EPB-66 EPB-110 H-75 PUNCHDOWN TOOL KIT An ideal combination of tools for electrical technicians, main frame telecommunications professionals, security & alarm and datacom professionals. Kit includes: punchdown tool with 66 & 110 blades, Ergonomic Electrician scissor, LED Flashlight with zoom lens, spudger, multi-bit screwdriver, Cyclops wire & cable stripper, Combo crimper long nose plier and convenient pouch JONARD P/N TK-17 DESCRIPTION Punchdown Tool Kit 31 Punchdown Tools TERMINATION & REMOVAL TOOL This tool is used for terminating, bridging, and removing wires from 2-beam or 3-beam, insulating-slicing, quick clip terminals found on QCM468 (MPC) and 391Q connectors and on Versablocks with quick-clip pins. JONARD P/N EP-QTH38B DESCRIPTION EP-QTH38B Patent Pending Termination & Removal Tool NON-IMPACT PUNCHDOWN TOOL A non-impact punchdown tool. Perfect for do-it-yourself small jobs on a 110 terminal block. Fits neatly in the palm of your hand. Quickly and easily switch from cutting and non-cutting blade side with one hand. Simple - Fast - Easy. JONARD P/N ENI-110 ENI-110 DESCRIPTION Non-Impact Punchdown Tool BIX PUNCHDOWN TOOL This tool is designed to terminate cables, pigtails, and jumper wires on all GigaBIX, BIX and UMOXS cross-connect system connectors. This single action, spring activated tool will terminate 22-26 AWG plastic insulated solid copper conductors. Button on the handle adjusts the tool for seating only, or for seating and cutting the conductors. JONARD P/N EP-16A EP-16A DESCRIPTION BIX Punchdown Tool QUICK CLIP INSERTION TOOL This multipurpose wire insertion tool performs several vital functions. The wire cutter is designed to cut 22 & 24 gauge wire, the hook at the back of the tool is used for both jumper and back-tap removal, and the bit inserts 22 or 24 gauge (0.5 mm or 0.6 mm) wire into the terminal block. Ideal for wire insertion in 3-beam (112 type blocks) and 4 beam (78 type blocks) terminals in Cosmic and Cosmic II distributing frames. JIC-950C BATTERY PUNCHDOWN TOOL JONARD P/N JIC-950C DESCRIPTION Quick Clip Insertion Tool JIC-955 JIC-950C Replacement Blade Features: • Over 1,000 impacts between charges • Dual action trigger for LED task lighting and impact • Quick-easy blade lock and release PATENTED EPB-1000 ACCESSORIES JONARD PART NO. EPB-B 32 DESCRIPTION EPB-1000 Lithium Ion Battery EPB-BC1 EPB-1000 115V Battery Charger EPB-BC2 EPB-1000 230V Battery Charger • 90º Blade orientation adjustment for any angled impact • Hi/Low impact settings easily adjusted • Powerful, lightweight 7.2V lithium ion battery • Quick charge battery charger JONARD PART NO. DESCRIPTION EPB-1200 EPB-1066 EPB-1110 EPB-11066 EPB-1000KR EPB-2200 EPB-2066 EPB-2110 EPB-211066 EPB-2000KR Punchdown Tool, Battery, 115V Charger (no blades included) Punchdown Tool, Battery, 115V Charger, 66 blade Punchdown Tool, Battery, 115V Charger, 110 blade Punchdown Tool, Battery, 115V Charger, 110 & 66 blades Punchdown Tool, Battery, 115V Charger, Krone blade Punchdown Tool, Battery, 230V Charger (no blades included) Punchdown Tool, Battery, 230V Charger, 66 blade Punchdown Tool, Battery, 230V Charger, 110 blade Punchdown Tool, Battery, 230V Charger, 110 & 66 blades Punchdown Tool, Battery, 230V Charger, Krone blade jonard.com Ӏ Screwdrivers Jonard Slotted, Phillips and Robertson Screwdrivers are made of special alloy steel for exceptional strength, long life and corrosion resistant. Soft rubber handles offer comfort and greater torque. The end of the handle is marked to identify the tool's size, and the tips are magnetic. Meets and exceeds applicable ASME/ANSI specifications. 6-IN-1 SCREWDRIVER The Jonard 6-in-1 Screwdrivers eliminate the need for multiple tools in your belt. This tool is configured to include: 2 bits with four heads and two nut drivers 5/16” & 1/4” JONARD P/N DESCRIPTION BITS INCLUDE SD-61 6-in-1 Screwdriver SD-RB1, SD-RB2, SD-1223 6-in-1 Robertson Screwdriver SD-RB1, SD-RB3 6-in-1 REPLACEMENT BITS JONARD P/N SD-RB1 SD-RB1 SD-RB2 SD-RB2 SD-RB3 DESCRIPTION Replacement Bit Phillips #1 & Slot 3/16" Replacement Bit Phillips #2 & Slot 9/32" Replacement Bit Robertson S1 & S2 OVERALL LENGTH SHAFT WEIGHT DIAMETER 3" 0.42 oz 1/4” HEX 3" 0.42 oz 5/16” HEX 2 1/2" 0.78 oz 1/4” HEX SLOTTED SCREWDRIVERS SD-RB3 SDC-3136 SLOTTED P/N SDC-3163 SDC-3166 SDC-144 SDC-3810 SDC-5166 DESCRIPTION Slotted 3/16"x 3" Slotted 3/16"x 6" Slotted 1/4"x 4" Slotted 3/8"x 10" Slotted 5/16"x 6" OVERALL LENGTH 6 3/4" (87mm) 9 3/4" (248mm) 8 11/32" (212mm) 14 3/8" (365mm) 10 3/8" (264mm) WEIGHT 1.6 oz 2.4 oz 4.0 oz 10.0 oz 5.6 oz DESCRIPTION Phillips #1 x 3" Phillips #2 x 4" Phillips #3 x 6" OVERALL LENGTH 6 3/4" (171mm) 8 5/16" (211mm) 11" (279mm) WEIGHT 2.4 oz 4.0 oz 5.6 oz PHILLIPS PHILLIPS P/N SDP-1 SDP-2 SDP-3 SDP-1 33 Screwdrivers ROBERTSON SCREWDRIVERS JONARD P/N SDC-24 SDC-34 DESCRIPTION Robertson #2 x 4" Robertson #3 x 4" OVERALL LENGTH 8 1/2" (216mm) 8 1/2" (216mm) WEIGHT 3.8 oz 3.8 oz OVERALL LENGTH 3 1/2" (89mm) 3 1/2" (89mm) WEIGHT 1.9 oz 1.9 oz SDC-34 STUBBY SCREWDRIVERS JONARD P/N SDSP-2 SDSC-14 SDSP-2 DESCRIPTION Phillips #2 Stubby Slotted 1/4" Stubby SDSC-14 EIGHT PIECE SCREWDRIVER SET KIT CONTAINS: • SDSP-2 Phillips #2 stubby • SDSC-14 Slotted 1/4" Stubby • SDP-1 Phillips #1 x 3" • SDC-3163 Slotted 3/16" x 3" • SDP-2 Phillips #2 x 4" • SDC-144 Slotted 1/4" x 4" • SDP-3 Phillips #3 x 6" • SDC-5166 Slotted 5/16" x 6" SDK-8 JONARD P/N DESCRIPTION SDK-8 8 Piece Screwdriver Set SCREWDRIVER, JEWELER'S TYPE Used to terminate the battery backup in the fiber ONT. Screwdriver has concaved swivel knob to fit the finger and hexagonal shape to prevent rolling. Solid blade made of high quality hardened tool steel. .100" blade width. 4” long. JONARD P/N DESCRIPTION SD-63 Jeweler’s Screwdriver SD-63 24 INCH LONG #3 PHILLIPS HEAD SCREWDRIVER This 24" long #3 Phillips Head Screwdriver is designed for use when you need an extra long screwdriver to reach the diodes in back of the various rectifiers. Made of chrome vanadium steel with a matte finish and a custom ergonomic tri-color handle. SD-243 34 JONARD P/N DESCRIPTION SD-243 #3 Philips Head Screwdriver 24” long jonard.com Ӏ Insulated Tools Jonard Insulated Tools are manufactured to IEC 60900 Standards for hazardous work environments. Our tools are tested to 10,000 VAC and rated for 1,000 VAC live use. JONARD P/N TK-70INS 1000V IEC 60900 DESCRIPTION 7 Piece Insulated Screwdriver Set Screwdriver Set contains: 3 Philips, 4 Slotted as shown below INSULATED SCREWDRIVERSSLOTTED HEAD JONARD P/N INS-475 INS-4100 INS-6150 INS-8175 DESCRIPTION 3/32 X 3 Slotted Screwdriver 5/32 X 4 Slotted Screwdriver 1/4 X 6 Slotted Screwdriver 5/16 X 7 Slotted Screwdriver INSULATED SCREWDRIVERSPHILLIPS HEAD TK-70INS JONARD P/N INS-180 INS-2100 INS-3150 JONARD P/N TK-110INS DESCRIPTION #1 X 3 Phillips Screwdriver #2 X 4 Phillips Screwdriver #3 X 6 Phillips Screwdriver DESCRIPTION 11 Piece Insulated Tool Kit Kit contains: 7 Screwdrivers in kit TK-70INS plus INP-1072, INP-2065, INP-3062 & INP- 4065 INSULATED PLIERS JONARD P/N INP-2065 INP-3062 INP-1072 DESCRIPTION Long Nose Plier 6 1/2” Long Diagonal Plier 6 1/4” Long Lineman’s Combo Plier 7 1/4” Long INSULATED WIRE STRIPPER JONARD P/N INP-4065 DESCRIPTION Wire Stripper 6 1/2” Long TK-110INS 35 Electrical Tools SMARTPHONE & TABLET REPAIR TOOL KIT For opening and repairing all series of smartphones, tablets and many "i" series computers (iPhones & iPads). Kit contains all the tools you need to take apart these highly specialized electronic devices. Perfect for DIY repair jobs. Tools are neatly organized and labeled in a convenient storage case. This kit is also suitable for other repair work where fine tipped screwdrivers are required (this includes eyeglass repair). Kit contains: Ergonomic Handle Thirteen 4mm bits: PH00, PH0, PH1 SL1.5, SL2.0 Torx: T4, T6, T8, T10 JONARD P/N TK-19 TK-19 Hex1.5, Hex2.0 Pentalobe 0.8 & 1.2 2 Plastic Prying Tools Guitar Pick Opening Tool Suction Vacuum Opener SIM Eject Tool Tweezer DESCRIPTION Smartphone & Tablet Repair Tool Kit ADJUSTABLE WRENCHES WITH EXTRA WIDE JAW All wrenches are made of chrome vanadium steel with a chrome plated finish. Wrenches are forged and heat treated for greater strength. Handles are covered with a red transparent plastic for user comfort. The knurl is precision formed and the operation is smooth and trouble free. For accurate adjustments use the