808-16
    KLEINTOOLS
    HAMMERCLAWFIBERGLASS
808-16 数据手册
Hammers, Chisels & Punches Klein hammers, chisels and punches are designed and created to strike through jobsite challenges. Engineered with the professional in mind, each tool is job-matched to fit the task at hand. Hammers, Chisels & Punches Hammers Electrician's Straight-Claw Hammer plastic-alloy jacketing helps to protect neck from fraying and • Durable splintering if incorrectly struck or overstruck • High-strength fiberglass shaft absorbs shock and keeps head tight • Comfortable, perforated neoprene grip bonded to handle neck and narrow striking face are ideal for reaching into outlet • Extra-long boxes and other tight areas • Balanced and designed specifically for use in electrical work Cat. No. 807-18 Head Weight 18.0 oz. (510 g) Overall Length 15" (381.0 mm) 807-18 Weight 1.9 lbs. (0.86 kg) Straight-Claw Hammers-Heavy-Duty plastic-alloy jacketing helps to protect neck from fraying and • Durable splintering if incorrectly struck or overstruck • High-strength fiberglass shaft absorbs shock and keeps head tight • Comfortable, perforated neoprene grip bonded to handle • Straight-claw design for easy nail pulling in tight quarters 808-16 Cat. No. 808-16 808-20 Head Weight 16.0 oz. (454 g) 20.0 oz. (567 g) Overall Length 13" (330.2 mm) 14" (355.6 mm) Weight 1.9 lbs. (0.86 kg) 2.0 lbs. (0.91 kg) Curved-Claw Hammers-Heavy-Duty plastic-alloy jacketing helps to protect neck from fraying and • Durable splintering if incorrectly struck or overstruck • High-strength fiberglass shaft absorbs shock and keeps head tight • Comfortable, perforated neoprene grip bonded to handle • Curved claw gives maximum nail-pulling leverage Cat. No. 818-16 818-20 Head Weight 16.0 oz. (454 g) 20.0 oz. (567 g) Overall Length 13" (330.2 mm) 14" (355.6 mm) 818-16 Weight 1.9 lbs. (0.86 kg) 2.0 lbs. (0.91 kg) Lineman's Straight-Claw Hammer • Heavy-duty, double-duty hammer drives lags and pulls large nails high-carbon steel head with solid, octagon-shaped driving • Special end and thick, strong claw • Straight-grain hickory handle, lacquered to withstand weather Cat. No. 832-32 Head Weight 32.0 oz. (907 g) Overall Length 15" (381.0 mm) Weight 2.5 lbs. (1.13 kg) See page 310 for additional information on warnings. For Sledge, Brass, Copper + Normalized Hammers, see Mining Tools section 832-32 293 www.kleintools.com Hammers, Chisels & Punches Hammers Ball-Peen Hammers • Forged high-carbon steel head is hardened for additional durability • Crowned face with uniform bevel • Smoothly rounded peen • Straight-grain hickory handle is stained and lacquered to withstand weather Cat. No. 803-8 803-12 803-16 803-24 803-32 Head Weight 8.0 oz. (227 g) 12.0 oz. (340 g) 16.0 oz. (454 g) 24.0 oz. (680 g) 32.0 oz. (907 g) Overall Length 11-1/2" (292.1 mm) 12-1/2" (317.5 mm) 13-1/2" (342.9 mm) 15" (381.0 mm) 15" (381.0 mm) 803-12 Weight 12.0 oz. (340 g) 1.1 lbs. (0.50 kg) 1.4 lbs. (0.64 kg) 1.9 lbs. (0.86 kg) 2.5 lbs. (1.13 kg) Hand-Drilling Hammer • Extra-heavy, forged steel head, hardened and tempered • Short handle for working in close quarters • Select hickory