D213-9NETT
D213-9NETT
    KLEINTOOLS
    PLIERSCOMBOFLATNOSE9.38"
D213-9NETT 数据手册
ESSENTIAL TOOLS TO KEEP THE JOB SITE SAFE AND PRODUCTIVE WORK@HEIGHT T O O L S In private industry, falling objects accounted for 10% of worker fatalities in 2013. In 2012, falling objects caused 18% of contractor deaths, a 7% increase from 2011. OSHA ranks being “struck by objects” as the third leading cause of disabling workplace injuries. Klein Tools’ growing line of tethers and tools for Work@Height are designed to protect workers on the job site as well as their tools. Tool Tethers Triple-locking carabiner for additional safety • Keep your tools close at hand while working at height • Allow for easy tool recovery in case of accidental drops Always use choke hitch formation Attach tether through tether hole when available Always use a load bearing anchor or attachment point Cat. No. UPC Code 0-92644- Maximum Load Capacity Relaxed Length Stretched Length TT1 46000-5 10 lbs (4.5 kg) 32" (813 mm) 60" (1.5 m) TT2 59006-1 15 lbs (4.5 kg) 32" (813 mm) 51" (1.3 m) WARNINGS: • Inspect for wear before each use. • Do not use for human support. • Never connect over 5 lbs. (2.3 kg) to a person. • Do not use around moving or rotating equipment. WARNINGS: • Tethers extend to anywhere from 3.5' to 5' (1.3 m to 1.5 m). Rig to avoid contact with objects below. • Always ensure cinch remains snug while in use. • Always attach carabiner end to anchor point. • Do not attach tether back onto itself. • Do not tie knots in tether. TT2 TT1 36" (914 mm) Round Bar • Forged fit-up bar is pointed on one end for aligning bolt holes • 15° angle chisel-end provides greater leverage Cat. No. 3246TT UPC Code 0-92644+ 66000-9 Diameter Length 7/8" (22 mm) 36" (914 mm) 3246TT Tether hole Provides extra leverage when positioning steel members and aligning bolt holes Split ring for tethering D228-8TT D248-9STT D213-9NETT D213-9STT D201-7CSTT Pliers with Tether Ring • High-leverage designs. Rivet is closer to the cutting edge for greater cutting power than other plier designs • Angled head design of the diagonal-cutting pliers allow for easy work in confined spaces • Side-cutting pliers feature a streamlined design with sure-gripping, cross-hatched knurled jaws • Cat. No. D248-9STT, D213-9STT and D201-7CSTT feature a hook-bend in the handle for added grip and leverage. Unique handle tempering helps absorb the “snap” when cutting wire. UPC Code 0-92644+ Cat. No. Nose Type Jaw Length Jaw Thickness Jaw Width Knife Length Overall Length High-Leverage Diagonal-Cutting Pliers D228-8TT 72037-6 — 13/16" (21 mm) 7/16" (11 mm) 1-3/16" (30 mm) — 8-1/16" (205 mm) D248-9STT 72049-9 — 13/16" (21 mm) 7/16" (11 mm) 1-3/16" (30 mm) — 9-3/16" (233 mm) High-Leverage Side-Cutting Pliers D213-9NETT 70104-7 New England 1-19/32" (41 mm) 5/8" (16 mm) 1-1/4" (32 mm) 25/32" (20 mm) 9-3/8" (238 mm) D213-9STT 70087-3 Square 1-9/32" (33 mm) 5/8" (16 mm) 1-1/4" (32 mm) 25/32" (20 mm) 9-1/8" (232 mm) D201-7CSTT 70102-3 Square 1-9/32" (33 mm) 1/2" (13 mm) 1-5/32" (29 mm) 5/8" (16 mm) 9-1/4" (235 mm) Headlamp Anti-slip silicone strap keeps headlamp securely • 150 150 fastened to hard hat Lumens Lumens 6h 6h • Strap comes pre-adjusted for quick fit to hard hat • 45-degree tilt for varied beam direction to point light where it is needed most 50 50 Code Lumens 10h 10h Lumens LumensUPC 0-92644- Run Time Drop Height Batteries 56220 6 hrs / 10 hrs 6 ft. 3xAAA Cat. No 66ftft 56220-4 150 / 50 FL 1 STANDARD Spotlight Two Modes: 150 Lumens Floodlight FL 1 STANDARD 150 Lumens 6h 50 Lumens 10h Impact and water resistant 6h FL 1 STANDARD 50 Lumens 6 ft 10h Erection Wrenches with Tether Hole Tether hole • Forged from select alloy steel to withstand high-leverage and heavy loads • Continuous taper of handle makes lining-up bolt holes easy and works on a range of bolt-hole sizes without binding • Extra-large hub area works on larger diameter holes better than other wrenches • Catalog number, bolt size and nominal opening size are stamped on every wrench for easy identification Cat. No Bolt Size Nominal Opening 3/4" (19 mm) 1-1/4" (32 mm) Head Width 3212TT UPC Code Nut Type 0-9264468071-7 U.S. Heavy 3213TT 68069-4 U.S. Heavy 7/8" (22 mm) 1-7/16" (37 mm) 3214TT 68070-0 U.S. Heavy 1" (25 mm) 3-5/8" (92 mm) 1-1/8" to 1/4" (29 mm to 6 mm) 1-5/8" (41 mm) Taper Diameter Length 2-1/2" (64 mm) 1" to 1/4" (25 mm to 6 mm) 16-5/8" (422 mm) 3" (76 mm) 1-1/8" to 9/32" (29 mm to 7 mm) 17-3/4" (451 mm) 3212TT 18" (457mm) Adjustable Head Wrenches with Tether Hole • Each wrench fits a variety