metric or English scales on either side of the jaws. JONARD PART NO. DESCRIPTION AW-6 AW-8 AW-10 AW-12 LENGTH JAW CAPACITY WEIGHT AW-6 Adjustable Wrench 6" 6" (152 mm) 15/16" (24mm) 5.2 oz AW-8 Adjustable Wrench 8" 8" (203mm) 1 1/8" (29mm) 10.6 oz AW-10 Adjustable Wrench 10" 10" (254mm) 1 5/16" (33mm) 14.6 oz AW-12 Adjustable Wrench 12" 12" (305 mm) 1 1/2" (38mm) 24.0 oz HOLLOW SHAFT NUT DRIVERS These are full length hollow shaft nut drivers intended for working with long bolts. They are designed with cushion gripped ergonomic color coded handles. Handles provide greater torque and user comfort. Overall length 7”. ASME Standard/YR: B107.12-2004 JONARD P/N ND-631 ND-630316 ND-63014 ND-630516 ND-6301132 ND-63038 ND-630716 ND-63012 ND-SET4 ND-631 DESCRIPTION Nut Driver Set – 7 Piece 3/16”, 1/4”, 5/16”, 11/32”, 3/8”, 7/16” & 1/2” Nut Driver 3/16” (Black) Nut Driver 1/4” (Red) Nut Driver 5/16” (Yellow) Nut Driver 11/32” (Green) Nut Driver 3/8” (Blue) Nut Driver 7/16” (Brown) Nut Driver 1/2” (Red) Nut Driver Set 4 piece, 1/2”, 11/32”,3/8”, 5/16” PANEL KNOCKOUT KIT–Patent Pending Remove panel knockouts without cutting holes in the drywall (For use on electrical, security, alarm, and datacom panels) WBK-100 36 JONARD P/N WBK-100 DESCRIPTION Panel Knockout Kit jonard.com Ӏ Wire Fishing MAGNETIC CABLE RETRIEVAL SYSTEM PATENTED A magnetic cable retrieval system which couples the cable with the pulling device through drywall, allowing the user complete control. Designed for both residential and commercial applications. MP-700 KIT INCLUDES: • Retriever Unit • 3/4” Drop Magnet with pull line • Jack Chain • Convenient Carrying Case Magnepull by Jonard Industries JONARD P/N MP-700 MP-100 MP-210 MP-220 MP-700 MP-800 DESCRIPTION Magnetic Cable Retrieval System 1/2” Drop magnet with leader 3/4” Drop Magnet with leader 3/4” Drop Magnet without leader MAGNESPOT – Intelligent Reference Point Locator Used to drill through exterior walls, drill from attics/basements into wall cavities, or drill on angles or corners. Also used to locate reference points in complicated construction and commercial buildings. Accurate to within ½” from 20” and within an inch up to 40”. Kit includes: transmitter, receiver, two 9V batteries, tack adhesive, operating instructions and carrying case JONARD P/N DESCRIPTION MP-800 Intelligent Reference Point Locator MAGNAMOLE MAGNETIC CABLE FISHING GUIDE Wire Fishing Made Easy! Quickly threads wire and cable through cavity walls and void spaces. Threads at an angle and safely through other wire and cable obstacles. Saves time, saves money, and sharply reduces the risk of accidents. MM-800 KIT INCLUDES: • 44% TIME SAVINGS Six Sigma certified • Dramatically reduces shock risk • Easy to use- No experience required • Diamond Award Winning Design JONARD P/N DESCRIPTION MM-800 MM-110 Magnamole Magnetic Cable retrieval System Replacement Magnets MM-120 Replacement Magnets • 1 magnetic rod • 2 magnetic extensions • 5 magnetic caps PATENTED MM-800 CAP COLOR & CABLE DIAMETER ACCOMMODATION USED WITH THE FOLLOWING CABLE QUANTITY (Red) .169” to .205” (Blue) .230” to .295 (White) .145” to .169” CAT5 RG6, RG6 TRI, RG6 QUAD CAT3, 3.1mm Simplex fiber Optic Cable, CAT5, CAT5e RG59, 12AWG Romex Includes 3 magnetic caps of each color Includes 2 magnetic caps of each color (Gray) .173” to .201” (Black) .205” to .232” 37 Wire Fishing TELESCOPIC POLE The RDT-18 is the perfect tool to install or retrieve a cable in drop ceilings or other hard to reach places. This Telescopic Pole is selfsupporting, so it is perfectly suited for spanning ceilings and voids to route or retrieve cable. The Jonard Industries RDT-18 Telescoping pole is constructed with a series of tapered tubes which interlock and extend a full 18 feet, collapsed length is only 33 inches. The pole is made from fiberglass with a polyester resin baked enamel coating for greater durability. The RDT-18 is considerably more rigid than rod or coil based products, and gives the installer far more control and greater accuracy over longer distances. The RDT-18 telescoping pole comes with two hooks. A conventional C type hook, an S hook to help grab and/or push cables, plus a special adapter for tight applications. RDT-18 When not in use, the RDT-18 is compact and lightweight and is easily carried using the shoulder strap. Weights 2.44 lbs. JONARD P/N RDT-18 MF-1/25 MF-4 MF-1/25 MF-75/25 MF-5/25 MF-25/25 MF-4 MF-75/25 Telescopic Pole MAGNETIC CABLE HOLDERS Made of neodymium (a rare earth magnet), these cable holders quickly and easily allow the technician to install cables without any drilling, screwing or nailing required. These powerful magnets can hold a substantial number of cables based on the size chosen. Hang wires in high places from the ground using a telescopic pole with the cable pole adapter. A Quick Easy Permanent installation that can easily be removed in seconds. JONARD P/N MF-25/25 DESCRIPTION DESCRIPTION Magnetic Cable Holder 1” (pkg. of 25) Magnetic Cable Holder 3/4” (pkg. of 25) Magnetic Cable Holder 1/2” (pkg. of 25) Magnetic Cable Holder – for Zip ties & Velcro (pkg. of 25) Cable Pole Adapter MF-5/25 GLOW ROD KIT Can extend a full 30 feet. These Rods glow in the dark to facilitate use in low lit areas. Designed to perform splinter free over the life of the product while also providing excellent flexibility. The luminescence of the rods is brighter and lasts longer than other similar products. The metal ends of the rods are glued and crimped to provide superior strength. The threads on the metal ends are standard 8-32 so the rods and accessories can be used with many other manufacturers glow rods. RDG-30 RDG-4 38 The Jonard Industries RDG-30 Glow Rod Kit includes: • Six 5 foot long Rods, 3/16" • Ball Chain attachment diameter, for greater flexibility • Wisk • Eyelet • Hook The four piece replacement kit includes the eyelet, ball chain attachment, wisk & hook. JONARD P/N DESCRIPTION RDG-30 Glow Rod Kit RDG-4 Four Piece Replacement Kit jonard.com Ӏ Wire Fishing CABLE SEWING NEEDLE-METAL Durable red anodized aluminum handle with curved notched sewing needle. Designed to harness or lace multiple lead bundles. 5 3/4” long. Replacement needles are also available. RB-287 JIC-287 JONARD P/N JIC-287 RB-287/6 DESCRIPTION Cable Sewing Needle Pkg. of 6 Replacement Needles WIRE LOOP PULLER-METAL Durable red anodized aluminum handle facilitates pulling wire through terminal blocks, rings on main frame or fanning strip holes. JIC-2257M overall length is 8 1/2” and JIC-2257M12 overall length is 15”. JIC-2257M RB-2257 JONARD P/N JIC-2257M JIC-2257M-12 RB-2257/6 DESCRIPTION Wire Loop Puller Overall Length 8 1/2” loop 4 1/2” 12” Wire Loop Puller Overall Length 15” loop 11” Pkg. of 6 Replacement Loops for JIC-2257M only WIRE LOOP PULLER- INSULATED Xylan insulated wire loop puller facilitates pulling wire through terminal blocks, rings on main frame, or fanning strip holes. The yellow plastic lightweight handle fits snugly and is easy to hold in your hand. 8” long. JIC-2257 JONARD P/N DESCRIPTION JIC-2257 Wire Loop Puller CABLE SEWING NEEDLE-INSULATED Xylan insulated cable sewing needle has a yellow lightweight molded grip handle that will harness or lace multiple lead bundles. 