handle, triple-wedged and lacquered to withstand weather handle treatment removes handle moisture and replaces it with oil to • Special help eliminate the effects of extreme temperatures Cat. No. 823-48 Head Weight 48 oz. (1361 g) Overall Length 10" (254.0 mm) 823-48 Weight 3.3 lbs. (1.50 kg) Lineman's Double-Face Hammer • Designed for pole-line work • Rugged and well-balanced, with the weight to drive lag bolts • Faces with 1-3/4" (44 mm) round-crown driving surface and beveled edges No. 809-36MF has one milled face for driving staples used in pole-line • Cat. work and common, unhardened nails tempered-steel head is only 3-3/4" (95 mm) long for use in tight • Forged, areas Cat. No. 809-36 809-36MF Head Weight 36 oz. (1021 g) 36 oz. (1021 g) Overall Length 14" (355.6 mm) 14" (355.6 mm) Weight 2.5 lbs. (1.13 kg) 2.5 lbs. (1.13 kg) 809-36 809-36 both sides 809-36MF one side Non-Sparking Hammers • Non-sparking, non-marring brass-head hammers • Fiberglass handle includes TPR overmold for extra comfort and shock absorption. • Built-in overstrike protector absorbs shock and vibration when overstrike occurs • Large sweep at base prevents loss of grip • Head is securely epoxied to prevent detachment • Does not contain beryllium Cat. No. 819-03 819-04 Head Weight 3.0 lbs. (1.36 kg) 4.0 lbs. (1.81 kg) 294 www.kleintools.com Overall Length 15-3/4" (400.1 mm) 16" (406.4 mm) 819-03 Weight 3.1 lbs. (1.41 kg) 4.1 lbs. (1.86 kg) See page 310 for additional information on warnings. For Sledge, Brass, Copper + Normalized Hammers, see Mining Tools section Hammers, Chisels & Punches Hammers Setting Hammer epoxy resin handle helps to protect neck from fraying and • Durable splintering if incorrectly struck or over struck • High-strength fiberglass shaft absorbs shock and keeps head tight • Cushioned, PVC grip bonded to handle high-carbon steel, octagon shaped head with flat striking • Special surface and rounded cross peen Cat. No. 820-16 Head Weight 16.0 oz. (454 g) Overall Length 13" (330.2 mm) 820-16 Weight 1.6 lbs. (0.73 kg) Riveting Hammer • High-carbon steel round head is forged and hardened • Flat striking surface with rounded cross peen • Straight-grain American hickory handle is stained and lacquered Cat. No. 821-12 Head Weight 12.0 oz. (340 g) Overall Length 12-1/4" (311.2 mm) Weight 1.1 lbs. (0.50 kg) 821-12 Dead Blow Hammers • Durable, abrasion resistant non-marring hammer face • Increased striking force with zero impact rebound • Design isolates user from striking impact and reduces fatigue • 40% more driving power than other dead blow hammers • Protects job surface from damage HVAC, metal fabrication, electronics, oil and mining, wood and • Applications: metal assembly, automotive, aerospace struck, the shot directs the striking power and increases the impact, • When creating a dead blow effect. The reduced rebound upon impact transfers full 811-16 energy of the blow to the object being struck. Cat. No. 811-16 811-32 Head Weight 16.0 oz. (454 g) 32.0 oz. (907 g) Overall Length 12-1/2" (317.5 mm) 18" (457.2 mm) Weight 1.4 lbs. (0.64 kg) 1.8 lbs. (0.82 kg) Chisels Cold Chisels