Menda - 35996 PLIERS, SCREW-O-SAURUS
Page 1 of 2
The Standard for Tools and Workbench Accessories
Multi-purpose screw removing tool
Screw remover for round, truss and pan head screws
Vertical and horizontal serrations grasp screw head with no slip
With maximum gripping power it will remove rusted, stripped or stuck screws
Spring loaded for repeated use of gripping and turning
Comfortable cushioned grip
Made in Japan
View a video demonstration here
Brand
Menda
Benefit
Part Number
35996
Product Name
Screw-O-Saurus
Spring Opening
Yes
Screw-O-Saurus works better in tight area for easy opening and re-gripping
Grip Material
Elastomer Rubber
Screw-O-Saurus Elastomer Rubber provides a better grip with more comfort than vinyl
Standard Screw Head
Capability-Front End Grip
0.374" (9.5mm) or less
Screw-O-Saurus has a wider range standard screw heads
Standard Screw Head
Capability-Side Grip
0.39" (10mm) or less
http://www.mendapump.com/MendaIndustrialCatalog/Tools/35996/
11/17/2011
Truss Head Screw Capable
Yes
Screw-O-Saurus front end grip designed with a
better angle for Truss Head Screws
Wire Cutting Capability
(copper)
0.047"(1.2mm) Diameter or
17 gauge
Screw-O-Saurus has cutter for wider use
Strap Hole in Handle
Yes
For attaching to a work belt to prevent dropping in
dangerous work areas
Page 2 of 2
3651 Walnut Ave., Chino, CA 91710
Phone: (909) 627-2453 Fax: (951) 755-8848
Site Map | Terms & Conditions | Privacy Policy | Affiliated Brands
Copyright © 2011 Desco Industries, Inc. All rights reserved.
11/17/2011
很抱歉,暂时无法提供与“35996”相匹配的价格&库存,您可以联系我们找货