5 1/2” long. JONARD P/N DESCRIPTION JIC-3209 Cable Sewing Needle JIC-3209 STRAIGHT METAL NEEDLE This”Chicago type” straight metal needle is designed for cable sewing. This tool, made of the finest steel is for anyone in the cable industry. Needle is .016” thick and 12” long. JIC-284 JONARD P/N DESCRIPTION JIC-284 Straight Metal Needle COTTER PIN REMOVAL TOOL Used for removing cotter pins on automotive, materials handling, and all other types of mechanical equipment that employ cutter pin locking devices. CP-4284 JONARD P/N DESCRIPTION CP-4284 Cotter Pin Removal Tool 39 Wire & Cable Strippers ADJUSTABLE PRECISION WIRE STRIPPERS OK-3907 SERIES OK-3907 SB-2830 SB-2426 SB-2224 The OK-3907 Series is the industry’s leading cutand-strip tool for copper interconnect applications. Installers and telecom technicians enjoy its rugged construction, ergonomic plastic grips, and high-leverage handle design, which allows time savings through the simultaneous cutting of multiple wires. Blades are made from specially tempered spring steel for clean, nickfree wire stripping. JONARD P/N OK-3907-2224 Wire Size AWG mm 22-24 0.65-0.50 Adjustable Strip-Off Length Inches mm 1-1⁄2" to 1-3⁄4" 38.10 to 44.45 Replacement Blade SB-2224 OK-3907-2426 24-26 0.50-0.40 1-1⁄2" to 1-3⁄4" 38.10 to 44.45 SB-2426 OK-3907-2830 28-30 0.32-0.25 7/8” to 1 1/8” 22.22 to 28.57 SB-2830 JIC-4473* 22-24 0.65-0.50 1-1⁄2" to 1-3⁄4" 38.10 to 44.45 SB-2224 * Supplied with 2 blades, SB-2224 and SB-2426 A revolutionary concept for easy and clean stripping of wires for wire wrapping, electronic and appliance applications. Biomechanically designed for maximum efficiency. Easy to operate... place wire (up to 4) in stripping slot with ends extending beyond cutter blades... press tool and pull... wire is cut and stripped to proper “wire wrapping” length. The hardened steel cutting blades and sturdy construction of the tool ensure long life. Strip length easily adjustable for your application. Blades are made from specially tempered spring steel for clean, nick-free wire stripping. WIRE CUT-AND-STRIP TOOLS ST-100 SERIES JONARD P/N ST-100 ST-100-2426 ST-100-2830 JIC-2060 RB-2060 Replacement Blade SB-2224 SB-2426 SB-2830 CABLE RING TOOL This cable ring tool is designed to cut/strip the outer jacket (sheath) of many types of cables where the jackets are made from plastic, fabric or rubber. The tool accommodates cable diameters from 3/16" (3.1mm) to 1/2"(12.7mm) cables. It can also accommodate larger diameter cables with thinner wall jackets up to 1" (25.4mm) in diameter. Designed with a metal slide, which allows you to put more or less tension on the cable. JONARD P/N JIC-2060 RB-2060/6 RB-2060 Wire Size Adjustable Strip-Off Length AWG mm Inches mm 22-24 0.65-0.50 1 5/16” to 1 9/16” 33.33 to 39.68 24-26 0.50-0.40 1 15/16” to 1 11/16” 39.68 to 42.86 28-30 0.32-0.25 7/8” to 1 1/8” 22.22 to 28.57 DESCRIPTION Cable Ring Tool Pkg. of 6 Replacement Blades OPTICAL FIBER CABLE SHEATH STRIPPER & RING TOOL This Cable Sheath Stripper is used to ring-cut many types of tight buffer, loose tube buffer, breakout cables and other types of jacketed fiber cables. A slitting blade is built into the tool and can be used to slit open the cable sheath if needed. Depth of the cut has two adjustments for .018" or .031" thick plastic, rubber or fabric insulation, and can handle cable diameters from 1/8" to 3/8". One spare blade of each style is included with the tool. Also known as CT2860. JIC-4366 JONARD P/N RB-2878 JIC-4366 RB-2060/6 RB-2878/6 40 DESCRIPTION Optical Fiber Sheath Stripper & Ring Tool Pkg. of 6 Replacement Blades for ring feature of tool Pkg. 6 replacement blades for stripper feature of tool jonard.com Ӏ Wire & Cable Strippers PATENTED CST-1i PATENTED CYCLOPS UTP/STP CABLE STRIPPER Fast easy removal of outer insulation from all unshielded twisted pair, shielded twisted pair and multicore cables. The Cyclops features a selfadjusting blade and is perfect for PVC and plenum type insulation, plus other materials without damaging the inner braids, foils or conductors. Cable performance is not impacted using this cable stripper. JONARD P/N DESCRIPTION CST-1i Cyclops Cable Stripper ROUND CABLE STRIPPER The CST-1900 is designed for fast and precise jacket removal of PVC, rubber, PE and other jacket materials, and works well on round cables with diameters ranging from 3/16" to 1-1/8" (4.5-29 mm). This is a Triple Action Tool, cutting longitudinally for end stripping, spiral for end stripping and mid-span cuts, and circular for jacket removal. A simple versatile easy to use tool your customers will love. The Replaceable Cutting Blade is spring loaded, adjustable for various cable diameters, provides a 90° blade rotation and is designed for long life. CST-1900 CST-7915 PATENTED FOD-2000 JONARD P/N DESCRIPTION CST-1900 Round Cable Stripper CST-7915 Replaceable Cutting Blade FIBER OPTIC DROP CABLE SLITTER The FOD-2000 Fiber Optic Drop Cable Slitter is a Patented tool that simplifies the slitting of drop cable jackets at the end of the cable or midspan. Designed for .250” flat drop cable. The FOD-2000 puts a slit on both sides of the jacket allowing easy access to the fiber or strength member. The ease of use makes this tool truly unique. To use just position the tool around the cable, pull and slit. A simple solution for a vital task. The FOD2000 comes completely assembled with two blades, which can be reversed once the blades are worn. JONARD P/N FOD-2000 FOD-RB25 PATENTED DESCRIPTION Fiber Optic Drop Cable Slitter Slitter Replacement Blades 25/pk MODULAR CRIMPING TOOL This is a modular crimping/stripping connector tool for voice and data applications. Designed to cut, strip 6mm & 12 mm lengths and crimp paired conductor cables (round STP/UTP and flat satin phone cables). Crimps 4,6 & 8 position modular connectors (RJ22, RJ11, RJ12 & RJ45). UC-864 JONARD P/N DESCRIPTION UC-864 Modular Crimping tool 6 in 1 41 Wire & Cable Strippers CABLE SLIT AND RING TOOL The CSR-1575 is designed to slit and ring UTP, STP, Coax and other cables, buffer tubes and Jackets on fiber optic cables up to 7.5mm (0.3”) in diameter. The tool features an easily adjustable slit blade and ring blade for nick-free strips. The removable/ reversible V block accommodates smaller and larger diameter cables. CSR-1575 JONARD P/N DESCRIPTION CSR-1575 Cable Slit and Ring Tool CSR-2 Replacement Blades – set of 2 WIRE STRIPPER AND CUTTER The JIC-1022 Wire Stripper and Cutter is designed to strip and cut the most commonly used stranded and solid wire gauges 10 to 22 AWG and 1.6-3 mm fiber jackets. The JIC-1626 Wire Stripper and Cutter is designed for 16 to 26 AWG wire. The JIC-2030 Wire Stripper and Cutter is designed for 20-30 AWG wire. Other features include a coil spring opening to reduce fatigue, wire looping, bending holes conveniently located, black oxide finish, locking mechanism, and cutting surfaces that are hardened, tempered and ground for superior performance. 6 3/4” long and weighing just 4.5 ounces. JIC-1022 Description Wire Stripper and Cutter 10-22 AWG Wire Stripper and Cutter 16-26 AWG Wire Stripper and Cutter 20-30 AWG Part No. JIC-1022 JIC-1626 JIC-2030 ADJUSTABLE PRECISION WIRE STRIPPERS These Precision Wire Strippers feature an adjustment dial that allows the operator to select one of six different settings. A calibrated wire stop can then be adjusted for the desired insulation strip length. In a single motion, the operator squeezes and pulls the tool. This action engages four specially hardened blades to cleanly cut the wire insulation while the pulling motion breaks the insulation / conductor bond. ST-500ESD ST-500 Part No. Wire Gauge Housing Material 42 ■ Adjustable to six wire gauges: ST-450 26 to 36 AWG (0.40 to 0.12mm) ST-500 20 to 30 AWG (0.80 to 0.25mm) ST-500ESD 20 to 30 AWG (0.80 to 0.25mm) ST-550 18 to 28 AWG (1.00 to 0.30mm) ST-450 ST-500 26-36 AWG 0.40 to 0.12mm ABS 20-30 AWG 0.80 to 0.25mm ABS ■ Calibrated Wire Stop adjustable to 2” (50.8mm) ■ Clean, precise strip of any insulation type ■ Lightweight-weighs 1 oz. ■ Blade is hardened steel (RC58) ■ Dimensions 3.9” x 1.6” x 0.6” (99 mm x 42 mm x 14 mm) ST-500ESD For ESD Use 20-30 AWG 0.80 to 0.25mm ESD Safe Polycarbonate ST-550 18-28 AWG 1.00 to 0.30mm ABS jonard.com Ӏ Wire & Cable Strippers UNIVERSAL CABLE STRIPPING TOOL Use for Coax, Round Network Cables and Flat Cables - This versatile tool is five tools in one. Simply reverse the blade for RG59/6 & 7/11 Coax Cables. Insert the Round Cable into the second hole (adjustable) for a fast and easy strip. Will strip CAT6 cables with outside diameter up to 0.250". The third hole is for cutting all styles of cable while the fourth hole is designed for Flat Cable and 4P/6P style cable. The perfect wire stripper for most stripping applications. Includes Velcro strip for holding back the braided shield of the cable. UST-500 JONARD P/N UST-500 UST-525 UST-596 UST-205 UST-210 UST-215 UST-220 UST-225 UST-215 UST-205 BLADE DESCRIPTION INCLUDED Coaxial Cable Stripper (RG59/6 & 7/11) UST-205 Coaxial Cable Stripper with cable stop UST-225 Universal Cable Stripping Tool (59/6) UST-210 REPLACEMENT BLADES Repl Blade for RG59/6 & 7/11 Repl Twin Blade RG59/6 with Cable Stop. Repl Blade for RG59/6 with Cable Stop & Untwisted Pair Repl Blade for UST-175 Mini-coax only Repl Blade for RG59/6 & RG7/11 with Cable Stop UST-210 UST-225 UST-100 UST-150 COAXIAL CABLE STRIPPER TOOL The UST 100 Series strips a multitude of cables. Virtually all the blades are interchangeable with the exception of the