high-carbon steel for • Heat-treated, necessary hardness and durability • Cuts, shapes and removes metal • Corrosion-resistant black finish Cat. No. 66140 66142 66143 66144 66145 66146 Blade Width 3/8" (9.5 mm) 1/2" (12.7 mm) 5/8" (15.9 mm) 3/4" (19.1 mm) 7/8" (22.2 mm) 1" (25.4 mm) Cold Chisels-Long-Length 66142 66177 Overall Length 5" (127.0 mm) 6" (152.4 mm) 6-1/2" (165.1 mm) 7-1/2" (190.5 mm) 8" (203.2 mm) 8-1/2" (215.9 mm) Weight 1.6 oz. (45 g) 3.2 oz. (91 g) 5.6 oz. (159 g) 9.6 oz. (272 g) 13.6 oz. (386 g) 20.8 oz. (590 g) • Heat-treated, high-carbon steel for necessary hardness and durability • Cuts, shapes and removes metal • Accurately ground edge and long length work better in hard-to-reach areas • Corrosion-resistant black finish Cat. No. 66174 66177 66183 See page 310 for additional information on warnings. For Sledge, Brass, Copper + Normalized Hammers, see Mining Tools section Blade Width 1/2" (12.7 mm) 3/4" (19.1 mm) 1" (25.4 mm) Overall Length 12" (304.8 mm) 12" (304.8 mm) 12" (304.8 mm) Weight 6.4 oz. (181 g) 1.1 lbs. (0.50 kg) 2.1 lbs. (0.95 kg) 295 www.kleintools.com Hammers, Chisels & Punches Chisels Electrician's Chisel • One-piece handle and blade forged of strong alloy steel • Corrosion-resistant black finish extends to the polished blade edge 66100 Cat. No. 66100 Blade Width 2-3/4" (69.9 mm) Overall Length 8" (203.2 mm) Weight 1.1 lbs. (0.50 kg) Punches Drift Punches • High-carbon steel for durability • Rugged design for impact strength • Strong, heat-treated points are smooth and precision tapered • Corrosion-resistant black finish Cat. No. 66340 66342 66343 66344 Point Diameter 0.125" (3.18 mm) 0.188" (4.76 mm) 1/4" (6.4 mm) 0.313" (7.9 mm) 66343 Taper 4-1/4" (108.0 mm) 5" (127.0 mm) 5-1/2" (139.7 mm) 5-1/2" (139.7 mm) Overall Length 8" (203.2 mm) 9" (228.6 mm) 11" (279.4 mm) 11" (279.4 mm) Weight 3.2 oz. (91 g) 5.6 oz. (159 g) 12.0 oz. (340 g) 12.0 oz. (340 g) Center Punches • High-carbon steel for durability • Rugged design for impact strength • Smooth-ground points heat-treated to stay sharp and true longer • Corrosion-resistant black finish Cat. No. 66310 66311 66312 66313 Shank Diameter 1/4" (6.4 mm) 5/16" (7.9 mm) 3/8" 1/2" (12.7 mm) 66313 Overall Length 4-1/4" (108.0 mm) 4-1/2" (114.3 mm) 5" (127.0 mm) 6" (152.4 mm) Weight 0.8 oz (23 g) 1.6 oz. (45 g) 1.6 oz. (45 g) 4.0 oz. (113 g) Pin Punches • High-carbon steel for durability • Precision-ground shank • Heat-treated for added strength and hardness at working end • Corrosion-resistant black finish Cat. No. 66320 66321 66322 66323 66324 66325 296 www.kleintools.com Point Diameter .063" (1.59 mm) .094" (2.4 mm) 0.125" (3.18 mm) 0.156" (3.97 mm) 0.188" (4.76 mm) 1/4" (6.4 mm) 66324 Overall Length 4-1/4" (108.0 mm) 4-3/4" (120.7 mm) 5" (127.0 mm) 5-1/4" (133.4 mm) 5-1/2" (139.7 mm) 7" (177.8 mm) Weight 0.8 oz (23 g) 1.6 oz. (45 g) 1.6 oz. (45 g) 1.6 oz. (45 g) 1.6 oz. (45 g) 3.2 oz. (91 g) See page 310 for additional information on warnings. For Sledge, Brass, Copper + Normalized Hammers, see Mining Tools section
808-16 价格&库存
很抱歉,暂时无法提供与“808-16”相匹配的价格&库存,您可以联系我们找货
  • 1+447.745811+55.95019
库存:1