of sizes of nuts and bolts • Forged from select alloy steel • Continuous-taper handle to help align bolt and rivet holes • Industrial black finish for corrosion resistance • Lanyard hole for easy tool tethering Tether hole Cat. No UPC Code 0-92644- Description Maximum Size Capacity Length 3227 67017-6 10" (254 mm) Spud Wrench 1-5/16" (33 mm) 11" (279 mm) 3239 67095-4 16" (406 mm) Construction Wrench 1-1/2" (38 mm) 16" (406 mm) 3227 Bull-Pins with Tether Hole Tether hole • Broad-head design provides larger striking surface and reduces • • chance of slipping from the hand when aligning holes Machined from quality alloy steel that is heat-treated for strength Rust resistant Cat. No. 3255TT 3256TT UPC Code 0-92644+ 48001-0 48002-7 Material Length Point Diameter Top Diameter Steel Steel 13-3/4" (349 mm) 10" (254 mm) 5/16" (8 mm) 1/4" (6 mm) 1-1/4" (32 mm) 1-1/16" (27 mm) Bull-Pin and Bolt Bags Tether anchor points • Bull pin loops on each side for easy access • Double bottom provides additional strength • Cat. No. 5416OCTO has two D-rings on the front of the pouch • 3255TT and four on the inside for plenty of space to connect tethers Cat. No. 5416TC and 5416TCP have drawstring closure on top Cat. No UPC Code 0-92644- Belt Capacity Belt Length Connection Width Depth 5416OCTO 55387-5 up to 3" (76 mm) wide loop 5" (127 mm) 9" (229 mm) 9" (229 mm) 5416TC 55229-8 up to 3" (76 mm) wide tunnel 5" (127 mm) 9" (229 mm) 10" (254 mm) 5416TCP 20017-5 up to 3" (76 mm) wide tunnel 5" (127 mm) 9" (229 mm) 12" (305 mm) 5416OCTO 5416TCP Load Rated Bucket with Connection Points • Six small D-rings sewn to the interior of the bucket • • • • 100 lbs. (45kg) provide secure connection points for tethers Extra large hook to fit onto oversized rigging equipment Leather reinforced bottom Made of heavy-duty canvas to withstand harsh job site conditions Features web straps extending down the side for additional strength Cat. No UPC Code 0-92644- Height Diameter 5104OCTO 61000-4 17" (432 mm) 12" (305 mm) 5104OCTO Load Rated Top Closing Canvas Buckets • Made of heavy-duty canvas to withstand harsh job site conditions • Leather reinforced bottom extends 3" (76 mm) up the side • Durable top ring maintains bucket shape • 5104CLR17 and 5104CLR22 feature web straps extending down the side for additional strength Cat. No. UPC Code 0-92644- Load Rating Top Closure Diameter Height 5104CLR17 62017-1 150 lbs. (68 kg) zipper 14" (356 mm) 17" (439 mm) 5104CLR22 62016-4 150 lbs. (68 kg) zipper 5104VT 55285-4 100 lbs. (45 kg) VELCRO 14" (356 mm) 22" (559 mm) ® 12" (305 mm) 17" (432 mm) VELCRO® is a registered trademark of Velcro Industries B.V. WARNINGS: Completely close top before each use. 14" diameter accommodates standard 5 gallon bucket. 5104CLR17 5104CLR22 5104VT Vinyl Bucket Top • Compatible with Klein Tools 5104 and 5109 series buckets • Attaches with Velcro • Includes safety strap loop to ensure connection to bucket • Bucket not included 51TOP ® Cat. No UPC Code 0-92644- Height Diameter 51TOP 61000-4 3.5" (89 mm) 12.5" (318 mm) VELCRO® is a registered trademark of Velcro Industries B.V. Flame-Retardant Storage • Provides added protection when welding and grinding in the field • Pouches meet the performance requirements of NFPA-701 Cat. No. UPC Code Belt 0-92644+ Capacity #4 Flame-Retardant Canvas Bolt Bag 5416TFR 55529-9 up to 3" (76 mm) wide Cat. No. UPC Code Back 0-92644+ Depth #4 Flame-Retardant Electrode Bag 5471FR 55530-5 15-1/2" (394 mm) Belt Connection Length Width Tunnel Diameter 5" (127 mm) Front Depth 9" (229 mm) Width 2-1/2" (64 mm) 12" (305 mm) N/A 5416TFR 5471FR Heavy-Duty Torpedo Level with Tether Ring • Powerful rare-earth magnets,10x stronger than strip magnets, hold firmly to iron and steel surfaces Strong split ring for tethering • Three acrylic vials – plumb, level and 45° provide the necessary jobsite measurements • Top read level window simplifies viewing in tight areas Cat. No. 931-9RETT UPC Code 0-92644+ 93000-3 Overall Length 9" (229 mm) 931-9RETT Tape Measure Holder with Tether Ring • Elastic bottom and hook-and-loop closure ensure this holder will fit most 25' and 30' tape measures securely • Includes D-ring on top for tethering • Reinforced stitching to add strength Cat. No UPC Code 0-92644- Overall Size 5195TT 55537-4 3" x 3.5" x 2" (76 mm x 89 mm x 50 mm) 5195TT See our complete line of Work@Height Tools & Accessories www.kleintools.com/workatheight © 2016 Klein Tools, Inc. Lincolnshire, IL 60069-1418 96429 03/16 Rev. B
D213-9NETT 价格&库存
很抱歉,暂时无法提供与“D213-9NETT”相匹配的价格&库存,您可以联系我们找货