UST-220. This blade is matched exclusively to the UST-175 handle. For replacement blades or complete tools see table above. Includes Velcro strip for holding back the braided shield of the cable. JONARD P/N UST-100 UST-125 UST-150 DESCRIPTION Coaxial Cable Stripper (RG59/6 & 7/11) Coaxial Cable Stripper with UST-225 Blade Coaxial Cable Stripper with UST-215 Blade BLADE INCLUDED UST-205 UST-225 UST-215 UST-175 Mini-Coaxial Cable Stripper UST-220 UST-1596 Coaxial Cable Stripper (59/6) w/Twin Blade UST-210 MINI-COAX CABLE STRIPPER The UST-175 is a three level coax stripper for mini-coax cables (CommScope73508, Belden 735A1 and similar cables). The mini strips 0.625” of the outer jacket in the first level, the second level strips the braid exposing 0.156” of dielectric, and the third level strips the dielectric exposing 0.156” of the 26 AWG center conductor. Includes Velcro strip for holding back the braided shield of the cable. UST-1596 UST-175 JONARD P/N DESCRIPTION UST-175 UST-220 Mini-Coax Cable Stripper Replacement Blade for the UST-175 UST-220 43 Wire Wrapping Wire UL Listed KYNAR® Insulated, Silver Plated Copper Conductor Ideally suited for wire wrapping and many other applications. OFHC (oxygen free high conductivity) provides a flexible yet abrasion resistant wire Wire Size AWG mm 24 0.50 26 0.40 28 0.32 30 0.25 Insulation Dia. In. mm .030 0.76 .027 0.69 .024 0.60 .020 0.50 Roll Size Feet Meters 100 30.4 100 30.4 100 30.4 100 30.4 1000 304.4 Blue R24B-0100 R26B-0100 R28B-0100 R30B-0100 R30B-1000 Yellow R24Y-0100 R26Y-0100 R28Y-0100 R30Y-0100 R30Y-1000 White R24W-0100 R26W-0100 R28W-0100 R30W-0100 R30W-1000 Black R24BLK-0100 R26BLK-0100 R28BLK-0100 R30BLK-0100 R30BLK-1000 Red R24R-0100 R26R-0100 R28R-0100 R30R-0100 R30R-1000 Green R30G-0100 R30G-1000 KSW Wire Wrapping Wire Rolls for Cut/Strip/Wrap Applications Low strip force Kynar® insulated silver plated copper conductor wire is further processed to provide a low strip force for use with CSW bits and sleeves. Ideally suited for wire wrapping and many other applications. OFHC (oxygen free high conductivity) provides a flexible yet abrasion resistant wire Wire Size AWG mm 24 0.50 26 0.40 28 0.32 30 0.25 Insulation Dia. In. mm .030 0.76 .027 0.69 .024 0.60 .020 0.50 Roll Size Feet Meters 100 30.4 100 30.4 100 30.4 100 30.4 1000 304.0 Blue KSW 24B-0100 KSW 26B-0100 KSW 28B-0100 KSW 30B-0100 KSW 30B-1000 Black KSW 24BLK-0100 KSW 26BLK-0100 KSW 28BLK-0100 KSW 30BLK-0100 KSW 30BLK-1000 Red KSW 24R-0100 KSW 26R-0100 KSW 28R-0100 KSW 30R-0100 KSW 30R-1000 Green KSW-30G-0100 KSW-30G-0000 Description Dispenser with 50’ of Blue wire Dispenser with 50’ of Yellow wire Dispenser with 50’ of White wire Dispenser with 50’ of Red wire Dispenser with 50’ each Blue, White and Red wire Pre-Cut and Pre-Stripped Wire Wrapping Wire WD-30-B Replacement Rolls of Wire For WD-30 Series Wire for wire-wrapping. 30 AWG (0.25mm) Kynar® wire, 50ft. (15.2m) roll, silver plated, solid conductor easy stripping. White KSW 24W-0100 KSW 26W-0100 KSW 28W-0100 KSW 30W-0100 KSW 30W-1000 Part No. WD-30-B WD-30-Y WD-30-W WD-30-R WD-30-TRI Wire Dispenser - WD-30 Series ■ With 50ft. (15.2m) Roll of 30 AWG (0.25mm) Kynar® wire-wrapping wire ■ Built-in Plunger cuts wire to desired length ■ Built-in Stripper strips 1" (25.4mm) of insulation ■ Refillable Yellow KSW 24Y-0100 KSW 26Y-0100 KSW 28Y-0100 KSW 30Y-0100 KSW 30Y-1000 R-30R-0050 ■ 50 pieces per package ■ Kynar® insulated ■ Silver plated copper conductor ■ UL listed ■ 1” of stripped wire on either end ■ Add 2” to the insulation length (see chart below) for total length of wire 30 AWG (0.25mm) Pre-Cut/Pre-Stripped Wire 50 Pieces/Pkg. Part No. R-30B-0050 R-30Y-0050 R-30W-0050 R-30R-0050 R-30-TRI 44 Description 30 AWG (0.25mm) Blue 50ft. for WD-30-B 30 AWG (0.25mm) Yellow 50ft. for WD-30-Y 30 AWG (0.25mm) White 50ft. for WD-30-W 30 AWG (0.25mm) Red 50ft. for WD-30-R 30 AWG (0.25mm) Red, White, Blue 50ft (15.2m) roll, each color for WD-30-TRI Insulation Length In. mm 1 25 2 51 3 76 5 127 White 30-W-50-010 30-W-50-020 30-W-50-030 30-W-50-050 Yellow 30-Y-50-010 30-Y-50-020 30-Y-50-030 30-Y-50-050 Blue 30-B-50-010 30-B-50-020 30-B-50-030 30-B-50-050 Red 30-R-50-010 30-R-50-020 30-R-50-030 30-R-50-050 jonard.com Ӏ Connector & Extraction Tools CONNECTOR INSERTION AND EXTRACTION TOOLS These tools service virtually all connectors conforming to Mil-C-26482, Mil-C-26500 with front release contacts made by such manufacturers as Amp, Amphenol, Bendix, Burndy, Cannon, Cinch, Continental, Elco, Flight, Pyle National and Deutsch. These tools contain strong, durable, stainless steel probes & color coded handles. KA-260 A-4598 A-4599 A-4600 JONARD MILITARY COLOR CONTACT P/N STANDARD (MS) CODE SIZE A-4598 MS24256-A20 RED 20 A-4599 MS24256-A16 BLUE 16 A-4600 MS24256-A12 YELLOW 12 KA-260 Insertion Tool Kit (contains above 3 tools) in leather case DIA 0.040” 0.063” 0.093” KR-260 R-4601 R-4602 JONARD MILITARY COLOR CONTACT P/N STANDARD (MS) CODE SIZE R-4601 MS24256-R20 RED 20 R-4602 MS24256-R16 BLUE 16 R-9461 MS24256-R12 YELLOW 12 KR-260 Removal Tool Kit (contains above 3 tools) in leather case R-9461 DIA 0.040” 0.063” 0.093” AR-910672 S-339 R-5926 PIN EXTRACTOR A plunger style pin extractor for pushing pins out from behind the connector blocks for contact sizes 16-20. 3” long. JONARD P/N R-5926 DESCRIPTION Pin Extractor LAMP EXTRACTOR Mechanical type extractor used to remove or insert miniature lamps with bayonnet type bases in panels and switchboards by firmly and gently grasping lamps. Grasp lever includes a return spring for fast lamp insertion and removal. Lamp grasp is limited to 5/16" to prevent shorts. Handle diameter 1/2”. 4” long. JONARD P/N S-339 DESCRIPTION Lamp Extractor CONTACT INSERTION-EXTRACTION TOOL A pin & socket insertion & extraction tool for contact size 20. Tool constructed of brass and ABS plastic with the red side for insertion and the white side for extraction. Mil standard M81969/1-02. For use on TE Connectivity Amplimite series HDP-20 plugs and pins and other similar manufacturers products. Use with: 215712-1 Plug 15 POS Crimp Snap 215711-1 Plug 9 POS Crimp Snap 1218266-1 Pin 18 AWG Gold Crimp 194081-1 Pin 1.04mm without Louver Band 205089-2 D-sub Pin 20-24 AWG Crimp JONARD P/N AR-910672 DESCRIPTION Contact Insertion-Extraction Tool 45 Burnishers POCKET TYPE BURNISHERS Adjustment of flexible blade-length and rigidity - is possible by varying depth in chuck. Supplied with replaceable blades stored in pen barrel at other end. Plastic barrel and cap made of sturdy plastic for dielectric work. Length 4 1/2", diameter 3/8". Blades are 3/16" Wide x 1 1/2" long. Rods are .020" diameter x 1 1/4" long. PB-3, PB-7 & PB-3R B-3R B-3 B-7 JONARD P/N PB-3 PB-3R PB-7 B-3/25 B-3R/25 B-7/25 DESCRIPTION Pen With 6 Blades .0035” Thick PB-3 plus 6 abrasive rods .020” Pen With 6 Blades, .007” thick Pkg. 25 Replacement Blades for PB-3 (.0035”) Pkg. 25 Replacement Rods for PB-3R (.020”) Pkg. 25 Replacement Blades for PB-7 (.007”) DIAMOND BURNISHERS These diamond contact burnishing spatulas consist of uniform abrasive diamond particles, set in a special metal for precise effective cleaning, polishing and burnishing with minimum pressure, so very little metal is removed. Diamond face 1” x 1/4”. Total length 6”. K-234 D-200, D-300, D-400 D-200 Coarse (grit for rapid cleaning), .019" Thick, two diamond faces, green shaft. D-300 Medium (grit for intermediate size contacts), .017" Thick, two diamond faces, red shaft. D-400 Fine (grit for small sensitive contacts), .011" Thick, single diamond face, blue shaft. JONARD P/N D-200 D-300 D-400 K-234 DESCRIPTION Diamond Burnisher Diamond Burnisher Diamond Burnisher Diamond Burnisher Coarse Medium Fine Assortment Kit K-234, Three assorted spatulas in a leather case. CONTACT BURNISHERS Plastic insulated handles for working on live contacts. Available in four styles for fine, extra sensitive, general purpose and industrial use. OB-1 OB-2 OB-3 JONARD P/N OB-1/3 OB-1/12 DESCRIPTION For Fine Contacts. Black handle 3/16” wide, .007” thick. 3” long, Package of 3 For Fine Contacts. OB-2/12 Black handle 3/16” wide, .007” thick. 3” long, Package of 12 For Extra Sensitive Points. OB-3/12 OB-4/12 OB-4 46 Blue handle. 1/4” wide, .007” thick. 3” long, Package of 12 For General Purpose Contacts. Red handle. 1/4” wide, .010” thick. 3” long, Package of 12 For Industrial Use. Green handle. 