32617
32617
    WIHA(威汉)
    PLIERS LONG NOSE STRAIGHT 6.3"
32617 数据手册
www.wihatools.com 13 Bent Long Nose Pliers With Cutters Long Nose Pliers With Return Spring Angled 40 O 326 Bent Long Nose Pliers With Cutters DIN ISO 5745 Long nose pliers angled 40O. Extra long cutters for flat and round wire. Partially Serrated Jaws. Cutting edges additionally induction hardened to approx. 64HRC. Special C70 tool steel forgings. Soft vinyl grips are oil & solvent resistant. Item No. 32623 32625 Cutting Capacity Copper AWG mm Inch 160 6.3 #10 200 8.0 #8 Pkg. lbs. 1 .28 1 .96 32617 Long Nose Pliers With Cutters DIN ISO 5745 Long nose pliers. Extra long cutters for flat and round cables. Serrated Jaws. Cutting edges additionally induction hardened to approx. 64HRC. Special C70 tool steel forgings. Soft vinyl grips are oil & solvent resistant. Item No. 32617 Item No. 32630 mm 160 Inch Pkg. lbs. 6.3 1 .26 32645 Stripping Pliers DIN ISO 5744 Heavy duty forged with induction hardened cutting edges for even stripping of insulation. Easy to use adjusting screw allows the stripping diameter to be set. Opening spring for effortless and sensitive handling of pliers. C70 special tool steel. 64HRC cutting edges. For Stripping up to Ø 5mm/#4 AWG conductor cross-section. Soft vinyl grips. Item No. 32645 Long Round Nose Pliers 32633 Long Round Nose Pliers DIN ISO 5745 Extra long head. Serrated Jaws are induction hardened. Special C70 tool steel forgings. Use for gripping and uniform round bending of wires and sheet metal parts. Soft vinyl grips are oil & solvent resistant. Item No. 32633 mm 160 Inch 6.3 Pkg. 1 lbs. .25 Pkg. lbs. 1 .22 Stripping Pliers Long Flat Nose Pliers 32630 Long Flat Nose Pliers DIN ISO 5745 Extra long head. Serrated Jaws are induction hardened. Special C70 tool steel forgings. Use for gripping and right-angled bending of wires and sheet metal parts. Soft vinyl grips are oil & solvent resistant. Cutting Capacity Copper AWG mm Inch 160 6.3 #12 Stripping Capacity Copper Awg# mm Inch 160 6.3 #8 - #28 Pkg. lbs. 1 .31 Proturn Stripping Pliers 57872 Proturn Stripping Pliers Wide long head with ridged gripping surface, shears blade and firm wire stripping stations. With opening spring and locking mechanism. Wire stripping stations 0.81 / 1.0 / 1.3 / 1.6 / 2.0 / 2.59mm, AWG 20 / 18 / 16 / 14 / 12 / 10. #57872 mm Inch Ø AWG Pkg. lbs. 180 7.0 0.81-2.59 20-10 1 .124 www.wihatools.com Diagonal Cutters 15 Flush Cutting Diagonal Cutters • Flush cutting, with return spring Diagonal Cutters DIN ISO 5749 326 Low wear lap joint, riveted and able to withstand high levels of load. Low force cutting action, clean cutting. Long life edge is achieved through additional induction hardening to approx. 64HRC. Special C70 tool steel hardened and tempered. For soft & medium hard wire. Soft vinyl grips. Item No. 32638 32642 32639 Cutting Capacity mm 140 160 180 Inch Copper AWG 5.5 #6 6.3 #6 7.0 #6 Pkg. lbs. 1 .33 1 .49 1 .54 High Leverage Cutters High Leverage Cutters DIN ISO 5749 326 Semi-circular. Low wear lap joint, riveted and able to withstand high levels of load. Low force action, clean cutting. Long life is achieved through additional induction hardening of cutting edge to 64HRC. C70 special tool steel hardened and tempered. Soft vinyl grips. Item No. 32646 32649 32652 Cutting Capacity mm 160 180 200 Copper AWG Inch 6.3 #6 7.0 #5 8.0 #4 Pkg. lbs. 1 .42 1 .50 1 .63 Cable Cutters 326 Flush Cutting Diagonal Cutters With Return Spring For Cutting Plastic DIN ISO 5749 Low wear lap joint, riveted and able to withstand high levels of load. Lightweight action, clean cutting. Long life edge is achieved through additional induction hardening to approx. 64HRC. Special C70 tool steel hardened and tempered. For cutting plastic tie wraps & injection mold components. Soft vinyl grips. Item No. 32607 32614 mm Inch Pkg. lbs. 127 5.0 1 .14 160 6.3 1 .36 Flush Cutting Mechanic’s Diagonal Cutters • Flush cutting, with return spring 326 Flush Cutting Mechanic’s Diagonal Cutters With Return Spring For Cutting Plastic DIN ISO 5749 Low wear lap joint, riveted and able to withstand high levels of load. Lightweight action, clean cutting. Long life edge is achieved through additional induction hardening to approx. 64HRC. Special C70 tool steel hardened and tempered. For flush cutting soft and semi-hard wires. Soft vinyl grips. Item No. 32613 Cutting Capacity mm 127 Copper AWG Inch 5.0 #12 Pkg. lbs. 1 .16 Soft Grip BiCut SuperCut Cutting capacity up to 2mm (.080”) Spring Wire 64HRC cutting edges Cable Cutters Light, energy-saving & clean cutting with 326 specially ground precision cutting edges. Long life is achieved through additional induction hardening of cutting edge to 64HRC. C70 special tool steel hardened and tempered. Soft vinyl grips. For cutting of copper & aluminum cables without crushing, also suitable for stripping. Not for steel cable, wires and copper conductors with hard coatings. Item Cutting Capacity Copper/Aluminum No. mm Inch Pkg. lbs. 32600 160 6.3 16mm 1 .34 32602 200 7.9 20mm 1 .62 · Double the power at the press of a button · BiCut does the job of two pairs of pliers · Up to 50% less hand strength required for cutting · Cutting force doubled for extremely hard materials · Easily switch between two strengths in one-handed operation 32636 Soft Grip BiCut SuperCut For cutting various materials from soft to extremely hard, such as nails, screws, bolts, wire cables, spring wires, chains, etc. Item No. mm Inch 32636 200 8.0 Pkg. lbs. 1 .72
32617 价格&库存
很抱歉,暂时无法提供与“32617”相匹配的价格&库存,您可以联系我们找货