1/4” wide. .020” thick 3” long, Package of 12 jonard.com Ӏ Alignment Tools, Spring Hooks / Clip Setter Used for inserting, removing and adjusting fine springs and other small parts in tight areas. Indispensable for precision work in production and maintenance of precision products, electronics, electromechanics and even maintenance jobs. All spring hooks are tapered to a fine point. Produced of the finest quality high carbon steel with a nickel-plated finish. We will custom design Spring Hooks to meet your specific requirements. M-125 M-120 M-126 M-137 M-121 M-130/SX M-145 M-120 Pull Hook with looped handle for maximum control 6" long. M-121 Pull Hook for difficult to reach areas, 11" long. M-125 Push Hook with looped handle for maximum control 6" long. JONARD P/N M-120 M-121 M-125 DESCRIPTION Pull Hook Pull Hook Push Hook CLIP SETTER Clip Setter used for setting and withdrawing E and C clips with a inside diameter of .156” min. and thickness of .025” min. Max inside diameter of 3” and thickness of .093” One end of this tool has a hook with leaf spring tension for removing the clip. Other end of tool has leaf spring for holding clip in position to insert. Narrow shape allows access to confined places. This tool is 6 3/4" long .275" wide and 1/16" thick. JONARD P/N CS-1022 DESCRIPTION Clip Setter M-126 Push Hook for difficult to reach areas, 11" long. M-130/SX Pull Hook and lifter. With a knurled grip. 8" long. M-137 Push & Pull 2 sided Hook, 7" long. JONARD P/N M-126 M-130/SX DESCRIPTION Push Hook Pull Hook M-145 Captive Spring Hook. Spring loaded hook is exposed by depressing plunger on top of tool. Internal spring retracts hook automatically. This hook is ideal for capturing small wires, springs or parts and holding them. 7" long. JONARD P/N M-137 M-145 DESCRIPTION Push & Pull Hook Captive Spring Hook JIC-139B JIC-719A COIN LEVELING TOOL Pay telephone Tool Tool used for leveling coins in coin collectors when the coin receptacle Pay telephone Tool becomes so full as to interfere with The key is used to release the operation of the collector. May also be housing and door locking used to measure the degree of fullness mechanism of the no. 1A type coin by means of a calibrated scale and metal telephone sets 2 1/2” long. slider. 7" long. T KEY TOOL JONARD P/N JIC-719A DESCRIPTION T Key Tool JONARD P/N JIC-139B DESCRIPTION Coin Leveling Tool 47 Alignment Tools SPUDGER Plastic pencil type tool tapered to a point on one end and screwdriver tip on other end. Used to form, shape, guide, spudge and separate fine computer wire terminals, telephone wires and cables. Also used for breaking solder bridges, probing or positioning loose components. Made of a high impact non-conductive thermoplastic material. 6" long double ended 5/16" diameter. JONARD P/N AT-3112/10 AT-3767 AT-6241 AT-3112 ALIGNMENT TOOL 2-in1 nonconductive Alignment Tool 1/4" in diameter, stepped down to 5/32" in diameter. Ideal for most variable capacitors, coils and resistors. Also used to harness and separate fine wire terminals in computers, telephones and cables. Made of non-conductive thermoplastic material. 7" long. JONARD P/N AT-6241/10 DESCRIPTION Alignment Tool TRIMPOT Double ended Trimpot with a hex (allen) steel .050" and 3/32" long steel screwdriver tip. Ideal for aligning, adjusting, calibrating and fine tuning of electronic circuitry, potentiometers, oscilloscopes and electronic equipment. Made of a high impact non-conductive thermoplastic material. 5" long. JONARD P/N AT-3767/10 DESCRIPTION Trimpot DESCRIPTION Spudger AT-3767 S-389M S-389 AT-6241 Flat end JIC-22035 JIC-22035 Point end AT-3112 S-389 PROBE PICK Tough resilient yellow nylon probe “spudger”. One end is tapered to a 1/16” diameter point having an insulated “L” shaped wire hook extension. The other end tapers to a flat, 3/16” wide and 1/16” thick, with 2 small notches. Used in electrical contacts. 7” long. JONARD P/N JIC-22035 JIC-22035NT 48 DESCRIPTION Insulated Probe Pick Uninsulated Probe Pick ORANGE STICKS Static free double ended economical tool made of birch wood. Used for cleaning electrical components and separating ALIGNMENT TOOL KIT contact points, fine wires and other delicate This 5 piece pocket kit contains components. 3/16” diameter x 7” long. The a selection of the most popular S-389 has one end tapered to a point and non-conductive tools for aligning the other end to a flat screwdriver type tip. and adjusting components. The S-389M has both ends tapered with a flat screwdriver type tip. AT-3767 Trimpot, AT-6241 Alignment Tool, AT-3112 Spudger, JONARD S-389 Orange Stick, JIC-22035 P/N DESCRIPTION Probe Pick JONARD P/N DESCRIPTION TK-AT5 Alignment Tool Kit S-389/10 S-389/100 S-389M/10 S-389M/100 Orange Sticks Point & Flat end Pk. of 10 Orange Sticks Point & Flat end Pk. of 100 Orange Sticks 2 Flat ends Pk. of 10 Orange Sticks 2 Flat ends Pk. of 100 jonard.com Ӏ Force Gauges Tension, Push-Pull Gauges Jonard force gauges are all ergonomically designed and have become the industry standard for measuring force. Our 3 different lines of force gauges are used by a multitude of industries and these gauges are being used in over 1000 different applications for measuring, calibrating, standardizing, testing and evaluating. Measurement is extremely simple. Just place point of gauge arm perpendicular to the force to be measured. Reading can be taken in both directions - clockwise and counter-clockwise. Gauges offer extreme precision and durability. The measuring springs are made of hard tempered annealed beryllium copper. All gauges equipped with maximum reading pointer. Small Gauges (Flat Tip, Dial Diameter 1 1/2") JONARD PART NO. GD-1 GD-3 GD-5 GD-10 GD-15 GD-25 GD-30 GPP-1 RANGE IN GRAMS 0-10 5-35 10-50 20-100 50-150 50-250 40-350 GRADUATION IN GRAMS .20 1.00 1.00 2.00 5.00 10.00 10.00 ACCURACY + .20 – + 1 – + 1 – + 2 – + 5 – + 10 – + 10 – Large Gauges (Round Tip, Dial Diameter 2 1/2") JONARD PART NO. GD-50 GD-100 GD-200 GD-400 PUSH-PULL PRECISION TENSION GAUGE Precision, compact tubular-type mechanical force gauge slender shape permits its use in confined areas. GPP-5 is graduated in two scales: grams and ounces, GPP-1 in grams only. Precision springs are individually calibrated. Full scale accuracy and factory calibration is held to ± 1 graduation. Construction is brass with satin chrome finish. Size: 1/2" diameter x 15" long. JONARD AVOIRDUPOIS P/N CAPACITY METRIC CAPACITY GPP-1 1000 g X 50 g 1 lb X 1 oz. GRADUATION IN GRAMS 20.00 25.00 50.00 100.00 ACCURACY + 20 – + 25 – + 50 – + 100 – GPP-5 GPP-8 GPP-5 RANGE IN GRAMS 60-500 150-1000 300-2000 700-4000 500 g X 50 g GPP-72 GPP-36 GPP-15 ECONOMY PUSH-PULL TENSION GAUGES These high impact polystyrene cased instruments accurately measure push pull forces. Gauge is graduated in two scales: grams and ounces. Precision springs. Full scale accuracy is held to ± 1 graduation. Size: 11/2" wide x 1" deep x 14" long. JONARD P/N GPP-8 GPP-36 GPP-72 GPP-15 AVOIRDUPOIS CAPACITY 8 oz. x 0.25 oz 36 oz. x 0.5 oz. 72 oz. x 1 oz. 15 lb. x 4 oz. METRIC CAPACITY 220 g x 5 g 1,020 g x 20 g 2,025 g x 25 g 6,804 x 100 g 49 Wire Wrapping Overview In February 2003 Jonard Industries acquired OK Industries and merged their operation into the “Jonard Family of Companies”. Established in 1946, OK Industries blossomed as a major force in the telecommunications and electronic industries with a special proficiency in the manufacture of Wire Wrapping Tools. These same tools have continously been supplied by Jonard Tools. Wire Wrapping is a method of making a wire connection by coiling the bare wire around the sharp corners of a terminal under mechanical tension. The technology was developed as an alternative to soldering, which presents various safety and reliability problems in many applications. A principal advantage of wire wrapping is that it provides a high-reliability connection that is also easily removed to correct or modify a wiring layout. Wire wrapping subjects the wire to tremendous tension and compression forces, causing the oxide layer on both wire and terminal to be crushed or sheared, resulting in a clean, oxide-free metal-to-metal contact. A standard wrap is generally used for 24 AWG and larger diameter wires; a modified wrap is typically used for 26 AWG and smaller wires, and is used almost exclusively for 28 to 30 AWG wires. In either case, the wrap style affects only the connection’s mechanical stability; both styles provide suitable electrical connections. METAL - TO - METAL CONTACT By bending the wire around the sharp corner of the terminal, the oxide layer on both wire and terminal is crushed or sheared, and a clean, oxide-free metal-to-metal contact is obtained. A B Regular Modified TYPES OF WRAP A “Regular” bit wraps the bare wire around the terminal. A “Modified” bit wraps a portion of insulation around the terminal in addition to the bare wire.This greatly increases the ability to withstand vibration. STRIP FORCE CHART* Min. number Wire Size of turns AWG Dia. Dia. inches mm (Bare Wire) 4 16 .051 1.30 4 18 .0403 1.00 5 20 .032 0.80 5 22 .0253 0.65 6 24 .0201 0.50 7 26 .0159 0.40 7 28 .0126 0.32 7 30 .0100 0.25 Min. strip force lbs. gms 15 6800 15 6800 8 3600 8 3600 7 3200 6 2700 5 2200 3.3 1500 *Conforms to MIL-STD-1130B HOW TO MAKE WIRE WRAPPED CONNECTIONS Step 1: Bit, Sleeve and Pre-Stripped Wire Step 2: Wire Insertion Step 3: Wire Anchoring Step 4: Terminal Insertion Step 5: Finished Connection SOME HINTS ON MAKING WRAPPED CONNECTIONS DIMENSION A PIGTAIL Wire wrapping is a precision technique and the wrong bit and sleeve just cannot do the job. Improper selection can cause problems ranging from “Pigtails” to loose wraps. INSUFFICIENT TURNS It’s easy to feed wire into the slot in the OK bit correctly. Be sure the stripped end of the wire is “pushedin” all the way. TERMINAL DIAGONAL CHART 50 OPEN WRAP & SPIRAL WRAP Just keep the OK tool on the terminal until the wrap is complete. Early removal can result in spiral and open wraps. OVERWRAP Do not press too hard. Let the OK tools do the work. Excessive pressure can lead to overwrapping. prevent to "BF" Backforce overwrapping is available on most power tools and is recommended for use with 26 through 30 AWG wire. .045 .040 .035 .030 .025 .020 .015 .010 In. 1.14 1.02 0.89 0.76 0.64 0.51 0.38 0.25 mm .046 .041 .036 .032 .027 .022 .018 .014 .010 1.17 1.04 0.91 0.81 0.69 0.56 0.46 0.36 0.25 .047 .043 .038 .033 .029 .025 .021 .018 .015 1.19 1.09 0.97 0.84 0.74 0.64 0.53 0.46 0.38 .049 .045 .040 .036 .032 .028 .025 .022 .020 1.25 1.14 1.02 0.91 0.81 0.71 0.64 0.56 0.51 .050 .047 .043 .039 .035 .032 .029 .027 .025 1.27 1.19 1.09 0.99 0.89 0.81 0.74 0.69 0.64 .054 .050 .046 .042 .039 .036 .033 .032 .030 1.37 1.27 1.17 1.07 0.99 0.91 0.84 0.81 0.76 .056 .052 .049 .046 .043 .040 .038 .036 .035 1.42 1.32 1.25 1.17 1.09 1.02 0.97 0.91 0.89 .060 .056 .052 .050 .047 .045 .043 .041 .040 1.52 1.42 1.32 1.27 1.19 1.14 1.09 1.04 1.02 .063 .060 .056 .054 .050 .049 .047 .046 .045 1.60 1.52 1.42 1.37 1.27 1.25 1.19 1.17 1.14 .067 .064 .060 .058 .056 .053 .052 .051 .050 1.70 1.63 1.52 1.47 1.42 1.35 1.32 1.30 1.27 Example: If “A”=.020”. “B”=.060”. The terminal diagonal is .063" as shown on chart. DIMENSION B .050 1.27 .051 1.30 .052 1.32 .053 1.35 .056 1.42 .058 1.47 .060 1.52 .064 1.63 .067 1.70 .071 1.80 .055 1.40 .056 1.42 .057 1.45 .058 1.47 .060 1.52 .062 1.58 .064 1.63 .068 1.73 .071 1.80 .074 1.88 .060 1.52 .061 1.55 .062 1.58 .063 1.60 .065 1.65 .067 1.70 .069 1.75 .072 1.83 .074 1.88 .078 1.98 .065 1.65 .066 1.68 .067 1.70 .068 1.73 .069 1.75 .071 1.80 .073 1.85 .076 1.93 .078 1.98 .082 2.08 .070 1.78 .071 1.80 .072 1.83 .073 1.85 .074 1.88 .076 1.93 .078 1.98 .080 2.03 .083 2.11 .086 2.18 .075 1.91 .076 1.93 .077 1.96 .078 1.98 .079 2.01 .080 2.03 .082 2.08 .084 2.13 .087 2.21 .090 2.29 .080 2.03 .081 2.06 .082 2.08 .083 2.11 .084 2.13 .085 2.16 .087 2.21 .089 2.26 .091 2.31 .094 2.39 .085 2.16 .086 2.18 .087 2.21 .088 2.24 .089 2.26 .090 2.29 .091 2.31 .092 2.34 .096 2.44 .098 2.49 .090 2.29 .091 2.31 .092 2.34 .093 2.36 .094 2.39 .095 2.41 .096 2.44 .097 2.46 .101 2.57 .103 2.62 .095 2.41 .096 2.44 .097 2.46 .098 2.49 .099 2.52 .100 2.54 .101 2.57 .102 2.59 .105 2.67 .107 2.72 .100 2.54 .101 2.57 .102 2.59 .103 2.62 .104 2.64 .105 2.67 .106 2.69 .107 2.72 .109 2.77 .111 2.82 jonard.com Ӏ PTX Series Wire Wrapping The ergonomic and patented PTX series wire wrap tools are the telecom industry standard for wire wrapping needs on main distribution frames as well as local and remote installations. Its rugged construction and high speed motor make the tool suitable for electronic assembly work and many other wire wrapping applications. PATENTED PTX BATTERY POWERED WIRE W RA PPING TOOLS Part No. Description PTX PTXFL PTX-KIT1 PTX-KIT1FL PTX-KIT1DH PTX-KIT1DHFL PTX-KIT2 PTX-KIT2FL PTX-KIT2DH PTX-KIT2DHFL Battery Wrap/Unwrap Tool (Battery not included) PTX plus Flashlight Attachment 115V battery tool kit (tool, charger, (2) batteries) PTX Kit1 plus Flashlight Attachment PTX-KIT1 w/DFB224 and H-1000 PTX-KIT1DH plus Flashlight Attachment 230V battery tool kit (tool, charger, (2) batteries) PTX-KIT2 plus Flashlight Attachment PTX-KIT2 w/DFB224 and H-1000 PTX-KIT2DH plus Flashlight Attachment Weight Voltage RPM 1.1 lb 1.1 lb 3.5 lb 3.5 lb 3.6 lb 3.6 lb 3.5 lb 3.5 lb 3.6 lb 3.6 lb 3.6V* 3.6V* 3.6V* 3.6V* 3.6V* 3.6V* 3.6V* 3.6V* 3.6V* 3.6V* 3700 3700 3700 3700 3700 3700 4200 4200 4200 4200 *NiMH Battery PTX EL ECTRIC POW ERED WIRE WRAPPING TOOLS Part No. Description Weight Voltage RPM Electric Wrap/Unwrap Tool - 115V 2.0 lb 115V 3700 PTX-1FL PTX-1 plus Flashlight Attachment 2.0 lb. 115V 3700 PTX-1BF Electric Wrap/Unwrap Tool w/Backforce – 115V 2.0 lb 115V 3700 PTX-1BFFL PTX-1BF plus Flashlight Attachment 2.0 lb. 115V 3700 PTX-2 Electric Wrap/Unwrap Tool - 230V 2.2 lb 230V 4200 PTX-2FL PTX-2 plus Flashlight Attachment 2.2 lb. 230V 4200 PTX-2BF Electric Wrap/Unwrap Tool w/Backforce - 230V 2.2 lb 230V 4200 PTX-2BFFL PTX-2BF plus Flashlight Attachment 2.2 lb 230V 4200 Effective PTX-1 D FB SERIES WRA P & U NWRA P BIT & SL EEVE SETS Min. Terminal Max. Terminal Part No. Description Wire Size AWG MM Terminal Terminal Hole Diagonal IN. MM Diagonal IN. MM Hole Depth IN. MM Diameter IN. MM Radius IN. MM DFB224 Wrap/Unwrap Bit/Sleeve Set 22-24 AWG 22/24 .50/.65 .054 1.37 .073 1.85 0.50 12.70 .075 1.90 .111 2.82 DFB2426 Wrap/Unwrap Bit/Sleeve Set 24-26 AWG 24/26 .40/.50 .054 1.37 .065 1.65 0.50 12.70 .066 1.67 .098 2.48 DFB224 Consists of KB-DF224 bit, P-DF224 sleeve DFB2426 Consists of KB-DF2426 bit, P-DF2426 sleeve ACCESSORIES PTX-B PTX-BC1 PTX-BC2 H-1000 PTX-FLA DFB224 DFB2426 PTX Battery, 3.6V 115V Battery Charger 230V Battery Charger Cordura Tool Pouch Flashlight Attachment Wrap/Unwrap Bit & Sleeve Set Wrap/Unwrap Bit & Sleeve Set H-1000 PTX-BC1 PTX-B PTX-FLA DFB224 51 Manual Wire Wrapping Tools MANUAL WIRE WRAPPING ■ G200/R3278 : Lexan™ ■ G100/R3278 : Aluminum ■ G100/R3278INS : Aluminum insulated ■ G100/R3278FL Aluminum Insulated with LED Flashlight ■ Bits & Sleeves : see pages 53-54 G100/R3278 Aluminum G100/R3278FL G200/R3278 Lexan™ Also available– bits and sleeves for old style chuckless wire wrapping tools G100/R3278INS Insulated For precise reliable wraps, choose the tool you want. We offer durability with our rugged aluminum tool, G100/R3278, added protection with our insulated version, G100/R3278INS, providing 1000V of dielectric strength across most of the housing, and the same reliability, light weight plus a lower cost with our Lexan® model, G200/R3278. G100/R3278FL is the insulated version with an LED flashlight attached. These tools accommodate wire sizes from 18 AWG (1.00mm) thru 32 AWG (0.20mm). WIRE WRAPPING FLASHLIGHT KIT G100-FL Part No. G100-FL G100-FLA G100-FLA Construction Metal Plastic For Use With G100/R3278, G100/R3278INS, Universal-for use with most manual wire wrapping guns MANUAL WIRE UNWRAPPING TOOL The combination of the G100/R3394CT unwrap tool and the PUW unwrap bit & sleeve set gives you the best tool for high speed wire unwrapping. High production, long life, low maintenance. Use Unwrap Set PUW2226 for wire AWG 20 thru 26 (0.80 thru 0.40mm). G100/R3394CT ■ G100/R3394CT : Manual Wire Unwrapping Tool (See bit & sleeve listed below) Unwrap Bit Part No. 2026UB 52 Unwrap Sleeve Part No. Bit and Sleeve Set Set No. SOK2230 PUW2226 Wire Size AWG mm 20-26 0.80-0.40 Terminal Hole Diameter Inches mm .070 1.77 jonard.com Ӏ Bits & Sleeves Fully compatible with any make or model wire wrapping tool. Modified bits provide 1 1/2–2 turns of insulation. 3” BITS AND SLEEVES CHART Wire Gauge Regular 18 AWG 1.00mm 20 AWG 0.80mm ● ● 20-22 AWG 0.65-0.80mm 22 AWG 0.65mm 22 AWG 0.65mm 22-24 AWG 0.50-0.65mm 22-24 AWG 0.50-0.65mm 22-24 AWG 0.50-0.65mm 22-24 AWG 0.50-0.65mm 24 AWG 0.50mm 24 AWG 0.50mm 24 AWG 0.50mm 24-26 AWG 0.40-0.50mm 24-26 AWG 0.40-0.50mm 26 AWG 0.40mm 26 AWG 0.40mm 26 AWG 0.40mm 26 AWG 0.40mm 26 AWG 0.40mm 28 AWG 0.32mm 30 AWG 0.25mm 30-32 AWG 0.20-0.25mm 30-32 AWG 0.20-0.25mm 30-32 AWG 0.20-0.25mm ● ● ● ● Modified Bit Part No. Sleeve Part No. ● ● KB18 KB18 WB20M WB20M P194LN P194LN P194LN P194LN KB2075 KB2075 KB22 KB22 WB2275M WB2275M KB224LH KB224LH KB224-1 KB224-1 KB224 KB224 WB224M WB224M WB24DH WB24DH KB24 KB24 WB24SM* WB24SM* WB2426M WB2426M KB2466 KB2466 KB26 KB26 WB26SM* WB26SM* WB26M WB26M WB2644M* WB2644M* WB2669M WB2669M WB28SHM WB28SHM SB30MSH-B* SB30MSH-B* WB3032M* WB3032M* WB3032MIL† WB3032MIL† KB3032 KB3032 P2224 P2224 P2224 P2224 P2224 P2224 P2224 P2224 P2224 P2224 P2224 P2224 P2224 P2224 P2224 P2224 P2426 P2426 P3032LN P3032LN P2224 P2224 OK8519 OK8519 P2426 P2426 P26LN P26LN P2224 P2224 P3032LN P3032LN P2426 P2426 P3032 P3032 P3032 P3032 P3032 P3032 P3032 P3032 P3032 P3032 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● *These tools are recommended for .025" square terminals on .100” center to center of the pins Maximum Insulation Diameter Minimum Terminal Diagonal Maximum Terminal Diagonal Terminal Hole Depth Effective Radius Terminal Hole Diameter .059” 1.50mm .060” 1.52mm .042” 1.07mm .073” 1.85mm .073” 1.85mm 1.000” 25.40mm 1.000” 25.40mm .150” 3.81mm .150” 3.81mm .075” 1.90mm .075” 1.90mm .042” 1.07mm .054” 1.37mm .049” 1.24mm .061” 1.54mm .054” 1.37mm .054” 1.37mm .049” 1.24mm .054” 1.37mm .055” 1.39mm .024” 0.60mm .054” 1.37mm .054” 1.37mm .058” 1.47mm .023” 0.58mm .054” 1.37mm .024” 0.60mm .053” 1.34mm .031” 0.79mm .031” 0.79mm .034” 0.86mm .034” 0.86mm .034” 0.86mm .073” 1.85mm .073” 1.85mm .074” 1.87mm .085” 2.15mm .073” 1.85mm .073” 1.85mm .074” 1.87mm .073” 1.85mm .074” 1.87mm .043” 1.09mm .073” 1.85mm .065” 1.65mm .073” 1.85mm .038” 0.96mm .073” 1.85mm .043” 1.09mm .068” 1.72mm .035” 0.89mm .035” 0.89mm .038” 0.96mm .038” 0.96mm .038” 0.96mm 1.000” 25.40mm .750” 19.05mm 1.000” 25.40mm 1.000” 25.40mm 1.000” 25.40mm .807” 20.50mm 1.250” 31.75mm 1.750” 44.50mm .750” 19.05mm .750” 19.05mm .750” 19.05mm 1.000” 25.40mm 1.000” 25.40mm .750” 19.05mm 1.000” 25.40mm .750” 19.05mm 1.000” 25.40mm .750” 19.05mm .750” 19.05mm .750” 19.05mm .750” 19.05mm .750” 19.05mm .123” 3.12mm .117” 2.97mm .132” 3.35mm .117” 2.97mm .111” 2.82mm .111” 2.82mm .121” 3.07mm .117” 2.97mm .100” 2.54mm .098” 2.48mm .118” 2.99mm .098” 2,48mm .100” 2.54mm .075” 1.90mm .118” 2.99mm .098” 2.48mm .109” 2.77mm .066” 1.67mm .064” 1.62mm .064” 1.62mm .064” 1.62mm .064” 1.62mm .075” 1.90mm .075” 1.90mm .075” 1.90mm .086” 2.18mm .075” 1.90mm .075” 1.90mm .075” 1.90mm .075” 1.90mm .075” 1.90mm .044” 1.11mm .075” 1.90mm .066” 1.67mm .075” 1.90mm .040” 1.02mm .075” 1.90mm .044” 1.11mm .069” 1.75mm .036” 0.91mm .036” 0.91mm .040” 1.02mm .040” 1.02mm .040” 1.02mm .052” 1.32mm .050” 1.27mm .046” 1.17mm .044” 1.11mm .046” 1.17mm .031” 0.79mm .046” 1.17mm .046” 1.17mm .041” 1.04mm .030” 0.76mm .027” 0.69mm .027” 0.69mm .027” 0.69mm † Provides 2.5 turns of insulation 53 Insulated Bits & Sleeves P2224INS 3” BITS AND INSULATED SLEEVES The insulated sleeves are covered with a material that provides 1000V dielectric strength which helps to prevent shorting between pins and enhances worker safety. KB22 Bit Part No. Sleeve Part No. KB22 KB224 KB24 KB26 KB3032 P2224INS P2224INS P2426INS P2426INS P3032INS Wire Size AWG 22 22-24 26 26 30-32 Minimum Terminal Diagonal In. mm .054 1.37 .054 1.37 .055 1.39 .058 1.47 .034 0.86 Regular mm 0.65 0.50-0.65 0.50 0.40 0.32 ● ● ● ● ● Uninsulated Sleeve Wire Size Part No. AWG mm P2224-5 22 0.65 KB22-5 P2224-5INS KB24-5 P2426-5INS P2426-5 24 0.50 KB26-5 P2426-5INS P2426-5 26 0.40 Effective Radius In. .117 .111 .100 .100 .064 Terminal Hole Diameter In. mm .075 1.90 .075 1.90 .075 1.90 .075 1.90 .040 1.02 mm 2.97 2.82 2.54 2.54 1.62 These bits and sleeves are designed for wire wrapping in areas requiring deep penetration. Their 5" (127mm) length ensures “true” connections in hard-to-get-at locations. Available with or without insulation. KB24-5 Insulated Sleeve Part No. Terminal Hole Depth In. mm .750 19.05 .807 20.50 .750 19.05 1.000 25.40 0.750 19.05 5” BITS AND SLEEVES (EXTENDED LENGTH) INSULATED AND NON INSULATED SLEEVES P2426-5INS Bit Part No. Maximum Terminal Diagonal In. mm .073 1.85 .073 1.85 .074 1.87 .073 1.85 .038 0.96 ● Minimum Terminal Diagonal In. mm .054 1.37 Maximum Terminal Diagonal In. mm .073 1.85 .075 1.90 ● .055 1.39 .073 1.85 .750 19.05 .100 2.54 .075 1.90 ● .058 1.47 .073 1.85 .750 19.05 .100 2.54 .075 1.90 Regular Terminal Hole Depth In. mm .750 19.05 Effective Radius In. mm .117 2.97 Terminal Hole Diameter mm In. 3” BIT & SLEEVE SETS WITH INSULATED COLOR CODED SLEEVES Enjoy the convenience of pre-assembled sets with insulated color-coded sleeves for easy identification of wire sizes based on color. Kit Number Bit Part No. KT22B KB22 KT224B KB224 KT24Y KB24 KT26G KB26 Sleeve Part No. Color Wire Size AWG mm P2224INS 22 0.65 Blue P2224INS 22-24 0.65-0.50 Blue SW-2426 24 0.50 Yellow P2426-G-INS 26 0.40 Green Regular Modified ● Maximum Insulation Diameter In. mm – – Minimum Terminal Diagonal In. mm .054 1.37 Maximum Terminal Diagonal In. mm .073 1.85 Terminal Hole Effective Depth Radius In. mm In. mm .750 19.05 .117 2.97 Terminal Hole Diameter In. mm .075 1.90 ● – – .054 1.37 .073 1.85 .807 20.05 .111 2.82 .075 1.90 ● – – .055 1.39 .074 1.87 .750 19.05 .100 2.54 .075 1.90 ● – – .058 1.47 .073 1.85 1.000 25.40 .100 2.54 .075 1.90 WIRE WRAPPING EXTENSION ATTACHMENT Precision device which attaches easily to your manual or power wire wrapping tool for applications requiring extra “reach”. 54 Part No. EXT-400 EXT-400 Extension Inches: 4.0 mm: 100 jonard.com Ӏ Manual Wire Wrapping Kits These are complete kits for technicians working at a Main Distributing Frame or for field service where wire wrapping is required. WWK-CO Insulated Wire Wrapping Kit- designed specifically for the Central Office. JIC-2257 JIC-22035 WWK-CO UW4 KB224 P2224INS JIC-21257 Kit Contains: G100/R3278INS, Insulated Wire Wrapping Tool, KB224 bit, 22-24 AWG, P2224INS Insulated sleeve, 22-24 AWG, H-1000 Cordura Pouch, JIC-21257 Telecom long nose pliers, JIC-22035 Probe pick, UW4 Sleeved unwrapping tool, JIC-2257 Insulated wire loop puller Part No. WWK-CO P2224 WWK-1 KB224 ST-100 HW-UW-224 Description Wire Wrapping Kit, Central Office G200/R3278 Kit Contains: G200/R3278 Wire Wrapping Tool, KB224 bit 22-24 AWG, P2224 sleeve 22-24 AWG, HW-UW-224 Wrap/unwrap tool, ST-100 wire stripper 22-24 AWG, H-1000 Cordura Pouch Part No. WWK-1 UW4 WWK-1INS G100/R3278INS ST-100 KB224 P2224INS Description Wire Wrapping Kit G100/R3278INS Kit Contains: G100/R3278INS Insulated Wire Wrapping tool, KB224 bit 22-24 AWG, P2224INS Insulated sleeve 22-24 AWG, UW4 sleeved unwrapping tool 20-26 AWG, ST-100 Wire stripper 22-24 AWG, H-1000 Cordura Pouch Part No. WWK-1INS Description Insulated Wire Wrapping Kit 55 Hand Wrapping & Unwrapping Tools Type “A” HAND WRAPPING TOOLS These Hand Wrapping Tools are carefully designed to produce perfect wire wrapped connections. Precision, long-lasting tools for use where occasional wraps are required or where power wirewrapping tools are not practical. Compact and convenient. HW-30 Part No. Wire Size Reg. Mod. Type HW-20 HW-224 HW-26 HW-30* A A A ● ● ● ● AWG 20 22-24 26 30 mm 0.80 0.65-0.50 0.40 0.25 Max. Insulation Diameter Inches mm – – – – – – .027 0.69 Terminal Hole Diameter Inches mm .075 1.90 .075 1.90 .075 1.90 .036 0.91 Terminal Hole Depth Inches mm 1.000 25.40 .807 20.50 1.000 25.40 .750 19.05 Outside Diameter Inches mm .218 5.53 .218 5.53 .218 5.53 .125 3.17 *This tool is recommended for .025" (0.63mm) square terminals on .100" (2.54mm) centers Type “B” HAND UNWRAPPING TOOLS These tools are used to remove wire connections made with 20 thru 32 gauge wire. Type “C” Type “D” Part No. UW1 UW2 UW4 UW5 UW093R UWD93-93 UW2832C Type D C B B D C B Wire Size AWG mm 20-26 0.80-0.40 20-26 0.80-0.40 20-26 0.80-0.40 20-26 0.80-0.40 24-32 0.50-0.20 24-32 0.50-0.20 28-32 0.32-0.20 Type of Unwrap Left Hand Left and Right Hand Left Hand Left and Right Hand Left Hand Left and Right Hand Left and Right Hand WSU-2224 (Regular Wrap) WSU-24M (Modified Wrap) WSU-26M (Modified Wrap) WSU-30 (Regular Wrap) Terminal Hole Diameter Inches mm .070 1.77 .070 1.77 .070 1.77 .070 1.77 .038 0.96 .038 0.96 .038 0.96 Terminal Hole Depth Inches mm 1.000 25.40 1.000 25.40 2.360 60.00 2.360 60.00 1.000 25.40 1.000 25.40 .750 19.05 Outside Diameter Inches mm .156 3.96 .156 3.96 1.95 4.95 1.95 4.95 .093 2.36 .093 2.36 .156 3.96 WRAP / STRIP / UNWRAP TOOLS Each WSU tool wraps, unwraps and even strips the appropriate wire diameter with a unique built-in stripper blade. Ideal for bench use or tool kit in all service and repair applications. In addition to versatility, convenience, and reliability, the WSU Series offers exceptional value. WSU-30M (Modified Wrap) PATENTED Part No. Reg WSU-2224 WSU-24M WSU-26M WSU-30 WSU-30M Mod ● ● ● ● ● Wire Size AWG mm 22-24 24 26 30 30 0.65-0.50 0.50 0.40 0.25 0.25 Max. Insulation Diameter In. mm .036 .034 0.92 0.86 .021 0.53 Terminal Hole Diameter In. mm Terminal Hole Depth In. mm Outside Diameter In. mm Square Post In. mm .075 .075 .075 .036 .036 1.50 1.50 1.50 1.50 1.50 .213 .213 .213 .125 .125 .045 .045 .045 .025 .025 1.90 1.90 1.90 0.91 0.91 38.1 38.1 38.1 38.1 38.1 These tools are recommended for .025” (0.63mm) square terminals on .100” (2.54mm) centers 56 5.4 5.4 5.4 3.2 3.2 1.14 1.14 1.14 0.63 0.63 jonard.com Ӏ Hand Wrapping & Unwrapping Tools HAND WRAPPING AND UNWRAPPING TOOLS These Hand Wrapping and Unwrapping Tools are carefully designed to produce perfect wire wrapped connections. Precision, long-lasting tools for use where occasional wraps are required or where power wire-wrapping tools are not practical. Compact and convenient. HW-UW-224INS HAND WRAPPING AND UNWRAPPING TOOLS To switch from wire wrapping to unwrapping takes only seconds - just a quick change of the cap from one end to the other. WRAPPING SIDE JONARD Part No. Wire Size Reg Mod AWG mm Max. Insulation Diameter In. mm UNWRAPPING SIDE Terminal Hole Diameter In. mm Terminal Hole Depth In. mm Outside Wire Size Diameter In. mm AWG mm Terminal Hole Diameter In. mm Terminal Hole Depth In. mm Outside Diameter In. mm HW-UW-18-19 ● 18-19 1.00-0.91 - - .075 1.90 1.000 25.40 .250 6.35 18-19 1.00-0.91 .075 1.90 1.000 25.40 .187 4.74 HW-UW-20 ● 20 0.80 - - .075 1.90 1.000 25.40 .218 6.35 20-26 1.00-0.91 .070 1.77 1.000 25.40 .156 3.96 HW-UW-224 ● 22-24 0.65-0.50 - - .075 1.90 .807 20.50 .218 5.53 20-26 0.80-0.40 .070 1.77 1.000 25.40 .156 3.96 HW-UW-224-1 ● 22-24 0.65-0.50 - - .075 1.90 1.000 25.40 .218 5.53 20-26 0.80-0.40 .070 1.77 1.000 25.40 .156 3.96 HW-UW-2426 ● 24-26 0.50-0.40 - - .075 1.90 .750 19.05 .218 5.53 20-26 0.80-0.40 .070 1.77 1.000 25.40 .156 3.96 HW-UW-26 ● 26 0.40 - - .075 1.90 1.000 25.40 .218 5.53 20-26 0.80-0.40 .070 1.77 1.000 25.40 .156 3.96 .031 0.79 .040 1.02 .750 19.05 .125 3.17 24-32 0.50-0.20 .038 0.96 1.000 25.40 .093 2.36 0.32-0.29 .036 0.91 .040 1.02 .750 19.05 .156 3.96 24-32 0.50-0.20 .038 0.96 1.000 25.40 .093 2.36 .036 0.91 .750 19.05 .125 3.17 24-32 0.50-0.20 .038 0.96 1.000 25.40 .093 2.36 5.53 5.53 20-26 0.80-0.40 .070 20-26 0.80-0.40 .070 1.77 1.77 1.000 25.40 1.000 25.40 .156 .156 3.96 3.96 HW-UW-26SM* ● 26 HW-UW-2829M* ● 28-29 HW-UW-30* ● 30 0.40 0.25 .027 0.69 IN I NSSUUL LAT ATEEDD HHAANNDD WWRRAAPPPPI N I NGG AANNDD UUNNWWRRAAPPPPI N I NGG TTOOOOL LSS HW-UW-224INS† WDUD-26DS† ● ● 22-24 26 0.65-0.60 0.40 - - .075 .075 1.90 1.000 1.90 1.000 25.40 .218 25.40 .218 *These tools are recommended for .025" (0.63mm) square terminals on .100" (2.54mm) centers. A modified wrap provides 1.5 – 2 turns of insulation. † Insulated handle for dielectric protection. NOTE: WDUD-26DS and HW-UW-224INS have insulated handles to prevent shocks. 57 IC Insertion Extraction Tools UNIVERSAL PLCC EXTRACTION TOOL EX-5/EX-6 Features ■ Extracts a range of PLCC sizes from 20 pins through 128 pins from any socket without damage to the chip. ■ Spring loaded one-hand design requires no pulling, just squeeze handles and chip is lifted from the socket. ■ ESD safe handles for use on all static safe components (EX-5). ■ Machined stainless steel for long-life (EX-5). ■ EX-6 - ABS handles and stamped steel. EX-5 EX-6 STATIC SAFE Part No. Description EX-5 ESD safe PLCC extraction tool EX-6 PLCC extraction tool INSERTION/EXTRACTION KIT WK-7 EX-1 EX-2 MOS-1416 (.3” Pitch) MOS-40 (.6” Pitch) WK-7 kit includes DIP IC extractors and inserters to accommodate all IC’s from 8 to 40 pins. All tools are CMOS safe and include grounding lugs where appropriate except EX-1. The kit consists of extractors EX-1 for 8-24 pin devices, and EX-2 for 24-40 pin ICs, plus inserters MOS-1416, MOS-2428, and MOS-40 for 14-16, 24-28 and 36-40 pin IC’s respectively. WK-7 Kit Includes S-340 DIP/IC EXTRACTOR This is a one-piece insulated spring steel extractor used to extract LSI, MSI and SSI devices from 8 to 24 pins. Will remove all types of DIP/IC's without bending pins. 4” long. Part No. S-340 58 Description DIP/IC Extractor ■ EX-1 Extraction Tool (8-24 Pins). ■ EX-2 Extraction Tool (24-40 Pins). ■ MOS-1416 Insertion Tool (14-16 Pins). ■ MOS-40 Insertion Tool (36-40 Pins). ■ MOS-2428 Insertion Tool (24-28 Pins). Part No. Description WK-7 5 piece insertion/extraction kit Note: WK-7 items may be purchased individually. MOS-2428 (.6” Pitch) jonard.com Ӏ Fume Absorbers & Desolder Pumps HIGH-VACUUM DESOLDERING PUMPS Features A specially engineered desolder pump made to exacting specifications and providing precise repeatable operation. Fitted with a Teflon Tip with ID .125”, OD .22” and included cleaning mechanism. DP-100 and DP-200. 13” long including tip, DP-140 8” long. ■ Durable corrosion resistant plastic construction. ■ Precision metal plunger. ■ Corrosion treated springs. ■ Insulated vacuum pulse. ■ Regulated return (1 millisecond ±30%). ■ Uniform reset pressure (11in. lbs. ±20%). ■ Cushioned shock reduction (pulse release to minimize board damage). DP-200 DPT-200 DP-100 DPT-100 STATIC SAFE DP-140 Part No. DP-100 DP-200 DPT-100 DPT-200 Description High Vacuum Desoldering Pump High Vacuum Desoldering Pump, ESD Safe 1 Replacement Tip, DP-100/DP-140 1 Replacement Tip, DP-200 Part No. DP-140 DPT-100 Description Desoldering Pump 1 Replacement Tip, DP-100/DP-140 BENCHTOP F U ME A BSORBERS ■ Aerodynamic hood design effectively draws irritating soldering fumes away from the work area. ■ Carbon-impregnated filters trap a limited portion of the flux fumes. ■ Compact size, low profile and adjustable stand allows convenient placement 6" to 8" (152 to 203mm) from work area. ■ SA-9-E-115 feature static-dissipative housings. ■ Dimentions: 8 1/2” H x 8 1/4” W x 4” D ■ Articulating arm allows optimized positioning and saves bench space. SA-9-E-115 SA-9-115 Benchtop Part No. SA-9-115 SA-9-E-115 ■ Bench mounting clamp and 3 filters come complete with unit. ■ SA-91-E features a static-dissipative housing. Description Benchtop fume absorber, 115V AC with 3 filters ESD-Safe benchtop fume absorber, 115V AC with 3 filters Articulating Arm Part No. SA-91 SA-91-E SAK-90 SAF-1 Description SA-9-115 with Articulating Arm, & Bracket SA-9-E-115 with Articulating Arm, & Bracket Arm Assembly Kit Retro-fits SA-9/9-E to SA-91/SA-91-E Replacement Filter Set, 3pcs. Specifications Part No. SA-9-115 SA-91 SA-9-E-115 SA-91-E Input Voltage 115V 115V 60Hz 60Hz Maximum Air Volume 105 to 126 CFM 105 to 126 CFM Activated Carbon Wt. 12g 12g Unit Weight 2.2 lbs. (1 kg) 4 lbs. (1.8 kg) Arm Length - 24" (607mm) 59 ® M A D E F O R SINCE 1958 L I F E ® 134 Marbledale Road, Tuckahoe, NY 10707 I Tel 914.793.0700 I jonard.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Jonard Industries: G100/R3278INS DPT-100 WB26SM SA-91 G200/R3278 R26R-0100 R28R-0100 R28Y-0100 R26B-0100 R24W-0100 R28B-0100 R28W-0100 R24B-0100 R24Y-0100 R26Y-0100 R24R-0100 R26W-0100 DP-100 DP140 ID-40-25 ID-22-50 KB224 ID-8-100 ID-16-100 R28BLK-0100 ID-28-50 ID-24-50 R30BLK-0100 WB3032M P2224 MOS-2428 ID-18-50 R26BLK-0100 R30B-0100 R30R-0100 R30W-0100 R30Y-0100 SAF-1 ID-20-50 ID96-25 G100/R3278 TK-AT5 R24BLK-0100 30-W-50-020 30-Y-50-050 30-B-50-020 30-Y-50-010 30-B-50-010 30R-50-050 30-R-50-020 30-Y-50-020 30-B-50-050 30-W-50-050 30-B-50-030 30-W-50-010 30-R-50-030 30-R-50010 30-Y-50-030 30-W-50-030 EX-6 R30BLK-1000 AT-6241 BW-2600 D-200 D-300 EPB-66 EPB-KR GPP-5 HW-UW-224 HW-UW-2426 JIC-125 JIC-22035 JIC-22148 JIC-63050 KB3032 OB-1/3 OB-3/12 P2426 PTX-2BF PTX-B PTX-BC1 PTX-KIT1DH SB-2830 SW-2426 UW093R UW5 WB224M WB2275M WB2426M WB24DH WB28SHM WG-350L UC-8000 UCD-2045 UC-8012 UC-8039 UCD-2685 MM-800 MM-120 MM-110
CSR-2 价格&库存
很抱歉,暂时无法提供与“CSR-2”相匹配的价格&库存,您可以联系我们找货
